{"id":13406,"date":"2026-04-05T00:00:03","date_gmt":"2026-04-04T15:00:03","guid":{"rendered":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/?p=13406"},"modified":"2026-10-05T10:29:34","modified_gmt":"2026-10-05T01:29:34","slug":"%e3%80%8c%e7%b3%b8%e9%9d%a2%e5%8f%96%e3%82%8a%e3%80%8d%e6%8a%80%e8%a1%93%e3%83%9e%e3%83%8b%e3%83%a5%e3%82%a2%e3%83%ab%e4%bd%9c%e6%88%90%e5%af%be%e8%b1%a1%e9%83%a8%e5%93%81-%e6%9d%90%e6%96%99%e3%83%9a","status":"publish","type":"post","link":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/13406\/","title":{"rendered":"\u9762\u53d6\u308a\u306e\u5bfe\u8c61\u7bc4\u56f2"},"content":{"rendered":"\t\t<div data-elementor-type=\"wp-post\" data-elementor-id=\"13406\" class=\"elementor elementor-13406\">\n\t\t\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-6229f76 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"6229f76\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-1153c5b\" data-id=\"1153c5b\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-64fcda3f elementor-widget elementor-widget-text-editor\" data-id=\"64fcda3f\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<ul><li>\u677f\u91d1\u306e\u9762\u53d6\u308a\u8ffd\u52a0\u5de5\u3067\u306f\u3001\u4e21\u9762\u30d0\u30ea\u53d6\u308a\u6a5f\u3092\u4f7f\u7528\u3057\u3066\u30d0\u30ea\u30fb\u30ab\u30a8\u30ea\u306e\u9664\u53bb\u3092\u884c\u3044\u307e\u3059\u3002<\/li><li>\u305d\u306e\u305f\u3081\u3001\u4f53\u88c1\u9762\u306b\u7d30\u304b\u306a\u50b7\u304c\u5165\u308b\u6050\u308c\u304c\u3054\u3056\u3044\u307e\u3059\u3002<\/li><li>\u8a73\u7d30\u306f\u300c<a href=\"\/help\/ja\/technical_info\/shm_conditions\/15196\/\">\u9762\u53d6\u308a\u306b\u3064\u3044\u3066<\/a>\u300d\u3092\u3054\u78ba\u8a8d\u4e0b\u3055\u3044\u3002<\/li><li>\u9285\u30fb\u771f\u936e\u306f\u300c\u7cf8\u9762\u53d6\u308a\uff1a\u306a\u3057\uff08\u30d0\u30ea\u30fb\u30ab\u30a8\u30ea\u306f\u9664\u53bb\uff09\u300d\u306e\u5834\u5408\u3067\u3082\u4e21\u9762\u306b\u7814\u78e8\u75d5\u304c\u6b8b\u308a\u307e\u3059\u3002\u8a73\u7d30\u306f\u300c<a href=\"\/help\/ja\/technical_info\/shm_conditions\/34578\/\">\u9285\u30fb\u771f\u936e\u306b\u3064\u3044\u3066<\/a>\u300d\u3092\u3054\u78ba\u8a8d\u304f\u3060\u3055\u3044\u3002<\/li><\/ul>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-7fdc289d elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"7fdc289d\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-4109a16a\" data-id=\"4109a16a\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-722984a5 elementor-widget elementor-widget-heading\" data-id=\"722984a5\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h2 class=\"elementor-heading-title elementor-size-default\">\u9762\u53d6\u308a\u306e\u5bfe\u8c61\u6750\u8cea\u30fb\u677f\u539a<\/h2>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<section class=\"elementor-section elementor-inner-section elementor-element elementor-element-3b2597b3 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"3b2597b3\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-inner-column elementor-element elementor-element-2faf2da7\" data-id=\"2faf2da7\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-575c9902 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"575c9902\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<ul><li>\u3007\uff1a \u81ea\u52d5\u898b\u7a4d\u3082\u308a\u53ef<\/li><li>\u30fc\uff1a \u62c5\u5f53\u8005\u898b\u7a4d\u3082\u308a\u306e\u307f\u53ef<\/li><\/ul><table class=\"table04 mT0 tableHover_single\"><tbody><tr><th>\u6750\u8cea\uff1a\u9244\u7cfb<\/th><th style=\"width: 25%;\">\u8868\u9762\u51e6\u7406<\/th><th style=\"width: 25%;\">\u677f\u539a<\/th><th>\u7cf8\u9762\u53d6\u308a<\/th><th>C\/R\u9762\u53d6\u308a<\/th><\/tr><tr><th rowspan=\"7\">SPCC\/SPHC<\/th><th>\u30fc<\/th><td>0.8 1.0 1.2 1.6 2.0 2.3 3.2 4.5 6.0<\/td><td>\u3007<\/td><td>\u3007<\/td><\/tr><tr><th>\u7c89\u4f53\u5857\u88c5 \u203b<\/th><td rowspan=\"2\">0.8 1.0 1.2 1.6 2.0 2.3 3.2 4.5 6.0<\/td><td rowspan=\"2\">\u3007<\/td><td rowspan=\"2\">\u30fc<\/td><\/tr><tr><th>\u6eb6\u5264\u5857\u88c5<\/th><\/tr><tr><th>\u7121\u96fb\u89e3\u30cb\u30c3\u30b1\u30eb\u30e1\u30c3\u30ad<\/th><td rowspan=\"3\">0.8 1.0 1.2 1.6 2.0 2.3 3.2 4.5 6.0<\/td><td rowspan=\"3\">\u3007<\/td><td rowspan=\"3\">\u3007<\/td><\/tr><tr><th>\u56db\u4e09\u9178\u5316\u9244\u76ae\u819c<\/th><\/tr><tr><th>\u4e09\u4fa1\u30af\u30ed\u30e1\u30fc\u30c8(\u767d)<\/th><\/tr><tr><th>\u4e09\u4fa1\u30af\u30ed\u30e1\u30fc\u30c8(\u9ed2)<\/th><td>0.8 1.0 1.2 1.6 2.0 2.3 3.2 4.5 6.0<\/td><td>\u3007<\/td><td>\u30fc<\/td><\/tr><tr><th rowspan=\"4\">SS400<\/th><th>\u30fc<\/th><td>9.0 10.0 12.0 16.0<\/td><td>\u3007<\/td><td>\u3007<\/td><\/tr><tr><th>\u7121\u96fb\u89e3\u30cb\u30c3\u30b1\u30eb\u30e1\u30c3\u30ad<\/th><td rowspan=\"3\">9.0<\/td><td rowspan=\"3\">\u3007<\/td><td rowspan=\"3\">\u3007<\/td><\/tr><tr><th>\u56db\u4e09\u9178\u5316\u9244\u76ae\u819c<\/th><\/tr><tr><th>\u4e09\u4fa1\u30af\u30ed\u30e1\u30fc\u30c8(\u767d)<\/th><\/tr><tr><th>SECC(\u96fb\u6c17\u4e9c\u925b\u30e1\u30c3\u30ad\u92fc\u677f)<\/th><th>\u96fb\u6c17\u4e9c\u925b\u30e1\u30c3\u30ad<\/th><td>0.8 1.0 1.2 1.6 2.0 2.3 3.2<\/td><td>\u3007<\/td><td>\u30fc<\/td><\/tr><\/tbody><\/table><div style=\"margin-top: 10px;\">\u203b\u7c89\u4f53\u5857\u88c5\u54c1\u306f\u300cN1 (\u8fd1\u4f3c\u30de\u30f3\u30bb\u30eb) \u534a\u30c4\u30e4\u300d\u300c5Y7\/1 (\u8fd1\u4f3c\u30de\u30f3\u30bb\u30eb) \u534a\u30c4\u30e4\u300d\u3001\u300c5P9\/1 (\u8fd1\u4f3c\u30de\u30f3\u30bb\u30eb) \u534a\u30c4\u30e4\u300d\u3001\u300c5P9\/1 (\u8fd1\u4f3c\u30de\u30f3\u30bb\u30eb) \u5168\u30c4\u30e4\u300d\u3001\u300c5Y7.2\/1.4 (\u8fd1\u4f3c\u30de\u30f3\u30bb\u30eb) \u534a\u30c4\u30e4\u300d\u306e\u307f\u5bfe\u8c61<\/div>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-inner-section elementor-element elementor-element-4afee972 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"4afee972\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-inner-column elementor-element elementor-element-5ca89115\" data-id=\"5ca89115\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-36ec02dd tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"36ec02dd\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"table04 mT0 tableHover_single\">\n<tbody>\n<tr>\n<th>\u6750\u8cea\uff1a\u30b9\u30c6\u30f3\u30ec\u30b9<\/th>\n<th style=\"width: 25%;\">\u4ed5\u4e0a\u3052\u65b9\u6cd5<\/th>\n<th style=\"width: 25%;\">\u677f\u539a<\/th>\n<th>\u7cf8\u9762\u53d6\u308a<\/th>\n<th>C\/R\u9762\u53d6\u308a<\/th>\n<\/tr>\n<tr>\n<th rowspan=\"2\">SUS304<\/th>\n<th>2B<\/th>\n<td>0.8 1.0 1.2 1.5 2.0 2.5 3.0 4.0 5.0 6.0<\/td>\n<td rowspan=\"3\">\u3007<\/td>\n<td>\u3007<\/td>\n<\/tr>\n<tr>\n<th>No.1<\/th>\n<td>9.0 10.0 12.0<\/td>\n<td>\u3007<\/td>\n<\/tr>\n<tr>\n<th>SUS316<\/th>\n<th>2B<\/th>\n<td>0.8 1.0 1.2 1.5 2.0 3.0 4.0 5.0 6.0<\/td>\n<td>\u30fc<\/td>\n<\/tr>\n\t<tr>\n\t\t<th>SUS316L<\/th>\n\t\t<th>2B<\/th>\n\t\t<td>1.0 2.0 3.0<\/td>\n\t\t<td>\u30fc<\/td>\n\t\t<td>\u30fc<\/td>\n\t<\/tr>\n<tr>\n<th>SUS430<\/th>\n<th>2B<\/th>\n<td>0.8 1.0 1.2 1.5 2.0 3.0<\/td>\n<td>\u3007<\/td>\n<td>\u3007<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-inner-section elementor-element elementor-element-4be1bfe elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"4be1bfe\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-inner-column elementor-element elementor-element-4fa2901\" data-id=\"4fa2901\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-719cbee tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"719cbee\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"table04 mT0 tableHover_single\">\n<tbody>\n<tr>\n<th>\u6750\u8cea\uff1a\u30a2\u30eb\u30df\u30cb\u30a6\u30e0<\/th>\n<th style=\"width: 25%;\">\u8868\u9762\u51e6\u7406<\/th>\n<th style=\"width: 25%;\">\u677f\u539a<\/th>\n<th>\u7cf8\u9762\u53d6\u308a<\/th>\n<th>C\/R\u9762\u53d6\u308a<\/th>\n<\/tr>\n<tr>\n<th rowspan=\"5\">A5052<\/th>\n<th>\u30fc<\/th>\n<td rowspan=\"5\">0.8 1.0 1.2 1.5 1.6 2.0 2.5 3.0 4.0 5.0 6.0<\/td>\n<td rowspan=\"5\">\u3007<\/td>\n<td rowspan=\"5\">\u30fc<\/td>\n<\/tr>\n<tr>\n<th>\u30a2\u30eb\u30de\u30a4\u30c8(\u767d)<\/th>\n<\/tr>\n<tr>\n<th>\u30a2\u30eb\u30de\u30a4\u30c8(\u9ed2)<\/th>\n<\/tr>\n<tr>\n<th>\u30a2\u30eb\u30de\u30a4\u30c8(\u3064\u3084\u6d88\u3057\u9ed2)<\/th>\n<\/tr>\n<tr>\n<th>\u30a2\u30ed\u30b8\u30f3\u51e6\u7406\u76f8\u5f53(\u4e09\u4fa1\u30af\u30ed\u30e0\u5316\u6210\u51e6\u7406)<\/th>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-inner-section elementor-element elementor-element-07dd99e elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"07dd99e\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-inner-column elementor-element elementor-element-ada515e\" data-id=\"ada515e\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-4375f7d tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"4375f7d\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"table04 mT0 tableHover_single\"><tbody><tr><th>\u6750\u8cea\uff1a\u9285<\/th><th style=\"width: 25%;\">\u8868\u9762\u51e6\u7406<\/th><th style=\"width: 25%;\">\u677f\u539a<\/th><th>\u7cf8\u9762\u53d6\u308a<\/th><th>C\/R\u9762\u53d6\u308a<\/th><\/tr><tr><th>C1020(\u7121\u9178\u7d20\u9285)<\/th><th>\u30fc<\/th><td>1.0 1.5 2.0 3.0<\/td><td rowspan=\"3\">\u3007<\/td><td rowspan=\"3\">\u30fc<\/td><\/tr><tr><th>C1100(\u30bf\u30d5\u30d4\u30c3\u30c1\u9285)<\/th><th>\u30fc<\/th><td>1.0 2.0 3.0<\/td><\/tr><tr><th>C2801P(\u771f\u936e\u30fb\u9ec4\u9285)<\/th><th>\u30fc<\/th><td>1.0 2.0 3.0<\/td><\/tr><\/tbody><\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<\/div>\n\t\t\n\t\t\t<div id=\"daexthefu-container\"\n\t\t\t\tclass=\"daexthefu-container daexthefu-layout-stacked daexthefu-alignment-left\"\n\t\t\t\tdata-post-id=\"13406\">\n\n\t\t\t\t<div class=\"daexthefu-feedback\">\n\t\t\t\t\t<div class=\"daexthefu-text\">\n\t\t\t\t\t\t<h3 class=\"daexthefu-title\">\u3053\u306e\u8a18\u4e8b\u306f\u53c2\u8003\u306b\u306a\u308a\u307e\u3057\u305f\u304b\uff1f<\/h3>\n\t\t\t\t\t<\/div>\n\t\t\t\t\t<div class=\"daexthefu-buttons-container\">\n\t\t\t\t\t\t<div class=\"daexthefu-buttons\">\n\t\t\t\t\t\t\t\n\t\t\t<div class=\"daexthefu-yes daexthefu-button daexthefu-button-type-icon-and-text\" data-value=\"1\">\n\t\t\t\t<div class=\"daexthefu-button-icon\">\n\t\t\t\t\n                <svg>\n                    <defs>\n                        <style>.thumb-up-cls-1{fill:#c9c9c9;}.thumb-up-cls-2{fill:#e1e1e1;}.thumb-up-cls-3{fill:#676767;}<\/style>\n                    <\/defs>\n                    <g id=\"thumb_up\">\n                        <path class=\"thumb-up-cls-2 daexthefu-icon-circle\" d=\"m24,3c11.58,0,21,9.42,21,21s-9.42,21-21,21S3,35.58,3,24,12.42,3,24,3m0-1C11.85,2,2,11.85,2,24s9.85,22,22,22,22-9.85,22-22S36.15,2,24,2h0Z\" \/>\n                        <g>\n                            <rect class=\"thumb-up-cls-3 daexthefu-icon-secondary-color\" x=\"10\" y=\"20\" width=\"6\" height=\"15\" rx=\"1.5\" ry=\"1.5\" \/>\n                            <path class=\"thumb-up-cls-1 daexthefu-icon-primary-color\" d=\"m30.57,9.06l-.49-.1c-.81-.17-1.61.35-1.78,1.16l-5.3,11.74c-.17.81,3.16,1.61,3.97,1.78l1.96.41c.81.17,1.61-.35,1.78-1.16l2.18-10.27c.34-1.61-.7-3.21-2.31-3.56Z\" \/>\n                            <path class=\"thumb-up-cls-1 daexthefu-icon-primary-color\" d=\"m38.17,20h-18.67c-.83,0-1.5.67-1.5,1.5v12c0,.83.67,1.5,1.5,1.5h16.27c.71,0,1.33-.5,1.47-1.21l2.4-12c.19-.93-.53-1.8-1.47-1.8Z\" \/>\n                        <\/g>\n                    <\/g>\n                <\/svg>\t\t\t\t\t\t<\/div>\n\t\t\t\t<div class=\"daexthefu-button-text\">\u5f79\u306b\u7acb\u3063\u305f\uff01<\/div>\n\t\t\t<\/div>\n\n\t\t\t\t\t\t\t\t\t\t\n\t\t\t<div class=\"daexthefu-no daexthefu-button daexthefu-button-type-icon-and-text\" data-value=\"0\">\n\t\t\t\t<div class=\"daexthefu-button-icon\">\n\t\t\t\t\n                <svg>\n                    <defs>\n                        <style>.thumb-down-cls-1{fill:#c9c9c9;}.thumb-down-cls-2{fill:#e1e1e1;}.thumb-down-cls-3{fill:#676767;}<\/style>\n                    <\/defs>\n                    <g id=\"thumb_down\">\n                        <path class=\"thumb-down-cls-2 daexthefu-icon-circle\" d=\"m24,3c11.58,0,21,9.42,21,21s-9.42,21-21,21S3,35.58,3,24,12.42,3,24,3m0-1C11.85,2,2,11.85,2,24s9.85,22,22,22,22-9.85,22-22S36.15,2,24,2h0Z\" \/>\n                        <g>\n                            <rect class=\"thumb-down-cls-3 daexthefu-icon-secondary-color\" x=\"10\" y=\"13\" width=\"6\" height=\"15\" rx=\"1.5\" ry=\"1.5\" \/>\n                            <path class=\"thumb-down-cls-1 daexthefu-icon-primary-color\" d=\"m30.57,38.94l-.49.1c-.81.17-1.61-.35-1.78-1.16l-5.3-11.74c-.17-.81,3.16-1.61,3.97-1.78l1.96-.41c.81-.17,1.61.35,1.78,1.16l2.18,10.27c.34,1.61-.7,3.21-2.31,3.56Z\" \/>\n                            <path class=\"thumb-down-cls-1 daexthefu-icon-primary-color\" d=\"m38.17,28h-18.67c-.83,0-1.5-.67-1.5-1.5v-12c0-.83.67-1.5,1.5-1.5h16.27c.71,0,1.33.5,1.47,1.21l2.4,12c.19.93-.53,1.8-1.47,1.8Z\" \/>\n                        <\/g>\n                    <\/g>\n                <\/svg>\t\t\t\t\t\t<\/div>\n\t\t\t\t<div class=\"daexthefu-button-text\">\u5f79\u306b\u7acb\u305f\u306a\u304b\u3063\u305f<\/div>\n\t\t\t<\/div>\n\n\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\n\t\t\t\t<div class=\"daexthefu-comment\">\n\t\t\t\t\t<div class=\"daexthefu-comment-top-container\">\n\t\t\t\t\t\t<label id=\"daexthefu-comment-label\" class=\"daexthefu-comment-label\"><\/label>\n\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t\t<textarea id=\"daexthefu-comment-textarea\" class=\"daexthefu-comment-textarea\"\n\t\t\t\t\t\t\t\tplaceholder=\"\"\n\t\t\t\t\t\t\t\tmaxlength=\"\n\t\t\t\t\t\t\t\t400\t\t\t\t\t\t\t\t\t\"><\/textarea>\n\t\t\t\t\t<div class=\"daexthefu-comment-buttons-container\">\n\t\t\t\t\t\t<button class=\"daexthefu-comment-submit daexthefu-button\">\u9001\u4fe1<\/button>\n\t\t\t\t\t\t<button class=\"daexthefu-comment-cancel daexthefu-button\">\u53d6\u6d88<\/button>\n\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\n\t\t\t\t<div class=\"daexthefu-successful-submission-text\">\u8a55\u4fa1\u3044\u305f\u3060\u304d\u3042\u308a\u304c\u3068\u3046\u3054\u3056\u3044\u307e\u3057\u305f\u3002<\/div>\n\n\t\t\t<\/div>\n\n\t\t\t","protected":false},"excerpt":{"rendered":"<p>\u677f\u91d1\u306e\u9762\u53d6\u308a\u8ffd\u52a0\u5de5\u3067\u306f\u3001\u4e21\u9762\u30d0\u30ea\u53d6\u308a\u6a5f\u3092\u4f7f\u7528\u3057\u3066\u30d0\u30ea\u30fb\u30ab\u30a8\u30ea\u306e\u9664\u53bb\u3092\u884c\u3044\u307e\u3059\u3002 \u305d\u306e\u305f\u3081\u3001\u4f53\u88c1\u9762\u306b\u7d30\u304b\u306a\u50b7\u304c\u5165\u308b\u6050\u308c\u304c\u3054\u3056\u3044\u307e\u3059\u3002 \u8a73\u7d30\u306f\u300c\u9762\u53d6\u308a\u306b\u3064\u3044\u3066\u300d\u3092\u3054\u78ba\u8a8d\u4e0b\u3055\u3044\u3002 \u9285\u30fb\u771f\u936e\u306f\u300c\u7cf8\u9762\u53d6\u308a\uff1a\u306a\u3057\uff08\u30d0\u30ea\u30fb\u30ab\u30a8\u30ea\u306f\u9664\u53bb [&hellip;]<\/p>\n","protected":false},"author":15,"featured_media":0,"comment_status":"closed","ping_status":"closed","sticky":false,"template":"","format":"standard","meta":{"_helpful_status":1,"footnotes":""},"categories":[50],"tags":[64],"class_list":["post-13406","post","type-post","status-publish","format-standard","hentry","category-shm_shape-material","tag-technical_shm"],"yoast_head":"<!-- This site is optimized with the Yoast SEO plugin v28.0 - https:\/\/yoast.com\/product\/yoast-seo-wordpress\/ -->\n<title>\u9762\u53d6\u308a\u306e\u5bfe\u8c61\u7bc4\u56f2 | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb<\/title>\n<meta name=\"robots\" content=\"index, follow, max-snippet:-1, max-image-preview:large, max-video-preview:-1\" \/>\n<link rel=\"canonical\" href=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/13406\/\" \/>\n<meta property=\"og:locale\" content=\"ja_JP\" \/>\n<meta property=\"og:type\" content=\"article\" \/>\n<meta property=\"og:title\" content=\"\u9762\u53d6\u308a\u306e\u5bfe\u8c61\u7bc4\u56f2 | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\" \/>\n<meta property=\"og:description\" content=\"\u677f\u91d1\u306e\u9762\u53d6\u308a\u8ffd\u52a0\u5de5\u3067\u306f\u3001\u4e21\u9762\u30d0\u30ea\u53d6\u308a\u6a5f\u3092\u4f7f\u7528\u3057\u3066\u30d0\u30ea\u30fb\u30ab\u30a8\u30ea\u306e\u9664\u53bb\u3092\u884c\u3044\u307e\u3059\u3002 \u305d\u306e\u305f\u3081\u3001\u4f53\u88c1\u9762\u306b\u7d30\u304b\u306a\u50b7\u304c\u5165\u308b\u6050\u308c\u304c\u3054\u3056\u3044\u307e\u3059\u3002 \u8a73\u7d30\u306f\u300c\u9762\u53d6\u308a\u306b\u3064\u3044\u3066\u300d\u3092\u3054\u78ba\u8a8d\u4e0b\u3055\u3044\u3002 \u9285\u30fb\u771f\u936e\u306f\u300c\u7cf8\u9762\u53d6\u308a\uff1a\u306a\u3057\uff08\u30d0\u30ea\u30fb\u30ab\u30a8\u30ea\u306f\u9664\u53bb [&hellip;]\" \/>\n<meta property=\"og:url\" content=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/13406\/\" \/>\n<meta property=\"og:site_name\" content=\"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\" \/>\n<meta property=\"article:published_time\" content=\"2026-04-04T15:00:03+00:00\" \/>\n<meta property=\"article:modified_time\" content=\"2026-10-05T01:29:34+00:00\" \/>\n<meta name=\"author\" content=\"\u7f8e\u7d00\" \/>\n<meta name=\"twitter:card\" content=\"summary_large_image\" \/>\n<script type=\"application\/ld+json\" class=\"yoast-schema-graph\">{\"@context\":\"https:\\\/\\\/schema.org\",\"@graph\":[{\"@type\":\"Article\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_shape-material\\\/13406\\\/#article\",\"isPartOf\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_shape-material\\\/13406\\\/\"},\"author\":{\"name\":\"\u7f8e\u7d00\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#\\\/schema\\\/person\\\/6ff70d9094b7fdc810efdfcc2fdb63c5\"},\"headline\":\"\u9762\u53d6\u308a\u306e\u5bfe\u8c61\u7bc4\u56f2\",\"datePublished\":\"2026-04-04T15:00:03+00:00\",\"dateModified\":\"2026-10-05T01:29:34+00:00\",\"mainEntityOfPage\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_shape-material\\\/13406\\\/\"},\"wordCount\":32,\"publisher\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#organization\"},\"keywords\":[\"technical_shm\"],\"articleSection\":[\"\u5bfe\u8c61\u90e8\u54c1\\\/\u6750\u6599\"],\"inLanguage\":\"ja\"},{\"@type\":\"WebPage\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_shape-material\\\/13406\\\/\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_shape-material\\\/13406\\\/\",\"name\":\"\u9762\u53d6\u308a\u306e\u5bfe\u8c61\u7bc4\u56f2 | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\",\"isPartOf\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#website\"},\"datePublished\":\"2026-04-04T15:00:03+00:00\",\"dateModified\":\"2026-10-05T01:29:34+00:00\",\"breadcrumb\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_shape-material\\\/13406\\\/#breadcrumb\"},\"inLanguage\":\"ja\",\"potentialAction\":[{\"@type\":\"ReadAction\",\"target\":[\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_shape-material\\\/13406\\\/\"]}]},{\"@type\":\"BreadcrumbList\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_shape-material\\\/13406\\\/#breadcrumb\",\"itemListElement\":[{\"@type\":\"ListItem\",\"position\":1,\"name\":\"\u30db\u30fc\u30e0\",\"item\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/\"},{\"@type\":\"ListItem\",\"position\":2,\"name\":\"\u9762\u53d6\u308a\u306e\u5bfe\u8c61\u7bc4\u56f2\"}]},{\"@type\":\"WebSite\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#website\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/\",\"name\":\"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\",\"description\":\"\",\"publisher\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#organization\"},\"potentialAction\":[{\"@type\":\"SearchAction\",\"target\":{\"@type\":\"EntryPoint\",\"urlTemplate\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/?s={search_term_string}\"},\"query-input\":{\"@type\":\"PropertyValueSpecification\",\"valueRequired\":true,\"valueName\":\"search_term_string\"}}],\"inLanguage\":\"ja\"},{\"@type\":\"Organization\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#organization\",\"name\":\"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/\",\"logo\":{\"@type\":\"ImageObject\",\"inLanguage\":\"ja\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#\\\/schema\\\/logo\\\/image\\\/\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2019\\\/05\\\/A01-b_b4-1_jpeg.jpg\",\"contentUrl\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2019\\\/05\\\/A01-b_b4-1_jpeg.jpg\",\"width\":260,\"height\":70,\"caption\":\"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df\"},\"image\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#\\\/schema\\\/logo\\\/image\\\/\"}},{\"@type\":\"Person\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#\\\/schema\\\/person\\\/6ff70d9094b7fdc810efdfcc2fdb63c5\",\"name\":\"\u7f8e\u7d00\",\"image\":{\"@type\":\"ImageObject\",\"inLanguage\":\"ja\",\"@id\":\"https:\\\/\\\/secure.gravatar.com\\\/avatar\\\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g\",\"url\":\"https:\\\/\\\/secure.gravatar.com\\\/avatar\\\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g\",\"contentUrl\":\"https:\\\/\\\/secure.gravatar.com\\\/avatar\\\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g\",\"caption\":\"\u7f8e\u7d00\"},\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/author\\\/miki-aa3x-momosemisumi-co-jp\\\/\"}]}<\/script>\n<!-- \/ Yoast SEO plugin. -->","yoast_head_json":{"title":"\u9762\u53d6\u308a\u306e\u5bfe\u8c61\u7bc4\u56f2 | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","robots":{"index":"index","follow":"follow","max-snippet":"max-snippet:-1","max-image-preview":"max-image-preview:large","max-video-preview":"max-video-preview:-1"},"canonical":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/13406\/","og_locale":"ja_JP","og_type":"article","og_title":"\u9762\u53d6\u308a\u306e\u5bfe\u8c61\u7bc4\u56f2 | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","og_description":"\u677f\u91d1\u306e\u9762\u53d6\u308a\u8ffd\u52a0\u5de5\u3067\u306f\u3001\u4e21\u9762\u30d0\u30ea\u53d6\u308a\u6a5f\u3092\u4f7f\u7528\u3057\u3066\u30d0\u30ea\u30fb\u30ab\u30a8\u30ea\u306e\u9664\u53bb\u3092\u884c\u3044\u307e\u3059\u3002 \u305d\u306e\u305f\u3081\u3001\u4f53\u88c1\u9762\u306b\u7d30\u304b\u306a\u50b7\u304c\u5165\u308b\u6050\u308c\u304c\u3054\u3056\u3044\u307e\u3059\u3002 \u8a73\u7d30\u306f\u300c\u9762\u53d6\u308a\u306b\u3064\u3044\u3066\u300d\u3092\u3054\u78ba\u8a8d\u4e0b\u3055\u3044\u3002 \u9285\u30fb\u771f\u936e\u306f\u300c\u7cf8\u9762\u53d6\u308a\uff1a\u306a\u3057\uff08\u30d0\u30ea\u30fb\u30ab\u30a8\u30ea\u306f\u9664\u53bb [&hellip;]","og_url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/13406\/","og_site_name":"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","article_published_time":"2026-04-04T15:00:03+00:00","article_modified_time":"2026-10-05T01:29:34+00:00","author":"\u7f8e\u7d00","twitter_card":"summary_large_image","schema":{"@context":"https:\/\/schema.org","@graph":[{"@type":"Article","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/13406\/#article","isPartOf":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/13406\/"},"author":{"name":"\u7f8e\u7d00","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/person\/6ff70d9094b7fdc810efdfcc2fdb63c5"},"headline":"\u9762\u53d6\u308a\u306e\u5bfe\u8c61\u7bc4\u56f2","datePublished":"2026-04-04T15:00:03+00:00","dateModified":"2026-10-05T01:29:34+00:00","mainEntityOfPage":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/13406\/"},"wordCount":32,"publisher":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#organization"},"keywords":["technical_shm"],"articleSection":["\u5bfe\u8c61\u90e8\u54c1\/\u6750\u6599"],"inLanguage":"ja"},{"@type":"WebPage","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/13406\/","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/13406\/","name":"\u9762\u53d6\u308a\u306e\u5bfe\u8c61\u7bc4\u56f2 | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","isPartOf":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#website"},"datePublished":"2026-04-04T15:00:03+00:00","dateModified":"2026-10-05T01:29:34+00:00","breadcrumb":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/13406\/#breadcrumb"},"inLanguage":"ja","potentialAction":[{"@type":"ReadAction","target":["https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/13406\/"]}]},{"@type":"BreadcrumbList","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/13406\/#breadcrumb","itemListElement":[{"@type":"ListItem","position":1,"name":"\u30db\u30fc\u30e0","item":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/"},{"@type":"ListItem","position":2,"name":"\u9762\u53d6\u308a\u306e\u5bfe\u8c61\u7bc4\u56f2"}]},{"@type":"WebSite","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#website","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/","name":"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","description":"","publisher":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#organization"},"potentialAction":[{"@type":"SearchAction","target":{"@type":"EntryPoint","urlTemplate":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/?s={search_term_string}"},"query-input":{"@type":"PropertyValueSpecification","valueRequired":true,"valueName":"search_term_string"}}],"inLanguage":"ja"},{"@type":"Organization","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#organization","name":"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/","logo":{"@type":"ImageObject","inLanguage":"ja","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/logo\/image\/","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2019\/05\/A01-b_b4-1_jpeg.jpg","contentUrl":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2019\/05\/A01-b_b4-1_jpeg.jpg","width":260,"height":70,"caption":"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df"},"image":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/logo\/image\/"}},{"@type":"Person","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/person\/6ff70d9094b7fdc810efdfcc2fdb63c5","name":"\u7f8e\u7d00","image":{"@type":"ImageObject","inLanguage":"ja","@id":"https:\/\/secure.gravatar.com\/avatar\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g","url":"https:\/\/secure.gravatar.com\/avatar\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g","contentUrl":"https:\/\/secure.gravatar.com\/avatar\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g","caption":"\u7f8e\u7d00"},"url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/author\/miki-aa3x-momosemisumi-co-jp\/"}]}},"views":8304,"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts\/13406","targetHints":{"allow":["GET"]}}],"collection":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts"}],"about":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/types\/post"}],"author":[{"embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/users\/15"}],"replies":[{"embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/comments?post=13406"}],"version-history":[{"count":62,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts\/13406\/revisions"}],"predecessor-version":[{"id":38017,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts\/13406\/revisions\/38017"}],"wp:attachment":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/media?parent=13406"}],"wp:term":[{"taxonomy":"category","embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/categories?post=13406"},{"taxonomy":"post_tag","embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/tags?post=13406"}],"curies":[{"name":"wp","href":"https:\/\/api.w.org\/{rel}","templated":true}]}}
