{"id":33691,"date":"2025-12-15T00:00:45","date_gmt":"2025-12-14T15:00:45","guid":{"rendered":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/?p=33691"},"modified":"2026-10-05T10:27:20","modified_gmt":"2026-10-05T01:27:20","slug":"%e6%9d%90%e6%96%99%e3%81%ae%e7%89%b9%e6%80%a7-2","status":"publish","type":"post","link":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/tup_shape-material\/33691\/","title":{"rendered":"\u6750\u6599\u306e\u7279\u6027"},"content":{"rendered":"\t\t<div data-elementor-type=\"wp-post\" data-elementor-id=\"33691\" class=\"elementor elementor-33691\">\n\t\t\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-fd9e515 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"fd9e515\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-4209979\" data-id=\"4209979\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-9845011 elementor-widget elementor-widget-text-editor\" data-id=\"9845011\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<ul id=\"anchor\">\n<li><a href=\"#box1\">\u9244<\/a><\/li>\n<li><a href=\"#box2\">\u30a2\u30eb\u30df\u30cb\u30a6\u30e0<\/a><\/li>\n<li><a href=\"#box3\">\u30b9\u30c6\u30f3\u30ec\u30b9<\/a><\/li>\n<li><a href=\"#box4\">\u9285\u30fb\u771f\u936e<\/a><\/li>\n<li><a href=\"#box5\">\u6a39\u8102<\/a><\/li>\n<\/ul>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-60bf45f elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"60bf45f\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-e1a3f10\" data-id=\"e1a3f10\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-d684ade elementor-widget elementor-widget-menu-anchor\" data-id=\"d684ade\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"menu-anchor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t<div class=\"elementor-menu-anchor\" id=\"box1\"><\/div>\n\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-8de6295 elementor-widget elementor-widget-heading\" data-id=\"8de6295\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h2 class=\"elementor-heading-title elementor-size-default\">\u9244\n<\/h2>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-8d56c45 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"8d56c45\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\u6750\u8cea\u306e\u7279\u5fb4\n<table class=\"mT0 tableHover\">\n<tbody>\n<tr>\n<th>\u6750\u8cea<\/th>\n<th class=\"tblRowCFStyle01_33691\">\u7279\u5fb4<\/th>\n<\/tr>\n<tr>\n<td>SS400<\/td>\n<td class=\"tblFldCFStyle01_33691\">\u4e00\u822c\u69cb\u9020\u7528\u5727\u5ef6\u92fc\u6750\u3067\u65e5\u672c\u3067\u5e83\u304f\u4f7f\u7528\u3055\u308c\u3066\u3044\u308b\u6750\u6599\u3067\u3059\u3002\u5f15\u3063\u5f35\u308a\u5f37\u3055\u304c400N\/mm^2\u4ee5\u4e0a\u3042\u308b\u3053\u3068\u304c\u540d\u79f0\u306e\u7531\u6765\u306b\u306a\u308a\u307e\u3059\u3002\u7279\u5fb4\u306f\u4f4e\u30b3\u30b9\u30c8\u3067\u52a0\u5de5\u304c\u826f\u597d\u3067\u3042\u308b\u4e8b\u3067\u3059\u3002\u6a5f\u68b0\u3001\u5efa\u7bc9\u306a\u3069\u5e45\u5e83\u3044\u696d\u754c\u3067\u4f7f\u7528\u3055\u308c\u307e\u3059\u3002<\/td>\n<\/tr>\n<tr>\n<td>S45C<\/td>\n<td class=\"tblFldCFStyle01_33691\">\u70ad\u7d20\u3092\u7d040.45%\u542b\u3080\u69cb\u9020\u7528\u70ad\u7d20\u92fc\u3067\u3059\u3002\u6bd4\u8f03\u7684\u52a0\u5de5\u6027\u304c\u826f\u597d\u3067\u3001\u71b1\u51e6\u7406\uff08\u713c\u5165\u308c\u306a\u3069\uff09\u306b\u3088\u3063\u3066\u5f37\u5ea6\u3084\u8010\u6469\u8017\u6027\u3092\u5411\u4e0a\u3055\u305b\u308b\u3053\u3068\u304c\u53ef\u80fd\u3067\u3059\u3002\u30b7\u30e3\u30d5\u30c8\u3001\u30ae\u30a2\u3001\u30d4\u30f3\u306a\u3069\u306e\u6a5f\u68b0\u90e8\u54c1\u306b\u4f7f\u7528\u3055\u308c\u3066\u3044\u307e\u3059\u3002<\/td>\n<\/tr>\n<tr>\n<td>SCM415<\/td>\n<td class=\"tblFldCFStyle01_33691\">\u30af\u30ed\u30e0\u3068\u30e2\u30ea\u30d6\u30c7\u30f3\u3092\u6dfb\u52a0\u3057\u305f\u6a5f\u68b0\u69cb\u9020\u7528\u5408\u91d1\u92fc\u3067\u3001\u713c\u5165\u308c\u306b\u3088\u308b\u9ad8\u3044\u8010\u6469\u8017\u6027\u3068\u976d\u6027\u3092\u5099\u3048\u3066\u3044\u307e\u3059\u3002\u6b6f\u8eca\u3084\u8ef8\u90e8\u54c1\u306a\u3069\u3001\u8010\u4e45\u6027\u3068\u8010\u885d\u6483\u6027\u304c\u6c42\u3081\u3089\u308c\u308b\u7528\u9014\u306b\u9069\u3057\u3066\u3044\u307e\u3059\u3002<\/td>\n<\/tr>\n<tr>\n<td>SCM420H<\/td>\n<td class=\"tblFldCFStyle01_33691\">\u30af\u30ed\u30e0\u3068\u30e2\u30ea\u30d6\u30c7\u30f3\u3092\u6dfb\u52a0\u3057\u305f\u6a5f\u68b0\u69cb\u9020\u7528\u5408\u91d1\u92fc\u3067\u3001\u713c\u5165\u308c\u306b\u3088\u308a\u8868\u9762\u786c\u5ea6\u3068\u8010\u6469\u8017\u6027\u3092\u9ad8\u3081\u3089\u308c\u308b\u6750\u6599\u3067\u3059\u3002\u6b6f\u8eca\u3001\u30b7\u30e3\u30d5\u30c8\u3001\u30ab\u30e0\u306a\u3069\u3001\u9ad8\u3044\u5f37\u5ea6\u3068\u8010\u4e45\u6027\u304c\u6c42\u3081\u3089\u308c\u308b\u6a5f\u68b0\u90e8\u54c1\u306b\u9069\u3057\u3066\u3044\u307e\u3059\u3002<\/td>\n<\/tr>\n<tr>\n<td>SCM435<\/td>\n<td class=\"tblFldCFStyle01_33691\">\u30af\u30ed\u30e0\u3068\u30e2\u30ea\u30d6\u30c7\u30f3\u3092\u6dfb\u52a0\u3057\u305f\u5408\u91d1\u92fc\u3067\u3001\u9ad8\u3044\u5f37\u5ea6\u3068\u976d\u6027\u3092\u517c\u306d\u5099\u3048\u3066\u3044\u307e\u3059\u3002\u713c\u5165\u308c\u6027\u304c\u826f\u597d\u3067\u3001\u71b1\u51e6\u7406\u306b\u3088\u3063\u3066\u5f37\u5ea6\u3084\u8010\u6469\u8017\u6027\u3092\u5411\u4e0a\u3055\u305b\u308b\u3053\u3068\u304c\u53ef\u80fd\u3067\u3059\u3002\u4e3b\u306b\u9ad8\u5f37\u5ea6\u30dc\u30eb\u30c8\u3001\u30b7\u30e3\u30d5\u30c8\u3001\u30ae\u30a2\u306a\u3069\u306e\u6a5f\u68b0\u90e8\u54c1\u306b\u4f7f\u7528\u3055\u308c\u3066\u3044\u307e\u3059\u3002<\/td>\n<\/tr>\n<tr>\n<td>SCM440<\/td>\n<td class=\"tblFldCFStyle01_33691\">\u9ad8\u3044\u5f37\u5ea6\u3068\u976d\u6027\u3092\u517c\u306d\u63c3\u3048\u308b\u6750\u6599\u3067\u3059\u3002\u7279\u5fb4\u306f\u3001\u71b1\u51e6\u7406\uff08\u713c\u5165\u308c\u306a\u3069\uff09\u3092\u3059\u308b\u3053\u3068\u306b\u3088\u308a\u3001\u5f37\u5ea6\u3084\u8010\u6469\u8017\u6027\u3092\u5411\u4e0a\u3067\u304d\u307e\u3059\u3002\u5f37\u5ea6\u3084\u8010\u4e45\u6027\u304c\u6c42\u3081\u3089\u308c\u308b\u88fd\u54c1\u306b\u5411\u3044\u3066\u3044\u307e\u3059\u3002\u4e3b\u306b\u81ea\u52d5\u8eca\u3084\u6a5f\u68b0\u90e8\u54c1\u696d\u754c\u3067\u4f7f\u7528\u3055\u308c\u307e\u3059\u3002<\/td>\n<\/tr>\n<tr>\n<td>SKS3<\/td>\n<td class=\"tblFldCFStyle01_33691\">\u51b7\u9593\u52a0\u5de5\u7528\u306e\u5408\u91d1\u5de5\u5177\u92fc\u3067\u3001\u9ad8\u786c\u5ea6\u30fb\u9ad8\u8010\u6469\u8017\u6027\u3092\u6301\u3063\u3066\u3044\u307e\u3059\u3002\u976d\u6027\u3082\u6bd4\u8f03\u7684\u826f\u597d\u3067\u3001\u305b\u3093\u65ad\u5203\u3001\u30d1\u30f3\u30c1\u3001\u30c0\u30a4\u30b9\u3001\u30b2\u30fc\u30b8\u306a\u3069\u306e\u51b7\u9593\u91d1\u578b\u90e8\u54c1\u306b\u4f7f\u7528\u3055\u308c\u3066\u3044\u307e\u3059\u3002<\/td>\n<\/tr>\n<tr>\n\t\t<td>SKH51<\/td>\n\t\t<td class=\"tblFldCFStyle01_33691\">\u30bf\u30f3\u30b0\u30b9\u30c6\u30f3\u3001\u30e2\u30ea\u30d6\u30c7\u30f3\u3001\u30d0\u30ca\u30b8\u30a6\u30e0\u306a\u3069\u3092\u542b\u3080\u9ad8\u901f\u5ea6\u5de5\u5177\u92fc\u3067\u3059\u3002\u9ad8\u3044\u786c\u5ea6\u3068\u8010\u6469\u8017\u6027\u3092\u6301\u3061\u3001\u5207\u524a\u5de5\u5177\u3084\u91d1\u578b\u90e8\u54c1\u306a\u3069\u3001\u6469\u8017\u3078\u306e\u8010\u4e45\u6027\u304c\u6c42\u3081\u3089\u308c\u308b\u7528\u9014\u306b\u9069\u3057\u3066\u3044\u307e\u3059\u3002<\/td>\n\t<\/tr>\n<tr>\n<td>SKD11<\/td>\n<td class=\"tblFldCFStyle01_33691\">\u5408\u91d1\u5de5\u5177\u92fc\u306e\u4e00\u7a2e\u3067\u3059\u3002\u7279\u5fb4\u306f\u3001\u9ad8\u3044\u786c\u5ea6\u3068\u8010\u6469\u8017\u6027\u3092\u6709\u3057\u3066\u3044\u307e\u3059\u3002\u71b1\u51e6\u7406\uff08\u713c\u5165\u308c\u306a\u3069\uff09\u3092\u3059\u308b\u3053\u3068\u306b\u3088\u308a\u3001\u5f37\u5ea6\u3084\u8010\u6469\u8017\u6027\u306e\u5411\u4e0a\u304c\u53ef\u80fd\u3067\u3059\u3002\u30b9\u30c6\u30f3\u30ec\u30b9\u306b\u306f\u52a3\u308a\u307e\u3059\u304c\u3001\u6bd4\u8f03\u7684\u9ad8\u3044\u8010\u98df\u6027\u304c\u3042\u308a\u307e\u3059\u3002\u4e3b\u306b\u91d1\u578b\u3084\u6cbb\u5177\u3001\u30b2\u30fc\u30b8\u306a\u3069\u306e\u786c\u5ea6\u3084\u8010\u6469\u8017\u6027\u304c\u8981\u6c42\u3055\u308c\u308b\u88fd\u54c1\u306b\u4f7f\u7528\u3055\u308c\u307e\u3059\u3002<\/td>\n<\/tr>\n<tr>\n<td>SKD61<\/td>\n<td class=\"tblFldCFStyle01_33691\">\u71b1\u9593\u30c0\u30a4\u30b9\u92fc\u3067\u3001\u30af\u30ed\u30e0\uff08Cr\uff09\u3001\u30e2\u30ea\u30d6\u30c7\u30f3\uff08Mo\uff09\u3001\u30d0\u30ca\u30b8\u30a6\u30e0\uff08V\uff09\u3092\u6dfb\u52a0\u3057\u305f\u5408\u91d1\u5de5\u5177\u92fc\u3067\u3059\u3002\u9ad8\u6e29\u74b0\u5883\u4e0b\u3067\u3082\u5f37\u5ea6\u3092\u4fdd\u3061\u3001\u71b1\u75b2\u52b4\u3084\u71b1\u4e80\u88c2\u306b\u5f37\u3044\u7279\u6027\u3092\u6301\u3063\u3066\u3044\u307e\u3059\u3002\u713c\u5165\u308c\u30fb\u713c\u623b\u3057\u306b\u3088\u308b\u71b1\u51e6\u7406\u306b\u3088\u3063\u3066\u8010\u4e45\u6027\u304c\u5411\u4e0a\u3057\u3001\u5bf8\u6cd5\u5b89\u5b9a\u6027\u3082\u826f\u597d\u3067\u3059\u3002<\/td>\n<\/tr>\n<tr>\n<td>SUJ2<\/td>\n<td class=\"tblFldCFStyle01_33691\">\u9ad8\u70ad\u7d20\u30af\u30ed\u30e0\u8ef8\u53d7\u92fc\u3067\u3001\u975e\u5e38\u306b\u9ad8\u3044\u786c\u5ea6\u3068\u8010\u6469\u8017\u6027\u3092\u6301\u3063\u3066\u3044\u307e\u3059\u3002\u713c\u5165\u308c\u6027\u304c\u826f\u597d\u3067\u3001\u5bf8\u6cd5\u7cbe\u5ea6\u304c\u6c42\u3081\u3089\u308c\u308b\u7528\u9014\u306b\u9069\u3057\u3066\u3044\u307e\u3059\u3002\u4e3b\u306b\u30d9\u30a2\u30ea\u30f3\u30b0\u3001\u30ed\u30fc\u30e9\u30fc\u3001\u30b2\u30fc\u30b8\u3001\u7cbe\u5bc6\u6a5f\u68b0\u90e8\u54c1\u306a\u3069\u306b\u4f7f\u7528\u3055\u308c\u3066\u3044\u307e\u3059\u3002<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-88f8560 tblBasic print_block elementor-widget elementor-widget-text-editor\" data-id=\"88f8560\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\u6750\u8cea\u306e\u7279\u6027\u3000\u203b\u4e0b\u8a18\u7279\u6027\u5024\u306f\u53c2\u8003\u5024\u3067\u3042\u308a\u4fdd\u8a3c\u5024\u3067\u306f\u3042\u308a\u307e\u305b\u3093\n<table class=\"mT0 tableHover tblCFStyle01_33691 tableHover\">\n<tbody>\n<tr>\n<th>\u6750\u8cea<\/th>\n<th>\n<div>\u5f15\u5f35\u5f37\u3055<\/div>\n(N\/mm2)<\/th>\n<th>\n<div>\u8010\u529b<\/div>\n(N\/mm2)<\/th>\n<th>\n<div>\u7834\u65ad\u4f38\u3073<\/div>\n%<\/th>\n<th>\n<div>\u66f2\u3052\u5f37\u3055<\/div>\n(N\/mm2)<\/th>\n<th>\n<div>\u5727\u7e2e\u5f37\u3055<\/div>\n(N\/mm2)<\/th>\n<th>\n<div>\u964d\u4f0f\u70b9<\/div>\n(N\/mm2)<\/th>\n<th>\n<div>\u30e4\u30f3\u30b0\u7387<\/div>\n(N\/mm2)<\/th>\n<th>\n<div>\u66f2\u3052\u5f3e\u6027\u7387<\/div>\n(N\/mm2)<\/th>\n<th>\u6bd4\u91cd<\/th>\n<th>\n<div>\u5c0e\u96fb\u7387<\/div>\n(S\/m)<\/th>\n<th>\n<div>\u71b1\u4f1d\u5c0e\u7387<\/div>\n(W\/m\u30fbK)<\/th>\n<th>\n<div>\u7dda\u81a8\u5f35\u4fc2\u6570<\/div>\n(\/\u2103)<\/th>\n<\/tr>\n<tr>\n<th>SS400<\/th>\n<td>400~510<\/td>\n<td>215~355<\/td>\n<td>21\u4ee5\u4e0a<\/td>\n<td>360~485<\/td>\n<td>380~485<\/td>\n<td>245~355<\/td>\n<td>2.0\u00d710\u2075<\/td>\n<td>2.0\u00d710\u2075<\/td>\n<td>7.87<\/td>\n<td>6.96\u00d710\u2076<\/td>\n<td>58<\/td>\n<td>11.7\u00d710\u207b\u2076<\/td>\n<\/tr>\n<tr>\n<th>S45C<\/th>\n<td>570~750<\/td>\n<td>330~490<\/td>\n<td>20\u4ee5\u4e0a<\/td>\n<td>600<\/td>\n<td>600<\/td>\n<td>330~490<\/td>\n<td>2.0\u00d710\u2075<\/td>\n<td>2.0\u00d710\u2075<\/td>\n<td>7.87<\/td>\n<td>6.0\u00d710\u2076<\/td>\n<td>45<\/td>\n<td>11.9\u00d710\u207b\u2076<\/td>\n<\/tr>\n<tr>\n<th>SCM415<\/th>\n<td>880\u4ee5\u4e0a<\/td>\n<td>685\u4ee5\u4e0a<\/td>\n<td>12\u4ee5\u4e0a<\/td>\n<td>900<\/td>\n<td>900<\/td>\n<td>&#8211;<\/td>\n<td>2.1\u00d710\u2075<\/td>\n<td>2.1\u00d710\u2075<\/td>\n<td>7.85<\/td>\n<td>6.0\u00d710\u2076<\/td>\n<td>42<\/td>\n<td>11.7\u00d710\u207b\u2076<\/td>\n<\/tr>\n<tr>\n<th>SCM420H<\/th>\n<td>930\u4ee5\u4e0a<\/td>\n<td>785\u4ee5\u4e0a<\/td>\n<td>12\u4ee5\u4e0a<\/td>\n<td>950<\/td>\n<td>950<\/td>\n<td>&#8211;<\/td>\n<td>2.1\u00d710\u2075<\/td>\n<td>2.1\u00d710\u2075<\/td>\n<td>7.85<\/td>\n<td>6.0\u00d710\u2076<\/td>\n<td>42<\/td>\n<td>11.7\u00d710\u207b\u2076<\/td>\n<\/tr>\n<tr>\n<th>SCM435<\/th>\n<td>900~1050<\/td>\n<td>750~900<\/td>\n<td>15\u4ee5\u4e0a<\/td>\n<td>950<\/td>\n<td>950<\/td>\n<td>750~900<\/td>\n<td>2.1\u00d710\u2075<\/td>\n<td>2.1\u00d710\u2075<\/td>\n<td>7.85<\/td>\n<td>6.0\u00d710\u2076<\/td>\n<td>42<\/td>\n<td>11.0\u00d710\u207b\u2076<\/td>\n<\/tr>\n<tr>\n<th>SCM440<\/th>\n<td>950~1100<\/td>\n<td>800~950<\/td>\n<td>12\u4ee5\u4e0a<\/td>\n<td>1000<\/td>\n<td>1000<\/td>\n<td>800~950<\/td>\n<td>2.1\u00d710\u2075<\/td>\n<td>2.1\u00d710\u2075<\/td>\n<td>7.85<\/td>\n<td>6.0\u00d710\u2076<\/td>\n<td>42.7<\/td>\n<td>11.0\u00d710\u207b\u2076<\/td>\n<\/tr>\n<tr>\n<th>SKS3<\/th>\n<td>1000~1300<\/td>\n<td>850~1100<\/td>\n<td>10\u4ee5\u4e0a<\/td>\n<td>1100<\/td>\n<td>1100<\/td>\n<td>850~1100<\/td>\n<td>2.1\u00d710\u2075<\/td>\n<td>2.1\u00d710\u2075<\/td>\n<td>7.85<\/td>\n<td>4.5\u00d710\u2076<\/td>\n<td>25<\/td>\n<td>12.2\u00d710\u207b\u2076<\/td>\n<\/tr>\n<tr>\n\t\t<th>SKH51<\/th>\n\t\t<td>2100\u4ee5\u4e0a<\/td>\n\t\t<td>1800\u4ee5\u4e0a<\/td>\n\t\t<td>1\u301c3<\/td>\n\t\t<td>2500<\/td>\n\t\t<td>2500<\/td>\n\t\t<td>1800\u4ee5\u4e0a<\/td>\n\t\t<td>2.1\u00d710\u2075<\/td>\n\t\t<td>2.1\u00d710\u2075<\/td>\n\t\t<td>8.17<\/td>\n\t\t<td>1.8\u00d710\u2076<\/td>\n\t\t<td>25<\/td>\n\t\t<td>11.0\u00d710\u207b\u2076<\/td>\n\t<\/tr>\n<tr>\n<th>SKD11<\/th>\n<td>1800~2000<\/td>\n<td>1500~1700<\/td>\n<td>5\u4ee5\u4e0a<\/td>\n<td>1900<\/td>\n<td>1900<\/td>\n<td>1500~1700<\/td>\n<td>2.1\u00d710\u2075<\/td>\n<td>2.1\u00d710\u2075<\/td>\n<td>7.8<\/td>\n<td>4.0\u00d710\u2076<\/td>\n<td>20<\/td>\n<td>12\u00d710\u207b\u2076<\/td>\n<\/tr>\n<tr>\n<th>SKD61<\/th>\n<td>1200~1400<\/td>\n<td>1000~1200<\/td>\n<td>10\u4ee5\u4e0a<\/td>\n<td>1300<\/td>\n<td>1300<\/td>\n<td>1000~1200<\/td>\n<td>2.1\u00d710\u2075<\/td>\n<td>2.1\u00d710\u2075<\/td>\n<td>7.73<\/td>\n<td>4.0\u00d710\u2076<\/td>\n<td>25<\/td>\n<td>13.3\u00d710\u207b\u2076<\/td>\n<\/tr>\n<tr>\n<th>SUJ2<\/th>\n<td>1570~1960<\/td>\n<td>700~850<\/td>\n<td>10\u4ee5\u4e0a<\/td>\n<td>900<\/td>\n<td>900<\/td>\n<td>700~850<\/td>\n<td>2.1\u00d710\u2075<\/td>\n<td>2.1\u00d710\u2075<\/td>\n<td>7.8<\/td>\n<td>6.0\u00d710\u2076<\/td>\n<td>46.6<\/td>\n<td>12.5\u00d710\u207b\u2076<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-b0a63b8 print_block elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"b0a63b8\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-6138ee8\" data-id=\"6138ee8\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-a4186ce elementor-widget elementor-widget-menu-anchor\" data-id=\"a4186ce\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"menu-anchor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t<div class=\"elementor-menu-anchor\" id=\"box2\"><\/div>\n\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-e2a0a84 elementor-widget elementor-widget-heading\" data-id=\"e2a0a84\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h2 class=\"elementor-heading-title elementor-size-default\">\u30a2\u30eb\u30df\u30cb\u30a6\u30e0\n<\/h2>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-ee74db5 tblBasic print_block elementor-widget elementor-widget-text-editor\" data-id=\"ee74db5\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\u6750\u8cea\u306e\u7279\u5fb4\n<table class=\"mT0 tableHover\">\n<tbody>\n<tr>\n<th>\u6750\u8cea<\/th>\n<th class=\"tblRowCFStyle01_33691\">\u7279\u5fb4<\/th>\n<\/tr>\n<tr>\n<td>A1050<\/td>\n<td class=\"tblFldCFStyle01_33691\">\u7d14\u5ea6\u306e\u9ad8\u3044\u30a2\u30eb\u30df\u30cb\u30a6\u30e0\u6750\u3067\u3001\u512a\u308c\u305f\u8010\u98df\u6027\u3001\u71b1\u4f1d\u5c0e\u6027\u304a\u3088\u3073\u96fb\u6c17\u4f1d\u5c0e\u6027\u3092\u5099\u3048\u3066\u3044\u307e\u3059\u3002\u5c0e\u96fb\u30fb\u653e\u71b1\u6027\u304c\u6c42\u3081\u3089\u308c\u308b\u90e8\u54c1\u306b\u9069\u3057\u3066\u3044\u307e\u3059\u3002<\/td>\n<\/tr>\n<tr>\n<td>A2017<\/td>\n<td class=\"tblFldCFStyle01_33691\">\u300c\u30b8\u30e5\u30e9\u30eb\u30df\u30f3\u300d\u3068\u547c\u3070\u308c\u3001\u5207\u524a\u6027\u3068\u5f37\u5ea6\u3092\u5099\u3048\u305f\u30a2\u30eb\u30df\u5408\u91d1\u3067\u3059\u3002\u9285\u3092\u542b\u3080\u305f\u3081\u4ed6\u306e\u30a2\u30eb\u30df\u5408\u91d1\u3068\u6bd4\u8f03\u3057\u3066\u8010\u98df\u6027\u306b\u306f\u3084\u3084\u52a3\u308a\u307e\u3059\u3002\u512a\u308c\u305f\u5f37\u5ea6\u3092\u6709\u3057\u3066\u304a\u308a\u3001\u822a\u7a7a\u6a5f\u3084\u8eca\u4e21\u306a\u3069\u306e\u90e8\u54c1\u306b\u5e83\u304f\u4f7f\u7528\u3055\u308c\u3066\u3044\u307e\u3059\u3002<\/td>\n<\/tr>\n<tr>\n<td>A5052<\/td>\n<td class=\"tblFldCFStyle01_33691\">A5056\u3068\u6bd4\u8f03\u3057\u30de\u30b0\u30cd\u30b7\u30a6\u30e0\u304c\u4f4e\u304f\u6dfb\u52a0\u3055\u308c\u3066\u304a\u308a\u3001\u6210\u5f62\u6027\u30fb\u6eb6\u63a5\u6027\u306b\u512a\u308c\u307e\u3059\u3002\u8010\u98df\u6027\u3082\u9ad8\u304f\u3001\u30a2\u30eb\u30df\u5408\u91d1\u5168\u4f53\u306e\u4e2d\u3067\u4e2d\u7a0b\u5ea6\u306e\u5f37\u5ea6\u3092\u6301\u3061\u3001\u6d41\u901a\u91cf\u3082\u591a\u3044\u4e00\u822c\u7684\u306a\u6750\u8cea\u3067\u3059\u3002<\/td>\n<\/tr>\n<tr>\n<td>A5056<\/td>\n<td class=\"tblFldCFStyle01_33691\">\u30de\u30b0\u30cd\u30b7\u30a6\u30e0\u3092\u591a\u304f\u542b\u3080\u30a2\u30eb\u30df\u30cb\u30a6\u30e0\u5408\u91d1\u3067\u3001\u8010\u98df\u6027\u30fb\u5f37\u5ea6\u30fb\u6eb6\u63a5\u6027\u306b\u512a\u308c\u3066\u3044\u307e\u3059\u3002\u7279\u306b\u4e38\u68d2\u6750\u3068\u3057\u3066\u5e83\u304f\u6d41\u901a\u3057\u3066\u304a\u308a\u3001\u62bc\u51fa\u3057\u52a0\u5de5\u6027\u304c\u826f\u597d\u3067\u3001\u69cb\u9020\u6750\u3084\u30d5\u30ec\u30fc\u30e0\u3001\u652f\u67f1\u306a\u3069\u306b\u4f7f\u7528\u3055\u308c\u3066\u3044\u307e\u3059\u3002<\/td>\n<\/tr>\n<tr>\n<td>A6061<\/td>\n<td class=\"tblFldCFStyle01_33691\">\u8010\u98df\u6027\u3068\u71b1\u51e6\u7406\u6027\u3092\u9ad8\u3081\u305f\u30a2\u30eb\u30df\u5408\u91d1\u3067\u3059\u3002\u8010\u98df\u6027\u306f\u30a2\u30eb\u30df\u5408\u91d1\u306e\u4e2d\u3067\u30c8\u30c3\u30d7\u30af\u30e9\u30b9\u3067\u3059\u3002\u7279\u306bT6\u51e6\u7406\uff08\u4eba\u5de5\u6642\u52b9\u786c\u5316\uff09\u3092\u65bd\u3059\u3053\u3068\u3067\u3001\u9ad8\u3044\u5f15\u5f35\u5f37\u3055\u3068\u8010\u529b\u3092\u5f97\u308b\u3053\u3068\u304c\u3067\u304d\u307e\u3059\u3002\u6d77\u6c34\u3084\u5c4b\u5916\u74b0\u5883\u3067\u306e\u4f7f\u7528\u306b\u6700\u3082\u9069\u3057\u3066\u3044\u307e\u3059\u3002<\/td>\n<\/tr>\n<tr>\n<td>A7050<\/td>\n<td class=\"tblFldCFStyle01_33691\">\u9ad8\u3044\u5f37\u5ea6\u3068\u8010\u5fdc\u529b\u8150\u98df\u5272\u308c\u6027\u3092\u5099\u3048\u305f\u30a2\u30eb\u30df\u30cb\u30a6\u30e0\u5408\u91d1\u3067\u3059\u3002\u822a\u7a7a\u6a5f\u90e8\u54c1\u3092\u306f\u3058\u3081\u3001\u8efd\u91cf\u5316\u3068\u9ad8\u5f37\u5ea6\u306e\u4e21\u7acb\u304c\u6c42\u3081\u3089\u308c\u308b\u7528\u9014\u306b\u9069\u3057\u3066\u3044\u307e\u3059\u3002<\/td>\n<\/tr>\n<tr>\n<td>A7075<\/td>\n<td class=\"tblFldCFStyle01_33691\">\u300c\u8d85\u3005\u30b8\u30e5\u30e9\u30eb\u30df\u30f3\u300d\u3068\u3082\u547c\u3070\u308c\u3001\u512a\u308c\u305f\u5f37\u5ea6\u3068\u8efd\u91cf\u6027\u3092\u4e21\u7acb\u3057\u305f\u30a2\u30eb\u30df\u5408\u91d1\u3067\u3059\u3002\u71b1\u51e6\u7406\u6027\u306b\u3082\u512a\u308c\u3001\u5f37\u5ea6\u3084\u885d\u6483\u3078\u306e\u8010\u6027\u306f\u30a2\u30eb\u30df\u30cb\u30a6\u30e0\u5408\u91d1\u306e\u4e2d\u3067\u3082\u30c8\u30c3\u30d7\u30af\u30e9\u30b9\u3067\u3059\u3002\u8efd\u91cf\u5316\u3068\u9ad8\u3044\u5f37\u5ea6\u304c\u6c42\u3081\u3089\u308c\u308b\u7528\u9014\u306b\u6700\u9069\u306a\u6750\u6599\u3067\u3059\u3002<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-feda49e tblBasic print_block elementor-widget elementor-widget-text-editor\" data-id=\"feda49e\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\u6750\u8cea\u306e\u7279\u6027\u3000\u203b\u4e0b\u8a18\u7279\u6027\u5024\u306f\u53c2\u8003\u5024\u3067\u3042\u308a\u4fdd\u8a3c\u5024\u3067\u306f\u3042\u308a\u307e\u305b\u3093\n<table class=\"mT0 tableHover tblCFStyle01_33691\">\n<tbody>\n<tr>\n<th>\u6750\u8cea<\/th>\n<th>\u5f15\u5f35\u5f37\u3055(N\/mm2)<\/th>\n<th>\u8010\u529b(N\/mm2)<\/th>\n<th>\u7834\u65ad\u4f38\u3073\u3000%<\/th>\n<th>\u66f2\u3052\u5f37\u3055(N\/mm2)<\/th>\n<th>\u5727\u7e2e\u5f37\u3055(N\/mm2)<\/th>\n<th>\u964d\u4f0f\u70b9\n(N\/mm2)<\/th>\n<th>\u30e4\u30f3\u30b0\u7387\n(N\/mm2)<\/th>\n<th>\u66f2\u3052\u5f3e\u6027\u7387\n(N\/mm2)<\/th>\n<th>\u6bd4\u91cd<\/th>\n<th>\u5c0e\u96fb\u7387\n(S\/m)<\/th>\n<th>\u71b1\u4f1d\u5c0e\u7387\n(W\/m\u30fbK)<\/th>\n<th>\u7dda\u81a8\u5f35\u4fc2\u6570\n(\/\u2103)<\/th>\n<\/tr>\n<tr>\n<th>A1050<\/th>\n<td>95<\/td>\n<td>35<\/td>\n<td>40<\/td>\n<td>95<\/td>\n<td>95<\/td>\n<td>35<\/td>\n<td>0.69\u00d710\u2075<\/td>\n<td>0.69\u00d710\u2075<\/td>\n<td>2.71<\/td>\n<td>3.5\u00d710\u2077<\/td>\n<td>222<\/td>\n<td>23.5\u00d710\u207b\u2076<\/td>\n<\/tr>\n<tr>\n<th>A2017<\/th>\n<td>390~500<\/td>\n<td>250~350<\/td>\n<td>10~18<\/td>\n<td>450<\/td>\n<td>450<\/td>\n<td>250~350<\/td>\n<td>7.2\u00d710\u2074<\/td>\n<td>7.2\u00d710\u2074<\/td>\n<td>2.79<\/td>\n<td>2.0\u00d710\u2077<\/td>\n<td>130<\/td>\n<td>23.6\u00d710\u207b\u2076<\/td>\n<\/tr>\n<tr>\n<th>A5052<\/th>\n<td>210~265<\/td>\n<td>125~190<\/td>\n<td>12~20<\/td>\n<td>230<\/td>\n<td>230<\/td>\n<td>125~190<\/td>\n<td>7.0\u00d710\u2074<\/td>\n<td>7.0\u00d710\u2074<\/td>\n<td>2.68<\/td>\n<td>2.5\u00d710\u2077<\/td>\n<td>138<\/td>\n<td>23.8\u00d710\u207b\u2076<\/td>\n<\/tr>\n<tr>\n<th>A5056<\/th>\n<td>290~350<\/td>\n<td>200~270<\/td>\n<td>10~20<\/td>\n<td>320<\/td>\n<td>320<\/td>\n<td>200~270<\/td>\n<td>7.0\u00d710\u2074<\/td>\n<td>7.0\u00d710\u2074<\/td>\n<td>2.66<\/td>\n<td>2.5\u00d710\u2077<\/td>\n<td>130<\/td>\n<td>23.8\u00d710\u207b\u2076<\/td>\n<\/tr>\n<tr>\n<th>A6061<\/th>\n<td>260~310<\/td>\n<td>240~270<\/td>\n<td>8~15<\/td>\n<td>280<\/td>\n<td>280<\/td>\n<td>240~270<\/td>\n<td>6.9\u00d710\u2074<\/td>\n<td>6.9\u00d710\u2074<\/td>\n<td>2.7<\/td>\n<td>2.5\u00d710\u2077<\/td>\n<td>167<\/td>\n<td>23.6\u00d710\u207b\u2076<\/td>\n<\/tr>\n<tr>\n\t\t<th>A7050<\/th>\n\t\t<td>540<\/td>\n\t\t<td>470<\/td>\n\t\t<td>10<\/td>\n\t\t<td>620<\/td>\n\t\t<td>620<\/td>\n\t\t<td>470<\/td>\n\t\t<td>0.72\u00d710\u2075<\/td>\n\t\t<td>0.72\u00d710\u2075<\/td>\n\t\t<td>2.83<\/td>\n\t\t<td>1.9\u00d710\u2077<\/td>\n\t\t<td>130<\/td>\n\t\t<td>23.3\u00d710\u207b\u2076<\/td>\n\t<\/tr>\n<tr>\n<th>A7075<\/th>\n<td>510~580<\/td>\n<td>430~500<\/td>\n<td>7~12<\/td>\n<td>550<\/td>\n<td>550<\/td>\n<td>430~500<\/td>\n<td>7.1\u00d710\u2074<\/td>\n<td>7.1\u00d710\u2074<\/td>\n<td>2.8<\/td>\n<td>2.0\u00d710\u2077<\/td>\n<td>130<\/td>\n<td>23.6\u00d710\u207b\u2076<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-41f191b print_block elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"41f191b\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-5d3872f\" data-id=\"5d3872f\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-2b4b1c6 elementor-widget elementor-widget-menu-anchor\" data-id=\"2b4b1c6\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"menu-anchor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t<div class=\"elementor-menu-anchor\" id=\"box3\"><\/div>\n\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-ad59d7b elementor-widget elementor-widget-heading\" data-id=\"ad59d7b\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h2 class=\"elementor-heading-title elementor-size-default\">\u30b9\u30c6\u30f3\u30ec\u30b9\n<\/h2>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-4e99bf9 tblBasic print_block elementor-widget elementor-widget-text-editor\" data-id=\"4e99bf9\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\u6750\u8cea\u306e\u7279\u5fb4\n<table class=\"mT0 tableHover\">\n<tbody>\n<tr>\n<th>\u6750\u8cea<\/th>\n<th class=\"tblRowCFStyle01_33691\">\u7279\u5fb4<\/th>\n<\/tr>\n<tr>\n<td>SUS303<\/td>\n<td class=\"tblFldCFStyle01_33691\">\u5207\u524a\u6027\u3068\u52a0\u5de5\u6027\u3092\u5411\u4e0a\u3055\u305b\u305f\u30aa\u30fc\u30b9\u30c6\u30ca\u30a4\u30c8\u7cfb\u30b9\u30c6\u30f3\u30ec\u30b9\u92fc\u3067\u3059\u3002\u9ad8\u3044\u8010\u98df\u6027\u3068\u5f37\u5ea6\u3092\u4fdd\u3061\u306a\u304c\u3089\u3001\u512a\u308c\u305f\u5207\u524a\u6027\u3092\u6709\u3059\u308b\u305f\u3081\u3001\u8907\u96d1\u5f62\u72b6\u306e\u90e8\u54c1\u52a0\u5de5\u306b\u9069\u3057\u3066\u3044\u307e\u3059\u3002\u8010\u98df\u6027\u3084\u6eb6\u63a5\u6027\u306f\u3001SUS304\u306b\u52a3\u308a\u307e\u3059\u3002\u30dc\u30eb\u30c8\u3084\u30b7\u30e3\u30d5\u30c8\u306a\u3069\u306e\u5358\u4e00\u90e8\u54c1\u306b\u5e83\u304f\u4f7f\u7528\u3055\u308c\u307e\u3059\u3002<\/td>\n<\/tr>\n<tr>\n<td>SUS304<\/td>\n<td class=\"tblFldCFStyle01_33691\">\u8010\u98df\u6027\u3068\u6eb6\u63a5\u6027\u3092\u5411\u4e0a\u3055\u305b\u305f\u30aa\u30fc\u30b9\u30c6\u30ca\u30a4\u30c8\u7cfb\u30b9\u30c6\u30f3\u30ec\u30b9\u92fc\u3067\u3059\u3002\u7528\u9014\u306e\u5e83\u3055\u3068\u5165\u624b\u306e\u3057\u3084\u3059\u3055\u304b\u3089\u6c4e\u7528\u6027\u304c\u9ad8\u304f\u3001\u3055\u307e\u3056\u307e\u306a\u5206\u91ce\u3067\u5e83\u304f\u4f7f\u7528\u3055\u308c\u307e\u3059\u3002\u9ad8\u3044\u8010\u98df\u6027\u3068\u5f37\u5ea6\u3092\u4fdd\u3061\u3064\u3064\u512a\u308c\u305f\u6eb6\u63a5\u6027\u3092\u6709\u3057\u3066\u3044\u308b\u305f\u3081\u3001\u8a2d\u5099\u6a5f\u5668\u306a\u3069\u3078\u306e\u5229\u7528\u304c\u591a\u304f\u898b\u3089\u308c\u307e\u3059\u3002<\/td>\n<\/tr>\n<tr>\n<td>SUS316<\/td>\n<td class=\"tblFldCFStyle01_33691\">SUS304\u306b\u8010\u98df\u6027\u3001\u8010\u5b54\u98df\u6027\u3092\u5411\u4e0a\u3055\u305b\u305f\u30aa\u30fc\u30b9\u30c6\u30ca\u30a4\u30c8\u7cfb\u30b9\u30c6\u30f3\u30ec\u30b9\u92fc\u3067\u3059\u3002\u6cbf\u5cb8\u90e8\u306a\u3069\u6d77\u6c34\u3092\u542b\u3080\u6c34\u306b\u89e6\u308c\u308b\u7b87\u6240\u3001\u6f6e\u98a8\u306e\u5f71\u97ff\u3092\u53d7\u3051\u308b\u74b0\u5883\u3067\u3001\u8150\u98df\u3057\u305f\u969b\u306b\u91cd\u5927\u306a\u6b20\u9665\u306b\u7e4b\u304c\u308b\u6050\u308c\u304c\u3042\u308b\u53ef\u80fd\u6027\u306e\u3042\u308b\u3068\u3053\u308d\u306b\u9069\u3057\u3066\u3044\u307e\u3059\u3002<\/td>\n<\/tr>\n<tr>\n<td>SUS316L<\/td>\n<td class=\"tblFldCFStyle01_33691\">SUS316\u3088\u308a\u70ad\u7d20\u91cf\u304c\u4f4e\u304f\u3001\u8010\u7c92\u754c\u8150\u98df\u6027\uff08\u7d50\u6676\u3068\u7d50\u6676\u306e\u5883\u754c\u9762\u306b\u6cbf\u3063\u305f\u8150\u98df\u3078\u306e\u8010\u6027\uff09\u304c\u9ad8\u3044\u305f\u3081\u6d77\u6c34\u3092\u306f\u3058\u3081\u3068\u3059\u308b\u8010\u98df\u6027\u3001\u8010\u5b54\u98df\u6027\u304c\u5fc5\u8981\u306a\u5834\u6240\u3067\u4f7f\u7528\u3055\u308c\u3066\u3044\u307e\u3059\u3002<\/td>\n<\/tr>\n<tr>\n<td>SUS440C<\/td>\n<td class=\"tblFldCFStyle01_33691\">\u30b9\u30c6\u30f3\u30ec\u30b9\u92fc\u306e\u4e2d\u3067\u3082\u6700\u9ad8\u786c\u5ea6\u3092\u6301\u3063\u3066\u3044\u307e\u3059\u3002\u713c\u5165\u308c\u51e6\u7406\u306b\u3088\u3063\u3066\u9ad8\u5f37\u5ea6\u30fb\u9ad8\u786c\u5ea6\u30fb\u8010\u6469\u8017\u6027\u304c\u5f97\u3089\u308c\u308b\u305f\u3081\u3001\u8010\u4e45\u6027\u304c\u6c42\u3081\u3089\u308c\u308b\u6a5f\u68b0\u90e8\u54c1\u3084\u7cbe\u5bc6\u90e8\u54c1\u306b\u9069\u3057\u3066\u3044\u307e\u3059\u3002\u4e3b\u306a\u7528\u9014\u306f\u30d9\u30a2\u30ea\u30f3\u30b0\u3001\u30b7\u30e3\u30d5\u30c8\u3001\u30d4\u30f3\u3001\u5de5\u5177\u90e8\u54c1\u3001\u91d1\u578b\u90e8\u54c1\u306a\u3069\u3067\u3059\u3002<\/td>\n<\/tr>\n<tr>\n<td>SUS630<\/td>\n<td class=\"tblFldCFStyle01_33691\">\u71b1\u51e6\u7406\u306b\u3088\u308a\u9ad8\u3044\u5f37\u5ea6\u3068\u786c\u5ea6\u3092\u5f97\u3089\u308c\u308b\u6790\u51fa\u786c\u5316\u7cfb\u30b9\u30c6\u30f3\u30ec\u30b9\u92fc\u3067\u3059\u3002\u8010\u98df\u6027\u3068\u6a5f\u68b0\u7684\u5f37\u5ea6\u3092\u517c\u306d\u5099\u3048\u3001\u30b7\u30e3\u30d5\u30c8\u3084\u6a5f\u68b0\u90e8\u54c1\u306a\u3069\u9ad8\u5f37\u5ea6\u304c\u6c42\u3081\u3089\u308c\u308b\u7528\u9014\u306b\u9069\u3057\u3066\u3044\u307e\u3059\u3002<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-8fe26ca tblBasic print_block elementor-widget elementor-widget-text-editor\" data-id=\"8fe26ca\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\u6750\u8cea\u306e\u7279\u6027\u3000\u203b\u4e0b\u8a18\u7279\u6027\u5024\u306f\u53c2\u8003\u5024\u3067\u3042\u308a\u4fdd\u8a3c\u5024\u3067\u306f\u3042\u308a\u307e\u305b\u3093\n<table class=\"mT0 tableHover tblCFStyle01_33691\">\n<tbody>\n<tr>\n<th>\u6750\u8cea<\/th>\n<th>\u5f15\u5f35\u5f37\u3055(N\/mm2)<\/th>\n<th>\u8010\u529b(N\/mm2)<\/th>\n<th>\u7834\u65ad\u4f38\u3073\u3000%<\/th>\n<th>\u66f2\u3052\u5f37\u3055(N\/mm2)<\/th>\n<th>\u5727\u7e2e\u5f37\u3055(N\/mm2)<\/th>\n<th>\u964d\u4f0f\u70b9\n(N\/mm2)<\/th>\n<th>\u30e4\u30f3\u30b0\u7387\n(N\/mm2)<\/th>\n<th>\u66f2\u3052\u5f3e\u6027\u7387\n(N\/mm2)<\/th>\n<th>\u6bd4\u91cd<\/th>\n<th>\u5c0e\u96fb\u7387\n(S\/m)<\/th>\n<th>\u71b1\u4f1d\u5c0e\u7387\n(W\/m\u30fbK)<\/th>\n<th>\u7dda\u81a8\u5f35\u4fc2\u6570\n(\/\u2103)<\/th>\n<\/tr>\n<tr>\n<th>SUS303<\/th>\n<td>520~750<\/td>\n<td>205\u4ee5\u4e0a<\/td>\n<td>40~60<\/td>\n<td>600<\/td>\n<td>600<\/td>\n<td>205~310<\/td>\n<td>1.93\u00d710\u2075<\/td>\n<td>\u22481.93\u00d710\u2075<\/td>\n<td>7.93<\/td>\n<td>1.4\u00d710\u2076<\/td>\n<td>16.2<\/td>\n<td>17.3\u00d710\u207b\u2076<\/td>\n<\/tr>\n<tr>\n<th>SUS304<\/th>\n<td>520~750<\/td>\n<td>205\u4ee5\u4e0a<\/td>\n<td>40~60<\/td>\n<td>600<\/td>\n<td>600<\/td>\n<td>205~310<\/td>\n<td>1.93\u00d710\u2075<\/td>\n<td>\u22481.93\u00d710\u2075<\/td>\n<td>7.93<\/td>\n<td>1.4\u00d710\u2076<\/td>\n<td>16.2<\/td>\n<td>17.3\u00d710\u207b\u2076<\/td>\n<\/tr>\n<tr>\n<th>SUS316<\/th>\n<td>520~700<\/td>\n<td>205\u4ee5\u4e0a<\/td>\n<td>40~60<\/td>\n<td>580<\/td>\n<td>580<\/td>\n<td>200~300<\/td>\n<td>1.93\u00d710\u2075<\/td>\n<td>\u22481.93\u00d710\u2075<\/td>\n<td>7.98<\/td>\n<td>1.3\u00d710\u2076<\/td>\n<td>13<\/td>\n<td>15.9\u00d710\u207b\u2076<\/td>\n<\/tr>\n<tr>\n<th>SUS316L<\/th>\n<td>480~680<\/td>\n<td>177\u4ee5\u4e0a<\/td>\n<td>45~65<\/td>\n<td>560<\/td>\n<td>560<\/td>\n<td>170~280<\/td>\n<td>1.93\u00d710\u2075<\/td>\n<td>1.93\u00d710\u2075<\/td>\n<td>7.98<\/td>\n<td>1.3\u00d710\u2076<\/td>\n<td>13<\/td>\n<td>15.9\u00d710\u207b\u2076<\/td>\n<\/tr>\n<tr>\n<th>SUS440C<\/th>\n<td>1900~2100<\/td>\n<td>1500\u4ee5\u4e0a<\/td>\n<td>5~10<\/td>\n<td>2000<\/td>\n<td>2000<\/td>\n<td>1500~1700<\/td>\n<td>2.0\u00d710\u2075<\/td>\n<td>\u22482.0\u00d710\u2075<\/td>\n<td>7.7<\/td>\n<td>0.8\u00d710\u2076<\/td>\n<td>24<\/td>\n<td>10.\uff12\u00d710\u207b\u2076<\/td>\n<\/tr>\n<tr>\n\t\t<th>SUS630<\/th>\n\t\t<td>930\u4ee5\u4e0a<\/td>\n\t\t<td>725\u4ee5\u4e0a<\/td>\n\t\t<td>10<\/td>\n\t\t<td>930\u4ee5\u4e0a<\/td>\n\t\t<td>930\u4ee5\u4e0a<\/td>\n\t\t<td>790\u4ee5\u4e0a<\/td>\n\t\t<td>2.0\u00d710\u2075<\/td>\n\t\t<td>2.0\u00d710\u2075<\/td>\n\t\t<td>7.78<\/td>\n\t\t<td>1.2\u00d710\u2076<\/td>\n\t\t<td>16.3<\/td>\n\t\t<td>10.8\u00d710\u207b\u2076<\/td>\n\t<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-db3bef4 print_block elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"db3bef4\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-3ccb702\" data-id=\"3ccb702\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-5457496 elementor-widget elementor-widget-menu-anchor\" data-id=\"5457496\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"menu-anchor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t<div class=\"elementor-menu-anchor\" id=\"box4\"><\/div>\n\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-3dd426a elementor-widget elementor-widget-heading\" data-id=\"3dd426a\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h2 class=\"elementor-heading-title elementor-size-default\">\u9285\u30fb\u771f\u936e\n<\/h2>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-c4f5915 tblBasic print_block elementor-widget elementor-widget-text-editor\" data-id=\"c4f5915\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\u6750\u8cea\u306e\u7279\u5fb4\n<table class=\"mT0 tableHover\">\n<tbody>\n<tr>\n<th>\u6750\u8cea<\/th>\n<th class=\"tblRowCFStyle01_33691\">\u7279\u5fb4<\/th>\n<\/tr>\n<tr>\n<td>C3604-LCd\n\uff08\u771f\u936e\u30fb\u9ec4\u9285\uff09<\/td>\n<td class=\"tblFldCFStyle01_33691\">\u771f\u936e\u3068\u547c\u3070\u308c\u308b\u9285\u3068\u4e9c\u925b\u306e\u5408\u91d1\u3067\u3059\u3002C2801\u3068\u6bd4\u8f03\u3057\u3066\u5207\u524a\u62b5\u6297\u304c\u5c11\u306a\u304f\u3001\u5207\u524a\u6642\u306e\u5207\u7c89\u304c\u5206\u65ad\u3055\u308c\u308b\u6027\u8cea\u3092\u6301\u3061\u307e\u3059\u3002C2801\u3088\u308a\u3001\u7cbe\u5bc6\u90e8\u54c1\u306b\u9069\u3057\u3066\u3044\u307e\u3059\u3002<\/td>\n<\/tr>\n\n<tr>\n<td>\u30af\u30ed\u30e0\u9285<\/td>\n<td class=\"tblFldCFStyle01_33691\">\u9285\u306e\u9ad8\u3044\u5c0e\u96fb\u6027\u30fb\u71b1\u4f1d\u5c0e\u6027\u3092\u7dad\u6301\u3057\u306a\u304c\u3089\u3001\u5f37\u5ea6\u3068\u8010\u6469\u8017\u6027\u3092\u5411\u4e0a\u3055\u305b\u305f\u9285\u5408\u91d1\u3067\u3059\u3002\u96fb\u6975\u90e8\u54c1\u3084\u901a\u96fb\u90e8\u54c1\u3001\u653e\u71b1\u6027\u3068\u8010\u4e45\u6027\u304c\u6c42\u3081\u3089\u308c\u308b\u7528\u9014\u306b\u9069\u3057\u3066\u3044\u307e\u3059\u3002<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-85c50cf tblBasic print_block elementor-widget elementor-widget-text-editor\" data-id=\"85c50cf\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\u6750\u8cea\u306e\u7279\u6027\u3000\u203b\u4e0b\u8a18\u7279\u6027\u5024\u306f\u53c2\u8003\u5024\u3067\u3042\u308a\u4fdd\u8a3c\u5024\u3067\u306f\u3042\u308a\u307e\u305b\u3093\n<table class=\"mT0 tableHover tblCFStyle01_33691\">\n<tbody>\n<tr>\n<th>\u6750\u8cea<\/th>\n<th>\n<div>\u5f15\u5f35\u5f37\u3055<\/div>\n(N\/mm2)<\/th>\n<th>\n<div>\u8010\u529b<\/div>\n(N\/mm2)<\/th>\n<th>\n<div>\u7834\u65ad\u4f38\u3073<\/div>\n%<\/th>\n<th>\n<div>\u66f2\u3052\u5f37\u3055<\/div>\n(N\/mm2)<\/th>\n<th>\n<div>\u5727\u7e2e\u5f37\u3055<\/div>\n(N\/mm2)<\/th>\n<th>\n<div>\u964d\u4f0f\u70b9<\/div>\n(N\/mm2)<\/th>\n<th>\n<div>\u30e4\u30f3\u30b0\u7387<\/div>\n(N\/mm2)<\/th>\n<th>\n<div>\u66f2\u3052\u5f3e\u6027\u7387<\/div>\n(N\/mm2)<\/th>\n<th>\u6bd4\u91cd<\/th>\n<th>\n<div>\u5c0e\u96fb\u7387<\/div>\n(S\/m)<\/th>\n<th>\n<div>\u71b1\u4f1d\u5c0e\u7387<\/div>\n(W\/m\u30fbK)<\/th>\n<th>\n<div>\u7dda\u81a8\u5f35\u4fc2\u6570<\/div>\n(\/\u2103)<\/th>\n<\/tr>\n<tr>\n<th>C3604-LCd\n\uff08\u771f\u936e\u30fb\u9ec4\u9285\uff09<\/th>\n<td>335~540<\/td>\n<td>270~410<\/td>\n<td>\u226710<\/td>\n<td>\u30fc<\/td>\n<td>400~450<\/td>\n<td>\u30fc<\/td>\n<td>96000<\/td>\n<td>1.0\u00d710\u2075<\/td>\n<td>8.43<\/td>\n<td>1.51\u00d710\u2077<\/td>\n<td>117<\/td>\n<td>20.5\u00d710\u207b\u2076<\/td>\n<\/tr>\n<tr>\n\t\t<th>\u30af\u30ed\u30e0\u9285<\/th>\n\t\t<td>380\u4ee5\u4e0a<\/td>\n\t\t<td>&#8211;<\/td>\n\t\t<td>15\u4ee5\u4e0a<\/td>\n\t\t<td>&#8211;<\/td>\n\t\t<td>&#8211;<\/td>\n\t\t<td>400<\/td>\n\t\t<td>1.3\u00d710\u2075<\/td>\n\t\t<td>1.3\u00d710\u2075<\/td>\n\t\t<td>8.89<\/td>\n\t\t<td>4.7\u00d710\u2077<\/td>\n\t\t<td>320<\/td>\n\t\t<td>&#8211;<\/td>\n\t<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-428e357 print_block elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"428e357\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-686ddac\" data-id=\"686ddac\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-41e462d elementor-widget elementor-widget-menu-anchor\" data-id=\"41e462d\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"menu-anchor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t<div class=\"elementor-menu-anchor\" id=\"box5\"><\/div>\n\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-3fade22 elementor-widget elementor-widget-heading\" data-id=\"3fade22\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h2 class=\"elementor-heading-title elementor-size-default\">\u6a39\u8102\n<\/h2>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-efd0212 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"efd0212\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\u6750\u8cea\u306e\u7279\u5fb4\n<div>\n<div class=\"tableStickyHead\">\n<table class=\"mT0\">\n<tbody>\n<tr>\n<th>\u6750\u8cea<\/th>\n<th class=\"tblRowCFStyle02_33691\">\u7279\u5fb4<\/th>\n<th>\u5916\u89b3<\/th>\n<\/tr>\n<\/tbody>\n<\/table>\n<\/div>\n<table class=\"mT0 tableHover print_break\">\n<tbody>\n<tr>\n<td>\u30dd\u30ea\u30a2\u30bb\u30bf\u30fc\u30eb\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u767d\uff09<\/td>\n<td class=\"tblFldCFStyle01_33691 tblRowCFStyle02_33691\" rowspan=\"2\">POM\u3084\u30b8\u30e5\u30e9\u30b3\u30f3\u3068\u547c\u3070\u308c\u308b\u30a8\u30f3\u30b8\u30cb\u30a2\u30ea\u30f3\u30b0\u30d7\u30e9\u30b9\u30c1\u30c3\u30af\u306e\u4e00\u7a2e\u3067\u3059\u3002\u6a5f\u68b0\u7684\u5f37\u5ea6\u3001\u8010\u6469\u8017\u6027\u3001\u8010\u85ac\u54c1\u6027\u304c\u9ad8\u3044\u3067\u3059\u3002\u52a0\u5de5\u6027\u306b\u512a\u308c\u4f4e\u30b3\u30b9\u30c8\u3067\u3059\u3002MC\u30ca\u30a4\u30ed\u30f3\u3068\u6bd4\u8f03\u3057\u3066\u5438\u6c34\u6027\u304c\u4f4e\u304f\u8010\u6469\u8017\u6027\u3082\u9ad8\u3044\u3053\u3068\u304b\u3089\u9577\u671f\u4f7f\u7528\u6642\u306e\u5bf8\u6cd5\u5b89\u5b9a\u6027\u306b\u512a\u308c\u307e\u3059\u3002<\/td>\n<td><img decoding=\"async\" class=\"imgCFStyle01_33691\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/06\/12590_02_B.png\" alt=\"\u30dd\u30ea\u30a2\u30bb\u30bf\u30fc\u30eb\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u767d\uff09\u306e\u5916\u89b3\" \/><\/td>\n<\/tr>\n<tr>\n<td>\u30dd\u30ea\u30a2\u30bb\u30bf\u30fc\u30eb\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u9ed2\uff09<\/td>\n<td><img decoding=\"async\" class=\"imgCFStyle01_33691\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/06\/12590_03_B.png\" alt=\"\u30dd\u30ea\u30a2\u30bb\u30bf\u30fc\u30eb\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u9ed2\uff09\u306e\u5916\u89b3\" \/><\/td>\n<\/tr>\n<tr>\n<td>MC\u30ca\u30a4\u30ed\u30f3\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u9752\uff09<\/td>\n<td class=\"tblFldCFStyle01_33691\" rowspan=\"2\">\u6a5f\u68b0\u7684\u5f37\u5ea6\u3001\u5316\u5b66\u7684\u6027\u8cea\u3001\u71b1\u7684\u7279\u6027\u3001\u8010\u6469\u8017\u6027\u306b\u512a\u308c\u3001\u5f37\u9178\u4ee5\u5916\u306e\u85ac\u54c1\u306b\u5bfe\u3057\u3066\u8010\u6027\u3092\u6301\u3061\u307e\u3059\u3002\u5438\u6c34\u6027\u304c\u9ad8\u3044\u305f\u3081\u5bf8\u6cd5\u5b89\u5b9a\u6027\u306b\u52a3\u308a\u307e\u3059\u3002<\/td>\n<td><img decoding=\"async\" class=\"imgCFStyle01_33691\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/06\/12590_04_B.png\" alt=\"MC\u30ca\u30a4\u30ed\u30f3\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u9752\uff09\u306e\u5916\u89b3\" \/><\/td>\n<\/tr>\n<tr>\n<td>MC\u30ca\u30a4\u30ed\u30f3\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u30a2\u30a4\u30dc\u30ea\u30fc\uff09<\/td>\n<td><img decoding=\"async\" class=\"imgCFStyle01_33691\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/07\/12590_30.png\" alt=\"MC\u30ca\u30a4\u30ed\u30f3\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u30a2\u30a4\u30dc\u30ea\u30fc\uff09\u306e\u5916\u89b3\" \/><\/td>\n<\/tr>\n<tr>\n<td>MC\u30ca\u30a4\u30ed\u30f3\uff08\u8010\u4faf\u30fb\u9ed2\u7070\uff09<\/td>\n<td class=\"tblFldCFStyle01_33691\">MC\u30ca\u30a4\u30ed\u30f3\u306b\u5bfe\u5019\u6027\u3092\u6301\u305f\u305b\u305f\u30b0\u30ec\u30fc\u30c9\u6750\u3067\u3059\u3002\u5c4b\u5916\u4f7f\u7528\u6642\u306e\u52a3\u5316\u8010\u6027\u304c\u7279\u5fb4\u3067\u3059\u3002\u8010\u5019\u6027\u306b\u306f\u512a\u308c\u307e\u3059\u304c\u3001MC\u30ca\u30a4\u30ed\u30f3\u306e\u6027\u8cea\u4e0a\u5438\u6c34\u6027\u3092\u6301\u3064\u305f\u3081\u96e8\u304c\u5f53\u305f\u308b\u5834\u6240\u3067\u4f7f\u7528\u3059\u308b\u5834\u5408\u5bf8\u6cd5\u5909\u5316\u306b\u6ce8\u610f\u3092\u8981\u3057\u307e\u3059\u3002<\/td>\n<td><img decoding=\"async\" class=\"imgCFStyle01_33691\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/06\/12590_05_B.png\" alt=\"MC\u30ca\u30a4\u30ed\u30f3\uff08\u8010\u4faf\u30fb\u9ed2\u7070\uff09\u306e\u5916\u89b3\" \/><\/td>\n<\/tr>\n<tr>\n<td>MC\u30ca\u30a4\u30ed\u30f3\uff08\u5e2f\u96fb\u9632\u6b62\u30fb\u9ed2\uff09[MC501CD R6]<\/td>\n<td class=\"tblFldCFStyle01_33691\">MC\u30ca\u30a4\u30ed\u30f3\u306e\u5c0e\u96fb\u6027\u3092\u6301\u305f\u305b\u305f\u30b0\u30ec\u30fc\u30c9\u6750\u3067\u3059\u3002\u4f53\u7a4d\u62b5\u6297\u7387\u306f1\uff5e100\u2126\u30fbm\u3067\u3059\u3002MC\u30ca\u30a4\u30ed\u30f3\u306e\u6027\u8cea\u4e0a\u5438\u6c34\u6027\u3092\u6301\u3064\u305f\u3081\u96e8\u304c\u5f53\u305f\u308b\u5834\u6240\u3067\u4f7f\u7528\u3059\u308b\u5834\u5408\u5bf8\u6cd5\u5909\u5316\u306b\u6ce8\u610f\u3092\u8981\u3057\u307e\u3059\u3002MC\u30ca\u30a4\u30ed\u30f3\uff08\u5e2f\u96fb\u9632\u6b62\u30fb\u9ed2\uff09\u3088\u308a\u9ad8\u4fa1\u3067\u3059\u3002<\/td>\n<td><img decoding=\"async\" class=\"imgCFStyle01_33691\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/07\/12590_31.png\" alt=\"MC\u30ca\u30a4\u30ed\u30f3\uff08\u5e2f\u96fb\u9632\u6b62\u30fb\u9ed2\uff09[MC501CD R6]\u306e\u5916\u89b3\" \/><\/td>\n<\/tr>\n<tr>\n<td>MC\u30ca\u30a4\u30ed\u30f3\uff08\u5c0e\u96fb\u30fb\u9ed2\uff09[MC501CD R2]<\/td>\n<td class=\"tblFldCFStyle01_33691\">MC\u30ca\u30a4\u30ed\u30f3\u306b\u5c0e\u96fb\u6027\u3092\u6301\u305f\u305b\u5e2f\u96fb\u3092\u9632\u6b62\u3057\u305f\u30b0\u30ec\u30fc\u30c9\u6750\u3067\u3059\u3002\u4f53\u7a4d\u62b5\u6297\u7387\u306f10\uff5e1000k\u2126\u30fbm\u3067\u3042\u308a\u3001MC\u30ca\u30a4\u30ed\u30f3\uff08\u5c0e\u96fb\u30fb\u9ed2\uff09\u3088\u308a\u62b5\u6297\u304c\u5927\u304d\u3044\u3067\u3059\u3002MC\u30ca\u30a4\u30ed\u30f3\uff08\u5c0e\u96fb\u30fb\u9ed2\uff09\u3088\u308a\u5b89\u4fa1\u3067\u3059\u3002MC\u30ca\u30a4\u30ed\u30f3\u306e\u6027\u8cea\u4e0a\u5438\u6c34\u6027\u3092\u6301\u3064\u305f\u3081\u96e8\u304c\u5f53\u305f\u308b\u5834\u6240\u3067\u4f7f\u7528\u3059\u308b\u5834\u5408\u5bf8\u6cd5\u5909\u5316\u306b\u6ce8\u610f\u3092\u8981\u3057\u307e\u3059\u3002<\/td>\n<td><img decoding=\"async\" class=\"imgCFStyle01_33691\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/07\/12590_32.png\" alt=\"MC\u30ca\u30a4\u30ed\u30f3\uff08\u5c0e\u96fb\u30fb\u9ed2\uff09[MC501CD R2]\u306e\u5916\u89b3\" \/><\/td>\n<\/tr>\n<tr>\n<td>ABS\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u81ea\u7136\u8272\uff09<\/td>\n<td class=\"tblFldCFStyle01_33691\" rowspan=\"2\">\u30b3\u30b9\u30c8\u30d1\u30d5\u30a9\u30fc\u30de\u30f3\u30b9\u306e\u826f\u3044\u6a39\u8102\u3067\u3059\u3002\u4f4e\u30b3\u30b9\u30c8\u3067\u6a5f\u68b0\u7684\u5f37\u5ea6\u3068\u8010\u885d\u6483\u6027\u306b\u512a\u308c\u3066\u3044\u307e\u3059\u3002\u885d\u6483\u5438\u53ce\u6027\u306b\u3088\u308a\u8010\u885d\u6483\u6027\u304c\u7279\u306b\u9ad8\u3044\u3067\u3059\u3002\u5207\u524a\u6027\u304c\u512a\u308c\u3001\u63a5\u7740\u52a0\u5de5\u3082\u53ef\u80fd\u3067\u3059\u3002<\/td>\n<td><img decoding=\"async\" class=\"imgCFStyle01_33691\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/06\/12590_06_B.png\" alt=\"ABS\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u81ea\u7136\u8272\uff09\u306e\u5916\u89b3\" \/><\/td>\n<\/tr>\n<tr>\n<td>ABS\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u9ed2\uff09<\/td>\n<td><img decoding=\"async\" class=\"imgCFStyle01_33691\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/06\/12590_07_B.png\" alt=\"ABS\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u9ed2\uff09\u306e\u5916\u89b3\" \/><\/td>\n<\/tr>\n<tr>\n<td>PEEK\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u7070\u8910\u8272\uff09<\/td>\n<td class=\"tblFldCFStyle01_33691\">\u71b1\u53ef\u5851\u6027\u6a39\u8102\u306e\u4e2d\u3067\u6700\u9ad8\u30ec\u30d9\u30eb\u306e\u8010\u71b1\u6027\u3068\u6a5f\u68b0\u7684\u5f37\u5ea6\u3092\u6301\u3064\u6750\u8cea\u3067\u3059\u3002\u8010\u71b1\u6027\u30fb\u5bf8\u6cd5\u5b89\u5b9a\u6027\u30fb\u8010\u85ac\u54c1\u6027\u30fb\u8010\u6469\u8017\u6027\u30fb\u6a5f\u68b0\u7684\u5f37\u5ea6\u306e\u7279\u6027\u304c\u975e\u5e38\u306b\u9ad8\u3044\u3067\u3059\u3002\u975e\u5e38\u306b\u9ad8\u4fa1\u306a\u6750\u8cea\u3067\u3059\u3002\u9ad8\u6e29\u74b0\u5883\u3067\u3082\u307b\u3068\u3093\u3069\u306e\u9178\u30fb\u5869\u57fa\u30fb\u6709\u6a5f\u6eb6\u5264\u306b\u5bfe\u3057\u3066\u8010\u6027\u3092\u6301\u3061\u307e\u3059\u3002<\/td>\n<td><img decoding=\"async\" class=\"imgCFStyle01_33691\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/06\/12590_08_B.png\" alt=\"PEEK\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u7070\u8910\u8272\uff09\u306e\u5916\u89b3\" \/><\/td>\n<\/tr>\n<tr>\n<td>PPS\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u81ea\u7136\u8272\uff09<\/td>\n<td class=\"tblFldCFStyle01_33691\">\u30b9\u30fc\u30d1\u30fc\u30a8\u30f3\u30b8\u30cb\u30a2\u30ea\u30f3\u30b0\u30d7\u30e9\u30b9\u30c1\u30c3\u30af\u306e\u4e00\u7a2e\u3067\u3059\u3002\u8010\u71b1\u6027\u30fb\u5bf8\u6cd5\u5b89\u5b9a\u6027\u30fb\u8010\u85ac\u54c1\u6027\u30fb\u6a5f\u68b0\u7684\u5f37\u5ea6\u30fb\u8010\u6469\u8017\u6027\u306b\u512a\u308c\u305f\u6750\u8cea\u3067\u3059\u3002200\u2103\u4ee5\u4e0b\u306e\u74b0\u5883\u3067\u307b\u3068\u3093\u3069\u306e\u85ac\u54c1\u306b\u8010\u6027\u3092\u6301\u3061\u307e\u3059\u3002PEEK\u306b\u8fd1\u3044\u8010\u71b1\u6027\u3092\u6301\u3061\u3001\u4fa1\u683c\u306fPEEK\u306b\u6bd4\u3079\u3001\u4f4e\u4fa1\u683c\u3067\u3059\u3002\u5438\u6c34\u6027\u30fb\u71b1\u81a8\u5f35\u7387\u304c\u4f4e\u304f\u5bf8\u6cd5\u5b89\u5b9a\u6027\u306b\u512a\u308c\u307e\u3059\u3002<\/td>\n<td><img decoding=\"async\" class=\"imgCFStyle01_33691\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/07\/12590_25_B.png\" alt=\"PPS\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u81ea\u7136\u8272\uff09\u306e\u5916\u89b3\" \/><\/td>\n<\/tr>\n<tr>\n<td>\u30a2\u30af\u30ea\u30eb\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u900f\u660e\uff09<\/td>\n<td class=\"tblFldCFStyle01_33691\">\u5149\u900f\u904e\u6027\u304c\u975e\u5e38\u306b\u9ad8\u3044\u7279\u6027\u3092\u3082\u3061\u307e\u3059\u3002\u30c7\u30a3\u30b9\u30d7\u30ec\u30a4\u3001\u7167\u660e\u30ab\u30d0\u30fc\u3001\u30a4\u30f3\u30c6\u30ea\u30a2\u306a\u3069\u306b\u5229\u7528\u3055\u308c\u307e\u3059\u3002\u77f3\u6cb9\u7cfb\u6eb6\u5264\u3084\u30a2\u30eb\u30ab\u30ea\u6027\u306e\u85ac\u54c1\u306b\u5f31\u3044\u70b9\u306b\u6ce8\u610f\u304c\u5fc5\u8981\u3067\u3059\u3002\u307e\u305f\u3001\u52a0\u5de5\u9762\u306f\u900f\u660e\u5ea6\u304c\u4e0b\u304c\u308a\u307e\u3059\u3002<\/td>\n<td><img decoding=\"async\" class=\"imgCFStyle01_33691\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/07\/12590_28_B.png\" alt=\"\u30a2\u30af\u30ea\u30eb\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u900f\u660e\uff09\u306e\u5916\u89b3\" \/><\/td>\n<\/tr>\n<tr>\n<td>PC\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u900f\u660e\uff09<\/td>\n<td class=\"tblFldCFStyle01_33691\" rowspan=\"2\">\u8010\u885d\u6483\u6027\u30fb\u8010\u71b1\u6027\u30fb\u5bf8\u6cd5\u5b89\u5b9a\u6027\u306b\u512a\u308c\u307e\u3059\u3002\u5149\u900f\u904e\u6027\u304c\u9ad8\u304f\u3001\u30ab\u30d0\u30fc\u3084\u7a93\u6750\u3001\u4fdd\u8b77\u30d1\u30cd\u30eb\u306a\u3069\u306b\u4f7f\u7528\u3055\u308c\u3066\u3044\u307e\u3059\u3002\u5207\u524a\u52a0\u5de5\u6027\u3082\u826f\u597d\u3067\u3001\u6a5f\u68b0\u90e8\u54c1\u306b\u3082\u5229\u7528\u53ef\u80fd\u3067\u3059\u3002<\/td>\n<td><img decoding=\"async\" class=\"imgCFStyle01_33691\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/06\/12590_09_B.png\" alt=\"PC\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u900f\u660e\uff09\u306e\u5916\u89b3\" \/><\/td>\n<\/tr>\n<tr>\n<td>PC\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u9ed2\uff09<\/td>\n<td><img decoding=\"async\" class=\"imgCFStyle01_33691\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/06\/12590_10_B.png\" alt=\"PC\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u9ed2\uff09\u306e\u5916\u89b3\" \/><\/td>\n<\/tr>\n<tr>\n<td>PP\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u81ea\u7136\u8272\uff09<\/td>\n<td class=\"tblFldCFStyle01_33691\">\u30dd\u30ea\u30d7\u30ed\u30d4\u30ec\u30f3\u306e\u81ea\u7136\u8272\u30b0\u30ec\u30fc\u30c9\u3067\u3001\u8efd\u91cf\u3067\u8010\u85ac\u54c1\u6027\u30fb\u8010\u6c34\u6027\u30fb\u7d76\u7e01\u6027\u306b\u512a\u308c\u307e\u3059\u3002\u8010\u71b1\u6027\u3082\u9ad8\u304f\u3001\u6a5f\u68b0\u90e8\u54c1\u3001\u914d\u7ba1\u90e8\u54c1\u3001\u7d76\u7e01\u6750\u306a\u3069\u306b\u4f7f\u7528\u3055\u308c\u3066\u3044\u307e\u3059\u3002\u52a0\u5de5\u6027\u3082\u826f\u597d\u3067\u3001\u4f4e\u30b3\u30b9\u30c8\u3067\u3059\u3002<\/td>\n<td><img decoding=\"async\" class=\"imgCFStyle01_33691\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/06\/12590_11_B.png\" alt=\"PP\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u81ea\u7136\u8272\uff09\u306e\u5916\u89b3\" \/><\/td>\n<\/tr>\n<tr>\n<td>PVC\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u30b0\u30ec\u30fc\uff09<\/td>\n<td class=\"tblFldCFStyle01_33691\">\u5869\u5316\u30d3\u30cb\u30eb\u6a39\u8102\u306e\u30b0\u30ec\u30fc\u7740\u8272\u30b0\u30ec\u30fc\u30c9\u3067\u3001\u8010\u85ac\u54c1\u6027\u30fb\u8010\u6c34\u6027\u30fb\u96fb\u6c17\u7d76\u7e01\u6027\u306b\u512a\u308c\u307e\u3059\u3002\u786c\u8cea\u3067\u5bf8\u6cd5\u5b89\u5b9a\u6027\u304c\u9ad8\u304f\u3001\u914d\u7ba1\u90e8\u54c1\u3001\u7b50\u4f53\u3001\u7d76\u7e01\u6750\u306a\u3069\u306b\u4f7f\u7528\u3055\u308c\u3066\u3044\u307e\u3059\u3002\u52a0\u5de5\u6027\u3082\u826f\u597d\u3067\u3059\u3002<\/td>\n<td><img decoding=\"async\" class=\"imgCFStyle01_33691\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/07\/12590_27_B.png\" alt=\"PVC\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u30b0\u30ec\u30fc\uff09\u306e\u5916\u89b3\" \/><\/td>\n<\/tr>\n<tr>\n<td>\u8d85\u9ad8\u5206\u5b50\u91cf\u30dd\u30ea\u30a8\u30c1\u30ec\u30f3\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u767d\uff09<\/td>\n<td class=\"tblFldCFStyle01_33691\">\u5206\u5b50\u91cf\u304c100\u4e07\u4ee5\u4e0a\u306e\u30dd\u30ea\u30a8\u30c1\u30ec\u30f3\u3067\u3059\u3002\u4f4e\u6bd4\u91cd\u3001\u8010\u6469\u8017\u6027\u3001\u885d\u6483\u5438\u53ce\u6027\u3001\u6ed1\u308a\u7279\u6027\u304c\u975e\u5e38\u306b\u9ad8\u3044\u7279\u6027\u3092\u6301\u3061\u307e\u3059\u3002PTFE\u3088\u308a\u4f4e\u4fa1\u683c\u3002\u7dda\u81a8\u5f35\u4fc2\u6570\u304c\u5927\u304d\u304f\u3001\u5bf8\u6cd5\u5b89\u5b9a\u6027\u304c\u60aa\u3044\u3067\u3059\u3002\u30d0\u30ea\u304c\u9664\u53bb\u3057\u306b\u304f\u304f\u8868\u9762\u7c97\u3055\u304c\u7c97\u304f\u306a\u308a\u3084\u3059\u3044\u7279\u5fb4\u3092\u6301\u3061\u307e\u3059\u3002<\/td>\n<td><img decoding=\"async\" class=\"imgCFStyle01_33691\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/07\/12590_26_B.png\" alt=\"\u8d85\u9ad8\u5206\u5b50\u91cf\u30dd\u30ea\u30a8\u30c1\u30ec\u30f3\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u767d\uff09\u306e\u5916\u89b3\" \/><\/td>\n<\/tr>\n<tr>\n<td>\u8d85\u9ad8\u5206\u5b50\u91cf\u30dd\u30ea\u30a8\u30c1\u30ec\u30f3\uff08\u5c0e\u96fb\u30fb\u9ed2\uff09<\/td>\n<td class=\"tblFldCFStyle01_33691\">\u8d85\u9ad8\u5206\u5b50\u91cf\u30dd\u30ea\u30a8\u30c1\u30ec\u30f3\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u767d\uff09\u306b\u5c0e\u96fb\u6027\u3092\u6301\u305f\u305b\u305f\u6750\u8cea\u3067\u3059\u3002\u4f4e\u6bd4\u91cd\u3001\u8010\u6469\u8017\u6027\u3001\u885d\u6483\u5438\u53ce\u6027\u3001\u6ed1\u308a\u7279\u6027\u304c\u975e\u5e38\u306b\u9ad8\u3044\u7279\u6027\u3092\u6301\u3061\u307e\u3059\u3002\u7dda\u81a8\u5f35\u4fc2\u6570\u304c\u5927\u304d\u304f\u3001\u5bf8\u6cd5\u5b89\u5b9a\u6027\u304c\u60aa\u3044\u3067\u3059\u3002\u30d0\u30ea\u304c\u9664\u53bb\u3057\u306b\u304f\u304f\u8868\u9762\u7c97\u3055\u304c\u7c97\u304f\u306a\u308a\u3084\u3059\u3044\u7279\u5fb4\u3092\u6301\u3061\u307e\u3059\u3002<\/td>\n<td><img decoding=\"async\" class=\"imgCFStyle01_33691\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/07\/12590_33.png\" alt=\"\u8d85\u9ad8\u5206\u5b50\u91cf\u30dd\u30ea\u30a8\u30c1\u30ec\u30f3\uff08\u5c0e\u96fb\u30fb\u9ed2\uff09\u306e\u5916\u89b3\" \/><\/td>\n<\/tr>\n<tr>\n<td>\u3075\u3063\u7d20\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u767d\uff09[PTFE]<\/td>\n<td class=\"tblFldCFStyle01_33691\">\u30d5\u30c3\u7d20\u6a39\u8102\u306e\u4e00\u7a2e\u3067\u3059\u3002\u8010\u71b1\u6027\u30fb\u8010\u85ac\u54c1\u6027\u30fb\u8010\u5bd2\u6027\u30fb\u647a\u52d5\u6027\u304c\u975e\u5e38\u306b\u9ad8\u3044\u3067\u3059\u3002\u4ed6\u306e\u6a39\u8102\u3068\u6bd4\u8f03\u3057\u3066\u786c\u5ea6\u304c\u4f4e\u304f\u3001\u30d0\u30ea\u304c\u767a\u751f\u3057\u3084\u3059\u3044\u3067\u3059\u3002\u4f7f\u7528\u53ef\u80fd\u306a\u6e29\u5ea6\u57df\u304c\u5e83\u3044\u304c\u3001\u6e29\u5ea6\u306b\u3088\u308b\u4f53\u7a4d\u5909\u5316\u304c\u5927\u304d\u304f\u5bf8\u6cd5\u5b89\u5b9a\u6027\u306b\u52a3\u308a\u307e\u3059\u3002\u9ad8\u6e29\u74b0\u5883\u3084\u5316\u5b66\u85ac\u54c1\u306b\u89e6\u308c\u308b\u74b0\u5883\u4e0b\u3067\u306e\u4f7f\u7528\u306b\u9069\u3057\u307e\u3059\u3002<\/td>\n<td><img decoding=\"async\" class=\"imgCFStyle01_33691\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/07\/12590_29.png\" alt=\"\u3075\u3063\u7d20\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u767d\uff09[PTFE]\u306e\u5916\u89b3\" \/><\/td>\n<\/tr>\n<tr>\n<td>\u30e6\u30cb\u30ec\u30fc\u30c8\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u8336\uff09<\/td>\n<td class=\"tblFldCFStyle01_33691\">PET\u3092\u4e3b\u539f\u6599\u306b\u30ac\u30e9\u30b9\u77ed\u7e4a\u7dad\u3001\u7121\u6a5f\u30d5\u30a3\u30e9\u30fc\u7b49\u3092\u5145\u586b\u8907\u5408\u3057\u305f\u6750\u6599\u3067\u3059\u3002\u30ca\u30a4\u30ed\u30f3\u3001\u30dd\u30ea\u30a2\u30bb\u30bf\u30fc\u30eb\u7b49\u306e\u71b1\u53ef\u5851\u6027\u6a39\u8102\u677f\u306b\u6bd4\u8f03\u3057\u3066\u8010\u71b1\u6027\u3001\u96fb\u6c17\u7279\u6027\u3001\u5f37\u5ea6\u3001\u5bf8\u6cd5\u5b89\u5b9a\u6027\u306b\u512a\u308c\u307e\u3059\u3002\u5438\u6c34\u6027\u3001\u96fb\u6c17\u7279\u6027\u3001\u52a0\u5de5\u6027\u306b\u512a\u308c\u307e\u3059\u3002\u8010\u6469\u8017\u6027\u304c\u4f4e\u3044\u3067\u3059\u3002<\/td>\n<td><img decoding=\"async\" class=\"imgCFStyle01_33691\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/07\/12590_34.png\" alt=\"\u30e6\u30cb\u30ec\u30fc\u30c8\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u8336\uff09\u306e\u5916\u89b3\" \/><\/td>\n<\/tr>\n<\/tbody>\n<\/table>\n<\/div>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-02c4fda tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"02c4fda\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p>\u6750\u8cea\u306e\u7279\u6027\u3000\u203b\u4e0b\u8a18\u7279\u6027\u5024\u306f\u53c2\u8003\u5024\u3067\u3042\u308a\u4fdd\u8a3c\u5024\u3067\u306f\u3042\u308a\u307e\u305b\u3093<\/p><table class=\"mT0 tableHover tblCFStyle01_33691 print_break\"><tbody><tr><th>\u6750\u8cea<\/th><th><div>\u5f15\u5f35\u5f37\u3055<\/div><p>(N\/mm2)<\/p><\/th><th><div>\u66f2\u3052\u5f37\u3055<\/div><p>(N\/mm2)<\/p><\/th><th><div>\u7834\u65ad\u4f38\u3073<\/div><p>%<\/p><\/th><th><div>\u30e4\u30f3\u30b0\u7387<\/div><p>(N\/mm2)<\/p><\/th><th>\u30ed\u30c3\u30af\u30a6\u30a7\u30eb\u786c\u3055<\/th><th>\u6bd4\u91cd<\/th><th><div>\u9023\u7d9a\u4f7f\u7528\u6e29\u5ea6<\/div><p>\u2103<\/p><\/th><\/tr><tr><th><ul><li>\u30dd\u30ea\u30a2\u30bb\u30bf\u30fc\u30eb\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u767d\uff09<\/li><li>\u30dd\u30ea\u30a2\u30bb\u30bf\u30fc\u30eb\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u9ed2\uff09<\/li><\/ul><\/th><td>60~68<\/td><td>89~108<\/td><td>40~75<\/td><td>2988<\/td><td>R118<\/td><td>1.41<\/td><td>95~100<\/td><\/tr><tr><th><ul><li>MC\u30ca\u30a4\u30ed\u30f3\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u9752\uff09<\/li><li>MC\u30ca\u30a4\u30ed\u30f3\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u30a2\u30a4\u30dc\u30ea\u30fc\uff09<\/li><\/ul><\/th><td>96<\/td><td>110<\/td><td>30<\/td><td>3432<\/td><td>R120<\/td><td>1.16<\/td><td>120<\/td><\/tr><tr><th>MC\u30ca\u30a4\u30ed\u30f3\uff08\u8010\u4faf\u30fb\u9ed2\u7070\uff09<\/th><td>83<\/td><td>110<\/td><td>40<\/td><td>3334<\/td><td>R120<\/td><td>1.16<\/td><td>120<\/td><\/tr><tr><th>MC\u30ca\u30a4\u30ed\u30f3\uff08\u5e2f\u96fb\u9632\u6b62\u30fb\u9ed2\uff09[MC501CD R6]<\/th><td>75<\/td><td>118<\/td><td>7<\/td><td>2500~2700<\/td><td>R117<\/td><td>1.23<\/td><td>120<\/td><\/tr><tr><th>MC\u30ca\u30a4\u30ed\u30f3\uff08\u5c0e\u96fb\u30fb\u9ed2\uff09[MC501CD R2]<\/th><td>69<\/td><td>118<\/td><td>10<\/td><td>2500~2700<\/td><td>R119<\/td><td>1.2<\/td><td>120<\/td><\/tr><tr><th><ul><li>ABS\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u81ea\u7136\u8272\uff09<\/li><li>ABS\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u9ed2\uff09<\/li><\/ul><\/th><td>39~54<\/td><td>64~81<\/td><td>18<\/td><td>1900~2800<\/td><td>R105~115<\/td><td>1.05<\/td><td>60~95<\/td><\/tr><tr><th>PEEK\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u7070\u8910\u8272\uff09<\/th><td>98~116<\/td><td>170~175<\/td><td>20~40<\/td><td>4200~4345<\/td><td>M100-120<\/td><td>1.32<\/td><td>250~260<\/td><\/tr><tr><th>PPS\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u81ea\u7136\u8272\uff09<\/th><td>79~85<\/td><td>128~142<\/td><td>23~27<\/td><td>3300<\/td><td>M95-100<\/td><td>1.35<\/td><td>220<\/td><\/tr><tr><th>\u30a2\u30af\u30ea\u30eb\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u900f\u660e\uff09<\/th><td>60~70<\/td><td>80~95<\/td><td>90~120<\/td><td>2400<\/td><td>M70~M80<\/td><td>1.2<\/td><td>100~120<\/td><\/tr><tr><th>PC\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u900f\u660e\uff09<\/th><td>45~55<\/td><td>70~90<\/td><td>20~40<\/td><td>2800<\/td><td>R110~R120<\/td><td>1.4<\/td><td>50~70<\/td><\/tr><tr><th>PC\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u9ed2\uff09<\/th><td>45~55<\/td><td>70~90<\/td><td>20~40<\/td><td>2800<\/td><td>R110~R120<\/td><td>1.4<\/td><td>50~70<\/td><\/tr><tr><th>PP\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u81ea\u7136\u8272\uff09<\/th><td>33~34<\/td><td>51<\/td><td>33<\/td><td>1400<\/td><td>R126<\/td><td>0.91<\/td><td>100<\/td><\/tr><tr><th>PVC\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u30b0\u30ec\u30fc\uff09<\/th><td>55~65<\/td><td>80~100<\/td><td>50~100<\/td><td>2900<\/td><td>M80~M90<\/td><td>1.38<\/td><td>80~100<\/td><\/tr><tr><th>\u8d85\u9ad8\u5206\u5b50\u91cf\u30dd\u30ea\u30a8\u30c1\u30ec\u30f3\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u767d\uff09<\/th><td>21~45<\/td><td>22~26<\/td><td>300\u4ee5\u4e0a<\/td><td>500~826<\/td><td>R50-56<\/td><td>0.94<\/td><td>80<\/td><\/tr><tr><th>\u8d85\u9ad8\u5206\u5b50\u91cf\u30dd\u30ea\u30a8\u30c1\u30ec\u30f3\uff08\u5c0e\u96fb\u30fb\u9ed2\uff09<\/th><td>35<\/td><td>25<\/td><td>300\u4ee5\u4e0a<\/td><td>913<\/td><td>R52-60<\/td><td>0.95<\/td><td>80<\/td><\/tr><tr><th>\u3075\u3063\u7d20\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u767d\uff09[PTFE]<\/th><td>13.7~34.3<\/td><td>&#8211;<\/td><td>200~400<\/td><td>400~600<\/td><td>R20<\/td><td>2.2<\/td><td>260<\/td><\/tr><tr><th>\u30e6\u30cb\u30ec\u30fc\u30c8\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u8336\uff09<\/th><td>95~110(\u7e26) \/ 55~65(\u6a2a)<\/td><td>190~220(\u7e26) \/ 95~125(\u6a2a)<\/td><td>2.4(\u7e26) \/ 1.9(\u6a2a)<\/td><td>\u30fc<\/td><td>R120<\/td><td>1.63~1.74<\/td><td>120<\/td><\/tr><\/tbody><\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<\/div>\n\t\t\n\t\t\t<div id=\"daexthefu-container\"\n\t\t\t\tclass=\"daexthefu-container daexthefu-layout-stacked daexthefu-alignment-left\"\n\t\t\t\tdata-post-id=\"33691\">\n\n\t\t\t\t<div class=\"daexthefu-feedback\">\n\t\t\t\t\t<div class=\"daexthefu-text\">\n\t\t\t\t\t\t<h3 class=\"daexthefu-title\">\u3053\u306e\u8a18\u4e8b\u306f\u53c2\u8003\u306b\u306a\u308a\u307e\u3057\u305f\u304b\uff1f<\/h3>\n\t\t\t\t\t<\/div>\n\t\t\t\t\t<div class=\"daexthefu-buttons-container\">\n\t\t\t\t\t\t<div class=\"daexthefu-buttons\">\n\t\t\t\t\t\t\t\n\t\t\t<button type=\"button\" class=\"daexthefu-yes daexthefu-button daexthefu-button-type-icon-and-text\" data-value=\"1\">\n\t\t\t\t<span class=\"daexthefu-button-icon\">\n\t\t\t\t\n                <svg>\n                    <defs>\n                        <style>.thumb-up-cls-1{fill:#c9c9c9;}.thumb-up-cls-2{fill:#e1e1e1;}.thumb-up-cls-3{fill:#676767;}<\/style>\n                    <\/defs>\n                    <g id=\"thumb_up\">\n                        <path class=\"thumb-up-cls-2 daexthefu-icon-circle\" d=\"m24,3c11.58,0,21,9.42,21,21s-9.42,21-21,21S3,35.58,3,24,12.42,3,24,3m0-1C11.85,2,2,11.85,2,24s9.85,22,22,22,22-9.85,22-22S36.15,2,24,2h0Z\" \/>\n                        <g>\n                            <rect class=\"thumb-up-cls-3 daexthefu-icon-secondary-color\" x=\"10\" y=\"20\" width=\"6\" height=\"15\" rx=\"1.5\" ry=\"1.5\" \/>\n                            <path class=\"thumb-up-cls-1 daexthefu-icon-primary-color\" d=\"m30.57,9.06l-.49-.1c-.81-.17-1.61.35-1.78,1.16l-5.3,11.74c-.17.81,3.16,1.61,3.97,1.78l1.96.41c.81.17,1.61-.35,1.78-1.16l2.18-10.27c.34-1.61-.7-3.21-2.31-3.56Z\" \/>\n                            <path class=\"thumb-up-cls-1 daexthefu-icon-primary-color\" d=\"m38.17,20h-18.67c-.83,0-1.5.67-1.5,1.5v12c0,.83.67,1.5,1.5,1.5h16.27c.71,0,1.33-.5,1.47-1.21l2.4-12c.19-.93-.53-1.8-1.47-1.8Z\" \/>\n                        <\/g>\n                    <\/g>\n                <\/svg>\t\t\t\t\t\t<\/span>\n\t\t\t\t<span class=\"daexthefu-button-text\">\u5f79\u306b\u7acb\u3063\u305f\uff01<\/span>\n\t\t\t<\/button>\n\n\t\t\t\t\t\t\t\t\t\t\n\t\t\t<button type=\"button\" class=\"daexthefu-no daexthefu-button daexthefu-button-type-icon-and-text\" data-value=\"0\">\n\t\t\t\t<span class=\"daexthefu-button-icon\">\n\t\t\t\t\n                <svg>\n                    <defs>\n                        <style>.thumb-down-cls-1{fill:#c9c9c9;}.thumb-down-cls-2{fill:#e1e1e1;}.thumb-down-cls-3{fill:#676767;}<\/style>\n                    <\/defs>\n                    <g id=\"thumb_down\">\n                        <path class=\"thumb-down-cls-2 daexthefu-icon-circle\" d=\"m24,3c11.58,0,21,9.42,21,21s-9.42,21-21,21S3,35.58,3,24,12.42,3,24,3m0-1C11.85,2,2,11.85,2,24s9.85,22,22,22,22-9.85,22-22S36.15,2,24,2h0Z\" \/>\n                        <g>\n                            <rect class=\"thumb-down-cls-3 daexthefu-icon-secondary-color\" x=\"10\" y=\"13\" width=\"6\" height=\"15\" rx=\"1.5\" ry=\"1.5\" \/>\n                            <path class=\"thumb-down-cls-1 daexthefu-icon-primary-color\" d=\"m30.57,38.94l-.49.1c-.81.17-1.61-.35-1.78-1.16l-5.3-11.74c-.17-.81,3.16-1.61,3.97-1.78l1.96-.41c.81-.17,1.61.35,1.78,1.16l2.18,10.27c.34,1.61-.7,3.21-2.31,3.56Z\" \/>\n                            <path class=\"thumb-down-cls-1 daexthefu-icon-primary-color\" d=\"m38.17,28h-18.67c-.83,0-1.5-.67-1.5-1.5v-12c0-.83.67-1.5,1.5-1.5h16.27c.71,0,1.33.5,1.47,1.21l2.4,12c.19.93-.53,1.8-1.47,1.8Z\" \/>\n                        <\/g>\n                    <\/g>\n                <\/svg>\t\t\t\t\t\t<\/span>\n\t\t\t\t<span class=\"daexthefu-button-text\">\u5f79\u306b\u7acb\u305f\u306a\u304b\u3063\u305f<\/span>\n\t\t\t<\/button>\n\n\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\n\t\t\t\t<div class=\"daexthefu-comment\">\n\t\t\t\t\t<div class=\"daexthefu-comment-top-container\">\n\t\t\t\t\t\t<label id=\"daexthefu-comment-label\" class=\"daexthefu-comment-label\"><\/label>\n\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t\t<textarea id=\"daexthefu-comment-textarea\" class=\"daexthefu-comment-textarea\"\n\t\t\t\t\t\t\t\tplaceholder=\"\"\n\t\t\t\t\t\t\t\tmaxlength=\"\n\t\t\t\t\t\t\t\t400\t\t\t\t\t\t\t\t\t\"><\/textarea>\n\t\t\t\t\t<div class=\"daexthefu-comment-buttons-container\">\n\t\t\t\t\t\t<button class=\"daexthefu-comment-submit daexthefu-button\">\u9001\u4fe1<\/button>\n\t\t\t\t\t\t<button class=\"daexthefu-comment-cancel daexthefu-button\">\u53d6\u6d88<\/button>\n\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\n\t\t\t\t<div class=\"daexthefu-successful-submission-text\">\u8a55\u4fa1\u3044\u305f\u3060\u304d\u3042\u308a\u304c\u3068\u3046\u3054\u3056\u3044\u307e\u3057\u305f\u3002<\/div>\n\n\t\t\t<\/div>\n\n\t\t\t","protected":false},"excerpt":{"rendered":"<p>\u9244 \u30a2\u30eb\u30df\u30cb\u30a6\u30e0 \u30b9\u30c6\u30f3\u30ec\u30b9 \u9285\u30fb\u771f\u936e \u6a39\u8102 \u9244 \u6750\u8cea\u306e\u7279\u5fb4 \u6750\u8cea \u7279\u5fb4 SS400 \u4e00\u822c\u69cb\u9020\u7528\u5727\u5ef6\u92fc\u6750\u3067\u65e5\u672c\u3067\u5e83\u304f\u4f7f\u7528\u3055\u308c\u3066\u3044\u308b\u6750\u6599\u3067\u3059\u3002\u5f15\u3063\u5f35\u308a\u5f37\u3055\u304c400N\/mm^2\u4ee5\u4e0a\u3042\u308b\u3053\u3068\u304c\u540d\u79f0\u306e\u7531\u6765\u306b\u306a\u308a\u307e\u3059\u3002\u7279\u5fb4\u306f\u4f4e\u30b3\u30b9 [&hellip;]<\/p>\n","protected":false},"author":78,"featured_media":0,"comment_status":"closed","ping_status":"closed","sticky":false,"template":"","format":"standard","meta":{"_helpful_status":1,"footnotes":""},"categories":[76],"tags":[79],"class_list":["post-33691","post","type-post","status-publish","format-standard","hentry","category-tup_shape-material","tag-technical_tup"],"yoast_head":"<!-- This site is optimized with the Yoast SEO plugin v28.7 - https:\/\/yoast.com\/product\/yoast-seo-wordpress\/ -->\n<title>\u6750\u6599\u306e\u7279\u6027 | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb<\/title>\n<meta name=\"robots\" content=\"index, follow, max-snippet:-1, max-image-preview:large, max-video-preview:-1\" \/>\n<link rel=\"canonical\" href=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/tup_shape-material\/33691\/\" \/>\n<meta property=\"og:locale\" content=\"ja_JP\" \/>\n<meta property=\"og:type\" content=\"article\" \/>\n<meta property=\"og:title\" content=\"\u6750\u6599\u306e\u7279\u6027 | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\" \/>\n<meta property=\"og:description\" content=\"\u9244 \u30a2\u30eb\u30df\u30cb\u30a6\u30e0 \u30b9\u30c6\u30f3\u30ec\u30b9 \u9285\u30fb\u771f\u936e \u6a39\u8102 \u9244 \u6750\u8cea\u306e\u7279\u5fb4 \u6750\u8cea \u7279\u5fb4 SS400 \u4e00\u822c\u69cb\u9020\u7528\u5727\u5ef6\u92fc\u6750\u3067\u65e5\u672c\u3067\u5e83\u304f\u4f7f\u7528\u3055\u308c\u3066\u3044\u308b\u6750\u6599\u3067\u3059\u3002\u5f15\u3063\u5f35\u308a\u5f37\u3055\u304c400N\/mm^2\u4ee5\u4e0a\u3042\u308b\u3053\u3068\u304c\u540d\u79f0\u306e\u7531\u6765\u306b\u306a\u308a\u307e\u3059\u3002\u7279\u5fb4\u306f\u4f4e\u30b3\u30b9 [&hellip;]\" \/>\n<meta property=\"og:url\" content=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/tup_shape-material\/33691\/\" \/>\n<meta property=\"og:site_name\" content=\"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\" \/>\n<meta property=\"article:published_time\" content=\"2025-12-14T15:00:45+00:00\" \/>\n<meta property=\"article:modified_time\" content=\"2026-10-05T01:27:20+00:00\" \/>\n<meta property=\"og:image\" content=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/06\/12590_02_B.png\" \/>\n<meta name=\"author\" content=\"YAJIMAEmiri\" \/>\n<meta name=\"twitter:card\" content=\"summary_large_image\" \/>\n<script type=\"application\/ld+json\" class=\"yoast-schema-graph\">{\"@context\":\"https:\\\/\\\/schema.org\",\"@graph\":[{\"@type\":\"Article\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/tup_shape-material\\\/33691\\\/#article\",\"isPartOf\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/tup_shape-material\\\/33691\\\/\"},\"author\":{\"name\":\"YAJIMAEmiri\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#\\\/schema\\\/person\\\/f2a97510a6698cde0dd772c2c3da5fc8\"},\"headline\":\"\u6750\u6599\u306e\u7279\u6027\",\"datePublished\":\"2025-12-14T15:00:45+00:00\",\"dateModified\":\"2026-10-05T01:27:20+00:00\",\"mainEntityOfPage\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/tup_shape-material\\\/33691\\\/\"},\"wordCount\":244,\"publisher\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#organization\"},\"image\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/tup_shape-material\\\/33691\\\/#primaryimage\"},\"thumbnailUrl\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2023\\\/06\\\/12590_02_B.png\",\"keywords\":[\"technical_tup\"],\"articleSection\":[\"\u5bfe\u8c61\u90e8\u54c1\\\/\u6750\u6599\"],\"inLanguage\":\"ja\"},{\"@type\":\"WebPage\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/tup_shape-material\\\/33691\\\/\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/tup_shape-material\\\/33691\\\/\",\"name\":\"\u6750\u6599\u306e\u7279\u6027 | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\",\"isPartOf\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#website\"},\"primaryImageOfPage\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/tup_shape-material\\\/33691\\\/#primaryimage\"},\"image\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/tup_shape-material\\\/33691\\\/#primaryimage\"},\"thumbnailUrl\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2023\\\/06\\\/12590_02_B.png\",\"datePublished\":\"2025-12-14T15:00:45+00:00\",\"dateModified\":\"2026-10-05T01:27:20+00:00\",\"breadcrumb\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/tup_shape-material\\\/33691\\\/#breadcrumb\"},\"inLanguage\":\"ja\",\"potentialAction\":[{\"@type\":\"ReadAction\",\"target\":[\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/tup_shape-material\\\/33691\\\/\"]}]},{\"@type\":\"ImageObject\",\"inLanguage\":\"ja\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/tup_shape-material\\\/33691\\\/#primaryimage\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2023\\\/06\\\/12590_02_B.png\",\"contentUrl\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2023\\\/06\\\/12590_02_B.png\",\"width\":300,\"height\":225},{\"@type\":\"BreadcrumbList\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/tup_shape-material\\\/33691\\\/#breadcrumb\",\"itemListElement\":[{\"@type\":\"ListItem\",\"position\":1,\"name\":\"\u30db\u30fc\u30e0\",\"item\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/\"},{\"@type\":\"ListItem\",\"position\":2,\"name\":\"\u6750\u6599\u306e\u7279\u6027\"}]},{\"@type\":\"WebSite\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#website\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/\",\"name\":\"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\",\"description\":\"\",\"publisher\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#organization\"},\"potentialAction\":[{\"@type\":\"SearchAction\",\"target\":{\"@type\":\"EntryPoint\",\"urlTemplate\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/?s={search_term_string}\"},\"query-input\":{\"@type\":\"PropertyValueSpecification\",\"valueRequired\":true,\"valueName\":\"search_term_string\"}}],\"inLanguage\":\"ja\"},{\"@type\":\"Organization\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#organization\",\"name\":\"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/\",\"logo\":{\"@type\":\"ImageObject\",\"inLanguage\":\"ja\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#\\\/schema\\\/logo\\\/image\\\/\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2019\\\/05\\\/A01-b_b4-1_jpeg.jpg\",\"contentUrl\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2019\\\/05\\\/A01-b_b4-1_jpeg.jpg\",\"width\":260,\"height\":70,\"caption\":\"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df\"},\"image\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#\\\/schema\\\/logo\\\/image\\\/\"}},{\"@type\":\"Person\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#\\\/schema\\\/person\\\/f2a97510a6698cde0dd772c2c3da5fc8\",\"name\":\"YAJIMAEmiri\",\"image\":{\"@type\":\"ImageObject\",\"inLanguage\":\"ja\",\"@id\":\"https:\\\/\\\/secure.gravatar.com\\\/avatar\\\/bfae9e5ad7dc26073df2a027e378ef36eb27440c0fce95579db10e76551d3807?s=96&d=mm&r=g\",\"url\":\"https:\\\/\\\/secure.gravatar.com\\\/avatar\\\/bfae9e5ad7dc26073df2a027e378ef36eb27440c0fce95579db10e76551d3807?s=96&d=mm&r=g\",\"contentUrl\":\"https:\\\/\\\/secure.gravatar.com\\\/avatar\\\/bfae9e5ad7dc26073df2a027e378ef36eb27440c0fce95579db10e76551d3807?s=96&d=mm&r=g\",\"caption\":\"YAJIMAEmiri\"},\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/author\\\/yajima-emiri\\\/\"}]}<\/script>\n<!-- \/ Yoast SEO plugin. -->","yoast_head_json":{"title":"\u6750\u6599\u306e\u7279\u6027 | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","robots":{"index":"index","follow":"follow","max-snippet":"max-snippet:-1","max-image-preview":"max-image-preview:large","max-video-preview":"max-video-preview:-1"},"canonical":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/tup_shape-material\/33691\/","og_locale":"ja_JP","og_type":"article","og_title":"\u6750\u6599\u306e\u7279\u6027 | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","og_description":"\u9244 \u30a2\u30eb\u30df\u30cb\u30a6\u30e0 \u30b9\u30c6\u30f3\u30ec\u30b9 \u9285\u30fb\u771f\u936e \u6a39\u8102 \u9244 \u6750\u8cea\u306e\u7279\u5fb4 \u6750\u8cea \u7279\u5fb4 SS400 \u4e00\u822c\u69cb\u9020\u7528\u5727\u5ef6\u92fc\u6750\u3067\u65e5\u672c\u3067\u5e83\u304f\u4f7f\u7528\u3055\u308c\u3066\u3044\u308b\u6750\u6599\u3067\u3059\u3002\u5f15\u3063\u5f35\u308a\u5f37\u3055\u304c400N\/mm^2\u4ee5\u4e0a\u3042\u308b\u3053\u3068\u304c\u540d\u79f0\u306e\u7531\u6765\u306b\u306a\u308a\u307e\u3059\u3002\u7279\u5fb4\u306f\u4f4e\u30b3\u30b9 [&hellip;]","og_url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/tup_shape-material\/33691\/","og_site_name":"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","article_published_time":"2025-12-14T15:00:45+00:00","article_modified_time":"2026-10-05T01:27:20+00:00","og_image":[{"url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/06\/12590_02_B.png","type":"","width":"","height":""}],"author":"YAJIMAEmiri","twitter_card":"summary_large_image","schema":{"@context":"https:\/\/schema.org","@graph":[{"@type":"Article","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/tup_shape-material\/33691\/#article","isPartOf":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/tup_shape-material\/33691\/"},"author":{"name":"YAJIMAEmiri","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/person\/f2a97510a6698cde0dd772c2c3da5fc8"},"headline":"\u6750\u6599\u306e\u7279\u6027","datePublished":"2025-12-14T15:00:45+00:00","dateModified":"2026-10-05T01:27:20+00:00","mainEntityOfPage":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/tup_shape-material\/33691\/"},"wordCount":244,"publisher":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#organization"},"image":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/tup_shape-material\/33691\/#primaryimage"},"thumbnailUrl":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/06\/12590_02_B.png","keywords":["technical_tup"],"articleSection":["\u5bfe\u8c61\u90e8\u54c1\/\u6750\u6599"],"inLanguage":"ja"},{"@type":"WebPage","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/tup_shape-material\/33691\/","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/tup_shape-material\/33691\/","name":"\u6750\u6599\u306e\u7279\u6027 | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","isPartOf":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#website"},"primaryImageOfPage":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/tup_shape-material\/33691\/#primaryimage"},"image":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/tup_shape-material\/33691\/#primaryimage"},"thumbnailUrl":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/06\/12590_02_B.png","datePublished":"2025-12-14T15:00:45+00:00","dateModified":"2026-10-05T01:27:20+00:00","breadcrumb":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/tup_shape-material\/33691\/#breadcrumb"},"inLanguage":"ja","potentialAction":[{"@type":"ReadAction","target":["https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/tup_shape-material\/33691\/"]}]},{"@type":"ImageObject","inLanguage":"ja","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/tup_shape-material\/33691\/#primaryimage","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/06\/12590_02_B.png","contentUrl":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/06\/12590_02_B.png","width":300,"height":225},{"@type":"BreadcrumbList","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/tup_shape-material\/33691\/#breadcrumb","itemListElement":[{"@type":"ListItem","position":1,"name":"\u30db\u30fc\u30e0","item":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/"},{"@type":"ListItem","position":2,"name":"\u6750\u6599\u306e\u7279\u6027"}]},{"@type":"WebSite","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#website","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/","name":"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","description":"","publisher":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#organization"},"potentialAction":[{"@type":"SearchAction","target":{"@type":"EntryPoint","urlTemplate":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/?s={search_term_string}"},"query-input":{"@type":"PropertyValueSpecification","valueRequired":true,"valueName":"search_term_string"}}],"inLanguage":"ja"},{"@type":"Organization","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#organization","name":"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/","logo":{"@type":"ImageObject","inLanguage":"ja","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/logo\/image\/","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2019\/05\/A01-b_b4-1_jpeg.jpg","contentUrl":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2019\/05\/A01-b_b4-1_jpeg.jpg","width":260,"height":70,"caption":"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df"},"image":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/logo\/image\/"}},{"@type":"Person","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/person\/f2a97510a6698cde0dd772c2c3da5fc8","name":"YAJIMAEmiri","image":{"@type":"ImageObject","inLanguage":"ja","@id":"https:\/\/secure.gravatar.com\/avatar\/bfae9e5ad7dc26073df2a027e378ef36eb27440c0fce95579db10e76551d3807?s=96&d=mm&r=g","url":"https:\/\/secure.gravatar.com\/avatar\/bfae9e5ad7dc26073df2a027e378ef36eb27440c0fce95579db10e76551d3807?s=96&d=mm&r=g","contentUrl":"https:\/\/secure.gravatar.com\/avatar\/bfae9e5ad7dc26073df2a027e378ef36eb27440c0fce95579db10e76551d3807?s=96&d=mm&r=g","caption":"YAJIMAEmiri"},"url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/author\/yajima-emiri\/"}]}},"views":8054,"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts\/33691","targetHints":{"allow":["GET"]}}],"collection":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts"}],"about":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/types\/post"}],"author":[{"embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/users\/78"}],"replies":[{"embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/comments?post=33691"}],"version-history":[{"count":51,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts\/33691\/revisions"}],"predecessor-version":[{"id":38005,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts\/33691\/revisions\/38005"}],"wp:attachment":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/media?parent=33691"}],"wp:term":[{"taxonomy":"category","embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/categories?post=33691"},{"taxonomy":"post_tag","embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/tags?post=33691"}],"curies":[{"name":"wp","href":"https:\/\/api.w.org\/{rel}","templated":true}]}}
