{"id":12373,"date":"2022-08-18T19:10:18","date_gmt":"2022-08-18T10:10:18","guid":{"rendered":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/?p=12373"},"modified":"2025-06-20T14:05:03","modified_gmt":"2025-06-20T05:05:03","slug":"solidworks","status":"publish","type":"post","link":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/first\/12373\/","title":{"rendered":"SOLIDWORKS"},"content":{"rendered":"\t\t<div data-elementor-type=\"wp-post\" data-elementor-id=\"12373\" class=\"elementor elementor-12373\">\n\t\t\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-b90bace elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"b90bace\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-f357856\" data-id=\"f357856\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-201c904 elementor-widget elementor-widget-text-editor\" data-id=\"201c904\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<div class=\"boxBtn\">\n\t<a class=\"btn\" href=\"#hole\">\u7a74\u30bf\u30a4\u30d7\u306e\u81ea\u52d5\u8a8d\u8b58\u8a2d\u5b9a<\/a>\n\t<a class=\"btn\" href=\"#cadcolor\">\u8272\u5c5e\u6027\u9023\u643a<\/a>\n\t<a class=\"btn\" href=\"#section_5\">\u7a74\u5c5e\u6027\u9023\u643a<\/a>\n\t<a class=\"btn\" href=\"#SW_command\">SOLIDWORKS\u3000\u7a74\u30b3\u30de\u30f3\u30c9\u5bfe\u5fdc\u8868<\/a>\n<\/div>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-6457d61 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"6457d61\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-70adc6c\" data-id=\"70adc6c\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-4f6ee4b elementor-widget elementor-widget-text-editor\" data-id=\"4f6ee4b\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\tSOLIDWORKS\u3092\u304a\u4f7f\u3044\u306e\u5834\u5408\u306e\u3001\u7a74\u30bf\u30a4\u30d7\u81ea\u52d5\u8a8d\u8b58\u8a2d\u5b9a\u306e\u8a2d\u5b9a\u65b9\u6cd5\u306b\u3064\u3044\u3066\u3054\u6848\u5185\u3057\u307e\u3059\u3002\n\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-863bdbb elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"863bdbb\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-dabeace\" data-id=\"dabeace\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-e7f76c7 elementor-widget elementor-widget-menu-anchor\" data-id=\"e7f76c7\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"menu-anchor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t<div class=\"elementor-menu-anchor\" id=\"hole\"><\/div>\n\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-bf5ae76 elementor-widget elementor-widget-heading\" data-id=\"bf5ae76\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h2 class=\"elementor-heading-title elementor-size-default\">\u7a74\u30bf\u30a4\u30d7\u306e\u81ea\u52d5\u8a8d\u8b58\u8a2d\u5b9a<\/h2>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-a5dfa78 elementor-widget elementor-widget-text-editor\" data-id=\"a5dfa78\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t3D\u30e2\u30c7\u30eb\u306e\u7a74\u30bf\u30a4\u30d7\u3092meviy\u306e\u898b\u7a4d\u3082\u308a\u306b\u53cd\u6620\u3055\u305b\u308b\u305f\u3081\u306e3\u3064\u306e\u8a2d\u5b9a\u65b9\u6cd5\u3092\u3054\u7d39\u4ecb\u3057\u307e\u3059\u3002\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<section class=\"elementor-section elementor-inner-section elementor-element elementor-element-197dc40 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"197dc40\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-a40fe63\" data-id=\"a40fe63\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-6f8ffba elementor-widget elementor-widget-image\" data-id=\"6f8ffba\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img fetchpriority=\"high\" decoding=\"async\" width=\"770\" height=\"300\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2022\/08\/12373_01_A.png\" class=\"attachment-full size-full wp-image-25942\" alt=\"\" srcset=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2022\/08\/12373_01_A.png 770w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2022\/08\/12373_01_A-300x117.png 300w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2022\/08\/12373_01_A-768x299.png 768w\" sizes=\"(max-width: 770px) 100vw, 770px\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-c8f4080\" data-id=\"c8f4080\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-0bc8dd5 elementor-widget elementor-widget-text-editor\" data-id=\"0bc8dd5\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p>\u30e6\u30fc\u30b6\u30fc\u540d\u306b\u30ab\u30fc\u30bd\u30eb\u3092\u5408\u308f\u305b\u3066\u8868\u793a\u3055\u308c\u308b\uff3b\u30e6\u30fc\u30b6\u30fc\u30e1\u30cb\u30e5\u30fc\uff3d \u306e\uff3b\u30e6\u30fc\u30b6\u30fc\u8a2d\u5b9a\uff3d \u3092\u30af\u30ea\u30c3\u30af\u3057\u307e\u3059\u3002<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-inner-section elementor-element elementor-element-8df7929 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"8df7929\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-47121b8\" data-id=\"47121b8\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-4114c11 enlarged elementor-widget elementor-widget-image\" data-id=\"4114c11\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img decoding=\"async\" width=\"1600\" height=\"788\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/08\/6957_01.png\" class=\"attachment-full size-full wp-image-10575\" alt=\"\" srcset=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/08\/6957_01.png 1600w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/08\/6957_01-300x148.png 300w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/08\/6957_01-1024x504.png 1024w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/08\/6957_01-768x378.png 768w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/08\/6957_01-1536x756.png 1536w\" sizes=\"(max-width: 1600px) 100vw, 1600px\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-0ea61a1\" data-id=\"0ea61a1\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-707c267 elementor-widget elementor-widget-heading\" data-id=\"707c267\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h3 class=\"elementor-heading-title elementor-size-default\">\u8a2d\u5b9a\u65b9\u6cd5\uff11\uff1a\u81ea\u52d5\u8a8d\u8b58\u306a\u3057<\/h3>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-f488d91 elementor-widget elementor-widget-text-editor\" data-id=\"f488d91\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<ul><li>\u3053\u306e\u8a2d\u5b9a\u3067\u306f\u3001\u5186\u7b52\u5f62\u72b6\u306e\u7a74\u3092\u5168\u3066\u901a\u3057\u7a74(\u677f\u91d1)\u3001\u30b9\u30c8\u30ec\u30fc\u30c8\u7a74\u30fb\u516c\u5dee\u306a\u3057(\u5207\u524a\uff08\u89d2\u7269\uff09)\u3068\u3057\u3066\u8a8d\u8b58\u3057\u307e\u3059\u3002<\/li><li>\u30bf\u30c3\u30d7\u7a74\u3084\u7cbe\u5ea6\u7a74\u306e\u6307\u793a\u306f\u30013D CAD\u30c7\u30fc\u30bf\u306e\u30a2\u30c3\u30d7\u30ed\u30fc\u30c9\u5f8c\u306b[\u6b21\u3078\u9032\u3080]\u304b\u30893D\u30d3\u30e5\u30fc\u30ef\u30fc\u753b\u9762\u3092\u958b\u304d\u3001\u7a74\u3092\u30c0\u30d6\u30eb\u30af\u30ea\u30c3\u30af\u3057\u3066\u5909\u66f4\u3059\u308b\u3053\u3068\u304c\u53ef\u80fd\u3067\u3059\u3002<\/li><\/ul>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-5f4fedb elementor-widget elementor-widget-text-editor\" data-id=\"5f4fedb\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<div class=\"txtBasic bg\" style=\"margin-top: 20px;\">\n<p class=\"labelNote\">\u6ce8\u610f<\/p>\n\u30e2\u30c7\u30eb\u8a2d\u8a08\u6642\u306b3D CAD\u3067\u4ed8\u4e0e\u3055\u308c\u305f\u30aa\u30ea\u30b8\u30ca\u30eb\u306e\u7a74\u5c5e\u6027\u60c5\u5831\u306f\u5f15\u304d\u7d99\u304c\u308c\u307e\u305b\u3093\u3002\n\n<\/div>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-inner-section elementor-element elementor-element-654a039 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"654a039\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-8b140d6\" data-id=\"8b140d6\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-d5a3587 enlarged elementor-widget elementor-widget-image\" data-id=\"d5a3587\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img decoding=\"async\" width=\"1600\" height=\"856\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/08\/6957_02.png\" class=\"attachment-full size-full wp-image-10576\" alt=\"\" srcset=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/08\/6957_02.png 1600w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/08\/6957_02-300x161.png 300w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/08\/6957_02-1024x548.png 1024w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/08\/6957_02-768x411.png 768w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/08\/6957_02-1536x822.png 1536w\" sizes=\"(max-width: 1600px) 100vw, 1600px\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-6eab506\" data-id=\"6eab506\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-be6d560 elementor-widget elementor-widget-heading\" data-id=\"be6d560\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h3 class=\"elementor-heading-title elementor-size-default\">\u8a2d\u5b9a\u65b9\u6cd5\uff12\uff1a\u7a74\u5f84\u304b\u3089\u30bf\u30c3\u30d7\u7a74\u3092\u81ea\u52d5\u8a8d\u8b58 (\u30c7\u30d5\u30a9\u30eb\u30c8)<\/h3>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-a45964e elementor-widget elementor-widget-text-editor\" data-id=\"a45964e\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<ul><li>\u3053\u306e\u8a2d\u5b9a\u3067\u306f\u3001\u304a\u4f7f\u3044\u306e3D CAD\u30bd\u30d5\u30c8\u306b\u5fdc\u3058\u305f\u30e2\u30c7\u30eb\u306e\u7a74\u5f62\u72b6\u3068\u2019\u7a74\u5f84\u2019\u3092\u691c\u51fa\u3057\u3001\u30bf\u30c3\u30d7\u7a74\u3092\u81ea\u52d5\u3067\u8a8d\u8b58\u3057\u307e\u3059\u3002<\/li><li>\u00a0<\/li><li>\u30bf\u30c3\u30d7\u7a74\u8a8d\u8b58\u306e\u7a74\u5f84\u6761\u4ef6\u3068\u3057\u3066\u3001\u304a\u4f7f\u3044\u306e3D CAD\u30bd\u30d5\u30c8\u3092\u9078\u629e\u3057\u3066\u4e0b\u3055\u3044\u3002<\/li><li>\u203b\uff3b\u30d5\u30a1\u30a4\u30eb\u30bf\u30a4\u30d7\u306b\u5f93\u3046\uff3d\u3092\u9078\u629e\u3057\u305f\u5834\u5408\u306f\u3001\u62e1\u5f35\u5b50\u3092\u5143\u306b\u8a2d\u8a08\u6642\u306b\u4f7f\u7528\u3055\u308c\u305f3D CAD\u3092\u63a8\u5b9a\u3057\u3066\u3001\u7a74\u5f84\u306e\u7167\u5408\u3092\u884c\u3044\u307e\u3059\u3002<\/li><\/ul>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-05996e3 elementor-widget elementor-widget-text-editor\" data-id=\"05996e3\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<div class=\"txtBasic bg\" style=\"margin-top: 20px;\">\n<p class=\"labelMemo\">memo<\/p>\n\u8a73\u7d30\u306f\u4ee5\u4e0b\u3092\u53c2\u7167\u3057\u3066\u304f\u3060\u3055\u3044\u3002\n<ul>\n \t<li>\u2192\uff3b\u5207\u524a\uff08\u89d2\u7269\uff09\uff3d\u5404\u7a2e\u7a74\u306e\u8a8d\u8b58\u6761\u4ef6 &gt;\u300c<a href=\"\/help\/ja\/technical_info\/mpb_guideline\/3362\/\">\u5404\u7a2e\u7a74\u306e\u8a8d\u8b58\u6761\u4ef6<\/a>\u300d<\/li>\n \t<li>\u2192\uff3b\u677f\u91d1\uff3d\u5bfe\u5fdc\u7a74\u5f84\u8868 &gt;\u300c<a href=\"\/help\/ja\/technical_info\/shm_guideline\/3599\/\">\u30bf\u30c3\u30d7\u7a74\u8a8d\u8b58\u3068\u9078\u629e\u3067\u304d\u308b\u30b5\u30a4\u30ba<\/a>\u300d<\/li>\n<\/ul>\n<\/div>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-2c3f611 elementor-widget elementor-widget-text-editor\" data-id=\"2c3f611\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<div class=\"txtBasic bg\" style=\"margin-top: 20px;\">\n<p class=\"labelNote\">\u6ce8\u610f<\/p>\n\u30e2\u30c7\u30eb\u8a2d\u8a08\u6642\u306b3D CAD\u3067\u4ed8\u4e0e\u3055\u308c\u305f\u30aa\u30ea\u30b8\u30ca\u30eb\u306e\u7a74\u5c5e\u6027\u60c5\u5831\u306f\u5f15\u304d\u7d99\u304c\u308c\u307e\u305b\u3093\u3002\n\n<\/div>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-inner-section elementor-element elementor-element-332fa23 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"332fa23\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-53c4909\" data-id=\"53c4909\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-4bcb865 enlarged elementor-widget elementor-widget-image\" data-id=\"4bcb865\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img loading=\"lazy\" decoding=\"async\" width=\"1600\" height=\"860\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/08\/6957_03.png\" class=\"attachment-full size-full wp-image-10577\" alt=\"\" srcset=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/08\/6957_03.png 1600w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/08\/6957_03-300x161.png 300w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/08\/6957_03-1024x550.png 1024w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/08\/6957_03-768x413.png 768w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/08\/6957_03-1536x826.png 1536w\" sizes=\"(max-width: 1600px) 100vw, 1600px\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-16d6c41\" data-id=\"16d6c41\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-4cc5de2 elementor-widget elementor-widget-heading\" data-id=\"4cc5de2\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h3 class=\"elementor-heading-title elementor-size-default\">\u8a2d\u5b9a\u65b9\u6cd5\uff13\uff1a\u8272\u5c5e\u6027\u304b\u3089\u7a74\u30bf\u30a4\u30d7\u3092\u81ea\u52d5\u5224\u5b9a<\/h3>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-ad4969e elementor-widget elementor-widget-text-editor\" data-id=\"ad4969e\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<ul><li>\u3053\u306e\u8a2d\u5b9a\u3067\u306f\u3001\u304a\u4f7f\u3044\u306e3D CAD\u30bd\u30d5\u30c8\u3067\u7740\u8272\u3055\u308c\u305f\u30e2\u30c7\u30eb\u5185\u306e\u7a74\u5074\u9762\u3092\u691c\u51fa\u3057\u3001\u30bf\u30c3\u30d7\u7a74\u3084\u7cbe\u5ea6\u7a74\u7b49\u3092\u81ea\u52d5\u8a8d\u8b58\u3057\u307e\u3059\u3002<\/li><li>\u7a74\u30bf\u30a4\u30d7\u3054\u3068\u306e\u8272\u5c5e\u6027\u3092\u4e8b\u524d\u767b\u9332\u3057\u3066\u304a\u304d\u7a74\u5074\u9762\u306e\u7740\u8272\u3068\u7167\u5408\u3059\u308b\u3053\u3068\u3067\u3001\u4efb\u610f\u306e\u7a74\u30bf\u30a4\u30d7\u3092\u898b\u7a4d\u6761\u4ef6\u3078\u53cd\u6620\u3055\u305b\u307e\u3059\u3002<\/li><\/ul>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-fd518e3 elementor-widget elementor-widget-text-editor\" data-id=\"fd518e3\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<div class=\"txtBasic bg\" style=\"margin-top: 20px;\">\n<p class=\"labelNote\">\u6ce8\u610f<\/p>\n\u8272\u5c5e\u6027\u3092\u9023\u643a\u3067\u304d\u308b3D CAD\u30c7\u30fc\u30bf\u306b\u306f\u5236\u9650\u304c\u3042\u308a\u307e\u3059\u3002( \u53c2\u8003\uff1a<a href=\"\/help\/ja\/operation_manual\/first\/6957\/#section_4\">\u00a0\u8272\u5c5e\u6027\u9023\u643a\u5bfe\u8c61\u306e3D CAD\u60c5\u5831<\/a> )\n\n<\/div>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-2fe350f elementor-widget elementor-widget-text-editor\" data-id=\"2fe350f\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<ul><li>\u304a\u4f7f\u3044\u306e3D CAD\u30bd\u30d5\u30c8\u3092\u9078\u629e\u3057\u305f\u4e0a\u3067\u3001\u9078\u629e\u3057\u305f3D CAD\u304b\u3089\u51fa\u529b\u3055\u308c\u305f\u30cd\u30a4\u30c6\u30a3\u30d6\u5f62\u5f0f\u3001\u307e\u305f\u306f\u4e2d\u9593\u30d5\u30a1\u30a4\u30eb\uff08.x_t, .xmt_txt\u7b49\u306eParasolid\u306e\u307f\uff09\u3092\u30a2\u30c3\u30d7\u30ed\u30fc\u30c9\u3057\u3066\u3054\u4f7f\u7528\u304f\u3060\u3055\u3044\u3002<\/li><li>\u307e\u305f\u81ea\u52d5\u8a8d\u8b58\u3055\u305b\u305f\u3044\u7a74\u30bf\u30a4\u30d7\u306f\u3001\u540c\u30da\u30fc\u30b8\u4e0b\u90e8\u306b\u3042\u308b\u300c\u8272\u5c5e\u6027\u306e\u767b\u9332\u300d\u30d5\u30a9\u30fc\u30e0\u3067\u8272\u5c5e\u6027\u3092\u4e8b\u524d\u767b\u9332\u3057\u3066\u304b\u3089\u3054\u4f7f\u7528\u304f\u3060\u3055\u3044\u3002<\/li><\/ul>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-4c2869d elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"4c2869d\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-0d54559\" data-id=\"0d54559\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-e3d1a54 elementor-widget elementor-widget-menu-anchor\" data-id=\"e3d1a54\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"menu-anchor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t<div class=\"elementor-menu-anchor\" id=\"cadcolor\"><\/div>\n\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-3de71cf elementor-widget elementor-widget-heading\" data-id=\"3de71cf\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h2 class=\"elementor-heading-title elementor-size-default\">3D CAD\u30c7\u30fc\u30bf\u306e\u8272\u5c5e\u6027\u3092\u4f7f\u3063\u3066meviy\u306b\u7a74\u30bf\u30a4\u30d7\u3092\u81ea\u52d5\u8a8d\u8b58\u3055\u305b\u308b\u300c\u8272\u5c5e\u6027\u306e\u767b\u9332\u300d<\/h2>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-b950cd1 elementor-widget elementor-widget-text-editor\" data-id=\"b950cd1\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p>\u7a74\u30bf\u30a4\u30d7\u306e\u81ea\u52d5\u8a8d\u8b58\u8a2d\u5b9a\u3092\uff3b\u8272\u5c5e\u6027\u304b\u3089\u7a74\u30bf\u30a4\u30d7\u3092\u81ea\u52d5\u8a8d\u8b58\uff3d\u306b\u8a2d\u5b9a\u3059\u308b\u3068\u30013D CAD\u30c7\u30fc\u30bf\u306e\u8272\u5c5e\u6027\u3092meviy\u3078\u3068\u5f15\u304d\u7d99\u3050\u305f\u3081\u306eRGB\u8a2d\u5b9a\u304c\u53ef\u80fd\u306b\u306a\u308a\u307e\u3059\u3002<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<section class=\"elementor-section elementor-inner-section elementor-element elementor-element-638631c elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"638631c\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-ecb7826\" data-id=\"ecb7826\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-4e76b58 enlarged elementor-widget elementor-widget-image\" data-id=\"4e76b58\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img loading=\"lazy\" decoding=\"async\" width=\"1600\" height=\"860\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/08\/6957_04.png\" class=\"attachment-full size-full wp-image-10578\" alt=\"\" srcset=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/08\/6957_04.png 1600w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/08\/6957_04-300x161.png 300w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/08\/6957_04-1024x550.png 1024w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/08\/6957_04-768x413.png 768w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/08\/6957_04-1536x826.png 1536w\" sizes=\"(max-width: 1600px) 100vw, 1600px\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-388bc53\" data-id=\"388bc53\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-006720e elementor-widget elementor-widget-heading\" data-id=\"006720e\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h5 class=\"elementor-heading-title elementor-size-default\">STEP1\uff1a<\/h5>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-5863bec elementor-widget elementor-widget-text-editor\" data-id=\"5863bec\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\u30e6\u30fc\u30b6\u30fc\u8a2d\u5b9a\u306e\uff3b\u7a74\u30bf\u30a4\u30d7\u306e\u81ea\u52d5\u8a8d\u8b58\u8a2d\u5b9a\uff3d\u3092\u9078\u629e\u3057\u307e\u3059\u3002\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-87ece7b elementor-widget elementor-widget-heading\" data-id=\"87ece7b\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h5 class=\"elementor-heading-title elementor-size-default\">STEP2\uff1a<\/h5>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-895f9ea elementor-widget elementor-widget-text-editor\" data-id=\"895f9ea\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<div class=\"elementor-element elementor-element-5e6dfd1 elementor-widget elementor-widget-text-editor\" data-id=\"5e6dfd1\" data-element_type=\"widget\" data-widget_type=\"text-editor.default\"><div class=\"elementor-widget-container\"><ul><li class=\"elementor-text-editor elementor-clearfix\">\u7a74\u30bf\u30a4\u30d7\u8a8d\u8b58\u65b9\u6cd5\u3092[\u8272\u5c5e\u6027\u304b\u3089\u7a74\u30bf\u30a4\u30d7\u3092\u81ea\u52d5\u8a8d\u8b58]\u306b\u8a2d\u5b9a\u3057\u307e\u3059\u3002\u200b<\/li><li class=\"elementor-text-editor elementor-clearfix\">\u203b\uff3b\u8272\u5c5e\u6027\u304b\u3089\u7a74\u30bf\u30a4\u30d7\u3092\u81ea\u52d5\u8a8d\u8b58\uff3d\u3092\u9078\u629e\u3057\u3066\u3044\u308b\u3068\u304d\u306b\u9650\u308a\u3001\u8272\u5c5e\u6027\u306e\u767b\u9332\u30d5\u30a9\u30fc\u30e0\u3092\u3054\u5229\u7528\u3044\u305f\u3060\u3051\u307e\u3059\u3002<\/li><\/ul><\/div><\/div>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-inner-section elementor-element elementor-element-3adaea6 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"3adaea6\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-a1cb4e2\" data-id=\"a1cb4e2\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-8047cc3 elementor-widget elementor-widget-image\" data-id=\"8047cc3\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img loading=\"lazy\" decoding=\"async\" width=\"730\" height=\"103\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/08\/6957_05.png\" class=\"attachment-full size-full wp-image-10579\" alt=\"\" srcset=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/08\/6957_05.png 730w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/08\/6957_05-300x42.png 300w\" sizes=\"(max-width: 730px) 100vw, 730px\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-6e07509\" data-id=\"6e07509\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-bfe102a elementor-widget elementor-widget-heading\" data-id=\"bfe102a\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h5 class=\"elementor-heading-title elementor-size-default\">STEP3\uff1a<\/h5>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-309f89c elementor-widget elementor-widget-text-editor\" data-id=\"309f89c\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p>\u4f7f\u75283D CAD\u3092\u8a2d\u5b9a\u3057\u307e\u3059\u3002<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-inner-section elementor-element elementor-element-2da9934 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"2da9934\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-9fca0f0\" data-id=\"9fca0f0\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-630615a elementor-widget elementor-widget-image\" data-id=\"630615a\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img loading=\"lazy\" decoding=\"async\" width=\"730\" height=\"620\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/08\/6957_06.png\" class=\"attachment-full size-full wp-image-10580\" alt=\"\" srcset=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/08\/6957_06.png 730w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/08\/6957_06-300x255.png 300w\" sizes=\"(max-width: 730px) 100vw, 730px\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-012b5bf\" data-id=\"012b5bf\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-6f3da81 elementor-widget elementor-widget-heading\" data-id=\"6f3da81\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h5 class=\"elementor-heading-title elementor-size-default\">STEP4\uff1a<\/h5>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-84a265d elementor-widget elementor-widget-text-editor\" data-id=\"84a265d\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\u8a2d\u5b9a\u3057\u305f\u3044\u7a74\u7a2e\u306eON\/OFF\u30dc\u30bf\u30f3\u306b\u30c1\u30a7\u30c3\u30af\u3092\u5165\u308c\u3001RGB\u8a18\u5165\u6b04\u3092\u30a2\u30af\u30c6\u30a3\u30d6\u306b\u3057\u3066\u304f\u3060\u3055\u3044\u3002\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-a966ca8 elementor-widget elementor-widget-heading\" data-id=\"a966ca8\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h5 class=\"elementor-heading-title elementor-size-default\">STEP5\uff1a<\/h5>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-9a3d556 elementor-widget elementor-widget-text-editor\" data-id=\"9a3d556\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<ul><li>RGB\u306b\u6570\u5024\u3092\u5165\u308c\u307e\u3059\u3002<\/li><li>\u203bRGB\u306f0~255\u306e\u5024\u3067\u8a2d\u5b9a\u304f\u3060\u3055\u3044\u3002<\/li><\/ul>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-5538eac elementor-widget elementor-widget-heading\" data-id=\"5538eac\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h5 class=\"elementor-heading-title elementor-size-default\">STEP6\uff1a<\/h5>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-c615481 elementor-widget elementor-widget-text-editor\" data-id=\"c615481\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\uff3b\u8a2d\u5b9a\u3092\u4fdd\u5b58\u3059\u308b\uff3d\u3092\u62bc\u4e0b\u3057\u307e\u3059\u3002\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<div class=\"elementor-element elementor-element-d9b8609 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"d9b8609\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table style=\"width: 100%;\" class=\"tableHover_single\">\n<tbody>\n<tr style=\"height: 24px;\">\n<th style=\"width: 8%; height: 24px;\"><\/th>\n<th style=\"width: 20%; height: 24px;\">\u9805\u76ee\u540d<\/th>\n<th style=\"width: 60%; height: 24px;\">\u8a73\u7d30<\/th>\n<\/tr>\n<tr style=\"height: 24px;\">\n<th style=\"width: 8%; height: 24px;\">1<\/th>\n<td style=\"width: 20%; height: 24px; text-align: left;\">ON\/OFF<\/td>\n<td style=\"width: 60%; height: 24px; text-align: left;\">\u7a74\u7a2e\u6bce\u306b\u8a2d\u5b9a\u8981\u5426\u304c\u5207\u308a\u66ff\u3048\u3067\u304d\u307e\u3059\u3002<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<th style=\"width: 8%; height: 24px;\">2<\/th>\n<td style=\"width: 20%; height: 24px; text-align: left;\">\u7a74\u30bf\u30a4\u30d7<\/td>\n<td style=\"width: 60%; height: 24px; text-align: left;\">\u8272\u5c5e\u6027\u9023\u643a\u3067\u81ea\u52d5\u8a8d\u8b58\u3055\u305b\u308b\u3053\u3068\u304c\u3067\u304d\u308b\u7a74\u30bf\u30a4\u30d7\u306e\u4e00\u89a7\u3067\u3059\u3002<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<th style=\"width: 8%; height: 24px;\">3<\/th>\n<td style=\"width: 20%; height: 24px; text-align: left;\">RGB<\/td>\n<td style=\"width: 60%; height: 24px; text-align: left;\">\u8272\u5c5e\u6027\u306e\u767b\u9332\u6b04\u3067\u3059\u3002RGB\u305d\u308c\u305e\u308c\u306b\u3064\u3044\u30660~255\u306e\u5024\u3067\u8a2d\u5b9a\u3057\u307e\u3059\u3002<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<th style=\"width: 8%; height: 24px;\">4<\/th>\n<td style=\"width: 20%; height: 24px; text-align: left;\">\u8272\u78ba\u8a8d<\/td>\n<td style=\"width: 60%; height: 24px; text-align: left;\">RGB\u306e\u8a2d\u5b9a\u72b6\u6cc1\u306b\u5bfe\u3059\u308b\u30e1\u30c3\u30bb\u30fc\u30b8\u304c\u8868\u793a\u3055\u308c\u307e\u3059\u3002<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-978235e elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"978235e\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-71a8c0b\" data-id=\"71a8c0b\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-c52df19 elementor-widget elementor-widget-heading\" data-id=\"c52df19\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h2 class=\"elementor-heading-title elementor-size-default\">\u7a74\u306e\u81ea\u52d5\u8a8d\u8b58\u7d50\u679c\u30fb\u8272\u5c5e\u6027\u306e\u78ba\u8a8d\u65b9\u6cd5<\/h2>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-3fd0168 elementor-widget elementor-widget-text-editor\" data-id=\"3fd0168\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p>3D\u30d3\u30e5\u30fc\u30ef\u30fc\u753b\u9762\u3067\u7a74\u306e\u81ea\u52d5\u8a8d\u8b58\u7d50\u679c\u3068\u8272\u5c5e\u6027\u304c\u78ba\u8a8d\u53ef\u80fd\u3067\u3059<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<section class=\"elementor-section elementor-inner-section elementor-element elementor-element-6948d52 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"6948d52\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-bd6a2fd\" data-id=\"bd6a2fd\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-ad1eaef enlarged elementor-widget elementor-widget-image\" data-id=\"ad1eaef\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img loading=\"lazy\" decoding=\"async\" width=\"1600\" height=\"900\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/08\/6957_07.png\" class=\"attachment-full size-full wp-image-10581\" alt=\"\" srcset=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/08\/6957_07.png 1600w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/08\/6957_07-300x169.png 300w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/08\/6957_07-1024x576.png 1024w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/08\/6957_07-768x432.png 768w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/08\/6957_07-1536x864.png 1536w\" sizes=\"(max-width: 1600px) 100vw, 1600px\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-7d87e8d\" data-id=\"7d87e8d\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-c4d2922 elementor-widget elementor-widget-heading\" data-id=\"c4d2922\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h5 class=\"elementor-heading-title elementor-size-default\">STEP1\uff1a<\/h5>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-6bb1b3a elementor-widget elementor-widget-text-editor\" data-id=\"6bb1b3a\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p>3D\u30d3\u30e5\u30fc\u30ef\u30fc\u306e\uff3b\uff65\uff65\uff65\uff3d\u306b\u30ab\u30fc\u30bd\u30eb\u3092\u5f53\u3066\u307e\u3059\u3002<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-88eee04 elementor-widget elementor-widget-heading\" data-id=\"88eee04\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h5 class=\"elementor-heading-title elementor-size-default\">STEP2\uff1a<\/h5>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-e905e41 elementor-widget elementor-widget-text-editor\" data-id=\"e905e41\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\uff3b\u7a74\u306e\u81ea\u52d5\u8a8d\u8b58\u7d50\u679c\u30fb\u8272\u5c5e\u6027\u3092\u8868\u793a\uff3d\u3092\u30af\u30ea\u30c3\u30af\u3057\u307e\u3059\u3002\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-e9477d1 elementor-widget elementor-widget-heading\" data-id=\"e9477d1\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h5 class=\"elementor-heading-title elementor-size-default\">STEP3\uff1a<\/h5>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-7b56fef elementor-widget elementor-widget-text-editor\" data-id=\"7b56fef\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<ul><li>\u30c4\u30ea\u30fc\u30d3\u30e5\u30fc\u306e\u7a74\u30ea\u30b9\u30c8\u306b\u3001\u9023\u643a\u3055\u308c\u305f\u8272\u5c5e\u6027\u306e\u60c5\u5831\u304c\u8868\u793a\u3055\u308c\u307e\u3059\u3002<\/li><li>\u00a0<\/li><li>\u203b\u3053\u308c\u3089\u306e\u8272\u5c5e\u6027\u306f\u3001meviy\u304c\u72ec\u81ea\u3067\u89e3\u6790\u3057\u305f\u7d50\u679c\u3067\u3042\u308a\u3001\u304a\u4f7f\u3044\u306e3D CAD\u30bd\u30d5\u30c8\u3067\u8a2d\u5b9a\u3055\u308c\u305f\u8272\u5c5e\u6027\u306e\u5024\u3068\u4e00\u81f4\u3057\u306a\u3044\u53ef\u80fd\u6027\u304c\u3042\u308a\u307e\u3059\u3002<br \/>\u5f93\u3063\u3066\uff3b\u8272\u5c5e\u6027\u304b\u3089\u7a74\u30bf\u30a4\u30d7\u3092\u81ea\u52d5\u8a8d\u8b58\uff3d\u3092\u4f7f\u3044\u59cb\u3081\u308b\u3068\u304d\u3001\u304a\u4f7f\u3044\u306e3D CAD\u3001Version\u3001\u74b0\u5883\u8a2d\u5b9a\u304c\u5909\u308f\u3063\u305f\u3068\u304d\u306f\u3001\u5fc5\u305a\u5f53\u8a2d\u5b9a\u3067\u7a74\u306e\u81ea\u52d5\u8a8d\u8b58\u7d50\u679c\u3092\u78ba\u8a8d\u3057\u3066\u304f\u3060\u3055\u3044\u3002<\/li><li>\u307e\u305f\u5f8c\u8ff0\u306e\u5bfe\u5fdc3D CAD\u3001\u5bfe\u5fdc\u30d5\u30a9\u30fc\u30de\u30c3\u30c8\u306e\u307f\u3092\u5229\u7528\u3057\u3066\u304f\u3060\u3055\u3044\u3002<\/li><\/ul>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-6c67861 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"6c67861\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-a64327a\" data-id=\"a64327a\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-a37312d elementor-widget elementor-widget-heading\" data-id=\"a37312d\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h2 class=\"elementor-heading-title elementor-size-default\">\u8272\u5c5e\u6027\u9023\u643a\u5bfe\u8c61\u306e3D CAD\u60c5\u5831<\/h2>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-65e16ec elementor-widget elementor-widget-text-editor\" data-id=\"65e16ec\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p>\u8272\u5c5e\u6027\u3092\u9023\u643a\u3067\u304d\u308b3D CAD\u30c7\u30fc\u30bf\u306f\u4e0b\u8a18\u8868\u3092\u3054\u53c2\u7167\u304f\u3060\u3055\u3044<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-4d29ad1 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"4d29ad1\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"tableHover\" style=\"width: 100%;\">\n<tbody>\n<tr>\n<th colspan=\"5\" width=\"536\">3D CAD\u30d5\u30a9\u30fc\u30de\u30c3\u30c8<\/th>\n<\/tr>\n<tr>\n<th rowspan=\"2\">3D CAD\u540d<\/th>\n<th>\u30cd\u30a4\u30c6\u30a3\u30d6<\/th>\n<th colspan=\"3\">\u4e2d\u9593\u30d5\u30a9\u30fc\u30de\u30c3\u30c8(Parasolid)<\/th>\n<\/tr>\n<tr>\n<th>(.sldprt)(.icd)<\/th>\n<th>.x_t<\/th>\n<th>.x_b<\/th>\n<th>.xmt_txt<\/th>\n<\/tr>\n<tr>\n<th>SOLIDWORKS<\/th>\n<td>\u3007<\/td>\n<td>\u3007<\/td>\n<td>\u3007<\/td>\n<td>\uff70<\/td>\n<\/tr>\n<tr>\n<th>iCAD SX<\/th>\n<td>\u3007<\/td>\n<td>\u3007<\/td>\n<td>\u3007<\/td>\n<td>\u3007<\/td>\n<\/tr>\n<tr>\n<th>\u4ed6\u306e3D CAD<\/th>\n<td>\uff70<\/td>\n<td>\uff70<\/td>\n<td>\uff70<\/td>\n<td>\uff70<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-bd35e12 elementor-widget elementor-widget-text-editor\" data-id=\"bd35e12\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<div class=\"txtBasic bg\" style=\"margin-top: 20px;\">\n<p class=\"labelNote\">\u6ce8\u610f<\/p>\n\u5bfe\u8c61\u5916\u306e3D CAD\u3067\u751f\u6210\u3055\u308c\u305f\u30e2\u30c7\u30eb\u3084\u3001\u5bfe\u8c61\u5916\u306e3D CAD\u30d5\u30a9\u30fc\u30de\u30c3\u30c8\u306b\u95a2\u3057\u3066\u306f\u3001\u8272\u5c5e\u6027\u306b\u3088\u308b\u7a74\u30bf\u30a4\u30d7\u81ea\u52d5\u8a8d\u8b58\u306e\u52d5\u4f5c\u4fdd\u8a3c\u5bfe\u8c61\u5916\u3068\u306a\u308a\u307e\u3059\u3002\n\n<\/div>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-428f7b8 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"428f7b8\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-7188dc1\" data-id=\"7188dc1\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-d088ba4 elementor-widget elementor-widget-menu-anchor\" data-id=\"d088ba4\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"menu-anchor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t<div class=\"elementor-menu-anchor\" id=\"section_5\"><\/div>\n\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<section class=\"elementor-section elementor-inner-section elementor-element elementor-element-56e026c elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"56e026c\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-bde17b3\" data-id=\"bde17b3\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-14cf59f enlarged elementor-widget elementor-widget-image\" data-id=\"14cf59f\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img loading=\"lazy\" decoding=\"async\" width=\"1600\" height=\"860\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/08\/6957_08.png\" class=\"attachment-full size-full wp-image-12171\" alt=\"CAD\u306e\u7a74\u5c5e\u6027\u304b\u3089\u7a74\u30bf\u30a4\u30d7\u3092\u81ea\u52d5\u8a8d\u8b58\" srcset=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/08\/6957_08.png 1600w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/08\/6957_08-300x161.png 300w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/08\/6957_08-1024x550.png 1024w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/08\/6957_08-768x413.png 768w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/08\/6957_08-1536x826.png 1536w\" sizes=\"(max-width: 1600px) 100vw, 1600px\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-f9aaa8a\" data-id=\"f9aaa8a\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-6279891 elementor-widget elementor-widget-heading\" data-id=\"6279891\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h3 class=\"elementor-heading-title elementor-size-default\">\u8a2d\u5b9a\u65b9\u6cd5\uff14\uff1a3D CAD\u306e\u7a74\u5c5e\u6027\u304b\u3089\u7a74\u30bf\u30a4\u30d7\u3092\u81ea\u52d5\u8a8d\u8b58<\/h3>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-f4c5ded elementor-widget elementor-widget-text-editor\" data-id=\"f4c5ded\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<ul><li>\u3053\u306e\u8a2d\u5b9a\u3067\u306f3D CAD\u30bd\u30d5\u30c8\u306e\u7a74\u30b3\u30de\u30f3\u30c9\u3067\u4f5c\u6210\u3055\u308c\u305f\u7a74\u306e\u5c5e\u6027\u3092\u9023\u643a\u3057\u3001\u7a74\u30bf\u30a4\u30d7\u3092\u8a8d\u8b58\u3057\u307e\u3059\u3002<\/li><li>\u304a\u4f7f\u3044\u306e3D CAD\u30bd\u30d5\u30c8\u3092\u9078\u629e\u3057\u305f\u4e0a\u30673D CAD\u306e\u30cd\u30a4\u30c6\u30a3\u30d6\u5f62\u5f0f\u3092\u30a2\u30c3\u30d7\u30ed\u30fc\u30c9\u3057\u3066\u304f\u3060\u3055\u3044\u3002<\/li><\/ul>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-619873e elementor-widget elementor-widget-text-editor\" data-id=\"619873e\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<div class=\"txtBasic bg\" style=\"margin-top: 20px;\">\n<p class=\"labelNote\">\u6ce8\u610f<\/p>\n\n<ul>\n \t<li>\u7a74\u5c5e\u6027\u3092\u9023\u643a\u3067\u304d\u308b3D CAD\u30c7\u30fc\u30bf\u306b\u306f\u5236\u9650\u304c\u3042\u308a\u307e\u3059\u3002<\/li>\n \t<li><a href=\"\/help\/ja\/operation_manual\/first\/6957\/#section_7\">\u7a74\u5c5e\u6027\u9023\u643a\u5bfe\u8c613D CAD\u306e\u8a73\u7d30\u306f\u3053\u3061\u3089<\/a><\/li>\n<\/ul>\n<\/div>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-633fcea elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"633fcea\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-9fd4554\" data-id=\"9fd4554\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-613f853 elementor-widget elementor-widget-menu-anchor\" data-id=\"613f853\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"menu-anchor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t<div class=\"elementor-menu-anchor\" id=\"section_6\"><\/div>\n\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-d91d5c4 elementor-widget elementor-widget-heading\" data-id=\"d91d5c4\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h2 class=\"elementor-heading-title elementor-size-default\">\u7a74\u5c5e\u6027\u9023\u643a\u306e\u9069\u7528\u30eb\u30fc\u30eb<\/h2>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-5794e9d elementor-widget elementor-widget-text-editor\" data-id=\"5794e9d\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p>3D CAD\u306e\u7a74\u5c5e\u6027\u3092\u9023\u643a\u3057\u7a74\u30bf\u30a4\u30d7\u3092\u8a8d\u8b58\u3055\u305b\u308b\u306b\u306f\u4ee5\u4e0b\u306e\u9069\u7528\u30eb\u30fc\u30eb\u3092\u3054\u78ba\u8a8d\u304f\u3060\u3055\u3044\u3002<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<section class=\"elementor-section elementor-inner-section elementor-element elementor-element-acb0404 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"acb0404\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-a1998ab\" data-id=\"a1998ab\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-38ef826 elementor-widget elementor-widget-heading\" data-id=\"38ef826\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h3 class=\"elementor-heading-title elementor-size-default\">\u5bfe\u8c613D CAD\u30bd\u30d5\u30c8\u3068\u30d5\u30a1\u30a4\u30eb\u5f62\u5f0f\u306b\u3064\u3044\u3066<\/h3>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-af54fe6 elementor-widget elementor-widget-text-editor\" data-id=\"af54fe6\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\u2460 <a href=\"\/help\/ja\/operation_manual\/first\/6957\/#section_7\">\u9023\u643a\u5bfe\u8c61\u306e3D CAD\u30bd\u30d5\u30c8<\/a>\u3067\u4f5c\u6210\u3057\u3001\u30cd\u30a4\u30c6\u30a3\u30d6\u5f62\u5f0f\u3067\u30a2\u30c3\u30d7\u30ed\u30fc\u30c9\u3057\u3066\u304f\u3060\u3055\u3044\u3002\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-a98ee07 elementor-widget elementor-widget-heading\" data-id=\"a98ee07\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h3 class=\"elementor-heading-title elementor-size-default\">3D CAD\u306e\u7a74\u306e\u4f5c\u6210\u65b9\u6cd5\u306b\u3064\u3044\u3066<\/h3>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-87e7790 elementor-widget elementor-widget-text-editor\" data-id=\"87e7790\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<ul>\n \t<li>\u2461 3D CAD\u306e\u7a74\u30b3\u30de\u30f3\u30c9\u3067\u4f5c\u6210\u3055\u308c\u305f\u7a74\u304c\u9023\u643a\u5bfe\u8c61\u3067\u3059\u3002\uff08\u9023\u643a\u5bfe\u8c61\u306e\u7a74\u30fb\u5c5e\u6027\u306f\u4ee5\u4e0b\u306e<a href=\"#SW_command\">3D CAD\u5225\u7a74\u30b3\u30de\u30f3\u30c9\u5bfe\u5fdc\u8868<\/a>\u3092\u3054\u78ba\u8a8d\u304f\u3060\u3055\u3044\u3002\uff09<\/li>\n \t<li>\u7a74\u30b3\u30de\u30f3\u30c9\u3092\u4f7f\u3063\u3066\u3044\u306a\u3044\u5834\u5408\u306f\u7a74\u5c5e\u6027\u9023\u643a\u306e\u5bfe\u8c61\u5916\u3067\u3059\u3002<\/li>\n \t<li>\u2462 \u7a74\u30b3\u30de\u30f3\u30c9\u306e\u30ab\u30b9\u30bf\u30de\u30a4\u30ba\u306b\u3064\u3044\u3066\u306f\u52d5\u4f5c\u672a\u78ba\u8a8d\u306e\u305f\u3081\u6b63\u3057\u304f\u9023\u643a\u3055\u308c\u308b\u3053\u3068\u3092\u4fdd\u8a3c\u3067\u304d\u307e\u305b\u3093\u3002\n\uff08\u30ab\u30b9\u30bf\u30de\u30a4\u30ba\u3068\u306f\u3001\u65e2\u5b58\u306e\u898f\u683c\u3084\u5bf8\u6cd5\u3092\u5909\u66f4\u3057\u305f\u308a\u3001\u65b0\u898f\u306e\u898f\u683c\u3092\u4f5c\u6210\u3057\u305f\u308a\u3059\u308b\u3053\u3068\u3092\u610f\u5473\u3057\u307e\u3059\u3002 \uff09<\/li>\n \t<li>\u2783\u8907\u88fd\u306f\u8d64\u67a0\u3067\u56f2\u3063\u305f\u3082\u306e\u306e\u307f\u9023\u643a\u5bfe\u8c61\u3068\u306a\u308a\u307e\u3059\u3002\u305f\u3060\u3057<span class=\"ui-provider a b c d e f g h i j k l m n o p q r s t u v w x y z ab ac ae af ag ah ai aj ak\" dir=\"ltr\">SOLIDWORKS<\/span>\u306e\u307f\u3001\u7a74\u3092\u8907\u88fd\u5f8c\u3055\u3089\u306b\u8907\u88fd\u3057\u305f\u7a74\u306f\u7a74\u30b3\u30de\u30f3\u30c9\u3067\u4f5c\u6210\u3055\u308c\u305f\u7a74\u3068\u3057\u3066\u8a8d\u8b58\u3055\u308c\u305a\u3001\u7a74\u5c5e\u6027\u9023\u643a\u306e\u5bfe\u8c61\u5916\u306b\u306a\u308a\u307e\u3059\u3002<\/li>\n \t<li>\u2464 <span class=\"txtNote\">\u30bf\u30c3\u30d7\u7a74\u3068\u7cbe\u5ea6\u7a74\u306e\u6709\u52b9\u6df1\u3055\u306f\u9023\u643a\u3055\u308c\u305a\u3001\u30e6\u30fc\u30b6\u30fc\u8a2d\u5b9a\u306e\u30c0\u30a4\u30a2\u30ed\u30b0\u8a2d\u5b9a\u60c5\u5831\u304c\u9069\u7528\u3055\u308c\u307e\u3059\u3002<\/span><\/li>\n \t<li>\u2465 mm\u898f\u683c\u306e\u306d\u3058\u7a74\u306b\u5bfe\u5fdc\u3057\u3066\u3044\u307e\u3059\u3002inch\u306d\u3058\u306f\u672a\u5bfe\u5fdc\u3067\u3059\u3002<\/li>\n<\/ul>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-0242885\" data-id=\"0242885\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-fb8622f tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"fb8622f\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<div class=\"print_block\">\n<div class=\"tableStickyHead\">\n<table class=\"tableHover_single\">\n<thead>\n<tr>\n<th><\/th>\n<th style=\"width: 45%;\">SOLIDWORKS<\/th>\n<th style=\"width: 45%;\">iCAD SX<\/th>\n<\/tr>\n<\/thead>\n<\/table>\n<\/div>\n<table class=\"tableHover_single mT0\">\n<tbody>\n<tr>\n<th>\u2461<\/th>\n<td style=\"width: 45%; vertical-align: top;\"><img decoding=\"async\" src=\"\/help\/ja\/wp-content\/uploads\/2022\/08\/6957_rule_01_B.png\" alt=\"\" \/><\/td>\n<td style=\"width: 45%;\">\n<ul>\n \t<li><img decoding=\"async\" style=\"border: 1px solid #ddd;\" src=\"\/help\/ja\/wp-content\/uploads\/2022\/08\/6957_rule_04.png\" alt=\"\" \/><\/li>\n \t<li><img decoding=\"async\" src=\"\/help\/ja\/wp-content\/uploads\/2022\/08\/6957_rule_05.png\" alt=\"\" \/><\/li>\n<\/ul>\n<\/td>\n<\/tr>\n<tr>\n<th style=\"padding-top: 10px;\">\u2463<\/th>\n<td style=\"padding-top: 10px; vertical-align: top;\"><img decoding=\"async\" src=\"\/help\/ja\/wp-content\/uploads\/2022\/08\/6957_rule_02_B.png\" alt=\"\" \/><\/td>\n<td style=\"vertical-align: top;\"><img decoding=\"async\" src=\"\/help\/ja\/wp-content\/uploads\/2022\/08\/6957_rule_06.png\" alt=\"\" \/>\n<ul style=\"text-align: left;\">\n \t<li>I \u4e00\u90e8\u5f62\u72b6\u3092\u30b3\u30d4\u30fc\u3059\u308b<\/li>\n \t<li>II \u4e00\u90e8\u5f62\u72b6\u3092\u9023\u7d9a\u30b3\u30d4\u30fc\u3059\u308b<\/li>\n \t<li>III \u4e00\u90e8\u5f62\u72b6\u3092\u56de\u8ee2\u30b3\u30d4\u30fc\u3059\u308b<\/li>\n \t<li>IV \u4e00\u90e8\u5f62\u72b6\u3092\u30df\u30e9\u30fc\u3059\u308b<\/li>\n \t<li>V \u4e00\u90e8\u5f62\u72b6\u3092\u30df\u30e9\u30fc\u30b3\u30d4\u30fc\u3059\u308b<\/li>\n<\/ul>\n<\/td>\n<\/tr>\n<tr>\n<th style=\"padding-top: 10px;\">\u2464<\/th>\n<td style=\"padding-top: 10px;\" colspan=\"2\"><span class=\"enlarged\"><img decoding=\"async\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/11\/6957_rule_03_C.png\" alt=\"\" \/><\/span><\/td>\n<\/tr>\n<\/tbody>\n<\/table>\n<\/div>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-fbc1af0 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"fbc1af0\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-e97e82b\" data-id=\"e97e82b\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-116e4e5 elementor-widget elementor-widget-menu-anchor\" data-id=\"116e4e5\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"menu-anchor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t<div class=\"elementor-menu-anchor\" id=\"SW_command\"><\/div>\n\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-1de9efd print_page elementor-widget elementor-widget-heading\" data-id=\"1de9efd\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h2 class=\"elementor-heading-title elementor-size-default\">SOLIDWORKS\u7a74\u30b3\u30de\u30f3\u30c9\u5bfe\u5fdc\u8868\n<\/h2>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-2c5cf64 elementor-widget elementor-widget-text-editor\" data-id=\"2c5cf64\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<ul><li>\u9023\u643a\u5bfe\u8c61\u306e\u7a74\u30bf\u30a4\u30d7\u3068\u3001SOLIDWORKS\u306b\u304a\u3051\u308b\u7a74\u30b3\u30de\u30f3\u30c9\u8a2d\u5b9a\u6761\u4ef6\u306f\u4ee5\u4e0b\u3092\u3054\u78ba\u8a8d\u304f\u3060\u3055\u3044\u3002<\/li><li>\u8a18\u8f09\u306e\u65b9\u6cd5\u4ee5\u5916\u3067\u4f5c\u6210\u3055\u308c\u305f\u7a74\u306f\u9023\u643a\u5bfe\u8c61\u5916\u306e\u305f\u3081\u30b9\u30c8\u30ec\u30fc\u30c8\u7a74\u30fb\u901a\u3057\u7a74\u306b\u306a\u308a\u307e\u3059\u3002\u30d3\u30e5\u30fc\u30ef\u30fc\u753b\u9762\u3067\u7a74\u30bf\u30a4\u30d7\u3092\u5909\u66f4\u3057\u3066\u304f\u3060\u3055\u3044\u3002<\/li><\/ul>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-0b34047 elementor-widget elementor-widget-heading\" data-id=\"0b34047\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h3 class=\"elementor-heading-title elementor-size-default\">SOLIDWORKS\n<\/h3>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-bb31953 tblBasic print_break elementor-widget elementor-widget-text-editor\" data-id=\"bb31953\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<div class=\"tableStickyHead\">\n<table class=\"tableHover print_small\">\n<thead>\n<tr>\n<th style=\"width: 25%;\">\u7a74\u30bf\u30a4\u30d7\uff08meviy\uff09<\/th>\n<th style=\"width: 25%;\">\u7a74\u30b3\u30de\u30f3\u30c9\u8a2d\u5b9a\u6761\u4ef6<\/th>\n<th style=\"width: 25%;\">\u8aac\u660e<\/th>\n<th style=\"width: 25%;\">\u88dc\u8db3<\/th>\n<\/tr>\n<\/thead>\n<\/table>\n<\/div>\n<table class=\"tableHover mT0 print_small\">\n<tbody>\n<tr>\n<th style=\"width: 25%;\">\u30b9\u30c8\u30ec\u30fc\u30c8\u7a74\u30fb\u901a\u3057\u7a74<\/th>\n<td style=\"width: 25%;\"><img decoding=\"async\" style=\"width: 200px;\" title=\"\u30b9\u30c8\u30ec\u30fc\u30c8\u7a74\u30fb\u901a\u3057\u7a74\" src=\"\/help\/ja\/wp-content\/uploads\/2022\/06\/6957_cmd_01.png\" alt=\"\u30b9\u30c8\u30ec\u30fc\u30c8\u7a74\u30fb\u901a\u3057\u7a74\" \/><\/td>\n<td style=\"width: 25%; vertical-align: top;\">\n<ul>\n \t<li style=\"text-align: left;\">\u2460 \u300c\u7a74\u300d\u3092\u9078\u629e<\/li>\n \t<li style=\"text-align: left;\">\u2461 \u7a2e\u985e\u306f\u4e0b\u8a18\u3044\u305a\u308c\u304b<\/li>\n \t<li style=\"text-align: left;\">\u30fb\u30c9\u30ea\u30eb\u30b5\u30a4\u30ba<\/li>\n \t<li style=\"text-align: left;\">\u30fb\u306d\u3058\u3059\u304d\u307e<\/li>\n \t<li style=\"text-align: left;\">\u30fb\u306d\u3058\u4e0b\u7a74\u30c9\u30ea\u30eb<\/li>\n<\/ul>\n<\/td>\n<td style=\"width: 25%; text-align: left; vertical-align: top;\">\u7a2e\u985e\uff1a\u30c0\u30a6\u30a8\u30eb\u7a74\u3092\u9078\u629e\u3059\u308b\u3068\u300c\u7cbe\u5ea6\u7a74\u300d\u3068\u3057\u3066\u9023\u643a\u3055\u308c\u308b\u305f\u3081\u3001\u30b9\u30c8\u30ec\u30fc\u30c8\u7a74\u30fb\u901a\u3057\u7a74\u3068\u3057\u3066\u8a8d\u8b58\u3057\u305f\u3044\u5834\u5408\u306f\u9078\u629e\u3057\u306a\u3044\u3067\u304f\u3060\u3055\u3044\u3002<\/td>\n<\/tr>\n<tr>\n<th>\u30b9\u30c8\u30ec\u30fc\u30c8\u7a74\n\uff08\u30b6\u30b0\u30ea\u7a74\uff09\n\u203b\u5207\u524a\u306e\u307f\u5bfe\u5fdc<\/th>\n<td><img decoding=\"async\" style=\"width: 200px;\" src=\"\/help\/ja\/wp-content\/uploads\/2022\/06\/6957_cmd_02.png\" alt=\"\" \/><\/td>\n<td style=\"vertical-align: top; text-align: left;\">\u300c\u5ea7\u3050\u308a\u7a74\u300d\u3092\u9078\u629e<\/td>\n<td style=\"text-align: left; vertical-align: top;\">\n<ul>\n \t<li>\u5ea7\u3050\u308a\u7a74\u306f\u6bb5\u4ed8\u304d\u30b9\u30c8\u30ec\u30fc\u30c8\u7a74\u3068\u3057\u3066\u8a8d\u8b58\u3057\u307e\u3059\u3002<\/li>\n \t<li class=\"txtNote\">\u5ea7\u3050\u308a\u7a74\u306e\u5e95\u9762\u5f62\u72b6\u306f\u5e73\u9762\u3067\u306a\u304f\u5186\u9310\u5f62\u72b6\u306b\u306a\u308b\u3053\u3068\u304c\u3042\u308a\u307e\u3059\u3002<\/li>\n \t<li><a href=\"\/help\/ja\/technical_info\/mpb_guideline\/3327\/\">3D CAD\u30c7\u30fc\u30bf\u3068\u4ed5\u4e0a\u308a\u306b\u5dee\u7570\u304c\u751f\u3058\u308b\u5f62\u72b6\u30eb\u30fc\u30eb\u306f\u3053\u3061\u3089<\/a><\/li>\n<\/ul>\n<\/td>\n<\/tr>\n<tr>\n<th>\u7cbe\u5ea6\u7a74\n\n\u203b\u5207\u524a\u306e\u307f\u5bfe\u5fdc<\/th>\n<td><img decoding=\"async\" style=\"width: 200px;\" src=\"\/help\/ja\/wp-content\/uploads\/2022\/06\/6957_cmd_03.png\" alt=\"\" \/>\n<img decoding=\"async\" style=\"width: 200px;\" src=\"\/help\/ja\/wp-content\/uploads\/2022\/06\/6957_cmd_04.png\" alt=\"\" \/><\/td>\n<td style=\"text-align: left; vertical-align: top;\">\n<ul>\n \t<li>\u2460\u300c\u7a74\u300d\u3092\u9078\u629e<\/li>\n \t<li>\u2461\u300c\u30c0\u30a6\u30a8\u30eb\u7a74\u300d\u3092\u9078\u629e<\/li>\n \t<li>\u2462\u300c\u306f\u3081\u3042\u3044\u516c\u5dee\u300d\u3092\u9078\u629e<\/li>\n \t<li>\u2463\u300c\u516c\u5dee\u57df\u30af\u30e9\u30b9\u300d\u3092\u6307\u5b9a<\/li>\n<\/ul>\n<\/td>\n<td style=\"text-align: left; vertical-align: top;\">\n<ul>\n \t<li class=\"txtNote\" style=\"text-align: left;\">\u30fb\u6709\u52b9\u6df1\u3055\u306f\u30e6\u30fc\u30b6\u30fc\u8a2d\u5b9a\u306e\u30c0\u30a4\u30a2\u30ed\u30b0\u8a2d\u5b9a\u60c5\u5831\u304c\u9069\u7528\u3055\u308c\u307e\u3059\u3002<\/li>\n \t<li style=\"text-align: left;\">\u30fb\u7a74\u5f84\u306f3D CAD\u30d5\u30a1\u30a4\u30eb\u306e\u5f84\u3001\u516c\u5dee\u57df\u30af\u30e9\u30b9\u306f\u7a74\u30b3\u30de\u30f3\u30c9\u306e\u8a2d\u5b9a\u5024\u3092\u53c2\u7167\u3057\u307e\u3059\u3002\u306f\u3081\u3042\u3044\u516c\u5dee\u3092\u8a2d\u5b9a\u3057\u3066\u3044\u306a\u3044\u5834\u5408\u306f\u30e6\u30fc\u30b6\u30fc\u8a2d\u5b9a\u306e\u5e38\u7528\u3059\u308b\u516c\u5dee\u57df\u30af\u30e9\u30b9\u3092\u53c2\u7167\u3057\u307e\u3059\u3002<\/li>\n \t<li style=\"text-align: left;\"><span class=\"txtNote\">\u30fb\u4e21\u5074\u516c\u5dee(\u4f8b\uff1a\u00b10.02)\u304a\u3088\u3073\u7247\u5074\u516c\u5dee(\u4f8b\uff1a+0.02\/0)\u306f\u9023\u643a\u3067\u304d\u306a\u3044\u305f\u3081\u3001\u5fc5\u305a3D\u30d3\u30e5\u30fc\u30ef\u30fc\u3067\u78ba\u8a8d\u30fb\u8a2d\u5b9a\u3092\u884c\u3063\u3066\u304f\u3060\u3055\u3044\u3002<\/span>\u521d\u671f\u8868\u793a\u306f\u30e6\u30fc\u30b6\u30fc\u8a2d\u5b9a\u306e\u5e38\u7528\u3059\u308b\u516c\u5dee\u57df\u30af\u30e9\u30b9\u3092\u53c2\u7167\u3057\u307e\u3059\u3002<\/li>\n<\/ul>\n<\/td>\n<\/tr>\n<tr>\n<th>\u30bf\u30c3\u30d7\u7a74\u30fb\u30d0\u30fc\u30ea\u30f3\u30b0\u30bf\u30c3\u30d7<\/th>\n<td><img decoding=\"async\" style=\"width: 200px;\" src=\"\/help\/ja\/wp-content\/uploads\/2022\/07\/6957_cmd_05_B.png\" alt=\"\" \/><\/td>\n<td style=\"vertical-align: top; text-align: left;\">\n<ul>\n \t<li style=\"text-align: left;\">\u2460\u300c\u306d\u3058\u7a74-\u30b9\u30c8\u30ec\u30fc\u30c8\u300d\u3092\u9078\u629e<\/li>\n \t<li style=\"text-align: left;\">\u2461\u300c\u306d\u3058\u7a74\u300d\u3092\u9078\u629e<\/li>\n \t<li style=\"text-align: left;\">\u2462\u30b5\u30a4\u30ba\uff08M\uff09\u3092\u9078\u629e<\/li>\n<\/ul>\n<\/td>\n<td style=\"text-align: left; vertical-align: top;\">\n<ul>\n \t<li style=\"text-align: left;\"><span style=\"color: var( --e-global-color-text ); font-family: var( --e-global-typography-text-font-family ), Sans-serif; font-weight: var( --e-global-typography-text-font-weight ); font-size: 1.4rem;\">\u30fb\u30d4\u30c3\u30c1\u30b5\u30a4\u30ba\u304c\u53d6\u5f97\u3067\u304d\u306a\u3044\u5834\u5408\u306f\u4e26\u76ee\u3068\u3057\u3066\u8a8d\u8b58\u3057\u307e\u3059\u3002<\/span><\/li>\n \t<li class=\"txtNote\" style=\"text-align: left;\">\u30fb\u6709\u52b9\u6df1\u3055\u306f\u30e6\u30fc\u30b6\u30fc\u8a2d\u5b9a\u306e\u30c0\u30a4\u30a2\u30ed\u30b0\u8a2d\u5b9a\u60c5\u5831\u304c\u9069\u7528\u3055\u308c\u307e\u3059\u3002<\/li>\n \t<li style=\"text-align: left;\">\u30fb\u5f62\u72b6\u304a\u3088\u3073\u30b5\u30a4\u30ba\u306fmeviy\u306e\u30d0\u30fc\u30ea\u30f3\u30b0\u30bf\u30c3\u30d7\u30eb\u30fc\u30eb\u306b\u6e96\u3058\u307e\u3059\u3002<\/li>\n \t<li style=\"text-align: left;\"><a href=\"\/help\/ja\/technical_info\/shm_guideline\/3595\/\">\u677f\u91d1\u306e\u30d0\u30fc\u30ea\u30f3\u30b0\u30bf\u30c3\u30d7\u30eb\u30fc\u30eb\u306f\u3053\u3061\u3089<\/a><\/li>\n<\/ul>\n<\/td>\n<\/tr>\n<tr>\n<th>\u76bf\u7a74<\/th>\n<td><img decoding=\"async\" style=\"width: 200px;\" src=\"\/help\/ja\/wp-content\/uploads\/2022\/06\/6957_cmd_06.png\" alt=\"\" \/><\/td>\n<td style=\"text-align: left; vertical-align: top;\">\n<ul>\n \t<li style=\"text-align: left;\">\u300c\u76bf\u7a74\u300d\u3092\u9078\u629e<\/li>\n<\/ul>\n<\/td>\n<td style=\"text-align: left; vertical-align: top;\">\n<p style=\"text-align: left;\">\u5f62\u72b6\u304a\u3088\u3073\u30b5\u30a4\u30ba\u306fmeviy\u306e\u76bf\u7a74\u30eb\u30fc\u30eb\u306b\u6e96\u3058\u307e\u3059\u3002<\/p>\n<p style=\"text-align: left;\"><a href=\"\/help\/ja\/technical_info\/mpb_guideline\/3362\/#box_4\">\u5207\u524a\uff08\u89d2\u7269\uff09\u306e\u76bf\u7a74\u30eb\u30fc\u30eb\u306f\u3053\u3061\u3089<\/a><\/p>\n<p style=\"text-align: left;\"><a href=\"\/help\/ja\/technical_info\/shm_guideline\/3586\">\u677f\u91d1\u306e\u76bf\u7a74\u30eb\u30fc\u30eb\u306f\u3053\u3061\u3089<\/a><\/p>\n<\/td>\n<\/tr>\n<tr>\n<th>\u9023\u643a\u5bfe\u8c61\u5916\u2460<\/th>\n<td><img decoding=\"async\" style=\"width: 200px;\" src=\"\/help\/ja\/wp-content\/uploads\/2022\/06\/6957_cmd_07.png\" alt=\"\" \/><\/td>\n<td style=\"text-align: left; vertical-align: top;\">\n<ul>\n \t<li style=\"text-align: left;\">\u4ee5\u4e0b\u306e\u7a74\u30b3\u30de\u30f3\u30c9\u3092\u4f7f\u7528\u3057\u305f\u7a74\u306f\u9023\u643a\u306e\u5bfe\u8c61\u5916\u3067\u3059\u3002<\/li>\n \t<li style=\"text-align: left;\">\u2460\u306d\u3058\u7a74-\u30c6\u30fc\u30d1<\/li>\n \t<li style=\"text-align: left;\">\u2461\u5f93\u6765\u578b\u306e\u7a74<\/li>\n \t<li style=\"text-align: left;\">\u2462\u5ea7\u3050\u308a\u7a74\u30b9\u30ed\u30c3\u30c8<\/li>\n \t<li style=\"text-align: left;\">\u2463\u76bf\u7a74\u30b9\u30ed\u30c3\u30c8<\/li>\n \t<li style=\"text-align: left;\">\u2464\u30b9\u30ed\u30c3\u30c8<\/li>\n<\/ul>\n<\/td>\n<td style=\"text-align: left; vertical-align: top;\"><\/td>\n<\/tr>\n<tr>\n<th>\u9023\u643a\u5bfe\u8c61\u5916\u2461<\/th>\n<td><img decoding=\"async\" style=\"width: 200px;\" src=\"\/help\/ja\/wp-content\/uploads\/2022\/06\/6957_cmd_08.png\" alt=\"\" \/><\/td>\n<td style=\"text-align: left; vertical-align: top;\">\n<ul>\n \t<li style=\"text-align: left;\">\u4ee5\u4e0b\u306e\u7a74\u30b3\u30de\u30f3\u30c9\u3092\u4f7f\u7528\u3057\u305f\u7a74\u306f\u9023\u643a\u306e\u5bfe\u8c61\u5916\u3067\u3059\u3002<\/li>\n \t<li style=\"text-align: left;\">\u2465\u8a73\u7d30\u7a74<\/li>\n \t<li style=\"text-align: left;\">\u2466\u306d\u3058\u5c71<\/li>\n \t<li style=\"text-align: left;\">\u2467\u30b9\u30bf\u30c3\u30c9 \u30a6\u30a3\u30b6\u30fc\u30c9<\/li>\n \t<li style=\"text-align: left;\">\u62bc\u3057\u51fa\u3057\u30ab\u30c3\u30c8\u3084\u56de\u8ee2\u30ab\u30c3\u30c8\u7b49\u7a74\u30b3\u30de\u30f3\u30c9\u4ee5\u5916\u3092\u4f7f\u7528\u3057\u305f\u7a74\u306f\u9023\u643a\u306e\u5bfe\u8c61\u5916\u3067\u3059\u3002<\/li>\n<\/ul>\n<\/td>\n<td style=\"text-align: left; vertical-align: top;\">\n<p style=\"text-align: left; vertical-align: top;\">\u3053\u308c\u3089\u306e\u7a74\u3067\u4f5c\u3089\u308c\u3066\u3044\u308b\u5834\u5408\u306f\u300c\u7a74\u30b3\u30de\u30f3\u30c9\u672a\u4f7f\u7528\u300d\u3068\u8868\u793a\u3055\u308c\u307e\u3059\u3002<\/p>\n<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-1078d38 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"1078d38\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-8bf3455\" data-id=\"8bf3455\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-1f527b6 elementor-widget elementor-widget-heading\" data-id=\"1f527b6\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h2 class=\"elementor-heading-title elementor-size-default\">\u7a74\u306e\u81ea\u52d5\u8a8d\u8b58\u7d50\u679c\u30fb\u7a74\u5c5e\u6027\u306e\u78ba\u8a8d\u65b9\u6cd5<\/h2>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-556d62d elementor-widget elementor-widget-text-editor\" data-id=\"556d62d\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<ul><li><p>3D\u30d3\u30e5\u30fc\u30ef\u30fc\u753b\u9762\u3067\u306f\u7a74\u306e\u81ea\u52d5\u8a8d\u8b58\u7d50\u679c\u30683D CAD\u306e\u7a74\u5c5e\u6027\u60c5\u5831\u3092\u78ba\u8a8d\u3067\u304d\u307e\u3059\u3002<\/p><\/li><\/ul>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<section class=\"elementor-section elementor-inner-section elementor-element elementor-element-2b9110c elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"2b9110c\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-37196e9\" data-id=\"37196e9\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-1378d41 enlarged elementor-widget elementor-widget-image\" data-id=\"1378d41\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img loading=\"lazy\" decoding=\"async\" width=\"1600\" height=\"900\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/10\/12373_09.png\" class=\"attachment-full size-full wp-image-21310\" alt=\"\" srcset=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/10\/12373_09.png 1600w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/10\/12373_09-300x169.png 300w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/10\/12373_09-1024x576.png 1024w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/10\/12373_09-768x432.png 768w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/10\/12373_09-1536x864.png 1536w\" sizes=\"(max-width: 1600px) 100vw, 1600px\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-c3c49bc\" data-id=\"c3c49bc\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-c2a78c2 elementor-widget elementor-widget-text-editor\" data-id=\"c2a78c2\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<ul><li><p>\u2460\u3000\u30c4\u30ea\u30fc\u30d3\u30e5\u30fc\u306e\u5404\u7a74\u306e\u53f3\u5074\u306b[\u9ed2\u8272\u6587\u5b57]\u30673D CAD\u306e\u7a74\u5c5e\u6027\u60c5\u5831\u304c\u8868\u793a\u3055\u308c\u307e\u3059\u3002<\/p><\/li><li><p>\u9023\u643a\u3055\u308c\u306a\u304b\u3063\u305f\u5834\u5408\u306f\u300c\u672a\u9023\u643a\u306e\u7a74\u5c5e\u6027\u300d\u3068\u8868\u8a18\u306e\u4e0a[\u9ec4\u8272\u6587\u5b57]\u3067\u8868\u793a\u3055\u308c\u307e\u3059\u3002<\/p><\/li><li><p>\u2461\u30003D CAD\u306e\u7a74\u5c5e\u6027\u60c5\u5831\u3092\u975e\u8868\u793a\u306b\u3059\u308b\u3053\u3068\u304c\u3067\u304d\u307e\u3059\u3002<\/p><\/li><li><p>\u2462\u3000\u7a74\u5c5e\u6027\u9023\u643a\u306e\u9069\u7528\u30eb\u30fc\u30eb\u3092\u78ba\u8a8d\u3067\u304d\u307e\u3059\u3002<\/p><\/li><\/ul>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-4b69e49 elementor-widget elementor-widget-text-editor\" data-id=\"4b69e49\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<div class=\"txtBasic bg\" style=\"margin-top: 20px;\">\n<p class=\"labelNote\">\u6ce8\u610f<\/p>\n\n<ul>\n \t<li>\u3053\u308c\u3089\u306e\u7a74\u5c5e\u6027\u306f\u3001meviy\u72ec\u81ea\u306e\u30eb\u30fc\u30eb\u306b\u3082\u3068\u3065\u3044\u3066\u9023\u643a\u3057\u305f\u7d50\u679c\u3067\u3042\u308a\u3001\u304a\u4f7f\u3044\u306e3D CAD\u30bd\u30d5\u30c8\u3067\u8a2d\u5b9a\u3055\u308c\u305f\u7a74\u5c5e\u6027\u306e\u5024\u3068\u4e00\u81f4\u3057\u306a\u3044\u53ef\u80fd\u6027\u304c\u3042\u308a\u307e\u3059\u3002<\/li>\n \t<li>\uff3b3D CAD\u306e\u7a74\u5c5e\u6027\u304b\u3089\u7a74\u30bf\u30a4\u30d7\u3092\u81ea\u52d5\u8a8d\u8b58\uff3d\u306e\u4f7f\u3044\u59cb\u3081\u3068\u3001\u304a\u4f7f\u3044\u306e3D CAD\u3001Version\u3001\u74b0\u5883\u8a2d\u5b9a\u304c\u5909\u308f\u3063\u305f\u3068\u304d\u306f\u3001\u5fc5\u305a\u7a74\u306e\u81ea\u52d5\u8a8d\u8b58\u7d50\u679c\u3092\u78ba\u8a8d\u3057\u3066\u304f\u3060\u3055\u3044\u3002<\/li>\n<\/ul>\n<\/div>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-f88da7a elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"f88da7a\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-648a7cf\" data-id=\"648a7cf\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-26eb537 elementor-widget elementor-widget-menu-anchor\" data-id=\"26eb537\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"menu-anchor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t<div class=\"elementor-menu-anchor\" id=\"section_7\"><\/div>\n\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-5ac4483 elementor-widget elementor-widget-heading\" data-id=\"5ac4483\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h2 class=\"elementor-heading-title elementor-size-default\">\u7a74\u5c5e\u6027\u9023\u643a\u5bfe\u8c61\u306e3D CAD\u60c5\u5831<\/h2>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-b2a27d9 elementor-widget elementor-widget-text-editor\" data-id=\"b2a27d9\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<ul><li><p>\u7a74\u5c5e\u6027\u3092\u9023\u643a\u3067\u304d\u308b3D CAD\u30d5\u30a9\u30fc\u30de\u30c3\u30c8\u306f\u4ee5\u4e0b\u3092\u3054\u53c2\u7167\u304f\u3060\u3055\u3044\u3002<\/p><\/li><\/ul>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-bb06bca tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"bb06bca\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"tableHover_single\">\n<tbody>\n<tr style=\"height: 24px;\">\n<th style=\"width: 33.3333%; height: 24px;\" colspan=\"3\">3D CAD\u30d5\u30a9\u30fc\u30de\u30c3\u30c8<\/th>\n<\/tr>\n<tr style=\"height: 24px;\">\n<th style=\"width: 33.3333%; height: 48px;\" rowspan=\"2\">3D CAD\u540d<\/th>\n<th style=\"width: 33.3333%; height: 24px;\">\u30cd\u30a4\u30c6\u30a3\u30d6<\/th>\n<th style=\"width: 33.3333%; height: 24px;\">\u4e2d\u9593\u30d5\u30a9\u30fc\u30de\u30c3\u30c8<\/th>\n<\/tr>\n<tr style=\"height: 24px;\">\n<th style=\"width: 33.3333%; height: 24px;\">(.sldprt)(.icd)<\/th>\n<th style=\"width: 33.3333%; height: 24px;\">(.x_t)(.x_b)(.xmt_txt)<\/th>\n<\/tr>\n<tr style=\"height: 24px;\">\n<th style=\"width: 33.3333%; height: 24px;\">SOLIDWORKS<\/th>\n<td style=\"width: 33.3333%; height: 24px;\">\u3007<\/td>\n<td style=\"width: 33.3333%; height: 24px;\">\uff70<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<th style=\"width: 33.3333%; height: 24px;\">iCAD SX<\/th>\n<td style=\"width: 33.3333%; height: 24px;\">\u3007<\/td>\n<td style=\"width: 33.3333%; height: 24px;\">\uff70<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<th style=\"width: 33.3333%; height: 24px;\">\u4ed6\u306e3D CAD<\/th>\n<td style=\"width: 33.3333%; height: 24px;\">\uff70<\/td>\n<td style=\"width: 33.3333%; height: 24px;\">\uff70<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-29adc64 elementor-widget elementor-widget-text-editor\" data-id=\"29adc64\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<div class=\"txtBasic bg\" style=\"margin-top: 20px;\">\n<p class=\"labelNote\">\u6ce8\u610f<\/p>\n\u5bfe\u8c61\u5916\u306e3D CAD\u3067\u751f\u6210\u3055\u308c\u305f\u30e2\u30c7\u30eb\u30843D CAD\u30d5\u30a9\u30fc\u30de\u30c3\u30c8\u306f\u3001\u7a74\u5c5e\u6027\u9023\u643a\u306b\u3088\u308b\u7a74\u30bf\u30a4\u30d7\u81ea\u52d5\u8a8d\u8b58\u306e\u52d5\u4f5c\u4fdd\u8a3c\u5bfe\u8c61\u5916\u3068\u306a\u308a\u307e\u3059\u3002\n\n<\/div>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<\/div>\n\t\t\n\t\t\t<div id=\"daexthefu-container\"\n\t\t\t\tclass=\"daexthefu-container daexthefu-layout-stacked daexthefu-alignment-left\"\n\t\t\t\tdata-post-id=\"12373\">\n\n\t\t\t\t<div class=\"daexthefu-feedback\">\n\t\t\t\t\t<div class=\"daexthefu-text\">\n\t\t\t\t\t\t<h3 class=\"daexthefu-title\">\u3053\u306e\u8a18\u4e8b\u306f\u53c2\u8003\u306b\u306a\u308a\u307e\u3057\u305f\u304b\uff1f<\/h3>\n\t\t\t\t\t<\/div>\n\t\t\t\t\t<div class=\"daexthefu-buttons-container\">\n\t\t\t\t\t\t<div class=\"daexthefu-buttons\">\n\t\t\t\t\t\t\t\n\t\t\t<div class=\"daexthefu-yes daexthefu-button daexthefu-button-type-icon-and-text\" data-value=\"1\">\n\t\t\t\t<div class=\"daexthefu-button-icon\">\n\t\t\t\t\n                <svg>\n                    <defs>\n                        <style>.thumb-up-cls-1{fill:#c9c9c9;}.thumb-up-cls-2{fill:#e1e1e1;}.thumb-up-cls-3{fill:#676767;}<\/style>\n                    <\/defs>\n                    <g id=\"thumb_up\">\n                        <path class=\"thumb-up-cls-2 daexthefu-icon-circle\" d=\"m24,3c11.58,0,21,9.42,21,21s-9.42,21-21,21S3,35.58,3,24,12.42,3,24,3m0-1C11.85,2,2,11.85,2,24s9.85,22,22,22,22-9.85,22-22S36.15,2,24,2h0Z\" \/>\n                        <g>\n                            <rect class=\"thumb-up-cls-3 daexthefu-icon-secondary-color\" x=\"10\" y=\"20\" width=\"6\" height=\"15\" rx=\"1.5\" ry=\"1.5\" \/>\n                            <path class=\"thumb-up-cls-1 daexthefu-icon-primary-color\" d=\"m30.57,9.06l-.49-.1c-.81-.17-1.61.35-1.78,1.16l-5.3,11.74c-.17.81,3.16,1.61,3.97,1.78l1.96.41c.81.17,1.61-.35,1.78-1.16l2.18-10.27c.34-1.61-.7-3.21-2.31-3.56Z\" \/>\n                            <path class=\"thumb-up-cls-1 daexthefu-icon-primary-color\" d=\"m38.17,20h-18.67c-.83,0-1.5.67-1.5,1.5v12c0,.83.67,1.5,1.5,1.5h16.27c.71,0,1.33-.5,1.47-1.21l2.4-12c.19-.93-.53-1.8-1.47-1.8Z\" \/>\n                        <\/g>\n                    <\/g>\n                <\/svg>\t\t\t\t\t\t<\/div>\n\t\t\t\t<div class=\"daexthefu-button-text\">\u5f79\u306b\u7acb\u3063\u305f\uff01<\/div>\n\t\t\t<\/div>\n\n\t\t\t\t\t\t\t\t\t\t\n\t\t\t<div class=\"daexthefu-no daexthefu-button daexthefu-button-type-icon-and-text\" data-value=\"0\">\n\t\t\t\t<div class=\"daexthefu-button-icon\">\n\t\t\t\t\n                <svg>\n                    <defs>\n                        <style>.thumb-down-cls-1{fill:#c9c9c9;}.thumb-down-cls-2{fill:#e1e1e1;}.thumb-down-cls-3{fill:#676767;}<\/style>\n                    <\/defs>\n                    <g id=\"thumb_down\">\n                        <path class=\"thumb-down-cls-2 daexthefu-icon-circle\" d=\"m24,3c11.58,0,21,9.42,21,21s-9.42,21-21,21S3,35.58,3,24,12.42,3,24,3m0-1C11.85,2,2,11.85,2,24s9.85,22,22,22,22-9.85,22-22S36.15,2,24,2h0Z\" \/>\n                        <g>\n                            <rect class=\"thumb-down-cls-3 daexthefu-icon-secondary-color\" x=\"10\" y=\"13\" width=\"6\" height=\"15\" rx=\"1.5\" ry=\"1.5\" \/>\n                            <path class=\"thumb-down-cls-1 daexthefu-icon-primary-color\" d=\"m30.57,38.94l-.49.1c-.81.17-1.61-.35-1.78-1.16l-5.3-11.74c-.17-.81,3.16-1.61,3.97-1.78l1.96-.41c.81-.17,1.61.35,1.78,1.16l2.18,10.27c.34,1.61-.7,3.21-2.31,3.56Z\" \/>\n                            <path class=\"thumb-down-cls-1 daexthefu-icon-primary-color\" d=\"m38.17,28h-18.67c-.83,0-1.5-.67-1.5-1.5v-12c0-.83.67-1.5,1.5-1.5h16.27c.71,0,1.33.5,1.47,1.21l2.4,12c.19.93-.53,1.8-1.47,1.8Z\" \/>\n                        <\/g>\n                    <\/g>\n                <\/svg>\t\t\t\t\t\t<\/div>\n\t\t\t\t<div class=\"daexthefu-button-text\">\u5f79\u306b\u7acb\u305f\u306a\u304b\u3063\u305f<\/div>\n\t\t\t<\/div>\n\n\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\n\t\t\t\t<div class=\"daexthefu-comment\">\n\t\t\t\t\t<div class=\"daexthefu-comment-top-container\">\n\t\t\t\t\t\t<label id=\"daexthefu-comment-label\" class=\"daexthefu-comment-label\"><\/label>\n\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t\t<textarea id=\"daexthefu-comment-textarea\" class=\"daexthefu-comment-textarea\"\n\t\t\t\t\t\t\t\tplaceholder=\"\"\n\t\t\t\t\t\t\t\tmaxlength=\"\n\t\t\t\t\t\t\t\t400\t\t\t\t\t\t\t\t\t\"><\/textarea>\n\t\t\t\t\t<div class=\"daexthefu-comment-buttons-container\">\n\t\t\t\t\t\t<button class=\"daexthefu-comment-submit daexthefu-button\">\u9001\u4fe1<\/button>\n\t\t\t\t\t\t<button class=\"daexthefu-comment-cancel daexthefu-button\">\u53d6\u6d88<\/button>\n\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\n\t\t\t\t<div class=\"daexthefu-successful-submission-text\">\u8a55\u4fa1\u3044\u305f\u3060\u304d\u3042\u308a\u304c\u3068\u3046\u3054\u3056\u3044\u307e\u3057\u305f\u3002<\/div>\n\n\t\t\t<\/div>\n\n\t\t\t","protected":false},"excerpt":{"rendered":"<p>\u7a74\u30bf\u30a4\u30d7\u306e\u81ea\u52d5\u8a8d\u8b58\u8a2d\u5b9a \u8272\u5c5e\u6027\u9023\u643a \u7a74\u5c5e\u6027\u9023\u643a SOLIDWORKS\u3000\u7a74\u30b3\u30de\u30f3\u30c9\u5bfe\u5fdc\u8868 SOLIDWORKS\u3092\u304a\u4f7f\u3044\u306e\u5834\u5408\u306e\u3001\u7a74\u30bf\u30a4\u30d7\u81ea\u52d5\u8a8d\u8b58\u8a2d\u5b9a\u306e\u8a2d\u5b9a\u65b9\u6cd5\u306b\u3064\u3044\u3066\u3054\u6848\u5185\u3057\u307e\u3059\u3002 \u7a74\u30bf\u30a4\u30d7\u306e\u81ea\u52d5\u8a8d\u8b58\u8a2d\u5b9a 3D\u30e2\u30c7\u30eb\u306e\u7a74\u30bf [&hellip;]<\/p>\n","protected":false},"author":15,"featured_media":0,"comment_status":"closed","ping_status":"closed","sticky":false,"template":"","format":"standard","meta":{"_helpful_status":1,"footnotes":""},"categories":[2],"tags":[],"class_list":["post-12373","post","type-post","status-publish","format-standard","hentry","category-first"],"yoast_head":"<!-- This site is optimized with the Yoast SEO plugin v26.9 - https:\/\/yoast.com\/product\/yoast-seo-wordpress\/ -->\n<title>SOLIDWORKS | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb<\/title>\n<meta name=\"robots\" content=\"noindex, follow, max-snippet:-1, max-image-preview:large, max-video-preview:-1\" \/>\n<meta property=\"og:locale\" content=\"ja_JP\" \/>\n<meta property=\"og:type\" content=\"article\" \/>\n<meta property=\"og:title\" content=\"SOLIDWORKS | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\" \/>\n<meta property=\"og:description\" content=\"\u7a74\u30bf\u30a4\u30d7\u306e\u81ea\u52d5\u8a8d\u8b58\u8a2d\u5b9a \u8272\u5c5e\u6027\u9023\u643a \u7a74\u5c5e\u6027\u9023\u643a SOLIDWORKS\u3000\u7a74\u30b3\u30de\u30f3\u30c9\u5bfe\u5fdc\u8868 SOLIDWORKS\u3092\u304a\u4f7f\u3044\u306e\u5834\u5408\u306e\u3001\u7a74\u30bf\u30a4\u30d7\u81ea\u52d5\u8a8d\u8b58\u8a2d\u5b9a\u306e\u8a2d\u5b9a\u65b9\u6cd5\u306b\u3064\u3044\u3066\u3054\u6848\u5185\u3057\u307e\u3059\u3002 \u7a74\u30bf\u30a4\u30d7\u306e\u81ea\u52d5\u8a8d\u8b58\u8a2d\u5b9a 3D\u30e2\u30c7\u30eb\u306e\u7a74\u30bf [&hellip;]\" \/>\n<meta property=\"og:url\" content=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/first\/12373\/\" \/>\n<meta property=\"og:site_name\" content=\"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\" \/>\n<meta property=\"article:published_time\" content=\"2022-08-18T10:10:18+00:00\" \/>\n<meta property=\"article:modified_time\" content=\"2025-06-20T05:05:03+00:00\" \/>\n<meta property=\"og:image\" content=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2022\/08\/12373_01_A.png\" \/>\n\t<meta property=\"og:image:width\" content=\"770\" \/>\n\t<meta property=\"og:image:height\" content=\"300\" \/>\n\t<meta property=\"og:image:type\" content=\"image\/png\" \/>\n<meta name=\"author\" content=\"\u7f8e\u7d00\" \/>\n<meta name=\"twitter:card\" content=\"summary_large_image\" \/>\n<script type=\"application\/ld+json\" class=\"yoast-schema-graph\">{\"@context\":\"https:\/\/schema.org\",\"@graph\":[{\"@type\":\"Article\",\"@id\":\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/first\/12373\/#article\",\"isPartOf\":{\"@id\":\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/first\/12373\/\"},\"author\":{\"name\":\"\u7f8e\u7d00\",\"@id\":\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/person\/6ff70d9094b7fdc810efdfcc2fdb63c5\"},\"headline\":\"SOLIDWORKS\",\"datePublished\":\"2022-08-18T10:10:18+00:00\",\"dateModified\":\"2025-06-20T05:05:03+00:00\",\"mainEntityOfPage\":{\"@id\":\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/first\/12373\/\"},\"wordCount\":189,\"publisher\":{\"@id\":\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#organization\"},\"image\":{\"@id\":\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/first\/12373\/#primaryimage\"},\"thumbnailUrl\":\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2022\/08\/12373_01_A.png\",\"articleSection\":[\"\u3054\u5229\u7528\u3092\u59cb\u3081\u308b\u524d\u306b\"],\"inLanguage\":\"ja\"},{\"@type\":\"WebPage\",\"@id\":\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/first\/12373\/\",\"url\":\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/first\/12373\/\",\"name\":\"SOLIDWORKS | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\",\"isPartOf\":{\"@id\":\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#website\"},\"primaryImageOfPage\":{\"@id\":\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/first\/12373\/#primaryimage\"},\"image\":{\"@id\":\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/first\/12373\/#primaryimage\"},\"thumbnailUrl\":\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2022\/08\/12373_01_A.png\",\"datePublished\":\"2022-08-18T10:10:18+00:00\",\"dateModified\":\"2025-06-20T05:05:03+00:00\",\"breadcrumb\":{\"@id\":\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/first\/12373\/#breadcrumb\"},\"inLanguage\":\"ja\",\"potentialAction\":[{\"@type\":\"ReadAction\",\"target\":[\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/first\/12373\/\"]}]},{\"@type\":\"ImageObject\",\"inLanguage\":\"ja\",\"@id\":\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/first\/12373\/#primaryimage\",\"url\":\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2022\/08\/12373_01_A.png\",\"contentUrl\":\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2022\/08\/12373_01_A.png\",\"width\":770,\"height\":300},{\"@type\":\"BreadcrumbList\",\"@id\":\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/first\/12373\/#breadcrumb\",\"itemListElement\":[{\"@type\":\"ListItem\",\"position\":1,\"name\":\"\u30db\u30fc\u30e0\",\"item\":\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/\"},{\"@type\":\"ListItem\",\"position\":2,\"name\":\"SOLIDWORKS\"}]},{\"@type\":\"WebSite\",\"@id\":\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#website\",\"url\":\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/\",\"name\":\"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\",\"description\":\"\",\"publisher\":{\"@id\":\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#organization\"},\"potentialAction\":[{\"@type\":\"SearchAction\",\"target\":{\"@type\":\"EntryPoint\",\"urlTemplate\":\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/?s={search_term_string}\"},\"query-input\":{\"@type\":\"PropertyValueSpecification\",\"valueRequired\":true,\"valueName\":\"search_term_string\"}}],\"inLanguage\":\"ja\"},{\"@type\":\"Organization\",\"@id\":\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#organization\",\"name\":\"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df\",\"url\":\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/\",\"logo\":{\"@type\":\"ImageObject\",\"inLanguage\":\"ja\",\"@id\":\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/logo\/image\/\",\"url\":\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2019\/05\/A01-b_b4-1_jpeg.jpg\",\"contentUrl\":\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2019\/05\/A01-b_b4-1_jpeg.jpg\",\"width\":260,\"height\":70,\"caption\":\"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df\"},\"image\":{\"@id\":\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/logo\/image\/\"}},{\"@type\":\"Person\",\"@id\":\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/person\/6ff70d9094b7fdc810efdfcc2fdb63c5\",\"name\":\"\u7f8e\u7d00\",\"image\":{\"@type\":\"ImageObject\",\"inLanguage\":\"ja\",\"@id\":\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/person\/image\/\",\"url\":\"https:\/\/secure.gravatar.com\/avatar\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g\",\"contentUrl\":\"https:\/\/secure.gravatar.com\/avatar\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g\",\"caption\":\"\u7f8e\u7d00\"},\"url\":\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/author\/miki-aa3x-momosemisumi-co-jp\/\"}]}<\/script>\n<!-- \/ Yoast SEO plugin. -->","yoast_head_json":{"title":"SOLIDWORKS | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","robots":{"index":"noindex","follow":"follow","max-snippet":"max-snippet:-1","max-image-preview":"max-image-preview:large","max-video-preview":"max-video-preview:-1"},"og_locale":"ja_JP","og_type":"article","og_title":"SOLIDWORKS | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","og_description":"\u7a74\u30bf\u30a4\u30d7\u306e\u81ea\u52d5\u8a8d\u8b58\u8a2d\u5b9a \u8272\u5c5e\u6027\u9023\u643a \u7a74\u5c5e\u6027\u9023\u643a SOLIDWORKS\u3000\u7a74\u30b3\u30de\u30f3\u30c9\u5bfe\u5fdc\u8868 SOLIDWORKS\u3092\u304a\u4f7f\u3044\u306e\u5834\u5408\u306e\u3001\u7a74\u30bf\u30a4\u30d7\u81ea\u52d5\u8a8d\u8b58\u8a2d\u5b9a\u306e\u8a2d\u5b9a\u65b9\u6cd5\u306b\u3064\u3044\u3066\u3054\u6848\u5185\u3057\u307e\u3059\u3002 \u7a74\u30bf\u30a4\u30d7\u306e\u81ea\u52d5\u8a8d\u8b58\u8a2d\u5b9a 3D\u30e2\u30c7\u30eb\u306e\u7a74\u30bf [&hellip;]","og_url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/first\/12373\/","og_site_name":"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","article_published_time":"2022-08-18T10:10:18+00:00","article_modified_time":"2025-06-20T05:05:03+00:00","og_image":[{"width":770,"height":300,"url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2022\/08\/12373_01_A.png","type":"image\/png"}],"author":"\u7f8e\u7d00","twitter_card":"summary_large_image","schema":{"@context":"https:\/\/schema.org","@graph":[{"@type":"Article","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/first\/12373\/#article","isPartOf":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/first\/12373\/"},"author":{"name":"\u7f8e\u7d00","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/person\/6ff70d9094b7fdc810efdfcc2fdb63c5"},"headline":"SOLIDWORKS","datePublished":"2022-08-18T10:10:18+00:00","dateModified":"2025-06-20T05:05:03+00:00","mainEntityOfPage":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/first\/12373\/"},"wordCount":189,"publisher":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#organization"},"image":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/first\/12373\/#primaryimage"},"thumbnailUrl":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2022\/08\/12373_01_A.png","articleSection":["\u3054\u5229\u7528\u3092\u59cb\u3081\u308b\u524d\u306b"],"inLanguage":"ja"},{"@type":"WebPage","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/first\/12373\/","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/first\/12373\/","name":"SOLIDWORKS | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","isPartOf":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#website"},"primaryImageOfPage":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/first\/12373\/#primaryimage"},"image":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/first\/12373\/#primaryimage"},"thumbnailUrl":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2022\/08\/12373_01_A.png","datePublished":"2022-08-18T10:10:18+00:00","dateModified":"2025-06-20T05:05:03+00:00","breadcrumb":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/first\/12373\/#breadcrumb"},"inLanguage":"ja","potentialAction":[{"@type":"ReadAction","target":["https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/first\/12373\/"]}]},{"@type":"ImageObject","inLanguage":"ja","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/first\/12373\/#primaryimage","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2022\/08\/12373_01_A.png","contentUrl":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2022\/08\/12373_01_A.png","width":770,"height":300},{"@type":"BreadcrumbList","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/first\/12373\/#breadcrumb","itemListElement":[{"@type":"ListItem","position":1,"name":"\u30db\u30fc\u30e0","item":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/"},{"@type":"ListItem","position":2,"name":"SOLIDWORKS"}]},{"@type":"WebSite","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#website","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/","name":"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","description":"","publisher":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#organization"},"potentialAction":[{"@type":"SearchAction","target":{"@type":"EntryPoint","urlTemplate":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/?s={search_term_string}"},"query-input":{"@type":"PropertyValueSpecification","valueRequired":true,"valueName":"search_term_string"}}],"inLanguage":"ja"},{"@type":"Organization","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#organization","name":"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/","logo":{"@type":"ImageObject","inLanguage":"ja","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/logo\/image\/","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2019\/05\/A01-b_b4-1_jpeg.jpg","contentUrl":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2019\/05\/A01-b_b4-1_jpeg.jpg","width":260,"height":70,"caption":"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df"},"image":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/logo\/image\/"}},{"@type":"Person","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/person\/6ff70d9094b7fdc810efdfcc2fdb63c5","name":"\u7f8e\u7d00","image":{"@type":"ImageObject","inLanguage":"ja","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/person\/image\/","url":"https:\/\/secure.gravatar.com\/avatar\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g","contentUrl":"https:\/\/secure.gravatar.com\/avatar\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g","caption":"\u7f8e\u7d00"},"url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/author\/miki-aa3x-momosemisumi-co-jp\/"}]}},"views":7541,"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts\/12373","targetHints":{"allow":["GET"]}}],"collection":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts"}],"about":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/types\/post"}],"author":[{"embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/users\/15"}],"replies":[{"embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/comments?post=12373"}],"version-history":[{"count":73,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts\/12373\/revisions"}],"predecessor-version":[{"id":33501,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts\/12373\/revisions\/33501"}],"wp:attachment":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/media?parent=12373"}],"wp:term":[{"taxonomy":"category","embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/categories?post=12373"},{"taxonomy":"post_tag","embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/tags?post=12373"}],"curies":[{"name":"wp","href":"https:\/\/api.w.org\/{rel}","templated":true}]}}
