{"name":"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","description":"","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja","home":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja","gmt_offset":9,"timezone_string":"Asia\/Tokyo","page_for_posts":0,"page_on_front":1610,"show_on_front":"page","namespaces":["oembed\/1.0","redirection\/v1","wordfence\/v1","yoast\/v1","wp-super-cache\/v1","elementor-one\/v1","ai1wm\/v1","daext-helpful\/v1","elementor\/v1\/documents","elementor\/v1","elementor-ai\/v1","elementor\/v1\/feedback","wp\/v2","wp-site-health\/v1","wp-block-editor\/v1","wp-abilities\/v1"],"authentication":[],"routes":{"\/":{"namespace":"","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/"}]}},"\/batch\/v1":{"namespace":"","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"validation":{"type":"string","enum":["require-all-validate","normal"],"default":"normal","required":false},"requests":{"type":"array","maxItems":25,"items":{"type":"object","properties":{"method":{"type":"string","enum":["POST","PUT","PATCH","DELETE"],"default":"POST"},"path":{"type":"string","required":true},"body":{"type":"object","properties":[],"additionalProperties":true},"headers":{"type":"object","properties":[],"additionalProperties":{"type":["string","array"],"items":{"type":"string"}}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/batch\/v1"}]}},"\/oembed\/1.0":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"oembed\/1.0","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/oembed\/1.0"}]}},"\/oembed\/1.0\/embed":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"oEmbed \u30c7\u30fc\u30bf\u3092\u53d6\u5f97\u3059\u308b\u30ea\u30bd\u30fc\u30b9\u306e URL\u3002","type":"string","format":"uri","required":true},"format":{"default":"json","required":false},"maxwidth":{"default":600,"required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/oembed\/1.0\/embed"}]}},"\/oembed\/1.0\/proxy":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"oEmbed \u30c7\u30fc\u30bf\u3092\u53d6\u5f97\u3059\u308b\u30ea\u30bd\u30fc\u30b9\u306e URL\u3002","type":"string","format":"uri","required":true},"format":{"description":"\u4f7f\u7528\u3059\u308b oEmbed \u5f62\u5f0f\u3002","type":"string","default":"json","enum":["json","xml"],"required":false},"maxwidth":{"description":"\u57cb\u3081\u8fbc\u307f\u30d5\u30ec\u30fc\u30e0\u306e\u6700\u5927\u5e45 (\u30d4\u30af\u30bb\u30eb)\u3002","type":"integer","default":600,"required":false},"maxheight":{"description":"\u57cb\u3081\u8fbc\u307f\u30d5\u30ec\u30fc\u30e0\u306e\u6700\u5927\u306e\u9ad8\u3055 (\u30d4\u30af\u30bb\u30eb)\u3002","type":"integer","required":false},"discover":{"description":"\u8a31\u53ef\u3055\u308c\u3066\u3044\u306a\u3044\u30d7\u30ed\u30d0\u30a4\u30c0\u306b\u5bfe\u3057\u3066 oEmbed \u691c\u51fa\u30ea\u30af\u30a8\u30b9\u30c8\u3092\u884c\u3046\u304b\u3069\u3046\u304b\u3002","type":"boolean","default":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/oembed\/1.0\/proxy"}]}},"\/redirection\/v1":{"namespace":"redirection\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"redirection\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/redirection\/v1"}]}},"\/redirection\/v1\/redirect":{"namespace":"redirection\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"filterBy":{"description":"Field to filter by","required":false},"orderby":{"description":"Field to order results by","type":"string","enum":["source","last_count","last_access","position","id",""],"required":false},"direction":{"description":"Direction of ordered results","type":"string","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"description":"Field to filter by","required":false},"orderby":{"description":"Field to order results by","type":"string","enum":["source","last_count","last_access","position","id",""],"required":false},"direction":{"description":"Direction of ordered results","type":"string","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/redirection\/v1\/redirect"}]}},"\/redirection\/v1\/redirect\/(?P<id>[\\d]+)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/redirection\/v1\/redirect\/post":{"namespace":"redirection\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"text":{"description":"Text to match","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/redirection\/v1\/redirect\/post"}]}},"\/redirection\/v1\/bulk\/redirect\/(?P<bulk>delete|enable|disable|reset)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"description":"Field to filter by","required":false},"orderby":{"description":"Field to order results by","type":"string","enum":["source","last_count","last_access","position","id",""],"required":false},"direction":{"description":"Direction of ordered results","type":"string","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false},"global":{"description":"Apply bulk action globally, as per filters","type":"boolean","required":false},"items":{"description":"Array of IDs to perform action on","type":"array","items":{"description":"Item ID","type":["string","number"]},"required":false}}}]},"\/redirection\/v1\/group":{"namespace":"redirection\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"filterBy":{"description":"Field to filter by","required":false},"orderby":{"description":"Field to order results by","type":"string","enum":["name","id",""],"required":false},"direction":{"description":"Direction of ordered results","type":"string","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"description":"Field to filter by","required":false},"orderby":{"description":"Field to order results by","type":"string","enum":["name","id",""],"required":false},"direction":{"description":"Direction of ordered results","type":"string","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false},"moduleId":{"description":"Module ID","type":"integer","minimum":0,"maximum":3,"required":true},"name":{"description":"Group name","type":"string","required":true},"status":{"description":"Status of the group","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/redirection\/v1\/group"}]}},"\/redirection\/v1\/group\/(?P<id>[\\d]+)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"moduleId":{"description":"Module ID","type":"integer","minimum":0,"maximum":3,"required":true},"name":{"description":"Group name","type":"string","required":true},"status":{"description":"Status of the group","required":false}}}]},"\/redirection\/v1\/bulk\/group\/(?P<bulk>delete|enable|disable)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"description":"Field to filter by","required":false},"orderby":{"description":"Field to order results by","type":"string","enum":["name","id",""],"required":false},"direction":{"description":"Direction of ordered results","type":"string","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false},"items":{"description":"Comma separated list of item IDs to perform action on","type":"array","items":{"description":"Item ID","type":["string","number"]},"required":false}}}]},"\/redirection\/v1\/log":{"namespace":"redirection\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"filterBy":{"description":"Field to filter by","required":false},"orderby":{"description":"Field to order results by","type":"string","enum":["url","ip","total","count",""],"required":false},"direction":{"description":"Direction of ordered results","type":"string","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/redirection\/v1\/log"}]}},"\/redirection\/v1\/bulk\/log\/(?P<bulk>delete)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"description":"Field to filter by","required":false},"orderby":{"description":"Field to order results by","type":"string","enum":["url","ip","total","count",""],"required":false},"direction":{"description":"Direction of ordered results","type":"string","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false},"items":{"description":"Comma separated list of item IDs to perform action on","type":"array","items":{"description":"Item ID","type":["string","number"]},"required":false}}}]},"\/redirection\/v1\/404":{"namespace":"redirection\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"filterBy":{"description":"Field to filter by","required":false},"orderby":{"description":"Field to order results by","type":"string","enum":["url","ip","total","count",""],"required":false},"direction":{"description":"Direction of ordered results","type":"string","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/redirection\/v1\/404"}]}},"\/redirection\/v1\/bulk\/404\/(?P<bulk>delete)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"description":"Field to filter by","required":false},"orderby":{"description":"Field to order results by","type":"string","enum":["url","ip","total","count",""],"required":false},"direction":{"description":"Direction of ordered results","type":"string","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false},"items":{"description":"Comma separated list of item IDs to perform action on","type":"array","items":{"description":"Item ID","type":["string","number"]},"required":false}}}]},"\/redirection\/v1\/setting":{"namespace":"redirection\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/redirection\/v1\/setting"}]}},"\/redirection\/v1\/plugin":{"namespace":"redirection\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Name","type":"string","required":false},"value":{"description":"Value","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/redirection\/v1\/plugin"}]}},"\/redirection\/v1\/plugin\/delete":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/redirection\/v1\/plugin\/delete"}]}},"\/redirection\/v1\/plugin\/test":{"namespace":"redirection\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/redirection\/v1\/plugin\/test"}]}},"\/redirection\/v1\/plugin\/data":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"upgrade":{"description":"Upgrade parameter","type":"string","enum":["stop","skip","retry"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/redirection\/v1\/plugin\/data"}]}},"\/redirection\/v1\/plugin\/finish":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/redirection\/v1\/plugin\/finish"}]}},"\/redirection\/v1\/plugin\/fix":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"reason":{"description":"Reason for fix","type":"string","required":true},"current":{"description":"Current version","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/redirection\/v1\/plugin\/fix"}]}},"\/redirection\/v1\/import\/file\/(?P<group_id>\\d+)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"dry_run":{"required":false},"duplicate_mode":{"required":false},"deduplicate":{"required":false},"import_sections":{"required":false}}}]},"\/redirection\/v1\/import\/plugin":{"namespace":"redirection\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"delete_source":{"required":false},"duplicate_mode":{"required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/redirection\/v1\/import\/plugin"}]}},"\/redirection\/v1\/import\/plugin\/(?P<plugin>[a-z0-9-]+)\/preview":{"namespace":"redirection\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"delete_source":{"required":false},"duplicate_mode":{"required":false}}}]},"\/redirection\/v1\/export\/(?P<module>1|2|3|all)\/(?P<format>csv|apache|nginx|json)":{"namespace":"redirection\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/redirection\/v1\/export\/redirect\/preview":{"namespace":"redirection\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/redirection\/v1\/export\/redirect\/preview"}]}},"\/redirection\/v1\/export\/redirect":{"namespace":"redirection\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/redirection\/v1\/export\/redirect"}]}},"\/redirection\/v1\/export\/log\/preview":{"namespace":"redirection\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/redirection\/v1\/export\/log\/preview"}]}},"\/redirection\/v1\/export\/group\/(?P<format>csv|json)":{"namespace":"redirection\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/redirection\/v1\/export\/log\/(?P<format>csv|json)":{"namespace":"redirection\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/redirection\/v1\/export\/404\/preview":{"namespace":"redirection\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/redirection\/v1\/export\/404\/preview"}]}},"\/redirection\/v1\/export\/404\/(?P<format>csv|json)":{"namespace":"redirection\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/redirection\/v1\/export\/bundle":{"namespace":"redirection\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/redirection\/v1\/export\/bundle"}]}},"\/redirection\/v1\/export\/bundle\/preview":{"namespace":"redirection\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/redirection\/v1\/export\/bundle\/preview"}]}},"\/wordfence\/v1":{"namespace":"wordfence\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wordfence\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wordfence\/v1"}]}},"\/wordfence\/v1\/authenticate":{"namespace":"wordfence\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wordfence\/v1\/authenticate"}]}},"\/wordfence\/v1\/config":{"namespace":"wordfence\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wordfence\/v1\/config"}]}},"\/wordfence\/v1\/disconnect":{"namespace":"wordfence\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wordfence\/v1\/disconnect"}]}},"\/wordfence\/v1\/scan\/issues":{"namespace":"wordfence\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wordfence\/v1\/scan\/issues"}]}},"\/wordfence\/v1\/scan":{"namespace":"wordfence\/v1","methods":["POST","DELETE"],"endpoints":[{"methods":["POST"],"args":[]},{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wordfence\/v1\/scan"}]}},"\/wordfence\/v1\/scan\/issue":{"namespace":"wordfence\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wordfence\/v1\/scan\/issue"}]}},"\/yoast\/v1":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"yoast\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/yoast\/v1"}]}},"\/yoast\/v1\/file_size":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"type":"string","description":"The url to retrieve","required":true}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/yoast\/v1\/file_size"}]}},"\/yoast\/v1\/statistics":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/yoast\/v1\/statistics"}]}},"\/yoast\/v1\/new-content-type-visibility\/dismiss-post-type":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"postTypeName":{"required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/yoast\/v1\/new-content-type-visibility\/dismiss-post-type"}]}},"\/yoast\/v1\/new-content-type-visibility\/dismiss-taxonomy":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"taxonomyName":{"required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/yoast\/v1\/new-content-type-visibility\/dismiss-taxonomy"}]}},"\/yoast\/v1\/site_kit_configuration_permanent_dismissal":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"is_dismissed":{"type":"bool","required":true}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/yoast\/v1\/site_kit_configuration_permanent_dismissal"}]}},"\/yoast\/v1\/readability_scores":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"contentType":{"type":"string","required":true},"taxonomy":{"type":"string","default":"","required":false},"term":{"type":"integer","default":null,"required":false},"troubleshooting":{"type":"bool","default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/yoast\/v1\/readability_scores"}]}},"\/yoast\/v1\/seo_scores":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"contentType":{"type":"string","required":true},"taxonomy":{"type":"string","default":"","required":false},"term":{"type":"integer","default":null,"required":false},"troubleshooting":{"type":"bool","default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/yoast\/v1\/seo_scores"}]}},"\/yoast\/v1\/setup_steps_tracking":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"setup_widget_loaded":{"type":"string","enum":["yes","no"],"required":false},"first_interaction_stage":{"type":"string","enum":["install","activate","setup","grantConsent","successfullyConnected"],"required":false},"last_interaction_stage":{"type":"string","enum":["install","activate","setup","grantConsent","successfullyConnected"],"required":false},"setup_widget_temporarily_dismissed":{"type":"string","enum":["yes","no"],"required":false},"setup_widget_permanently_dismissed":{"type":"string","enum":["yes","no"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/yoast\/v1\/setup_steps_tracking"}]}},"\/yoast\/v1\/introductions\/(?P<introduction_id>[\\w-]+)\/seen":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"introduction_id":{"type":"string","required":true},"is_seen":{"type":"bool","default":true,"required":false}}}]},"\/yoast\/v1\/wistia_embed_permission":{"namespace":"yoast\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"value":{"type":"bool","default":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/yoast\/v1\/wistia_embed_permission"}]}},"\/yoast\/v1\/available_posts":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"search":{"type":"string","default":"","required":false},"postType":{"type":"string","default":"page","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/yoast\/v1\/available_posts"}]}},"\/yoast\/v1\/alerts\/dismiss":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"key":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/yoast\/v1\/alerts\/dismiss"}]}},"\/yoast\/v1\/configuration\/site_representation":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"company_or_person":{"type":"string","enum":["company","person"],"required":true},"company_name":{"type":"string","required":false},"company_logo":{"type":"string","required":false},"company_logo_id":{"type":"integer","required":false},"person_logo":{"type":"string","required":false},"person_logo_id":{"type":"integer","required":false},"company_or_person_user_id":{"type":"integer","required":false},"description":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/yoast\/v1\/configuration\/site_representation"}]}},"\/yoast\/v1\/configuration\/social_profiles":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"facebook_site":{"type":"string","required":false},"twitter_site":{"type":"string","required":false},"other_social_urls":{"type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/yoast\/v1\/configuration\/social_profiles"}]}},"\/yoast\/v1\/configuration\/check_capability":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"user_id":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/yoast\/v1\/configuration\/check_capability"}]}},"\/yoast\/v1\/configuration\/enable_tracking":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"tracking":{"type":"boolean","required":true}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/yoast\/v1\/configuration\/enable_tracking"}]}},"\/yoast\/v1\/configuration\/save_configuration_state":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"finishedSteps":{"type":"array","required":true}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/yoast\/v1\/configuration\/save_configuration_state"}]}},"\/yoast\/v1\/configuration\/get_configuration_state":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/yoast\/v1\/configuration\/get_configuration_state"}]}},"\/yoast\/v1\/import\/(?P<plugin>[\\w-]+)\/(?P<type>[\\w-]+)":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/yoast\/v1\/get_head":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/yoast\/v1\/get_head"}]}},"\/yoast\/v1\/indexing\/posts":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/yoast\/v1\/indexing\/posts"}]}},"\/yoast\/v1\/indexing\/terms":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/yoast\/v1\/indexing\/terms"}]}},"\/yoast\/v1\/indexing\/post-type-archives":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/yoast\/v1\/indexing\/post-type-archives"}]}},"\/yoast\/v1\/indexing\/general":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/yoast\/v1\/indexing\/general"}]}},"\/yoast\/v1\/indexing\/prepare":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/yoast\/v1\/indexing\/prepare"}]}},"\/yoast\/v1\/indexing\/indexables-complete":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/yoast\/v1\/indexing\/indexables-complete"}]}},"\/yoast\/v1\/indexing\/complete":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/yoast\/v1\/indexing\/complete"}]}},"\/yoast\/v1\/link-indexing\/posts":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/yoast\/v1\/link-indexing\/posts"}]}},"\/yoast\/v1\/link-indexing\/terms":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/yoast\/v1\/link-indexing\/terms"}]}},"\/yoast\/v1\/integrations\/set_active":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"active":{"type":"boolean","required":true},"integration":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/yoast\/v1\/integrations\/set_active"}]}},"\/yoast\/v1\/meta\/search":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/yoast\/v1\/meta\/search"}]}},"\/yoast\/v1\/semrush\/authenticate":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"code":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/yoast\/v1\/semrush\/authenticate"}]}},"\/yoast\/v1\/semrush\/country_code":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"country_code":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/yoast\/v1\/semrush\/country_code"}]}},"\/yoast\/v1\/semrush\/related_keyphrases":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"keyphrase":{"required":true},"country_code":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/yoast\/v1\/semrush\/related_keyphrases"}]}},"\/yoast\/v1\/wincher\/authorization-url":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/yoast\/v1\/wincher\/authorization-url"}]}},"\/yoast\/v1\/wincher\/authenticate":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"code":{"required":true},"websiteId":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/yoast\/v1\/wincher\/authenticate"}]}},"\/yoast\/v1\/wincher\/keyphrases\/track":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"keyphrases":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/yoast\/v1\/wincher\/keyphrases\/track"}]}},"\/yoast\/v1\/wincher\/keyphrases":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"keyphrases":{"required":false},"permalink":{"required":false},"startAt":{"required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/yoast\/v1\/wincher\/keyphrases"}]}},"\/yoast\/v1\/wincher\/keyphrases\/untrack":{"namespace":"yoast\/v1","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/yoast\/v1\/wincher\/keyphrases\/untrack"}]}},"\/yoast\/v1\/wincher\/account\/limit":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/yoast\/v1\/wincher\/account\/limit"}]}},"\/yoast\/v1\/wincher\/account\/upgrade-campaign":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/yoast\/v1\/wincher\/account\/upgrade-campaign"}]}},"\/yoast\/v1\/workouts":{"namespace":"yoast\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/yoast\/v1\/workouts"}]}},"\/yoast\/v1\/complete_task":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"options":{"type":"object","properties":{"task":{"type":"string","required":true,"sanitize_callback":"sanitize_text_field"}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/yoast\/v1\/complete_task"}]}},"\/yoast\/v1\/get_tasks":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"options":{"type":"object","properties":{"filter":{"type":"string","required":false,"sanitize_callback":"sanitize_text_field"},"limit":{"type":"int","required":false,"sanitize_callback":"absint"}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/yoast\/v1\/get_tasks"}]}},"\/yoast\/v1\/action_tracking":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"action":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/yoast\/v1\/action_tracking"}]}},"\/wp-super-cache\/v1":{"namespace":"wp-super-cache\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-super-cache\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp-super-cache\/v1"}]}},"\/wp-super-cache\/v1\/settings":{"namespace":"wp-super-cache\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp-super-cache\/v1\/settings"}]}},"\/wp-super-cache\/v1\/status":{"namespace":"wp-super-cache\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp-super-cache\/v1\/status"}]}},"\/wp-super-cache\/v1\/stats":{"namespace":"wp-super-cache\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp-super-cache\/v1\/stats"}]}},"\/wp-super-cache\/v1\/cache":{"namespace":"wp-super-cache\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp-super-cache\/v1\/cache"}]}},"\/wp-super-cache\/v1\/preload":{"namespace":"wp-super-cache\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp-super-cache\/v1\/preload"}]}},"\/wp-super-cache\/v1\/cache\/test":{"namespace":"wp-super-cache\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp-super-cache\/v1\/cache\/test"}]}},"\/wp-super-cache\/v1\/plugins":{"namespace":"wp-super-cache\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp-super-cache\/v1\/plugins"}]}},"\/elementor-one\/v1":{"namespace":"elementor-one\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"elementor-one\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/elementor-one\/v1"}]}},"\/elementor-one\/v1\/connect\/authorize":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"clearSession":{"type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/elementor-one\/v1\/connect\/authorize"}]}},"\/elementor-one\/v1\/connect\/disconnect":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/elementor-one\/v1\/connect\/disconnect"}]}},"\/elementor-one\/v1\/connect\/switch-domain":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/elementor-one\/v1\/connect\/switch-domain"}]}},"\/elementor-one\/v1\/connect\/deactivate":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/elementor-one\/v1\/connect\/deactivate"}]}},"\/elementor-one\/v1\/top-bar\/notifications":{"namespace":"elementor-one\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"app_name":{"type":"string","required":true},"app_version":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/elementor-one\/v1\/top-bar\/notifications"}]}},"\/elementor-one\/v1\/top-bar\/feedback":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"product":{"type":"string","required":true},"subject":{"type":"string","required":true},"title":{"type":"string","required":true},"description":{"type":"string","required":true},"countryCode":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/elementor-one\/v1\/top-bar\/feedback"}]}},"\/elementor-one\/v1\/themes":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org theme directory slug.","pattern":"[\\w\\-]+","required":true},"status":{"description":"The theme activation status.","type":"string","enum":["inactive","active"],"default":"inactive","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/elementor-one\/v1\/themes"}]}},"\/elementor-one\/v1\/themes\/(?P<slug>[\\w\\-]+)\/activate":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org theme directory slug.","pattern":"[\\w\\-]+","required":true}}}]},"\/elementor-one\/v1\/plugins":{"namespace":"elementor-one\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"search":{"description":"\u6587\u5b57\u5217\u306b\u4e00\u81f4\u3059\u308b\u3082\u306e\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","required":false},"status":{"description":"\u6307\u5b9a\u3057\u305f\u30b9\u30c6\u30fc\u30bf\u30b9\u306b\u4e00\u81f4\u3059\u308b\u30d7\u30e9\u30b0\u30a4\u30f3\u306e\u307f\u306b\u7d50\u679c\u3092\u5236\u9650\u3057\u307e\u3059\u3002","type":"array","items":{"type":"string","enum":["inactive","active"]},"required":false}}},{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org plugin directory slug.","enum":["angie","manage","elementor","elementor-pro","site-mailer","image-optimization","pojo-accessibility","cookiez"],"required":true},"status":{"description":"The plugin activation status.","type":"string","enum":["inactive","active"],"default":"inactive","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/elementor-one\/v1\/plugins"}]}},"\/elementor-one\/v1\/plugins\/(?P<slug>[\\w\\-]+)\/activate":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org plugin directory slug.","enum":["angie","manage","elementor","elementor-pro","site-mailer","image-optimization","pojo-accessibility","cookiez"],"required":true}}}]},"\/elementor-one\/v1\/plugins\/(?P<slug>[\\w\\-]+)\/deactivate":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org plugin directory slug.","enum":["angie","manage","elementor","elementor-pro","site-mailer","image-optimization","pojo-accessibility","cookiez"],"required":true}}}]},"\/elementor-one\/v1\/plugins\/(?P<slug>[\\w\\-]+)\/upgrade":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org plugin directory slug.","enum":["angie","manage","elementor","elementor-pro","site-mailer","image-optimization","pojo-accessibility","cookiez"],"required":true},"status":{"description":"The plugin activation status.","type":"string","enum":["active"],"required":false}}}]},"\/elementor-one\/v1\/plugins\/(?P<slug>[\\w\\-]+)\/migration\/run":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org plugin directory slug.","enum":{"1":"manage","2":"elementor","3":"elementor-pro","4":"site-mailer","5":"image-optimization","6":"pojo-accessibility","7":"cookiez"},"required":true},"force":{"type":"boolean","default":true,"description":"Force migration even if the plugin is already connected.","required":false}}}]},"\/elementor-one\/v1\/plugins\/(?P<slug>[\\w\\-]+)\/migration\/rollback":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org plugin directory slug.","enum":{"1":"manage","2":"elementor","3":"elementor-pro","4":"site-mailer","5":"image-optimization","6":"pojo-accessibility","7":"cookiez"},"required":true}}}]},"\/elementor-one\/v1\/settings":{"namespace":"elementor-one\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/elementor-one\/v1\/settings"}]}},"\/elementor-one\/v1\/manage-dashboard-widget\/state":{"namespace":"elementor-one\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/elementor-one\/v1\/manage-dashboard-widget\/state"}]}},"\/elementor-one\/v1\/logs":{"namespace":"elementor-one\/v1","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/elementor-one\/v1\/logs"}]}},"\/ai1wm\/v1":{"namespace":"ai1wm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"ai1wm\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/ai1wm\/v1"}]}},"\/ai1wm\/v1\/capabilities":{"namespace":"ai1wm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/ai1wm\/v1\/capabilities"}]}},"\/ai1wm\/v1\/exports":{"namespace":"ai1wm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"password":{"type":"string","description":"Archive password. For exports: enables encryption. For imports: used to decrypt an encrypted archive.","required":false},"options":{"type":"object","required":false},"find_replace":{"type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/ai1wm\/v1\/exports"}]}},"\/ai1wm\/v1\/exports\/(?P<job_id>[a-f0-9]{13,40})":{"namespace":"ai1wm\/v1","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"secret_key":{"type":"string","description":"Shared-secret auth fallback for status\/log polling after an import has invalidated the Application Password.","required":false}}},{"methods":["DELETE"],"args":[]}]},"\/ai1wm\/v1\/exports\/(?P<job_id>[a-f0-9]{13,40})\/log":{"namespace":"ai1wm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"secret_key":{"type":"string","description":"Shared-secret auth fallback for status\/log polling after an import has invalidated the Application Password.","required":false}}}]},"\/ai1wm\/v1\/imports":{"namespace":"ai1wm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/ai1wm\/v1\/imports"}]}},"\/ai1wm\/v1\/imports\/(?P<job_id>[a-f0-9]{13,40})\/file":{"namespace":"ai1wm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"auto_confirm":{"type":"boolean","required":false}}}]},"\/ai1wm\/v1\/imports\/(?P<job_id>[a-f0-9]{13,40})":{"namespace":"ai1wm\/v1","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"secret_key":{"type":"string","description":"Shared-secret auth fallback for status\/log polling after an import has invalidated the Application Password.","required":false}}},{"methods":["DELETE"],"args":[]}]},"\/ai1wm\/v1\/imports\/(?P<job_id>[a-f0-9]{13,40})\/confirm":{"namespace":"ai1wm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"password":{"type":"string","description":"Archive password. For exports: enables encryption. For imports: used to decrypt an encrypted archive.","required":false},"proceed":{"type":"boolean","required":true}}}]},"\/ai1wm\/v1\/imports\/(?P<job_id>[a-f0-9]{13,40})\/log":{"namespace":"ai1wm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"secret_key":{"type":"string","description":"Shared-secret auth fallback for status\/log polling after an import has invalidated the Application Password.","required":false}}}]},"\/ai1wm\/v1\/backups":{"namespace":"ai1wm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/ai1wm\/v1\/backups"}]}},"\/ai1wm\/v1\/backups\/(?P<name>[a-zA-Z0-9._-]{1,247}\\.wpress)":{"namespace":"ai1wm\/v1","methods":["GET","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["PATCH"],"args":{"label":{"type":"string","required":false}}},{"methods":["DELETE"],"args":[]}]},"\/ai1wm\/v1\/backups\/(?P<name>[a-zA-Z0-9._-]{1,247}\\.wpress)\/download":{"namespace":"ai1wm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/ai1wm\/v1\/backups\/(?P<name>[a-zA-Z0-9._-]{1,247}\\.wpress)\/restore":{"namespace":"ai1wm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/daext-helpful\/v1":{"namespace":"daext-helpful\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"daext-helpful\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/daext-helpful\/v1"}]}},"\/daext-helpful\/v1\/read-options":{"namespace":"daext-helpful\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/daext-helpful\/v1\/read-options"}]}},"\/daext-helpful\/v1\/options":{"namespace":"daext-helpful\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/daext-helpful\/v1\/options"}]}},"\/daext-helpful\/v1\/statistics":{"namespace":"daext-helpful\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/daext-helpful\/v1\/statistics"}]}},"\/daext-helpful\/v1\/statistics-details-view":{"namespace":"daext-helpful\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/daext-helpful\/v1\/statistics-details-view"}]}},"\/daext-helpful\/v1\/feedback":{"namespace":"daext-helpful\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/daext-helpful\/v1\/feedback"}]}},"\/elementor\/v1\/documents":{"namespace":"elementor\/v1\/documents","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"elementor\/v1\/documents","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/elementor\/v1\/documents"}]}},"\/elementor\/v1\/documents\/(?P<id>\\d+)\/media\/import":{"namespace":"elementor\/v1\/documents","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"required":true}}}]},"\/elementor\/v1":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"elementor\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/elementor\/v1"}]}},"\/elementor\/v1\/cache":{"namespace":"elementor\/v1","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/elementor\/v1\/cache"}]}},"\/elementor\/v1\/globals":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/elementor\/v1\/globals"}]}},"\/elementor\/v1\/globals\/colors":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/elementor\/v1\/globals\/colors"}]}},"\/elementor\/v1\/globals\/colors\/(?P<id>[\\w-]+)":{"namespace":"elementor\/v1","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}},{"methods":["POST"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}}]},"\/elementor\/v1\/globals\/typography":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/elementor\/v1\/globals\/typography"}]}},"\/elementor\/v1\/globals\/typography\/(?P<id>[\\w-]+)":{"namespace":"elementor\/v1","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}},{"methods":["POST"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}}]},"\/elementor\/v1\/settings\/(?P<key>[\\w_-]+)":{"namespace":"elementor\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/elementor\/v1\/post":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"included_types":{"description":"Included post types","type":"array","default":null,"required":false},"excluded_types":{"description":"Post type to exclude","type":"array","default":["e-floating-buttons","e-landing-page","elementor_library","attachment","revision","nav_menu_item","custom_css","customize_changeset"],"required":false},"term":{"description":"Posts to search","type":"string","default":"","required":false},"keys_conversion_map":{"description":"Specify keys to extract and convert, i.e. [\"key_1\" => \"new_key_1\"].","type":"array","default":{"ID":"id","post_title":"label","post_type":"groupLabel"},"required":false},"items_count":{"description":"Posts per page","type":"integer","default":100,"required":false},"is_public":{"description":"Whether to include only public post types","type":"boolean","default":true,"required":false},"meta_query":{"description":"WP_Query meta_query array","type":"array","default":null,"required":false},"tax_query":{"description":"WP_Query tax_query array","type":"array","default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/elementor\/v1\/post"}]}},"\/elementor\/v1\/term":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"included_types":{"description":"Included taxonomy containing terms (categories, tags, etc...)","type":"array","default":null,"required":false},"excluded_types":{"description":"Excluded taxonomy containing terms (categories, tags, etc...)","type":"array","default":null,"required":false},"term":{"description":"Terms to search","type":"string","default":"","required":false},"keys_conversion_map":{"description":"Specify keys to extract and convert, i.e. [\"key_1\" => \"new_key_1\"].","type":"array","default":{"term_id":"id","name":"label","taxonomy":"groupLabel"},"required":false},"items_count":{"description":"Terms per request","type":"integer","default":100,"required":false},"hide_empty":{"description":"Whether to include only public terms","type":"boolean","default":false,"required":false},"meta_query":{"description":"WP_Query meta_query array","type":"array","default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/elementor\/v1\/term"}]}},"\/elementor\/v1\/user":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"term":{"description":"Users to search","type":"string","default":"","required":false},"keys_conversion_map":{"description":"Specify keys to extract and convert, i.e. [\"key_1\" => \"new_key_1\"].","type":["array","string"],"default":{"ID":"id","display_name":"label","role":"groupLabel"},"required":false},"items_count":{"description":"Number of users to return","type":"integer","default":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/elementor\/v1\/user"}]}},"\/elementor-ai\/v1":{"namespace":"elementor-ai\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"elementor-ai\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/elementor-ai\/v1"}]}},"\/elementor-ai\/v1\/permissions":{"namespace":"elementor-ai\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/elementor-ai\/v1\/permissions"}]}},"\/elementor\/v1\/favorites":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","required":false},"page":{"description":"\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u306e\u73fe\u5728\u306e\u30da\u30fc\u30b8\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u3068\u3057\u3066\u8fd4\u3055\u308c\u308b\u9805\u76ee\u306e\u6700\u5927\u6570\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u6587\u5b57\u5217\u306b\u4e00\u81f4\u3059\u308b\u3082\u306e\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/elementor\/v1\/favorites"}]}},"\/elementor\/v1\/favorites\/(?P<id>[\\w]+)":{"namespace":"elementor\/v1","methods":["POST","DELETE"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Type of favorites.","type":"string","required":true},"favorite":{"description":"The favorite slug to create.","type":"string","required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Type of favorites.","type":"string","required":true},"favorite":{"description":"The favorite slug to delete.","type":"string","required":true}}}]},"\/elementor\/v1\/kit-elements-defaults":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/elementor\/v1\/kit-elements-defaults"}]}},"\/elementor\/v1\/kit-elements-defaults\/(?P<type>[\\w\\-\\_]+)":{"namespace":"elementor\/v1","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"type":{"type":"string","description":"The type of the element.","required":true},"settings":{"description":"All the default values for the requested type","type":"object","required":true}}},{"methods":["DELETE"],"args":{"type":{"type":"string","description":"The type of the element.","required":true}}}]},"\/elementor\/v1\/site-navigation\/recent-posts":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"posts_per_page":{"description":"Number of posts to return","type":"integer","required":true},"post_type":{"description":"Post types to retrieve","type":"array","default":["page","post","elementor_library"],"required":false},"post__not_in":{"description":"Post id`s to exclude","type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/elementor\/v1\/site-navigation\/recent-posts"}]}},"\/elementor\/v1\/site-navigation\/add-new-post":{"namespace":"elementor\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"post_type":{"description":"Post type to create","type":"string","default":"post","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/elementor\/v1\/site-navigation\/add-new-post"}]}},"\/elementor\/v1\/design-system-sync\/stylesheet":{"namespace":"elementor\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/elementor\/v1\/design-system-sync\/stylesheet"}]}},"\/elementor\/v1\/checklist":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","required":false},"page":{"description":"\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u306e\u73fe\u5728\u306e\u30da\u30fc\u30b8\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u3068\u3057\u3066\u8fd4\u3055\u308c\u308b\u9805\u76ee\u306e\u6700\u5927\u6570\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u6587\u5b57\u5217\u306b\u4e00\u81f4\u3059\u308b\u3082\u306e\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/elementor\/v1\/checklist"}]}},"\/elementor\/v1\/checklist\/(?P<id>[\\d]+)":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}}]},"\/elementor\/v1\/checklist\/steps":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/elementor\/v1\/checklist\/steps"}]}},"\/elementor\/v1\/checklist\/steps\/(?P<id>[\\d]+)":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}}]},"\/elementor\/v1\/checklist\/steps\/(?P<id>[\\w\\-\\_]+)":{"namespace":"elementor\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"id":{"type":"string","description":"The step id.","required":true}}}]},"\/elementor\/v1\/checklist\/user-progress":{"namespace":"elementor\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/elementor\/v1\/checklist\/user-progress"}]}},"\/elementor\/v1\/operations\/opt-in-v4":{"namespace":"elementor\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/elementor\/v1\/operations\/opt-in-v4"}]}},"\/elementor\/v1\/feedback":{"namespace":"elementor\/v1\/feedback","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"elementor\/v1\/feedback","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/elementor\/v1\/feedback"}]}},"\/elementor\/v1\/feedback\/submit":{"namespace":"elementor\/v1\/feedback","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/elementor\/v1\/feedback\/submit"}]}},"\/elementor\/v1\/angie\/consent":{"namespace":"elementor\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/elementor\/v1\/angie\/consent"}]}},"\/elementor\/v1\/template-library\/templates":{"namespace":"elementor\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"title":{"type":"string","description":"The title of the document","required":false},"type":{"description":"The document type.","type":"string","enum":["page","section"],"required":true},"content":{"description":"Elementor data object","type":"object","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/elementor\/v1\/template-library\/templates"}]}},"\/elementor\/v1\/user-data\/current-user":{"namespace":"elementor\/v1","methods":["GET","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["PATCH"],"args":{"suppressedMessages":{"type":"array","description":"Array of suppressed message keys","items":{"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/elementor\/v1\/user-data\/current-user"}]}},"\/elementor\/v1\/onboarding":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","required":false},"page":{"description":"\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u306e\u73fe\u5728\u306e\u30da\u30fc\u30b8\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u3068\u3057\u3066\u8fd4\u3055\u308c\u308b\u9805\u76ee\u306e\u6700\u5927\u6570\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u6587\u5b57\u5217\u306b\u4e00\u81f4\u3059\u308b\u3082\u306e\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/elementor\/v1\/onboarding"}]}},"\/elementor\/v1\/onboarding\/user-progress":{"namespace":"elementor\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/elementor\/v1\/onboarding\/user-progress"}]}},"\/elementor\/v1\/onboarding\/user-choices":{"namespace":"elementor\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/elementor\/v1\/onboarding\/user-choices"}]}},"\/elementor\/v1\/onboarding\/pro-install-screen":{"namespace":"elementor\/v1","methods":["GET","GET"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/elementor\/v1\/onboarding\/pro-install-screen"}]}},"\/elementor\/v1\/onboarding\/install-pro":{"namespace":"elementor\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/elementor\/v1\/onboarding\/install-pro"}]}},"\/elementor\/v1\/onboarding\/install-theme":{"namespace":"elementor\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/elementor\/v1\/onboarding\/install-theme"}]}},"\/elementor\/v1\/library\/connect":{"namespace":"elementor\/v1","methods":["POST","DELETE"],"endpoints":[{"methods":["POST"],"args":{"token":{"type":"string","description":"Connect CLI token","required":true}}},{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/elementor\/v1\/library\/connect"}]}},"\/elementor\/v1\/send-event":{"namespace":"elementor\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","required":false},"page":{"description":"\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u306e\u73fe\u5728\u306e\u30da\u30fc\u30b8\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u3068\u3057\u3066\u8fd4\u3055\u308c\u308b\u9805\u76ee\u306e\u6700\u5927\u6570\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u6587\u5b57\u5217\u306b\u4e00\u81f4\u3059\u308b\u3082\u306e\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","required":false}}},{"methods":["POST"],"args":{"event_data":{"description":"All the recorded event data in JSON format","type":"object","required":true}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/elementor\/v1\/send-event"}]}},"\/wp\/v2":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp\/v2","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2"}]}},"\/wp\/v2\/posts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u306e\u73fe\u5728\u306e\u30da\u30fc\u30b8\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u3068\u3057\u3066\u8fd4\u3055\u308c\u308b\u9805\u76ee\u306e\u6700\u5927\u6570\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u6587\u5b57\u5217\u306b\u4e00\u81f4\u3059\u308b\u3082\u306e\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","required":false},"after":{"description":"\u5165\u529b\u3055\u308c\u305f ISO8601 \u6e96\u62e0\u306e\u65e5\u4ed8\u3088\u308a\u5f8c\u306b\u516c\u958b\u3055\u308c\u305f\u6295\u7a3f\u306b\u30ec\u30b9\u30dd\u30f3\u30b9\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","format":"date-time","required":false},"modified_after":{"description":"\u5165\u529b\u3055\u308c\u305f ISO8601 \u6e96\u62e0\u306e\u65e5\u4ed8\u3088\u308a\u5f8c\u306b\u66f4\u65b0\u3055\u308c\u305f\u6295\u7a3f\u306b\u30ec\u30b9\u30dd\u30f3\u30b9\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","format":"date-time","required":false},"author":{"description":"\u7279\u5b9a\u306e\u6295\u7a3f\u8005\u306b\u5272\u308a\u5f53\u3066\u3089\u308c\u305f\u6295\u7a3f\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"\u7279\u5b9a\u306e\u6295\u7a3f\u8005\u304c\u5272\u308a\u5f53\u3066\u3089\u308c\u305f\u6295\u7a3f\u3092\u7d50\u679c\u304b\u3089\u9664\u5916\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"\u5165\u529b\u3055\u308c\u305f ISO8601 \u6e96\u62e0\u306e\u65e5\u4ed8\u3088\u308a\u524d\u306b\u516c\u958b\u3055\u308c\u305f\u6295\u7a3f\u306b\u30ec\u30b9\u30dd\u30f3\u30b9\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","format":"date-time","required":false},"modified_before":{"description":"\u5165\u529b\u3055\u308c\u305f ISO8601 \u6e96\u62e0\u306e\u65e5\u4ed8\u3088\u308a\u524d\u306b\u66f4\u65b0\u3055\u308c\u305f\u6295\u7a3f\u306b\u30ec\u30b9\u30dd\u30f3\u30b9\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","format":"date-time","required":false},"exclude":{"description":"\u7279\u5b9a\u306e ID \u3092\u7d50\u679c\u304b\u3089\u9664\u5916\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u7279\u5b9a\u306e ID \u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"\u691c\u7d22\u5165\u529b\u3092\u89e3\u91c8\u3059\u308b\u65b9\u6cd5\u3067\u3059\u3002","type":"string","enum":["exact"],"required":false},"offset":{"description":"\u7279\u5b9a\u306e\u9805\u76ee\u6570\u3067\u7d50\u679c\u3092\u30aa\u30d5\u30bb\u30c3\u30c8\u3057\u307e\u3059\u3002","type":"integer","required":false},"order":{"description":"\u5c5e\u6027\u3067\u6607\u9806\u307e\u305f\u306f\u964d\u9806\u306b\u4e26\u3079\u66ff\u3048\u307e\u3059\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6295\u7a3f\u306e\u5c5e\u6027\u3067\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u3092\u4e26\u3079\u66ff\u3048\u307e\u3059\u3002","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"\u691c\u7d22\u3059\u308b\u5217\u540d\u306e\u914d\u5217\u3002","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"\u4e00\u3064\u4ee5\u4e0a\u306e\u7279\u5b9a\u306e\u30b9\u30e9\u30c3\u30b0\u3092\u6301\u3064\u6295\u7a3f\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"\u4e00\u3064\u4ee5\u4e0a\u306e\u30b9\u30c6\u30fc\u30bf\u30b9\u304c\u5272\u308a\u5f53\u3066\u3089\u308c\u305f\u6295\u7a3f\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"\u8907\u6570\u306e\u30bf\u30af\u30bd\u30ce\u30df\u30fc\u9593\u306e\u95a2\u4fc2\u306b\u57fa\u3065\u3044\u3066\u7d50\u679c\u30bb\u30c3\u30c8\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"\u300ccategories\u300d\u30bf\u30af\u30bd\u30ce\u30df\u30fc\u306b\u5272\u308a\u5f53\u3066\u3089\u308c\u305f\u7279\u5b9a\u306e\u30bf\u30fc\u30e0\u3092\u6301\u3064\u9805\u76ee\u306b\u7d50\u679c\u30bb\u30c3\u30c8\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":["object","array"],"oneOf":[{"title":"\u30bf\u30fc\u30e0 ID \u4e00\u89a7","description":"\u30ea\u30b9\u30c8\u3057\u305f ID \u3068\u5408\u81f4\u3059\u308b\u30bf\u30fc\u30e0\u3002","type":"array","items":{"type":"integer"}},{"title":"\u30bf\u30fc\u30e0 ID \u30bf\u30af\u30bd\u30ce\u30df\u30fc\u30af\u30a8\u30ea\u30fc","description":"\u9ad8\u5ea6\u306a\u30bf\u30fc\u30e0\u30af\u30a8\u30ea\u30fc\u3092\u5b9f\u884c\u3057\u307e\u3059\u3002","type":"object","properties":{"terms":{"description":"\u30bf\u30fc\u30e0 ID\u3002","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"\u7d50\u679c\u3092\u9650\u5b9a\u3057\u305f\u30bf\u30fc\u30e0\u306b\u5b50\u30bf\u30fc\u30e0\u3092\u542b\u3081\u308b\u304b\u3069\u3046\u304b\u3002","type":"boolean","default":false},"operator":{"description":"\u7279\u5b9a\u306e\u30bf\u30fc\u30e0\u306e\u3059\u3079\u3066\u306b\u9805\u76ee\u3092\u5272\u308a\u5f53\u3066\u308b\u304b\u3001\u4e00\u90e8\u306b\u5272\u308a\u5f53\u3066\u308b\u304b\u3002","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"\u300ccategories\u300d\u30bf\u30af\u30bd\u30ce\u30df\u30fc\u306b\u5272\u308a\u5f53\u3066\u3089\u308c\u305f\u7279\u5b9a\u306e\u30bf\u30fc\u30e0\u3092\u6301\u3064\u9805\u76ee\u4ee5\u5916\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":["object","array"],"oneOf":[{"title":"\u30bf\u30fc\u30e0 ID \u4e00\u89a7","description":"\u30ea\u30b9\u30c8\u3057\u305f ID \u3068\u5408\u81f4\u3059\u308b\u30bf\u30fc\u30e0\u3002","type":"array","items":{"type":"integer"}},{"title":"\u30bf\u30fc\u30e0 ID \u30bf\u30af\u30bd\u30ce\u30df\u30fc\u30af\u30a8\u30ea\u30fc","description":"\u9ad8\u5ea6\u306a\u30bf\u30fc\u30e0\u30af\u30a8\u30ea\u30fc\u3092\u5b9f\u884c\u3057\u307e\u3059\u3002","type":"object","properties":{"terms":{"description":"\u30bf\u30fc\u30e0 ID\u3002","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"\u7d50\u679c\u3092\u9650\u5b9a\u3057\u305f\u30bf\u30fc\u30e0\u306b\u5b50\u30bf\u30fc\u30e0\u3092\u542b\u3081\u308b\u304b\u3069\u3046\u304b\u3002","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"\u300ctags\u300d\u30bf\u30af\u30bd\u30ce\u30df\u30fc\u306b\u5272\u308a\u5f53\u3066\u3089\u308c\u305f\u7279\u5b9a\u306e\u30bf\u30fc\u30e0\u3092\u6301\u3064\u9805\u76ee\u306b\u7d50\u679c\u30bb\u30c3\u30c8\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":["object","array"],"oneOf":[{"title":"\u30bf\u30fc\u30e0 ID \u4e00\u89a7","description":"\u30ea\u30b9\u30c8\u3057\u305f ID \u3068\u5408\u81f4\u3059\u308b\u30bf\u30fc\u30e0\u3002","type":"array","items":{"type":"integer"}},{"title":"\u30bf\u30fc\u30e0 ID \u30bf\u30af\u30bd\u30ce\u30df\u30fc\u30af\u30a8\u30ea\u30fc","description":"\u9ad8\u5ea6\u306a\u30bf\u30fc\u30e0\u30af\u30a8\u30ea\u30fc\u3092\u5b9f\u884c\u3057\u307e\u3059\u3002","type":"object","properties":{"terms":{"description":"\u30bf\u30fc\u30e0 ID\u3002","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"\u7279\u5b9a\u306e\u30bf\u30fc\u30e0\u306e\u3059\u3079\u3066\u306b\u9805\u76ee\u3092\u5272\u308a\u5f53\u3066\u308b\u304b\u3001\u4e00\u90e8\u306b\u5272\u308a\u5f53\u3066\u308b\u304b\u3002","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"\u300ctags\u300d\u30bf\u30af\u30bd\u30ce\u30df\u30fc\u306b\u5272\u308a\u5f53\u3066\u3089\u308c\u305f\u7279\u5b9a\u306e\u30bf\u30fc\u30e0\u3092\u6301\u3064\u9805\u76ee\u4ee5\u5916\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":["object","array"],"oneOf":[{"title":"\u30bf\u30fc\u30e0 ID \u4e00\u89a7","description":"\u30ea\u30b9\u30c8\u3057\u305f ID \u3068\u5408\u81f4\u3059\u308b\u30bf\u30fc\u30e0\u3002","type":"array","items":{"type":"integer"}},{"title":"\u30bf\u30fc\u30e0 ID \u30bf\u30af\u30bd\u30ce\u30df\u30fc\u30af\u30a8\u30ea\u30fc","description":"\u9ad8\u5ea6\u306a\u30bf\u30fc\u30e0\u30af\u30a8\u30ea\u30fc\u3092\u5b9f\u884c\u3057\u307e\u3059\u3002","type":"object","properties":{"terms":{"description":"\u30bf\u30fc\u30e0 ID\u3002","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"sticky":{"description":"\u5148\u982d\u56fa\u5b9a\u8868\u793a\u306e\u9805\u76ee\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"boolean","required":false},"ignore_sticky":{"description":"\u56fa\u5b9a\u8868\u793a\u6295\u7a3f\u3092\u7121\u8996\u3059\u308b\u304b\u3069\u3046\u304b\u3002","type":"boolean","default":true,"required":false},"format":{"description":"1\u3064\u4ee5\u4e0a\u306e\u30d5\u30a9\u30fc\u30de\u30c3\u30c8\u304c\u5272\u308a\u5f53\u3066\u3089\u308c\u305f\u9805\u76ee\u306b\u7d50\u679c\u30bb\u30c3\u30c8\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","uniqueItems":true,"items":{"enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"\u6295\u7a3f\u306e\u516c\u958b\u65e5 (\u30b5\u30a4\u30c8\u306e\u30bf\u30a4\u30e0\u30be\u30fc\u30f3)\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u6295\u7a3f\u306e\u516c\u958b\u65e5 (GMT)\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u305d\u306e\u30bf\u30a4\u30d7\u306b\u7279\u6709\u306a\u3001\u6295\u7a3f\u306e\u82f1\u6570\u5b57\u8b58\u5225\u5b50\u3002","type":"string","required":false},"status":{"description":"\u6295\u7a3f\u306b\u5bfe\u3057\u3066\u540d\u524d\u304c\u3064\u3044\u3066\u3044\u308b\u30b9\u30c6\u30fc\u30bf\u30b9\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u30b3\u30f3\u30c6\u30f3\u30c4\u3084\u629c\u7c8b\u3078\u306e\u30a2\u30af\u30bb\u30b9\u3092\u4fdd\u8b77\u3059\u308b\u30d1\u30b9\u30ef\u30fc\u30c9\u3002","type":"string","required":false},"title":{"description":"\u6295\u7a3f\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":"object","properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u5f62\u614b\u306e\u3001\u6295\u7a3f\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u8868\u793a\u7528\u306b\u6574\u5f62\u3055\u308c\u305f\u3001\u6295\u7a3f\u306e HTML \u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"\u6295\u7a3f\u306e\u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":"object","properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u5f62\u614b\u306e\u3001\u6295\u7a3f\u306e\u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u8868\u793a\u7528\u306b\u5909\u63db\u3055\u308c\u305f\u3001\u6295\u7a3f\u306e HTML \u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"\u6295\u7a3f\u304c\u4f7f\u7528\u3059\u308b\u30b3\u30f3\u30c6\u30f3\u30c4\u30d6\u30ed\u30c3\u30af\u5f62\u5f0f\u306e\u30d0\u30fc\u30b8\u30e7\u30f3\u3002","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u30b3\u30f3\u30c6\u30f3\u30c4\u3092\u30d1\u30b9\u30ef\u30fc\u30c9\u3067\u4fdd\u8b77\u3059\u308b\u304b\u3069\u3046\u304b\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"\u6295\u7a3f\u8005\u306e ID\u3002","type":"integer","required":false},"excerpt":{"description":"\u6295\u7a3f\u306e\u629c\u7c8b\u3002","type":"object","properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u5f62\u614b\u306e\u3001\u6295\u7a3f\u306e\u629c\u7c8b\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u8868\u793a\u7528\u306b\u5909\u63db\u3055\u308c\u305f\u3001\u6295\u7a3f\u306e HTML \u306e\u629c\u7c8b\u3002","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"\u629c\u7c8b\u304c\u30d1\u30b9\u30ef\u30fc\u30c9\u3067\u4fdd\u8b77\u3055\u308c\u3066\u3044\u308b\u304b\u3069\u3046\u304b\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"\u6295\u7a3f\u306e\u30a2\u30a4\u30ad\u30e3\u30c3\u30c1\u3068\u306a\u308b\u30e1\u30c7\u30a3\u30a2\u306e ID\u3002","type":"integer","required":false},"comment_status":{"description":"\u6295\u7a3f\u304c\u30b3\u30e1\u30f3\u30c8\u3092\u53d7\u3051\u4ed8\u3051\u3066\u3044\u308b\u304b\u3069\u3046\u304b\u3002","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"\u6295\u7a3f\u304c\u30d4\u30f3\u30d0\u30c3\u30af\u3092\u53d7\u3051\u4ed8\u3051\u3066\u3044\u308b\u304b\u3069\u3046\u304b\u3002","type":"string","enum":["open","closed"],"required":false},"format":{"description":"\u6295\u7a3f\u306e\u30d5\u30a9\u30fc\u30de\u30c3\u30c8\u3002","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"\u30e1\u30bf\u30d5\u30a3\u30fc\u30eb\u30c9\u3002","type":"object","properties":{"_yoast_wpseo_focuskw":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"_helpful_status":{"type":"integer","title":"","description":"","default":1},"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","cloud-template-preview",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]}},"required":false},"sticky":{"description":"\u6295\u7a3f\u3092\u5148\u982d\u56fa\u5b9a\u8868\u793a\u306b\u3059\u308b\u304b\u3069\u3046\u304b\u3002","type":"boolean","required":false},"template":{"description":"\u6295\u7a3f\u3092\u8868\u793a\u3059\u308b\u305f\u3081\u306b\u4f7f\u7528\u3059\u308b\u30c6\u30fc\u30de\u30d5\u30a1\u30a4\u30eb\u3002","type":"string","required":false},"categories":{"description":"\u30bf\u30af\u30bd\u30ce\u30df\u30fc\u300ccategory\u300d\u306b\u5c5e\u3057\u3001\u305d\u306e\u6295\u7a3f\u306b\u5272\u308a\u5f53\u3066\u3089\u308c\u3066\u3044\u308b\u30bf\u30fc\u30e0\u3002","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"\u30bf\u30af\u30bd\u30ce\u30df\u30fc\u300cpost_tag\u300d\u306b\u5c5e\u3057\u3001\u305d\u306e\u6295\u7a3f\u306b\u5272\u308a\u5f53\u3066\u3089\u308c\u3066\u3044\u308b\u30bf\u30fc\u30e0\u3002","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts"}]}},"\/wp\/v2\/posts\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6295\u7a3f\u306e\u4e00\u610f\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"\u30c7\u30d5\u30a9\u30eb\u30c8\u306e\u629c\u7c8b\u306e\u9577\u3055\u3092\u4e0a\u66f8\u304d\u3057\u307e\u3059\u3002","type":"integer","required":false},"password":{"description":"\u30d1\u30b9\u30ef\u30fc\u30c9\u3067\u4fdd\u8b77\u3055\u308c\u3066\u3044\u308b\u5834\u5408\u306e\u6295\u7a3f\u306e\u30d1\u30b9\u30ef\u30fc\u30c9\u3002","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6295\u7a3f\u306e\u4e00\u610f\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"date":{"description":"\u6295\u7a3f\u306e\u516c\u958b\u65e5 (\u30b5\u30a4\u30c8\u306e\u30bf\u30a4\u30e0\u30be\u30fc\u30f3)\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u6295\u7a3f\u306e\u516c\u958b\u65e5 (GMT)\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u305d\u306e\u30bf\u30a4\u30d7\u306b\u7279\u6709\u306a\u3001\u6295\u7a3f\u306e\u82f1\u6570\u5b57\u8b58\u5225\u5b50\u3002","type":"string","required":false},"status":{"description":"\u6295\u7a3f\u306b\u5bfe\u3057\u3066\u540d\u524d\u304c\u3064\u3044\u3066\u3044\u308b\u30b9\u30c6\u30fc\u30bf\u30b9\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u30b3\u30f3\u30c6\u30f3\u30c4\u3084\u629c\u7c8b\u3078\u306e\u30a2\u30af\u30bb\u30b9\u3092\u4fdd\u8b77\u3059\u308b\u30d1\u30b9\u30ef\u30fc\u30c9\u3002","type":"string","required":false},"title":{"description":"\u6295\u7a3f\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":"object","properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u5f62\u614b\u306e\u3001\u6295\u7a3f\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u8868\u793a\u7528\u306b\u6574\u5f62\u3055\u308c\u305f\u3001\u6295\u7a3f\u306e HTML \u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"\u6295\u7a3f\u306e\u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":"object","properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u5f62\u614b\u306e\u3001\u6295\u7a3f\u306e\u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u8868\u793a\u7528\u306b\u5909\u63db\u3055\u308c\u305f\u3001\u6295\u7a3f\u306e HTML \u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"\u6295\u7a3f\u304c\u4f7f\u7528\u3059\u308b\u30b3\u30f3\u30c6\u30f3\u30c4\u30d6\u30ed\u30c3\u30af\u5f62\u5f0f\u306e\u30d0\u30fc\u30b8\u30e7\u30f3\u3002","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u30b3\u30f3\u30c6\u30f3\u30c4\u3092\u30d1\u30b9\u30ef\u30fc\u30c9\u3067\u4fdd\u8b77\u3059\u308b\u304b\u3069\u3046\u304b\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"\u6295\u7a3f\u8005\u306e ID\u3002","type":"integer","required":false},"excerpt":{"description":"\u6295\u7a3f\u306e\u629c\u7c8b\u3002","type":"object","properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u5f62\u614b\u306e\u3001\u6295\u7a3f\u306e\u629c\u7c8b\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u8868\u793a\u7528\u306b\u5909\u63db\u3055\u308c\u305f\u3001\u6295\u7a3f\u306e HTML \u306e\u629c\u7c8b\u3002","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"\u629c\u7c8b\u304c\u30d1\u30b9\u30ef\u30fc\u30c9\u3067\u4fdd\u8b77\u3055\u308c\u3066\u3044\u308b\u304b\u3069\u3046\u304b\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"\u6295\u7a3f\u306e\u30a2\u30a4\u30ad\u30e3\u30c3\u30c1\u3068\u306a\u308b\u30e1\u30c7\u30a3\u30a2\u306e ID\u3002","type":"integer","required":false},"comment_status":{"description":"\u6295\u7a3f\u304c\u30b3\u30e1\u30f3\u30c8\u3092\u53d7\u3051\u4ed8\u3051\u3066\u3044\u308b\u304b\u3069\u3046\u304b\u3002","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"\u6295\u7a3f\u304c\u30d4\u30f3\u30d0\u30c3\u30af\u3092\u53d7\u3051\u4ed8\u3051\u3066\u3044\u308b\u304b\u3069\u3046\u304b\u3002","type":"string","enum":["open","closed"],"required":false},"format":{"description":"\u6295\u7a3f\u306e\u30d5\u30a9\u30fc\u30de\u30c3\u30c8\u3002","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"\u30e1\u30bf\u30d5\u30a3\u30fc\u30eb\u30c9\u3002","type":"object","properties":{"_yoast_wpseo_focuskw":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"_helpful_status":{"type":"integer","title":"","description":"","default":1},"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","cloud-template-preview",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]}},"required":false},"sticky":{"description":"\u6295\u7a3f\u3092\u5148\u982d\u56fa\u5b9a\u8868\u793a\u306b\u3059\u308b\u304b\u3069\u3046\u304b\u3002","type":"boolean","required":false},"template":{"description":"\u6295\u7a3f\u3092\u8868\u793a\u3059\u308b\u305f\u3081\u306b\u4f7f\u7528\u3059\u308b\u30c6\u30fc\u30de\u30d5\u30a1\u30a4\u30eb\u3002","type":"string","required":false},"categories":{"description":"\u30bf\u30af\u30bd\u30ce\u30df\u30fc\u300ccategory\u300d\u306b\u5c5e\u3057\u3001\u305d\u306e\u6295\u7a3f\u306b\u5272\u308a\u5f53\u3066\u3089\u308c\u3066\u3044\u308b\u30bf\u30fc\u30e0\u3002","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"\u30bf\u30af\u30bd\u30ce\u30df\u30fc\u300cpost_tag\u300d\u306b\u5c5e\u3057\u3001\u305d\u306e\u6295\u7a3f\u306b\u5272\u308a\u5f53\u3066\u3089\u308c\u3066\u3044\u308b\u30bf\u30fc\u30e0\u3002","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6295\u7a3f\u306e\u4e00\u610f\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u30b4\u30df\u7bb1\u306b\u5165\u308c\u305a\u306b\u5f37\u5236\u7684\u306b\u524a\u9664\u3059\u308b\u304b\u3069\u3046\u304b\u3002","required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u89aa\u30ea\u30d3\u30b8\u30e7\u30f3\u306e ID\u3002","type":"integer","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u306e\u73fe\u5728\u306e\u30da\u30fc\u30b8\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u3068\u3057\u3066\u8fd4\u3055\u308c\u308b\u9805\u76ee\u306e\u6700\u5927\u6570\u3002","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"\u6587\u5b57\u5217\u306b\u4e00\u81f4\u3059\u308b\u3082\u306e\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","required":false},"exclude":{"description":"\u7279\u5b9a\u306e ID \u3092\u7d50\u679c\u304b\u3089\u9664\u5916\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u7279\u5b9a\u306e ID \u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u7279\u5b9a\u306e\u9805\u76ee\u6570\u3067\u7d50\u679c\u3092\u30aa\u30d5\u30bb\u30c3\u30c8\u3057\u307e\u3059\u3002","type":"integer","required":false},"order":{"description":"\u5c5e\u6027\u3067\u6607\u9806\u307e\u305f\u306f\u964d\u9806\u306b\u4e26\u3079\u66ff\u3048\u307e\u3059\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u30aa\u30d6\u30b8\u30a7\u30af\u30c8\u5c5e\u6027\u3067\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u3092\u4e26\u3073\u66ff\u3048\u307e\u3059\u3002","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u89aa\u30ea\u30d3\u30b8\u30e7\u30f3\u306e ID\u3002","type":"integer","required":false},"id":{"description":"\u30ea\u30d3\u30b8\u30e7\u30f3\u306e\u56fa\u6709\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"\u89aa\u30ea\u30d3\u30b8\u30e7\u30f3\u306e ID\u3002","type":"integer","required":false},"id":{"description":"\u30ea\u30d3\u30b8\u30e7\u30f3\u306e\u56fa\u6709\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u30ea\u30d3\u30b8\u30e7\u30f3\u304c\u30b4\u30df\u7bb1\u6a5f\u80fd\u306b\u5bfe\u5fdc\u3057\u3066\u3044\u306a\u3044\u305f\u3081\u3001true \u3067\u306a\u3051\u308c\u3070\u306a\u308a\u307e\u305b\u3093\u3002","required":false}}}]},"\/wp\/v2\/posts\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u89aa\u81ea\u52d5\u4fdd\u5b58\u306e ID\u3002","type":"integer","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"\u89aa\u81ea\u52d5\u4fdd\u5b58\u306e ID\u3002","type":"integer","required":false},"date":{"description":"\u6295\u7a3f\u306e\u516c\u958b\u65e5 (\u30b5\u30a4\u30c8\u306e\u30bf\u30a4\u30e0\u30be\u30fc\u30f3)\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u6295\u7a3f\u306e\u516c\u958b\u65e5 (GMT)\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u305d\u306e\u30bf\u30a4\u30d7\u306b\u7279\u6709\u306a\u3001\u6295\u7a3f\u306e\u82f1\u6570\u5b57\u8b58\u5225\u5b50\u3002","type":"string","required":false},"status":{"description":"\u6295\u7a3f\u306b\u5bfe\u3057\u3066\u540d\u524d\u304c\u3064\u3044\u3066\u3044\u308b\u30b9\u30c6\u30fc\u30bf\u30b9\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u30b3\u30f3\u30c6\u30f3\u30c4\u3084\u629c\u7c8b\u3078\u306e\u30a2\u30af\u30bb\u30b9\u3092\u4fdd\u8b77\u3059\u308b\u30d1\u30b9\u30ef\u30fc\u30c9\u3002","type":"string","required":false},"title":{"description":"\u6295\u7a3f\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":"object","properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u5f62\u614b\u306e\u3001\u6295\u7a3f\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u8868\u793a\u7528\u306b\u6574\u5f62\u3055\u308c\u305f\u3001\u6295\u7a3f\u306e HTML \u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"\u6295\u7a3f\u306e\u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":"object","properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u5f62\u614b\u306e\u3001\u6295\u7a3f\u306e\u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u8868\u793a\u7528\u306b\u5909\u63db\u3055\u308c\u305f\u3001\u6295\u7a3f\u306e HTML \u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"\u6295\u7a3f\u304c\u4f7f\u7528\u3059\u308b\u30b3\u30f3\u30c6\u30f3\u30c4\u30d6\u30ed\u30c3\u30af\u5f62\u5f0f\u306e\u30d0\u30fc\u30b8\u30e7\u30f3\u3002","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u30b3\u30f3\u30c6\u30f3\u30c4\u3092\u30d1\u30b9\u30ef\u30fc\u30c9\u3067\u4fdd\u8b77\u3059\u308b\u304b\u3069\u3046\u304b\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"\u6295\u7a3f\u8005\u306e ID\u3002","type":"integer","required":false},"excerpt":{"description":"\u6295\u7a3f\u306e\u629c\u7c8b\u3002","type":"object","properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u5f62\u614b\u306e\u3001\u6295\u7a3f\u306e\u629c\u7c8b\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u8868\u793a\u7528\u306b\u5909\u63db\u3055\u308c\u305f\u3001\u6295\u7a3f\u306e HTML \u306e\u629c\u7c8b\u3002","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"\u629c\u7c8b\u304c\u30d1\u30b9\u30ef\u30fc\u30c9\u3067\u4fdd\u8b77\u3055\u308c\u3066\u3044\u308b\u304b\u3069\u3046\u304b\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"\u6295\u7a3f\u306e\u30a2\u30a4\u30ad\u30e3\u30c3\u30c1\u3068\u306a\u308b\u30e1\u30c7\u30a3\u30a2\u306e ID\u3002","type":"integer","required":false},"comment_status":{"description":"\u6295\u7a3f\u304c\u30b3\u30e1\u30f3\u30c8\u3092\u53d7\u3051\u4ed8\u3051\u3066\u3044\u308b\u304b\u3069\u3046\u304b\u3002","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"\u6295\u7a3f\u304c\u30d4\u30f3\u30d0\u30c3\u30af\u3092\u53d7\u3051\u4ed8\u3051\u3066\u3044\u308b\u304b\u3069\u3046\u304b\u3002","type":"string","enum":["open","closed"],"required":false},"format":{"description":"\u6295\u7a3f\u306e\u30d5\u30a9\u30fc\u30de\u30c3\u30c8\u3002","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"\u30e1\u30bf\u30d5\u30a3\u30fc\u30eb\u30c9\u3002","type":"object","properties":{"_yoast_wpseo_focuskw":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"_helpful_status":{"type":"integer","title":"","description":"","default":1},"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","cloud-template-preview",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]}},"required":false},"sticky":{"description":"\u6295\u7a3f\u3092\u5148\u982d\u56fa\u5b9a\u8868\u793a\u306b\u3059\u308b\u304b\u3069\u3046\u304b\u3002","type":"boolean","required":false},"template":{"description":"\u6295\u7a3f\u3092\u8868\u793a\u3059\u308b\u305f\u3081\u306b\u4f7f\u7528\u3059\u308b\u30c6\u30fc\u30de\u30d5\u30a1\u30a4\u30eb\u3002","type":"string","required":false},"categories":{"description":"\u30bf\u30af\u30bd\u30ce\u30df\u30fc\u300ccategory\u300d\u306b\u5c5e\u3057\u3001\u305d\u306e\u6295\u7a3f\u306b\u5272\u308a\u5f53\u3066\u3089\u308c\u3066\u3044\u308b\u30bf\u30fc\u30e0\u3002","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"\u30bf\u30af\u30bd\u30ce\u30df\u30fc\u300cpost_tag\u300d\u306b\u5c5e\u3057\u3001\u305d\u306e\u6295\u7a3f\u306b\u5272\u308a\u5f53\u3066\u3089\u308c\u3066\u3044\u308b\u30bf\u30fc\u30e0\u3002","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u89aa\u81ea\u52d5\u4fdd\u5b58\u306e ID\u3002","type":"integer","required":false},"id":{"description":"\u81ea\u52d5\u4fdd\u5b58\u306e ID\u3002","type":"integer","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/pages":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u306e\u73fe\u5728\u306e\u30da\u30fc\u30b8\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u3068\u3057\u3066\u8fd4\u3055\u308c\u308b\u9805\u76ee\u306e\u6700\u5927\u6570\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u6587\u5b57\u5217\u306b\u4e00\u81f4\u3059\u308b\u3082\u306e\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","required":false},"after":{"description":"\u5165\u529b\u3055\u308c\u305f ISO8601 \u6e96\u62e0\u306e\u65e5\u4ed8\u3088\u308a\u5f8c\u306b\u516c\u958b\u3055\u308c\u305f\u6295\u7a3f\u306b\u30ec\u30b9\u30dd\u30f3\u30b9\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","format":"date-time","required":false},"modified_after":{"description":"\u5165\u529b\u3055\u308c\u305f ISO8601 \u6e96\u62e0\u306e\u65e5\u4ed8\u3088\u308a\u5f8c\u306b\u66f4\u65b0\u3055\u308c\u305f\u6295\u7a3f\u306b\u30ec\u30b9\u30dd\u30f3\u30b9\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","format":"date-time","required":false},"author":{"description":"\u7279\u5b9a\u306e\u6295\u7a3f\u8005\u306b\u5272\u308a\u5f53\u3066\u3089\u308c\u305f\u6295\u7a3f\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"\u7279\u5b9a\u306e\u6295\u7a3f\u8005\u304c\u5272\u308a\u5f53\u3066\u3089\u308c\u305f\u6295\u7a3f\u3092\u7d50\u679c\u304b\u3089\u9664\u5916\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"\u5165\u529b\u3055\u308c\u305f ISO8601 \u6e96\u62e0\u306e\u65e5\u4ed8\u3088\u308a\u524d\u306b\u516c\u958b\u3055\u308c\u305f\u6295\u7a3f\u306b\u30ec\u30b9\u30dd\u30f3\u30b9\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","format":"date-time","required":false},"modified_before":{"description":"\u5165\u529b\u3055\u308c\u305f ISO8601 \u6e96\u62e0\u306e\u65e5\u4ed8\u3088\u308a\u524d\u306b\u66f4\u65b0\u3055\u308c\u305f\u6295\u7a3f\u306b\u30ec\u30b9\u30dd\u30f3\u30b9\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","format":"date-time","required":false},"exclude":{"description":"\u7279\u5b9a\u306e ID \u3092\u7d50\u679c\u304b\u3089\u9664\u5916\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u7279\u5b9a\u306e ID \u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"\u7279\u5b9a\u306e menu_order \u5024\u3092\u6301\u3064\u6295\u7a3f\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"integer","required":false},"search_semantics":{"description":"\u691c\u7d22\u5165\u529b\u3092\u89e3\u91c8\u3059\u308b\u65b9\u6cd5\u3067\u3059\u3002","type":"string","enum":["exact"],"required":false},"offset":{"description":"\u7279\u5b9a\u306e\u9805\u76ee\u6570\u3067\u7d50\u679c\u3092\u30aa\u30d5\u30bb\u30c3\u30c8\u3057\u307e\u3059\u3002","type":"integer","required":false},"order":{"description":"\u5c5e\u6027\u3067\u6607\u9806\u307e\u305f\u306f\u964d\u9806\u306b\u4e26\u3079\u66ff\u3048\u307e\u3059\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6295\u7a3f\u306e\u5c5e\u6027\u3067\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u3092\u4e26\u3079\u66ff\u3048\u307e\u3059\u3002","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"parent":{"description":"\u7279\u5b9a\u306e\u89aa ID \u306b\u5c5e\u3059\u308b\u9805\u76ee\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"\u7279\u5b9a\u306e\u89aa ID \u306b\u5c5e\u3055\u306a\u3044\u9805\u76ee\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"\u691c\u7d22\u3059\u308b\u5217\u540d\u306e\u914d\u5217\u3002","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"\u4e00\u3064\u4ee5\u4e0a\u306e\u7279\u5b9a\u306e\u30b9\u30e9\u30c3\u30b0\u3092\u6301\u3064\u6295\u7a3f\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"\u4e00\u3064\u4ee5\u4e0a\u306e\u30b9\u30c6\u30fc\u30bf\u30b9\u304c\u5272\u308a\u5f53\u3066\u3089\u308c\u305f\u6295\u7a3f\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"\u6295\u7a3f\u306e\u516c\u958b\u65e5 (\u30b5\u30a4\u30c8\u306e\u30bf\u30a4\u30e0\u30be\u30fc\u30f3)\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u6295\u7a3f\u306e\u516c\u958b\u65e5 (GMT)\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u305d\u306e\u30bf\u30a4\u30d7\u306b\u7279\u6709\u306a\u3001\u6295\u7a3f\u306e\u82f1\u6570\u5b57\u8b58\u5225\u5b50\u3002","type":"string","required":false},"status":{"description":"\u6295\u7a3f\u306b\u5bfe\u3057\u3066\u540d\u524d\u304c\u3064\u3044\u3066\u3044\u308b\u30b9\u30c6\u30fc\u30bf\u30b9\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u30b3\u30f3\u30c6\u30f3\u30c4\u3084\u629c\u7c8b\u3078\u306e\u30a2\u30af\u30bb\u30b9\u3092\u4fdd\u8b77\u3059\u308b\u30d1\u30b9\u30ef\u30fc\u30c9\u3002","type":"string","required":false},"parent":{"description":"\u89aa\u6295\u7a3f\u306e ID\u3002","type":"integer","required":false},"title":{"description":"\u6295\u7a3f\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":"object","properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u5f62\u614b\u306e\u3001\u6295\u7a3f\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u8868\u793a\u7528\u306b\u6574\u5f62\u3055\u308c\u305f\u3001\u6295\u7a3f\u306e HTML \u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"\u6295\u7a3f\u306e\u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":"object","properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u5f62\u614b\u306e\u3001\u6295\u7a3f\u306e\u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u8868\u793a\u7528\u306b\u5909\u63db\u3055\u308c\u305f\u3001\u6295\u7a3f\u306e HTML \u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"\u6295\u7a3f\u304c\u4f7f\u7528\u3059\u308b\u30b3\u30f3\u30c6\u30f3\u30c4\u30d6\u30ed\u30c3\u30af\u5f62\u5f0f\u306e\u30d0\u30fc\u30b8\u30e7\u30f3\u3002","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u30b3\u30f3\u30c6\u30f3\u30c4\u3092\u30d1\u30b9\u30ef\u30fc\u30c9\u3067\u4fdd\u8b77\u3059\u308b\u304b\u3069\u3046\u304b\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"\u6295\u7a3f\u8005\u306e ID\u3002","type":"integer","required":false},"excerpt":{"description":"\u6295\u7a3f\u306e\u629c\u7c8b\u3002","type":"object","properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u5f62\u614b\u306e\u3001\u6295\u7a3f\u306e\u629c\u7c8b\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u8868\u793a\u7528\u306b\u5909\u63db\u3055\u308c\u305f\u3001\u6295\u7a3f\u306e HTML \u306e\u629c\u7c8b\u3002","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"\u629c\u7c8b\u304c\u30d1\u30b9\u30ef\u30fc\u30c9\u3067\u4fdd\u8b77\u3055\u308c\u3066\u3044\u308b\u304b\u3069\u3046\u304b\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"\u6295\u7a3f\u306e\u30a2\u30a4\u30ad\u30e3\u30c3\u30c1\u3068\u306a\u308b\u30e1\u30c7\u30a3\u30a2\u306e ID\u3002","type":"integer","required":false},"comment_status":{"description":"\u6295\u7a3f\u304c\u30b3\u30e1\u30f3\u30c8\u3092\u53d7\u3051\u4ed8\u3051\u3066\u3044\u308b\u304b\u3069\u3046\u304b\u3002","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"\u6295\u7a3f\u304c\u30d4\u30f3\u30d0\u30c3\u30af\u3092\u53d7\u3051\u4ed8\u3051\u3066\u3044\u308b\u304b\u3069\u3046\u304b\u3002","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"\u4ed6\u306e\u6295\u7a3f\u3068\u306e\u95a2\u9023\u306b\u3088\u308b\u3001\u6295\u7a3f\u306e\u9806\u756a\u3002","type":"integer","required":false},"meta":{"description":"\u30e1\u30bf\u30d5\u30a3\u30fc\u30eb\u30c9\u3002","type":"object","properties":{"_helpful_status":{"type":"integer","title":"","description":"","default":1},"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","cloud-template-preview",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"\u6295\u7a3f\u3092\u8868\u793a\u3059\u308b\u305f\u3081\u306b\u4f7f\u7528\u3059\u308b\u30c6\u30fc\u30de\u30d5\u30a1\u30a4\u30eb\u3002","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/pages"}]}},"\/wp\/v2\/pages\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6295\u7a3f\u306e\u4e00\u610f\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"\u30c7\u30d5\u30a9\u30eb\u30c8\u306e\u629c\u7c8b\u306e\u9577\u3055\u3092\u4e0a\u66f8\u304d\u3057\u307e\u3059\u3002","type":"integer","required":false},"password":{"description":"\u30d1\u30b9\u30ef\u30fc\u30c9\u3067\u4fdd\u8b77\u3055\u308c\u3066\u3044\u308b\u5834\u5408\u306e\u6295\u7a3f\u306e\u30d1\u30b9\u30ef\u30fc\u30c9\u3002","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6295\u7a3f\u306e\u4e00\u610f\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"date":{"description":"\u6295\u7a3f\u306e\u516c\u958b\u65e5 (\u30b5\u30a4\u30c8\u306e\u30bf\u30a4\u30e0\u30be\u30fc\u30f3)\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u6295\u7a3f\u306e\u516c\u958b\u65e5 (GMT)\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u305d\u306e\u30bf\u30a4\u30d7\u306b\u7279\u6709\u306a\u3001\u6295\u7a3f\u306e\u82f1\u6570\u5b57\u8b58\u5225\u5b50\u3002","type":"string","required":false},"status":{"description":"\u6295\u7a3f\u306b\u5bfe\u3057\u3066\u540d\u524d\u304c\u3064\u3044\u3066\u3044\u308b\u30b9\u30c6\u30fc\u30bf\u30b9\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u30b3\u30f3\u30c6\u30f3\u30c4\u3084\u629c\u7c8b\u3078\u306e\u30a2\u30af\u30bb\u30b9\u3092\u4fdd\u8b77\u3059\u308b\u30d1\u30b9\u30ef\u30fc\u30c9\u3002","type":"string","required":false},"parent":{"description":"\u89aa\u6295\u7a3f\u306e ID\u3002","type":"integer","required":false},"title":{"description":"\u6295\u7a3f\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":"object","properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u5f62\u614b\u306e\u3001\u6295\u7a3f\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u8868\u793a\u7528\u306b\u6574\u5f62\u3055\u308c\u305f\u3001\u6295\u7a3f\u306e HTML \u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"\u6295\u7a3f\u306e\u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":"object","properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u5f62\u614b\u306e\u3001\u6295\u7a3f\u306e\u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u8868\u793a\u7528\u306b\u5909\u63db\u3055\u308c\u305f\u3001\u6295\u7a3f\u306e HTML \u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"\u6295\u7a3f\u304c\u4f7f\u7528\u3059\u308b\u30b3\u30f3\u30c6\u30f3\u30c4\u30d6\u30ed\u30c3\u30af\u5f62\u5f0f\u306e\u30d0\u30fc\u30b8\u30e7\u30f3\u3002","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u30b3\u30f3\u30c6\u30f3\u30c4\u3092\u30d1\u30b9\u30ef\u30fc\u30c9\u3067\u4fdd\u8b77\u3059\u308b\u304b\u3069\u3046\u304b\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"\u6295\u7a3f\u8005\u306e ID\u3002","type":"integer","required":false},"excerpt":{"description":"\u6295\u7a3f\u306e\u629c\u7c8b\u3002","type":"object","properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u5f62\u614b\u306e\u3001\u6295\u7a3f\u306e\u629c\u7c8b\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u8868\u793a\u7528\u306b\u5909\u63db\u3055\u308c\u305f\u3001\u6295\u7a3f\u306e HTML \u306e\u629c\u7c8b\u3002","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"\u629c\u7c8b\u304c\u30d1\u30b9\u30ef\u30fc\u30c9\u3067\u4fdd\u8b77\u3055\u308c\u3066\u3044\u308b\u304b\u3069\u3046\u304b\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"\u6295\u7a3f\u306e\u30a2\u30a4\u30ad\u30e3\u30c3\u30c1\u3068\u306a\u308b\u30e1\u30c7\u30a3\u30a2\u306e ID\u3002","type":"integer","required":false},"comment_status":{"description":"\u6295\u7a3f\u304c\u30b3\u30e1\u30f3\u30c8\u3092\u53d7\u3051\u4ed8\u3051\u3066\u3044\u308b\u304b\u3069\u3046\u304b\u3002","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"\u6295\u7a3f\u304c\u30d4\u30f3\u30d0\u30c3\u30af\u3092\u53d7\u3051\u4ed8\u3051\u3066\u3044\u308b\u304b\u3069\u3046\u304b\u3002","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"\u4ed6\u306e\u6295\u7a3f\u3068\u306e\u95a2\u9023\u306b\u3088\u308b\u3001\u6295\u7a3f\u306e\u9806\u756a\u3002","type":"integer","required":false},"meta":{"description":"\u30e1\u30bf\u30d5\u30a3\u30fc\u30eb\u30c9\u3002","type":"object","properties":{"_helpful_status":{"type":"integer","title":"","description":"","default":1},"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","cloud-template-preview",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"\u6295\u7a3f\u3092\u8868\u793a\u3059\u308b\u305f\u3081\u306b\u4f7f\u7528\u3059\u308b\u30c6\u30fc\u30de\u30d5\u30a1\u30a4\u30eb\u3002","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6295\u7a3f\u306e\u4e00\u610f\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u30b4\u30df\u7bb1\u306b\u5165\u308c\u305a\u306b\u5f37\u5236\u7684\u306b\u524a\u9664\u3059\u308b\u304b\u3069\u3046\u304b\u3002","required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u89aa\u30ea\u30d3\u30b8\u30e7\u30f3\u306e ID\u3002","type":"integer","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u306e\u73fe\u5728\u306e\u30da\u30fc\u30b8\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u3068\u3057\u3066\u8fd4\u3055\u308c\u308b\u9805\u76ee\u306e\u6700\u5927\u6570\u3002","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"\u6587\u5b57\u5217\u306b\u4e00\u81f4\u3059\u308b\u3082\u306e\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","required":false},"exclude":{"description":"\u7279\u5b9a\u306e ID \u3092\u7d50\u679c\u304b\u3089\u9664\u5916\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u7279\u5b9a\u306e ID \u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u7279\u5b9a\u306e\u9805\u76ee\u6570\u3067\u7d50\u679c\u3092\u30aa\u30d5\u30bb\u30c3\u30c8\u3057\u307e\u3059\u3002","type":"integer","required":false},"order":{"description":"\u5c5e\u6027\u3067\u6607\u9806\u307e\u305f\u306f\u964d\u9806\u306b\u4e26\u3079\u66ff\u3048\u307e\u3059\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u30aa\u30d6\u30b8\u30a7\u30af\u30c8\u5c5e\u6027\u3067\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u3092\u4e26\u3073\u66ff\u3048\u307e\u3059\u3002","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u89aa\u30ea\u30d3\u30b8\u30e7\u30f3\u306e ID\u3002","type":"integer","required":false},"id":{"description":"\u30ea\u30d3\u30b8\u30e7\u30f3\u306e\u56fa\u6709\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"\u89aa\u30ea\u30d3\u30b8\u30e7\u30f3\u306e ID\u3002","type":"integer","required":false},"id":{"description":"\u30ea\u30d3\u30b8\u30e7\u30f3\u306e\u56fa\u6709\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u30ea\u30d3\u30b8\u30e7\u30f3\u304c\u30b4\u30df\u7bb1\u6a5f\u80fd\u306b\u5bfe\u5fdc\u3057\u3066\u3044\u306a\u3044\u305f\u3081\u3001true \u3067\u306a\u3051\u308c\u3070\u306a\u308a\u307e\u305b\u3093\u3002","required":false}}}]},"\/wp\/v2\/pages\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u89aa\u81ea\u52d5\u4fdd\u5b58\u306e ID\u3002","type":"integer","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"\u89aa\u6295\u7a3f\u306e ID\u3002","type":"integer","required":false},"date":{"description":"\u6295\u7a3f\u306e\u516c\u958b\u65e5 (\u30b5\u30a4\u30c8\u306e\u30bf\u30a4\u30e0\u30be\u30fc\u30f3)\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u6295\u7a3f\u306e\u516c\u958b\u65e5 (GMT)\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u305d\u306e\u30bf\u30a4\u30d7\u306b\u7279\u6709\u306a\u3001\u6295\u7a3f\u306e\u82f1\u6570\u5b57\u8b58\u5225\u5b50\u3002","type":"string","required":false},"status":{"description":"\u6295\u7a3f\u306b\u5bfe\u3057\u3066\u540d\u524d\u304c\u3064\u3044\u3066\u3044\u308b\u30b9\u30c6\u30fc\u30bf\u30b9\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u30b3\u30f3\u30c6\u30f3\u30c4\u3084\u629c\u7c8b\u3078\u306e\u30a2\u30af\u30bb\u30b9\u3092\u4fdd\u8b77\u3059\u308b\u30d1\u30b9\u30ef\u30fc\u30c9\u3002","type":"string","required":false},"title":{"description":"\u6295\u7a3f\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":"object","properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u5f62\u614b\u306e\u3001\u6295\u7a3f\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u8868\u793a\u7528\u306b\u6574\u5f62\u3055\u308c\u305f\u3001\u6295\u7a3f\u306e HTML \u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"\u6295\u7a3f\u306e\u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":"object","properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u5f62\u614b\u306e\u3001\u6295\u7a3f\u306e\u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u8868\u793a\u7528\u306b\u5909\u63db\u3055\u308c\u305f\u3001\u6295\u7a3f\u306e HTML \u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"\u6295\u7a3f\u304c\u4f7f\u7528\u3059\u308b\u30b3\u30f3\u30c6\u30f3\u30c4\u30d6\u30ed\u30c3\u30af\u5f62\u5f0f\u306e\u30d0\u30fc\u30b8\u30e7\u30f3\u3002","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u30b3\u30f3\u30c6\u30f3\u30c4\u3092\u30d1\u30b9\u30ef\u30fc\u30c9\u3067\u4fdd\u8b77\u3059\u308b\u304b\u3069\u3046\u304b\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"\u6295\u7a3f\u8005\u306e ID\u3002","type":"integer","required":false},"excerpt":{"description":"\u6295\u7a3f\u306e\u629c\u7c8b\u3002","type":"object","properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u5f62\u614b\u306e\u3001\u6295\u7a3f\u306e\u629c\u7c8b\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u8868\u793a\u7528\u306b\u5909\u63db\u3055\u308c\u305f\u3001\u6295\u7a3f\u306e HTML \u306e\u629c\u7c8b\u3002","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"\u629c\u7c8b\u304c\u30d1\u30b9\u30ef\u30fc\u30c9\u3067\u4fdd\u8b77\u3055\u308c\u3066\u3044\u308b\u304b\u3069\u3046\u304b\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"\u6295\u7a3f\u306e\u30a2\u30a4\u30ad\u30e3\u30c3\u30c1\u3068\u306a\u308b\u30e1\u30c7\u30a3\u30a2\u306e ID\u3002","type":"integer","required":false},"comment_status":{"description":"\u6295\u7a3f\u304c\u30b3\u30e1\u30f3\u30c8\u3092\u53d7\u3051\u4ed8\u3051\u3066\u3044\u308b\u304b\u3069\u3046\u304b\u3002","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"\u6295\u7a3f\u304c\u30d4\u30f3\u30d0\u30c3\u30af\u3092\u53d7\u3051\u4ed8\u3051\u3066\u3044\u308b\u304b\u3069\u3046\u304b\u3002","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"\u4ed6\u306e\u6295\u7a3f\u3068\u306e\u95a2\u9023\u306b\u3088\u308b\u3001\u6295\u7a3f\u306e\u9806\u756a\u3002","type":"integer","required":false},"meta":{"description":"\u30e1\u30bf\u30d5\u30a3\u30fc\u30eb\u30c9\u3002","type":"object","properties":{"_helpful_status":{"type":"integer","title":"","description":"","default":1},"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","cloud-template-preview",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"\u6295\u7a3f\u3092\u8868\u793a\u3059\u308b\u305f\u3081\u306b\u4f7f\u7528\u3059\u308b\u30c6\u30fc\u30de\u30d5\u30a1\u30a4\u30eb\u3002","type":"string","required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u89aa\u81ea\u52d5\u4fdd\u5b58\u306e ID\u3002","type":"integer","required":false},"id":{"description":"\u81ea\u52d5\u4fdd\u5b58\u306e ID\u3002","type":"integer","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/media":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u306e\u73fe\u5728\u306e\u30da\u30fc\u30b8\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u3068\u3057\u3066\u8fd4\u3055\u308c\u308b\u9805\u76ee\u306e\u6700\u5927\u6570\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u6587\u5b57\u5217\u306b\u4e00\u81f4\u3059\u308b\u3082\u306e\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","required":false},"after":{"description":"\u5165\u529b\u3055\u308c\u305f ISO8601 \u6e96\u62e0\u306e\u65e5\u4ed8\u3088\u308a\u5f8c\u306b\u516c\u958b\u3055\u308c\u305f\u6295\u7a3f\u306b\u30ec\u30b9\u30dd\u30f3\u30b9\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","format":"date-time","required":false},"modified_after":{"description":"\u5165\u529b\u3055\u308c\u305f ISO8601 \u6e96\u62e0\u306e\u65e5\u4ed8\u3088\u308a\u5f8c\u306b\u66f4\u65b0\u3055\u308c\u305f\u6295\u7a3f\u306b\u30ec\u30b9\u30dd\u30f3\u30b9\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","format":"date-time","required":false},"author":{"description":"\u7279\u5b9a\u306e\u6295\u7a3f\u8005\u306b\u5272\u308a\u5f53\u3066\u3089\u308c\u305f\u6295\u7a3f\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"\u7279\u5b9a\u306e\u6295\u7a3f\u8005\u304c\u5272\u308a\u5f53\u3066\u3089\u308c\u305f\u6295\u7a3f\u3092\u7d50\u679c\u304b\u3089\u9664\u5916\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"\u5165\u529b\u3055\u308c\u305f ISO8601 \u6e96\u62e0\u306e\u65e5\u4ed8\u3088\u308a\u524d\u306b\u516c\u958b\u3055\u308c\u305f\u6295\u7a3f\u306b\u30ec\u30b9\u30dd\u30f3\u30b9\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","format":"date-time","required":false},"modified_before":{"description":"\u5165\u529b\u3055\u308c\u305f ISO8601 \u6e96\u62e0\u306e\u65e5\u4ed8\u3088\u308a\u524d\u306b\u66f4\u65b0\u3055\u308c\u305f\u6295\u7a3f\u306b\u30ec\u30b9\u30dd\u30f3\u30b9\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","format":"date-time","required":false},"exclude":{"description":"\u7279\u5b9a\u306e ID \u3092\u7d50\u679c\u304b\u3089\u9664\u5916\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u7279\u5b9a\u306e ID \u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"\u691c\u7d22\u5165\u529b\u3092\u89e3\u91c8\u3059\u308b\u65b9\u6cd5\u3067\u3059\u3002","type":"string","enum":["exact"],"required":false},"offset":{"description":"\u7279\u5b9a\u306e\u9805\u76ee\u6570\u3067\u7d50\u679c\u3092\u30aa\u30d5\u30bb\u30c3\u30c8\u3057\u307e\u3059\u3002","type":"integer","required":false},"order":{"description":"\u5c5e\u6027\u3067\u6607\u9806\u307e\u305f\u306f\u964d\u9806\u306b\u4e26\u3079\u66ff\u3048\u307e\u3059\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6295\u7a3f\u306e\u5c5e\u6027\u3067\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u3092\u4e26\u3079\u66ff\u3048\u307e\u3059\u3002","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"parent":{"description":"\u7279\u5b9a\u306e\u89aa ID \u306b\u5c5e\u3059\u308b\u9805\u76ee\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"\u7279\u5b9a\u306e\u89aa ID \u306b\u5c5e\u3055\u306a\u3044\u9805\u76ee\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"\u691c\u7d22\u3059\u308b\u5217\u540d\u306e\u914d\u5217\u3002","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"\u4e00\u3064\u4ee5\u4e0a\u306e\u7279\u5b9a\u306e\u30b9\u30e9\u30c3\u30b0\u3092\u6301\u3064\u6295\u7a3f\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"type":"string"},"required":false},"status":{"default":"inherit","description":"\u4e00\u3064\u4ee5\u4e0a\u306e\u30b9\u30c6\u30fc\u30bf\u30b9\u304c\u5272\u308a\u5f53\u3066\u3089\u308c\u305f\u6295\u7a3f\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"enum":["inherit","private","trash"],"type":"string"},"required":false},"media_type":{"default":null,"description":"\u7279\u5b9a\u306e\u30e1\u30c7\u30a3\u30a2\u30bf\u30a4\u30d7\u306e\u6dfb\u4ed8\u30d5\u30a1\u30a4\u30eb\u306b\u7d50\u679c\u30bb\u30c3\u30c8\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"type":"string","enum":["image","video","text","application","audio"]},"required":false},"mime_type":{"default":null,"description":"\u7279\u5b9a\u306e MIME \u30bf\u30a4\u30d7\u306e\u6dfb\u4ed8\u30d5\u30a1\u30a4\u30eb\u306b\u7d50\u679c\u30bb\u30c3\u30c8\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"date":{"description":"\u6295\u7a3f\u306e\u516c\u958b\u65e5 (\u30b5\u30a4\u30c8\u306e\u30bf\u30a4\u30e0\u30be\u30fc\u30f3)\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u6295\u7a3f\u306e\u516c\u958b\u65e5 (GMT)\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u305d\u306e\u30bf\u30a4\u30d7\u306b\u7279\u6709\u306a\u3001\u6295\u7a3f\u306e\u82f1\u6570\u5b57\u8b58\u5225\u5b50\u3002","type":"string","required":false},"status":{"description":"\u6295\u7a3f\u306b\u5bfe\u3057\u3066\u540d\u524d\u304c\u3064\u3044\u3066\u3044\u308b\u30b9\u30c6\u30fc\u30bf\u30b9\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"title":{"description":"\u6295\u7a3f\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":"object","properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u5f62\u614b\u306e\u3001\u6295\u7a3f\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u8868\u793a\u7528\u306b\u6574\u5f62\u3055\u308c\u305f\u3001\u6295\u7a3f\u306e HTML \u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"\u6295\u7a3f\u8005\u306e ID\u3002","type":"integer","required":false},"featured_media":{"description":"\u6295\u7a3f\u306e\u30a2\u30a4\u30ad\u30e3\u30c3\u30c1\u3068\u306a\u308b\u30e1\u30c7\u30a3\u30a2\u306e ID\u3002","type":"integer","required":false},"comment_status":{"description":"\u6295\u7a3f\u304c\u30b3\u30e1\u30f3\u30c8\u3092\u53d7\u3051\u4ed8\u3051\u3066\u3044\u308b\u304b\u3069\u3046\u304b\u3002","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"\u6295\u7a3f\u304c\u30d4\u30f3\u30d0\u30c3\u30af\u3092\u53d7\u3051\u4ed8\u3051\u3066\u3044\u308b\u304b\u3069\u3046\u304b\u3002","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"\u30e1\u30bf\u30d5\u30a3\u30fc\u30eb\u30c9\u3002","type":"object","properties":{"_helpful_status":{"type":"integer","title":"","description":"","default":1}},"required":false},"template":{"description":"\u6295\u7a3f\u3092\u8868\u793a\u3059\u308b\u305f\u3081\u306b\u4f7f\u7528\u3059\u308b\u30c6\u30fc\u30de\u30d5\u30a1\u30a4\u30eb\u3002","type":"string","required":false},"alt_text":{"description":"\u6dfb\u4ed8\u30d5\u30a1\u30a4\u30eb\u304c\u8868\u793a\u3055\u308c\u306a\u3044\u3068\u304d\u306b\u8868\u793a\u3059\u308b\u4ee3\u66ff\u30c6\u30ad\u30b9\u30c8\u3002","type":"string","required":false},"caption":{"description":"\u6dfb\u4ed8\u30d5\u30a1\u30a4\u30eb\u306e\u30ad\u30e3\u30d7\u30b7\u30e7\u30f3\u3002","type":"object","properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u5f62\u614b\u306e\u3001\u6dfb\u4ed8\u30d5\u30a1\u30a4\u30eb\u306e\u30ad\u30e3\u30d7\u30b7\u30e7\u30f3\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u8868\u793a\u7528\u306b\u5909\u63db\u3055\u308c\u305f\u3001\u6dfb\u4ed8\u30d5\u30a1\u30a4\u30eb\u306e HTML \u30ad\u30e3\u30d7\u30b7\u30e7\u30f3\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"\u6dfb\u4ed8\u30d5\u30a1\u30a4\u30eb\u306e\u8aac\u660e\u3002","type":"object","properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u5f62\u614b\u306e\u3001\u6dfb\u4ed8\u30d5\u30a1\u30a4\u30eb\u306e\u8aac\u660e\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u8868\u793a\u7528\u306b\u5909\u63db\u3055\u308c\u305f\u3001\u6dfb\u4ed8\u30d5\u30a1\u30a4\u30eb\u306e HTML \u306e\u8aac\u660e\u3002","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"\u6dfb\u4ed8\u30d5\u30a1\u30a4\u30eb\u306e\u95a2\u9023\u6295\u7a3f\u306e ID\u3002","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/media"}]}},"\/wp\/v2\/media\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u6295\u7a3f\u306e\u4e00\u610f\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"\u6295\u7a3f\u306e\u4e00\u610f\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"date":{"description":"\u6295\u7a3f\u306e\u516c\u958b\u65e5 (\u30b5\u30a4\u30c8\u306e\u30bf\u30a4\u30e0\u30be\u30fc\u30f3)\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u6295\u7a3f\u306e\u516c\u958b\u65e5 (GMT)\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u305d\u306e\u30bf\u30a4\u30d7\u306b\u7279\u6709\u306a\u3001\u6295\u7a3f\u306e\u82f1\u6570\u5b57\u8b58\u5225\u5b50\u3002","type":"string","required":false},"status":{"description":"\u6295\u7a3f\u306b\u5bfe\u3057\u3066\u540d\u524d\u304c\u3064\u3044\u3066\u3044\u308b\u30b9\u30c6\u30fc\u30bf\u30b9\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"title":{"description":"\u6295\u7a3f\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":"object","properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u5f62\u614b\u306e\u3001\u6295\u7a3f\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u8868\u793a\u7528\u306b\u6574\u5f62\u3055\u308c\u305f\u3001\u6295\u7a3f\u306e HTML \u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"\u6295\u7a3f\u8005\u306e ID\u3002","type":"integer","required":false},"featured_media":{"description":"\u6295\u7a3f\u306e\u30a2\u30a4\u30ad\u30e3\u30c3\u30c1\u3068\u306a\u308b\u30e1\u30c7\u30a3\u30a2\u306e ID\u3002","type":"integer","required":false},"comment_status":{"description":"\u6295\u7a3f\u304c\u30b3\u30e1\u30f3\u30c8\u3092\u53d7\u3051\u4ed8\u3051\u3066\u3044\u308b\u304b\u3069\u3046\u304b\u3002","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"\u6295\u7a3f\u304c\u30d4\u30f3\u30d0\u30c3\u30af\u3092\u53d7\u3051\u4ed8\u3051\u3066\u3044\u308b\u304b\u3069\u3046\u304b\u3002","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"\u30e1\u30bf\u30d5\u30a3\u30fc\u30eb\u30c9\u3002","type":"object","properties":{"_helpful_status":{"type":"integer","title":"","description":"","default":1}},"required":false},"template":{"description":"\u6295\u7a3f\u3092\u8868\u793a\u3059\u308b\u305f\u3081\u306b\u4f7f\u7528\u3059\u308b\u30c6\u30fc\u30de\u30d5\u30a1\u30a4\u30eb\u3002","type":"string","required":false},"alt_text":{"description":"\u6dfb\u4ed8\u30d5\u30a1\u30a4\u30eb\u304c\u8868\u793a\u3055\u308c\u306a\u3044\u3068\u304d\u306b\u8868\u793a\u3059\u308b\u4ee3\u66ff\u30c6\u30ad\u30b9\u30c8\u3002","type":"string","required":false},"caption":{"description":"\u6dfb\u4ed8\u30d5\u30a1\u30a4\u30eb\u306e\u30ad\u30e3\u30d7\u30b7\u30e7\u30f3\u3002","type":"object","properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u5f62\u614b\u306e\u3001\u6dfb\u4ed8\u30d5\u30a1\u30a4\u30eb\u306e\u30ad\u30e3\u30d7\u30b7\u30e7\u30f3\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u8868\u793a\u7528\u306b\u5909\u63db\u3055\u308c\u305f\u3001\u6dfb\u4ed8\u30d5\u30a1\u30a4\u30eb\u306e HTML \u30ad\u30e3\u30d7\u30b7\u30e7\u30f3\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"\u6dfb\u4ed8\u30d5\u30a1\u30a4\u30eb\u306e\u8aac\u660e\u3002","type":"object","properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u5f62\u614b\u306e\u3001\u6dfb\u4ed8\u30d5\u30a1\u30a4\u30eb\u306e\u8aac\u660e\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u8868\u793a\u7528\u306b\u5909\u63db\u3055\u308c\u305f\u3001\u6dfb\u4ed8\u30d5\u30a1\u30a4\u30eb\u306e HTML \u306e\u8aac\u660e\u3002","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"\u6dfb\u4ed8\u30d5\u30a1\u30a4\u30eb\u306e\u95a2\u9023\u6295\u7a3f\u306e ID\u3002","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"\u6295\u7a3f\u306e\u4e00\u610f\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u30b4\u30df\u7bb1\u306b\u5165\u308c\u305a\u306b\u5f37\u5236\u7684\u306b\u524a\u9664\u3059\u308b\u304b\u3069\u3046\u304b\u3002","required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/post-process":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"\u6dfb\u4ed8\u30d5\u30a1\u30a4\u30eb\u306e\u4e00\u610f\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"action":{"type":"string","enum":["create-image-subsizes"],"required":true}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/edit":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"src":{"description":"\u7de8\u96c6\u3055\u308c\u305f\u753b\u50cf\u30d5\u30a1\u30a4\u30eb\u306e URL\u3002","type":"string","format":"uri","required":true},"modifiers":{"description":"\u753b\u50cf\u7de8\u96c6\u306e\u914d\u5217\u3002","type":"array","minItems":1,"items":{"description":"\u753b\u50cf\u7de8\u96c6\u3002","type":"object","required":["type","args"],"oneOf":[{"title":"\u53cd\u8ee2","properties":{"type":{"description":"\u53cd\u8ee2\u30bf\u30a4\u30d7\u3002","type":"string","enum":["flip"]},"args":{"description":"\u53cd\u8ee2\u306e\u5f15\u6570\u3002","type":"object","required":["flip"],"properties":{"flip":{"description":"\u5411\u304d\u3092\u53cd\u8ee2\u3002","type":"object","required":["horizontal","vertical"],"properties":{"horizontal":{"description":"\u6c34\u5e73\u65b9\u5411\u306b\u53cd\u8ee2\u3059\u308b\u304b\u3069\u3046\u304b\u3002","type":"boolean"},"vertical":{"description":"\u5782\u76f4\u65b9\u5411\u306b\u53cd\u8ee2\u3059\u308b\u304b\u3069\u3046\u304b\u3002","type":"boolean"}}}}}}},{"title":"\u56de\u8ee2","properties":{"type":{"description":"\u56de\u8ee2\u306e\u30bf\u30a4\u30d7\u3002","type":"string","enum":["rotate"]},"args":{"description":"\u56de\u8ee2\u306e\u5f15\u6570\u3002","type":"object","required":["angle"],"properties":{"angle":{"description":"\u6642\u8a08\u56de\u308a\u306b\u56de\u8ee2\u3059\u308b\u89d2\u5ea6\u3002","type":"number"}}}}},{"title":"\u5207\u308a\u629c\u304d","properties":{"type":{"description":"\u5207\u308a\u629c\u304d\u306e\u7a2e\u985e\u3002","type":"string","enum":["crop"]},"args":{"description":"\u5207\u308a\u629c\u304d\u306e\u5f15\u6570\u3002","type":"object","required":["left","top","width","height"],"properties":{"left":{"description":"\u753b\u50cf\u306e\u5e45\u306b\u5bfe\u3059\u308b\u3001\u5207\u308a\u629c\u304d\u3092\u958b\u59cb\u3059\u308b\u5de6\u304b\u3089\u306e\u6c34\u5e73\u4f4d\u7f6e\u306e\u30d1\u30fc\u30bb\u30f3\u30c8\u6307\u5b9a\u3002","type":"number"},"top":{"description":"\u753b\u50cf\u306e\u9ad8\u3055\u306b\u5bfe\u3059\u308b\u3001\u5207\u308a\u629c\u304d\u3092\u958b\u59cb\u3059\u308b\u4e0a\u304b\u3089\u306e\u5782\u76f4\u4f4d\u7f6e\u306e\u30d1\u30fc\u30bb\u30f3\u30c8\u6307\u5b9a\u3002","type":"number"},"width":{"description":"\u5143\u306e\u753b\u50cf\u306b\u5bfe\u3059\u308b\u3001\u5207\u308a\u629c\u304f\u753b\u50cf\u306e\u5e45\u306e\u30d1\u30fc\u30bb\u30f3\u30c8\u6307\u5b9a\u3002","type":"number"},"height":{"description":"\u5143\u306e\u753b\u50cf\u306b\u5bfe\u3059\u308b\u3001\u5207\u308a\u629c\u304f\u753b\u50cf\u306e\u9ad8\u3055\u306e\u30d1\u30fc\u30bb\u30f3\u30c8\u6307\u5b9a\u3002","type":"number"}}}}}]},"required":false},"rotation":{"description":"\u56de\u8ee2\u3059\u308b\u753b\u50cf\u306e\u6642\u8a08\u56de\u308a\u306e\u89d2\u5ea6\u3002\u975e\u63a8\u5968: \u4ee3\u308f\u308a\u306b `modifiers` \u3092\u4f7f\u7528\u3057\u3066\u304f\u3060\u3055\u3044\u3002","type":"integer","minimum":0,"exclusiveMinimum":true,"maximum":360,"exclusiveMaximum":true,"required":false},"x":{"description":"\u5143\u306e\u753b\u50cf\u306b\u5bfe\u3059\u308b\u3001\u5207\u308a\u629c\u304f\u958b\u59cb\u4f4d\u7f6e\u306e x \u5ea7\u6a19\u306e\u30d1\u30fc\u30bb\u30f3\u30c8\u6307\u5b9a\u3002\u975e\u63a8\u5968: \u4ee3\u308f\u308a\u306b `modifiers` \u3092\u4f7f\u7528\u3057\u3066\u304f\u3060\u3055\u3044\u3002","type":"number","minimum":0,"maximum":100,"required":false},"y":{"description":"\u5143\u306e\u753b\u50cf\u306b\u5bfe\u3059\u308b\u3001\u5207\u308a\u629c\u304f\u958b\u59cb\u4f4d\u7f6e\u306e y \u5ea7\u6a19\u306e\u30d1\u30fc\u30bb\u30f3\u30c8\u6307\u5b9a\u3002\u975e\u63a8\u5968: \u4ee3\u308f\u308a\u306b `modifiers` \u3092\u4f7f\u7528\u3057\u3066\u304f\u3060\u3055\u3044\u3002","type":"number","minimum":0,"maximum":100,"required":false},"width":{"description":"\u5143\u306e\u753b\u50cf\u306b\u5bfe\u3059\u308b\u3001\u5207\u308a\u629c\u304f\u753b\u50cf\u306e\u5e45\u306e\u30d1\u30fc\u30bb\u30f3\u30c8\u6307\u5b9a\u3002\u975e\u63a8\u5968: \u4ee3\u308f\u308a\u306b `modifiers` \u3092\u4f7f\u7528\u3057\u3066\u304f\u3060\u3055\u3044\u3002","type":"number","minimum":0,"maximum":100,"required":false},"height":{"description":"\u5143\u306e\u753b\u50cf\u306b\u5bfe\u3059\u308b\u3001\u5207\u308a\u629c\u304f\u753b\u50cf\u306e\u9ad8\u3055\u306e\u30d1\u30fc\u30bb\u30f3\u30c8\u6307\u5b9a\u3002\u975e\u63a8\u5968: \u4ee3\u308f\u308a\u306b `modifiers` \u3092\u4f7f\u7528\u3057\u3066\u304f\u3060\u3055\u3044\u3002","type":"number","minimum":0,"maximum":100,"required":false},"caption":{"description":"\u6dfb\u4ed8\u30d5\u30a1\u30a4\u30eb\u306e\u30ad\u30e3\u30d7\u30b7\u30e7\u30f3\u3002","type":"object","properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u5f62\u614b\u306e\u3001\u6dfb\u4ed8\u30d5\u30a1\u30a4\u30eb\u306e\u30ad\u30e3\u30d7\u30b7\u30e7\u30f3\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u8868\u793a\u7528\u306b\u5909\u63db\u3055\u308c\u305f\u3001\u6dfb\u4ed8\u30d5\u30a1\u30a4\u30eb\u306e HTML \u30ad\u30e3\u30d7\u30b7\u30e7\u30f3\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"\u6dfb\u4ed8\u30d5\u30a1\u30a4\u30eb\u306e\u8aac\u660e\u3002","type":"object","properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u5f62\u614b\u306e\u3001\u6dfb\u4ed8\u30d5\u30a1\u30a4\u30eb\u306e\u8aac\u660e\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u8868\u793a\u7528\u306b\u5909\u63db\u3055\u308c\u305f\u3001\u6dfb\u4ed8\u30d5\u30a1\u30a4\u30eb\u306e HTML \u306e\u8aac\u660e\u3002","type":"string","context":["view","edit"],"readonly":true}},"required":false},"title":{"description":"\u6295\u7a3f\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":"object","properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u5f62\u614b\u306e\u3001\u6295\u7a3f\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u8868\u793a\u7528\u306b\u6574\u5f62\u3055\u308c\u305f\u3001\u6295\u7a3f\u306e HTML \u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"post":{"description":"\u6dfb\u4ed8\u30d5\u30a1\u30a4\u30eb\u306e\u95a2\u9023\u6295\u7a3f\u306e ID\u3002","type":"integer","required":false},"alt_text":{"description":"\u6dfb\u4ed8\u30d5\u30a1\u30a4\u30eb\u304c\u8868\u793a\u3055\u308c\u306a\u3044\u3068\u304d\u306b\u8868\u793a\u3059\u308b\u4ee3\u66ff\u30c6\u30ad\u30b9\u30c8\u3002","type":"string","required":false}}}]},"\/wp\/v2\/menu-items":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u306e\u73fe\u5728\u306e\u30da\u30fc\u30b8\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u3068\u3057\u3066\u8fd4\u3055\u308c\u308b\u9805\u76ee\u306e\u6700\u5927\u6570\u3002","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u6587\u5b57\u5217\u306b\u4e00\u81f4\u3059\u308b\u3082\u306e\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","required":false},"after":{"description":"\u5165\u529b\u3055\u308c\u305f ISO8601 \u6e96\u62e0\u306e\u65e5\u4ed8\u3088\u308a\u5f8c\u306b\u516c\u958b\u3055\u308c\u305f\u6295\u7a3f\u306b\u30ec\u30b9\u30dd\u30f3\u30b9\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","format":"date-time","required":false},"modified_after":{"description":"\u5165\u529b\u3055\u308c\u305f ISO8601 \u6e96\u62e0\u306e\u65e5\u4ed8\u3088\u308a\u5f8c\u306b\u66f4\u65b0\u3055\u308c\u305f\u6295\u7a3f\u306b\u30ec\u30b9\u30dd\u30f3\u30b9\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","format":"date-time","required":false},"before":{"description":"\u5165\u529b\u3055\u308c\u305f ISO8601 \u6e96\u62e0\u306e\u65e5\u4ed8\u3088\u308a\u524d\u306b\u516c\u958b\u3055\u308c\u305f\u6295\u7a3f\u306b\u30ec\u30b9\u30dd\u30f3\u30b9\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","format":"date-time","required":false},"modified_before":{"description":"\u5165\u529b\u3055\u308c\u305f ISO8601 \u6e96\u62e0\u306e\u65e5\u4ed8\u3088\u308a\u524d\u306b\u66f4\u65b0\u3055\u308c\u305f\u6295\u7a3f\u306b\u30ec\u30b9\u30dd\u30f3\u30b9\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","format":"date-time","required":false},"exclude":{"description":"\u7279\u5b9a\u306e ID \u3092\u7d50\u679c\u304b\u3089\u9664\u5916\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u7279\u5b9a\u306e ID \u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"\u691c\u7d22\u5165\u529b\u3092\u89e3\u91c8\u3059\u308b\u65b9\u6cd5\u3067\u3059\u3002","type":"string","enum":["exact"],"required":false},"offset":{"description":"\u7279\u5b9a\u306e\u9805\u76ee\u6570\u3067\u7d50\u679c\u3092\u30aa\u30d5\u30bb\u30c3\u30c8\u3057\u307e\u3059\u3002","type":"integer","required":false},"order":{"description":"\u5c5e\u6027\u3067\u6607\u9806\u307e\u305f\u306f\u964d\u9806\u306b\u4e26\u3079\u66ff\u3048\u307e\u3059\u3002","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u30aa\u30d6\u30b8\u30a7\u30af\u30c8\u5c5e\u6027\u3067\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u3092\u4e26\u3073\u66ff\u3048\u307e\u3059\u3002","type":"string","default":"menu_order","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"\u691c\u7d22\u3059\u308b\u5217\u540d\u306e\u914d\u5217\u3002","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"\u4e00\u3064\u4ee5\u4e0a\u306e\u7279\u5b9a\u306e\u30b9\u30e9\u30c3\u30b0\u3092\u6301\u3064\u6295\u7a3f\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"\u4e00\u3064\u4ee5\u4e0a\u306e\u30b9\u30c6\u30fc\u30bf\u30b9\u304c\u5272\u308a\u5f53\u3066\u3089\u308c\u305f\u6295\u7a3f\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"\u8907\u6570\u306e\u30bf\u30af\u30bd\u30ce\u30df\u30fc\u9593\u306e\u95a2\u4fc2\u306b\u57fa\u3065\u3044\u3066\u7d50\u679c\u30bb\u30c3\u30c8\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","enum":["AND","OR"],"required":false},"menus":{"description":"\u300cmenus\u300d\u30bf\u30af\u30bd\u30ce\u30df\u30fc\u306b\u5272\u308a\u5f53\u3066\u3089\u308c\u305f\u7279\u5b9a\u306e\u30bf\u30fc\u30e0\u3092\u6301\u3064\u9805\u76ee\u306b\u7d50\u679c\u30bb\u30c3\u30c8\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":["object","array"],"oneOf":[{"title":"\u30bf\u30fc\u30e0 ID \u4e00\u89a7","description":"\u30ea\u30b9\u30c8\u3057\u305f ID \u3068\u5408\u81f4\u3059\u308b\u30bf\u30fc\u30e0\u3002","type":"array","items":{"type":"integer"}},{"title":"\u30bf\u30fc\u30e0 ID \u30bf\u30af\u30bd\u30ce\u30df\u30fc\u30af\u30a8\u30ea\u30fc","description":"\u9ad8\u5ea6\u306a\u30bf\u30fc\u30e0\u30af\u30a8\u30ea\u30fc\u3092\u5b9f\u884c\u3057\u307e\u3059\u3002","type":"object","properties":{"terms":{"description":"\u30bf\u30fc\u30e0 ID\u3002","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"\u7279\u5b9a\u306e\u30bf\u30fc\u30e0\u306e\u3059\u3079\u3066\u306b\u9805\u76ee\u3092\u5272\u308a\u5f53\u3066\u308b\u304b\u3001\u4e00\u90e8\u306b\u5272\u308a\u5f53\u3066\u308b\u304b\u3002","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"menus_exclude":{"description":"\u300cmenus\u300d\u30bf\u30af\u30bd\u30ce\u30df\u30fc\u306b\u5272\u308a\u5f53\u3066\u3089\u308c\u305f\u7279\u5b9a\u306e\u30bf\u30fc\u30e0\u3092\u6301\u3064\u9805\u76ee\u4ee5\u5916\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":["object","array"],"oneOf":[{"title":"\u30bf\u30fc\u30e0 ID \u4e00\u89a7","description":"\u30ea\u30b9\u30c8\u3057\u305f ID \u3068\u5408\u81f4\u3059\u308b\u30bf\u30fc\u30e0\u3002","type":"array","items":{"type":"integer"}},{"title":"\u30bf\u30fc\u30e0 ID \u30bf\u30af\u30bd\u30ce\u30df\u30fc\u30af\u30a8\u30ea\u30fc","description":"\u9ad8\u5ea6\u306a\u30bf\u30fc\u30e0\u30af\u30a8\u30ea\u30fc\u3092\u5b9f\u884c\u3057\u307e\u3059\u3002","type":"object","properties":{"terms":{"description":"\u30bf\u30fc\u30e0 ID\u3002","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"menu_order":{"description":"\u7279\u5b9a\u306e menu_order \u5024\u3092\u6301\u3064\u6295\u7a3f\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"integer","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"title":{"description":"\u30aa\u30d6\u30b8\u30a7\u30af\u30c8\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":["string","object"],"properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u5f62\u614b\u306e\u3001\u30aa\u30d6\u30b8\u30a7\u30af\u30c8\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u8868\u793a\u7528\u306b\u6574\u5f62\u3055\u308c\u305f\u3001\u30aa\u30d6\u30b8\u30a7\u30af\u30c8\u306e HTML \u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"default":"custom","description":"\"post_type\" \u3084 \"taxonomy\" \u306e\u3088\u3046\u306b\u3001\u5143\u3005\u8868\u308f\u3055\u308c\u3066\u3044\u305f\u30aa\u30d6\u30b8\u30a7\u30af\u30c8\u306e\u30d5\u30a1\u30df\u30ea\u30fc\u3002","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"default":"publish","description":"\u30aa\u30d6\u30b8\u30a7\u30af\u30c8\u306b\u5bfe\u3057\u3066\u540d\u524d\u304c\u3064\u3044\u3066\u3044\u308b\u30b9\u30c6\u30fc\u30bf\u30b9\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"parent":{"default":0,"description":"\u89aa\u30aa\u30d6\u30b8\u30a7\u30af\u30c8\u306e ID\u3002","type":"integer","minimum":0,"required":false},"attr_title":{"description":"\u3053\u306e\u30e1\u30cb\u30e5\u30fc\u9805\u76ee\u306e\u30ea\u30f3\u30af\u8981\u7d20\u306e\u30bf\u30a4\u30c8\u30eb\u5c5e\u6027\u306e\u30c6\u30ad\u30b9\u30c8\u3002","type":"string","required":false},"classes":{"description":"\u3053\u306e\u30e1\u30cb\u30e5\u30fc\u9805\u76ee\u306e\u30ea\u30f3\u30af\u8981\u7d20\u306e\u30af\u30e9\u30b9\u540d\u3002","type":"array","items":{"type":"string"},"required":false},"description":{"description":"\u3053\u306e\u30e1\u30cb\u30e5\u30fc\u9805\u76ee\u306e\u8aac\u660e\u3002","type":"string","required":false},"menu_order":{"default":1,"description":"\u3053\u306e\u9805\u76ee\u306e\u89aa\u30e1\u30cb\u30e5\u30fc\u3067\u3042\u308b nav_menu_item \u306e DB ID (\u3082\u3057\u3042\u308c\u3070)\u3002\u306a\u3044\u5834\u5408\u306f0\u3002","type":"integer","minimum":1,"required":false},"object":{"description":"\u300c\u30ab\u30c6\u30b4\u30ea\u30fc\u300d\u3001\u300c\u6295\u7a3f\u300d\u3001\u300c\u6dfb\u4ed8\u30d5\u30a1\u30a4\u30eb\u300d\u306a\u3069\u3001\u5143\u3005\u8868\u308f\u3055\u308c\u3066\u3044\u305f\u30aa\u30d6\u30b8\u30a7\u30af\u30c8\u306e\u30bf\u30a4\u30d7\u3002","type":"string","required":false},"object_id":{"default":0,"description":"\u3053\u306e\u30e1\u30cb\u30e5\u30fc\u9805\u76ee\u304c\u8868\u3059\u5143\u306e\u30aa\u30d6\u30b8\u30a7\u30af\u30c8\u306e\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9 ID\u3002\u4f8b: \u6295\u7a3f\u306e ID \u3084\u30ab\u30c6\u30b4\u30ea\u30fc\u306e term_id\u3002","type":"integer","minimum":0,"required":false},"target":{"description":"\u3053\u306e\u30e1\u30cb\u30e5\u30fc\u9805\u76ee\u306e\u30ea\u30f3\u30af\u8981\u7d20\u306e\u30bf\u30fc\u30b2\u30c3\u30c8\u5c5e\u6027\u3002","type":"string","enum":["_blank",""],"required":false},"url":{"description":"\u3053\u306e\u30e1\u30cb\u30e5\u30fc\u9805\u76ee\u304c\u6307\u3059 URL\u3002","type":"string","format":"uri","required":false},"xfn":{"description":"\u3053\u306e\u30e1\u30cb\u30e5\u30fc\u9805\u76ee\u306e\u30ea\u30f3\u30af\u3067\u8868\u73fe\u3055\u308c\u305f XFN \u95a2\u4fc2\u3002","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"\u30bf\u30af\u30bd\u30ce\u30df\u30fc\u300cnav_menu\u300d\u306b\u5c5e\u3057\u3001\u305d\u306e\u30aa\u30d6\u30b8\u30a7\u30af\u30c8\u306b\u5272\u308a\u5f53\u3066\u3089\u308c\u3066\u3044\u308b\u30bf\u30fc\u30e0\u3002","type":"integer","required":false},"meta":{"description":"\u30e1\u30bf\u30d5\u30a3\u30fc\u30eb\u30c9\u3002","type":"object","properties":{"_helpful_status":{"type":"integer","title":"","description":"","default":1}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/menu-items"}]}},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6295\u7a3f\u306e\u4e00\u610f\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6295\u7a3f\u306e\u4e00\u610f\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"title":{"description":"\u30aa\u30d6\u30b8\u30a7\u30af\u30c8\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":["string","object"],"properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u5f62\u614b\u306e\u3001\u30aa\u30d6\u30b8\u30a7\u30af\u30c8\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u8868\u793a\u7528\u306b\u6574\u5f62\u3055\u308c\u305f\u3001\u30aa\u30d6\u30b8\u30a7\u30af\u30c8\u306e HTML \u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"\"post_type\" \u3084 \"taxonomy\" \u306e\u3088\u3046\u306b\u3001\u5143\u3005\u8868\u308f\u3055\u308c\u3066\u3044\u305f\u30aa\u30d6\u30b8\u30a7\u30af\u30c8\u306e\u30d5\u30a1\u30df\u30ea\u30fc\u3002","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"\u30aa\u30d6\u30b8\u30a7\u30af\u30c8\u306b\u5bfe\u3057\u3066\u540d\u524d\u304c\u3064\u3044\u3066\u3044\u308b\u30b9\u30c6\u30fc\u30bf\u30b9\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"parent":{"description":"\u89aa\u30aa\u30d6\u30b8\u30a7\u30af\u30c8\u306e ID\u3002","type":"integer","minimum":0,"required":false},"attr_title":{"description":"\u3053\u306e\u30e1\u30cb\u30e5\u30fc\u9805\u76ee\u306e\u30ea\u30f3\u30af\u8981\u7d20\u306e\u30bf\u30a4\u30c8\u30eb\u5c5e\u6027\u306e\u30c6\u30ad\u30b9\u30c8\u3002","type":"string","required":false},"classes":{"description":"\u3053\u306e\u30e1\u30cb\u30e5\u30fc\u9805\u76ee\u306e\u30ea\u30f3\u30af\u8981\u7d20\u306e\u30af\u30e9\u30b9\u540d\u3002","type":"array","items":{"type":"string"},"required":false},"description":{"description":"\u3053\u306e\u30e1\u30cb\u30e5\u30fc\u9805\u76ee\u306e\u8aac\u660e\u3002","type":"string","required":false},"menu_order":{"description":"\u3053\u306e\u9805\u76ee\u306e\u89aa\u30e1\u30cb\u30e5\u30fc\u3067\u3042\u308b nav_menu_item \u306e DB ID (\u3082\u3057\u3042\u308c\u3070)\u3002\u306a\u3044\u5834\u5408\u306f0\u3002","type":"integer","minimum":1,"required":false},"object":{"description":"\u300c\u30ab\u30c6\u30b4\u30ea\u30fc\u300d\u3001\u300c\u6295\u7a3f\u300d\u3001\u300c\u6dfb\u4ed8\u30d5\u30a1\u30a4\u30eb\u300d\u306a\u3069\u3001\u5143\u3005\u8868\u308f\u3055\u308c\u3066\u3044\u305f\u30aa\u30d6\u30b8\u30a7\u30af\u30c8\u306e\u30bf\u30a4\u30d7\u3002","type":"string","required":false},"object_id":{"description":"\u3053\u306e\u30e1\u30cb\u30e5\u30fc\u9805\u76ee\u304c\u8868\u3059\u5143\u306e\u30aa\u30d6\u30b8\u30a7\u30af\u30c8\u306e\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9 ID\u3002\u4f8b: \u6295\u7a3f\u306e ID \u3084\u30ab\u30c6\u30b4\u30ea\u30fc\u306e term_id\u3002","type":"integer","minimum":0,"required":false},"target":{"description":"\u3053\u306e\u30e1\u30cb\u30e5\u30fc\u9805\u76ee\u306e\u30ea\u30f3\u30af\u8981\u7d20\u306e\u30bf\u30fc\u30b2\u30c3\u30c8\u5c5e\u6027\u3002","type":"string","enum":["_blank",""],"required":false},"url":{"description":"\u3053\u306e\u30e1\u30cb\u30e5\u30fc\u9805\u76ee\u304c\u6307\u3059 URL\u3002","type":"string","format":"uri","required":false},"xfn":{"description":"\u3053\u306e\u30e1\u30cb\u30e5\u30fc\u9805\u76ee\u306e\u30ea\u30f3\u30af\u3067\u8868\u73fe\u3055\u308c\u305f XFN \u95a2\u4fc2\u3002","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"\u30bf\u30af\u30bd\u30ce\u30df\u30fc\u300cnav_menu\u300d\u306b\u5c5e\u3057\u3001\u305d\u306e\u30aa\u30d6\u30b8\u30a7\u30af\u30c8\u306b\u5272\u308a\u5f53\u3066\u3089\u308c\u3066\u3044\u308b\u30bf\u30fc\u30e0\u3002","type":"integer","required":false},"meta":{"description":"\u30e1\u30bf\u30d5\u30a3\u30fc\u30eb\u30c9\u3002","type":"object","properties":{"_helpful_status":{"type":"integer","title":"","description":"","default":1}},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6295\u7a3f\u306e\u4e00\u610f\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u30b4\u30df\u7bb1\u306b\u5165\u308c\u305a\u306b\u5f37\u5236\u7684\u306b\u524a\u9664\u3059\u308b\u304b\u3069\u3046\u304b\u3002","required":false}}}]},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u89aa\u81ea\u52d5\u4fdd\u5b58\u306e ID\u3002","type":"integer","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"\u89aa\u30aa\u30d6\u30b8\u30a7\u30af\u30c8\u306e ID\u3002","type":"integer","minimum":0,"required":false},"title":{"description":"\u30aa\u30d6\u30b8\u30a7\u30af\u30c8\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":["string","object"],"properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u5f62\u614b\u306e\u3001\u30aa\u30d6\u30b8\u30a7\u30af\u30c8\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u8868\u793a\u7528\u306b\u6574\u5f62\u3055\u308c\u305f\u3001\u30aa\u30d6\u30b8\u30a7\u30af\u30c8\u306e HTML \u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"\"post_type\" \u3084 \"taxonomy\" \u306e\u3088\u3046\u306b\u3001\u5143\u3005\u8868\u308f\u3055\u308c\u3066\u3044\u305f\u30aa\u30d6\u30b8\u30a7\u30af\u30c8\u306e\u30d5\u30a1\u30df\u30ea\u30fc\u3002","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"\u30aa\u30d6\u30b8\u30a7\u30af\u30c8\u306b\u5bfe\u3057\u3066\u540d\u524d\u304c\u3064\u3044\u3066\u3044\u308b\u30b9\u30c6\u30fc\u30bf\u30b9\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"attr_title":{"description":"\u3053\u306e\u30e1\u30cb\u30e5\u30fc\u9805\u76ee\u306e\u30ea\u30f3\u30af\u8981\u7d20\u306e\u30bf\u30a4\u30c8\u30eb\u5c5e\u6027\u306e\u30c6\u30ad\u30b9\u30c8\u3002","type":"string","required":false},"classes":{"description":"\u3053\u306e\u30e1\u30cb\u30e5\u30fc\u9805\u76ee\u306e\u30ea\u30f3\u30af\u8981\u7d20\u306e\u30af\u30e9\u30b9\u540d\u3002","type":"array","items":{"type":"string"},"required":false},"description":{"description":"\u3053\u306e\u30e1\u30cb\u30e5\u30fc\u9805\u76ee\u306e\u8aac\u660e\u3002","type":"string","required":false},"menu_order":{"description":"\u3053\u306e\u9805\u76ee\u306e\u89aa\u30e1\u30cb\u30e5\u30fc\u3067\u3042\u308b nav_menu_item \u306e DB ID (\u3082\u3057\u3042\u308c\u3070)\u3002\u306a\u3044\u5834\u5408\u306f0\u3002","type":"integer","minimum":1,"required":false},"object":{"description":"\u300c\u30ab\u30c6\u30b4\u30ea\u30fc\u300d\u3001\u300c\u6295\u7a3f\u300d\u3001\u300c\u6dfb\u4ed8\u30d5\u30a1\u30a4\u30eb\u300d\u306a\u3069\u3001\u5143\u3005\u8868\u308f\u3055\u308c\u3066\u3044\u305f\u30aa\u30d6\u30b8\u30a7\u30af\u30c8\u306e\u30bf\u30a4\u30d7\u3002","type":"string","required":false},"object_id":{"description":"\u3053\u306e\u30e1\u30cb\u30e5\u30fc\u9805\u76ee\u304c\u8868\u3059\u5143\u306e\u30aa\u30d6\u30b8\u30a7\u30af\u30c8\u306e\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9 ID\u3002\u4f8b: \u6295\u7a3f\u306e ID \u3084\u30ab\u30c6\u30b4\u30ea\u30fc\u306e term_id\u3002","type":"integer","minimum":0,"required":false},"target":{"description":"\u3053\u306e\u30e1\u30cb\u30e5\u30fc\u9805\u76ee\u306e\u30ea\u30f3\u30af\u8981\u7d20\u306e\u30bf\u30fc\u30b2\u30c3\u30c8\u5c5e\u6027\u3002","type":"string","enum":["_blank",""],"required":false},"url":{"description":"\u3053\u306e\u30e1\u30cb\u30e5\u30fc\u9805\u76ee\u304c\u6307\u3059 URL\u3002","type":"string","format":"uri","required":false},"xfn":{"description":"\u3053\u306e\u30e1\u30cb\u30e5\u30fc\u9805\u76ee\u306e\u30ea\u30f3\u30af\u3067\u8868\u73fe\u3055\u308c\u305f XFN \u95a2\u4fc2\u3002","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"\u30bf\u30af\u30bd\u30ce\u30df\u30fc\u300cnav_menu\u300d\u306b\u5c5e\u3057\u3001\u305d\u306e\u30aa\u30d6\u30b8\u30a7\u30af\u30c8\u306b\u5272\u308a\u5f53\u3066\u3089\u308c\u3066\u3044\u308b\u30bf\u30fc\u30e0\u3002","type":"integer","required":false},"meta":{"description":"\u30e1\u30bf\u30d5\u30a3\u30fc\u30eb\u30c9\u3002","type":"object","properties":{"_helpful_status":{"type":"integer","title":"","description":"","default":1}},"required":false}}}]},"\/wp\/v2\/menu-items\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u89aa\u81ea\u52d5\u4fdd\u5b58\u306e ID\u3002","type":"integer","required":false},"id":{"description":"\u81ea\u52d5\u4fdd\u5b58\u306e ID\u3002","type":"integer","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/blocks":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u306e\u73fe\u5728\u306e\u30da\u30fc\u30b8\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u3068\u3057\u3066\u8fd4\u3055\u308c\u308b\u9805\u76ee\u306e\u6700\u5927\u6570\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u6587\u5b57\u5217\u306b\u4e00\u81f4\u3059\u308b\u3082\u306e\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","required":false},"after":{"description":"\u5165\u529b\u3055\u308c\u305f ISO8601 \u6e96\u62e0\u306e\u65e5\u4ed8\u3088\u308a\u5f8c\u306b\u516c\u958b\u3055\u308c\u305f\u6295\u7a3f\u306b\u30ec\u30b9\u30dd\u30f3\u30b9\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","format":"date-time","required":false},"modified_after":{"description":"\u5165\u529b\u3055\u308c\u305f ISO8601 \u6e96\u62e0\u306e\u65e5\u4ed8\u3088\u308a\u5f8c\u306b\u66f4\u65b0\u3055\u308c\u305f\u6295\u7a3f\u306b\u30ec\u30b9\u30dd\u30f3\u30b9\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","format":"date-time","required":false},"before":{"description":"\u5165\u529b\u3055\u308c\u305f ISO8601 \u6e96\u62e0\u306e\u65e5\u4ed8\u3088\u308a\u524d\u306b\u516c\u958b\u3055\u308c\u305f\u6295\u7a3f\u306b\u30ec\u30b9\u30dd\u30f3\u30b9\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","format":"date-time","required":false},"modified_before":{"description":"\u5165\u529b\u3055\u308c\u305f ISO8601 \u6e96\u62e0\u306e\u65e5\u4ed8\u3088\u308a\u524d\u306b\u66f4\u65b0\u3055\u308c\u305f\u6295\u7a3f\u306b\u30ec\u30b9\u30dd\u30f3\u30b9\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","format":"date-time","required":false},"exclude":{"description":"\u7279\u5b9a\u306e ID \u3092\u7d50\u679c\u304b\u3089\u9664\u5916\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u7279\u5b9a\u306e ID \u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"\u691c\u7d22\u5165\u529b\u3092\u89e3\u91c8\u3059\u308b\u65b9\u6cd5\u3067\u3059\u3002","type":"string","enum":["exact"],"required":false},"offset":{"description":"\u7279\u5b9a\u306e\u9805\u76ee\u6570\u3067\u7d50\u679c\u3092\u30aa\u30d5\u30bb\u30c3\u30c8\u3057\u307e\u3059\u3002","type":"integer","required":false},"order":{"description":"\u5c5e\u6027\u3067\u6607\u9806\u307e\u305f\u306f\u964d\u9806\u306b\u4e26\u3079\u66ff\u3048\u307e\u3059\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6295\u7a3f\u306e\u5c5e\u6027\u3067\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u3092\u4e26\u3079\u66ff\u3048\u307e\u3059\u3002","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"\u691c\u7d22\u3059\u308b\u5217\u540d\u306e\u914d\u5217\u3002","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"\u4e00\u3064\u4ee5\u4e0a\u306e\u7279\u5b9a\u306e\u30b9\u30e9\u30c3\u30b0\u3092\u6301\u3064\u6295\u7a3f\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"\u4e00\u3064\u4ee5\u4e0a\u306e\u30b9\u30c6\u30fc\u30bf\u30b9\u304c\u5272\u308a\u5f53\u3066\u3089\u308c\u305f\u6295\u7a3f\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"\u8907\u6570\u306e\u30bf\u30af\u30bd\u30ce\u30df\u30fc\u9593\u306e\u95a2\u4fc2\u306b\u57fa\u3065\u3044\u3066\u7d50\u679c\u30bb\u30c3\u30c8\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","enum":["AND","OR"],"required":false},"wp_pattern_category":{"description":"\u300cwp_pattern_category\u300d\u30bf\u30af\u30bd\u30ce\u30df\u30fc\u306b\u5272\u308a\u5f53\u3066\u3089\u308c\u305f\u7279\u5b9a\u306e\u30bf\u30fc\u30e0\u3092\u6301\u3064\u9805\u76ee\u306b\u7d50\u679c\u30bb\u30c3\u30c8\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":["object","array"],"oneOf":[{"title":"\u30bf\u30fc\u30e0 ID \u4e00\u89a7","description":"\u30ea\u30b9\u30c8\u3057\u305f ID \u3068\u5408\u81f4\u3059\u308b\u30bf\u30fc\u30e0\u3002","type":"array","items":{"type":"integer"}},{"title":"\u30bf\u30fc\u30e0 ID \u30bf\u30af\u30bd\u30ce\u30df\u30fc\u30af\u30a8\u30ea\u30fc","description":"\u9ad8\u5ea6\u306a\u30bf\u30fc\u30e0\u30af\u30a8\u30ea\u30fc\u3092\u5b9f\u884c\u3057\u307e\u3059\u3002","type":"object","properties":{"terms":{"description":"\u30bf\u30fc\u30e0 ID\u3002","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"\u7279\u5b9a\u306e\u30bf\u30fc\u30e0\u306e\u3059\u3079\u3066\u306b\u9805\u76ee\u3092\u5272\u308a\u5f53\u3066\u308b\u304b\u3001\u4e00\u90e8\u306b\u5272\u308a\u5f53\u3066\u308b\u304b\u3002","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"wp_pattern_category_exclude":{"description":"\u300cwp_pattern_category\u300d\u30bf\u30af\u30bd\u30ce\u30df\u30fc\u306b\u5272\u308a\u5f53\u3066\u3089\u308c\u305f\u7279\u5b9a\u306e\u30bf\u30fc\u30e0\u3092\u6301\u3064\u9805\u76ee\u4ee5\u5916\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":["object","array"],"oneOf":[{"title":"\u30bf\u30fc\u30e0 ID \u4e00\u89a7","description":"\u30ea\u30b9\u30c8\u3057\u305f ID \u3068\u5408\u81f4\u3059\u308b\u30bf\u30fc\u30e0\u3002","type":"array","items":{"type":"integer"}},{"title":"\u30bf\u30fc\u30e0 ID \u30bf\u30af\u30bd\u30ce\u30df\u30fc\u30af\u30a8\u30ea\u30fc","description":"\u9ad8\u5ea6\u306a\u30bf\u30fc\u30e0\u30af\u30a8\u30ea\u30fc\u3092\u5b9f\u884c\u3057\u307e\u3059\u3002","type":"object","properties":{"terms":{"description":"\u30bf\u30fc\u30e0 ID\u3002","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"\u6295\u7a3f\u306e\u516c\u958b\u65e5 (\u30b5\u30a4\u30c8\u306e\u30bf\u30a4\u30e0\u30be\u30fc\u30f3)\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u6295\u7a3f\u306e\u516c\u958b\u65e5 (GMT)\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u305d\u306e\u30bf\u30a4\u30d7\u306b\u7279\u6709\u306a\u3001\u6295\u7a3f\u306e\u82f1\u6570\u5b57\u8b58\u5225\u5b50\u3002","type":"string","required":false},"status":{"description":"\u6295\u7a3f\u306b\u5bfe\u3057\u3066\u540d\u524d\u304c\u3064\u3044\u3066\u3044\u308b\u30b9\u30c6\u30fc\u30bf\u30b9\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u30b3\u30f3\u30c6\u30f3\u30c4\u3084\u629c\u7c8b\u3078\u306e\u30a2\u30af\u30bb\u30b9\u3092\u4fdd\u8b77\u3059\u308b\u30d1\u30b9\u30ef\u30fc\u30c9\u3002","type":"string","required":false},"title":{"description":"\u6295\u7a3f\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":"object","properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u5f62\u614b\u306e\u3001\u6295\u7a3f\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"\u6295\u7a3f\u306e\u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":"object","properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u5f62\u614b\u306e\u3001\u6295\u7a3f\u306e\u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":"string","context":["view","edit"]},"block_version":{"description":"\u6295\u7a3f\u304c\u4f7f\u7528\u3059\u308b\u30b3\u30f3\u30c6\u30f3\u30c4\u30d6\u30ed\u30c3\u30af\u5f62\u5f0f\u306e\u30d0\u30fc\u30b8\u30e7\u30f3\u3002","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u30b3\u30f3\u30c6\u30f3\u30c4\u3092\u30d1\u30b9\u30ef\u30fc\u30c9\u3067\u4fdd\u8b77\u3059\u308b\u304b\u3069\u3046\u304b\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"\u6295\u7a3f\u306e\u629c\u7c8b\u3002","type":"object","properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u5f62\u614b\u306e\u3001\u6295\u7a3f\u306e\u629c\u7c8b\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u8868\u793a\u7528\u306b\u5909\u63db\u3055\u308c\u305f\u3001\u6295\u7a3f\u306e HTML \u306e\u629c\u7c8b\u3002","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"\u629c\u7c8b\u304c\u30d1\u30b9\u30ef\u30fc\u30c9\u3067\u4fdd\u8b77\u3055\u308c\u3066\u3044\u308b\u304b\u3069\u3046\u304b\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"\u30e1\u30bf\u30d5\u30a3\u30fc\u30eb\u30c9\u3002","type":"object","properties":{"_helpful_status":{"type":"integer","title":"","description":"","default":1},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"\u6295\u7a3f\u3092\u8868\u793a\u3059\u308b\u305f\u3081\u306b\u4f7f\u7528\u3059\u308b\u30c6\u30fc\u30de\u30d5\u30a1\u30a4\u30eb\u3002","type":"string","required":false},"wp_pattern_category":{"description":"\u30bf\u30af\u30bd\u30ce\u30df\u30fc\u300cwp_pattern_category\u300d\u306b\u5c5e\u3057\u3001\u305d\u306e\u6295\u7a3f\u306b\u5272\u308a\u5f53\u3066\u3089\u308c\u3066\u3044\u308b\u30bf\u30fc\u30e0\u3002","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/blocks"}]}},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6295\u7a3f\u306e\u4e00\u610f\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"\u30c7\u30d5\u30a9\u30eb\u30c8\u306e\u629c\u7c8b\u306e\u9577\u3055\u3092\u4e0a\u66f8\u304d\u3057\u307e\u3059\u3002","type":"integer","required":false},"password":{"description":"\u30d1\u30b9\u30ef\u30fc\u30c9\u3067\u4fdd\u8b77\u3055\u308c\u3066\u3044\u308b\u5834\u5408\u306e\u6295\u7a3f\u306e\u30d1\u30b9\u30ef\u30fc\u30c9\u3002","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6295\u7a3f\u306e\u4e00\u610f\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"date":{"description":"\u6295\u7a3f\u306e\u516c\u958b\u65e5 (\u30b5\u30a4\u30c8\u306e\u30bf\u30a4\u30e0\u30be\u30fc\u30f3)\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u6295\u7a3f\u306e\u516c\u958b\u65e5 (GMT)\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u305d\u306e\u30bf\u30a4\u30d7\u306b\u7279\u6709\u306a\u3001\u6295\u7a3f\u306e\u82f1\u6570\u5b57\u8b58\u5225\u5b50\u3002","type":"string","required":false},"status":{"description":"\u6295\u7a3f\u306b\u5bfe\u3057\u3066\u540d\u524d\u304c\u3064\u3044\u3066\u3044\u308b\u30b9\u30c6\u30fc\u30bf\u30b9\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u30b3\u30f3\u30c6\u30f3\u30c4\u3084\u629c\u7c8b\u3078\u306e\u30a2\u30af\u30bb\u30b9\u3092\u4fdd\u8b77\u3059\u308b\u30d1\u30b9\u30ef\u30fc\u30c9\u3002","type":"string","required":false},"title":{"description":"\u6295\u7a3f\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":"object","properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u5f62\u614b\u306e\u3001\u6295\u7a3f\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"\u6295\u7a3f\u306e\u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":"object","properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u5f62\u614b\u306e\u3001\u6295\u7a3f\u306e\u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":"string","context":["view","edit"]},"block_version":{"description":"\u6295\u7a3f\u304c\u4f7f\u7528\u3059\u308b\u30b3\u30f3\u30c6\u30f3\u30c4\u30d6\u30ed\u30c3\u30af\u5f62\u5f0f\u306e\u30d0\u30fc\u30b8\u30e7\u30f3\u3002","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u30b3\u30f3\u30c6\u30f3\u30c4\u3092\u30d1\u30b9\u30ef\u30fc\u30c9\u3067\u4fdd\u8b77\u3059\u308b\u304b\u3069\u3046\u304b\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"\u6295\u7a3f\u306e\u629c\u7c8b\u3002","type":"object","properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u5f62\u614b\u306e\u3001\u6295\u7a3f\u306e\u629c\u7c8b\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u8868\u793a\u7528\u306b\u5909\u63db\u3055\u308c\u305f\u3001\u6295\u7a3f\u306e HTML \u306e\u629c\u7c8b\u3002","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"\u629c\u7c8b\u304c\u30d1\u30b9\u30ef\u30fc\u30c9\u3067\u4fdd\u8b77\u3055\u308c\u3066\u3044\u308b\u304b\u3069\u3046\u304b\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"\u30e1\u30bf\u30d5\u30a3\u30fc\u30eb\u30c9\u3002","type":"object","properties":{"_helpful_status":{"type":"integer","title":"","description":"","default":1},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"\u6295\u7a3f\u3092\u8868\u793a\u3059\u308b\u305f\u3081\u306b\u4f7f\u7528\u3059\u308b\u30c6\u30fc\u30de\u30d5\u30a1\u30a4\u30eb\u3002","type":"string","required":false},"wp_pattern_category":{"description":"\u30bf\u30af\u30bd\u30ce\u30df\u30fc\u300cwp_pattern_category\u300d\u306b\u5c5e\u3057\u3001\u305d\u306e\u6295\u7a3f\u306b\u5272\u308a\u5f53\u3066\u3089\u308c\u3066\u3044\u308b\u30bf\u30fc\u30e0\u3002","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6295\u7a3f\u306e\u4e00\u610f\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u30b4\u30df\u7bb1\u306b\u5165\u308c\u305a\u306b\u5f37\u5236\u7684\u306b\u524a\u9664\u3059\u308b\u304b\u3069\u3046\u304b\u3002","required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u89aa\u30ea\u30d3\u30b8\u30e7\u30f3\u306e ID\u3002","type":"integer","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u306e\u73fe\u5728\u306e\u30da\u30fc\u30b8\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u3068\u3057\u3066\u8fd4\u3055\u308c\u308b\u9805\u76ee\u306e\u6700\u5927\u6570\u3002","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"\u6587\u5b57\u5217\u306b\u4e00\u81f4\u3059\u308b\u3082\u306e\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","required":false},"exclude":{"description":"\u7279\u5b9a\u306e ID \u3092\u7d50\u679c\u304b\u3089\u9664\u5916\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u7279\u5b9a\u306e ID \u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u7279\u5b9a\u306e\u9805\u76ee\u6570\u3067\u7d50\u679c\u3092\u30aa\u30d5\u30bb\u30c3\u30c8\u3057\u307e\u3059\u3002","type":"integer","required":false},"order":{"description":"\u5c5e\u6027\u3067\u6607\u9806\u307e\u305f\u306f\u964d\u9806\u306b\u4e26\u3079\u66ff\u3048\u307e\u3059\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u30aa\u30d6\u30b8\u30a7\u30af\u30c8\u5c5e\u6027\u3067\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u3092\u4e26\u3073\u66ff\u3048\u307e\u3059\u3002","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u89aa\u30ea\u30d3\u30b8\u30e7\u30f3\u306e ID\u3002","type":"integer","required":false},"id":{"description":"\u30ea\u30d3\u30b8\u30e7\u30f3\u306e\u56fa\u6709\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"\u89aa\u30ea\u30d3\u30b8\u30e7\u30f3\u306e ID\u3002","type":"integer","required":false},"id":{"description":"\u30ea\u30d3\u30b8\u30e7\u30f3\u306e\u56fa\u6709\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u30ea\u30d3\u30b8\u30e7\u30f3\u304c\u30b4\u30df\u7bb1\u6a5f\u80fd\u306b\u5bfe\u5fdc\u3057\u3066\u3044\u306a\u3044\u305f\u3081\u3001true \u3067\u306a\u3051\u308c\u3070\u306a\u308a\u307e\u305b\u3093\u3002","required":false}}}]},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u89aa\u81ea\u52d5\u4fdd\u5b58\u306e ID\u3002","type":"integer","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"\u89aa\u81ea\u52d5\u4fdd\u5b58\u306e ID\u3002","type":"integer","required":false},"date":{"description":"\u6295\u7a3f\u306e\u516c\u958b\u65e5 (\u30b5\u30a4\u30c8\u306e\u30bf\u30a4\u30e0\u30be\u30fc\u30f3)\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u6295\u7a3f\u306e\u516c\u958b\u65e5 (GMT)\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u305d\u306e\u30bf\u30a4\u30d7\u306b\u7279\u6709\u306a\u3001\u6295\u7a3f\u306e\u82f1\u6570\u5b57\u8b58\u5225\u5b50\u3002","type":"string","required":false},"status":{"description":"\u6295\u7a3f\u306b\u5bfe\u3057\u3066\u540d\u524d\u304c\u3064\u3044\u3066\u3044\u308b\u30b9\u30c6\u30fc\u30bf\u30b9\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u30b3\u30f3\u30c6\u30f3\u30c4\u3084\u629c\u7c8b\u3078\u306e\u30a2\u30af\u30bb\u30b9\u3092\u4fdd\u8b77\u3059\u308b\u30d1\u30b9\u30ef\u30fc\u30c9\u3002","type":"string","required":false},"title":{"description":"\u6295\u7a3f\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":"object","properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u5f62\u614b\u306e\u3001\u6295\u7a3f\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"\u6295\u7a3f\u306e\u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":"object","properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u5f62\u614b\u306e\u3001\u6295\u7a3f\u306e\u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":"string","context":["view","edit"]},"block_version":{"description":"\u6295\u7a3f\u304c\u4f7f\u7528\u3059\u308b\u30b3\u30f3\u30c6\u30f3\u30c4\u30d6\u30ed\u30c3\u30af\u5f62\u5f0f\u306e\u30d0\u30fc\u30b8\u30e7\u30f3\u3002","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u30b3\u30f3\u30c6\u30f3\u30c4\u3092\u30d1\u30b9\u30ef\u30fc\u30c9\u3067\u4fdd\u8b77\u3059\u308b\u304b\u3069\u3046\u304b\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"\u6295\u7a3f\u306e\u629c\u7c8b\u3002","type":"object","properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u5f62\u614b\u306e\u3001\u6295\u7a3f\u306e\u629c\u7c8b\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u8868\u793a\u7528\u306b\u5909\u63db\u3055\u308c\u305f\u3001\u6295\u7a3f\u306e HTML \u306e\u629c\u7c8b\u3002","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"\u629c\u7c8b\u304c\u30d1\u30b9\u30ef\u30fc\u30c9\u3067\u4fdd\u8b77\u3055\u308c\u3066\u3044\u308b\u304b\u3069\u3046\u304b\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"\u30e1\u30bf\u30d5\u30a3\u30fc\u30eb\u30c9\u3002","type":"object","properties":{"_helpful_status":{"type":"integer","title":"","description":"","default":1},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"\u6295\u7a3f\u3092\u8868\u793a\u3059\u308b\u305f\u3081\u306b\u4f7f\u7528\u3059\u308b\u30c6\u30fc\u30de\u30d5\u30a1\u30a4\u30eb\u3002","type":"string","required":false},"wp_pattern_category":{"description":"\u30bf\u30af\u30bd\u30ce\u30df\u30fc\u300cwp_pattern_category\u300d\u306b\u5c5e\u3057\u3001\u305d\u306e\u6295\u7a3f\u306b\u5272\u308a\u5f53\u3066\u3089\u308c\u3066\u3044\u308b\u30bf\u30fc\u30e0\u3002","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u89aa\u81ea\u52d5\u4fdd\u5b58\u306e ID\u3002","type":"integer","required":false},"id":{"description":"\u81ea\u52d5\u4fdd\u5b58\u306e ID\u3002","type":"integer","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e ID","type":"string","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u306e\u73fe\u5728\u306e\u30da\u30fc\u30b8\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u3068\u3057\u3066\u8fd4\u3055\u308c\u308b\u9805\u76ee\u306e\u6700\u5927\u6570\u3002","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"\u6587\u5b57\u5217\u306b\u4e00\u81f4\u3059\u308b\u3082\u306e\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","required":false},"exclude":{"description":"\u7279\u5b9a\u306e ID \u3092\u7d50\u679c\u304b\u3089\u9664\u5916\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u7279\u5b9a\u306e ID \u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u7279\u5b9a\u306e\u9805\u76ee\u6570\u3067\u7d50\u679c\u3092\u30aa\u30d5\u30bb\u30c3\u30c8\u3057\u307e\u3059\u3002","type":"integer","required":false},"order":{"description":"\u5c5e\u6027\u3067\u6607\u9806\u307e\u305f\u306f\u964d\u9806\u306b\u4e26\u3079\u66ff\u3048\u307e\u3059\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u30aa\u30d6\u30b8\u30a7\u30af\u30c8\u5c5e\u6027\u3067\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u3092\u4e26\u3073\u66ff\u3048\u307e\u3059\u3002","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e ID","type":"string","required":false},"id":{"description":"\u30ea\u30d3\u30b8\u30e7\u30f3\u306e\u56fa\u6709\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e ID","type":"string","required":false},"id":{"description":"\u30ea\u30d3\u30b8\u30e7\u30f3\u306e\u56fa\u6709\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u30ea\u30d3\u30b8\u30e7\u30f3\u304c\u30b4\u30df\u7bb1\u6a5f\u80fd\u306b\u5bfe\u5fdc\u3057\u3066\u3044\u306a\u3044\u305f\u3081\u3001true \u3067\u306a\u3051\u308c\u3070\u306a\u308a\u307e\u305b\u3093\u3002","required":false}}}]},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e ID","type":"string","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"id":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e ID","type":"string","required":false},"slug":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u3092\u8b58\u5225\u3059\u308b\u56fa\u6709\u306e\u30b9\u30e9\u30c3\u30b0\u3002","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u30c6\u30fc\u30de\u56fa\u6709\u8b58\u5225\u5b50\u3002","type":"string","required":false},"type":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u30bf\u30a4\u30d7","type":"string","required":false},"content":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":["object","string"],"properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u72b6\u614b\u306e\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":"string","context":["view","edit"]},"block_version":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u304c\u4f7f\u7528\u3059\u308b\u30b3\u30f3\u30c6\u30f3\u30c4\u30d6\u30ed\u30c3\u30af\u5f62\u5f0f\u306e\u30d0\u30fc\u30b8\u30e7\u30f3\u3002","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":["object","string"],"properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u72b6\u614b\u306e\u3001\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["view","edit","embed"]},"rendered":{"description":"\u8868\u793a\u7528\u306b\u6574\u5f62\u3055\u308c\u305f\u3001\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e HTML \u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u8aac\u660e\u3002","type":"string","required":false},"status":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u72b6\u614b\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u4f5c\u6210\u8005\u306e ID\u3002","type":"integer","required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e ID","type":"string","required":false},"id":{"description":"\u81ea\u52d5\u4fdd\u5b58\u306e ID\u3002","type":"integer","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/templates":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"\u6307\u5b9a\u3057\u305f\u6295\u7a3f ID \u306b\u5236\u9650\u3057\u307e\u3059\u3002","type":"integer","required":false},"area":{"description":"\u7279\u5b9a\u306e\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u30d1\u30fc\u30c4\u30a8\u30ea\u30a2\u306b\u5236\u9650\u3059\u308b\u3002","type":"string","required":false},"post_type":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u3092\u53d6\u5f97\u3059\u308b\u6295\u7a3f\u30bf\u30a4\u30d7\u3002","type":"string","required":false}}},{"methods":["POST"],"args":{"slug":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u3092\u8b58\u5225\u3059\u308b\u56fa\u6709\u306e\u30b9\u30e9\u30c3\u30b0\u3002","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u30c6\u30fc\u30de\u56fa\u6709\u8b58\u5225\u5b50\u3002","type":"string","required":false},"type":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u30bf\u30a4\u30d7","type":"string","required":false},"content":{"default":"","description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":["object","string"],"properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u72b6\u614b\u306e\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":"string","context":["view","edit"]},"block_version":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u304c\u4f7f\u7528\u3059\u308b\u30b3\u30f3\u30c6\u30f3\u30c4\u30d6\u30ed\u30c3\u30af\u5f62\u5f0f\u306e\u30d0\u30fc\u30b8\u30e7\u30f3\u3002","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":["object","string"],"properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u72b6\u614b\u306e\u3001\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["view","edit","embed"]},"rendered":{"description":"\u8868\u793a\u7528\u306b\u6574\u5f62\u3055\u308c\u305f\u3001\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e HTML \u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u8aac\u660e\u3002","type":"string","required":false},"status":{"default":"publish","description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u72b6\u614b\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u4f5c\u6210\u8005\u306e ID\u3002","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/templates"}]}},"\/wp\/v2\/templates\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"\u4ee5\u4e0b\u306e\u30d5\u30a9\u30fc\u30eb\u30d0\u30c3\u30af\u3092\u53d6\u5f97\u3059\u308b\u305f\u3081\u306e\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u30b9\u30e9\u30c3\u30b0","type":"string","required":true},"is_custom":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u304c\u30ab\u30b9\u30bf\u30e0\u3067\u3042\u308b\u304b\u3001\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u968e\u5c64\u306e\u4e00\u90e8\u3067\u3042\u308b\u304b\u3092\u6307\u5b9a\u3057\u307e\u3059","type":"boolean","required":false},"template_prefix":{"description":"\u4f5c\u6210\u3055\u308c\u305f\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u63a5\u982d\u8f9e\u3002\u3053\u308c\u306f\u30e1\u30a4\u30f3\u306e\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u30bf\u30a4\u30d7\u3092\u62bd\u51fa\u3059\u308b\u305f\u3081\u306b\u4f7f\u7528\u3055\u308c\u307e\u3059 (\u4f8b: \"taxonomy-blocks\"\u3067\u306f\u3001\"taxonomy\" \u304c\u62bd\u51fa\u3055\u308c\u307e\u3059)\u3002","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/templates\/lookup"}]}},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e ID","type":"string","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e ID","type":"string","required":false},"slug":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u3092\u8b58\u5225\u3059\u308b\u56fa\u6709\u306e\u30b9\u30e9\u30c3\u30b0\u3002","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u30c6\u30fc\u30de\u56fa\u6709\u8b58\u5225\u5b50\u3002","type":"string","required":false},"type":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u30bf\u30a4\u30d7","type":"string","required":false},"content":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":["object","string"],"properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u72b6\u614b\u306e\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":"string","context":["view","edit"]},"block_version":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u304c\u4f7f\u7528\u3059\u308b\u30b3\u30f3\u30c6\u30f3\u30c4\u30d6\u30ed\u30c3\u30af\u5f62\u5f0f\u306e\u30d0\u30fc\u30b8\u30e7\u30f3\u3002","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":["object","string"],"properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u72b6\u614b\u306e\u3001\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["view","edit","embed"]},"rendered":{"description":"\u8868\u793a\u7528\u306b\u6574\u5f62\u3055\u308c\u305f\u3001\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e HTML \u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u8aac\u660e\u3002","type":"string","required":false},"status":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u72b6\u614b\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u4f5c\u6210\u8005\u306e ID\u3002","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e ID","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"\u30b4\u30df\u7bb1\u306b\u5165\u308c\u305a\u306b\u5f37\u5236\u7684\u306b\u524a\u9664\u3059\u308b\u304b\u3069\u3046\u304b\u3002","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e ID","type":"string","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u306e\u73fe\u5728\u306e\u30da\u30fc\u30b8\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u3068\u3057\u3066\u8fd4\u3055\u308c\u308b\u9805\u76ee\u306e\u6700\u5927\u6570\u3002","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"\u6587\u5b57\u5217\u306b\u4e00\u81f4\u3059\u308b\u3082\u306e\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","required":false},"exclude":{"description":"\u7279\u5b9a\u306e ID \u3092\u7d50\u679c\u304b\u3089\u9664\u5916\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u7279\u5b9a\u306e ID \u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u7279\u5b9a\u306e\u9805\u76ee\u6570\u3067\u7d50\u679c\u3092\u30aa\u30d5\u30bb\u30c3\u30c8\u3057\u307e\u3059\u3002","type":"integer","required":false},"order":{"description":"\u5c5e\u6027\u3067\u6607\u9806\u307e\u305f\u306f\u964d\u9806\u306b\u4e26\u3079\u66ff\u3048\u307e\u3059\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u30aa\u30d6\u30b8\u30a7\u30af\u30c8\u5c5e\u6027\u3067\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u3092\u4e26\u3073\u66ff\u3048\u307e\u3059\u3002","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e ID","type":"string","required":false},"id":{"description":"\u30ea\u30d3\u30b8\u30e7\u30f3\u306e\u56fa\u6709\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e ID","type":"string","required":false},"id":{"description":"\u30ea\u30d3\u30b8\u30e7\u30f3\u306e\u56fa\u6709\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u30ea\u30d3\u30b8\u30e7\u30f3\u304c\u30b4\u30df\u7bb1\u6a5f\u80fd\u306b\u5bfe\u5fdc\u3057\u3066\u3044\u306a\u3044\u305f\u3081\u3001true \u3067\u306a\u3051\u308c\u3070\u306a\u308a\u307e\u305b\u3093\u3002","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e ID","type":"string","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"id":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e ID","type":"string","required":false},"slug":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u3092\u8b58\u5225\u3059\u308b\u56fa\u6709\u306e\u30b9\u30e9\u30c3\u30b0\u3002","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u30c6\u30fc\u30de\u56fa\u6709\u8b58\u5225\u5b50\u3002","type":"string","required":false},"type":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u30bf\u30a4\u30d7","type":"string","required":false},"content":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":["object","string"],"properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u72b6\u614b\u306e\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":"string","context":["view","edit"]},"block_version":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u304c\u4f7f\u7528\u3059\u308b\u30b3\u30f3\u30c6\u30f3\u30c4\u30d6\u30ed\u30c3\u30af\u5f62\u5f0f\u306e\u30d0\u30fc\u30b8\u30e7\u30f3\u3002","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":["object","string"],"properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u72b6\u614b\u306e\u3001\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["view","edit","embed"]},"rendered":{"description":"\u8868\u793a\u7528\u306b\u6574\u5f62\u3055\u308c\u305f\u3001\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e HTML \u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u8aac\u660e\u3002","type":"string","required":false},"status":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u72b6\u614b\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u4f5c\u6210\u8005\u306e ID\u3002","type":"integer","required":false},"area":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u30d1\u30fc\u30c4\u306e\u4f7f\u7528\u3092\u76ee\u7684\u3068\u3057\u305f\u5834\u6240 (\u30d8\u30c3\u30c0\u30fc\u3001\u30d5\u30c3\u30bf\u30fc\u3001\u306a\u3069)","type":"string","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e ID","type":"string","required":false},"id":{"description":"\u81ea\u52d5\u4fdd\u5b58\u306e ID\u3002","type":"integer","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/template-parts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"\u6307\u5b9a\u3057\u305f\u6295\u7a3f ID \u306b\u5236\u9650\u3057\u307e\u3059\u3002","type":"integer","required":false},"area":{"description":"\u7279\u5b9a\u306e\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u30d1\u30fc\u30c4\u30a8\u30ea\u30a2\u306b\u5236\u9650\u3059\u308b\u3002","type":"string","required":false},"post_type":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u3092\u53d6\u5f97\u3059\u308b\u6295\u7a3f\u30bf\u30a4\u30d7\u3002","type":"string","required":false}}},{"methods":["POST"],"args":{"slug":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u3092\u8b58\u5225\u3059\u308b\u56fa\u6709\u306e\u30b9\u30e9\u30c3\u30b0\u3002","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u30c6\u30fc\u30de\u56fa\u6709\u8b58\u5225\u5b50\u3002","type":"string","required":false},"type":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u30bf\u30a4\u30d7","type":"string","required":false},"content":{"default":"","description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":["object","string"],"properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u72b6\u614b\u306e\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":"string","context":["view","edit"]},"block_version":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u304c\u4f7f\u7528\u3059\u308b\u30b3\u30f3\u30c6\u30f3\u30c4\u30d6\u30ed\u30c3\u30af\u5f62\u5f0f\u306e\u30d0\u30fc\u30b8\u30e7\u30f3\u3002","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":["object","string"],"properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u72b6\u614b\u306e\u3001\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["view","edit","embed"]},"rendered":{"description":"\u8868\u793a\u7528\u306b\u6574\u5f62\u3055\u308c\u305f\u3001\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e HTML \u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u8aac\u660e\u3002","type":"string","required":false},"status":{"default":"publish","description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u72b6\u614b\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u4f5c\u6210\u8005\u306e ID\u3002","type":"integer","required":false},"area":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u30d1\u30fc\u30c4\u306e\u4f7f\u7528\u3092\u76ee\u7684\u3068\u3057\u305f\u5834\u6240 (\u30d8\u30c3\u30c0\u30fc\u3001\u30d5\u30c3\u30bf\u30fc\u3001\u306a\u3069)","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/template-parts"}]}},"\/wp\/v2\/template-parts\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"\u4ee5\u4e0b\u306e\u30d5\u30a9\u30fc\u30eb\u30d0\u30c3\u30af\u3092\u53d6\u5f97\u3059\u308b\u305f\u3081\u306e\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u30b9\u30e9\u30c3\u30b0","type":"string","required":true},"is_custom":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u304c\u30ab\u30b9\u30bf\u30e0\u3067\u3042\u308b\u304b\u3001\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u968e\u5c64\u306e\u4e00\u90e8\u3067\u3042\u308b\u304b\u3092\u6307\u5b9a\u3057\u307e\u3059","type":"boolean","required":false},"template_prefix":{"description":"\u4f5c\u6210\u3055\u308c\u305f\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u63a5\u982d\u8f9e\u3002\u3053\u308c\u306f\u30e1\u30a4\u30f3\u306e\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u30bf\u30a4\u30d7\u3092\u62bd\u51fa\u3059\u308b\u305f\u3081\u306b\u4f7f\u7528\u3055\u308c\u307e\u3059 (\u4f8b: \"taxonomy-blocks\"\u3067\u306f\u3001\"taxonomy\" \u304c\u62bd\u51fa\u3055\u308c\u307e\u3059)\u3002","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/template-parts\/lookup"}]}},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e ID","type":"string","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e ID","type":"string","required":false},"slug":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u3092\u8b58\u5225\u3059\u308b\u56fa\u6709\u306e\u30b9\u30e9\u30c3\u30b0\u3002","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u30c6\u30fc\u30de\u56fa\u6709\u8b58\u5225\u5b50\u3002","type":"string","required":false},"type":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u30bf\u30a4\u30d7","type":"string","required":false},"content":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":["object","string"],"properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u72b6\u614b\u306e\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":"string","context":["view","edit"]},"block_version":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u304c\u4f7f\u7528\u3059\u308b\u30b3\u30f3\u30c6\u30f3\u30c4\u30d6\u30ed\u30c3\u30af\u5f62\u5f0f\u306e\u30d0\u30fc\u30b8\u30e7\u30f3\u3002","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":["object","string"],"properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u72b6\u614b\u306e\u3001\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["view","edit","embed"]},"rendered":{"description":"\u8868\u793a\u7528\u306b\u6574\u5f62\u3055\u308c\u305f\u3001\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e HTML \u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u8aac\u660e\u3002","type":"string","required":false},"status":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u72b6\u614b\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e\u4f5c\u6210\u8005\u306e ID\u3002","type":"integer","required":false},"area":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u30d1\u30fc\u30c4\u306e\u4f7f\u7528\u3092\u76ee\u7684\u3068\u3057\u305f\u5834\u6240 (\u30d8\u30c3\u30c0\u30fc\u3001\u30d5\u30c3\u30bf\u30fc\u3001\u306a\u3069)","type":"string","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"\u30c6\u30f3\u30d7\u30ec\u30fc\u30c8\u306e ID","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"\u30b4\u30df\u7bb1\u306b\u5165\u308c\u305a\u306b\u5f37\u5236\u7684\u306b\u524a\u9664\u3059\u308b\u304b\u3069\u3046\u304b\u3002","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u89aa\u30ea\u30d3\u30b8\u30e7\u30f3\u306e ID\u3002","type":"integer","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u306e\u73fe\u5728\u306e\u30da\u30fc\u30b8\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u3068\u3057\u3066\u8fd4\u3055\u308c\u308b\u9805\u76ee\u306e\u6700\u5927\u6570\u3002","type":"integer","minimum":1,"maximum":100,"required":false},"offset":{"description":"\u7279\u5b9a\u306e\u9805\u76ee\u6570\u3067\u7d50\u679c\u3092\u30aa\u30d5\u30bb\u30c3\u30c8\u3057\u307e\u3059\u3002","type":"integer","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u30b0\u30ed\u30fc\u30d0\u30eb\u30b9\u30bf\u30a4\u30eb\u30ea\u30d3\u30b8\u30e7\u30f3\u306e\u89aa\u306e ID\u3002","type":"integer","required":false},"id":{"description":"\u30b0\u30ed\u30fc\u30d0\u30eb\u30b9\u30bf\u30a4\u30eb\u30ea\u30d3\u30b8\u30e7\u30f3\u306e\u4e00\u610f\u306e\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[\\\/\\s%\\w\\.\\(\\)\\[\\]\\@_\\-]+)\/variations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"\u30c6\u30fc\u30de\u8b58\u5225\u5b50","type":"string","required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"\u30c6\u30fc\u30de\u8b58\u5225\u5b50","type":"string","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<id>[\\\/\\d+]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"id":{"description":"\u30b0\u30ed\u30fc\u30d0\u30eb\u30b9\u30bf\u30a4\u30eb\u69cb\u6210\u306e ID\u3002","type":"integer","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":false},"args":{"styles":{"description":"\u30b0\u30ed\u30fc\u30d0\u30eb\u30b9\u30bf\u30a4\u30eb\u3002","type":["object"],"required":false},"settings":{"description":"\u30b0\u30ed\u30fc\u30d0\u30eb\u8a2d\u5b9a\u3002","type":["object"],"required":false},"title":{"description":"\u30b0\u30ed\u30fc\u30d0\u30eb\u30b9\u30bf\u30a4\u30eb\u30d0\u30ea\u30a8\u30fc\u30b7\u30e7\u30f3\u306e\u30bf\u30a4\u30c8\u30eb","type":["object","string"],"properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u5185\u306b\u5b58\u5728\u3059\u308b\u5f62\u3067\u306e\u3001\u30b0\u30ed\u30fc\u30d0\u30eb\u30b9\u30bf\u30a4\u30eb\u30d0\u30ea\u30a8\u30fc\u30b7\u30e7\u30f3\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["view","edit","embed"]},"rendered":{"description":"\u8868\u793a\u7528\u306b\u6574\u5f62\u3055\u308c\u305f\u3001\u6295\u7a3f\u306e HTML \u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false}}}]},"\/wp\/v2\/navigation":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u306e\u73fe\u5728\u306e\u30da\u30fc\u30b8\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u3068\u3057\u3066\u8fd4\u3055\u308c\u308b\u9805\u76ee\u306e\u6700\u5927\u6570\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u6587\u5b57\u5217\u306b\u4e00\u81f4\u3059\u308b\u3082\u306e\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","required":false},"after":{"description":"\u5165\u529b\u3055\u308c\u305f ISO8601 \u6e96\u62e0\u306e\u65e5\u4ed8\u3088\u308a\u5f8c\u306b\u516c\u958b\u3055\u308c\u305f\u6295\u7a3f\u306b\u30ec\u30b9\u30dd\u30f3\u30b9\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","format":"date-time","required":false},"modified_after":{"description":"\u5165\u529b\u3055\u308c\u305f ISO8601 \u6e96\u62e0\u306e\u65e5\u4ed8\u3088\u308a\u5f8c\u306b\u66f4\u65b0\u3055\u308c\u305f\u6295\u7a3f\u306b\u30ec\u30b9\u30dd\u30f3\u30b9\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","format":"date-time","required":false},"before":{"description":"\u5165\u529b\u3055\u308c\u305f ISO8601 \u6e96\u62e0\u306e\u65e5\u4ed8\u3088\u308a\u524d\u306b\u516c\u958b\u3055\u308c\u305f\u6295\u7a3f\u306b\u30ec\u30b9\u30dd\u30f3\u30b9\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","format":"date-time","required":false},"modified_before":{"description":"\u5165\u529b\u3055\u308c\u305f ISO8601 \u6e96\u62e0\u306e\u65e5\u4ed8\u3088\u308a\u524d\u306b\u66f4\u65b0\u3055\u308c\u305f\u6295\u7a3f\u306b\u30ec\u30b9\u30dd\u30f3\u30b9\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","format":"date-time","required":false},"exclude":{"description":"\u7279\u5b9a\u306e ID \u3092\u7d50\u679c\u304b\u3089\u9664\u5916\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u7279\u5b9a\u306e ID \u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"\u691c\u7d22\u5165\u529b\u3092\u89e3\u91c8\u3059\u308b\u65b9\u6cd5\u3067\u3059\u3002","type":"string","enum":["exact"],"required":false},"offset":{"description":"\u7279\u5b9a\u306e\u9805\u76ee\u6570\u3067\u7d50\u679c\u3092\u30aa\u30d5\u30bb\u30c3\u30c8\u3057\u307e\u3059\u3002","type":"integer","required":false},"order":{"description":"\u5c5e\u6027\u3067\u6607\u9806\u307e\u305f\u306f\u964d\u9806\u306b\u4e26\u3079\u66ff\u3048\u307e\u3059\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6295\u7a3f\u306e\u5c5e\u6027\u3067\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u3092\u4e26\u3079\u66ff\u3048\u307e\u3059\u3002","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"\u691c\u7d22\u3059\u308b\u5217\u540d\u306e\u914d\u5217\u3002","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"\u4e00\u3064\u4ee5\u4e0a\u306e\u7279\u5b9a\u306e\u30b9\u30e9\u30c3\u30b0\u3092\u6301\u3064\u6295\u7a3f\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"\u4e00\u3064\u4ee5\u4e0a\u306e\u30b9\u30c6\u30fc\u30bf\u30b9\u304c\u5272\u308a\u5f53\u3066\u3089\u308c\u305f\u6295\u7a3f\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"\u6295\u7a3f\u306e\u516c\u958b\u65e5 (\u30b5\u30a4\u30c8\u306e\u30bf\u30a4\u30e0\u30be\u30fc\u30f3)\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u6295\u7a3f\u306e\u516c\u958b\u65e5 (GMT)\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u305d\u306e\u30bf\u30a4\u30d7\u306b\u7279\u6709\u306a\u3001\u6295\u7a3f\u306e\u82f1\u6570\u5b57\u8b58\u5225\u5b50\u3002","type":"string","required":false},"status":{"description":"\u6295\u7a3f\u306b\u5bfe\u3057\u3066\u540d\u524d\u304c\u3064\u3044\u3066\u3044\u308b\u30b9\u30c6\u30fc\u30bf\u30b9\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u30b3\u30f3\u30c6\u30f3\u30c4\u3084\u629c\u7c8b\u3078\u306e\u30a2\u30af\u30bb\u30b9\u3092\u4fdd\u8b77\u3059\u308b\u30d1\u30b9\u30ef\u30fc\u30c9\u3002","type":"string","required":false},"title":{"description":"\u6295\u7a3f\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":"object","properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u5f62\u614b\u306e\u3001\u6295\u7a3f\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["edit","embed"]},"rendered":{"description":"\u8868\u793a\u7528\u306b\u6574\u5f62\u3055\u308c\u305f\u3001\u6295\u7a3f\u306e HTML \u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"\u6295\u7a3f\u306e\u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":"object","properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u5f62\u614b\u306e\u3001\u6295\u7a3f\u306e\u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":"string","context":["edit","embed"]},"rendered":{"description":"\u8868\u793a\u7528\u306b\u5909\u63db\u3055\u308c\u305f\u3001\u6295\u7a3f\u306e HTML \u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"\u6295\u7a3f\u304c\u4f7f\u7528\u3059\u308b\u30b3\u30f3\u30c6\u30f3\u30c4\u30d6\u30ed\u30c3\u30af\u5f62\u5f0f\u306e\u30d0\u30fc\u30b8\u30e7\u30f3\u3002","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"\u30b3\u30f3\u30c6\u30f3\u30c4\u3092\u30d1\u30b9\u30ef\u30fc\u30c9\u3067\u4fdd\u8b77\u3059\u308b\u304b\u3069\u3046\u304b\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"\u6295\u7a3f\u3092\u8868\u793a\u3059\u308b\u305f\u3081\u306b\u4f7f\u7528\u3059\u308b\u30c6\u30fc\u30de\u30d5\u30a1\u30a4\u30eb\u3002","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/navigation"}]}},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6295\u7a3f\u306e\u4e00\u610f\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"\u30d1\u30b9\u30ef\u30fc\u30c9\u3067\u4fdd\u8b77\u3055\u308c\u3066\u3044\u308b\u5834\u5408\u306e\u6295\u7a3f\u306e\u30d1\u30b9\u30ef\u30fc\u30c9\u3002","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6295\u7a3f\u306e\u4e00\u610f\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"date":{"description":"\u6295\u7a3f\u306e\u516c\u958b\u65e5 (\u30b5\u30a4\u30c8\u306e\u30bf\u30a4\u30e0\u30be\u30fc\u30f3)\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u6295\u7a3f\u306e\u516c\u958b\u65e5 (GMT)\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u305d\u306e\u30bf\u30a4\u30d7\u306b\u7279\u6709\u306a\u3001\u6295\u7a3f\u306e\u82f1\u6570\u5b57\u8b58\u5225\u5b50\u3002","type":"string","required":false},"status":{"description":"\u6295\u7a3f\u306b\u5bfe\u3057\u3066\u540d\u524d\u304c\u3064\u3044\u3066\u3044\u308b\u30b9\u30c6\u30fc\u30bf\u30b9\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u30b3\u30f3\u30c6\u30f3\u30c4\u3084\u629c\u7c8b\u3078\u306e\u30a2\u30af\u30bb\u30b9\u3092\u4fdd\u8b77\u3059\u308b\u30d1\u30b9\u30ef\u30fc\u30c9\u3002","type":"string","required":false},"title":{"description":"\u6295\u7a3f\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":"object","properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u5f62\u614b\u306e\u3001\u6295\u7a3f\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["edit","embed"]},"rendered":{"description":"\u8868\u793a\u7528\u306b\u6574\u5f62\u3055\u308c\u305f\u3001\u6295\u7a3f\u306e HTML \u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"\u6295\u7a3f\u306e\u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":"object","properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u5f62\u614b\u306e\u3001\u6295\u7a3f\u306e\u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":"string","context":["edit","embed"]},"rendered":{"description":"\u8868\u793a\u7528\u306b\u5909\u63db\u3055\u308c\u305f\u3001\u6295\u7a3f\u306e HTML \u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"\u6295\u7a3f\u304c\u4f7f\u7528\u3059\u308b\u30b3\u30f3\u30c6\u30f3\u30c4\u30d6\u30ed\u30c3\u30af\u5f62\u5f0f\u306e\u30d0\u30fc\u30b8\u30e7\u30f3\u3002","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"\u30b3\u30f3\u30c6\u30f3\u30c4\u3092\u30d1\u30b9\u30ef\u30fc\u30c9\u3067\u4fdd\u8b77\u3059\u308b\u304b\u3069\u3046\u304b\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"\u6295\u7a3f\u3092\u8868\u793a\u3059\u308b\u305f\u3081\u306b\u4f7f\u7528\u3059\u308b\u30c6\u30fc\u30de\u30d5\u30a1\u30a4\u30eb\u3002","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6295\u7a3f\u306e\u4e00\u610f\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u30b4\u30df\u7bb1\u306b\u5165\u308c\u305a\u306b\u5f37\u5236\u7684\u306b\u524a\u9664\u3059\u308b\u304b\u3069\u3046\u304b\u3002","required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u89aa\u30ea\u30d3\u30b8\u30e7\u30f3\u306e ID\u3002","type":"integer","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u306e\u73fe\u5728\u306e\u30da\u30fc\u30b8\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u3068\u3057\u3066\u8fd4\u3055\u308c\u308b\u9805\u76ee\u306e\u6700\u5927\u6570\u3002","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"\u6587\u5b57\u5217\u306b\u4e00\u81f4\u3059\u308b\u3082\u306e\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","required":false},"exclude":{"description":"\u7279\u5b9a\u306e ID \u3092\u7d50\u679c\u304b\u3089\u9664\u5916\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u7279\u5b9a\u306e ID \u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u7279\u5b9a\u306e\u9805\u76ee\u6570\u3067\u7d50\u679c\u3092\u30aa\u30d5\u30bb\u30c3\u30c8\u3057\u307e\u3059\u3002","type":"integer","required":false},"order":{"description":"\u5c5e\u6027\u3067\u6607\u9806\u307e\u305f\u306f\u964d\u9806\u306b\u4e26\u3079\u66ff\u3048\u307e\u3059\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u30aa\u30d6\u30b8\u30a7\u30af\u30c8\u5c5e\u6027\u3067\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u3092\u4e26\u3073\u66ff\u3048\u307e\u3059\u3002","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u89aa\u30ea\u30d3\u30b8\u30e7\u30f3\u306e ID\u3002","type":"integer","required":false},"id":{"description":"\u30ea\u30d3\u30b8\u30e7\u30f3\u306e\u56fa\u6709\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"\u89aa\u30ea\u30d3\u30b8\u30e7\u30f3\u306e ID\u3002","type":"integer","required":false},"id":{"description":"\u30ea\u30d3\u30b8\u30e7\u30f3\u306e\u56fa\u6709\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u30ea\u30d3\u30b8\u30e7\u30f3\u304c\u30b4\u30df\u7bb1\u6a5f\u80fd\u306b\u5bfe\u5fdc\u3057\u3066\u3044\u306a\u3044\u305f\u3081\u3001true \u3067\u306a\u3051\u308c\u3070\u306a\u308a\u307e\u305b\u3093\u3002","required":false}}}]},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u89aa\u81ea\u52d5\u4fdd\u5b58\u306e ID\u3002","type":"integer","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"\u89aa\u81ea\u52d5\u4fdd\u5b58\u306e ID\u3002","type":"integer","required":false},"date":{"description":"\u6295\u7a3f\u306e\u516c\u958b\u65e5 (\u30b5\u30a4\u30c8\u306e\u30bf\u30a4\u30e0\u30be\u30fc\u30f3)\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u6295\u7a3f\u306e\u516c\u958b\u65e5 (GMT)\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u305d\u306e\u30bf\u30a4\u30d7\u306b\u7279\u6709\u306a\u3001\u6295\u7a3f\u306e\u82f1\u6570\u5b57\u8b58\u5225\u5b50\u3002","type":"string","required":false},"status":{"description":"\u6295\u7a3f\u306b\u5bfe\u3057\u3066\u540d\u524d\u304c\u3064\u3044\u3066\u3044\u308b\u30b9\u30c6\u30fc\u30bf\u30b9\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u30b3\u30f3\u30c6\u30f3\u30c4\u3084\u629c\u7c8b\u3078\u306e\u30a2\u30af\u30bb\u30b9\u3092\u4fdd\u8b77\u3059\u308b\u30d1\u30b9\u30ef\u30fc\u30c9\u3002","type":"string","required":false},"title":{"description":"\u6295\u7a3f\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":"object","properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u5f62\u614b\u306e\u3001\u6295\u7a3f\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["edit","embed"]},"rendered":{"description":"\u8868\u793a\u7528\u306b\u6574\u5f62\u3055\u308c\u305f\u3001\u6295\u7a3f\u306e HTML \u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"\u6295\u7a3f\u306e\u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":"object","properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u5f62\u614b\u306e\u3001\u6295\u7a3f\u306e\u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":"string","context":["edit","embed"]},"rendered":{"description":"\u8868\u793a\u7528\u306b\u5909\u63db\u3055\u308c\u305f\u3001\u6295\u7a3f\u306e HTML \u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"\u6295\u7a3f\u304c\u4f7f\u7528\u3059\u308b\u30b3\u30f3\u30c6\u30f3\u30c4\u30d6\u30ed\u30c3\u30af\u5f62\u5f0f\u306e\u30d0\u30fc\u30b8\u30e7\u30f3\u3002","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"\u30b3\u30f3\u30c6\u30f3\u30c4\u3092\u30d1\u30b9\u30ef\u30fc\u30c9\u3067\u4fdd\u8b77\u3059\u308b\u304b\u3069\u3046\u304b\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"\u6295\u7a3f\u3092\u8868\u793a\u3059\u308b\u305f\u3081\u306b\u4f7f\u7528\u3059\u308b\u30c6\u30fc\u30de\u30d5\u30a1\u30a4\u30eb\u3002","type":"string","required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u89aa\u81ea\u52d5\u4fdd\u5b58\u306e ID\u3002","type":"integer","required":false},"id":{"description":"\u81ea\u52d5\u4fdd\u5b58\u306e ID\u3002","type":"integer","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/font-families":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u306e\u73fe\u5728\u306e\u30da\u30fc\u30b8\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u3068\u3057\u3066\u8fd4\u3055\u308c\u308b\u9805\u76ee\u306e\u6700\u5927\u6570\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"\u7279\u5b9a\u306e ID \u3092\u7d50\u679c\u304b\u3089\u9664\u5916\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u7279\u5b9a\u306e ID \u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"\u691c\u7d22\u5165\u529b\u3092\u89e3\u91c8\u3059\u308b\u65b9\u6cd5\u3067\u3059\u3002","type":"string","enum":["exact"],"required":false},"offset":{"description":"\u7279\u5b9a\u306e\u9805\u76ee\u6570\u3067\u7d50\u679c\u3092\u30aa\u30d5\u30bb\u30c3\u30c8\u3057\u307e\u3059\u3002","type":"integer","required":false},"order":{"description":"\u5c5e\u6027\u3067\u6607\u9806\u307e\u305f\u306f\u964d\u9806\u306b\u4e26\u3079\u66ff\u3048\u307e\u3059\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6295\u7a3f\u306e\u5c5e\u6027\u3067\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u3092\u4e26\u3079\u66ff\u3048\u307e\u3059\u3002","type":"string","default":"id","enum":["id","include"],"required":false},"slug":{"description":"\u4e00\u3064\u4ee5\u4e0a\u306e\u7279\u5b9a\u306e\u30b9\u30e9\u30c3\u30b0\u3092\u6301\u3064\u6295\u7a3f\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"theme_json_version":{"description":"\u30bf\u30a4\u30dd\u30b0\u30e9\u30d5\u30a3\u8a2d\u5b9a\u306b\u4f7f\u7528\u3055\u308c\u308b theme.json \u30b9\u30ad\u30fc\u30de\u306e\u30d0\u30fc\u30b8\u30e7\u30f3\u3002","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"\u6587\u5b57\u5217\u3067\u30a8\u30f3\u30b3\u30fc\u30c9\u3055\u308c\u305f theme.json \u5f62\u5f0f\u306e font-family \u306e\u5ba3\u8a00\u3002","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/font-families"}]}},"\/wp\/v2\/font-families\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u6295\u7a3f\u306e\u4e00\u610f\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"\u6295\u7a3f\u306e\u4e00\u610f\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"theme_json_version":{"description":"\u30bf\u30a4\u30dd\u30b0\u30e9\u30d5\u30a3\u8a2d\u5b9a\u306b\u4f7f\u7528\u3055\u308c\u308b theme.json \u30b9\u30ad\u30fc\u30de\u306e\u30d0\u30fc\u30b8\u30e7\u30f3\u3002","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"\u6587\u5b57\u5217\u3067\u30a8\u30f3\u30b3\u30fc\u30c9\u3055\u308c\u305f theme.json \u5f62\u5f0f\u306e font-family \u306e\u5ba3\u8a00\u3002","type":"string","required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"\u6295\u7a3f\u306e\u4e00\u610f\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u30b4\u30df\u7bb1\u306b\u5165\u308c\u305a\u306b\u5f37\u5236\u7684\u306b\u524a\u9664\u3059\u308b\u304b\u3069\u3046\u304b\u3002","required":false}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"\u30d5\u30a9\u30f3\u30c8\u30d5\u30a7\u30a4\u30b9\u306e\u89aa\u30d5\u30a9\u30f3\u30c8\u30d5\u30a1\u30df\u30ea\u30fc\u306e ID\u3002","type":"integer","required":true},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u306e\u73fe\u5728\u306e\u30da\u30fc\u30b8\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u3068\u3057\u3066\u8fd4\u3055\u308c\u308b\u9805\u76ee\u306e\u6700\u5927\u6570\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"\u7279\u5b9a\u306e ID \u3092\u7d50\u679c\u304b\u3089\u9664\u5916\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u7279\u5b9a\u306e ID \u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"\u691c\u7d22\u5165\u529b\u3092\u89e3\u91c8\u3059\u308b\u65b9\u6cd5\u3067\u3059\u3002","type":"string","enum":["exact"],"required":false},"offset":{"description":"\u7279\u5b9a\u306e\u9805\u76ee\u6570\u3067\u7d50\u679c\u3092\u30aa\u30d5\u30bb\u30c3\u30c8\u3057\u307e\u3059\u3002","type":"integer","required":false},"order":{"description":"\u5c5e\u6027\u3067\u6607\u9806\u307e\u305f\u306f\u964d\u9806\u306b\u4e26\u3079\u66ff\u3048\u307e\u3059\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6295\u7a3f\u306e\u5c5e\u6027\u3067\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u3092\u4e26\u3079\u66ff\u3048\u307e\u3059\u3002","type":"string","default":"id","enum":["id","include"],"required":false}}},{"methods":["POST"],"args":{"font_family_id":{"description":"\u30d5\u30a9\u30f3\u30c8\u30d5\u30a7\u30a4\u30b9\u306e\u89aa\u30d5\u30a9\u30f3\u30c8\u30d5\u30a1\u30df\u30ea\u30fc\u306e ID\u3002","type":"integer","required":true},"theme_json_version":{"description":"\u30bf\u30a4\u30dd\u30b0\u30e9\u30d5\u30a3\u8a2d\u5b9a\u306b\u4f7f\u7528\u3055\u308c\u308b theme.json \u30b9\u30ad\u30fc\u30de\u306e\u30d0\u30fc\u30b8\u30e7\u30f3\u3002","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_face_settings":{"description":"\u6587\u5b57\u5217\u3067\u30a8\u30f3\u30b3\u30fc\u30c9\u3055\u308c\u305f theme.json \u5f62\u5f0f\u306e font-face \u306e\u5ba3\u8a00\u3002","type":"string","required":true}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"\u30d5\u30a9\u30f3\u30c8\u30d5\u30a7\u30a4\u30b9\u306e\u89aa\u30d5\u30a9\u30f3\u30c8\u30d5\u30a1\u30df\u30ea\u30fc\u306e ID\u3002","type":"integer","required":true},"id":{"description":"\u30d5\u30a9\u30f3\u30c8\u30d5\u30a7\u30a4\u30b9\u306e\u4e00\u610f\u306e\u8b58\u5225\u5b50\u3002","type":"integer","required":true},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"font_family_id":{"description":"\u30d5\u30a9\u30f3\u30c8\u30d5\u30a7\u30a4\u30b9\u306e\u89aa\u30d5\u30a9\u30f3\u30c8\u30d5\u30a1\u30df\u30ea\u30fc\u306e ID\u3002","type":"integer","required":true},"id":{"description":"\u30d5\u30a9\u30f3\u30c8\u30d5\u30a7\u30a4\u30b9\u306e\u4e00\u610f\u306e\u8b58\u5225\u5b50\u3002","type":"integer","required":true},"force":{"type":"boolean","default":false,"description":"\u30b4\u30df\u7bb1\u306b\u5165\u308c\u305a\u306b\u5f37\u5236\u7684\u306b\u524a\u9664\u3059\u308b\u304b\u3069\u3046\u304b\u3002","required":false}}}]},"\/wp\/v2\/elementor_library":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u306e\u73fe\u5728\u306e\u30da\u30fc\u30b8\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u3068\u3057\u3066\u8fd4\u3055\u308c\u308b\u9805\u76ee\u306e\u6700\u5927\u6570\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u6587\u5b57\u5217\u306b\u4e00\u81f4\u3059\u308b\u3082\u306e\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","required":false},"after":{"description":"\u5165\u529b\u3055\u308c\u305f ISO8601 \u6e96\u62e0\u306e\u65e5\u4ed8\u3088\u308a\u5f8c\u306b\u516c\u958b\u3055\u308c\u305f\u6295\u7a3f\u306b\u30ec\u30b9\u30dd\u30f3\u30b9\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","format":"date-time","required":false},"modified_after":{"description":"\u5165\u529b\u3055\u308c\u305f ISO8601 \u6e96\u62e0\u306e\u65e5\u4ed8\u3088\u308a\u5f8c\u306b\u66f4\u65b0\u3055\u308c\u305f\u6295\u7a3f\u306b\u30ec\u30b9\u30dd\u30f3\u30b9\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","format":"date-time","required":false},"author":{"description":"\u7279\u5b9a\u306e\u6295\u7a3f\u8005\u306b\u5272\u308a\u5f53\u3066\u3089\u308c\u305f\u6295\u7a3f\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"\u7279\u5b9a\u306e\u6295\u7a3f\u8005\u304c\u5272\u308a\u5f53\u3066\u3089\u308c\u305f\u6295\u7a3f\u3092\u7d50\u679c\u304b\u3089\u9664\u5916\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"\u5165\u529b\u3055\u308c\u305f ISO8601 \u6e96\u62e0\u306e\u65e5\u4ed8\u3088\u308a\u524d\u306b\u516c\u958b\u3055\u308c\u305f\u6295\u7a3f\u306b\u30ec\u30b9\u30dd\u30f3\u30b9\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","format":"date-time","required":false},"modified_before":{"description":"\u5165\u529b\u3055\u308c\u305f ISO8601 \u6e96\u62e0\u306e\u65e5\u4ed8\u3088\u308a\u524d\u306b\u66f4\u65b0\u3055\u308c\u305f\u6295\u7a3f\u306b\u30ec\u30b9\u30dd\u30f3\u30b9\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","format":"date-time","required":false},"exclude":{"description":"\u7279\u5b9a\u306e ID \u3092\u7d50\u679c\u304b\u3089\u9664\u5916\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u7279\u5b9a\u306e ID \u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"\u691c\u7d22\u5165\u529b\u3092\u89e3\u91c8\u3059\u308b\u65b9\u6cd5\u3067\u3059\u3002","type":"string","enum":["exact"],"required":false},"offset":{"description":"\u7279\u5b9a\u306e\u9805\u76ee\u6570\u3067\u7d50\u679c\u3092\u30aa\u30d5\u30bb\u30c3\u30c8\u3057\u307e\u3059\u3002","type":"integer","required":false},"order":{"description":"\u5c5e\u6027\u3067\u6607\u9806\u307e\u305f\u306f\u964d\u9806\u306b\u4e26\u3079\u66ff\u3048\u307e\u3059\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6295\u7a3f\u306e\u5c5e\u6027\u3067\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u3092\u4e26\u3079\u66ff\u3048\u307e\u3059\u3002","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"\u691c\u7d22\u3059\u308b\u5217\u540d\u306e\u914d\u5217\u3002","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"\u4e00\u3064\u4ee5\u4e0a\u306e\u7279\u5b9a\u306e\u30b9\u30e9\u30c3\u30b0\u3092\u6301\u3064\u6295\u7a3f\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"\u4e00\u3064\u4ee5\u4e0a\u306e\u30b9\u30c6\u30fc\u30bf\u30b9\u304c\u5272\u308a\u5f53\u3066\u3089\u308c\u305f\u6295\u7a3f\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"\u6295\u7a3f\u306e\u516c\u958b\u65e5 (\u30b5\u30a4\u30c8\u306e\u30bf\u30a4\u30e0\u30be\u30fc\u30f3)\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u6295\u7a3f\u306e\u516c\u958b\u65e5 (GMT)\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u305d\u306e\u30bf\u30a4\u30d7\u306b\u7279\u6709\u306a\u3001\u6295\u7a3f\u306e\u82f1\u6570\u5b57\u8b58\u5225\u5b50\u3002","type":"string","required":false},"status":{"description":"\u6295\u7a3f\u306b\u5bfe\u3057\u3066\u540d\u524d\u304c\u3064\u3044\u3066\u3044\u308b\u30b9\u30c6\u30fc\u30bf\u30b9\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u30b3\u30f3\u30c6\u30f3\u30c4\u3084\u629c\u7c8b\u3078\u306e\u30a2\u30af\u30bb\u30b9\u3092\u4fdd\u8b77\u3059\u308b\u30d1\u30b9\u30ef\u30fc\u30c9\u3002","type":"string","required":false},"title":{"description":"\u6295\u7a3f\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":"object","properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u5f62\u614b\u306e\u3001\u6295\u7a3f\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u8868\u793a\u7528\u306b\u6574\u5f62\u3055\u308c\u305f\u3001\u6295\u7a3f\u306e HTML \u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"\u6295\u7a3f\u8005\u306e ID\u3002","type":"integer","required":false},"featured_media":{"description":"\u6295\u7a3f\u306e\u30a2\u30a4\u30ad\u30e3\u30c3\u30c1\u3068\u306a\u308b\u30e1\u30c7\u30a3\u30a2\u306e ID\u3002","type":"integer","required":false},"meta":{"description":"\u30e1\u30bf\u30d5\u30a3\u30fc\u30eb\u30c9\u3002","type":"object","properties":{"_helpful_status":{"type":"integer","title":"","description":"","default":1},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","cloud-template-preview",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"\u6295\u7a3f\u3092\u8868\u793a\u3059\u308b\u305f\u3081\u306b\u4f7f\u7528\u3059\u308b\u30c6\u30fc\u30de\u30d5\u30a1\u30a4\u30eb\u3002","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/elementor_library"}]}},"\/wp\/v2\/elementor_library\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6295\u7a3f\u306e\u4e00\u610f\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"\u30d1\u30b9\u30ef\u30fc\u30c9\u3067\u4fdd\u8b77\u3055\u308c\u3066\u3044\u308b\u5834\u5408\u306e\u6295\u7a3f\u306e\u30d1\u30b9\u30ef\u30fc\u30c9\u3002","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6295\u7a3f\u306e\u4e00\u610f\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"date":{"description":"\u6295\u7a3f\u306e\u516c\u958b\u65e5 (\u30b5\u30a4\u30c8\u306e\u30bf\u30a4\u30e0\u30be\u30fc\u30f3)\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u6295\u7a3f\u306e\u516c\u958b\u65e5 (GMT)\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u305d\u306e\u30bf\u30a4\u30d7\u306b\u7279\u6709\u306a\u3001\u6295\u7a3f\u306e\u82f1\u6570\u5b57\u8b58\u5225\u5b50\u3002","type":"string","required":false},"status":{"description":"\u6295\u7a3f\u306b\u5bfe\u3057\u3066\u540d\u524d\u304c\u3064\u3044\u3066\u3044\u308b\u30b9\u30c6\u30fc\u30bf\u30b9\u3002","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"\u30b3\u30f3\u30c6\u30f3\u30c4\u3084\u629c\u7c8b\u3078\u306e\u30a2\u30af\u30bb\u30b9\u3092\u4fdd\u8b77\u3059\u308b\u30d1\u30b9\u30ef\u30fc\u30c9\u3002","type":"string","required":false},"title":{"description":"\u6295\u7a3f\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":"object","properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u5f62\u614b\u306e\u3001\u6295\u7a3f\u306e\u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u8868\u793a\u7528\u306b\u6574\u5f62\u3055\u308c\u305f\u3001\u6295\u7a3f\u306e HTML \u30bf\u30a4\u30c8\u30eb\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"\u6295\u7a3f\u8005\u306e ID\u3002","type":"integer","required":false},"featured_media":{"description":"\u6295\u7a3f\u306e\u30a2\u30a4\u30ad\u30e3\u30c3\u30c1\u3068\u306a\u308b\u30e1\u30c7\u30a3\u30a2\u306e ID\u3002","type":"integer","required":false},"meta":{"description":"\u30e1\u30bf\u30d5\u30a3\u30fc\u30eb\u30c9\u3002","type":"object","properties":{"_helpful_status":{"type":"integer","title":"","description":"","default":1},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","cloud-template-preview",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"\u6295\u7a3f\u3092\u8868\u793a\u3059\u308b\u305f\u3081\u306b\u4f7f\u7528\u3059\u308b\u30c6\u30fc\u30de\u30d5\u30a1\u30a4\u30eb\u3002","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6295\u7a3f\u306e\u4e00\u610f\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u30b4\u30df\u7bb1\u306b\u5165\u308c\u305a\u306b\u5f37\u5236\u7684\u306b\u524a\u9664\u3059\u308b\u304b\u3069\u3046\u304b\u3002","required":false}}}]},"\/wp\/v2\/elementor_library\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u89aa\u30ea\u30d3\u30b8\u30e7\u30f3\u306e ID\u3002","type":"integer","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u306e\u73fe\u5728\u306e\u30da\u30fc\u30b8\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u3068\u3057\u3066\u8fd4\u3055\u308c\u308b\u9805\u76ee\u306e\u6700\u5927\u6570\u3002","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"\u6587\u5b57\u5217\u306b\u4e00\u81f4\u3059\u308b\u3082\u306e\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","required":false},"exclude":{"description":"\u7279\u5b9a\u306e ID \u3092\u7d50\u679c\u304b\u3089\u9664\u5916\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u7279\u5b9a\u306e ID \u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u7279\u5b9a\u306e\u9805\u76ee\u6570\u3067\u7d50\u679c\u3092\u30aa\u30d5\u30bb\u30c3\u30c8\u3057\u307e\u3059\u3002","type":"integer","required":false},"order":{"description":"\u5c5e\u6027\u3067\u6607\u9806\u307e\u305f\u306f\u964d\u9806\u306b\u4e26\u3079\u66ff\u3048\u307e\u3059\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u30aa\u30d6\u30b8\u30a7\u30af\u30c8\u5c5e\u6027\u3067\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u3092\u4e26\u3073\u66ff\u3048\u307e\u3059\u3002","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/elementor_library\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u89aa\u30ea\u30d3\u30b8\u30e7\u30f3\u306e ID\u3002","type":"integer","required":false},"id":{"description":"\u30ea\u30d3\u30b8\u30e7\u30f3\u306e\u56fa\u6709\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"\u89aa\u30ea\u30d3\u30b8\u30e7\u30f3\u306e ID\u3002","type":"integer","required":false},"id":{"description":"\u30ea\u30d3\u30b8\u30e7\u30f3\u306e\u56fa\u6709\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u30ea\u30d3\u30b8\u30e7\u30f3\u304c\u30b4\u30df\u7bb1\u6a5f\u80fd\u306b\u5bfe\u5fdc\u3057\u3066\u3044\u306a\u3044\u305f\u3081\u3001true \u3067\u306a\u3051\u308c\u3070\u306a\u308a\u307e\u305b\u3093\u3002","required":false}}}]},"\/wp\/v2\/types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/types"}]}},"\/wp\/v2\/types\/(?P<type>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"description":"\u6295\u7a3f\u30bf\u30a4\u30d7\u306e\u82f1\u6570\u5b57\u306e\u8b58\u5225\u5b50\u3002","type":"string","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/statuses":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/statuses"}]}},"\/wp\/v2\/statuses\/(?P<status>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"\u30b9\u30c6\u30fc\u30bf\u30b9\u306e\u82f1\u6570\u5b57\u306e\u8b58\u5225\u5b50\u3002","type":"string","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/taxonomies":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"type":{"description":"\u7279\u5b9a\u306e\u6295\u7a3f\u30bf\u30a4\u30d7\u306b\u95a2\u9023\u4ed8\u3051\u3089\u308c\u305f\u30bf\u30af\u30bd\u30ce\u30df\u30fc\u306b\u7d50\u679c\u3092\u5236\u9650\u3057\u307e\u3059\u3002","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/taxonomies"}]}},"\/wp\/v2\/taxonomies\/(?P<taxonomy>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"taxonomy":{"description":"\u30bf\u30af\u30bd\u30ce\u30df\u30fc\u306e\u82f1\u6570\u5b57\u306e\u8b58\u5225\u5b50\u3002","type":"string","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/categories":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u306e\u73fe\u5728\u306e\u30da\u30fc\u30b8\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u3068\u3057\u3066\u8fd4\u3055\u308c\u308b\u9805\u76ee\u306e\u6700\u5927\u6570\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u6587\u5b57\u5217\u306b\u4e00\u81f4\u3059\u308b\u3082\u306e\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","required":false},"exclude":{"description":"\u7279\u5b9a\u306e ID \u3092\u7d50\u679c\u304b\u3089\u9664\u5916\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u7279\u5b9a\u306e ID \u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"\u5c5e\u6027\u3067\u6607\u9806\u307e\u305f\u306f\u964d\u9806\u306b\u4e26\u3079\u66ff\u3048\u307e\u3059\u3002","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u30bf\u30fc\u30e0\u306e\u5c5e\u6027\u3067\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u3092\u4e26\u3079\u66ff\u3048\u307e\u3059\u3002","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"\u3069\u306e\u6295\u7a3f\u306b\u3082\u5272\u308a\u5f53\u3066\u3089\u308c\u3066\u3044\u306a\u3044\u30bf\u30fc\u30e0\u3092\u975e\u8868\u793a\u306b\u3059\u308b\u304b\u3069\u3046\u304b\u3002","type":"boolean","default":false,"required":false},"parent":{"description":"\u7279\u5b9a\u306e\u89aa\u306b\u5272\u308a\u5f53\u3066\u3089\u308c\u305f\u30bf\u30fc\u30e0\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"integer","required":false},"post":{"description":"\u7279\u5b9a\u306e\u6295\u7a3f\u306b\u5272\u308a\u5f53\u3066\u3089\u308c\u305f\u30bf\u30fc\u30e0\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"integer","default":null,"required":false},"slug":{"description":"\u4e00\u3064\u4ee5\u4e0a\u306e\u7279\u5b9a\u306e\u30b9\u30e9\u30c3\u30b0\u3092\u6301\u3064\u30bf\u30fc\u30e0\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"\u30bf\u30fc\u30e0\u306e HTML \u306e\u8aac\u660e\u3002","type":"string","required":false},"name":{"description":"\u30bf\u30fc\u30e0\u306e HTML \u30bf\u30a4\u30c8\u30eb\u3002","type":"string","required":true},"slug":{"description":"\u305d\u306e\u30bf\u30a4\u30d7\u306b\u7279\u6709\u306a\u3001\u30bf\u30fc\u30e0\u306e\u82f1\u6570\u5b57\u8b58\u5225\u5b50\u3002","type":"string","required":false},"parent":{"description":"\u89aa\u306e\u30bf\u30fc\u30e0 ID\u3002","type":"integer","required":false},"meta":{"description":"\u30e1\u30bf\u30d5\u30a3\u30fc\u30eb\u30c9\u3002","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/categories"}]}},"\/wp\/v2\/categories\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u30bf\u30fc\u30e0\u306e\u4e00\u610f\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u30bf\u30fc\u30e0\u306e\u4e00\u610f\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"description":{"description":"\u30bf\u30fc\u30e0\u306e HTML \u306e\u8aac\u660e\u3002","type":"string","required":false},"name":{"description":"\u30bf\u30fc\u30e0\u306e HTML \u30bf\u30a4\u30c8\u30eb\u3002","type":"string","required":false},"slug":{"description":"\u305d\u306e\u30bf\u30a4\u30d7\u306b\u7279\u6709\u306a\u3001\u30bf\u30fc\u30e0\u306e\u82f1\u6570\u5b57\u8b58\u5225\u5b50\u3002","type":"string","required":false},"parent":{"description":"\u89aa\u306e\u30bf\u30fc\u30e0 ID\u3002","type":"integer","required":false},"meta":{"description":"\u30e1\u30bf\u30d5\u30a3\u30fc\u30eb\u30c9\u3002","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u30bf\u30fc\u30e0\u306e\u4e00\u610f\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u30bf\u30fc\u30e0\u304c\u30b4\u30df\u7bb1\u6a5f\u80fd\u306b\u5bfe\u5fdc\u3057\u3066\u3044\u306a\u3044\u305f\u3081\u3001true \u3067\u306a\u3051\u308c\u3070\u306a\u308a\u307e\u305b\u3093\u3002","required":false}}}]},"\/wp\/v2\/tags":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u306e\u73fe\u5728\u306e\u30da\u30fc\u30b8\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u3068\u3057\u3066\u8fd4\u3055\u308c\u308b\u9805\u76ee\u306e\u6700\u5927\u6570\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u6587\u5b57\u5217\u306b\u4e00\u81f4\u3059\u308b\u3082\u306e\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","required":false},"exclude":{"description":"\u7279\u5b9a\u306e ID \u3092\u7d50\u679c\u304b\u3089\u9664\u5916\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u7279\u5b9a\u306e ID \u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u7279\u5b9a\u306e\u9805\u76ee\u6570\u3067\u7d50\u679c\u3092\u30aa\u30d5\u30bb\u30c3\u30c8\u3057\u307e\u3059\u3002","type":"integer","required":false},"order":{"description":"\u5c5e\u6027\u3067\u6607\u9806\u307e\u305f\u306f\u964d\u9806\u306b\u4e26\u3079\u66ff\u3048\u307e\u3059\u3002","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u30bf\u30fc\u30e0\u306e\u5c5e\u6027\u3067\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u3092\u4e26\u3079\u66ff\u3048\u307e\u3059\u3002","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"\u3069\u306e\u6295\u7a3f\u306b\u3082\u5272\u308a\u5f53\u3066\u3089\u308c\u3066\u3044\u306a\u3044\u30bf\u30fc\u30e0\u3092\u975e\u8868\u793a\u306b\u3059\u308b\u304b\u3069\u3046\u304b\u3002","type":"boolean","default":false,"required":false},"post":{"description":"\u7279\u5b9a\u306e\u6295\u7a3f\u306b\u5272\u308a\u5f53\u3066\u3089\u308c\u305f\u30bf\u30fc\u30e0\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"integer","default":null,"required":false},"slug":{"description":"\u4e00\u3064\u4ee5\u4e0a\u306e\u7279\u5b9a\u306e\u30b9\u30e9\u30c3\u30b0\u3092\u6301\u3064\u30bf\u30fc\u30e0\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"\u30bf\u30fc\u30e0\u306e HTML \u306e\u8aac\u660e\u3002","type":"string","required":false},"name":{"description":"\u30bf\u30fc\u30e0\u306e HTML \u30bf\u30a4\u30c8\u30eb\u3002","type":"string","required":true},"slug":{"description":"\u305d\u306e\u30bf\u30a4\u30d7\u306b\u7279\u6709\u306a\u3001\u30bf\u30fc\u30e0\u306e\u82f1\u6570\u5b57\u8b58\u5225\u5b50\u3002","type":"string","required":false},"meta":{"description":"\u30e1\u30bf\u30d5\u30a3\u30fc\u30eb\u30c9\u3002","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/tags"}]}},"\/wp\/v2\/tags\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u30bf\u30fc\u30e0\u306e\u4e00\u610f\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u30bf\u30fc\u30e0\u306e\u4e00\u610f\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"description":{"description":"\u30bf\u30fc\u30e0\u306e HTML \u306e\u8aac\u660e\u3002","type":"string","required":false},"name":{"description":"\u30bf\u30fc\u30e0\u306e HTML \u30bf\u30a4\u30c8\u30eb\u3002","type":"string","required":false},"slug":{"description":"\u305d\u306e\u30bf\u30a4\u30d7\u306b\u7279\u6709\u306a\u3001\u30bf\u30fc\u30e0\u306e\u82f1\u6570\u5b57\u8b58\u5225\u5b50\u3002","type":"string","required":false},"meta":{"description":"\u30e1\u30bf\u30d5\u30a3\u30fc\u30eb\u30c9\u3002","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u30bf\u30fc\u30e0\u306e\u4e00\u610f\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u30bf\u30fc\u30e0\u304c\u30b4\u30df\u7bb1\u6a5f\u80fd\u306b\u5bfe\u5fdc\u3057\u3066\u3044\u306a\u3044\u305f\u3081\u3001true \u3067\u306a\u3051\u308c\u3070\u306a\u308a\u307e\u305b\u3093\u3002","required":false}}}]},"\/wp\/v2\/menus":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u306e\u73fe\u5728\u306e\u30da\u30fc\u30b8\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u3068\u3057\u3066\u8fd4\u3055\u308c\u308b\u9805\u76ee\u306e\u6700\u5927\u6570\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u6587\u5b57\u5217\u306b\u4e00\u81f4\u3059\u308b\u3082\u306e\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","required":false},"exclude":{"description":"\u7279\u5b9a\u306e ID \u3092\u7d50\u679c\u304b\u3089\u9664\u5916\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u7279\u5b9a\u306e ID \u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u7279\u5b9a\u306e\u9805\u76ee\u6570\u3067\u7d50\u679c\u3092\u30aa\u30d5\u30bb\u30c3\u30c8\u3057\u307e\u3059\u3002","type":"integer","required":false},"order":{"description":"\u5c5e\u6027\u3067\u6607\u9806\u307e\u305f\u306f\u964d\u9806\u306b\u4e26\u3079\u66ff\u3048\u307e\u3059\u3002","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u30bf\u30fc\u30e0\u306e\u5c5e\u6027\u3067\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u3092\u4e26\u3079\u66ff\u3048\u307e\u3059\u3002","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"\u3069\u306e\u6295\u7a3f\u306b\u3082\u5272\u308a\u5f53\u3066\u3089\u308c\u3066\u3044\u306a\u3044\u30bf\u30fc\u30e0\u3092\u975e\u8868\u793a\u306b\u3059\u308b\u304b\u3069\u3046\u304b\u3002","type":"boolean","default":false,"required":false},"post":{"description":"\u7279\u5b9a\u306e\u6295\u7a3f\u306b\u5272\u308a\u5f53\u3066\u3089\u308c\u305f\u30bf\u30fc\u30e0\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"integer","default":null,"required":false},"slug":{"description":"\u4e00\u3064\u4ee5\u4e0a\u306e\u7279\u5b9a\u306e\u30b9\u30e9\u30c3\u30b0\u3092\u6301\u3064\u30bf\u30fc\u30e0\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"\u30bf\u30fc\u30e0\u306e HTML \u306e\u8aac\u660e\u3002","type":"string","required":false},"name":{"description":"\u30bf\u30fc\u30e0\u306e HTML \u30bf\u30a4\u30c8\u30eb\u3002","type":"string","required":true},"slug":{"description":"\u305d\u306e\u30bf\u30a4\u30d7\u306b\u7279\u6709\u306a\u3001\u30bf\u30fc\u30e0\u306e\u82f1\u6570\u5b57\u8b58\u5225\u5b50\u3002","type":"string","required":false},"meta":{"description":"\u30e1\u30bf\u30d5\u30a3\u30fc\u30eb\u30c9\u3002","type":"object","properties":[],"required":false},"locations":{"description":"\u30e1\u30cb\u30e5\u30fc\u306b\u5272\u308a\u5f53\u3066\u3089\u308c\u305f\u4f4d\u7f6e\u3002","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"\u81ea\u52d5\u7684\u306b\u30c8\u30c3\u30d7\u30ec\u30d9\u30eb\u306e\u30da\u30fc\u30b8\u3092\u3053\u306e\u30e1\u30cb\u30e5\u30fc\u306b\u8ffd\u52a0\u3059\u308b\u304b\u3069\u3046\u304b\u3002","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/menus"}]}},"\/wp\/v2\/menus\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u30bf\u30fc\u30e0\u306e\u4e00\u610f\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u30bf\u30fc\u30e0\u306e\u4e00\u610f\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"description":{"description":"\u30bf\u30fc\u30e0\u306e HTML \u306e\u8aac\u660e\u3002","type":"string","required":false},"name":{"description":"\u30bf\u30fc\u30e0\u306e HTML \u30bf\u30a4\u30c8\u30eb\u3002","type":"string","required":false},"slug":{"description":"\u305d\u306e\u30bf\u30a4\u30d7\u306b\u7279\u6709\u306a\u3001\u30bf\u30fc\u30e0\u306e\u82f1\u6570\u5b57\u8b58\u5225\u5b50\u3002","type":"string","required":false},"meta":{"description":"\u30e1\u30bf\u30d5\u30a3\u30fc\u30eb\u30c9\u3002","type":"object","properties":[],"required":false},"locations":{"description":"\u30e1\u30cb\u30e5\u30fc\u306b\u5272\u308a\u5f53\u3066\u3089\u308c\u305f\u4f4d\u7f6e\u3002","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"\u81ea\u52d5\u7684\u306b\u30c8\u30c3\u30d7\u30ec\u30d9\u30eb\u306e\u30da\u30fc\u30b8\u3092\u3053\u306e\u30e1\u30cb\u30e5\u30fc\u306b\u8ffd\u52a0\u3059\u308b\u304b\u3069\u3046\u304b\u3002","type":"boolean","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u30bf\u30fc\u30e0\u306e\u4e00\u610f\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u30bf\u30fc\u30e0\u304c\u30b4\u30df\u7bb1\u6a5f\u80fd\u306b\u5bfe\u5fdc\u3057\u3066\u3044\u306a\u3044\u305f\u3081\u3001true \u3067\u306a\u3051\u308c\u3070\u306a\u308a\u307e\u305b\u3093\u3002","required":false}}}]},"\/wp\/v2\/wp_pattern_category":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u306e\u73fe\u5728\u306e\u30da\u30fc\u30b8\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u3068\u3057\u3066\u8fd4\u3055\u308c\u308b\u9805\u76ee\u306e\u6700\u5927\u6570\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u6587\u5b57\u5217\u306b\u4e00\u81f4\u3059\u308b\u3082\u306e\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","required":false},"exclude":{"description":"\u7279\u5b9a\u306e ID \u3092\u7d50\u679c\u304b\u3089\u9664\u5916\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u7279\u5b9a\u306e ID \u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u7279\u5b9a\u306e\u9805\u76ee\u6570\u3067\u7d50\u679c\u3092\u30aa\u30d5\u30bb\u30c3\u30c8\u3057\u307e\u3059\u3002","type":"integer","required":false},"order":{"description":"\u5c5e\u6027\u3067\u6607\u9806\u307e\u305f\u306f\u964d\u9806\u306b\u4e26\u3079\u66ff\u3048\u307e\u3059\u3002","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u30bf\u30fc\u30e0\u306e\u5c5e\u6027\u3067\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u3092\u4e26\u3079\u66ff\u3048\u307e\u3059\u3002","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"\u3069\u306e\u6295\u7a3f\u306b\u3082\u5272\u308a\u5f53\u3066\u3089\u308c\u3066\u3044\u306a\u3044\u30bf\u30fc\u30e0\u3092\u975e\u8868\u793a\u306b\u3059\u308b\u304b\u3069\u3046\u304b\u3002","type":"boolean","default":false,"required":false},"post":{"description":"\u7279\u5b9a\u306e\u6295\u7a3f\u306b\u5272\u308a\u5f53\u3066\u3089\u308c\u305f\u30bf\u30fc\u30e0\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"integer","default":null,"required":false},"slug":{"description":"\u4e00\u3064\u4ee5\u4e0a\u306e\u7279\u5b9a\u306e\u30b9\u30e9\u30c3\u30b0\u3092\u6301\u3064\u30bf\u30fc\u30e0\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"\u30bf\u30fc\u30e0\u306e HTML \u306e\u8aac\u660e\u3002","type":"string","required":false},"name":{"description":"\u30bf\u30fc\u30e0\u306e HTML \u30bf\u30a4\u30c8\u30eb\u3002","type":"string","required":true},"slug":{"description":"\u305d\u306e\u30bf\u30a4\u30d7\u306b\u7279\u6709\u306a\u3001\u30bf\u30fc\u30e0\u306e\u82f1\u6570\u5b57\u8b58\u5225\u5b50\u3002","type":"string","required":false},"meta":{"description":"\u30e1\u30bf\u30d5\u30a3\u30fc\u30eb\u30c9\u3002","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/wp_pattern_category"}]}},"\/wp\/v2\/wp_pattern_category\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u30bf\u30fc\u30e0\u306e\u4e00\u610f\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u30bf\u30fc\u30e0\u306e\u4e00\u610f\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"description":{"description":"\u30bf\u30fc\u30e0\u306e HTML \u306e\u8aac\u660e\u3002","type":"string","required":false},"name":{"description":"\u30bf\u30fc\u30e0\u306e HTML \u30bf\u30a4\u30c8\u30eb\u3002","type":"string","required":false},"slug":{"description":"\u305d\u306e\u30bf\u30a4\u30d7\u306b\u7279\u6709\u306a\u3001\u30bf\u30fc\u30e0\u306e\u82f1\u6570\u5b57\u8b58\u5225\u5b50\u3002","type":"string","required":false},"meta":{"description":"\u30e1\u30bf\u30d5\u30a3\u30fc\u30eb\u30c9\u3002","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u30bf\u30fc\u30e0\u306e\u4e00\u610f\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u30bf\u30fc\u30e0\u304c\u30b4\u30df\u7bb1\u6a5f\u80fd\u306b\u5bfe\u5fdc\u3057\u3066\u3044\u306a\u3044\u305f\u3081\u3001true \u3067\u306a\u3051\u308c\u3070\u306a\u308a\u307e\u305b\u3093\u3002","required":false}}}]},"\/wp\/v2\/users":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u306e\u73fe\u5728\u306e\u30da\u30fc\u30b8\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u3068\u3057\u3066\u8fd4\u3055\u308c\u308b\u9805\u76ee\u306e\u6700\u5927\u6570\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u6587\u5b57\u5217\u306b\u4e00\u81f4\u3059\u308b\u3082\u306e\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","required":false},"exclude":{"description":"\u7279\u5b9a\u306e ID \u3092\u7d50\u679c\u304b\u3089\u9664\u5916\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u7279\u5b9a\u306e ID \u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u7279\u5b9a\u306e\u9805\u76ee\u6570\u3067\u7d50\u679c\u3092\u30aa\u30d5\u30bb\u30c3\u30c8\u3057\u307e\u3059\u3002","type":"integer","required":false},"order":{"default":"asc","description":"\u5c5e\u6027\u3067\u6607\u9806\u307e\u305f\u306f\u964d\u9806\u306b\u4e26\u3079\u66ff\u3048\u307e\u3059\u3002","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"name","description":"\u30e6\u30fc\u30b6\u30fc\u306e\u5c5e\u6027\u3067\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u3092\u4e26\u3079\u66ff\u3048\u307e\u3059\u3002","enum":["id","include","name","registered_date","slug","include_slugs","email","url"],"type":"string","required":false},"slug":{"description":"\u4e00\u3064\u4ee5\u4e0a\u306e\u7279\u5b9a\u306e\u30b9\u30e9\u30c3\u30b0\u3092\u6301\u3064\u30e6\u30fc\u30b6\u30fc\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"type":"string"},"required":false},"roles":{"description":"\u5165\u529b\u3055\u308c\u305f\u3001\u5c11\u306a\u304f\u3068\u3082\u4e00\u3064\u4ee5\u4e0a\u306e\u7279\u5b9a\u306e\u6a29\u9650\u30b0\u30eb\u30fc\u30d7\u306b\u4e00\u81f4\u3059\u308b\u30e6\u30fc\u30b6\u30fc\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002csv \u30d5\u30a1\u30a4\u30eb\u306e\u30ea\u30b9\u30c8\u3001\u3042\u308b\u3044\u306f\u4e00\u3064\u306e\u6a29\u9650\u30b0\u30eb\u30fc\u30d7\u3082\u53ef\u80fd\u3067\u3059\u3002","type":"array","items":{"type":"string"},"required":false},"capabilities":{"description":"\u63d0\u4f9b\u3055\u308c\u305f\u5c11\u306a\u304f\u3068\u3082\u4e00\u3064\u4ee5\u4e0a\u306e\u7279\u5b9a\u306e\u6a29\u9650\u306b\u4e00\u81f4\u3059\u308b\u30e6\u30fc\u30b6\u30fc\u306b\u7d50\u679c\u30bb\u30c3\u30c8\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002csv \u30d5\u30a1\u30a4\u30eb\u306e\u30ea\u30b9\u30c8\u3001\u3042\u308b\u3044\u306f\u4e00\u3064\u306e\u6a29\u9650\u3082\u53ef\u80fd\u3067\u3059\u3002","type":"array","items":{"type":"string"},"required":false},"who":{"description":"\u6295\u7a3f\u8005\u3068\u307f\u306a\u3055\u308c\u308b\u30e6\u30fc\u30b6\u30fc\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3059\u308b\u3002","type":"string","enum":["authors"],"required":false},"has_published_posts":{"description":"\u6295\u7a3f\u3092\u516c\u958b\u3057\u305f\u30e6\u30fc\u30b6\u30fc\u306b\u7d50\u679c\u30bb\u30c3\u30c8\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":["boolean","array"],"items":{"type":"string","enum":{"post":"post","page":"page","attachment":"attachment","nav_menu_item":"nav_menu_item","wp_block":"wp_block","wp_template":"wp_template","wp_template_part":"wp_template_part","wp_global_styles":"wp_global_styles","wp_navigation":"wp_navigation","wp_font_family":"wp_font_family","wp_font_face":"wp_font_face","elementor_library":"elementor_library"}},"required":false},"search_columns":{"default":[],"description":"\u691c\u7d22\u3059\u308b\u5217\u540d\u306e\u914d\u5217\u3002","type":"array","items":{"enum":["email","name","id","username","slug"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"username":{"description":"\u30e6\u30fc\u30b6\u30fc\u306e\u30ed\u30b0\u30a4\u30f3\u540d\u3002","type":"string","required":true},"name":{"description":"\u30e6\u30fc\u30b6\u30fc\u306e\u3001\u30d6\u30ed\u30b0\u4e0a\u306e\u8868\u793a\u540d\u3002","type":"string","required":false},"first_name":{"description":"\u30e6\u30fc\u30b6\u30fc\u306e\u540d\u3002","type":"string","required":false},"last_name":{"description":"\u30e6\u30fc\u30b6\u30fc\u306e\u59d3\u3002","type":"string","required":false},"email":{"description":"\u30e6\u30fc\u30b6\u30fc\u306e\u30e1\u30fc\u30eb\u30a2\u30c9\u30ec\u30b9\u3002","type":"string","format":"email","required":true},"url":{"description":"\u30e6\u30fc\u30b6\u30fc\u306e URL\u3002","type":"string","format":"uri","required":false},"description":{"description":"\u30e6\u30fc\u30b6\u30fc\u306e\u8aac\u660e\u3002","type":"string","required":false},"locale":{"description":"\u30e6\u30fc\u30b6\u30fc\u306e\u30ed\u30b1\u30fc\u30eb\u3002","type":"string","enum":["","en_US","ja"],"required":false},"nickname":{"description":"\u30e6\u30fc\u30b6\u30fc\u306e\u30cb\u30c3\u30af\u30cd\u30fc\u30e0\u3002","type":"string","required":false},"slug":{"description":"\u30e6\u30fc\u30b6\u30fc\u306e\u82f1\u6570\u5b57\u306e\u8b58\u5225\u5b50\u3002","type":"string","required":false},"roles":{"description":"\u30e6\u30fc\u30b6\u30fc\u306b\u5272\u308a\u5f53\u3066\u3089\u308c\u305f\u6a29\u9650\u30b0\u30eb\u30fc\u30d7\u3002","type":"array","items":{"type":"string"},"required":false},"password":{"description":"\u30e6\u30fc\u30b6\u30fc\u306e\u30d1\u30b9\u30ef\u30fc\u30c9 (\u542b\u307e\u308c\u308b\u3053\u3068\u306f\u3042\u308a\u307e\u305b\u3093)\u3002","type":"string","required":true},"meta":{"description":"\u30e1\u30bf\u30d5\u30a3\u30fc\u30eb\u30c9\u3002","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"\u8a2d\u5b9a\u304c\u66f4\u65b0\u3055\u308c\u305f\u65e5\u6642\u3067\u3059\u3002","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false},"elementor_introduction":{"description":"Elementor user meta data","type":"object","properties":{"ai_get_started":{"type":"boolean"}},"additionalProperties":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/users"}]}},"\/wp\/v2\/users\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u30e6\u30fc\u30b6\u30fc\u306e\u4e00\u610f\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u30e6\u30fc\u30b6\u30fc\u306e\u4e00\u610f\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"username":{"description":"\u30e6\u30fc\u30b6\u30fc\u306e\u30ed\u30b0\u30a4\u30f3\u540d\u3002","type":"string","required":false},"name":{"description":"\u30e6\u30fc\u30b6\u30fc\u306e\u3001\u30d6\u30ed\u30b0\u4e0a\u306e\u8868\u793a\u540d\u3002","type":"string","required":false},"first_name":{"description":"\u30e6\u30fc\u30b6\u30fc\u306e\u540d\u3002","type":"string","required":false},"last_name":{"description":"\u30e6\u30fc\u30b6\u30fc\u306e\u59d3\u3002","type":"string","required":false},"email":{"description":"\u30e6\u30fc\u30b6\u30fc\u306e\u30e1\u30fc\u30eb\u30a2\u30c9\u30ec\u30b9\u3002","type":"string","format":"email","required":false},"url":{"description":"\u30e6\u30fc\u30b6\u30fc\u306e URL\u3002","type":"string","format":"uri","required":false},"description":{"description":"\u30e6\u30fc\u30b6\u30fc\u306e\u8aac\u660e\u3002","type":"string","required":false},"locale":{"description":"\u30e6\u30fc\u30b6\u30fc\u306e\u30ed\u30b1\u30fc\u30eb\u3002","type":"string","enum":["","en_US","ja"],"required":false},"nickname":{"description":"\u30e6\u30fc\u30b6\u30fc\u306e\u30cb\u30c3\u30af\u30cd\u30fc\u30e0\u3002","type":"string","required":false},"slug":{"description":"\u30e6\u30fc\u30b6\u30fc\u306e\u82f1\u6570\u5b57\u306e\u8b58\u5225\u5b50\u3002","type":"string","required":false},"roles":{"description":"\u30e6\u30fc\u30b6\u30fc\u306b\u5272\u308a\u5f53\u3066\u3089\u308c\u305f\u6a29\u9650\u30b0\u30eb\u30fc\u30d7\u3002","type":"array","items":{"type":"string"},"required":false},"password":{"description":"\u30e6\u30fc\u30b6\u30fc\u306e\u30d1\u30b9\u30ef\u30fc\u30c9 (\u542b\u307e\u308c\u308b\u3053\u3068\u306f\u3042\u308a\u307e\u305b\u3093)\u3002","type":"string","required":false},"meta":{"description":"\u30e1\u30bf\u30d5\u30a3\u30fc\u30eb\u30c9\u3002","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"\u8a2d\u5b9a\u304c\u66f4\u65b0\u3055\u308c\u305f\u65e5\u6642\u3067\u3059\u3002","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false},"elementor_introduction":{"description":"Elementor user meta data","type":"object","properties":{"ai_get_started":{"type":"boolean"}},"additionalProperties":true,"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u30e6\u30fc\u30b6\u30fc\u306e\u4e00\u610f\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u30e6\u30fc\u30b6\u30fc\u304c\u30b4\u30df\u7bb1\u6a5f\u80fd\u306b\u5bfe\u5fdc\u3057\u3066\u3044\u306a\u3044\u305f\u3081\u3001true \u3067\u306a\u3051\u308c\u3070\u306a\u308a\u307e\u305b\u3093\u3002","required":false},"reassign":{"type":"integer","description":"\u524a\u9664\u3059\u308b\u30e6\u30fc\u30b6\u30fc\u306e\u6295\u7a3f\u3068\u30ea\u30f3\u30af\u3092\u3001\u6307\u5b9a ID \u306e\u30e6\u30fc\u30b6\u30fc\u306b\u5272\u308a\u5f53\u3066\u307e\u3059\u3002","required":true}}}]},"\/wp\/v2\/users\/me":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"username":{"description":"\u30e6\u30fc\u30b6\u30fc\u306e\u30ed\u30b0\u30a4\u30f3\u540d\u3002","type":"string","required":false},"name":{"description":"\u30e6\u30fc\u30b6\u30fc\u306e\u3001\u30d6\u30ed\u30b0\u4e0a\u306e\u8868\u793a\u540d\u3002","type":"string","required":false},"first_name":{"description":"\u30e6\u30fc\u30b6\u30fc\u306e\u540d\u3002","type":"string","required":false},"last_name":{"description":"\u30e6\u30fc\u30b6\u30fc\u306e\u59d3\u3002","type":"string","required":false},"email":{"description":"\u30e6\u30fc\u30b6\u30fc\u306e\u30e1\u30fc\u30eb\u30a2\u30c9\u30ec\u30b9\u3002","type":"string","format":"email","required":false},"url":{"description":"\u30e6\u30fc\u30b6\u30fc\u306e URL\u3002","type":"string","format":"uri","required":false},"description":{"description":"\u30e6\u30fc\u30b6\u30fc\u306e\u8aac\u660e\u3002","type":"string","required":false},"locale":{"description":"\u30e6\u30fc\u30b6\u30fc\u306e\u30ed\u30b1\u30fc\u30eb\u3002","type":"string","enum":["","en_US","ja"],"required":false},"nickname":{"description":"\u30e6\u30fc\u30b6\u30fc\u306e\u30cb\u30c3\u30af\u30cd\u30fc\u30e0\u3002","type":"string","required":false},"slug":{"description":"\u30e6\u30fc\u30b6\u30fc\u306e\u82f1\u6570\u5b57\u306e\u8b58\u5225\u5b50\u3002","type":"string","required":false},"roles":{"description":"\u30e6\u30fc\u30b6\u30fc\u306b\u5272\u308a\u5f53\u3066\u3089\u308c\u305f\u6a29\u9650\u30b0\u30eb\u30fc\u30d7\u3002","type":"array","items":{"type":"string"},"required":false},"password":{"description":"\u30e6\u30fc\u30b6\u30fc\u306e\u30d1\u30b9\u30ef\u30fc\u30c9 (\u542b\u307e\u308c\u308b\u3053\u3068\u306f\u3042\u308a\u307e\u305b\u3093)\u3002","type":"string","required":false},"meta":{"description":"\u30e1\u30bf\u30d5\u30a3\u30fc\u30eb\u30c9\u3002","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"\u8a2d\u5b9a\u304c\u66f4\u65b0\u3055\u308c\u305f\u65e5\u6642\u3067\u3059\u3002","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false},"elementor_introduction":{"description":"Elementor user meta data","type":"object","properties":{"ai_get_started":{"type":"boolean"}},"additionalProperties":true,"required":false}}},{"methods":["DELETE"],"args":{"force":{"type":"boolean","default":false,"description":"\u30e6\u30fc\u30b6\u30fc\u304c\u30b4\u30df\u7bb1\u6a5f\u80fd\u306b\u5bfe\u5fdc\u3057\u3066\u3044\u306a\u3044\u305f\u3081\u3001true \u3067\u306a\u3051\u308c\u3070\u306a\u308a\u307e\u305b\u3093\u3002","required":false},"reassign":{"type":"integer","description":"\u524a\u9664\u3059\u308b\u30e6\u30fc\u30b6\u30fc\u306e\u6295\u7a3f\u3068\u30ea\u30f3\u30af\u3092\u3001\u6307\u5b9a ID \u306e\u30e6\u30fc\u30b6\u30fc\u306b\u5272\u308a\u5f53\u3066\u307e\u3059\u3002","required":true}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/users\/me"}]}},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords":{"namespace":"wp\/v2","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"app_id":{"description":"\u30a2\u30d7\u30ea\u30b1\u30fc\u30b7\u30e7\u30f3\u304c\u63d0\u4f9b\u3057\u305f\u56fa\u6709\u8b58\u5225\u7528 UUID\u3002UUID v5\u3092 URL \u307e\u305f\u306f DNS \u306e\u540d\u524d\u7a7a\u9593\u3068\u5171\u306b\u4f7f\u3046\u3053\u3068\u3092\u304a\u3059\u3059\u3081\u3057\u307e\u3059\u3002","type":"string","oneOf":[{"type":"string","format":"uuid"},{"type":"string","enum":[""]}],"required":false},"name":{"description":"\u30a2\u30d7\u30ea\u30b1\u30fc\u30b7\u30e7\u30f3\u30d1\u30b9\u30ef\u30fc\u30c9\u306e\u540d\u79f0\u3002","type":"string","minLength":1,"pattern":".*\\S.*","required":true}}},{"methods":["DELETE"],"args":[]}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/introspect":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/(?P<uuid>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"app_id":{"description":"\u30a2\u30d7\u30ea\u30b1\u30fc\u30b7\u30e7\u30f3\u304c\u63d0\u4f9b\u3057\u305f\u56fa\u6709\u8b58\u5225\u7528 UUID\u3002UUID v5\u3092 URL \u307e\u305f\u306f DNS \u306e\u540d\u524d\u7a7a\u9593\u3068\u5171\u306b\u4f7f\u3046\u3053\u3068\u3092\u304a\u3059\u3059\u3081\u3057\u307e\u3059\u3002","type":"string","oneOf":[{"type":"string","format":"uuid"},{"type":"string","enum":[""]}],"required":false},"name":{"description":"\u30a2\u30d7\u30ea\u30b1\u30fc\u30b7\u30e7\u30f3\u30d1\u30b9\u30ef\u30fc\u30c9\u306e\u540d\u79f0\u3002","type":"string","minLength":1,"pattern":".*\\S.*","required":false}}},{"methods":["DELETE"],"args":[]}]},"\/wp\/v2\/comments":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u306e\u73fe\u5728\u306e\u30da\u30fc\u30b8\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u3068\u3057\u3066\u8fd4\u3055\u308c\u308b\u9805\u76ee\u306e\u6700\u5927\u6570\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u6587\u5b57\u5217\u306b\u4e00\u81f4\u3059\u308b\u3082\u306e\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","required":false},"after":{"description":"\u5165\u529b\u3055\u308c\u305f ISO8601 \u6e96\u62e0\u306e\u65e5\u4ed8\u3088\u308a\u5f8c\u306b\u516c\u958b\u3055\u308c\u305f\u30b3\u30e1\u30f3\u30c8\u306b\u30ec\u30b9\u30dd\u30f3\u30b9\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","format":"date-time","required":false},"author":{"description":"\u7279\u5b9a\u306e\u30e6\u30fc\u30b6\u30fc ID \u304c\u5272\u308a\u5f53\u3066\u3089\u308c\u305f\u30b3\u30e1\u30f3\u30c8\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002\u8a8d\u8a3c\u304c\u5fc5\u8981\u3067\u3059\u3002","type":"array","items":{"type":"integer"},"required":false},"author_exclude":{"description":"\u7279\u5b9a\u306e\u30e6\u30fc\u30b6\u30fc ID \u304c\u5272\u308a\u5f53\u3066\u3089\u308c\u305f\u30b3\u30e1\u30f3\u30c8\u3092\u7d50\u679c\u304b\u3089\u9664\u5916\u3057\u307e\u3059\u3002\u8a8d\u8a3c\u304c\u5fc5\u8981\u3067\u3059\u3002","type":"array","items":{"type":"integer"},"required":false},"author_email":{"default":null,"description":"\u7279\u5b9a\u306e\u6295\u7a3f\u8005\u306e\u30e1\u30fc\u30eb\u304b\u3089\u306e\u3082\u306e\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002\u8a8d\u8a3c\u304c\u5fc5\u8981\u3067\u3059\u3002","format":"email","type":"string","required":false},"before":{"description":"\u5165\u529b\u3055\u308c\u305f ISO8601 \u6e96\u62e0\u306e\u65e5\u4ed8\u3088\u308a\u524d\u306b\u516c\u958b\u3055\u308c\u305f\u30b3\u30e1\u30f3\u30c8\u306b\u30ec\u30b9\u30dd\u30f3\u30b9\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","format":"date-time","required":false},"exclude":{"description":"\u7279\u5b9a\u306e ID \u3092\u7d50\u679c\u304b\u3089\u9664\u5916\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u7279\u5b9a\u306e ID \u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u7279\u5b9a\u306e\u9805\u76ee\u6570\u3067\u7d50\u679c\u3092\u30aa\u30d5\u30bb\u30c3\u30c8\u3057\u307e\u3059\u3002","type":"integer","required":false},"order":{"description":"\u5c5e\u6027\u3067\u6607\u9806\u307e\u305f\u306f\u964d\u9806\u306b\u4e26\u3079\u66ff\u3048\u307e\u3059\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u30b3\u30e1\u30f3\u30c8\u306e\u5c5e\u6027\u3067\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u3092\u4e26\u3079\u66ff\u3048\u307e\u3059\u3002","type":"string","default":"date_gmt","enum":["date","date_gmt","id","include","post","parent","type"],"required":false},"parent":{"default":[],"description":"\u7279\u5b9a\u306e\u89aa ID \u306b\u5c5e\u3059\u308b\u30b3\u30e1\u30f3\u30c8\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"required":false},"parent_exclude":{"default":[],"description":"\u7279\u5b9a\u306e\u89aa ID \u3092\u7d50\u679c\u304b\u3089\u9664\u5916\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"required":false},"post":{"default":[],"description":"\u7279\u5b9a\u306e\u6295\u7a3f ID \u306b\u5272\u308a\u5f53\u3066\u3089\u308c\u305f\u30b3\u30e1\u30f3\u30c8\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"required":false},"status":{"default":"approve","description":"\u7279\u5b9a\u306e\u30b9\u30c6\u30fc\u30bf\u30b9\u304c\u5272\u308a\u5f53\u3066\u3089\u308c\u305f\u30b3\u30e1\u30f3\u30c8\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002\u8a8d\u8a3c\u304c\u5fc5\u8981\u3067\u3059\u3002","type":"string","required":false},"type":{"default":"comment","description":"\u7279\u5b9a\u306e\u30bf\u30a4\u30d7\u304c\u5272\u308a\u5f53\u3066\u3089\u308c\u305f\u30b3\u30e1\u30f3\u30c8\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002\u8a8d\u8a3c\u304c\u5fc5\u8981\u3067\u3059\u3002","type":"string","required":false},"password":{"description":"\u30d1\u30b9\u30ef\u30fc\u30c9\u3067\u4fdd\u8b77\u3055\u308c\u3066\u3044\u308b\u5834\u5408\u306e\u6295\u7a3f\u306e\u30d1\u30b9\u30ef\u30fc\u30c9\u3002","type":"string","required":false}}},{"methods":["POST"],"args":{"author":{"description":"\u6295\u7a3f\u8005\u304c\u30e6\u30fc\u30b6\u30fc\u3060\u3063\u305f\u5834\u5408\u306e\u3001\u30e6\u30fc\u30b6\u30fc\u30aa\u30d6\u30b8\u30a7\u30af\u30c8\u306e ID\u3002","type":"integer","required":false},"author_email":{"description":"\u30b3\u30e1\u30f3\u30c8\u6295\u7a3f\u8005\u306e\u30e1\u30fc\u30eb\u30a2\u30c9\u30ec\u30b9\u3002","type":"string","format":"email","required":false},"author_ip":{"description":"\u30b3\u30e1\u30f3\u30c8\u6295\u7a3f\u8005\u306e IP \u30a2\u30c9\u30ec\u30b9\u3002","type":"string","format":"ip","required":false},"author_name":{"description":"\u30b3\u30e1\u30f3\u30c8\u4f5c\u6210\u8005\u306e\u540d\u524d\u3092\u8868\u793a\u3057\u307e\u3059\u3002","type":"string","required":false},"author_url":{"description":"\u30b3\u30e1\u30f3\u30c8\u6295\u7a3f\u8005\u306e URL\u3002","type":"string","format":"uri","required":false},"author_user_agent":{"description":"\u30b3\u30e1\u30f3\u30c8\u6295\u7a3f\u8005\u306e\u30e6\u30fc\u30b6\u30fc\u30a8\u30fc\u30b8\u30a7\u30f3\u30c8\u3002","type":"string","required":false},"content":{"description":"\u30b3\u30e1\u30f3\u30c8\u306e\u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":"object","properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u5f62\u614b\u306e\u3001\u30b3\u30e1\u30f3\u30c8\u306e\u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u8868\u793a\u7528\u306b\u5909\u63db\u3055\u308c\u305f\u3001\u30b3\u30e1\u30f3\u30c8\u306e HTML \u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"\u30b3\u30e1\u30f3\u30c8\u306e\u516c\u958b\u65e5 (\u30b5\u30a4\u30c8\u306e\u30bf\u30a4\u30e0\u30be\u30fc\u30f3)\u3002","type":"string","format":"date-time","required":false},"date_gmt":{"description":"\u30b3\u30e1\u30f3\u30c8\u306e\u516c\u958b\u65e5 (GMT)\u3002","type":"string","format":"date-time","required":false},"parent":{"default":0,"description":"\u89aa\u30b3\u30e1\u30f3\u30c8\u306e ID\u3002","type":"integer","required":false},"post":{"default":0,"description":"\u95a2\u9023\u6295\u7a3f\u30aa\u30d6\u30b8\u30a7\u30af\u30c8\u306e ID\u3002","type":"integer","required":false},"status":{"description":"\u30b3\u30e1\u30f3\u30c8\u306e\u30b9\u30c6\u30fc\u30bf\u30b9\u3002","type":"string","required":false},"meta":{"description":"\u30e1\u30bf\u30d5\u30a3\u30fc\u30eb\u30c9\u3002","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"\u30ce\u30fc\u30c8\u306e\u89e3\u6c7a\u306e\u72b6\u6cc1","default":"","enum":["resolved","reopen"]}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/comments"}]}},"\/wp\/v2\/comments\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u30b3\u30e1\u30f3\u30c8\u306e\u4e00\u610f\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"\u30b3\u30e1\u30f3\u30c8\u306e\u89aa\u6295\u7a3f\u306e\u30d1\u30b9\u30ef\u30fc\u30c9 (\u6295\u7a3f\u304c\u30d1\u30b9\u30ef\u30fc\u30c9\u4fdd\u8b77\u3055\u308c\u3066\u3044\u308b\u5834\u5408)\u3002","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"\u30b3\u30e1\u30f3\u30c8\u306e\u4e00\u610f\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"author":{"description":"\u6295\u7a3f\u8005\u304c\u30e6\u30fc\u30b6\u30fc\u3060\u3063\u305f\u5834\u5408\u306e\u3001\u30e6\u30fc\u30b6\u30fc\u30aa\u30d6\u30b8\u30a7\u30af\u30c8\u306e ID\u3002","type":"integer","required":false},"author_email":{"description":"\u30b3\u30e1\u30f3\u30c8\u6295\u7a3f\u8005\u306e\u30e1\u30fc\u30eb\u30a2\u30c9\u30ec\u30b9\u3002","type":"string","format":"email","required":false},"author_ip":{"description":"\u30b3\u30e1\u30f3\u30c8\u6295\u7a3f\u8005\u306e IP \u30a2\u30c9\u30ec\u30b9\u3002","type":"string","format":"ip","required":false},"author_name":{"description":"\u30b3\u30e1\u30f3\u30c8\u4f5c\u6210\u8005\u306e\u540d\u524d\u3092\u8868\u793a\u3057\u307e\u3059\u3002","type":"string","required":false},"author_url":{"description":"\u30b3\u30e1\u30f3\u30c8\u6295\u7a3f\u8005\u306e URL\u3002","type":"string","format":"uri","required":false},"author_user_agent":{"description":"\u30b3\u30e1\u30f3\u30c8\u6295\u7a3f\u8005\u306e\u30e6\u30fc\u30b6\u30fc\u30a8\u30fc\u30b8\u30a7\u30f3\u30c8\u3002","type":"string","required":false},"content":{"description":"\u30b3\u30e1\u30f3\u30c8\u306e\u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":"object","properties":{"raw":{"description":"\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u5b58\u5728\u3059\u308b\u5f62\u614b\u306e\u3001\u30b3\u30e1\u30f3\u30c8\u306e\u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u8868\u793a\u7528\u306b\u5909\u63db\u3055\u308c\u305f\u3001\u30b3\u30e1\u30f3\u30c8\u306e HTML \u30b3\u30f3\u30c6\u30f3\u30c4\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"\u30b3\u30e1\u30f3\u30c8\u306e\u516c\u958b\u65e5 (\u30b5\u30a4\u30c8\u306e\u30bf\u30a4\u30e0\u30be\u30fc\u30f3)\u3002","type":"string","format":"date-time","required":false},"date_gmt":{"description":"\u30b3\u30e1\u30f3\u30c8\u306e\u516c\u958b\u65e5 (GMT)\u3002","type":"string","format":"date-time","required":false},"parent":{"description":"\u89aa\u30b3\u30e1\u30f3\u30c8\u306e ID\u3002","type":"integer","required":false},"post":{"description":"\u95a2\u9023\u6295\u7a3f\u30aa\u30d6\u30b8\u30a7\u30af\u30c8\u306e ID\u3002","type":"integer","required":false},"status":{"description":"\u30b3\u30e1\u30f3\u30c8\u306e\u30b9\u30c6\u30fc\u30bf\u30b9\u3002","type":"string","required":false},"meta":{"description":"\u30e1\u30bf\u30d5\u30a3\u30fc\u30eb\u30c9\u3002","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"\u30ce\u30fc\u30c8\u306e\u89e3\u6c7a\u306e\u72b6\u6cc1","default":"","enum":["resolved","reopen"]}},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"\u30b3\u30e1\u30f3\u30c8\u306e\u4e00\u610f\u8b58\u5225\u5b50\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u30b4\u30df\u7bb1\u306b\u5165\u308c\u305a\u306b\u5f37\u5236\u7684\u306b\u524a\u9664\u3059\u308b\u304b\u3069\u3046\u304b\u3002","required":false},"password":{"description":"\u30b3\u30e1\u30f3\u30c8\u306e\u89aa\u6295\u7a3f\u306e\u30d1\u30b9\u30ef\u30fc\u30c9 (\u6295\u7a3f\u304c\u30d1\u30b9\u30ef\u30fc\u30c9\u4fdd\u8b77\u3055\u308c\u3066\u3044\u308b\u5834\u5408)\u3002","type":"string","required":false}}}]},"\/wp\/v2\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed"],"default":"view","required":false},"page":{"description":"\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u306e\u73fe\u5728\u306e\u30da\u30fc\u30b8\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u3068\u3057\u3066\u8fd4\u3055\u308c\u308b\u9805\u76ee\u306e\u6700\u5927\u6570\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u6587\u5b57\u5217\u306b\u4e00\u81f4\u3059\u308b\u3082\u306e\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","required":false},"type":{"default":"post","description":"\u30aa\u30d6\u30b8\u30a7\u30af\u30c8\u30bf\u30a4\u30d7\u306e\u30a2\u30a4\u30c6\u30e0\u306e\u7d50\u679c\u3092\u5236\u9650\u3057\u307e\u3059\u3002","type":"string","enum":["post","term","post-format"],"required":false},"subtype":{"default":"any","description":"1\u3064\u4ee5\u4e0a\u306e\u30aa\u30d6\u30b8\u30a7\u30af\u30c8\u30b5\u30d6\u30bf\u30a4\u30d7\u306e\u30a2\u30a4\u30c6\u30e0\u306e\u7d50\u679c\u3092\u5236\u9650\u3057\u307e\u3059\u3002","type":"array","items":{"enum":["post","page","elementor_library","category","post_tag","any"],"type":"string"},"required":false},"exclude":{"description":"\u7279\u5b9a\u306e ID \u3092\u7d50\u679c\u304b\u3089\u9664\u5916\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u7279\u5b9a\u306e ID \u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/search"}]}},"\/wp\/v2\/block-renderer\/(?P<name>[a-z0-9-]+\/[a-z0-9-]+)":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET","POST"],"args":{"name":{"description":"\u30d6\u30ed\u30c3\u30af\u306e\u30e6\u30cb\u30fc\u30af\u306a\u767b\u9332\u540d\u3002","type":"string","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["edit"],"default":"view","required":false},"attributes":{"description":"\u30d6\u30ed\u30c3\u30af\u306e\u5c5e\u6027\u3002","type":"object","default":[],"required":false},"post_id":{"description":"\u6295\u7a3f\u30b3\u30f3\u30c6\u30ad\u30b9\u30c8\u306e ID\u3002","type":"integer","required":false}}}]},"\/wp\/v2\/block-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"\u30d6\u30ed\u30c3\u30af\u540d\u524d\u7a7a\u9593\u3002","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/block-types"}]}},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"\u30d6\u30ed\u30c3\u30af\u540d\u524d\u7a7a\u9593\u3002","type":"string","required":false}}}]},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)\/(?P<name>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"\u30d6\u30ed\u30c3\u30af\u540d\u3002","type":"string","required":false},"namespace":{"description":"\u30d6\u30ed\u30c3\u30af\u540d\u524d\u7a7a\u9593\u3002","type":"string","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/settings":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"themeisle_sdk_promotions":{"title":"","description":"","type":"string","required":false},"themeisle_sdk_promotions_otter_installed":{"title":"","description":"","type":"boolean","required":false},"themeisle_sdk_promotions_optimole_installed":{"title":"","description":"","type":"boolean","required":false},"themeisle_sdk_promotions_rop_installed":{"title":"","description":"","type":"boolean","required":false},"themeisle_sdk_promotions_neve_installed":{"title":"","description":"","type":"boolean","required":false},"themeisle_sdk_promotions_redirection_cf7_installed":{"title":"","description":"","type":"boolean","required":false},"themeisle_sdk_promotions_hyve_installed":{"title":"","description":"","type":"boolean","required":false},"themeisle_sdk_promotions_wp_full_pay_installed":{"title":"","description":"","type":"boolean","required":false},"themeisle_sdk_promotions_masteriyo_installed":{"title":"","description":"","type":"boolean","required":false},"title":{"title":"\u30bf\u30a4\u30c8\u30eb","description":"\u30b5\u30a4\u30c8\u540d\u3002","type":"string","required":false},"description":{"title":"\u30ad\u30e3\u30c3\u30c1\u30d5\u30ec\u30fc\u30ba","description":"\u30b5\u30a4\u30c8\u306e\u30ad\u30e3\u30c3\u30c1\u30d5\u30ec\u30fc\u30ba\u3002","type":"string","required":false},"url":{"title":"","description":"\u30b5\u30a4\u30c8 URL\u3002","type":"string","format":"uri","required":false},"email":{"title":"","description":"\u3053\u306e\u30a2\u30c9\u30ec\u30b9\u306f\u65b0\u898f\u30e6\u30fc\u30b6\u30fc\u306e\u901a\u77e5\u306a\u3069\u30b5\u30a4\u30c8\u7ba1\u7406\u306e\u305f\u3081\u306b\u4f7f\u308f\u308c\u307e\u3059\u3002","type":"string","format":"email","required":false},"timezone":{"title":"","description":"\u73fe\u5728\u5730\u3068\u540c\u3058\u30bf\u30a4\u30e0\u30be\u30fc\u30f3\u306e\u90fd\u5e02\u3002","type":"string","required":false},"date_format":{"title":"","description":"\u65e5\u4ed8\u6587\u5b57\u5217\u306e\u66f8\u5f0f\u3002","type":"string","required":false},"time_format":{"title":"","description":"\u6642\u523b\u6587\u5b57\u5217\u306e\u66f8\u5f0f\u3002","type":"string","required":false},"start_of_week":{"title":"","description":"\u9031\u306e\u59cb\u307e\u308a\u306e\u66dc\u65e5\u756a\u53f7\u3002","type":"integer","required":false},"language":{"title":"","description":"WordPress \u306e\u30ed\u30b1\u30fc\u30eb\u30b3\u30fc\u30c9\u3002","type":"string","required":false},"use_smilies":{"title":"","description":":-) \u3084 :-P \u306a\u3069\u306e\u9854\u6587\u5b57\u3092\u7d75\u6587\u5b57\u306b\u5909\u63db\u3057\u307e\u3059\u3002","type":"boolean","required":false},"default_category":{"title":"","description":"\u30c7\u30d5\u30a9\u30eb\u30c8\u306e\u6295\u7a3f\u30ab\u30c6\u30b4\u30ea\u30fc\u3002","type":"integer","required":false},"default_post_format":{"title":"","description":"\u30c7\u30d5\u30a9\u30eb\u30c8\u306e\u6295\u7a3f\u30d5\u30a9\u30fc\u30de\u30c3\u30c8\u3002","type":"string","required":false},"posts_per_page":{"title":"\u30da\u30fc\u30b8\u3054\u3068\u306e\u6700\u5927\u6295\u7a3f\u6570","description":"\u8868\u793a\u3059\u308b\u6700\u5927\u6295\u7a3f\u6570\u3002","type":"integer","required":false},"show_on_front":{"title":"\u30d5\u30ed\u30f3\u30c8\u30da\u30fc\u30b8\u3067\u306e\u8868\u793a","description":"\u30d5\u30ed\u30f3\u30c8\u30da\u30fc\u30b8\u306b\u8868\u793a\u3059\u308b\u5185\u5bb9","type":"string","required":false},"page_on_front":{"title":"\u30d5\u30ed\u30f3\u30c8\u30da\u30fc\u30b8\u306e\u30da\u30fc\u30b8","description":"\u30d5\u30ed\u30f3\u30c8\u30da\u30fc\u30b8\u306b\u8868\u793a\u3059\u308b\u30da\u30fc\u30b8\u306e ID","type":"integer","required":false},"page_for_posts":{"title":"","description":"\u6700\u65b0\u306e\u6295\u7a3f\u3092\u8868\u793a\u3059\u308b\u30da\u30fc\u30b8\u306e ID","type":"integer","required":false},"default_ping_status":{"title":"","description":"\u65b0\u3057\u3044\u8a18\u4e8b\u306b\u5bfe\u3057\u4ed6\u306e\u30d6\u30ed\u30b0\u304b\u3089\u306e\u901a\u77e5 (\u30d4\u30f3\u30d0\u30c3\u30af\u30fb\u30c8\u30e9\u30c3\u30af\u30d0\u30c3\u30af) \u3092\u53d7\u3051\u4ed8\u3051\u308b\u3002","type":"string","enum":["open","closed"],"required":false},"default_comment_status":{"title":"\u65b0\u898f\u6295\u7a3f\u3078\u306e\u30b3\u30e1\u30f3\u30c8\u3092\u8a31\u53ef\u3059\u308b","description":"\u65b0\u3057\u3044\u6295\u7a3f\u3078\u306e\u30b3\u30e1\u30f3\u30c8\u3092\u8a31\u53ef\u3059\u308b\u3002","type":"string","enum":["open","closed"],"required":false},"site_logo":{"title":"\u30ed\u30b4","description":"\u30b5\u30a4\u30c8\u30ed\u30b4\u3002","type":"integer","required":false},"site_icon":{"title":"\u30a2\u30a4\u30b3\u30f3","description":"\u30b5\u30a4\u30c8\u30a2\u30a4\u30b3\u30f3\u3002","type":"integer","required":false},"elementor_one_welcome_screen_completed":{"title":"","description":"Elementor One Welcome Screen Completed","type":"boolean","required":false},"elementor_one_dismiss_connect_alert":{"title":"","description":"Elementor One Dismiss Connect Alert","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/settings"}]}},"\/wp\/v2\/themes":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"1\u3064\u4ee5\u4e0a\u306e\u30b9\u30c6\u30fc\u30bf\u30b9\u304c\u5272\u308a\u5f53\u3066\u3089\u308c\u305f\u30c6\u30fc\u30de\u306b\u7d50\u679c\u30bb\u30c3\u30c8\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","items":{"enum":["active","inactive"],"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/themes"}]}},"\/wp\/v2\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"stylesheet":{"description":"\u30c6\u30fc\u30de\u306e\u30b9\u30bf\u30a4\u30eb\u30b7\u30fc\u30c8\u3002\u30c6\u30fc\u30de\u3092\u4e00\u610f\u306b\u8b58\u5225\u3057\u307e\u3059\u3002","type":"string","required":false}}}]},"\/wp\/v2\/plugins":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"search":{"description":"\u6587\u5b57\u5217\u306b\u4e00\u81f4\u3059\u308b\u3082\u306e\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","required":false},"status":{"description":"\u6307\u5b9a\u3057\u305f\u30b9\u30c6\u30fc\u30bf\u30b9\u306b\u4e00\u81f4\u3059\u308b\u30d7\u30e9\u30b0\u30a4\u30f3\u306e\u307f\u306b\u7d50\u679c\u3092\u5236\u9650\u3057\u307e\u3059\u3002","type":"array","items":{"type":"string","enum":["inactive","active"]},"required":false}}},{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org \u30d7\u30e9\u30b0\u30a4\u30f3\u30c7\u30a3\u30ec\u30af\u30c8\u30ea\u306e\u30b9\u30e9\u30c3\u30b0\u3002","pattern":"[\\w\\-]+","required":true},"status":{"description":"\u30d7\u30e9\u30b0\u30a4\u30f3\u306e\u6709\u52b9\u5316\u30b9\u30c6\u30fc\u30bf\u30b9\u3002","type":"string","enum":["inactive","active"],"default":"inactive","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/plugins"}]}},"\/wp\/v2\/plugins\/(?P<plugin>[^.\\\/]+(?:\\\/[^.\\\/]+)?)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false},"status":{"description":"\u30d7\u30e9\u30b0\u30a4\u30f3\u306e\u6709\u52b9\u5316\u30b9\u30c6\u30fc\u30bf\u30b9\u3002","type":"string","enum":["inactive","active"],"required":false}}},{"methods":["DELETE"],"args":{"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false}}}]},"\/wp\/v2\/sidebars":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/sidebars"}]}},"\/wp\/v2\/sidebars\/(?P<id>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u767b\u9332\u3055\u308c\u305f\u30b5\u30a4\u30c9\u30d0\u30fc\u306e ID","type":"string","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"widgets":{"description":"\u30cd\u30b9\u30c8\u3057\u305f\u30a6\u30a3\u30b8\u30a7\u30c3\u30c8\u3002","type":"array","items":{"type":["object","string"]},"required":false}}}]},"\/wp\/v2\/widget-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/widget-types"}]}},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u30a6\u30a3\u30b8\u30a7\u30c3\u30c8\u30bf\u30a4\u30d7 ID\u3002","type":"string","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/encode":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"\u30a6\u30a3\u30b8\u30a7\u30c3\u30c8\u30bf\u30a4\u30d7 ID\u3002","type":"string","required":true},"instance":{"description":"\u30a6\u30a3\u30b8\u30a7\u30c3\u30c8\u306e\u73fe\u5728\u306e\u30a4\u30f3\u30b9\u30bf\u30f3\u30b9\u8a2d\u5b9a\u3002","type":"object","required":false},"form_data":{"description":"\u30a4\u30f3\u30b9\u30bf\u30f3\u30b9\u8a2d\u5b9a\u306b\u30a8\u30f3\u30b3\u30fc\u30c9\u3055\u308c\u308b\u30b7\u30ea\u30a2\u30eb\u5316\u3055\u308c\u305f\u30a6\u30a3\u30b8\u30a7\u30c3\u30c8\u306e\u30d5\u30a9\u30fc\u30e0\u30c7\u30fc\u30bf\u3002","type":"string","required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/render":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"\u30a6\u30a3\u30b8\u30a7\u30c3\u30c8\u30bf\u30a4\u30d7 ID\u3002","type":"string","required":true},"instance":{"description":"\u30a6\u30a3\u30b8\u30a7\u30c3\u30c8\u306e\u73fe\u5728\u306e\u30a4\u30f3\u30b9\u30bf\u30f3\u30b9\u8a2d\u5b9a\u3002","type":"object","required":false}}}]},"\/wp\/v2\/widgets":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"sidebar":{"description":"\u30a6\u30a3\u30b8\u30a7\u30c3\u30c8\u3092\u623b\u3059\u305f\u3081\u306e\u30b5\u30a4\u30c9\u30d0\u30fc\u3002","type":"string","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u30a6\u30a3\u30b8\u30a7\u30c3\u30c8\u306e\u56fa\u6709\u8b58\u5225\u5b50\u3002","type":"string","required":false},"id_base":{"description":"\u30a6\u30a3\u30b8\u30a7\u30c3\u30c8\u306e\u30bf\u30a4\u30d7\u3002widget-types \u30a8\u30f3\u30c9\u30dd\u30a4\u30f3\u30c8\u306e ID \u3068\u5bfe\u5fdc\u3057\u307e\u3059\u3002","type":"string","required":false},"sidebar":{"default":"wp_inactive_widgets","description":"\u30a6\u30a3\u30b8\u30a7\u30c3\u30c8\u304c\u5c5e\u3059\u308b\u30b5\u30a4\u30c9\u30d0\u30fc\u3002","type":"string","required":true},"instance":{"description":"\u30b5\u30dd\u30fc\u30c8\u3057\u3066\u3044\u308b\u5834\u5408\u3001\u30a6\u30a3\u30b8\u30a7\u30c3\u30c8\u306e\u30a4\u30f3\u30b9\u30bf\u30f3\u30b9\u8a2d\u5b9a\u3002","type":"object","properties":{"encoded":{"description":"\u30a4\u30f3\u30b9\u30bf\u30f3\u30b9\u8a2d\u5b9a\u306e Base64 \u30a8\u30f3\u30b3\u30fc\u30c9\u8868\u73fe\u3002","type":"string","context":["edit"]},"hash":{"description":"\u30a4\u30f3\u30b9\u30bf\u30f3\u30b9\u8a2d\u5b9a\u306e\u6697\u53f7\u5316\u30cf\u30c3\u30b7\u30e5\u3002","type":"string","context":["edit"]},"raw":{"description":"\u30b5\u30dd\u30fc\u30c8\u3057\u3066\u3044\u308b\u5834\u5408\u3001\u30c7\u30b3\u30fc\u30c9\u3057\u305f\u30a4\u30f3\u30b9\u30bf\u30f3\u30b9\u8a2d\u5b9a\u3002","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"\u30a6\u30a3\u30b8\u30a7\u30c3\u30c8\u7ba1\u7406\u30d5\u30a9\u30fc\u30e0\u304b\u3089 URL \u30a8\u30f3\u30b3\u30fc\u30c9\u3057\u305f\u30d5\u30a9\u30fc\u30e0\u30c7\u30fc\u30bf\u3002\u30a4\u30f3\u30b9\u30bf\u30f3\u30b9\u3092\u30b5\u30dd\u30fc\u30c8\u3057\u306a\u3044\u30a6\u30a3\u30b8\u30a7\u30c3\u30c8\u306e\u66f4\u65b0\u306b\u4f7f\u7528\u3055\u308c\u307e\u3059\u3002\u66f8\u304d\u8fbc\u307f\u306e\u307f\u3002","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/widgets"}]}},"\/wp\/v2\/widgets\/(?P<id>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u30a6\u30a3\u30b8\u30a7\u30c3\u30c8\u306e\u56fa\u6709\u8b58\u5225\u5b50\u3002","type":"string","required":false},"id_base":{"description":"\u30a6\u30a3\u30b8\u30a7\u30c3\u30c8\u306e\u30bf\u30a4\u30d7\u3002widget-types \u30a8\u30f3\u30c9\u30dd\u30a4\u30f3\u30c8\u306e ID \u3068\u5bfe\u5fdc\u3057\u307e\u3059\u3002","type":"string","required":false},"sidebar":{"description":"\u30a6\u30a3\u30b8\u30a7\u30c3\u30c8\u304c\u5c5e\u3059\u308b\u30b5\u30a4\u30c9\u30d0\u30fc\u3002","type":"string","required":false},"instance":{"description":"\u30b5\u30dd\u30fc\u30c8\u3057\u3066\u3044\u308b\u5834\u5408\u3001\u30a6\u30a3\u30b8\u30a7\u30c3\u30c8\u306e\u30a4\u30f3\u30b9\u30bf\u30f3\u30b9\u8a2d\u5b9a\u3002","type":"object","properties":{"encoded":{"description":"\u30a4\u30f3\u30b9\u30bf\u30f3\u30b9\u8a2d\u5b9a\u306e Base64 \u30a8\u30f3\u30b3\u30fc\u30c9\u8868\u73fe\u3002","type":"string","context":["edit"]},"hash":{"description":"\u30a4\u30f3\u30b9\u30bf\u30f3\u30b9\u8a2d\u5b9a\u306e\u6697\u53f7\u5316\u30cf\u30c3\u30b7\u30e5\u3002","type":"string","context":["edit"]},"raw":{"description":"\u30b5\u30dd\u30fc\u30c8\u3057\u3066\u3044\u308b\u5834\u5408\u3001\u30c7\u30b3\u30fc\u30c9\u3057\u305f\u30a4\u30f3\u30b9\u30bf\u30f3\u30b9\u8a2d\u5b9a\u3002","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"\u30a6\u30a3\u30b8\u30a7\u30c3\u30c8\u7ba1\u7406\u30d5\u30a9\u30fc\u30e0\u304b\u3089 URL \u30a8\u30f3\u30b3\u30fc\u30c9\u3057\u305f\u30d5\u30a9\u30fc\u30e0\u30c7\u30fc\u30bf\u3002\u30a4\u30f3\u30b9\u30bf\u30f3\u30b9\u3092\u30b5\u30dd\u30fc\u30c8\u3057\u306a\u3044\u30a6\u30a3\u30b8\u30a7\u30c3\u30c8\u306e\u66f4\u65b0\u306b\u4f7f\u7528\u3055\u308c\u307e\u3059\u3002\u66f8\u304d\u8fbc\u307f\u306e\u307f\u3002","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"force":{"description":"\u5f37\u5236\u7684\u306b\u30a6\u30a3\u30b8\u30a7\u30c3\u30c8\u3092\u524a\u9664\u3059\u308b\u304b\u3001\u7121\u52b9\u5316\u30b5\u30a4\u30c9\u30d0\u30fc\u306b\u79fb\u52d5\u3059\u308b\u304b\u3069\u3046\u304b\u3002","type":"boolean","required":false}}}]},"\/wp\/v2\/block-directory\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view"],"default":"view","required":false},"page":{"description":"\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u306e\u73fe\u5728\u306e\u30da\u30fc\u30b8\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u3068\u3057\u3066\u8fd4\u3055\u308c\u308b\u9805\u76ee\u306e\u6700\u5927\u6570\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"term":{"description":"\u691c\u7d22\u30ad\u30fc\u30ef\u30fc\u30c9\u306b\u4e00\u81f4\u3059\u308b\u30d6\u30ed\u30c3\u30af\u306e\u307f\u306b\u7d50\u679c\u30bb\u30c3\u30c8\u3092\u5236\u9650\u3057\u307e\u3059\u3002","type":"string","minLength":1,"required":true}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/block-directory\/search"}]}},"\/wp\/v2\/pattern-directory\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u306e\u73fe\u5728\u306e\u30da\u30fc\u30b8\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u3068\u3057\u3066\u8fd4\u3055\u308c\u308b\u9805\u76ee\u306e\u6700\u5927\u6570\u3002","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u6587\u5b57\u5217\u306b\u4e00\u81f4\u3059\u308b\u3082\u306e\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","minLength":1,"required":false},"category":{"description":"\u30ab\u30c6\u30b4\u30ea\u30fc ID \u306b\u4e00\u81f4\u3059\u308b\u3082\u306e\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"integer","minimum":1,"required":false},"keyword":{"description":"\u30ad\u30fc\u30ef\u30fc\u30c9 ID \u306b\u4e00\u81f4\u3059\u308b\u3082\u306e\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"integer","minimum":1,"required":false},"slug":{"description":"\u30d1\u30bf\u30fc\u30f3 (\u30b9\u30e9\u30c3\u30b0) \u306b\u4e00\u81f4\u3059\u308b\u3082\u306e\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"array","required":false},"offset":{"description":"\u7279\u5b9a\u306e\u9805\u76ee\u6570\u3067\u7d50\u679c\u3092\u30aa\u30d5\u30bb\u30c3\u30c8\u3057\u307e\u3059\u3002","type":"integer","required":false},"order":{"description":"\u5c5e\u6027\u3067\u6607\u9806\u307e\u305f\u306f\u964d\u9806\u306b\u4e26\u3079\u66ff\u3048\u307e\u3059\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6295\u7a3f\u306e\u5c5e\u6027\u3067\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u3092\u4e26\u3079\u66ff\u3048\u307e\u3059\u3002","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","favorite_count"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/pattern-directory\/patterns"}]}},"\/wp\/v2\/block-patterns\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/block-patterns\/patterns"}]}},"\/wp\/v2\/block-patterns\/categories":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/block-patterns\/categories"}]}},"\/wp-site-health\/v1":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-site-health\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp-site-health\/v1"}]}},"\/wp-site-health\/v1\/tests\/background-updates":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp-site-health\/v1\/tests\/background-updates"}]}},"\/wp-site-health\/v1\/tests\/loopback-requests":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp-site-health\/v1\/tests\/loopback-requests"}]}},"\/wp-site-health\/v1\/tests\/https-status":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp-site-health\/v1\/tests\/https-status"}]}},"\/wp-site-health\/v1\/tests\/dotorg-communication":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp-site-health\/v1\/tests\/dotorg-communication"}]}},"\/wp-site-health\/v1\/tests\/authorization-header":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp-site-health\/v1\/tests\/authorization-header"}]}},"\/wp-site-health\/v1\/directory-sizes":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp-site-health\/v1\/directory-sizes"}]}},"\/wp-site-health\/v1\/tests\/page-cache":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp-site-health\/v1\/tests\/page-cache"}]}},"\/wp-block-editor\/v1":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-block-editor\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp-block-editor\/v1"}]}},"\/wp-block-editor\/v1\/url-details":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"\u51e6\u7406\u3059\u308b URL\u3002","type":"string","format":"uri","required":true}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp-block-editor\/v1\/url-details"}]}},"\/wp\/v2\/menu-locations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/menu-locations"}]}},"\/wp\/v2\/menu-locations\/(?P<location>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"location":{"description":"\u30e1\u30cb\u30e5\u30fc\u4f4d\u7f6e\u306e\u82f1\u6570\u5b57\u306e\u8b58\u5225\u5b50\u3002","type":"string","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp-block-editor\/v1\/export":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp-block-editor\/v1\/export"}]}},"\/wp-block-editor\/v1\/navigation-fallback":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp-block-editor\/v1\/navigation-fallback"}]}},"\/wp\/v2\/font-collections":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u306e\u73fe\u5728\u306e\u30da\u30fc\u30b8\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u3068\u3057\u3066\u8fd4\u3055\u308c\u308b\u9805\u76ee\u306e\u6700\u5927\u6570\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/font-collections"}]}},"\/wp\/v2\/font-collections\/(?P<slug>[\\\/\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp-abilities\/v1":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-abilities\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp-abilities\/v1"}]}},"\/wp-abilities\/v1\/categories":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u306e\u73fe\u5728\u306e\u30da\u30fc\u30b8\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u3068\u3057\u3066\u8fd4\u3055\u308c\u308b\u9805\u76ee\u306e\u6700\u5927\u6570\u3002","type":"integer","default":50,"minimum":1,"maximum":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp-abilities\/v1\/categories"}]}},"\/wp-abilities\/v1\/categories\/(?P<slug>[a-z0-9]+(?:-[a-z0-9]+)*)":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"\u30a2\u30d3\u30ea\u30c6\u30a3\u30ab\u30c6\u30b4\u30ea\u30fc\u306e\u4e00\u610f\u306e\u8b58\u5225\u5b50\u3002","type":"string","pattern":"^[a-z0-9]+(?:-[a-z0-9]+)*$","required":false}}}]},"\/wp-abilities\/v1\/abilities\/(?P<name>[a-zA-Z0-9\\-\\\/]+?)\/run":{"namespace":"wp-abilities\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"name":{"description":"\u30a2\u30d3\u30ea\u30c6\u30a3\u306e\u4e00\u610f\u306e\u8b58\u5225\u5b50\u3002","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false},"input":{"description":"\u30a2\u30d3\u30ea\u30c6\u30a3\u5b9f\u884c\u306e\u5165\u529b\u30d1\u30e9\u30e1\u30fc\u30bf\u3002","type":["integer","number","boolean","string","array","object","null"],"default":null,"required":false}}}]},"\/wp-abilities\/v1\/abilities":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u306e\u73fe\u5728\u306e\u30da\u30fc\u30b8\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u3068\u3057\u3066\u8fd4\u3055\u308c\u308b\u9805\u76ee\u306e\u6700\u5927\u6570\u3002","type":"integer","default":50,"minimum":1,"maximum":100,"required":false},"category":{"description":"\u7279\u5b9a\u306e\u30a2\u30d3\u30ea\u30c6\u30a3\u30ab\u30c6\u30b4\u30ea\u30fc\u306e\u30a2\u30d3\u30ea\u30c6\u30a3\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp-abilities\/v1\/abilities"}]}},"\/wp-abilities\/v1\/abilities\/(?P<name>[a-zA-Z0-9\\-\\\/]+)":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"\u30a2\u30d3\u30ea\u30c6\u30a3\u306e\u4e00\u610f\u306e\u8b58\u5225\u5b50\u3002","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false}}}]},"\/wp\/v2\/icons":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u30b3\u30ec\u30af\u30b7\u30e7\u30f3\u306e\u73fe\u5728\u306e\u30da\u30fc\u30b8\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7d50\u679c\u3068\u3057\u3066\u8fd4\u3055\u308c\u308b\u9805\u76ee\u306e\u6700\u5927\u6570\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u6587\u5b57\u5217\u306b\u4e00\u81f4\u3059\u308b\u3082\u306e\u306b\u7d50\u679c\u3092\u9650\u5b9a\u3057\u307e\u3059\u3002","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/icons"}]}},"\/wp\/v2\/icons\/(?P<name>[a-z][a-z0-9-]*\/[a-z][a-z0-9-]*)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"\u30a2\u30a4\u30b3\u30f3\u540d\u3002","type":"string","required":false},"context":{"description":"\u3053\u306e\u30ea\u30af\u30a8\u30b9\u30c8\u304c\u4f5c\u6210\u3055\u308c\u305f\u30b9\u30b3\u30fc\u30d7\u3002\u30ec\u30b9\u30dd\u30f3\u30b9\u306b\u542b\u307e\u308c\u308b\u30d5\u30a3\u30fc\u30eb\u30c9\u306f\u30b9\u30b3\u30fc\u30d7\u306b\u3088\u308a\u7570\u306a\u308a\u307e\u3059\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]}},"site_logo":0,"site_icon":0,"site_icon_url":"","_links":{"help":[{"href":"https:\/\/developer.wordpress.org\/rest-api\/"}]}}
