{"id":2610,"date":"2025-05-12T00:00:54","date_gmt":"2025-05-11T15:00:54","guid":{"rendered":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/?p=2610"},"modified":"2026-08-07T15:34:19","modified_gmt":"2026-08-07T06:34:19","slug":"%e3%83%9f%e3%82%b9%e3%83%9fvona%e3%81%8b%e3%82%89%e6%b3%a8%e6%96%87%e3%81%99%e3%82%8b","status":"publish","type":"post","link":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/order\/2610\/","title":{"rendered":"meviy\u304b\u3089\u306e\u767a\u6ce8\u624b\u9806"},"content":{"rendered":"\t\t<div data-elementor-type=\"wp-post\" data-elementor-id=\"2610\" class=\"elementor elementor-2610\">\n\t\t\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-35bcf61 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"35bcf61\" data-element_type=\"section\" data-e-type=\"section\" id=\"fa\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-208fc12\" data-id=\"208fc12\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<section class=\"elementor-section elementor-inner-section elementor-element elementor-element-4b7c6db elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"4b7c6db\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-17b7e04\" data-id=\"17b7e04\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-65b19ea elementor-widget elementor-widget-text-editor\" data-id=\"65b19ea\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<ul>\n \t<li>\u30ab\u30fc\u30c8\u306b\u8ffd\u52a0\u3057\u305f\u30d1\u30fc\u30c4\u3092\u6ce8\u6587\u3059\u308b\u5834\u5408\u306f\u3001[MISUMI\u30ab\u30fc\u30c8\u3078\u9032\u3080]\u3092\u30af\u30ea\u30c3\u30af\u3057\u3066\u304f\u3060\u3055\u3044\u3002<\/li>\n \t<li>MISUMI\u30b5\u30a4\u30c8\u306e\u6ce8\u6587\u5165\u529b\u753b\u9762\u306b\u9077\u79fb\u3057\u3066\u6ce8\u6587\u3067\u304d\u307e\u3059\u3002<\/li>\n<\/ul>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-36c0a2d elementor-widget elementor-widget-text-editor\" data-id=\"36c0a2d\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<div class=\"txtBasic bg\">\n<p class=\"labelMemo\">memo<\/p>\n\n<ul>\n \t<li>\uff3b\u6982\u7b97\u898b\u7a4d\u66f8(PDF)\uff3d\u3001\uff3b\u90e8\u54c1\u4e00\u89a7(CSV)\uff3d\u3092\u30af\u30ea\u30c3\u30af\u3057\u3066\u3001\u6982\u7b97\u898b\u7a4d\u66f8(PDF\u30d5\u30a1\u30a4\u30eb)\u3084\u90e8\u54c1\u8868(CSV\u30d5\u30a1\u30a4\u30eb)\u3092\u30c0\u30a6\u30f3\u30ed\u30fc\u30c9\u3067\u304d\u307e\u3059\u3002<\/li>\n<\/ul>\n<\/div>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-39ace1a elementor-widget elementor-widget-text-editor\" data-id=\"39ace1a\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<div class=\"txtBasic bg\">\n<p class=\"labelNote\">\u6ce8\u610f<\/p>\n\u578b\u756a\u516c\u958b\u306b\u3088\u3063\u3066\u30d7\u30ed\u30b8\u30a7\u30af\u30c8\u3092\u516c\u958b\u3057\u305f\u5834\u5408\u3001\u62c5\u5f53\u8005\u4ee5\u5916\u306e\u30e6\u30fc\u30b6\u30fc\u30823D\u30d3\u30e5\u30fc\u30ef\u30fc\u753b\u9762\uff08\u95b2\u89a7\u30e2\u30fc\u30c9\uff09\u3067\u90e8\u54c1\u306e\u5f62\u72b6\u3084\u6750\u8cea\u306e\u78ba\u8a8d\u304c\u3067\u304d\u307e\u3059\u3002\u753b\u9762\u5de6\u4e0b\u304b\u3089\u578b\u756a\u3092\u30b3\u30d4\u30fc\u3057\u3066\u3044\u305f\u3060\u304d\u3001\u6a19\u6e96\u90e8\u54c1\u540c\u69d8\u306bMISUMI\u30b5\u30a4\u30c8\u304b\u3089\u3054\u767a\u6ce8\u304c\u53ef\u80fd\u3067\u3059\u3002\n\n<img decoding=\"async\" src=\"\/help\/ja\/wp-content\/uploads\/2026\/03\/2610_03.png\" \/>\n<div>\u64cd\u4f5c\u30de\u30cb\u30e5\u30a2\u30eb\uff1e\u4fbf\u5229\u306a\u6a5f\u80fd\uff1e<a href=\"\/help\/ja\/operation_manual\/project_sharing\/2754\/\">\u767a\u884c\u578b\u756a\u3092\u516c\u958b\u3059\u308b\/\u30d7\u30ed\u30b8\u30a7\u30af\u30c8\u3092\u516c\u958b\u3059\u308b<\/a><\/div>\n<div>\u64cd\u4f5c\u30de\u30cb\u30e5\u30a2\u30eb\uff1e\u6ce8\u6587\u3059\u308b\uff1e<a href=\"\/help\/ja\/operation_manual\/order\/9326\/\">MISUMI\u30b5\u30a4\u30c8\u304b\u3089\u306e\u767a\u6ce8\u624b\u9806<\/a><\/div>\n<\/div>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-79b0cd5\" data-id=\"79b0cd5\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-7773890 enlarged elementor-widget elementor-widget-image\" data-id=\"7773890\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img fetchpriority=\"high\" decoding=\"async\" width=\"1600\" height=\"900\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/2610_01_D.png\" class=\"attachment-full size-full wp-image-32708\" alt=\"\" srcset=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/2610_01_D.png 1600w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/2610_01_D-300x169.png 300w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/2610_01_D-1024x576.png 1024w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/2610_01_D-768x432.png 768w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/2610_01_D-1536x864.png 1536w\" sizes=\"(max-width: 1600px) 100vw, 1600px\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<\/div>\n\t\t\n\t\t\t<div id=\"daexthefu-container\"\n\t\t\t\tclass=\"daexthefu-container daexthefu-layout-stacked daexthefu-alignment-left\"\n\t\t\t\tdata-post-id=\"2610\">\n\n\t\t\t\t<div class=\"daexthefu-feedback\">\n\t\t\t\t\t<div class=\"daexthefu-text\">\n\t\t\t\t\t\t<h3 class=\"daexthefu-title\">\u3053\u306e\u8a18\u4e8b\u306f\u53c2\u8003\u306b\u306a\u308a\u307e\u3057\u305f\u304b\uff1f<\/h3>\n\t\t\t\t\t<\/div>\n\t\t\t\t\t<div class=\"daexthefu-buttons-container\">\n\t\t\t\t\t\t<div class=\"daexthefu-buttons\">\n\t\t\t\t\t\t\t\n\t\t\t<div class=\"daexthefu-yes daexthefu-button daexthefu-button-type-icon-and-text\" data-value=\"1\">\n\t\t\t\t<div class=\"daexthefu-button-icon\">\n\t\t\t\t\n                <svg>\n                    <defs>\n                        <style>.thumb-up-cls-1{fill:#c9c9c9;}.thumb-up-cls-2{fill:#e1e1e1;}.thumb-up-cls-3{fill:#676767;}<\/style>\n                    <\/defs>\n                    <g id=\"thumb_up\">\n                        <path class=\"thumb-up-cls-2 daexthefu-icon-circle\" d=\"m24,3c11.58,0,21,9.42,21,21s-9.42,21-21,21S3,35.58,3,24,12.42,3,24,3m0-1C11.85,2,2,11.85,2,24s9.85,22,22,22,22-9.85,22-22S36.15,2,24,2h0Z\" \/>\n                        <g>\n                            <rect class=\"thumb-up-cls-3 daexthefu-icon-secondary-color\" x=\"10\" y=\"20\" width=\"6\" height=\"15\" rx=\"1.5\" ry=\"1.5\" \/>\n                            <path class=\"thumb-up-cls-1 daexthefu-icon-primary-color\" d=\"m30.57,9.06l-.49-.1c-.81-.17-1.61.35-1.78,1.16l-5.3,11.74c-.17.81,3.16,1.61,3.97,1.78l1.96.41c.81.17,1.61-.35,1.78-1.16l2.18-10.27c.34-1.61-.7-3.21-2.31-3.56Z\" \/>\n                            <path class=\"thumb-up-cls-1 daexthefu-icon-primary-color\" d=\"m38.17,20h-18.67c-.83,0-1.5.67-1.5,1.5v12c0,.83.67,1.5,1.5,1.5h16.27c.71,0,1.33-.5,1.47-1.21l2.4-12c.19-.93-.53-1.8-1.47-1.8Z\" \/>\n                        <\/g>\n                    <\/g>\n                <\/svg>\t\t\t\t\t\t<\/div>\n\t\t\t\t<div class=\"daexthefu-button-text\">\u5f79\u306b\u7acb\u3063\u305f\uff01<\/div>\n\t\t\t<\/div>\n\n\t\t\t\t\t\t\t\t\t\t\n\t\t\t<div class=\"daexthefu-no daexthefu-button daexthefu-button-type-icon-and-text\" data-value=\"0\">\n\t\t\t\t<div class=\"daexthefu-button-icon\">\n\t\t\t\t\n                <svg>\n                    <defs>\n                        <style>.thumb-down-cls-1{fill:#c9c9c9;}.thumb-down-cls-2{fill:#e1e1e1;}.thumb-down-cls-3{fill:#676767;}<\/style>\n                    <\/defs>\n                    <g id=\"thumb_down\">\n                        <path class=\"thumb-down-cls-2 daexthefu-icon-circle\" d=\"m24,3c11.58,0,21,9.42,21,21s-9.42,21-21,21S3,35.58,3,24,12.42,3,24,3m0-1C11.85,2,2,11.85,2,24s9.85,22,22,22,22-9.85,22-22S36.15,2,24,2h0Z\" \/>\n                        <g>\n                            <rect class=\"thumb-down-cls-3 daexthefu-icon-secondary-color\" x=\"10\" y=\"13\" width=\"6\" height=\"15\" rx=\"1.5\" ry=\"1.5\" \/>\n                            <path class=\"thumb-down-cls-1 daexthefu-icon-primary-color\" d=\"m30.57,38.94l-.49.1c-.81.17-1.61-.35-1.78-1.16l-5.3-11.74c-.17-.81,3.16-1.61,3.97-1.78l1.96-.41c.81-.17,1.61.35,1.78,1.16l2.18,10.27c.34,1.61-.7,3.21-2.31,3.56Z\" \/>\n                            <path class=\"thumb-down-cls-1 daexthefu-icon-primary-color\" d=\"m38.17,28h-18.67c-.83,0-1.5-.67-1.5-1.5v-12c0-.83.67-1.5,1.5-1.5h16.27c.71,0,1.33.5,1.47,1.21l2.4,12c.19.93-.53,1.8-1.47,1.8Z\" \/>\n                        <\/g>\n                    <\/g>\n                <\/svg>\t\t\t\t\t\t<\/div>\n\t\t\t\t<div class=\"daexthefu-button-text\">\u5f79\u306b\u7acb\u305f\u306a\u304b\u3063\u305f<\/div>\n\t\t\t<\/div>\n\n\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\n\t\t\t\t<div class=\"daexthefu-comment\">\n\t\t\t\t\t<div class=\"daexthefu-comment-top-container\">\n\t\t\t\t\t\t<label id=\"daexthefu-comment-label\" class=\"daexthefu-comment-label\"><\/label>\n\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t\t<textarea id=\"daexthefu-comment-textarea\" class=\"daexthefu-comment-textarea\"\n\t\t\t\t\t\t\t\tplaceholder=\"\"\n\t\t\t\t\t\t\t\tmaxlength=\"\n\t\t\t\t\t\t\t\t400\t\t\t\t\t\t\t\t\t\"><\/textarea>\n\t\t\t\t\t<div class=\"daexthefu-comment-buttons-container\">\n\t\t\t\t\t\t<button class=\"daexthefu-comment-submit daexthefu-button\">\u9001\u4fe1<\/button>\n\t\t\t\t\t\t<button class=\"daexthefu-comment-cancel daexthefu-button\">\u53d6\u6d88<\/button>\n\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\n\t\t\t\t<div class=\"daexthefu-successful-submission-text\">\u8a55\u4fa1\u3044\u305f\u3060\u304d\u3042\u308a\u304c\u3068\u3046\u3054\u3056\u3044\u307e\u3057\u305f\u3002<\/div>\n\n\t\t\t<\/div>\n\n\t\t\t","protected":false},"excerpt":{"rendered":"<p>\u30ab\u30fc\u30c8\u306b\u8ffd\u52a0\u3057\u305f\u30d1\u30fc\u30c4\u3092\u6ce8\u6587\u3059\u308b\u5834\u5408\u306f\u3001[MISUMI\u30ab\u30fc\u30c8\u3078\u9032\u3080]\u3092\u30af\u30ea\u30c3\u30af\u3057\u3066\u304f\u3060\u3055\u3044\u3002 MISUMI\u30b5\u30a4\u30c8\u306e\u6ce8\u6587\u5165\u529b\u753b\u9762\u306b\u9077\u79fb\u3057\u3066\u6ce8\u6587\u3067\u304d\u307e\u3059\u3002 memo \uff3b\u6982\u7b97\u898b\u7a4d\u66f8(PDF)\uff3d\u3001\uff3b\u90e8\u54c1\u4e00\u89a7(CSV)\uff3d\u3092\u30af\u30ea\u30c3\u30af [&hellip;]<\/p>\n","protected":false},"author":17,"featured_media":0,"comment_status":"closed","ping_status":"closed","sticky":false,"template":"","format":"standard","meta":{"_helpful_status":1,"footnotes":""},"categories":[6],"tags":[],"class_list":["post-2610","post","type-post","status-publish","format-standard","hentry","category-order"],"yoast_head":"<!-- This site is optimized with the Yoast SEO plugin v28.0 - https:\/\/yoast.com\/product\/yoast-seo-wordpress\/ -->\n<title>meviy\u304b\u3089\u306e\u767a\u6ce8\u624b\u9806 | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb<\/title>\n<meta name=\"robots\" content=\"index, follow, max-snippet:-1, max-image-preview:large, max-video-preview:-1\" \/>\n<link rel=\"canonical\" href=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/order\/2610\/\" \/>\n<meta property=\"og:locale\" content=\"ja_JP\" \/>\n<meta property=\"og:type\" content=\"article\" \/>\n<meta property=\"og:title\" content=\"meviy\u304b\u3089\u306e\u767a\u6ce8\u624b\u9806 | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\" \/>\n<meta property=\"og:description\" content=\"\u30ab\u30fc\u30c8\u306b\u8ffd\u52a0\u3057\u305f\u30d1\u30fc\u30c4\u3092\u6ce8\u6587\u3059\u308b\u5834\u5408\u306f\u3001[MISUMI\u30ab\u30fc\u30c8\u3078\u9032\u3080]\u3092\u30af\u30ea\u30c3\u30af\u3057\u3066\u304f\u3060\u3055\u3044\u3002 MISUMI\u30b5\u30a4\u30c8\u306e\u6ce8\u6587\u5165\u529b\u753b\u9762\u306b\u9077\u79fb\u3057\u3066\u6ce8\u6587\u3067\u304d\u307e\u3059\u3002 memo \uff3b\u6982\u7b97\u898b\u7a4d\u66f8(PDF)\uff3d\u3001\uff3b\u90e8\u54c1\u4e00\u89a7(CSV)\uff3d\u3092\u30af\u30ea\u30c3\u30af [&hellip;]\" \/>\n<meta property=\"og:url\" content=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/order\/2610\/\" \/>\n<meta property=\"og:site_name\" content=\"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\" \/>\n<meta property=\"article:published_time\" content=\"2025-05-11T15:00:54+00:00\" \/>\n<meta property=\"article:modified_time\" content=\"2026-08-07T06:34:19+00:00\" \/>\n<meta property=\"og:image\" content=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/2610_01_D.png\" \/>\n<meta name=\"author\" content=\"\u9ad8\u7530\u6b69\u7f8e\" \/>\n<meta name=\"twitter:card\" content=\"summary_large_image\" \/>\n<script type=\"application\/ld+json\" class=\"yoast-schema-graph\">{\"@context\":\"https:\\\/\\\/schema.org\",\"@graph\":[{\"@type\":\"Article\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/operation_manual\\\/order\\\/2610\\\/#article\",\"isPartOf\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/operation_manual\\\/order\\\/2610\\\/\"},\"author\":{\"name\":\"\u9ad8\u7530\u6b69\u7f8e\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#\\\/schema\\\/person\\\/ef477ef06cfb62900ed6e75fbafd4108\"},\"headline\":\"meviy\u304b\u3089\u306e\u767a\u6ce8\u624b\u9806\",\"datePublished\":\"2025-05-11T15:00:54+00:00\",\"dateModified\":\"2026-08-07T06:34:19+00:00\",\"mainEntityOfPage\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/operation_manual\\\/order\\\/2610\\\/\"},\"wordCount\":11,\"publisher\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#organization\"},\"image\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/operation_manual\\\/order\\\/2610\\\/#primaryimage\"},\"thumbnailUrl\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2020\\\/01\\\/2610_01_D.png\",\"articleSection\":[\"\u6ce8\u6587\u3059\u308b\"],\"inLanguage\":\"ja\"},{\"@type\":\"WebPage\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/operation_manual\\\/order\\\/2610\\\/\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/operation_manual\\\/order\\\/2610\\\/\",\"name\":\"meviy\u304b\u3089\u306e\u767a\u6ce8\u624b\u9806 | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\",\"isPartOf\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#website\"},\"primaryImageOfPage\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/operation_manual\\\/order\\\/2610\\\/#primaryimage\"},\"image\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/operation_manual\\\/order\\\/2610\\\/#primaryimage\"},\"thumbnailUrl\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2020\\\/01\\\/2610_01_D.png\",\"datePublished\":\"2025-05-11T15:00:54+00:00\",\"dateModified\":\"2026-08-07T06:34:19+00:00\",\"breadcrumb\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/operation_manual\\\/order\\\/2610\\\/#breadcrumb\"},\"inLanguage\":\"ja\",\"potentialAction\":[{\"@type\":\"ReadAction\",\"target\":[\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/operation_manual\\\/order\\\/2610\\\/\"]}]},{\"@type\":\"ImageObject\",\"inLanguage\":\"ja\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/operation_manual\\\/order\\\/2610\\\/#primaryimage\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2020\\\/01\\\/2610_01_D.png\",\"contentUrl\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2020\\\/01\\\/2610_01_D.png\",\"width\":1600,\"height\":900},{\"@type\":\"BreadcrumbList\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/operation_manual\\\/order\\\/2610\\\/#breadcrumb\",\"itemListElement\":[{\"@type\":\"ListItem\",\"position\":1,\"name\":\"\u30db\u30fc\u30e0\",\"item\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/\"},{\"@type\":\"ListItem\",\"position\":2,\"name\":\"meviy\u304b\u3089\u306e\u767a\u6ce8\u624b\u9806\"}]},{\"@type\":\"WebSite\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#website\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/\",\"name\":\"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\",\"description\":\"\",\"publisher\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#organization\"},\"potentialAction\":[{\"@type\":\"SearchAction\",\"target\":{\"@type\":\"EntryPoint\",\"urlTemplate\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/?s={search_term_string}\"},\"query-input\":{\"@type\":\"PropertyValueSpecification\",\"valueRequired\":true,\"valueName\":\"search_term_string\"}}],\"inLanguage\":\"ja\"},{\"@type\":\"Organization\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#organization\",\"name\":\"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/\",\"logo\":{\"@type\":\"ImageObject\",\"inLanguage\":\"ja\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#\\\/schema\\\/logo\\\/image\\\/\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2019\\\/05\\\/A01-b_b4-1_jpeg.jpg\",\"contentUrl\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2019\\\/05\\\/A01-b_b4-1_jpeg.jpg\",\"width\":260,\"height\":70,\"caption\":\"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df\"},\"image\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#\\\/schema\\\/logo\\\/image\\\/\"}},{\"@type\":\"Person\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#\\\/schema\\\/person\\\/ef477ef06cfb62900ed6e75fbafd4108\",\"name\":\"\u9ad8\u7530\u6b69\u7f8e\",\"image\":{\"@type\":\"ImageObject\",\"inLanguage\":\"ja\",\"@id\":\"https:\\\/\\\/secure.gravatar.com\\\/avatar\\\/65ca753e63e5d4c85f69cabf8a6fd3c10b715f1572416e45c72159dc6913980a?s=96&d=mm&r=g\",\"url\":\"https:\\\/\\\/secure.gravatar.com\\\/avatar\\\/65ca753e63e5d4c85f69cabf8a6fd3c10b715f1572416e45c72159dc6913980a?s=96&d=mm&r=g\",\"contentUrl\":\"https:\\\/\\\/secure.gravatar.com\\\/avatar\\\/65ca753e63e5d4c85f69cabf8a6fd3c10b715f1572416e45c72159dc6913980a?s=96&d=mm&r=g\",\"caption\":\"\u9ad8\u7530\u6b69\u7f8e\"},\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/author\\\/a-takadacrestec-co-jp\\\/\"}]}<\/script>\n<!-- \/ Yoast SEO plugin. -->","yoast_head_json":{"title":"meviy\u304b\u3089\u306e\u767a\u6ce8\u624b\u9806 | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","robots":{"index":"index","follow":"follow","max-snippet":"max-snippet:-1","max-image-preview":"max-image-preview:large","max-video-preview":"max-video-preview:-1"},"canonical":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/order\/2610\/","og_locale":"ja_JP","og_type":"article","og_title":"meviy\u304b\u3089\u306e\u767a\u6ce8\u624b\u9806 | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","og_description":"\u30ab\u30fc\u30c8\u306b\u8ffd\u52a0\u3057\u305f\u30d1\u30fc\u30c4\u3092\u6ce8\u6587\u3059\u308b\u5834\u5408\u306f\u3001[MISUMI\u30ab\u30fc\u30c8\u3078\u9032\u3080]\u3092\u30af\u30ea\u30c3\u30af\u3057\u3066\u304f\u3060\u3055\u3044\u3002 MISUMI\u30b5\u30a4\u30c8\u306e\u6ce8\u6587\u5165\u529b\u753b\u9762\u306b\u9077\u79fb\u3057\u3066\u6ce8\u6587\u3067\u304d\u307e\u3059\u3002 memo \uff3b\u6982\u7b97\u898b\u7a4d\u66f8(PDF)\uff3d\u3001\uff3b\u90e8\u54c1\u4e00\u89a7(CSV)\uff3d\u3092\u30af\u30ea\u30c3\u30af [&hellip;]","og_url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/order\/2610\/","og_site_name":"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","article_published_time":"2025-05-11T15:00:54+00:00","article_modified_time":"2026-08-07T06:34:19+00:00","og_image":[{"url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/2610_01_D.png","type":"","width":"","height":""}],"author":"\u9ad8\u7530\u6b69\u7f8e","twitter_card":"summary_large_image","schema":{"@context":"https:\/\/schema.org","@graph":[{"@type":"Article","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/order\/2610\/#article","isPartOf":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/order\/2610\/"},"author":{"name":"\u9ad8\u7530\u6b69\u7f8e","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/person\/ef477ef06cfb62900ed6e75fbafd4108"},"headline":"meviy\u304b\u3089\u306e\u767a\u6ce8\u624b\u9806","datePublished":"2025-05-11T15:00:54+00:00","dateModified":"2026-08-07T06:34:19+00:00","mainEntityOfPage":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/order\/2610\/"},"wordCount":11,"publisher":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#organization"},"image":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/order\/2610\/#primaryimage"},"thumbnailUrl":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/2610_01_D.png","articleSection":["\u6ce8\u6587\u3059\u308b"],"inLanguage":"ja"},{"@type":"WebPage","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/order\/2610\/","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/order\/2610\/","name":"meviy\u304b\u3089\u306e\u767a\u6ce8\u624b\u9806 | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","isPartOf":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#website"},"primaryImageOfPage":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/order\/2610\/#primaryimage"},"image":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/order\/2610\/#primaryimage"},"thumbnailUrl":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/2610_01_D.png","datePublished":"2025-05-11T15:00:54+00:00","dateModified":"2026-08-07T06:34:19+00:00","breadcrumb":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/order\/2610\/#breadcrumb"},"inLanguage":"ja","potentialAction":[{"@type":"ReadAction","target":["https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/order\/2610\/"]}]},{"@type":"ImageObject","inLanguage":"ja","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/order\/2610\/#primaryimage","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/2610_01_D.png","contentUrl":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/2610_01_D.png","width":1600,"height":900},{"@type":"BreadcrumbList","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/operation_manual\/order\/2610\/#breadcrumb","itemListElement":[{"@type":"ListItem","position":1,"name":"\u30db\u30fc\u30e0","item":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/"},{"@type":"ListItem","position":2,"name":"meviy\u304b\u3089\u306e\u767a\u6ce8\u624b\u9806"}]},{"@type":"WebSite","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#website","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/","name":"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","description":"","publisher":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#organization"},"potentialAction":[{"@type":"SearchAction","target":{"@type":"EntryPoint","urlTemplate":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/?s={search_term_string}"},"query-input":{"@type":"PropertyValueSpecification","valueRequired":true,"valueName":"search_term_string"}}],"inLanguage":"ja"},{"@type":"Organization","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#organization","name":"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/","logo":{"@type":"ImageObject","inLanguage":"ja","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/logo\/image\/","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2019\/05\/A01-b_b4-1_jpeg.jpg","contentUrl":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2019\/05\/A01-b_b4-1_jpeg.jpg","width":260,"height":70,"caption":"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df"},"image":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/logo\/image\/"}},{"@type":"Person","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/person\/ef477ef06cfb62900ed6e75fbafd4108","name":"\u9ad8\u7530\u6b69\u7f8e","image":{"@type":"ImageObject","inLanguage":"ja","@id":"https:\/\/secure.gravatar.com\/avatar\/65ca753e63e5d4c85f69cabf8a6fd3c10b715f1572416e45c72159dc6913980a?s=96&d=mm&r=g","url":"https:\/\/secure.gravatar.com\/avatar\/65ca753e63e5d4c85f69cabf8a6fd3c10b715f1572416e45c72159dc6913980a?s=96&d=mm&r=g","contentUrl":"https:\/\/secure.gravatar.com\/avatar\/65ca753e63e5d4c85f69cabf8a6fd3c10b715f1572416e45c72159dc6913980a?s=96&d=mm&r=g","caption":"\u9ad8\u7530\u6b69\u7f8e"},"url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/author\/a-takadacrestec-co-jp\/"}]}},"views":15390,"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts\/2610","targetHints":{"allow":["GET"]}}],"collection":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts"}],"about":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/types\/post"}],"author":[{"embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/users\/17"}],"replies":[{"embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/comments?post=2610"}],"version-history":[{"count":114,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts\/2610\/revisions"}],"predecessor-version":[{"id":37604,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts\/2610\/revisions\/37604"}],"wp:attachment":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/media?parent=2610"}],"wp:term":[{"taxonomy":"category","embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/categories?post=2610"},{"taxonomy":"post_tag","embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/tags?post=2610"}],"curies":[{"name":"wp","href":"https:\/\/api.w.org\/{rel}","templated":true}]}}
