{"id":3348,"date":"2021-04-30T15:07:50","date_gmt":"2021-04-30T06:07:50","guid":{"rendered":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/?p=3348"},"modified":"2025-09-29T10:28:20","modified_gmt":"2025-09-29T01:28:20","slug":"%e8%96%84%e8%82%89%e6%9d%a1%e4%bb%b6","status":"publish","type":"post","link":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/mpb_guideline\/3348\/","title":{"rendered":"\u8584\u8089\u5224\u5b9a\u30ed\u30b8\u30c3\u30af"},"content":{"rendered":"\t\t<div data-elementor-type=\"wp-post\" data-elementor-id=\"3348\" class=\"elementor elementor-3348\">\n\t\t\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-54f75a0 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"54f75a0\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-c7cc24b\" data-id=\"c7cc24b\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-ca5f1ab elementor-widget elementor-widget-text-editor\" data-id=\"ca5f1ab\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p>\u4ee5\u4e0b\u306e\u3088\u3046\u306b\u3001\u52a0\u5de5\u9650\u754c\u5024\u672a\u6e80\u306e\u8584\u8089\u304c\u5b58\u5728\u3059\u308b\u5834\u5408\u306f\u3001\u88fd\u4f5c\u6642\u306b\u7834\u308c\u3084\u3001\u5f62\u72b6\u304c\u6b6a\u3080\u3053\u3068\u3067\u516c\u5dee\u5916\u308c\u304c\u751f\u3058\u307e\u3059\u3002\u203b\u9650\u754c\u5024\u304c\u91cd\u8907\u3059\u308b\u5834\u5408\u306f\u5927\u304d\u3044\u5024\u3092\u512a\u5148\u81f4\u3057\u307e\u3059\u3002<\/p><p>\u9650\u754c\u5024\u3092\u4e0b\u56de\u308b\u5834\u5408\u306f\u753b\u9762\u4e0a\u306b\u300c\u54c1\u8cea\u540c\u610f\u4e8b\u9805\u300d\u304c\u8868\u793a\u3055\u308c\u307e\u3059\u306e\u3067\u30013D\u30d3\u30e5\u30fc\u30ef\u30fc\u4e0a\u3067\u8a72\u5f53\u7b87\u6240\u3092\u78ba\u8a8d\u3057\u3001\u7834\u308c\u3001\u6b6a\u307f\u516c\u5dee\u5916\u308c\u306e\u53ef\u5426\u56de\u7b54\u3092\u3057\u3066\u304f\u3060\u3055\u3044\u3002<\/p><p>\u540c\u610f\u4e0d\u53ef\u306e\u5834\u5408\u306f\u81ea\u52d5\u3067\u306e\u898b\u7a4d\u56de\u7b54\u306f\u3067\u304d\u307e\u305b\u3093\u3002\u30e2\u30c7\u30eb\u901a\u308a\u306e\u54c1\u8cea\u306e\u898b\u7a4d\u3092\u3054\u5e0c\u671b\u3067\u3042\u308c\u3070\u3001\u30b3\u30e1\u30f3\u30c8\u6b04\u306b\u300c\u54c1\u8cea\u540c\u610f\u4e0d\u53ef\u300d\u7b49\u3092\u8a18\u5165\u3057meviy\u30b5\u30dd\u30fc\u30c8\u306b\u898b\u7a4d\u3092\u4f9d\u983c\u3057\u3066\u304f\u3060\u3055\u3044\u3002\u8ffd\u3063\u3066\u3001\u6b63\u5f0f\u306a\u898b\u7a4d\u56de\u7b54\u3092\u5dee\u3057\u4e0a\u3052\u307e\u3059\u3002<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-281f9c6 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"281f9c6\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-c30e882\" data-id=\"c30e882\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-b257b41 elementor-widget elementor-widget-heading\" data-id=\"b257b41\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h2 class=\"elementor-heading-title elementor-size-default\">\u300c\u30b9\u30c8\u30ec\u30fc\u30c8\u7a74\u300d\u300c\u7cbe\u5ea6\u7a74\u300d\u300c\u30bf\u30c3\u30d7\u7a74\u300d\u5186\u7b52\u90e8\u3068\u4ed6\u5f62\u72b6\u8981\u7d20\u9593\u306e\u8584\u8089<\/h2>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-b9511ff elementor-section-full_width elementor-section-height-default elementor-section-height-default\" data-id=\"b9511ff\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-25 elementor-top-column elementor-element elementor-element-1216582\" data-id=\"1216582\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-e038fe9 elementor-widget elementor-widget-image\" data-id=\"e038fe9\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img decoding=\"async\" width=\"219\" height=\"151\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/tgt04_fac_156.png\" class=\"attachment-full size-full wp-image-3094\" alt=\"\u5f62\u72b6\u4f8b\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-25 elementor-top-column elementor-element elementor-element-9d3110d\" data-id=\"9d3110d\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-606ccb0 elementor-widget elementor-widget-image\" data-id=\"606ccb0\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img decoding=\"async\" width=\"219\" height=\"151\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/tgt04_fac_157.png\" class=\"attachment-full size-full wp-image-3092\" alt=\"\u5f62\u72b6\u4f8b\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-25 elementor-top-column elementor-element elementor-element-a28e330\" data-id=\"a28e330\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-67b1da7 elementor-widget elementor-widget-image\" data-id=\"67b1da7\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img decoding=\"async\" width=\"237\" height=\"151\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/tgt04_fac_158.png\" class=\"attachment-large size-large wp-image-3091\" alt=\"\u5f62\u72b6\u4f8b\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-25 elementor-top-column elementor-element elementor-element-7ede8e4\" data-id=\"7ede8e4\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap\">\n\t\t\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-548626a elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"548626a\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-b13eaab\" data-id=\"b13eaab\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-bca5a49 elementor-widget elementor-widget-heading\" data-id=\"bca5a49\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h4 class=\"elementor-heading-title elementor-size-default\"><span style=\"text-decoration:underline\">\u300c\u30b9\u30c8\u30ec\u30fc\u30c8\u7a74\u300d\u3068\u4ed6\u5f62\u72b6\u8981\u7d20\u9593\u306e\u8584\u8089<\/span><\/h4>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-be51985 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"be51985\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-126a370\" data-id=\"126a370\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-f4dd95e elementor-widget elementor-widget-text-editor\" data-id=\"f4dd95e\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p>\u00a0<\/p><p style=\"text-align: right;\">[mm]<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-4f39c1b1 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"4f39c1b1\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-76582252\" data-id=\"76582252\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-4e82982b tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"4e82982b\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"table04 mt0 tableHover_single\">\n<tbody>\n<tr>\n<th style=\"width: 62.9027%;\" colspan=\"3\">\u5168\u6750\u8cea<\/th>\n<\/tr>\n<tr>\n<th style=\"width: 19.7479%;\">\u5f84<\/th>\n<th style=\"width: 17.6471%;\">\u00f82\u4ee5\u4e0a\n\u00f85\u4ee5\u4e0b<\/th>\n<th style=\"width: 25.5077%;\">\u00f85\u8d85<\/th>\n<\/tr>\n<tr>\n<th style=\"width: 19.7479%;\">\u52a0\u5de5\u9650\u754c<\/th>\n<td class=\"elementCenter\" style=\"width: 17.6471%;\">0.8<\/td>\n<td class=\"elementCenter\" style=\"width: 25.5077%;\">1.0<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-1d85d7b elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"1d85d7b\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-d8239fe\" data-id=\"d8239fe\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-011301f elementor-widget elementor-widget-heading\" data-id=\"011301f\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h4 class=\"elementor-heading-title elementor-size-default\"><span style=\"text-decoration:underline\">\u300c\u7cbe\u5ea6\u7a74\u300d\u3068\u4ed6\u5f62\u72b6\u8981\u7d20\u9593\u306e\u8584\u8089<\/span><\/h4>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-2f96d57 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"2f96d57\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-06fc1c6\" data-id=\"06fc1c6\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-a0ed042 elementor-widget elementor-widget-text-editor\" data-id=\"a0ed042\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p>\u00a0<\/p><p style=\"text-align: right;\">[mm]<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-7c671b3 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"7c671b3\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"table04 mt0 tableHover_single\">\n<tbody>\n<tr>\n<th style=\"width: 37.395%;\" colspan=\"2\"><span style=\"color: #000000; font-family: Arial, '\u30d2\u30e9\u30ae\u30ce\u89d2\u30b4 ProN W3', 'Hiragino Kaku Gothic ProN', \u30e1\u30a4\u30ea\u30aa, Meiryo, sans-serif;\">\u9244\u30fb\u30d7\u30ea\u30cf\u30fc\u30c9\u30f3\u92fc\u30fb\u5de5\u5177\u92fc\u30fb\u30a2\u30eb\u30df\u30fbSUS\u30fb\u9285\u30fb\u771f\u936e<\/span><\/th>\n<\/tr>\n<tr>\n<th style=\"width: 19.7479%;\">\u5f84<\/th>\n<th style=\"width: 17.6471%;\">\u00f82\u4ee5\u4e0a<\/th>\n<\/tr>\n<tr>\n<th style=\"width: 19.7479%;\">\u52a0\u5de5\u9650\u754c<\/th>\n<td class=\"elementCenter\" style=\"width: 17.6471%;\">0.8<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-6e4345c elementor-widget elementor-widget-text-editor\" data-id=\"6e4345c\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p>\u00a0<\/p><p style=\"text-align: right;\">[mm]<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-a3cbe78 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"a3cbe78\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"table04 mt0 tableHover_single\"><tbody><tr><th style=\"width: 37.395%;\" colspan=\"2\"><span style=\"color: #000000; font-family: Arial, '\u30d2\u30e9\u30ae\u30ce\u89d2\u30b4 ProN W3', 'Hiragino Kaku Gothic ProN', \u30e1\u30a4\u30ea\u30aa, Meiryo, sans-serif;\">\u30dd\u30ea\u30a2\u30bb\u30bf\u30fc\u30eb\u30fbMC\u30ca\u30a4\u30ed\u30f3\u30fb\u3075\u3063\u7d20\u30fb\u8d85\u9ad8\u5206\u5b50\u91cf\u30dd\u30ea\u30a8\u30c1\u30ec\u30f3\u30fbABS\u30fbPEEK<\/span><\/th><\/tr><tr><th style=\"width: 19.7479%;\">\u5f84<\/th><th style=\"width: 17.6471%;\">\u00f82\u4ee5\u4e0a<\/th><\/tr><tr><th style=\"width: 19.7479%;\">\u52a0\u5de5\u9650\u754c<\/th><td class=\"elementCenter\" style=\"width: 17.6471%;\">1.5<\/td><\/tr><\/tbody><\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-6a40d12 elementor-widget elementor-widget-text-editor\" data-id=\"6a40d12\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p>\u00a0<\/p><p style=\"text-align: right;\">[mm]<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-c34a58b tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"c34a58b\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"table04 mt0 tableHover_single\"><tbody><tr><th style=\"width: 37.395%;\" colspan=\"2\"><span style=\"color: #000000; font-family: Arial, \u30d2\u30e9\u30ae\u30ce\u89d2\u30b4 ProN W3, Hiragino Kaku Gothic ProN, \u30e1\u30a4\u30ea\u30aa, Meiryo, sans-serif;\">\u30d9\u30fc\u30af\u30e9\u30a4\u30c8<\/span><\/th><\/tr><tr><th style=\"width: 19.7479%;\">\u5f84<\/th><th style=\"width: 17.6471%;\">\u00f82\u4ee5\u4e0a<\/th><\/tr><tr><th style=\"width: 19.7479%;\">\u52a0\u5de5\u9650\u754c<\/th><td class=\"elementCenter\" style=\"width: 17.6471%;\">2.0<\/td><\/tr><\/tbody><\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-346645a elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"346645a\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-3722bda\" data-id=\"3722bda\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-1551f4d elementor-widget elementor-widget-heading\" data-id=\"1551f4d\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h4 class=\"elementor-heading-title elementor-size-default\"><span style=\"text-decoration:underline\">\u300c\u30bf\u30c3\u30d7\u7a74\u300d\u3068\u4ed6\u5f62\u72b6\u8981\u7d20\u9593\u306e\u8584\u8089<\/span><\/h4>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-43e61f5 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"43e61f5\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-d259095\" data-id=\"d259095\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-56b6116 elementor-widget elementor-widget-text-editor\" data-id=\"56b6116\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p>\u00a0<\/p><p style=\"text-align: right;\">[mm]<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-b87b3ee elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"b87b3ee\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-c2427cb\" data-id=\"c2427cb\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-3e17b28 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"3e17b28\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"table04 mt0 tableHover_single\">\n<tbody>\n<tr>\n<th colspan=\"4\">\u5168\u6750\u8cea<\/th>\n<\/tr>\n<tr>\n<th>\u547c\u5f84<\/th>\n<th>M2\u4ee5\u4e0a\nM5\u4ee5\u4e0b<\/th>\n<th>M6\u4ee5\u4e0a\nM10\u4ee5\u4e0b<\/th>\n<th>M12\u4ee5\u4e0a<\/th>\n<\/tr>\n<tr>\n<th>\u52a0\u5de5\u9650\u754c<\/th>\n<td>0.8<\/td>\n<td>1.0<\/td>\n<td>1.5<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-6bdd9e6 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"6bdd9e6\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-bbae6d8\" data-id=\"bbae6d8\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-c04f6de elementor-widget elementor-widget-heading\" data-id=\"c04f6de\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h4 class=\"elementor-heading-title elementor-size-default\"><span style=\"text-decoration:underline\">\u300c\u30a4\u30f3\u30b5\u30fc\u30c8\u7a74\u300d\u3068\u4ed6\u5f62\u72b6\u8981\u7d20\u9593\u306e\u8584\u8089<\/span><\/h4>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-2ca2729 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"2ca2729\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-66a8d63\" data-id=\"66a8d63\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-4f9926e elementor-widget elementor-widget-text-editor\" data-id=\"4f9926e\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p>\u00a0<\/p><p style=\"text-align: right;\">[mm]<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-8c49906 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"8c49906\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-974d138\" data-id=\"974d138\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-c3280db tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"c3280db\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"table04 mt0 tableHover_single\">\n<tbody>\n<tr>\n<th colspan=\"4\"><span style=\"color: #000000; font-family: Arial, '\u30d2\u30e9\u30ae\u30ce\u89d2\u30b4 ProN W3', 'Hiragino Kaku Gothic ProN', \u30e1\u30a4\u30ea\u30aa, Meiryo, sans-serif;\">\u5168\u6750\u8cea<\/span><\/th>\n<\/tr>\n<tr>\n<th>\u547c\u5f84<\/th>\n<th>M2\u4ee5\u4e0a\nM5\u4ee5\u4e0b<\/th>\n<th>M6\u4ee5\u4e0a\nM10\u4ee5\u4e0b<\/th>\n<th>M12<\/th>\n<\/tr>\n<tr>\n<th>\u52a0\u5de5\u9650\u754c<\/th>\n<td class=\"elementCenter\">2.0<\/td>\n<td class=\"elementCenter\">3.1<\/td>\n<td class=\"elementCenter\">3.9<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-9733810 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"9733810\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-a4ecdcf\" data-id=\"a4ecdcf\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-c9fc75b elementor-widget elementor-widget-heading\" data-id=\"c9fc75b\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h4 class=\"elementor-heading-title elementor-size-default\"><span style=\"text-decoration:underline\">\u300c\u76bf\u7a74\u300d\u3068\u4ed6\u5f62\u72b6\u8981\u7d20\u9593\u306e\u8584\u8089<\/span><\/h4>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-2a55b27 elementor-section-full_width elementor-section-height-default elementor-section-height-default\" data-id=\"2a55b27\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-25 elementor-top-column elementor-element elementor-element-13d94a0\" data-id=\"13d94a0\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-dec4e9c elementor-widget elementor-widget-image\" data-id=\"dec4e9c\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img loading=\"lazy\" decoding=\"async\" width=\"150\" height=\"150\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/19-2-150x150.png\" class=\"attachment-thumb150 size-thumb150 wp-image-4855\" alt=\"\" srcset=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/19-2-150x150.png 150w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/19-2-100x100.png 100w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/19-2-200x200.png 200w\" sizes=\"(max-width: 150px) 100vw, 150px\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-25 elementor-top-column elementor-element elementor-element-4cdbb50\" data-id=\"4cdbb50\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-9d35ea1 elementor-widget elementor-widget-image\" data-id=\"9d35ea1\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img loading=\"lazy\" decoding=\"async\" width=\"150\" height=\"150\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/20-2-150x150.png\" class=\"attachment-thumb150 size-thumb150 wp-image-4856\" alt=\"\" srcset=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/20-2-150x150.png 150w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/20-2-100x100.png 100w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/20-2-200x200.png 200w\" sizes=\"(max-width: 150px) 100vw, 150px\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-25 elementor-top-column elementor-element elementor-element-ffc7765\" data-id=\"ffc7765\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap\">\n\t\t\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-25 elementor-top-column elementor-element elementor-element-3e77fcb\" data-id=\"3e77fcb\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap\">\n\t\t\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-1135106 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"1135106\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-1a082dd\" data-id=\"1a082dd\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-0890c8c elementor-widget elementor-widget-text-editor\" data-id=\"0890c8c\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p>\u00a0<\/p><p style=\"text-align: right;\">[mm]<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-1fcbbe0 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"1fcbbe0\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-e3f9a47\" data-id=\"e3f9a47\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-68eb052 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"68eb052\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"table04 mt0 tableHover_single\">\n<tbody>\n<tr>\n<th style=\"width: 100.979%;\" colspan=\"3\"><span style=\"color: #000000; font-family: Arial, '\u30d2\u30e9\u30ae\u30ce\u89d2\u30b4 ProN W3', 'Hiragino Kaku Gothic ProN', \u30e1\u30a4\u30ea\u30aa, Meiryo, sans-serif;\">\u5168\u6750\u8cea<\/span><\/th>\n<\/tr>\n<tr>\n<th style=\"width: 36.3636%;\">\u5f84\uff08D,d\uff09<\/th>\n<th style=\"width: 27.2727%;\">\u00f82\u4ee5\u4e0a\n\u00f85\u4ee5\u4e0b<\/th>\n<th style=\"width: 37.3431%;\">\u00f85\u8d85<\/th>\n<\/tr>\n<tr>\n<th style=\"width: 36.3636%;\">\u52a0\u5de5\u9650\u754c<\/th>\n<td class=\"elementCenter\" style=\"width: 27.2727%;\">0.8<\/td>\n<td class=\"elementCenter\" style=\"width: 37.3431%;\">1.0<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-70a301f elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"70a301f\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-4f02be7\" data-id=\"4f02be7\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-c405c2c elementor-widget elementor-widget-heading\" data-id=\"c405c2c\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h4 class=\"elementor-heading-title elementor-size-default\"><span style=\"text-decoration:underline\">\u300c\u30b6\u30b0\u30ea\u7a74\u306e\u5e95\u9762\u300d\u3068\u4ed6\u5f62\u72b6\u8981\u7d20\u9593\u306e\u8584\u8089<\/span><\/h4>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-4df49a6 elementor-section-full_width elementor-section-height-default elementor-section-height-default\" data-id=\"4df49a6\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-25 elementor-top-column elementor-element elementor-element-a3cb6d6\" data-id=\"a3cb6d6\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-1b8bc7e elementor-widget elementor-widget-image\" data-id=\"1b8bc7e\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img loading=\"lazy\" decoding=\"async\" width=\"150\" height=\"150\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/21-150x150.png\" class=\"attachment-thumb150 size-thumb150 wp-image-4857\" alt=\"\" srcset=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/21-150x150.png 150w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/21-100x100.png 100w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/21-200x200.png 200w\" sizes=\"(max-width: 150px) 100vw, 150px\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-25 elementor-top-column elementor-element elementor-element-2d2aab2\" data-id=\"2d2aab2\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap\">\n\t\t\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-25 elementor-top-column elementor-element elementor-element-28b09e3\" data-id=\"28b09e3\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap\">\n\t\t\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-25 elementor-top-column elementor-element elementor-element-2097e44\" data-id=\"2097e44\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap\">\n\t\t\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-547d0863 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"547d0863\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-142511f8\" data-id=\"142511f8\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-45669eb4 elementor-widget elementor-widget-text-editor\" data-id=\"45669eb4\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p>\u00a0<\/p><p style=\"text-align: right;\">[mm]<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-0311ca4 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"0311ca4\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-7f6bf76\" data-id=\"7f6bf76\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-f43e431 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"f43e431\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"table04 mt0 tableHover_single\">\n<tbody>\n<tr>\n<th style=\"width: 100.419%;\" colspan=\"3\">\u9244\u30fb\u30d7\u30ea\u30cf\u30fc\u30c9\u30f3\u92fc\u30fb\u5de5\u5177\u92fc\u30fb\u30a2\u30eb\u30df\u30fbSUS\u30fb\u9285\u30fb\u771f\u936e<\/th>\n<\/tr>\n<tr>\n<th style=\"width: 31.016%;\">\u547c\u5f84<\/th>\n<th style=\"width: 29.9465%;\">\u00f83\u4ee5\u4e0a\n\u00f86\u4ee5\u4e0b<\/th>\n<th style=\"width: 39.4565%;\">\u00f86\u8d85<\/th>\n<\/tr>\n<tr>\n<th style=\"width: 31.016%;\">\u52a0\u5de5\u9650\u754c<\/th>\n<td class=\"elementCenter\" style=\"width: 29.9465%;\">0.8<\/td>\n<td class=\"elementCenter\" style=\"width: 39.4565%;\">1.0<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-26e923a elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"26e923a\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-17da9d7\" data-id=\"17da9d7\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-763c248 elementor-widget elementor-widget-text-editor\" data-id=\"763c248\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p>\u00a0<\/p><p style=\"text-align: right;\">[mm]<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-3f45631 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"3f45631\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-2dd3562\" data-id=\"2dd3562\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-c336813 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"c336813\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"table04 mt0 tableHover_single\"><tbody><tr><th style=\"width: 99.4737%;\" colspan=\"2\"><span style=\"color: #000000; font-family: Arial, '\u30d2\u30e9\u30ae\u30ce\u89d2\u30b4 ProN W3', 'Hiragino Kaku Gothic ProN', \u30e1\u30a4\u30ea\u30aa, Meiryo, sans-serif;\">\u30dd\u30ea\u30a2\u30bb\u30bf\u30fc\u30eb\u30fbMC\u30ca\u30a4\u30ed\u30f3\u30fb\u3075\u3063\u7d20\u30fb\u8d85\u9ad8\u5206\u5b50\u91cf\u30dd\u30ea\u30a8\u30c1\u30ec\u30f3\u30fbABS\u30fbPEEK\u30fb\u30d9\u30fc\u30af\u30e9\u30a4\u30c8<\/span><\/th><\/tr><tr><th style=\"width: 50%;\">\u547c\u5f84<\/th><th style=\"width: 49.4737%;\">\u00f83\u4ee5\u4e0a<\/th><\/tr><tr><th style=\"width: 50%;\">\u52a0\u5de5\u9650\u754c<\/th><td class=\"elementCenter\" style=\"width: 49.4737%;\">1.0<\/td><\/tr><\/tbody><\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-0bdae3d elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"0bdae3d\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-99efb46\" data-id=\"99efb46\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-8af2df4 elementor-widget elementor-widget-heading\" data-id=\"8af2df4\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h2 class=\"elementor-heading-title elementor-size-default\">\u305d\u306e\u4ed6\u5f62\u72b6\u8981\u7d20\u306e\u8584\u8089\u6761\u4ef6<\/h2>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-50ae8c0 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"50ae8c0\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-17e9ac3\" data-id=\"17e9ac3\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-2d983e4 elementor-widget elementor-widget-heading\" data-id=\"2d983e4\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h4 class=\"elementor-heading-title elementor-size-default\"><span style=\"text-decoration:underline\">\u300c\u9577\u7a74\u306e\u30b9\u30c8\u30ec\u30fc\u30c8\u90e8\u300d\u3068\u4ed6\u5f62\u72b6\u8981\u7d20\u9593\u306e\u8584\u8089<\/span><\/h4>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-72c2c16 elementor-section-full_width elementor-section-height-default elementor-section-height-default\" data-id=\"72c2c16\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-25 elementor-top-column elementor-element elementor-element-d277d07\" data-id=\"d277d07\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-f812bcb elementor-widget elementor-widget-image\" data-id=\"f812bcb\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img loading=\"lazy\" decoding=\"async\" width=\"219\" height=\"152\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/tgt04_fac_168.png\" class=\"attachment-full size-full wp-image-3087\" alt=\"\u5f62\u72b6\u4f8b\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-25 elementor-top-column elementor-element elementor-element-a3a1b71\" data-id=\"a3a1b71\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-f84ab74 elementor-widget elementor-widget-image\" data-id=\"f84ab74\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img loading=\"lazy\" decoding=\"async\" width=\"219\" height=\"154\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/tgt04_fac_169.png\" class=\"attachment-full size-full wp-image-3084\" alt=\"\u5f62\u72b6\u4f8b\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-25 elementor-top-column elementor-element elementor-element-fea5034\" data-id=\"fea5034\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap\">\n\t\t\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-25 elementor-top-column elementor-element elementor-element-d3ed79a\" data-id=\"d3ed79a\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap\">\n\t\t\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-e734940 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"e734940\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-608e834\" data-id=\"608e834\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-9fd6b43 elementor-widget elementor-widget-text-editor\" data-id=\"9fd6b43\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p>\u00a0<\/p><p style=\"text-align: right;\">[mm]<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-8bde36e elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"8bde36e\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-7d06e45\" data-id=\"7d06e45\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-e327322 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"e327322\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"table04 mt0 tableHover_single\">\n<tbody>\n<tr>\n<th style=\"width: 125.178%;\" colspan=\"4\"><span style=\"color: #000000; font-family: Arial, '\u30d2\u30e9\u30ae\u30ce\u89d2\u30b4 ProN W3', 'Hiragino Kaku Gothic ProN', \u30e1\u30a4\u30ea\u30aa, Meiryo, sans-serif;\">\u5168\u6750\u8cea<\/span><\/th>\n<\/tr>\n<tr>\n<th style=\"width: 55.1785%;\">\u52a0\u5de5\u9650\u754c<\/th>\n<td style=\"width: 70%;\" colspan=\"3\">1.0<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-9108267 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"9108267\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-e8593f0\" data-id=\"e8593f0\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-bba6698 elementor-widget elementor-widget-heading\" data-id=\"bba6698\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h4 class=\"elementor-heading-title elementor-size-default\"><span style=\"text-decoration:underline\">\u300c\u9577\u7a74\u306e\u30b9\u30c8\u30ec\u30fc\u30c8\u90e8\u4ee5\u5916\u300d\u3068\u4ed6\u5f62\u72b6\u8981\u7d20<\/span><\/h4>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-9a45e47 elementor-section-full_width elementor-section-height-default elementor-section-height-default\" data-id=\"9a45e47\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-25 elementor-top-column elementor-element elementor-element-215baf4\" data-id=\"215baf4\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-4b21d9e elementor-widget elementor-widget-image\" data-id=\"4b21d9e\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img loading=\"lazy\" decoding=\"async\" width=\"219\" height=\"149\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/tgt04_fac_170.png\" class=\"attachment-full size-full wp-image-3083\" alt=\"\u5f62\u72b6\u4f8b\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-25 elementor-top-column elementor-element elementor-element-ffa0232\" data-id=\"ffa0232\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-bacb261 elementor-widget elementor-widget-image\" data-id=\"bacb261\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img loading=\"lazy\" decoding=\"async\" width=\"219\" height=\"149\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/tgt04_fac_171.png\" class=\"attachment-full size-full wp-image-3085\" alt=\"\u5f62\u72b6\u4f8b\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-25 elementor-top-column elementor-element elementor-element-770e4e6\" data-id=\"770e4e6\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap\">\n\t\t\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-25 elementor-top-column elementor-element elementor-element-3b33c9e\" data-id=\"3b33c9e\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap\">\n\t\t\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-8b8814a elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"8b8814a\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-817e807\" data-id=\"817e807\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-4efdda8 elementor-widget elementor-widget-text-editor\" data-id=\"4efdda8\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p style=\"text-align: right;\">[mm]<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-38d8da1 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"38d8da1\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-d8715e6\" data-id=\"d8715e6\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-4635db4 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"4635db4\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"table04 mt0 tableHover_single\">\n<tbody>\n<tr>\n<th style=\"width: 156.652%;\" colspan=\"4\"><span style=\"color: #000000; font-family: Arial, '\u30d2\u30e9\u30ae\u30ce\u89d2\u30b4 ProN W3', 'Hiragino Kaku Gothic ProN', \u30e1\u30a4\u30ea\u30aa, Meiryo, sans-serif;\">\u5168\u6750\u8cea<\/span><\/th>\n<\/tr>\n<tr>\n<th style=\"width: 78.0952%;\">\u52a0\u5de5\u9650\u754c<\/th>\n<td class=\"elementCenter\" style=\"width: 78.5571%;\" colspan=\"3\">1.0<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-f5d3de7 print_block elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"f5d3de7\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-802e7ca\" data-id=\"802e7ca\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-fe0fe4d elementor-widget elementor-widget-heading\" data-id=\"fe0fe4d\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h4 class=\"elementor-heading-title elementor-size-default\"><span style=\"text-decoration:underline\">\u300c\u30dd\u30b1\u30c3\u30c8\u5f62\u72b6\u306e\u30b9\u30c8\u30ec\u30fc\u30c8\u90e8\u300d\u3068\u4ed6\u5f62\u72b6\u8981\u7d20<\/span><\/h4>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<section class=\"elementor-section elementor-inner-section elementor-element elementor-element-1ae0155 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"1ae0155\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-25 elementor-inner-column elementor-element elementor-element-4534a21\" data-id=\"4534a21\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-a9d9bf0 elementor-widget elementor-widget-image\" data-id=\"a9d9bf0\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img loading=\"lazy\" decoding=\"async\" width=\"219\" height=\"155\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/tgt04_fac_172.png\" class=\"attachment-full size-full wp-image-3081\" alt=\"\u5f62\u72b6\u4f8b\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-25 elementor-inner-column elementor-element elementor-element-26ced5a\" data-id=\"26ced5a\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-9e65211 elementor-widget elementor-widget-image\" data-id=\"9e65211\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img loading=\"lazy\" decoding=\"async\" width=\"219\" height=\"156\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/tgt04_fac_173.png\" class=\"attachment-full size-full wp-image-3086\" alt=\"\u5f62\u72b6\u4f8b\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-25 elementor-inner-column elementor-element elementor-element-3b496b0\" data-id=\"3b496b0\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap\">\n\t\t\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-25 elementor-inner-column elementor-element elementor-element-2ff57b5\" data-id=\"2ff57b5\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap\">\n\t\t\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<div class=\"elementor-element elementor-element-f68fb41 elementor-widget elementor-widget-text-editor\" data-id=\"f68fb41\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p style=\"text-align: right;\">[mm]<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-408e4b3 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"408e4b3\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"table04 mt0 tableHover_single\">\n<tbody>\n<tr>\n<th style=\"width: 156.652%;\" colspan=\"4\"><span style=\"color: #000000; font-family: Arial, '\u30d2\u30e9\u30ae\u30ce\u89d2\u30b4 ProN W3', 'Hiragino Kaku Gothic ProN', \u30e1\u30a4\u30ea\u30aa, Meiryo, sans-serif;\">\u5168\u6750\u8cea<\/span><\/th>\n<\/tr>\n<tr>\n<th style=\"width: 78.0952%;\">\u52a0\u5de5\u9650\u754c<\/th>\n<td class=\"elementCenter\" style=\"width: 78.5571%;\" colspan=\"3\">1.0<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-1860a28 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"1860a28\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-326eb2b\" data-id=\"326eb2b\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-fa1603a elementor-widget elementor-widget-heading\" data-id=\"fa1603a\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h4 class=\"elementor-heading-title elementor-size-default\"><span style=\"text-decoration:underline\">\u300c\u30dd\u30b1\u30c3\u30c8\u5f62\u72b6\u306e\u30b9\u30c8\u30ec\u30fc\u30c8\u90e8\u4ee5\u5916\u300d\u3068\u4ed6\u5f62\u72b6\u8981\u7d20<\/span><\/h4>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<section class=\"elementor-section elementor-inner-section elementor-element elementor-element-4bf2834 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"4bf2834\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-25 elementor-inner-column elementor-element elementor-element-efabd63\" data-id=\"efabd63\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-6579048 elementor-widget elementor-widget-image\" data-id=\"6579048\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img loading=\"lazy\" decoding=\"async\" width=\"219\" height=\"152\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/tgt04_fac_174.png\" class=\"attachment-full size-full wp-image-3082\" alt=\"\u5f62\u72b6\u4f8b\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-25 elementor-inner-column elementor-element elementor-element-8163a8b\" data-id=\"8163a8b\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-a3ad502 elementor-widget elementor-widget-image\" data-id=\"a3ad502\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img loading=\"lazy\" decoding=\"async\" width=\"219\" height=\"152\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/tgt04_fac_175.png\" class=\"attachment-full size-full wp-image-3080\" alt=\"\u5f62\u72b6\u4f8b\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-25 elementor-inner-column elementor-element elementor-element-92cf896\" data-id=\"92cf896\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap\">\n\t\t\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-25 elementor-inner-column elementor-element elementor-element-16d3738\" data-id=\"16d3738\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap\">\n\t\t\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<div class=\"elementor-element elementor-element-4988a73 elementor-widget elementor-widget-text-editor\" data-id=\"4988a73\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p style=\"text-align: right;\">[mm]<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-933e5a9 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"933e5a9\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"table04 mt0 tableHover_single\">\n<tbody>\n<tr>\n<th style=\"width: 156.652%;\" colspan=\"4\"><span style=\"color: #000000; font-family: Arial, '\u30d2\u30e9\u30ae\u30ce\u89d2\u30b4 ProN W3', 'Hiragino Kaku Gothic ProN', \u30e1\u30a4\u30ea\u30aa, Meiryo, sans-serif;\">\u5168\u6750\u8cea<\/span><\/th>\n<\/tr>\n<tr>\n<th style=\"width: 78.0952%;\">\u52a0\u5de5\u9650\u754c<\/th>\n<td class=\"elementCenter\" style=\"width: 78.5571%;\" colspan=\"3\">1.0<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-1b567da elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"1b567da\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-6f3adfc\" data-id=\"6f3adfc\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-55a0d8a elementor-widget elementor-widget-heading\" data-id=\"55a0d8a\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h4 class=\"elementor-heading-title elementor-size-default\"><span style=\"text-decoration:underline\">\u300c\u7a74\u5148\u7aef\u300d\u3068\u4ed6\u5f62\u72b6\u8981\u7d20<\/span><\/h4>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<section class=\"elementor-section elementor-inner-section elementor-element elementor-element-18c38a9 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"18c38a9\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-25 elementor-inner-column elementor-element elementor-element-ca18844\" data-id=\"ca18844\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-cd3d1bf elementor-widget elementor-widget-image\" data-id=\"cd3d1bf\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img loading=\"lazy\" decoding=\"async\" width=\"100\" height=\"100\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/2b530e80c7d0de90885e285c5d798063-1-100x100.jpg\" class=\"attachment-thumb100 size-thumb100 wp-image-4901\" alt=\"\" srcset=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/2b530e80c7d0de90885e285c5d798063-1-100x100.jpg 100w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/2b530e80c7d0de90885e285c5d798063-1-150x150.jpg 150w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/2b530e80c7d0de90885e285c5d798063-1-200x200.jpg 200w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/2b530e80c7d0de90885e285c5d798063-1.jpg 284w\" sizes=\"(max-width: 100px) 100vw, 100px\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-25 elementor-inner-column elementor-element elementor-element-8baa4e4\" data-id=\"8baa4e4\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-9f1cf6e elementor-widget__width-initial elementor-widget elementor-widget-image\" data-id=\"9f1cf6e\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img loading=\"lazy\" decoding=\"async\" width=\"100\" height=\"100\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/c8856789ec11ab8b1013037cef6929f9-100x100.jpg\" class=\"attachment-thumb100 size-thumb100 wp-image-4902\" alt=\"\" srcset=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/c8856789ec11ab8b1013037cef6929f9-100x100.jpg 100w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/c8856789ec11ab8b1013037cef6929f9-150x150.jpg 150w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/c8856789ec11ab8b1013037cef6929f9-200x200.jpg 200w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/c8856789ec11ab8b1013037cef6929f9.jpg 284w\" sizes=\"(max-width: 100px) 100vw, 100px\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-25 elementor-inner-column elementor-element elementor-element-5fad0c3\" data-id=\"5fad0c3\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap\">\n\t\t\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-25 elementor-inner-column elementor-element elementor-element-c7029c2\" data-id=\"c7029c2\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap\">\n\t\t\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<div class=\"elementor-element elementor-element-ee51d77 elementor-widget elementor-widget-text-editor\" data-id=\"ee51d77\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p style=\"text-align: right;\">[mm]<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-772304a tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"772304a\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"table04 mt0 tableHover_single\">\n<tbody>\n<tr>\n<th style=\"width: 156.652%;\" colspan=\"4\"><span style=\"color: #000000; font-family: Arial, '\u30d2\u30e9\u30ae\u30ce\u89d2\u30b4 ProN W3', 'Hiragino Kaku Gothic ProN', \u30e1\u30a4\u30ea\u30aa, Meiryo, sans-serif;\">\u5168\u6750\u8cea<\/span><\/th>\n<\/tr>\n<tr>\n<th style=\"width: 78.0952%;\">\u52a0\u5de5\u9650\u754c<\/th>\n<td class=\"elementCenter\" style=\"width: 78.5571%;\" colspan=\"3\">2.0<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<\/div>\n\t\t\n\t\t\t<div id=\"daexthefu-container\"\n\t\t\t\tclass=\"daexthefu-container daexthefu-layout-stacked daexthefu-alignment-left\"\n\t\t\t\tdata-post-id=\"3348\">\n\n\t\t\t\t<div class=\"daexthefu-feedback\">\n\t\t\t\t\t<div class=\"daexthefu-text\">\n\t\t\t\t\t\t<h3 class=\"daexthefu-title\">\u3053\u306e\u8a18\u4e8b\u306f\u53c2\u8003\u306b\u306a\u308a\u307e\u3057\u305f\u304b\uff1f<\/h3>\n\t\t\t\t\t<\/div>\n\t\t\t\t\t<div class=\"daexthefu-buttons-container\">\n\t\t\t\t\t\t<div class=\"daexthefu-buttons\">\n\t\t\t\t\t\t\t\n\t\t\t<div class=\"daexthefu-yes daexthefu-button daexthefu-button-type-icon-and-text\" data-value=\"1\">\n\t\t\t\t<div class=\"daexthefu-button-icon\">\n\t\t\t\t\n                <svg>\n                    <defs>\n                        <style>.thumb-up-cls-1{fill:#c9c9c9;}.thumb-up-cls-2{fill:#e1e1e1;}.thumb-up-cls-3{fill:#676767;}<\/style>\n                    <\/defs>\n                    <g id=\"thumb_up\">\n                        <path class=\"thumb-up-cls-2 daexthefu-icon-circle\" d=\"m24,3c11.58,0,21,9.42,21,21s-9.42,21-21,21S3,35.58,3,24,12.42,3,24,3m0-1C11.85,2,2,11.85,2,24s9.85,22,22,22,22-9.85,22-22S36.15,2,24,2h0Z\" \/>\n                        <g>\n                            <rect class=\"thumb-up-cls-3 daexthefu-icon-secondary-color\" x=\"10\" y=\"20\" width=\"6\" height=\"15\" rx=\"1.5\" ry=\"1.5\" \/>\n                            <path class=\"thumb-up-cls-1 daexthefu-icon-primary-color\" d=\"m30.57,9.06l-.49-.1c-.81-.17-1.61.35-1.78,1.16l-5.3,11.74c-.17.81,3.16,1.61,3.97,1.78l1.96.41c.81.17,1.61-.35,1.78-1.16l2.18-10.27c.34-1.61-.7-3.21-2.31-3.56Z\" \/>\n                            <path class=\"thumb-up-cls-1 daexthefu-icon-primary-color\" d=\"m38.17,20h-18.67c-.83,0-1.5.67-1.5,1.5v12c0,.83.67,1.5,1.5,1.5h16.27c.71,0,1.33-.5,1.47-1.21l2.4-12c.19-.93-.53-1.8-1.47-1.8Z\" \/>\n                        <\/g>\n                    <\/g>\n                <\/svg>\t\t\t\t\t\t<\/div>\n\t\t\t\t<div class=\"daexthefu-button-text\">\u5f79\u306b\u7acb\u3063\u305f\uff01<\/div>\n\t\t\t<\/div>\n\n\t\t\t\t\t\t\t\t\t\t\n\t\t\t<div class=\"daexthefu-no daexthefu-button daexthefu-button-type-icon-and-text\" data-value=\"0\">\n\t\t\t\t<div class=\"daexthefu-button-icon\">\n\t\t\t\t\n                <svg>\n                    <defs>\n                        <style>.thumb-down-cls-1{fill:#c9c9c9;}.thumb-down-cls-2{fill:#e1e1e1;}.thumb-down-cls-3{fill:#676767;}<\/style>\n                    <\/defs>\n                    <g id=\"thumb_down\">\n                        <path class=\"thumb-down-cls-2 daexthefu-icon-circle\" d=\"m24,3c11.58,0,21,9.42,21,21s-9.42,21-21,21S3,35.58,3,24,12.42,3,24,3m0-1C11.85,2,2,11.85,2,24s9.85,22,22,22,22-9.85,22-22S36.15,2,24,2h0Z\" \/>\n                        <g>\n                            <rect class=\"thumb-down-cls-3 daexthefu-icon-secondary-color\" x=\"10\" y=\"13\" width=\"6\" height=\"15\" rx=\"1.5\" ry=\"1.5\" \/>\n                            <path class=\"thumb-down-cls-1 daexthefu-icon-primary-color\" d=\"m30.57,38.94l-.49.1c-.81.17-1.61-.35-1.78-1.16l-5.3-11.74c-.17-.81,3.16-1.61,3.97-1.78l1.96-.41c.81-.17,1.61.35,1.78,1.16l2.18,10.27c.34,1.61-.7,3.21-2.31,3.56Z\" \/>\n                            <path class=\"thumb-down-cls-1 daexthefu-icon-primary-color\" d=\"m38.17,28h-18.67c-.83,0-1.5-.67-1.5-1.5v-12c0-.83.67-1.5,1.5-1.5h16.27c.71,0,1.33.5,1.47,1.21l2.4,12c.19.93-.53,1.8-1.47,1.8Z\" \/>\n                        <\/g>\n                    <\/g>\n                <\/svg>\t\t\t\t\t\t<\/div>\n\t\t\t\t<div class=\"daexthefu-button-text\">\u5f79\u306b\u7acb\u305f\u306a\u304b\u3063\u305f<\/div>\n\t\t\t<\/div>\n\n\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\n\t\t\t\t<div class=\"daexthefu-comment\">\n\t\t\t\t\t<div class=\"daexthefu-comment-top-container\">\n\t\t\t\t\t\t<label id=\"daexthefu-comment-label\" class=\"daexthefu-comment-label\"><\/label>\n\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t\t<textarea id=\"daexthefu-comment-textarea\" class=\"daexthefu-comment-textarea\"\n\t\t\t\t\t\t\t\tplaceholder=\"\"\n\t\t\t\t\t\t\t\tmaxlength=\"\n\t\t\t\t\t\t\t\t400\t\t\t\t\t\t\t\t\t\"><\/textarea>\n\t\t\t\t\t<div class=\"daexthefu-comment-buttons-container\">\n\t\t\t\t\t\t<button class=\"daexthefu-comment-submit daexthefu-button\">\u9001\u4fe1<\/button>\n\t\t\t\t\t\t<button class=\"daexthefu-comment-cancel daexthefu-button\">\u53d6\u6d88<\/button>\n\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\n\t\t\t\t<div class=\"daexthefu-successful-submission-text\">\u8a55\u4fa1\u3044\u305f\u3060\u304d\u3042\u308a\u304c\u3068\u3046\u3054\u3056\u3044\u307e\u3057\u305f\u3002<\/div>\n\n\t\t\t<\/div>\n\n\t\t\t","protected":false},"excerpt":{"rendered":"<p>\u4ee5\u4e0b\u306e\u3088\u3046\u306b\u3001\u52a0\u5de5\u9650\u754c\u5024\u672a\u6e80\u306e\u8584\u8089\u304c\u5b58\u5728\u3059\u308b\u5834\u5408\u306f\u3001\u88fd\u4f5c\u6642\u306b\u7834\u308c\u3084\u3001\u5f62\u72b6\u304c\u6b6a\u3080\u3053\u3068\u3067\u516c\u5dee\u5916\u308c\u304c\u751f\u3058\u307e\u3059\u3002\u203b\u9650\u754c\u5024\u304c\u91cd\u8907\u3059\u308b\u5834\u5408\u306f\u5927\u304d\u3044\u5024\u3092\u512a\u5148\u81f4\u3057\u307e\u3059\u3002 \u9650\u754c\u5024\u3092\u4e0b\u56de\u308b\u5834\u5408\u306f\u753b\u9762\u4e0a\u306b\u300c\u54c1\u8cea\u540c\u610f\u4e8b\u9805\u300d\u304c\u8868\u793a\u3055\u308c\u307e\u3059\u306e\u3067\u30013 [&hellip;]<\/p>\n","protected":false},"author":15,"featured_media":0,"comment_status":"closed","ping_status":"closed","sticky":false,"template":"","format":"standard","meta":{"_helpful_status":1,"footnotes":""},"categories":[45],"tags":[65],"class_list":["post-3348","post","type-post","status-publish","format-standard","hentry","category-mpb_guideline","tag-technical_mpb"],"yoast_head":"<!-- This site is optimized with the Yoast SEO plugin v28.0 - https:\/\/yoast.com\/product\/yoast-seo-wordpress\/ -->\n<title>\u8584\u8089\u5224\u5b9a\u30ed\u30b8\u30c3\u30af | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb<\/title>\n<meta name=\"robots\" content=\"index, follow, max-snippet:-1, max-image-preview:large, max-video-preview:-1\" \/>\n<link rel=\"canonical\" href=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/mpb_guideline\/3348\/\" \/>\n<meta property=\"og:locale\" content=\"ja_JP\" \/>\n<meta property=\"og:type\" content=\"article\" \/>\n<meta property=\"og:title\" content=\"\u8584\u8089\u5224\u5b9a\u30ed\u30b8\u30c3\u30af | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\" \/>\n<meta property=\"og:description\" content=\"\u4ee5\u4e0b\u306e\u3088\u3046\u306b\u3001\u52a0\u5de5\u9650\u754c\u5024\u672a\u6e80\u306e\u8584\u8089\u304c\u5b58\u5728\u3059\u308b\u5834\u5408\u306f\u3001\u88fd\u4f5c\u6642\u306b\u7834\u308c\u3084\u3001\u5f62\u72b6\u304c\u6b6a\u3080\u3053\u3068\u3067\u516c\u5dee\u5916\u308c\u304c\u751f\u3058\u307e\u3059\u3002\u203b\u9650\u754c\u5024\u304c\u91cd\u8907\u3059\u308b\u5834\u5408\u306f\u5927\u304d\u3044\u5024\u3092\u512a\u5148\u81f4\u3057\u307e\u3059\u3002 \u9650\u754c\u5024\u3092\u4e0b\u56de\u308b\u5834\u5408\u306f\u753b\u9762\u4e0a\u306b\u300c\u54c1\u8cea\u540c\u610f\u4e8b\u9805\u300d\u304c\u8868\u793a\u3055\u308c\u307e\u3059\u306e\u3067\u30013 [&hellip;]\" \/>\n<meta property=\"og:url\" content=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/mpb_guideline\/3348\/\" \/>\n<meta property=\"og:site_name\" content=\"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\" \/>\n<meta property=\"article:published_time\" content=\"2021-04-30T06:07:50+00:00\" \/>\n<meta property=\"article:modified_time\" content=\"2025-09-29T01:28:20+00:00\" \/>\n<meta property=\"og:image\" content=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/tgt04_fac_156.png\" \/>\n<meta name=\"author\" content=\"\u7f8e\u7d00\" \/>\n<meta name=\"twitter:card\" content=\"summary_large_image\" \/>\n<script type=\"application\/ld+json\" class=\"yoast-schema-graph\">{\"@context\":\"https:\\\/\\\/schema.org\",\"@graph\":[{\"@type\":\"Article\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/mpb_guideline\\\/3348\\\/#article\",\"isPartOf\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/mpb_guideline\\\/3348\\\/\"},\"author\":{\"name\":\"\u7f8e\u7d00\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#\\\/schema\\\/person\\\/6ff70d9094b7fdc810efdfcc2fdb63c5\"},\"headline\":\"\u8584\u8089\u5224\u5b9a\u30ed\u30b8\u30c3\u30af\",\"datePublished\":\"2021-04-30T06:07:50+00:00\",\"dateModified\":\"2025-09-29T01:28:20+00:00\",\"mainEntityOfPage\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/mpb_guideline\\\/3348\\\/\"},\"wordCount\":36,\"publisher\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#organization\"},\"image\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/mpb_guideline\\\/3348\\\/#primaryimage\"},\"thumbnailUrl\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2020\\\/01\\\/tgt04_fac_156.png\",\"keywords\":[\"technical_mpb\"],\"articleSection\":[\"\u8a2d\u8a08\u30ac\u30a4\u30c9\u30e9\u30a4\u30f3\"],\"inLanguage\":\"ja\"},{\"@type\":\"WebPage\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/mpb_guideline\\\/3348\\\/\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/mpb_guideline\\\/3348\\\/\",\"name\":\"\u8584\u8089\u5224\u5b9a\u30ed\u30b8\u30c3\u30af | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\",\"isPartOf\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#website\"},\"primaryImageOfPage\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/mpb_guideline\\\/3348\\\/#primaryimage\"},\"image\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/mpb_guideline\\\/3348\\\/#primaryimage\"},\"thumbnailUrl\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2020\\\/01\\\/tgt04_fac_156.png\",\"datePublished\":\"2021-04-30T06:07:50+00:00\",\"dateModified\":\"2025-09-29T01:28:20+00:00\",\"breadcrumb\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/mpb_guideline\\\/3348\\\/#breadcrumb\"},\"inLanguage\":\"ja\",\"potentialAction\":[{\"@type\":\"ReadAction\",\"target\":[\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/mpb_guideline\\\/3348\\\/\"]}]},{\"@type\":\"ImageObject\",\"inLanguage\":\"ja\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/mpb_guideline\\\/3348\\\/#primaryimage\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2020\\\/01\\\/tgt04_fac_156.png\",\"contentUrl\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2020\\\/01\\\/tgt04_fac_156.png\",\"width\":219,\"height\":151,\"caption\":\"\u5f62\u72b6\u4f8b\"},{\"@type\":\"BreadcrumbList\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/mpb_guideline\\\/3348\\\/#breadcrumb\",\"itemListElement\":[{\"@type\":\"ListItem\",\"position\":1,\"name\":\"\u30db\u30fc\u30e0\",\"item\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/\"},{\"@type\":\"ListItem\",\"position\":2,\"name\":\"\u8584\u8089\u5224\u5b9a\u30ed\u30b8\u30c3\u30af\"}]},{\"@type\":\"WebSite\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#website\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/\",\"name\":\"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\",\"description\":\"\",\"publisher\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#organization\"},\"potentialAction\":[{\"@type\":\"SearchAction\",\"target\":{\"@type\":\"EntryPoint\",\"urlTemplate\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/?s={search_term_string}\"},\"query-input\":{\"@type\":\"PropertyValueSpecification\",\"valueRequired\":true,\"valueName\":\"search_term_string\"}}],\"inLanguage\":\"ja\"},{\"@type\":\"Organization\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#organization\",\"name\":\"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/\",\"logo\":{\"@type\":\"ImageObject\",\"inLanguage\":\"ja\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#\\\/schema\\\/logo\\\/image\\\/\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2019\\\/05\\\/A01-b_b4-1_jpeg.jpg\",\"contentUrl\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2019\\\/05\\\/A01-b_b4-1_jpeg.jpg\",\"width\":260,\"height\":70,\"caption\":\"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df\"},\"image\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#\\\/schema\\\/logo\\\/image\\\/\"}},{\"@type\":\"Person\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#\\\/schema\\\/person\\\/6ff70d9094b7fdc810efdfcc2fdb63c5\",\"name\":\"\u7f8e\u7d00\",\"image\":{\"@type\":\"ImageObject\",\"inLanguage\":\"ja\",\"@id\":\"https:\\\/\\\/secure.gravatar.com\\\/avatar\\\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g\",\"url\":\"https:\\\/\\\/secure.gravatar.com\\\/avatar\\\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g\",\"contentUrl\":\"https:\\\/\\\/secure.gravatar.com\\\/avatar\\\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g\",\"caption\":\"\u7f8e\u7d00\"},\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/author\\\/miki-aa3x-momosemisumi-co-jp\\\/\"}]}<\/script>\n<!-- \/ Yoast SEO plugin. -->","yoast_head_json":{"title":"\u8584\u8089\u5224\u5b9a\u30ed\u30b8\u30c3\u30af | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","robots":{"index":"index","follow":"follow","max-snippet":"max-snippet:-1","max-image-preview":"max-image-preview:large","max-video-preview":"max-video-preview:-1"},"canonical":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/mpb_guideline\/3348\/","og_locale":"ja_JP","og_type":"article","og_title":"\u8584\u8089\u5224\u5b9a\u30ed\u30b8\u30c3\u30af | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","og_description":"\u4ee5\u4e0b\u306e\u3088\u3046\u306b\u3001\u52a0\u5de5\u9650\u754c\u5024\u672a\u6e80\u306e\u8584\u8089\u304c\u5b58\u5728\u3059\u308b\u5834\u5408\u306f\u3001\u88fd\u4f5c\u6642\u306b\u7834\u308c\u3084\u3001\u5f62\u72b6\u304c\u6b6a\u3080\u3053\u3068\u3067\u516c\u5dee\u5916\u308c\u304c\u751f\u3058\u307e\u3059\u3002\u203b\u9650\u754c\u5024\u304c\u91cd\u8907\u3059\u308b\u5834\u5408\u306f\u5927\u304d\u3044\u5024\u3092\u512a\u5148\u81f4\u3057\u307e\u3059\u3002 \u9650\u754c\u5024\u3092\u4e0b\u56de\u308b\u5834\u5408\u306f\u753b\u9762\u4e0a\u306b\u300c\u54c1\u8cea\u540c\u610f\u4e8b\u9805\u300d\u304c\u8868\u793a\u3055\u308c\u307e\u3059\u306e\u3067\u30013 [&hellip;]","og_url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/mpb_guideline\/3348\/","og_site_name":"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","article_published_time":"2021-04-30T06:07:50+00:00","article_modified_time":"2025-09-29T01:28:20+00:00","og_image":[{"url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/tgt04_fac_156.png","type":"","width":"","height":""}],"author":"\u7f8e\u7d00","twitter_card":"summary_large_image","schema":{"@context":"https:\/\/schema.org","@graph":[{"@type":"Article","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/mpb_guideline\/3348\/#article","isPartOf":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/mpb_guideline\/3348\/"},"author":{"name":"\u7f8e\u7d00","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/person\/6ff70d9094b7fdc810efdfcc2fdb63c5"},"headline":"\u8584\u8089\u5224\u5b9a\u30ed\u30b8\u30c3\u30af","datePublished":"2021-04-30T06:07:50+00:00","dateModified":"2025-09-29T01:28:20+00:00","mainEntityOfPage":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/mpb_guideline\/3348\/"},"wordCount":36,"publisher":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#organization"},"image":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/mpb_guideline\/3348\/#primaryimage"},"thumbnailUrl":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/tgt04_fac_156.png","keywords":["technical_mpb"],"articleSection":["\u8a2d\u8a08\u30ac\u30a4\u30c9\u30e9\u30a4\u30f3"],"inLanguage":"ja"},{"@type":"WebPage","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/mpb_guideline\/3348\/","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/mpb_guideline\/3348\/","name":"\u8584\u8089\u5224\u5b9a\u30ed\u30b8\u30c3\u30af | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","isPartOf":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#website"},"primaryImageOfPage":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/mpb_guideline\/3348\/#primaryimage"},"image":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/mpb_guideline\/3348\/#primaryimage"},"thumbnailUrl":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/tgt04_fac_156.png","datePublished":"2021-04-30T06:07:50+00:00","dateModified":"2025-09-29T01:28:20+00:00","breadcrumb":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/mpb_guideline\/3348\/#breadcrumb"},"inLanguage":"ja","potentialAction":[{"@type":"ReadAction","target":["https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/mpb_guideline\/3348\/"]}]},{"@type":"ImageObject","inLanguage":"ja","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/mpb_guideline\/3348\/#primaryimage","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/tgt04_fac_156.png","contentUrl":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/tgt04_fac_156.png","width":219,"height":151,"caption":"\u5f62\u72b6\u4f8b"},{"@type":"BreadcrumbList","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/mpb_guideline\/3348\/#breadcrumb","itemListElement":[{"@type":"ListItem","position":1,"name":"\u30db\u30fc\u30e0","item":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/"},{"@type":"ListItem","position":2,"name":"\u8584\u8089\u5224\u5b9a\u30ed\u30b8\u30c3\u30af"}]},{"@type":"WebSite","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#website","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/","name":"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","description":"","publisher":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#organization"},"potentialAction":[{"@type":"SearchAction","target":{"@type":"EntryPoint","urlTemplate":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/?s={search_term_string}"},"query-input":{"@type":"PropertyValueSpecification","valueRequired":true,"valueName":"search_term_string"}}],"inLanguage":"ja"},{"@type":"Organization","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#organization","name":"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/","logo":{"@type":"ImageObject","inLanguage":"ja","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/logo\/image\/","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2019\/05\/A01-b_b4-1_jpeg.jpg","contentUrl":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2019\/05\/A01-b_b4-1_jpeg.jpg","width":260,"height":70,"caption":"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df"},"image":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/logo\/image\/"}},{"@type":"Person","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/person\/6ff70d9094b7fdc810efdfcc2fdb63c5","name":"\u7f8e\u7d00","image":{"@type":"ImageObject","inLanguage":"ja","@id":"https:\/\/secure.gravatar.com\/avatar\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g","url":"https:\/\/secure.gravatar.com\/avatar\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g","contentUrl":"https:\/\/secure.gravatar.com\/avatar\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g","caption":"\u7f8e\u7d00"},"url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/author\/miki-aa3x-momosemisumi-co-jp\/"}]}},"views":18011,"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts\/3348","targetHints":{"allow":["GET"]}}],"collection":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts"}],"about":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/types\/post"}],"author":[{"embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/users\/15"}],"replies":[{"embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/comments?post=3348"}],"version-history":[{"count":60,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts\/3348\/revisions"}],"predecessor-version":[{"id":34470,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts\/3348\/revisions\/34470"}],"wp:attachment":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/media?parent=3348"}],"wp:term":[{"taxonomy":"category","embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/categories?post=3348"},{"taxonomy":"post_tag","embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/tags?post=3348"}],"curies":[{"name":"wp","href":"https:\/\/api.w.org\/{rel}","templated":true}]}}
