{"id":30940,"date":"2025-10-20T00:00:38","date_gmt":"2025-10-19T15:00:38","guid":{"rendered":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/?p=30940"},"modified":"2026-10-05T10:30:01","modified_gmt":"2026-10-05T01:30:01","slug":"%e3%82%af%e3%83%aa%e3%83%bc%e3%83%b3%e6%b4%97%e6%b5%84%e3%81%ab%e3%81%a4%e3%81%84%e3%81%a6","status":"publish","type":"post","link":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/30940\/","title":{"rendered":"\u30af\u30ea\u30fc\u30f3\u6d17\u6d44\u306e\u5bfe\u8c61\u7bc4\u56f2"},"content":{"rendered":"\t\t<div data-elementor-type=\"wp-post\" data-elementor-id=\"30940\" class=\"elementor elementor-30940\">\n\t\t\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-d540ba1 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"d540ba1\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-c869db3\" data-id=\"c869db3\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-491bb52 elementor-widget elementor-widget-text-editor\" data-id=\"491bb52\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<ul><li>\u30af\u30ea\u30fc\u30f3\u6d17\u6d44\u3067\u306f3\u7a2e\u985e\u306e\u6d17\u6d44\u65b9\u6cd5\u306b\u5bfe\u5fdc\u3057\u3066\u304a\u308a\u307e\u3059\u3002<\/li><li>\u5404\u6d17\u6d44\u65b9\u6cd5\u306e\u8a73\u7d30\u306b\u3064\u304d\u307e\u3057\u3066\u306f\u300c<a href=\"\/help\/ja\/technical_info\/shm_conditions\/30943\/\">\u30af\u30ea\u30fc\u30f3\u6d17\u6d44\u306b\u3064\u3044\u3066<\/a>\u300d\u3092\u3054\u78ba\u8a8d\u304f\u3060\u3055\u3044\u3002<\/li><\/ul>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-1b7c1ab5 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"1b7c1ab5\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-43917ede\" data-id=\"43917ede\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-27de63d8 elementor-widget elementor-widget-heading\" data-id=\"27de63d8\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h2 class=\"elementor-heading-title elementor-size-default\">\u30af\u30ea\u30fc\u30f3\u6d17\u6d44\u306e\u5bfe\u8c61\u88fd\u54c1\u30b5\u30a4\u30ba\u30fb\u91cd\u91cf\n<\/h2>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-2e5098df elementor-widget elementor-widget-text-editor\" data-id=\"2e5098df\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<ul><li>\u6d17\u6d44\u65b9\u6cd5\u306b\u3088\u308a\u5bfe\u5fdc\u53ef\u80fd\u306a\u88fd\u54c1\u30b5\u30a4\u30ba\u3001\u88fd\u54c1\u91cd\u91cf\u306b\u5236\u9650\u304c\u3054\u3056\u3044\u307e\u3059\u3002<\/li><li>\u5404\u6750\u8cea\u306e\u88fd\u4f5c\u53ef\u80fd\u30b5\u30a4\u30ba\u306b\u3064\u304d\u307e\u3057\u3066\u306f\u300c<a href=\"\/help\/ja\/technical_info\/shm_shape-material\/3646\/\">\u6750\u8cea\u30fb\u8868\u9762\u51e6\u7406\u30fb\u30b5\u30a4\u30ba<\/a>\u300d\u30da\u30fc\u30b8\u3092\u3054\u78ba\u8a8d\u304f\u3060\u3055\u3044\u3002<\/li><\/ul>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-0b7bea1 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"0b7bea1\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"mT0 tableHover_single\" style=\"width: 100%;\">\n<tbody>\n<tr>\n<th>\u6d17\u6d44\u65b9\u6cd5<\/th>\n<th>\u8131\u8102\u6d17\u6d44<\/th>\n<th>\u7cbe\u5bc6\u6d17\u6d44<\/th>\n<th>\u96fb\u89e3\u7814\u78e8\uff0b\u7cbe\u5bc6\u6d17\u6d44<\/th>\n<\/tr>\n<tr>\n<th>\u88fd\u54c11\u500b\u3042\u305f\u308a\u306e\u30b5\u30a4\u30ba\u4e0a\u9650<\/th>\n<td>1\u8fba\u6700\u5927 1,500mm<\/td>\n<td>1\u8fba\u6700\u5927 1,500mm<\/td>\n<td>1\u8fba\u6700\u5927 1,500mm<\/td>\n<\/tr>\n<tr>\n<th>\u88fd\u54c11\u500b\u5f53\u305f\u308a\u306e\u91cd\u91cf\u4e0a\u9650<\/th>\n<td>40kg<\/td>\n<td>60kg<\/td>\n<td>60kg<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-14aaac1 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"14aaac1\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-5ea71f9\" data-id=\"5ea71f9\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-4cb9220 elementor-widget elementor-widget-heading\" data-id=\"4cb9220\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h2 class=\"elementor-heading-title elementor-size-default\">\u30af\u30ea\u30fc\u30f3\u6d17\u6d44\u306e\u5bfe\u8c61\u6750\u8cea\u30fb\u8868\u9762\u51e6\u7406\n<\/h2>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-9f6cbf1 elementor-widget elementor-widget-text-editor\" data-id=\"9f6cbf1\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<ul><li>\u5404\u6d17\u6d44\u65b9\u6cd5\u3067\u5bfe\u5fdc\u53ef\u80fd\u306a\u6750\u8cea\u30fb\u8868\u9762\u51e6\u7406\u306f\u4ee5\u4e0b\u306e\u901a\u308a\u3067\u3059\u3002\u677f\u539a\u306b\u3088\u308b\u5236\u9650\u306f\u3054\u3056\u3044\u307e\u305b\u3093\u3002<\/li><li>\u3000\u3007\uff1a \u81ea\u52d5\u898b\u7a4d\u3082\u308a\u53ef\u3001\u62c5\u5f53\u8005\u898b\u7a4d\u3082\u308a\u53ef<\/li><li>\u3000\u30fc\uff1a \u81ea\u52d5\u898b\u7a4d\u3082\u308a\u4e0d\u53ef\u3001\u62c5\u5f53\u8005\u898b\u7a4d\u3082\u308a\u4e0d\u53ef<\/li><\/ul>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-9dbeea9 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"9dbeea9\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"mT0 tableHover\" style=\"width: 100%;\"><tbody><tr><th style=\"width: 25%;\" rowspan=\"2\">\u6750\u8cea\uff1a\u9244\u7cfb<\/th><th style=\"width: 25%;\" rowspan=\"2\">\u8868\u9762\u51e6\u7406<\/th><th colspan=\"3\">\u6d17\u6d44\u65b9\u6cd5<\/th><\/tr><tr><th>\u8131\u8102\u6d17\u6d44<\/th><th>\u7cbe\u5bc6\u6d17\u6d44<\/th><th>\u96fb\u89e3\u7814\u78e8\uff0b\u7cbe\u5bc6\u6d17\u6d44<\/th><\/tr><tr><th rowspan=\"7\">SPCC\/SPHC<\/th><th>\u30fc<\/th><td>\u30fc<\/td><td>\u30fc<\/td><td>\u30fc<\/td><\/tr><tr><th>\u7c89\u4f53\u5857\u88c5<\/th><td>\u3007<\/td><td>\u3007 \u203b1<\/td><td>\u30fc<\/td><\/tr><tr><th>\u6eb6\u5264\u5857\u88c5<\/th><td>\u3007<\/td><td>\u3007 \u203b1<\/td><td>\u30fc<\/td><\/tr><tr><th>\u7121\u96fb\u89e3\u30cb\u30c3\u30b1\u30eb\u30e1\u30c3\u30ad<\/th><td>\u3007<\/td><td>\u3007 \u203b1<\/td><td>\u30fc<\/td><\/tr><tr><th>\u56db\u4e09\u9178\u5316\u9244\u76ae\u819c<\/th><td>\u3007<\/td><td>\u3007 \u203b1<\/td><td>\u30fc<\/td><\/tr><tr><th>\u4e09\u4fa1\u30af\u30ed\u30e1\u30fc\u30c8(\u767d)<\/th><td>\u3007<\/td><td>\u3007 \u203b1<\/td><td>\u30fc<\/td><\/tr><tr><th>\u4e09\u4fa1\u30af\u30ed\u30e1\u30fc\u30c8(\u9ed2)<\/th><td>\u3007<\/td><td>\u3007 \u203b1<\/td><td>\u30fc<\/td><\/tr><tr><th rowspan=\"4\">SS400<\/th><th>\u30fc<\/th><td>\u3007<\/td><td>\u3007<\/td><td>\u30fc<\/td><\/tr><tr><th>\u7121\u96fb\u89e3\u30cb\u30c3\u30b1\u30eb\u30e1\u30c3\u30ad<\/th><td>\u3007<\/td><td>\u3007<\/td><td>\u30fc<\/td><\/tr><tr><th>\u56db\u4e09\u9178\u5316\u9244\u76ae\u819c<\/th><td>\u3007<\/td><td>\u3007<\/td><td>\u30fc<\/td><\/tr><tr><th>\u4e09\u4fa1\u30af\u30ed\u30e1\u30fc\u30c8(\u767d)<\/th><td>\u3007<\/td><td>\u3007<\/td><td>\u30fc<\/td><\/tr><tr><th>SECC(\u96fb\u6c17\u4e9c\u925b\u30e1\u30c3\u30ad\u92fc\u677f)<\/th><th>\u96fb\u6c17\u4e9c\u925b\u30e1\u30c3\u30ad<\/th><td>\u3007<\/td><td>\u30fc<\/td><td>\u30fc<\/td><\/tr><tr><th>SPCC(\u6eb6\u878d\u4e9c\u925b\u30e1\u30c3\u30ad\u92fc\u677f)<\/th><th>\u6eb6\u878d\u4e9c\u925b\u30e1\u30c3\u30ad<\/th><td>\u3007<\/td><td>\u30fc<\/td><td>\u30fc<\/td><\/tr><tr><th>SPCC(\u30b7\u30e0\u7528)<\/th><th>\u30fc<\/th><td>\u30fc<\/td><td>\u30fc<\/td><td>\u30fc<\/td><\/tr><\/tbody><\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-11dcb42 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"11dcb42\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"mT0 tableHover\" style=\"width: 100%;\"><tbody><tr><th style=\"width: 25%;\" rowspan=\"2\">\u6750\u8cea\uff1a\u30b9\u30c6\u30f3\u30ec\u30b9\u7cfb<\/th><th style=\"width: 25%;\" rowspan=\"2\">\u4ed5\u4e0a\u3052\u65b9\u6cd5<\/th><th colspan=\"3\">\u6d17\u6d44\u65b9\u6cd5<\/th><\/tr><tr><th>\u8131\u8102\u6d17\u6d44<\/th><th>\u7cbe\u5bc6\u6d17\u6d44<\/th><th>\u96fb\u89e3\u7814\u78e8\uff0b\u7cbe\u5bc6\u6d17\u6d44<\/th><\/tr><tr><th rowspan=\"5\">SUS304<\/th><th>No.1<\/th><td>\u3007<\/td><td>\u3007<\/td><td>\u3007<\/td><\/tr><tr><th>2B<\/th><td>\u3007<\/td><td>\u3007<\/td><td>\u3007<\/td><\/tr><tr><th>2B\u7247\u9762\u4fdd\u8b77\u30b7\u30fc\u30c8\u4ed8<\/th><td>\u30fc<\/td><td>\u30fc<\/td><td>\u30fc<\/td><\/tr><tr><th>\u7247\u9762#400\u7814\u78e8\uff08\u4f53\u88c1\u9762\u5074\uff09<\/th><td>\u3007<\/td><td>\u3007<\/td><td>\u3007<\/td><\/tr><tr><th>\u7247\u9762\u30d8\u30a2\u30e9\u30a4\u30f3(\u4f53\u88c1\u9762\u5074)<\/th><td>\u3007<\/td><td>\u3007<\/td><td>\u3007<\/td><\/tr><tr><th>SUS316<\/th><th>2B<\/th><td>\u3007<\/td><td>\u3007<\/td><td>\u3007<\/td><\/tr><tr><th>SUS316L<\/th><th>2B<\/th><td>\u30fc<\/td><td>\u30fc<\/td><td>\u30fc<\/td><\/tr><tr><th>SUS430<\/th><th>2B<\/th><td>\u3007<\/td><td>\u3007<\/td><td>\u3007<\/td><\/tr><tr><th>SUS304(H)(\u30b7\u30e0\u7528)<\/th><th>\u30fc<\/th><td>\u3007<\/td><td>\u3007<\/td><td>\u3007<\/td><\/tr><\/tbody><\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-991b7d1 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"991b7d1\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"mT0 tableHover\" style=\"width: 100%;\">\n<tbody>\n<tr>\n<th style=\"width: 25%;\" rowspan=\"2\">\u6750\u8cea\uff1a\u30a2\u30eb\u30df\u30cb\u30a6\u30e0<\/th>\n<th style=\"width: 25%;\" rowspan=\"2\">\u8868\u9762\u51e6\u7406<\/th>\n<th colspan=\"3\">\u6d17\u6d44\u65b9\u6cd5<\/th>\n<\/tr>\n<tr>\n<th>\u8131\u8102\u6d17\u6d44<\/th>\n<th>\u7cbe\u5bc6\u6d17\u6d44<\/th>\n<th>\u96fb\u89e3\u7814\u78e8\uff0b\u7cbe\u5bc6\u6d17\u6d44<\/th>\n<\/tr>\n<tr>\n<th rowspan=\"5\">A5052<\/th>\n<th>\u30fc<\/th>\n<td>\u3007<\/td>\n<td>\u3007<\/td>\n<td>\u3007 \u203b2<\/td>\n<\/tr>\n<tr>\n<th>\u30a2\u30eb\u30de\u30a4\u30c8\uff08\u767d\uff09<\/th>\n<td>\u3007<\/td>\n<td>\u3007<\/td>\n<td>\u30fc<\/td>\n<\/tr>\n<tr>\n<th>\u30a2\u30eb\u30de\u30a4\u30c8\uff08\u9ed2\uff09<\/th>\n<td>\u3007<\/td>\n<td>\u3007<\/td>\n<td>\u30fc<\/td>\n<\/tr>\n<tr>\n<th>\u30a2\u30eb\u30de\u30a4\u30c8\uff08\u3064\u3084\u6d88\u3057\u9ed2\uff09<\/th>\n<td>\u3007<\/td>\n<td>\u3007<\/td>\n<td>\u30fc<\/td>\n<\/tr>\n<tr>\n<th>\u30a2\u30ed\u30b8\u30f3\u51e6\u7406\u76f8\u5f53(\u4e09\u4fa1\u30af\u30ed\u30e0\u5316\u6210\u51e6\u7406)<\/th>\n<td>\u3007<\/td>\n<td>\u3007<\/td>\n<td>\u30fc<\/td>\n<\/tr>\n<tr>\n<th>A5052(\u30a2\u30eb\u30de\u30a4\u30c8\u92fc\u677f\u767d)<\/th>\n<th>\u30a2\u30eb\u30de\u30a4\u30c8(\u767d)<\/th>\n<td>\u3007<\/td>\n<td>\u3007<\/td>\n<td>\u30fc<\/td>\n<\/tr>\n<tr>\n<th>A5052(\u30a2\u30eb\u30de\u30a4\u30c8\u92fc\u677f\u9ed2)<\/th>\n<th>\u30a2\u30eb\u30de\u30a4\u30c8(\u9ed2)<\/th>\n<td>\u3007<\/td>\n<td>\u3007<\/td>\n<td>\u30fc<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-351f86e tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"351f86e\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"mT0 tableHover\" style=\"width: 100%;\"><tbody><tr><th style=\"width: 25%;\" rowspan=\"2\">\u6750\u8cea\uff1a\u9285\u7cfb<\/th><th style=\"width: 25%;\" rowspan=\"2\">\u8868\u9762\u51e6\u7406<\/th><th colspan=\"3\">\u6d17\u6d44\u65b9\u6cd5<\/th><\/tr><tr><th>\u8131\u8102\u6d17\u6d44<\/th><th>\u7cbe\u5bc6\u6d17\u6d44<\/th><th>\u96fb\u89e3\u7814\u78e8\uff0b\u7cbe\u5bc6\u6d17\u6d44<\/th><\/tr><tr><th>C1020(\u7121\u9178\u7d20\u9285)<\/th><th>\u30fc<\/th><td>\u30fc<\/td><td>\u30fc<\/td><td>\u30fc<\/td><\/tr><tr><th>C1100(\u30bf\u30d5\u30d4\u30c3\u30c1\u9285)<\/th><th>\u30fc<\/th><td>\u30fc<\/td><td>\u30fc<\/td><td>\u30fc<\/td><\/tr><tr><th>C2801P(\u771f\u936e\u30fb\u9ec4\u9285)<\/th><th>\u30fc<\/th><td>\u3007<\/td><td>\u3007<\/td><td>\u30fc<\/td><\/tr><tr><th>C2680P\/C2801P(\u30b7\u30e0\u7528)<\/th><th>\u30fc<\/th><td>\u3007<\/td><td>\u3007<\/td><td>\u30fc<\/td><\/tr><\/tbody><\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-e67c409 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"e67c409\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"mT0 tableHover\" style=\"width: 100%;\">\n<tbody>\n<tr>\n<th rowspan=\"2\" style=\"width: 25%;\">\u6750\u8cea\uff1a\u30d1\u30f3\u30c1\u30f3\u30b0\u30e1\u30bf\u30eb\u6750<\/th>\n<th rowspan=\"2\" style=\"width: 25%;\">\u5b54\u5f84\u00d7\u5b54\u30d4\u30c3\u30c1<\/th>\n<th colspan=\"3\">\u6d17\u6d44\u65b9\u6cd5<\/th>\n<\/tr>\n<tr>\n<th>\u8131\u8102\u6d17\u6d44<\/th>\n<th>\u7cbe\u5bc6\u6d17\u6d44<\/th>\n<th>\u96fb\u89e3\u7814\u78e8\uff0b\u7cbe\u5bc6\u6d17\u6d44<\/th>\n<\/tr>\n<tr>\n<th rowspan=\"5\">\u30d1\u30f3\u30c1\u30f3\u30b0\u30e1\u30bf\u30eb\uff08SUS304-BA\uff09<\/th>\n<th>\u00f81 \u00d7 2p<\/th>\n<td>\u3007<\/td>\n<td>\u3007<\/td>\n<td>\u3007<\/td>\n<\/tr>\n<tr>\n<th>\u00f82 \u00d7 3p<\/th>\n<td>\u3007<\/td>\n<td>\u3007<\/td>\n<td>\u3007<\/td>\n<\/tr>\n<tr>\n<th>\u00f83 \u00d7 5p<\/th>\n<td>\u3007<\/td>\n<td>\u3007<\/td>\n<td>\u3007<\/td>\n<\/tr>\n<tr>\n<th>\u00f85 \u00d7 8p<\/th>\n<td>\u3007<\/td>\n<td>\u3007<\/td>\n<td>\u3007<\/td>\n<\/tr>\n<tr>\n<th>\u00f88 \u00d7 12p<\/th>\n<td>\u3007<\/td>\n<td>\u3007<\/td>\n<td>\u3007<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-835da18 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"835da18\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"mT0 tableHover\" style=\"width: 100%;\">\n<tbody>\n<tr>\n<th rowspan=\"2\" style=\"width: 20%;\">\u6750\u8cea\uff1a\u900f\u660e\u6a39\u8102<\/th>\n<th rowspan=\"2\" style=\"width: 15%;\">\u30b0\u30ec\u30fc\u30c9<\/th>\n<th rowspan=\"2\" style=\"width: 15%;\">\u8272<\/th>\n<th colspan=\"3\">\u6d17\u6d44\u65b9\u6cd5<\/th>\n<\/tr>\n<tr>\n<th>\u8131\u8102\u6d17\u6d44<\/th>\n<th>\u7cbe\u5bc6\u6d17\u6d44<\/th>\n<th>\u96fb\u89e3\u7814\u78e8\uff0b\u7cbe\u5bc6\u6d17\u6d44<\/th>\n<\/tr>\n<tr>\n<th rowspan=\"4\">PET (\u30dd\u30ea\u30a8\u30c1\u30ec\u30f3\u30c6\u30ec\u30d5\u30bf\u30ec\u30fc\u30c8)<\/th>\n<th rowspan=\"2\">\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9<\/th>\n<th>\u900f\u660e<\/th>\n<td>\u3007<\/td>\n<td>\u3007<\/td>\n<td>\u30fc<\/td>\n<\/tr>\n<tr>\n<th>\u30d6\u30e9\u30a6\u30f3\u30b9\u30e2\u30fc\u30af<\/th>\n<td>\u3007<\/td>\n<td>\u3007<\/td>\n<td>\u30fc<\/td>\n<\/tr>\n<tr>\n<th rowspan=\"2\">\u5236\u96fb<\/th>\n<th>\u900f\u660e<\/th>\n<td>\u3007<\/td>\n<td>\u3007<\/td>\n<td>\u30fc<\/td>\n<\/tr>\n<tr>\n<th>\u30d6\u30e9\u30a6\u30f3\u30b9\u30e2\u30fc\u30af<\/th>\n<td>\u3007<\/td>\n<td>\u3007<\/td>\n<td>\u30fc<\/td>\n<\/tr>\n<tr>\n<th rowspan=\"4\">\u30a2\u30af\u30ea\u30eb<\/th>\n<th rowspan=\"2\">\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9<\/th>\n<th>\u900f\u660e<\/th>\n<td>\u3007<\/td>\n<td>\u3007<\/td>\n<td>\u30fc<\/td>\n<\/tr>\n<tr>\n<th>\u30d6\u30e9\u30a6\u30f3\u30b9\u30e2\u30fc\u30af<\/th>\n<td>\u3007<\/td>\n<td>\u3007<\/td>\n<td>\u30fc<\/td>\n<\/tr>\n<tr>\n<th rowspan=\"2\">\u5236\u96fb<\/th>\n<th>\u900f\u660e<\/th>\n<td>\u3007<\/td>\n<td>\u3007<\/td>\n<td>\u30fc<\/td>\n<\/tr>\n<tr>\n<th>\u30d6\u30e9\u30a6\u30f3\u30b9\u30e2\u30fc\u30af<\/th>\n<td>\u3007<\/td>\n<td>\u3007<\/td>\n<td>\u30fc<\/td>\n<\/tr>\n<tr>\n<th rowspan=\"4\">\u30dd\u30ea\u30ab\u30fc\u30dc\u30cd\u30fc\u30c8<\/th>\n<th rowspan=\"2\">\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9<\/th>\n<th>\u900f\u660e<\/th>\n<td>\u3007<\/td>\n<td>\u3007<\/td>\n<td>\u30fc<\/td>\n<\/tr>\n<tr>\n<th>\u30d6\u30e9\u30a6\u30f3\u30b9\u30e2\u30fc\u30af<\/th>\n<td>\u3007<\/td>\n<td>\u3007<\/td>\n<td>\u30fc<\/td>\n<\/tr>\n<tr>\n<th rowspan=\"2\">\u5236\u96fb<\/th>\n<th>\u900f\u660e<\/th>\n<td>\u3007<\/td>\n<td>\u3007<\/td>\n<td>\u30fc<\/td>\n<\/tr>\n<tr>\n<th>\u30d6\u30e9\u30a6\u30f3\u30b9\u30e2\u30fc\u30af<\/th>\n<td>\u3007<\/td>\n<td>\u3007<\/td>\n<td>\u30fc<\/td>\n<\/tr>\n<tr>\n<th rowspan=\"4\">\u5869\u30d3 \uff08\u30dd\u30ea\u5869\u5316\u30d3\u30cb\u30eb\uff09<\/th>\n<th rowspan=\"2\">\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9<\/th>\n<th>\u900f\u660e<\/th>\n<td>\u3007<\/td>\n<td>\u3007<\/td>\n<td>\u30fc<\/td>\n<\/tr>\n<tr>\n<th>\u30d6\u30e9\u30a6\u30f3\u30b9\u30e2\u30fc\u30af<\/th>\n<td>\u3007<\/td>\n<td>\u3007<\/td>\n<td>\u30fc<\/td>\n<\/tr>\n<tr>\n<th rowspan=\"2\">\u5236\u96fb<\/th>\n<th>\u900f\u660e<\/th>\n<td>\u3007<\/td>\n<td>\u3007<\/td>\n<td>\u30fc<\/td>\n<\/tr>\n<tr>\n<th>\u30d6\u30e9\u30a6\u30f3\u30b9\u30e2\u30fc\u30af<\/th>\n<td>\u3007<\/td>\n<td>\u3007<\/td>\n<td>\u30fc<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-7419cdb tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"7419cdb\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"mT0 tableHover\" style=\"width: 100%;\">\n<tbody>\n<tr>\n<th rowspan=\"2\" style=\"width: 13%;\">\u6750\u8cea\uff1a\u8907\u5408\u677f<\/th>\n<th rowspan=\"2\" style=\"width: 15%;\">\u82af\u6750<\/th>\n<th rowspan=\"2\" style=\"width: 10%;\">\u8868\u9762\u51e6\u7406<\/th>\n<th rowspan=\"2\" style=\"width: 12%;\">\u8272<\/th>\n<th colspan=\"3\">\u6d17\u6d44\u65b9\u6cd5<\/th>\n<\/tr>\n<tr>\n<th>\u8131\u8102\u6d17\u6d44<\/th>\n<th>\u7cbe\u5bc6\u6d17\u6d44<\/th>\n<th>\u96fb\u89e3\u7814\u78e8\uff0b\u7cbe\u5bc6\u6d17\u6d44<\/th>\n<\/tr>\n<tr>\n<th rowspan=\"3\">\u30a2\u30eb\u30df\u8907\u5408\u677f<\/th>\n<th rowspan=\"3\">\u767a\u6ce1\u30dd\u30ea\u30a8\u30c1\u30ec\u30f3\u6a39\u8102<\/th>\n<th rowspan=\"3\">\u713c\u4ed8\u5857\u88c5<\/th>\n<th>\u30b7\u30eb\u30d0\u30fc<\/th>\n<td>\u3007<\/td>\n<td>\u3007<\/td>\n<td>\u30fc<\/td>\n<\/tr>\n<tr>\n<th>\u3064\u3084\u6d88\u3057\u30b7\u30eb\u30d0\u30fc<\/th>\n<td>\u3007<\/td>\n<td>\u3007<\/td>\n<td>\u30fc<\/td>\n<\/tr>\n<tr>\n<th>\u9ed2<\/th>\n<td>\u3007<\/td>\n<td>\u3007<\/td>\n<td>\u30fc<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-3e932bc elementor-widget elementor-widget-text-editor\" data-id=\"3e932bc\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<ul><li>\u203b1 \u30bd\u30b1\u30c3\u30c8\u53d6\u4ed8\u3068\u306e\u4f75\u7528\u306f\u5bfe\u8c61\u5916\u3068\u306a\u308a\u307e\u3059\u3002<\/li><li>\u203b2 \u5727\u5165\u30ca\u30c3\u30c8\u53d6\u4ed8\u3068\u306e\u4f75\u7528\u306f\u5bfe\u8c61\u5916\u3068\u306a\u308a\u307e\u3059\u3002<\/li><\/ul>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<\/div>\n\t\t\n\t\t\t<div id=\"daexthefu-container\"\n\t\t\t\tclass=\"daexthefu-container daexthefu-layout-stacked daexthefu-alignment-left\"\n\t\t\t\tdata-post-id=\"30940\">\n\n\t\t\t\t<div class=\"daexthefu-feedback\">\n\t\t\t\t\t<div class=\"daexthefu-text\">\n\t\t\t\t\t\t<h3 class=\"daexthefu-title\">\u3053\u306e\u8a18\u4e8b\u306f\u53c2\u8003\u306b\u306a\u308a\u307e\u3057\u305f\u304b\uff1f<\/h3>\n\t\t\t\t\t<\/div>\n\t\t\t\t\t<div class=\"daexthefu-buttons-container\">\n\t\t\t\t\t\t<div class=\"daexthefu-buttons\">\n\t\t\t\t\t\t\t\n\t\t\t<div class=\"daexthefu-yes daexthefu-button daexthefu-button-type-icon-and-text\" data-value=\"1\">\n\t\t\t\t<div class=\"daexthefu-button-icon\">\n\t\t\t\t\n                <svg>\n                    <defs>\n                        <style>.thumb-up-cls-1{fill:#c9c9c9;}.thumb-up-cls-2{fill:#e1e1e1;}.thumb-up-cls-3{fill:#676767;}<\/style>\n                    <\/defs>\n                    <g id=\"thumb_up\">\n                        <path class=\"thumb-up-cls-2 daexthefu-icon-circle\" d=\"m24,3c11.58,0,21,9.42,21,21s-9.42,21-21,21S3,35.58,3,24,12.42,3,24,3m0-1C11.85,2,2,11.85,2,24s9.85,22,22,22,22-9.85,22-22S36.15,2,24,2h0Z\" \/>\n                        <g>\n                            <rect class=\"thumb-up-cls-3 daexthefu-icon-secondary-color\" x=\"10\" y=\"20\" width=\"6\" height=\"15\" rx=\"1.5\" ry=\"1.5\" \/>\n                            <path class=\"thumb-up-cls-1 daexthefu-icon-primary-color\" d=\"m30.57,9.06l-.49-.1c-.81-.17-1.61.35-1.78,1.16l-5.3,11.74c-.17.81,3.16,1.61,3.97,1.78l1.96.41c.81.17,1.61-.35,1.78-1.16l2.18-10.27c.34-1.61-.7-3.21-2.31-3.56Z\" \/>\n                            <path class=\"thumb-up-cls-1 daexthefu-icon-primary-color\" d=\"m38.17,20h-18.67c-.83,0-1.5.67-1.5,1.5v12c0,.83.67,1.5,1.5,1.5h16.27c.71,0,1.33-.5,1.47-1.21l2.4-12c.19-.93-.53-1.8-1.47-1.8Z\" \/>\n                        <\/g>\n                    <\/g>\n                <\/svg>\t\t\t\t\t\t<\/div>\n\t\t\t\t<div class=\"daexthefu-button-text\">\u5f79\u306b\u7acb\u3063\u305f\uff01<\/div>\n\t\t\t<\/div>\n\n\t\t\t\t\t\t\t\t\t\t\n\t\t\t<div class=\"daexthefu-no daexthefu-button daexthefu-button-type-icon-and-text\" data-value=\"0\">\n\t\t\t\t<div class=\"daexthefu-button-icon\">\n\t\t\t\t\n                <svg>\n                    <defs>\n                        <style>.thumb-down-cls-1{fill:#c9c9c9;}.thumb-down-cls-2{fill:#e1e1e1;}.thumb-down-cls-3{fill:#676767;}<\/style>\n                    <\/defs>\n                    <g id=\"thumb_down\">\n                        <path class=\"thumb-down-cls-2 daexthefu-icon-circle\" d=\"m24,3c11.58,0,21,9.42,21,21s-9.42,21-21,21S3,35.58,3,24,12.42,3,24,3m0-1C11.85,2,2,11.85,2,24s9.85,22,22,22,22-9.85,22-22S36.15,2,24,2h0Z\" \/>\n                        <g>\n                            <rect class=\"thumb-down-cls-3 daexthefu-icon-secondary-color\" x=\"10\" y=\"13\" width=\"6\" height=\"15\" rx=\"1.5\" ry=\"1.5\" \/>\n                            <path class=\"thumb-down-cls-1 daexthefu-icon-primary-color\" d=\"m30.57,38.94l-.49.1c-.81.17-1.61-.35-1.78-1.16l-5.3-11.74c-.17-.81,3.16-1.61,3.97-1.78l1.96-.41c.81-.17,1.61.35,1.78,1.16l2.18,10.27c.34,1.61-.7,3.21-2.31,3.56Z\" \/>\n                            <path class=\"thumb-down-cls-1 daexthefu-icon-primary-color\" d=\"m38.17,28h-18.67c-.83,0-1.5-.67-1.5-1.5v-12c0-.83.67-1.5,1.5-1.5h16.27c.71,0,1.33.5,1.47,1.21l2.4,12c.19.93-.53,1.8-1.47,1.8Z\" \/>\n                        <\/g>\n                    <\/g>\n                <\/svg>\t\t\t\t\t\t<\/div>\n\t\t\t\t<div class=\"daexthefu-button-text\">\u5f79\u306b\u7acb\u305f\u306a\u304b\u3063\u305f<\/div>\n\t\t\t<\/div>\n\n\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\n\t\t\t\t<div class=\"daexthefu-comment\">\n\t\t\t\t\t<div class=\"daexthefu-comment-top-container\">\n\t\t\t\t\t\t<label id=\"daexthefu-comment-label\" class=\"daexthefu-comment-label\"><\/label>\n\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t\t<textarea id=\"daexthefu-comment-textarea\" class=\"daexthefu-comment-textarea\"\n\t\t\t\t\t\t\t\tplaceholder=\"\"\n\t\t\t\t\t\t\t\tmaxlength=\"\n\t\t\t\t\t\t\t\t400\t\t\t\t\t\t\t\t\t\"><\/textarea>\n\t\t\t\t\t<div class=\"daexthefu-comment-buttons-container\">\n\t\t\t\t\t\t<button class=\"daexthefu-comment-submit daexthefu-button\">\u9001\u4fe1<\/button>\n\t\t\t\t\t\t<button class=\"daexthefu-comment-cancel daexthefu-button\">\u53d6\u6d88<\/button>\n\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\n\t\t\t\t<div class=\"daexthefu-successful-submission-text\">\u8a55\u4fa1\u3044\u305f\u3060\u304d\u3042\u308a\u304c\u3068\u3046\u3054\u3056\u3044\u307e\u3057\u305f\u3002<\/div>\n\n\t\t\t<\/div>\n\n\t\t\t","protected":false},"excerpt":{"rendered":"<p>\u30af\u30ea\u30fc\u30f3\u6d17\u6d44\u3067\u306f3\u7a2e\u985e\u306e\u6d17\u6d44\u65b9\u6cd5\u306b\u5bfe\u5fdc\u3057\u3066\u304a\u308a\u307e\u3059\u3002 \u5404\u6d17\u6d44\u65b9\u6cd5\u306e\u8a73\u7d30\u306b\u3064\u304d\u307e\u3057\u3066\u306f\u300c\u30af\u30ea\u30fc\u30f3\u6d17\u6d44\u306b\u3064\u3044\u3066\u300d\u3092\u3054\u78ba\u8a8d\u304f\u3060\u3055\u3044\u3002 \u30af\u30ea\u30fc\u30f3\u6d17\u6d44\u306e\u5bfe\u8c61\u88fd\u54c1\u30b5\u30a4\u30ba\u30fb\u91cd\u91cf \u6d17\u6d44\u65b9\u6cd5\u306b\u3088\u308a\u5bfe\u5fdc\u53ef\u80fd\u306a\u88fd\u54c1\u30b5\u30a4\u30ba\u3001\u88fd\u54c1\u91cd\u91cf\u306b\u5236\u9650\u304c\u3054\u3056 [&hellip;]<\/p>\n","protected":false},"author":66,"featured_media":0,"comment_status":"closed","ping_status":"closed","sticky":false,"template":"","format":"standard","meta":{"_helpful_status":1,"footnotes":""},"categories":[50],"tags":[64],"class_list":["post-30940","post","type-post","status-publish","format-standard","hentry","category-shm_shape-material","tag-technical_shm"],"yoast_head":"<!-- This site is optimized with the Yoast SEO plugin v28.0 - https:\/\/yoast.com\/product\/yoast-seo-wordpress\/ -->\n<title>\u30af\u30ea\u30fc\u30f3\u6d17\u6d44\u306e\u5bfe\u8c61\u7bc4\u56f2 | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb<\/title>\n<meta name=\"robots\" content=\"index, follow, max-snippet:-1, max-image-preview:large, max-video-preview:-1\" \/>\n<link rel=\"canonical\" href=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/30940\/\" \/>\n<meta property=\"og:locale\" content=\"ja_JP\" \/>\n<meta property=\"og:type\" content=\"article\" \/>\n<meta property=\"og:title\" content=\"\u30af\u30ea\u30fc\u30f3\u6d17\u6d44\u306e\u5bfe\u8c61\u7bc4\u56f2 | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\" \/>\n<meta property=\"og:description\" content=\"\u30af\u30ea\u30fc\u30f3\u6d17\u6d44\u3067\u306f3\u7a2e\u985e\u306e\u6d17\u6d44\u65b9\u6cd5\u306b\u5bfe\u5fdc\u3057\u3066\u304a\u308a\u307e\u3059\u3002 \u5404\u6d17\u6d44\u65b9\u6cd5\u306e\u8a73\u7d30\u306b\u3064\u304d\u307e\u3057\u3066\u306f\u300c\u30af\u30ea\u30fc\u30f3\u6d17\u6d44\u306b\u3064\u3044\u3066\u300d\u3092\u3054\u78ba\u8a8d\u304f\u3060\u3055\u3044\u3002 \u30af\u30ea\u30fc\u30f3\u6d17\u6d44\u306e\u5bfe\u8c61\u88fd\u54c1\u30b5\u30a4\u30ba\u30fb\u91cd\u91cf \u6d17\u6d44\u65b9\u6cd5\u306b\u3088\u308a\u5bfe\u5fdc\u53ef\u80fd\u306a\u88fd\u54c1\u30b5\u30a4\u30ba\u3001\u88fd\u54c1\u91cd\u91cf\u306b\u5236\u9650\u304c\u3054\u3056 [&hellip;]\" \/>\n<meta property=\"og:url\" content=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/30940\/\" \/>\n<meta property=\"og:site_name\" content=\"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\" \/>\n<meta property=\"article:published_time\" content=\"2025-10-19T15:00:38+00:00\" \/>\n<meta property=\"article:modified_time\" content=\"2026-10-05T01:30:01+00:00\" \/>\n<meta name=\"author\" content=\"\u7965\u5b50\u670d\u90e8\" \/>\n<meta name=\"twitter:card\" content=\"summary_large_image\" \/>\n<script type=\"application\/ld+json\" class=\"yoast-schema-graph\">{\"@context\":\"https:\\\/\\\/schema.org\",\"@graph\":[{\"@type\":\"Article\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_shape-material\\\/30940\\\/#article\",\"isPartOf\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_shape-material\\\/30940\\\/\"},\"author\":{\"name\":\"\u7965\u5b50\u670d\u90e8\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#\\\/schema\\\/person\\\/80454d8b7e81a0a5014b1b3a8ef1fa06\"},\"headline\":\"\u30af\u30ea\u30fc\u30f3\u6d17\u6d44\u306e\u5bfe\u8c61\u7bc4\u56f2\",\"datePublished\":\"2025-10-19T15:00:38+00:00\",\"dateModified\":\"2026-10-05T01:30:01+00:00\",\"mainEntityOfPage\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_shape-material\\\/30940\\\/\"},\"wordCount\":44,\"publisher\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#organization\"},\"keywords\":[\"technical_shm\"],\"articleSection\":[\"\u5bfe\u8c61\u90e8\u54c1\\\/\u6750\u6599\"],\"inLanguage\":\"ja\"},{\"@type\":\"WebPage\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_shape-material\\\/30940\\\/\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_shape-material\\\/30940\\\/\",\"name\":\"\u30af\u30ea\u30fc\u30f3\u6d17\u6d44\u306e\u5bfe\u8c61\u7bc4\u56f2 | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\",\"isPartOf\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#website\"},\"datePublished\":\"2025-10-19T15:00:38+00:00\",\"dateModified\":\"2026-10-05T01:30:01+00:00\",\"breadcrumb\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_shape-material\\\/30940\\\/#breadcrumb\"},\"inLanguage\":\"ja\",\"potentialAction\":[{\"@type\":\"ReadAction\",\"target\":[\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_shape-material\\\/30940\\\/\"]}]},{\"@type\":\"BreadcrumbList\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_shape-material\\\/30940\\\/#breadcrumb\",\"itemListElement\":[{\"@type\":\"ListItem\",\"position\":1,\"name\":\"\u30db\u30fc\u30e0\",\"item\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/\"},{\"@type\":\"ListItem\",\"position\":2,\"name\":\"\u30af\u30ea\u30fc\u30f3\u6d17\u6d44\u306e\u5bfe\u8c61\u7bc4\u56f2\"}]},{\"@type\":\"WebSite\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#website\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/\",\"name\":\"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\",\"description\":\"\",\"publisher\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#organization\"},\"potentialAction\":[{\"@type\":\"SearchAction\",\"target\":{\"@type\":\"EntryPoint\",\"urlTemplate\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/?s={search_term_string}\"},\"query-input\":{\"@type\":\"PropertyValueSpecification\",\"valueRequired\":true,\"valueName\":\"search_term_string\"}}],\"inLanguage\":\"ja\"},{\"@type\":\"Organization\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#organization\",\"name\":\"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/\",\"logo\":{\"@type\":\"ImageObject\",\"inLanguage\":\"ja\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#\\\/schema\\\/logo\\\/image\\\/\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2019\\\/05\\\/A01-b_b4-1_jpeg.jpg\",\"contentUrl\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2019\\\/05\\\/A01-b_b4-1_jpeg.jpg\",\"width\":260,\"height\":70,\"caption\":\"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df\"},\"image\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#\\\/schema\\\/logo\\\/image\\\/\"}},{\"@type\":\"Person\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#\\\/schema\\\/person\\\/80454d8b7e81a0a5014b1b3a8ef1fa06\",\"name\":\"\u7965\u5b50\u670d\u90e8\",\"image\":{\"@type\":\"ImageObject\",\"inLanguage\":\"ja\",\"@id\":\"https:\\\/\\\/secure.gravatar.com\\\/avatar\\\/3a222d7e140b45c6d91dcc98d80eebcbd57cf3659e4b6e73b6556a78887474a7?s=96&d=mm&r=g\",\"url\":\"https:\\\/\\\/secure.gravatar.com\\\/avatar\\\/3a222d7e140b45c6d91dcc98d80eebcbd57cf3659e4b6e73b6556a78887474a7?s=96&d=mm&r=g\",\"contentUrl\":\"https:\\\/\\\/secure.gravatar.com\\\/avatar\\\/3a222d7e140b45c6d91dcc98d80eebcbd57cf3659e4b6e73b6556a78887474a7?s=96&d=mm&r=g\",\"caption\":\"\u7965\u5b50\u670d\u90e8\"},\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/author\\\/shoko-hattori\\\/\"}]}<\/script>\n<!-- \/ Yoast SEO plugin. -->","yoast_head_json":{"title":"\u30af\u30ea\u30fc\u30f3\u6d17\u6d44\u306e\u5bfe\u8c61\u7bc4\u56f2 | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","robots":{"index":"index","follow":"follow","max-snippet":"max-snippet:-1","max-image-preview":"max-image-preview:large","max-video-preview":"max-video-preview:-1"},"canonical":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/30940\/","og_locale":"ja_JP","og_type":"article","og_title":"\u30af\u30ea\u30fc\u30f3\u6d17\u6d44\u306e\u5bfe\u8c61\u7bc4\u56f2 | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","og_description":"\u30af\u30ea\u30fc\u30f3\u6d17\u6d44\u3067\u306f3\u7a2e\u985e\u306e\u6d17\u6d44\u65b9\u6cd5\u306b\u5bfe\u5fdc\u3057\u3066\u304a\u308a\u307e\u3059\u3002 \u5404\u6d17\u6d44\u65b9\u6cd5\u306e\u8a73\u7d30\u306b\u3064\u304d\u307e\u3057\u3066\u306f\u300c\u30af\u30ea\u30fc\u30f3\u6d17\u6d44\u306b\u3064\u3044\u3066\u300d\u3092\u3054\u78ba\u8a8d\u304f\u3060\u3055\u3044\u3002 \u30af\u30ea\u30fc\u30f3\u6d17\u6d44\u306e\u5bfe\u8c61\u88fd\u54c1\u30b5\u30a4\u30ba\u30fb\u91cd\u91cf \u6d17\u6d44\u65b9\u6cd5\u306b\u3088\u308a\u5bfe\u5fdc\u53ef\u80fd\u306a\u88fd\u54c1\u30b5\u30a4\u30ba\u3001\u88fd\u54c1\u91cd\u91cf\u306b\u5236\u9650\u304c\u3054\u3056 [&hellip;]","og_url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/30940\/","og_site_name":"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","article_published_time":"2025-10-19T15:00:38+00:00","article_modified_time":"2026-10-05T01:30:01+00:00","author":"\u7965\u5b50\u670d\u90e8","twitter_card":"summary_large_image","schema":{"@context":"https:\/\/schema.org","@graph":[{"@type":"Article","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/30940\/#article","isPartOf":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/30940\/"},"author":{"name":"\u7965\u5b50\u670d\u90e8","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/person\/80454d8b7e81a0a5014b1b3a8ef1fa06"},"headline":"\u30af\u30ea\u30fc\u30f3\u6d17\u6d44\u306e\u5bfe\u8c61\u7bc4\u56f2","datePublished":"2025-10-19T15:00:38+00:00","dateModified":"2026-10-05T01:30:01+00:00","mainEntityOfPage":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/30940\/"},"wordCount":44,"publisher":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#organization"},"keywords":["technical_shm"],"articleSection":["\u5bfe\u8c61\u90e8\u54c1\/\u6750\u6599"],"inLanguage":"ja"},{"@type":"WebPage","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/30940\/","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/30940\/","name":"\u30af\u30ea\u30fc\u30f3\u6d17\u6d44\u306e\u5bfe\u8c61\u7bc4\u56f2 | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","isPartOf":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#website"},"datePublished":"2025-10-19T15:00:38+00:00","dateModified":"2026-10-05T01:30:01+00:00","breadcrumb":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/30940\/#breadcrumb"},"inLanguage":"ja","potentialAction":[{"@type":"ReadAction","target":["https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/30940\/"]}]},{"@type":"BreadcrumbList","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/30940\/#breadcrumb","itemListElement":[{"@type":"ListItem","position":1,"name":"\u30db\u30fc\u30e0","item":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/"},{"@type":"ListItem","position":2,"name":"\u30af\u30ea\u30fc\u30f3\u6d17\u6d44\u306e\u5bfe\u8c61\u7bc4\u56f2"}]},{"@type":"WebSite","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#website","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/","name":"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","description":"","publisher":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#organization"},"potentialAction":[{"@type":"SearchAction","target":{"@type":"EntryPoint","urlTemplate":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/?s={search_term_string}"},"query-input":{"@type":"PropertyValueSpecification","valueRequired":true,"valueName":"search_term_string"}}],"inLanguage":"ja"},{"@type":"Organization","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#organization","name":"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/","logo":{"@type":"ImageObject","inLanguage":"ja","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/logo\/image\/","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2019\/05\/A01-b_b4-1_jpeg.jpg","contentUrl":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2019\/05\/A01-b_b4-1_jpeg.jpg","width":260,"height":70,"caption":"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df"},"image":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/logo\/image\/"}},{"@type":"Person","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/person\/80454d8b7e81a0a5014b1b3a8ef1fa06","name":"\u7965\u5b50\u670d\u90e8","image":{"@type":"ImageObject","inLanguage":"ja","@id":"https:\/\/secure.gravatar.com\/avatar\/3a222d7e140b45c6d91dcc98d80eebcbd57cf3659e4b6e73b6556a78887474a7?s=96&d=mm&r=g","url":"https:\/\/secure.gravatar.com\/avatar\/3a222d7e140b45c6d91dcc98d80eebcbd57cf3659e4b6e73b6556a78887474a7?s=96&d=mm&r=g","contentUrl":"https:\/\/secure.gravatar.com\/avatar\/3a222d7e140b45c6d91dcc98d80eebcbd57cf3659e4b6e73b6556a78887474a7?s=96&d=mm&r=g","caption":"\u7965\u5b50\u670d\u90e8"},"url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/author\/shoko-hattori\/"}]}},"views":1360,"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts\/30940","targetHints":{"allow":["GET"]}}],"collection":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts"}],"about":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/types\/post"}],"author":[{"embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/users\/66"}],"replies":[{"embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/comments?post=30940"}],"version-history":[{"count":28,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts\/30940\/revisions"}],"predecessor-version":[{"id":38020,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts\/30940\/revisions\/38020"}],"wp:attachment":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/media?parent=30940"}],"wp:term":[{"taxonomy":"category","embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/categories?post=30940"},{"taxonomy":"post_tag","embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/tags?post=30940"}],"curies":[{"name":"wp","href":"https:\/\/api.w.org\/{rel}","templated":true}]}}
