{"id":18450,"date":"2023-06-05T10:00:24","date_gmt":"2023-06-05T01:00:24","guid":{"rendered":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/?p=18450"},"modified":"2026-08-06T17:51:29","modified_gmt":"2026-08-06T08:51:29","slug":"%e9%95%b7%e7%a9%b4%e3%82%ad%e3%83%bc%e6%ba%9d%e6%83%85%e5%a0%b1%e3%82%92%e5%a4%89%e6%9b%b4%e3%81%99%e3%82%8b","status":"publish","type":"post","link":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/tup_configuration\/18450\/","title":{"rendered":"\u9577\u7a74\/\u30ad\u30fc\u6e9d\u60c5\u5831\u3092\u8a2d\u5b9a\u3059\u308b"},"content":{"rendered":"\t\t<div data-elementor-type=\"wp-post\" data-elementor-id=\"18450\" class=\"elementor elementor-18450\">\n\t\t\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-7907387 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"7907387\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-ecee0ff\" data-id=\"ecee0ff\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-bf33785 elementor-widget elementor-widget-html\" data-id=\"bf33785\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"html.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<ul id=\"anchor\">\r\n<li><a href=\"#box1\">\u5916\u5f84\u30ad\u30fc\u6e9d\u60c5\u5831\u3092\u5909\u66f4\u3059\u308b\u200b<\/a><\/li>\r\n<li><a href=\"#box2\">\u9577\u7a74\u60c5\u5831\u3092\u5909\u66f4\u3059\u308b\u200b<\/a><\/li>\r\n<li><a href=\"#box3\">\u5185\u5f84\u30ad\u30fc\u6e9d\u60c5\u5831\u3092\u5909\u66f4\u3059\u308b\u200b<\/a><\/li>\r\n<\/ul>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-7f03a86 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"7f03a86\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-a57f883\" data-id=\"a57f883\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-f303c66 elementor-widget elementor-widget-menu-anchor\" data-id=\"f303c66\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"menu-anchor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t<div class=\"elementor-menu-anchor\" id=\"box1\"><\/div>\n\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-9849b54 elementor-widget elementor-widget-heading\" data-id=\"9849b54\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h2 class=\"elementor-heading-title elementor-size-default\">\u5916\u5f84\u30ad\u30fc\u6e9d\u60c5\u5831\u3092\u5909\u66f4\u3059\u308b\t\t\t\t\t\t\t\t\t\t\t\t<\/h2>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-f8ec712 elementor-widget elementor-widget-text-editor\" data-id=\"f8ec712\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p>\u6e9d\u5e45\u304cJIS\u898f\u683c(B 1301\uff1a1996)\u3068\u4e00\u81f4\u3059\u308b\u5834\u5408\u3001\u30ad\u30fc\u6e9d\u3068\u8a8d\u8b58\u3055\u308c\u307e\u3059\u3002<\/p><ul><li style=\"margin-top: 10px;\">\u6280\u8853\u60c5\u5831\u2192<a href=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/tup_guideline\/12594\/#box4\">\u300c\u30ad\u30fc\u6e9d\u306e\u8a8d\u8b58\u6761\u4ef6\u300d<\/a><\/li><\/ul>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<section class=\"elementor-section elementor-inner-section elementor-element elementor-element-5e45727 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"5e45727\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-7287b6a\" data-id=\"7287b6a\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-f7f8a7e elementor-widget elementor-widget-heading\" data-id=\"f7f8a7e\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h5 class=\"elementor-heading-title elementor-size-default\">1.  \u30c4\u30ea\u30fc\u30d3\u30e5\u30fc\u306e\u300c\u6570\u5024\u300d\u307e\u305f\u306f3D\u30d3\u30e5\u30fc\u30ef\u30fc\u304b\u3089\u5bfe\u8c61\u306e\u300c\u5bf8\u6cd5\u300d\u300c\u9762\u300d\u3092\u30c0\u30d6\u30eb\u30af\u30ea\u30c3\u30af\u3057\u307e\u3059\u3002\n<\/h5>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-41a389c\" data-id=\"41a389c\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-67ac4ef enlarged elementor-widget elementor-widget-image\" data-id=\"67ac4ef\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img fetchpriority=\"high\" decoding=\"async\" width=\"1600\" height=\"900\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/05\/18450_01.png\" class=\"attachment-full size-full wp-image-18828\" alt=\"\u5916\u5f84\u30ad\u30fc\u6e9d\u60c5\u5831\u3092\u5909\u66f4\u3059\u308b\" srcset=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/05\/18450_01.png 1600w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/05\/18450_01-300x169.png 300w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/05\/18450_01-1024x576.png 1024w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/05\/18450_01-768x432.png 768w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/05\/18450_01-1536x864.png 1536w\" sizes=\"(max-width: 1600px) 100vw, 1600px\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-inner-section elementor-element elementor-element-dbbf016 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"dbbf016\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-45ada29\" data-id=\"45ada29\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-2809f58 elementor-widget elementor-widget-heading\" data-id=\"2809f58\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h5 class=\"elementor-heading-title elementor-size-default\">2.  \u8868\u793a\u3055\u308c\u305f[\u9577\u7a74\/\u5916\u5f84\u30ad\u30fc\u6e9d\u60c5\u5831\u6307\u793a]\u30c0\u30a4\u30a2\u30ed\u30b0\u304b\u3089\u516c\u5dee\u3092\u8a2d\u5b9a\u3057\u3001[\u66f4\u65b0]\u3092\u30af\u30ea\u30c3\u30af\u3057\u307e\u3059\u3002<\/h5>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-a3b3eec\" data-id=\"a3b3eec\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-ad8741a elementor-widget elementor-widget-image\" data-id=\"ad8741a\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img decoding=\"async\" width=\"700\" height=\"440\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/05\/18450_02.png\" class=\"attachment-full size-full wp-image-18829\" alt=\"\u8868\u793a\u3055\u308c\u305f[\u9577\u7a74\uff0f\u5916\u5f84\u30ad\u30fc\u6e9d\u60c5\u5831\u6307\u793a\u30c0\u30a4\u30a2\u30ed\u30b0]\u304b\u3089\u516c\u5dee\u3092\u9078\u629e\u3057\u3001[\u66f4\u65b0]\u3092\u30af\u30ea\u30c3\u30af\u3057\u307e\u3059\u3002\" srcset=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/05\/18450_02.png 700w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/05\/18450_02-300x189.png 300w\" sizes=\"(max-width: 700px) 100vw, 700px\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-6eb0bf0 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"6eb0bf0\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-e2d158a\" data-id=\"e2d158a\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-fcc630e elementor-widget elementor-widget-menu-anchor\" data-id=\"fcc630e\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"menu-anchor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t<div class=\"elementor-menu-anchor\" id=\"box2\"><\/div>\n\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-8dd29b2 elementor-widget elementor-widget-heading\" data-id=\"8dd29b2\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h2 class=\"elementor-heading-title elementor-size-default\">\u9577\u7a74\u60c5\u5831\u3092\u5909\u66f4\u3059\u308b\t\t\t\t\t\t\t\t\t\t\t\t<\/h2>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-067bf6e elementor-widget elementor-widget-text-editor\" data-id=\"067bf6e\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<ul><li>\u6e9d\u5e45\u304cJIS\u898f\u683c(B 1301\uff1a1996)\u3068\u4e00\u81f4\u3057\u306a\u3044\u5834\u5408\u3001\u9577\u7a74\u3068\u8a8d\u8b58\u3055\u308c\u307e\u3059\u3002<\/li><li style=\"margin-top: 10px;\">\u6280\u8853\u60c5\u5831\u2192<a href=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/tup_guideline\/12594\/#box4\">\u300c\u30ad\u30fc\u6e9d\u306e\u8a8d\u8b58\u6761\u4ef6\u300d<\/a><\/li><\/ul>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<section class=\"elementor-section elementor-inner-section elementor-element elementor-element-8837080 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"8837080\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-2db1ba1\" data-id=\"2db1ba1\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-73295bf elementor-widget elementor-widget-heading\" data-id=\"73295bf\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h5 class=\"elementor-heading-title elementor-size-default\">1.  \u30c4\u30ea\u30fc\u30d3\u30e5\u30fc\u306e\u300c\u6570\u5024\u300d\u307e\u305f\u306f3D\u30d3\u30e5\u30fc\u30ef\u30fc\u304b\u3089\u5bfe\u8c61\u306e\u300c\u5bf8\u6cd5\u300d\u300c\u9762\u300d\u3092\u30c0\u30d6\u30eb\u30af\u30ea\u30c3\u30af\u3057\u307e\u3059\u3002\n<\/h5>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-83b3261\" data-id=\"83b3261\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-a4f84f5 enlarged elementor-widget elementor-widget-image\" data-id=\"a4f84f5\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img decoding=\"async\" width=\"1600\" height=\"900\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/05\/18450_03.png\" class=\"attachment-full size-full wp-image-18883\" alt=\"\u9577\u7a74\u60c5\u5831\u3092\u5909\u66f4\u3059\u308b\" srcset=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/05\/18450_03.png 1600w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/05\/18450_03-300x169.png 300w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/05\/18450_03-1024x576.png 1024w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/05\/18450_03-768x432.png 768w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/05\/18450_03-1536x864.png 1536w\" sizes=\"(max-width: 1600px) 100vw, 1600px\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-inner-section elementor-element elementor-element-ec37a36 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"ec37a36\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-8ad91b1\" data-id=\"8ad91b1\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-b1b4dab elementor-widget elementor-widget-heading\" data-id=\"b1b4dab\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h5 class=\"elementor-heading-title elementor-size-default\">2.  \u8868\u793a\u3055\u308c\u305f[\u9577\u7a74\uff0f\u5916\u5f84\u30ad\u30fc\u6e9d\u60c5\u5831\u6307\u793a]\u30c0\u30a4\u30a2\u30ed\u30b0\u304b\u3089\u516c\u5dee\u3092\u8a2d\u5b9a\u3057\u3001[\u66f4\u65b0]\u3092\u30af\u30ea\u30c3\u30af\u3057\u307e\u3059\u3002<\/h5>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-60de8df\" data-id=\"60de8df\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-64d653d elementor-widget elementor-widget-image\" data-id=\"64d653d\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img loading=\"lazy\" decoding=\"async\" width=\"700\" height=\"330\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/05\/18450_04.png\" class=\"attachment-full size-full wp-image-18884\" alt=\"\u8868\u793a\u3055\u308c\u305f[\u9577\u7a74\uff0f\u5916\u5f84\u30ad\u30fc\u6e9d\u60c5\u5831\u6307\u793a\u30c0\u30a4\u30a2\u30ed\u30b0]\u304b\u3089\u516c\u5dee\u3092\u9078\u629e\u3057\u3001[\u66f4\u65b0]\u3092\u30af\u30ea\u30c3\u30af\u3057\u307e\u3059\u3002\" srcset=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/05\/18450_04.png 700w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/05\/18450_04-300x141.png 300w\" sizes=\"(max-width: 700px) 100vw, 700px\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-ccba210 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"ccba210\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-de9f034\" data-id=\"de9f034\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-fea549d elementor-widget elementor-widget-menu-anchor\" data-id=\"fea549d\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"menu-anchor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t<div class=\"elementor-menu-anchor\" id=\"box3\"><\/div>\n\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-8ac1275 elementor-widget elementor-widget-heading\" data-id=\"8ac1275\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h2 class=\"elementor-heading-title elementor-size-default\">\u5185\u5f84\u30ad\u30fc\u6e9d\u60c5\u5831\u3092\u5909\u66f4\u3059\u308b\t\t\t\t\t\t\t\t\t\t\t\t<\/h2>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-6a19883 elementor-widget elementor-widget-text-editor\" data-id=\"6a19883\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p>\u6e9d\u5e45\u304cJIS\u898f\u683c(B 1301\uff1a1996)\u3068\u4e00\u81f4\u3059\u308b\u5834\u5408\u3001\u30ad\u30fc\u6e9d\u3068\u8a8d\u8b58\u3055\u308c\u307e\u3059\u3002<\/p><ul><li style=\"margin-top: 10px;\">\u6280\u8853\u60c5\u5831\u2192<a href=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/tup_guideline\/12594\/#box4\">\u300c\u30ad\u30fc\u6e9d\u306e\u8a8d\u8b58\u6761\u4ef6\u300d<\/a><\/li><\/ul>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<section class=\"elementor-section elementor-inner-section elementor-element elementor-element-b73688a elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"b73688a\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-b0250f1\" data-id=\"b0250f1\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-08f836c elementor-widget elementor-widget-heading\" data-id=\"08f836c\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h5 class=\"elementor-heading-title elementor-size-default\"><span style=\"color: var( --e-global-color-primary );font-family: var( --e-global-typography-primary-font-family ), Sans-serif;font-size: 1.4rem\">1.  \u30c4\u30ea\u30fc\u30d3\u30e5\u30fc\u306e\u300c\u6570\u5024\u300d\u307e\u305f\u306f3D\u30d3\u30e5\u30fc\u30ef\u30fc\u304b\u3089\u5bfe\u8c61\u306e\u300c\u5bf8\u6cd5\u300d\u300c\u9762\u300d\u3092\u30c0\u30d6\u30eb\u30af\u30ea\u30c3\u30af\u3057\u307e\u3059\u3002<\/span><\/h5>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-e09fbe7\" data-id=\"e09fbe7\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-df98a31 enlarged elementor-widget elementor-widget-image\" data-id=\"df98a31\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img loading=\"lazy\" decoding=\"async\" width=\"1600\" height=\"900\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/05\/18450_05.png\" class=\"attachment-full size-full wp-image-18830\" alt=\"\u5185\u5f84\u30ad\u30fc\u6e9d\u60c5\u5831\u3092\u5909\u66f4\u3059\u308b\" srcset=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/05\/18450_05.png 1600w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/05\/18450_05-300x169.png 300w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/05\/18450_05-1024x576.png 1024w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/05\/18450_05-768x432.png 768w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/05\/18450_05-1536x864.png 1536w\" sizes=\"(max-width: 1600px) 100vw, 1600px\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-inner-section elementor-element elementor-element-fbc2ec8 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"fbc2ec8\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-454b731\" data-id=\"454b731\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-7e1c16b elementor-widget elementor-widget-heading\" data-id=\"7e1c16b\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h5 class=\"elementor-heading-title elementor-size-default\">2.  \u8868\u793a\u3055\u308c\u305f[\u5185\u5f84\u30ad\u30fc\u6e9d\u60c5\u5831\u6307\u793a]\u30c0\u30a4\u30a2\u30ed\u30b0\u304b\u3089\u516c\u5dee\u3092\u9078\u629e\u3057\u3001[\u66f4\u65b0]\u3092\u30af\u30ea\u30c3\u30af\u3057\u307e\u3059\u3002<\/h5>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-4e149de elementor-widget elementor-widget-text-editor\" data-id=\"4e149de\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<div class=\"txtBasic bg\">\n\n&nbsp;\n<p class=\"labelMemo\">memo<\/p>\n\n<ul>\n \t<li>\u6e9d\u5e45\u304cJIS\u898f\u683c(B 1301\uff1a1996)\u3068\u4e00\u81f4\u3057\u306a\u3044\u5834\u5408\u306f\u3001\u300c\u4e00\u822c\u516c\u5dee\u300d\u6271\u3044\u3068\u306a\u308a\u516c\u5dee\u9078\u629e\u3067\u304d\u307e\u305b\u3093\u3002<\/li>\n \t<li><span class=\"enlarged\"><img decoding=\"async\" style=\"margin-top: 10px; width: 100%; max-width: 300px;\" src=\"\/help\/ja\/wp-content\/uploads\/2023\/05\/18450_07.png\" alt=\"\" \/><\/span><\/li>\n<\/ul>\n<\/div>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-a87920b\" data-id=\"a87920b\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-62197a6 elementor-widget elementor-widget-image\" data-id=\"62197a6\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img loading=\"lazy\" decoding=\"async\" width=\"700\" height=\"340\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/05\/18450_06.png\" class=\"attachment-full size-full wp-image-18831\" alt=\"2. \u8868\u793a\u3055\u308c\u305f[\u5185\u5f84\u30ad\u30fc\u6e9d\u60c5\u5831\u6307\u793a\u30c0\u30a4\u30a2\u30ed\u30b0]\u304b\u3089\u516c\u5dee\u3092\u9078\u629e\u3057\u3001[\u66f4\u65b0]\u3092\u30af\u30ea\u30c3\u30af\u3057\u307e\u3059\u3002\" srcset=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/05\/18450_06.png 700w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/05\/18450_06-300x146.png 300w\" sizes=\"(max-width: 700px) 100vw, 700px\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<\/div>\n\t\t\n\t\t\t<div id=\"daexthefu-container\"\n\t\t\t\tclass=\"daexthefu-container daexthefu-layout-stacked daexthefu-alignment-left\"\n\t\t\t\tdata-post-id=\"18450\">\n\n\t\t\t\t<div class=\"daexthefu-feedback\">\n\t\t\t\t\t<div class=\"daexthefu-text\">\n\t\t\t\t\t\t<h3 class=\"daexthefu-title\">\u3053\u306e\u8a18\u4e8b\u306f\u53c2\u8003\u306b\u306a\u308a\u307e\u3057\u305f\u304b\uff1f<\/h3>\n\t\t\t\t\t<\/div>\n\t\t\t\t\t<div class=\"daexthefu-buttons-container\">\n\t\t\t\t\t\t<div class=\"daexthefu-buttons\">\n\t\t\t\t\t\t\t\n\t\t\t<button type=\"button\" class=\"daexthefu-yes daexthefu-button daexthefu-button-type-icon-and-text\" data-value=\"1\">\n\t\t\t\t<span class=\"daexthefu-button-icon\">\n\t\t\t\t\n                <svg>\n                    <defs>\n                        <style>.thumb-up-cls-1{fill:#c9c9c9;}.thumb-up-cls-2{fill:#e1e1e1;}.thumb-up-cls-3{fill:#676767;}<\/style>\n                    <\/defs>\n                    <g id=\"thumb_up\">\n                        <path class=\"thumb-up-cls-2 daexthefu-icon-circle\" d=\"m24,3c11.58,0,21,9.42,21,21s-9.42,21-21,21S3,35.58,3,24,12.42,3,24,3m0-1C11.85,2,2,11.85,2,24s9.85,22,22,22,22-9.85,22-22S36.15,2,24,2h0Z\" \/>\n                        <g>\n                            <rect class=\"thumb-up-cls-3 daexthefu-icon-secondary-color\" x=\"10\" y=\"20\" width=\"6\" height=\"15\" rx=\"1.5\" ry=\"1.5\" \/>\n                            <path class=\"thumb-up-cls-1 daexthefu-icon-primary-color\" d=\"m30.57,9.06l-.49-.1c-.81-.17-1.61.35-1.78,1.16l-5.3,11.74c-.17.81,3.16,1.61,3.97,1.78l1.96.41c.81.17,1.61-.35,1.78-1.16l2.18-10.27c.34-1.61-.7-3.21-2.31-3.56Z\" \/>\n                            <path class=\"thumb-up-cls-1 daexthefu-icon-primary-color\" d=\"m38.17,20h-18.67c-.83,0-1.5.67-1.5,1.5v12c0,.83.67,1.5,1.5,1.5h16.27c.71,0,1.33-.5,1.47-1.21l2.4-12c.19-.93-.53-1.8-1.47-1.8Z\" \/>\n                        <\/g>\n                    <\/g>\n                <\/svg>\t\t\t\t\t\t<\/span>\n\t\t\t\t<span class=\"daexthefu-button-text\">\u5f79\u306b\u7acb\u3063\u305f\uff01<\/span>\n\t\t\t<\/button>\n\n\t\t\t\t\t\t\t\t\t\t\n\t\t\t<button type=\"button\" class=\"daexthefu-no daexthefu-button daexthefu-button-type-icon-and-text\" data-value=\"0\">\n\t\t\t\t<span class=\"daexthefu-button-icon\">\n\t\t\t\t\n                <svg>\n                    <defs>\n                        <style>.thumb-down-cls-1{fill:#c9c9c9;}.thumb-down-cls-2{fill:#e1e1e1;}.thumb-down-cls-3{fill:#676767;}<\/style>\n                    <\/defs>\n                    <g id=\"thumb_down\">\n                        <path class=\"thumb-down-cls-2 daexthefu-icon-circle\" d=\"m24,3c11.58,0,21,9.42,21,21s-9.42,21-21,21S3,35.58,3,24,12.42,3,24,3m0-1C11.85,2,2,11.85,2,24s9.85,22,22,22,22-9.85,22-22S36.15,2,24,2h0Z\" \/>\n                        <g>\n                            <rect class=\"thumb-down-cls-3 daexthefu-icon-secondary-color\" x=\"10\" y=\"13\" width=\"6\" height=\"15\" rx=\"1.5\" ry=\"1.5\" \/>\n                            <path class=\"thumb-down-cls-1 daexthefu-icon-primary-color\" d=\"m30.57,38.94l-.49.1c-.81.17-1.61-.35-1.78-1.16l-5.3-11.74c-.17-.81,3.16-1.61,3.97-1.78l1.96-.41c.81-.17,1.61.35,1.78,1.16l2.18,10.27c.34,1.61-.7,3.21-2.31,3.56Z\" \/>\n                            <path class=\"thumb-down-cls-1 daexthefu-icon-primary-color\" d=\"m38.17,28h-18.67c-.83,0-1.5-.67-1.5-1.5v-12c0-.83.67-1.5,1.5-1.5h16.27c.71,0,1.33.5,1.47,1.21l2.4,12c.19.93-.53,1.8-1.47,1.8Z\" \/>\n                        <\/g>\n                    <\/g>\n                <\/svg>\t\t\t\t\t\t<\/span>\n\t\t\t\t<span class=\"daexthefu-button-text\">\u5f79\u306b\u7acb\u305f\u306a\u304b\u3063\u305f<\/span>\n\t\t\t<\/button>\n\n\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\n\t\t\t\t<div class=\"daexthefu-comment\">\n\t\t\t\t\t<div class=\"daexthefu-comment-top-container\">\n\t\t\t\t\t\t<label id=\"daexthefu-comment-label\" class=\"daexthefu-comment-label\"><\/label>\n\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t\t<textarea id=\"daexthefu-comment-textarea\" class=\"daexthefu-comment-textarea\"\n\t\t\t\t\t\t\t\tplaceholder=\"\"\n\t\t\t\t\t\t\t\tmaxlength=\"\n\t\t\t\t\t\t\t\t400\t\t\t\t\t\t\t\t\t\"><\/textarea>\n\t\t\t\t\t<div class=\"daexthefu-comment-buttons-container\">\n\t\t\t\t\t\t<button class=\"daexthefu-comment-submit daexthefu-button\">\u9001\u4fe1<\/button>\n\t\t\t\t\t\t<button class=\"daexthefu-comment-cancel daexthefu-button\">\u53d6\u6d88<\/button>\n\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\n\t\t\t\t<div class=\"daexthefu-successful-submission-text\">\u8a55\u4fa1\u3044\u305f\u3060\u304d\u3042\u308a\u304c\u3068\u3046\u3054\u3056\u3044\u307e\u3057\u305f\u3002<\/div>\n\n\t\t\t<\/div>\n\n\t\t\t","protected":false},"excerpt":{"rendered":"<p>\u5916\u5f84\u30ad\u30fc\u6e9d\u60c5\u5831\u3092\u5909\u66f4\u3059\u308b\u200b \u9577\u7a74\u60c5\u5831\u3092\u5909\u66f4\u3059\u308b\u200b \u5185\u5f84\u30ad\u30fc\u6e9d\u60c5\u5831\u3092\u5909\u66f4\u3059\u308b\u200b \u5916\u5f84\u30ad\u30fc\u6e9d\u60c5\u5831\u3092\u5909\u66f4\u3059\u308b \u6e9d\u5e45\u304cJIS\u898f\u683c(B 1301\uff1a1996)\u3068\u4e00\u81f4\u3059\u308b\u5834\u5408\u3001\u30ad\u30fc\u6e9d\u3068\u8a8d\u8b58\u3055\u308c\u307e\u3059\u3002 \u6280\u8853\u60c5\u5831\u2192\u300c\u30ad\u30fc\u6e9d\u306e\u8a8d\u8b58\u6761\u4ef6\u300d 1 [&hellip;]<\/p>\n","protected":false},"author":15,"featured_media":0,"comment_status":"closed","ping_status":"closed","sticky":false,"template":"","format":"standard","meta":{"_helpful_status":1,"footnotes":""},"categories":[96],"tags":[97],"class_list":["post-18450","post","type-post","status-publish","format-standard","hentry","category-tup_configuration","tag-manual_tup"],"yoast_head":"<!-- This site is optimized with the Yoast SEO plugin v28.7 - https:\/\/yoast.com\/product\/yoast-seo-wordpress\/ -->\n<title>\u9577\u7a74\/\u30ad\u30fc\u6e9d\u60c5\u5831\u3092\u8a2d\u5b9a\u3059\u308b | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb<\/title>\n<meta name=\"robots\" content=\"index, follow, max-snippet:-1, max-image-preview:large, max-video-preview:-1\" \/>\n<link rel=\"canonical\" href=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/tup_configuration\/18450\/\" \/>\n<meta property=\"og:locale\" content=\"ja_JP\" \/>\n<meta property=\"og:type\" content=\"article\" \/>\n<meta property=\"og:title\" content=\"\u9577\u7a74\/\u30ad\u30fc\u6e9d\u60c5\u5831\u3092\u8a2d\u5b9a\u3059\u308b | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\" \/>\n<meta property=\"og:description\" content=\"\u5916\u5f84\u30ad\u30fc\u6e9d\u60c5\u5831\u3092\u5909\u66f4\u3059\u308b\u200b \u9577\u7a74\u60c5\u5831\u3092\u5909\u66f4\u3059\u308b\u200b \u5185\u5f84\u30ad\u30fc\u6e9d\u60c5\u5831\u3092\u5909\u66f4\u3059\u308b\u200b \u5916\u5f84\u30ad\u30fc\u6e9d\u60c5\u5831\u3092\u5909\u66f4\u3059\u308b \u6e9d\u5e45\u304cJIS\u898f\u683c(B 1301\uff1a1996)\u3068\u4e00\u81f4\u3059\u308b\u5834\u5408\u3001\u30ad\u30fc\u6e9d\u3068\u8a8d\u8b58\u3055\u308c\u307e\u3059\u3002 \u6280\u8853\u60c5\u5831\u2192\u300c\u30ad\u30fc\u6e9d\u306e\u8a8d\u8b58\u6761\u4ef6\u300d 1 [&hellip;]\" \/>\n<meta property=\"og:url\" content=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/tup_configuration\/18450\/\" \/>\n<meta property=\"og:site_name\" content=\"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\" \/>\n<meta property=\"article:published_time\" content=\"2023-06-05T01:00:24+00:00\" \/>\n<meta property=\"article:modified_time\" content=\"2026-08-06T08:51:29+00:00\" \/>\n<meta property=\"og:image\" content=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/05\/18450_01.png\" \/>\n<meta name=\"author\" content=\"\u7f8e\u7d00\" \/>\n<meta name=\"twitter:card\" content=\"summary_large_image\" \/>\n<script type=\"application\/ld+json\" class=\"yoast-schema-graph\">{\"@context\":\"https:\\\/\\\/schema.org\",\"@graph\":[{\"@type\":\"Article\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/operation_manual\\\/tup_configuration\\\/18450\\\/#article\",\"isPartOf\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/operation_manual\\\/tup_configuration\\\/18450\\\/\"},\"author\":{\"name\":\"\u7f8e\u7d00\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#\\\/schema\\\/person\\\/6ff70d9094b7fdc810efdfcc2fdb63c5\"},\"headline\":\"\u9577\u7a74\\\/\u30ad\u30fc\u6e9d\u60c5\u5831\u3092\u8a2d\u5b9a\u3059\u308b\",\"datePublished\":\"2023-06-05T01:00:24+00:00\",\"dateModified\":\"2026-08-06T08:51:29+00:00\",\"mainEntityOfPage\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/operation_manual\\\/tup_configuration\\\/18450\\\/\"},\"wordCount\":13,\"publisher\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#organization\"},\"image\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/operation_manual\\\/tup_configuration\\\/18450\\\/#primaryimage\"},\"thumbnailUrl\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2023\\\/05\\\/18450_01.png\",\"keywords\":[\"manual_tup\"],\"articleSection\":[\"\uff3bFA \u4e38\u7269\uff3d\u898b\u7a4d\u3082\u308a\u8a2d\u5b9a\"],\"inLanguage\":\"ja\"},{\"@type\":\"WebPage\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/operation_manual\\\/tup_configuration\\\/18450\\\/\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/operation_manual\\\/tup_configuration\\\/18450\\\/\",\"name\":\"\u9577\u7a74\\\/\u30ad\u30fc\u6e9d\u60c5\u5831\u3092\u8a2d\u5b9a\u3059\u308b | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\",\"isPartOf\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#website\"},\"primaryImageOfPage\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/operation_manual\\\/tup_configuration\\\/18450\\\/#primaryimage\"},\"image\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/operation_manual\\\/tup_configuration\\\/18450\\\/#primaryimage\"},\"thumbnailUrl\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2023\\\/05\\\/18450_01.png\",\"datePublished\":\"2023-06-05T01:00:24+00:00\",\"dateModified\":\"2026-08-06T08:51:29+00:00\",\"breadcrumb\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/operation_manual\\\/tup_configuration\\\/18450\\\/#breadcrumb\"},\"inLanguage\":\"ja\",\"potentialAction\":[{\"@type\":\"ReadAction\",\"target\":[\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/operation_manual\\\/tup_configuration\\\/18450\\\/\"]}]},{\"@type\":\"ImageObject\",\"inLanguage\":\"ja\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/operation_manual\\\/tup_configuration\\\/18450\\\/#primaryimage\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2023\\\/05\\\/18450_01.png\",\"contentUrl\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2023\\\/05\\\/18450_01.png\",\"width\":1600,\"height\":900,\"caption\":\"\u5916\u5f84\u30ad\u30fc\u6e9d\u60c5\u5831\u3092\u5909\u66f4\u3059\u308b\"},{\"@type\":\"BreadcrumbList\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/operation_manual\\\/tup_configuration\\\/18450\\\/#breadcrumb\",\"itemListElement\":[{\"@type\":\"ListItem\",\"position\":1,\"name\":\"\u30db\u30fc\u30e0\",\"item\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/\"},{\"@type\":\"ListItem\",\"position\":2,\"name\":\"\u9577\u7a74\\\/\u30ad\u30fc\u6e9d\u60c5\u5831\u3092\u8a2d\u5b9a\u3059\u308b\"}]},{\"@type\":\"WebSite\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#website\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/\",\"name\":\"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\",\"description\":\"\",\"publisher\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#organization\"},\"potentialAction\":[{\"@type\":\"SearchAction\",\"target\":{\"@type\":\"EntryPoint\",\"urlTemplate\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/?s={search_term_string}\"},\"query-input\":{\"@type\":\"PropertyValueSpecification\",\"valueRequired\":true,\"valueName\":\"search_term_string\"}}],\"inLanguage\":\"ja\"},{\"@type\":\"Organization\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#organization\",\"name\":\"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/\",\"logo\":{\"@type\":\"ImageObject\",\"inLanguage\":\"ja\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#\\\/schema\\\/logo\\\/image\\\/\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2019\\\/05\\\/A01-b_b4-1_jpeg.jpg\",\"contentUrl\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2019\\\/05\\\/A01-b_b4-1_jpeg.jpg\",\"width\":260,\"height\":70,\"caption\":\"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df\"},\"image\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#\\\/schema\\\/logo\\\/image\\\/\"}},{\"@type\":\"Person\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#\\\/schema\\\/person\\\/6ff70d9094b7fdc810efdfcc2fdb63c5\",\"name\":\"\u7f8e\u7d00\",\"image\":{\"@type\":\"ImageObject\",\"inLanguage\":\"ja\",\"@id\":\"https:\\\/\\\/secure.gravatar.com\\\/avatar\\\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g\",\"url\":\"https:\\\/\\\/secure.gravatar.com\\\/avatar\\\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g\",\"contentUrl\":\"https:\\\/\\\/secure.gravatar.com\\\/avatar\\\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g\",\"caption\":\"\u7f8e\u7d00\"},\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/author\\\/miki-aa3x-momosemisumi-co-jp\\\/\"}]}<\/script>\n<!-- \/ Yoast SEO plugin. -->","yoast_head_json":{"title":"\u9577\u7a74\/\u30ad\u30fc\u6e9d\u60c5\u5831\u3092\u8a2d\u5b9a\u3059\u308b | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","robots":{"index":"index","follow":"follow","max-snippet":"max-snippet:-1","max-image-preview":"max-image-preview:large","max-video-preview":"max-video-preview:-1"},"canonical":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/tup_configuration\/18450\/","og_locale":"ja_JP","og_type":"article","og_title":"\u9577\u7a74\/\u30ad\u30fc\u6e9d\u60c5\u5831\u3092\u8a2d\u5b9a\u3059\u308b | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","og_description":"\u5916\u5f84\u30ad\u30fc\u6e9d\u60c5\u5831\u3092\u5909\u66f4\u3059\u308b\u200b \u9577\u7a74\u60c5\u5831\u3092\u5909\u66f4\u3059\u308b\u200b \u5185\u5f84\u30ad\u30fc\u6e9d\u60c5\u5831\u3092\u5909\u66f4\u3059\u308b\u200b \u5916\u5f84\u30ad\u30fc\u6e9d\u60c5\u5831\u3092\u5909\u66f4\u3059\u308b \u6e9d\u5e45\u304cJIS\u898f\u683c(B 1301\uff1a1996)\u3068\u4e00\u81f4\u3059\u308b\u5834\u5408\u3001\u30ad\u30fc\u6e9d\u3068\u8a8d\u8b58\u3055\u308c\u307e\u3059\u3002 \u6280\u8853\u60c5\u5831\u2192\u300c\u30ad\u30fc\u6e9d\u306e\u8a8d\u8b58\u6761\u4ef6\u300d 1 [&hellip;]","og_url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/tup_configuration\/18450\/","og_site_name":"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","article_published_time":"2023-06-05T01:00:24+00:00","article_modified_time":"2026-08-06T08:51:29+00:00","og_image":[{"url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/05\/18450_01.png","type":"","width":"","height":""}],"author":"\u7f8e\u7d00","twitter_card":"summary_large_image","schema":{"@context":"https:\/\/schema.org","@graph":[{"@type":"Article","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/tup_configuration\/18450\/#article","isPartOf":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/tup_configuration\/18450\/"},"author":{"name":"\u7f8e\u7d00","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/person\/6ff70d9094b7fdc810efdfcc2fdb63c5"},"headline":"\u9577\u7a74\/\u30ad\u30fc\u6e9d\u60c5\u5831\u3092\u8a2d\u5b9a\u3059\u308b","datePublished":"2023-06-05T01:00:24+00:00","dateModified":"2026-08-06T08:51:29+00:00","mainEntityOfPage":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/tup_configuration\/18450\/"},"wordCount":13,"publisher":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#organization"},"image":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/tup_configuration\/18450\/#primaryimage"},"thumbnailUrl":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/05\/18450_01.png","keywords":["manual_tup"],"articleSection":["\uff3bFA \u4e38\u7269\uff3d\u898b\u7a4d\u3082\u308a\u8a2d\u5b9a"],"inLanguage":"ja"},{"@type":"WebPage","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/tup_configuration\/18450\/","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/tup_configuration\/18450\/","name":"\u9577\u7a74\/\u30ad\u30fc\u6e9d\u60c5\u5831\u3092\u8a2d\u5b9a\u3059\u308b | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","isPartOf":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#website"},"primaryImageOfPage":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/tup_configuration\/18450\/#primaryimage"},"image":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/tup_configuration\/18450\/#primaryimage"},"thumbnailUrl":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/05\/18450_01.png","datePublished":"2023-06-05T01:00:24+00:00","dateModified":"2026-08-06T08:51:29+00:00","breadcrumb":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/tup_configuration\/18450\/#breadcrumb"},"inLanguage":"ja","potentialAction":[{"@type":"ReadAction","target":["https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/tup_configuration\/18450\/"]}]},{"@type":"ImageObject","inLanguage":"ja","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/tup_configuration\/18450\/#primaryimage","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/05\/18450_01.png","contentUrl":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/05\/18450_01.png","width":1600,"height":900,"caption":"\u5916\u5f84\u30ad\u30fc\u6e9d\u60c5\u5831\u3092\u5909\u66f4\u3059\u308b"},{"@type":"BreadcrumbList","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/tup_configuration\/18450\/#breadcrumb","itemListElement":[{"@type":"ListItem","position":1,"name":"\u30db\u30fc\u30e0","item":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/"},{"@type":"ListItem","position":2,"name":"\u9577\u7a74\/\u30ad\u30fc\u6e9d\u60c5\u5831\u3092\u8a2d\u5b9a\u3059\u308b"}]},{"@type":"WebSite","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#website","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/","name":"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","description":"","publisher":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#organization"},"potentialAction":[{"@type":"SearchAction","target":{"@type":"EntryPoint","urlTemplate":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/?s={search_term_string}"},"query-input":{"@type":"PropertyValueSpecification","valueRequired":true,"valueName":"search_term_string"}}],"inLanguage":"ja"},{"@type":"Organization","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#organization","name":"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/","logo":{"@type":"ImageObject","inLanguage":"ja","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/logo\/image\/","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2019\/05\/A01-b_b4-1_jpeg.jpg","contentUrl":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2019\/05\/A01-b_b4-1_jpeg.jpg","width":260,"height":70,"caption":"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df"},"image":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/logo\/image\/"}},{"@type":"Person","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/person\/6ff70d9094b7fdc810efdfcc2fdb63c5","name":"\u7f8e\u7d00","image":{"@type":"ImageObject","inLanguage":"ja","@id":"https:\/\/secure.gravatar.com\/avatar\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g","url":"https:\/\/secure.gravatar.com\/avatar\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g","contentUrl":"https:\/\/secure.gravatar.com\/avatar\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g","caption":"\u7f8e\u7d00"},"url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/author\/miki-aa3x-momosemisumi-co-jp\/"}]}},"views":1930,"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts\/18450","targetHints":{"allow":["GET"]}}],"collection":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts"}],"about":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/types\/post"}],"author":[{"embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/users\/15"}],"replies":[{"embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/comments?post=18450"}],"version-history":[{"count":61,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts\/18450\/revisions"}],"predecessor-version":[{"id":37374,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts\/18450\/revisions\/37374"}],"wp:attachment":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/media?parent=18450"}],"wp:term":[{"taxonomy":"category","embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/categories?post=18450"},{"taxonomy":"post_tag","embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/tags?post=18450"}],"curies":[{"name":"wp","href":"https:\/\/api.w.org\/{rel}","templated":true}]}}
