{"id":3420,"date":"2025-12-15T00:00:58","date_gmt":"2025-12-14T15:00:58","guid":{"rendered":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/?p=3420"},"modified":"2026-08-10T12:05:12","modified_gmt":"2026-08-10T03:05:12","slug":"%e3%81%8a%e8%a6%8b%e7%a9%8d%e5%8f%af%e8%83%bd%e3%81%aa%e3%82%b5%e3%82%a4%e3%82%ba","status":"publish","type":"post","link":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/mpb_shape-material\/3420\/","title":{"rendered":"\u898b\u7a4d\u3082\u308a\u53ef\u80fd\u306a\u30b5\u30a4\u30ba"},"content":{"rendered":"\t\t<div data-elementor-type=\"wp-post\" data-elementor-id=\"3420\" class=\"elementor elementor-3420\">\n\t\t\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-c549e7e elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"c549e7e\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-9af589b\" data-id=\"9af589b\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-6582541 elementor-widget elementor-widget-html\" data-id=\"6582541\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"html.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<ul id=\"anchor\">\r\n<li><a href=\"#box1\">\u898f\u683c\u4e00\u89a7<\/a><\/li>\r\n<li><a href=\"#box2\"> \u81ea\u52d5\u898b\u7a4d\u30b5\u30a4\u30ba \u539a\u307f(Z)<\/a><\/li>\r\n<li><a href=\"#box3\"> \u81ea\u52d5\u898b\u7a4d\u30b5\u30a4\u30ba\u9577\u3055(X)\u30fb\u5e45(Y)<\/a><\/li>\r\n<li><a href=\"#box4\"> \u30df\u30ac\u30ad\u6750\u30d5\u30e9\u30c3\u30c8\u30d0\u30fc \u81ea\u52d5\u898b\u7a4d\u30b5\u30a4\u30ba \u5e45(Y)\u30fb\u539a\u307f(Z)<\/a><\/li>\r\n<li><a href=\"#box5\"> \u6750\u6599\u6bd4\u91cd<\/a><\/li>\r\n<\/ul>\r\n\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-64194414 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"64194414\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-5af72488\" data-id=\"5af72488\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-e2ef906 elementor-widget elementor-widget-menu-anchor\" data-id=\"e2ef906\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"menu-anchor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t<div class=\"elementor-menu-anchor\" id=\"box1\"><\/div>\n\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-56e885d elementor-widget elementor-widget-heading\" data-id=\"56e885d\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h3 class=\"elementor-heading-title elementor-size-default\">\u898f\u683c\u4e00\u89a7<\/h3>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<section class=\"elementor-section elementor-inner-section elementor-element elementor-element-3f3f162 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"3f3f162\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-4fac0e0\" data-id=\"4fac0e0\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-5c01e995 elementor-widget elementor-widget-text-editor\" data-id=\"5c01e995\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<ul><li>\u30fb\u901a\u5e38\u898f\u683c<\/li><li class=\"lstCFStyle02_3420\">\u9577\u3055(X)\uff1a10mm\u4ee5\u4e0a\uff5e1,000mm\u4ee5\u4e0b<\/li><li class=\"lstCFStyle02_3420\">\u5e45(Y)\uff1a10mm\u4ee5\u4e0a\uff5e600mm\u4ee5\u4e0b<\/li><li class=\"lstCFStyle02_3420\">\u539a\u307f(Z)\uff1a5mm\u4ee5\u4e0a\uff5e70mm\u4ee5\u4e0b<\/li><li class=\"lstCFStyle01_3420\">\u30fb\u8584\u677f\u898f\u683c<\/li><li class=\"lstCFStyle02_3420\">\u9577\u3055(X) \/ \u5e45(Y)\uff1a5mm\u4ee5\u4e0a\uff5e100mm\u4ee5\u4e0b<\/li><li class=\"lstCFStyle02_3420\">\u539a\u307f(Z)\uff1a3mm\u4ee5\u4e0a\uff5e5mm\u672a\u6e80<\/li><li class=\"lstCFStyle01_3420\">\u30fb\u539a\u677f\u898f\u683c<\/li><li class=\"lstCFStyle02_3420\">\u9577\u3055(X) \/ \u5e45(Y)\uff1a70mm\u8d85\uff5e400mm\u4ee5\u4e0b<\/li><li class=\"lstCFStyle02_3420\">\u539a\u307f(Z)\uff1a70mm\u8d85\uff5e130mm\u4ee5\u4e0b<\/li><li class=\"lstCFStyle01_3420\">\u30fb\u30df\u30ac\u30ad\u6750\u30d5\u30e9\u30c3\u30c8\u30d0\u30fc\u898f\u683c<\/li><li class=\"lstCFStyle02_3420\">\u9577\u3055(X)\uff1a10mm\u4ee5\u4e0a\uff5e500mm\u4ee5\u4e0b<\/li><li class=\"lstCFStyle02_3420\">\u5e45(Y)\uff1a10mm\u4ee5\u4e0a\uff5e125mm\u4ee5\u4e0b<\/li><li class=\"lstCFStyle02_3420\">\u539a\u307f(Z)\uff1a3mm\u4ee5\u4e0a\uff5e30mm\u4ee5\u4e0b<\/li><li class=\"lstCFStyle01_3420\">\u30fb\u6750\u6599\u30d7\u30ec\u30fc\u30c8\u898f\u683c<\/li><li class=\"lstCFStyle02_3420\">\u9577\u3055(X)\uff1a10mm\u4ee5\u4e0a\uff5e500mm\u4ee5\u4e0b<\/li><li class=\"lstCFStyle02_3420\">\u5e45(Y)\uff1a10mm\u4ee5\u4e0a\uff5e300mm\u4ee5\u4e0b<\/li><li class=\"lstCFStyle02_3420\">\u539a\u307f(Z)\uff1a5mm\u4ee5\u4e0a\uff5e50mm\u4ee5\u4e0b<\/li><\/ul>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-7a024d1\" data-id=\"7a024d1\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-7e98438e elementor-widget elementor-widget-image\" data-id=\"7e98438e\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img fetchpriority=\"high\" decoding=\"async\" width=\"313\" height=\"224\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/tgt04_plate_pic_01.png\" class=\"attachment-full size-full wp-image-3161\" alt=\"\u304a\u898b\u7a4d\u53ef\u80fd\u306a\u30b5\u30a4\u30ba\" srcset=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/tgt04_plate_pic_01.png 313w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/tgt04_plate_pic_01-300x215.png 300w\" sizes=\"(max-width: 313px) 100vw, 313px\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<div class=\"elementor-element elementor-element-c00820a elementor-widget elementor-widget-text-editor\" data-id=\"c00820a\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<div class=\"txtBasic bg\"><p class=\"labelPoint\">\u30dd\u30a4\u30f3\u30c8<\/p><ul><li>\u898f\u683c\u4e00\u89a7\u306f\u30b5\u30a4\u30ba\u306e\u9069\u5fdc\u7bc4\u56f2\u3092\u793a\u3059\u3082\u306e\u3067\u3059\u3002\u8a73\u7d30\u306f\u5404\u6750\u8cea\u306e\u30b5\u30a4\u30ba\u6761\u4ef6\u3092\u3054\u78ba\u8a8d\u304f\u3060\u3055\u3044\u3002<\/li><li>\u30df\u30ac\u30ad\u6750\u30d5\u30e9\u30c3\u30c8\u30d0\u30fc\u898f\u683c\u306e \u5e45(Y) \/ \u539a\u307f(Z) \u306e\u9069\u5408\u5024\u306f\u4e0b\u8868\u3092\u3054\u78ba\u8a8d\u304f\u3060\u3055\u3044\u3002<\/li><li>\u6750\u6599\u30d7\u30ec\u30fc\u30c8\u306e\u8a73\u7d30\u306b\u3064\u304d\u307e\u3057\u3066\u306f\u3001<a href=\"https:\/\/jp.meviy.misumi-ec.com\/info\/ja\/news\/new-release\/43624\/\">\u3053\u3061\u3089<\/a>\u3092\u3054\u53c2\u7167\u304f\u3060\u3055\u3044\u3002<\/li><li>\u62c5\u5f53\u8005\u898b\u7a4d\u3067\u306f\u3001(X)2,000mm \u00d7 (Y)1,000mm \u00d7 (Z)200mm \u307e\u3067\u5b9f\u7e3e\u304c\u3054\u3056\u3044\u307e\u3059\u3002<\/li><li>\u203b \u62c5\u5f53\u8005\u898b\u7a4d\u3082\u308a\u306e\u8a73\u7d30\u306b\u3064\u3044\u3066\u306f<a href=\"\/help\/ja\/operation_manual\/mpb_configuration\/4232\/\">\u3053\u3061\u3089<\/a><\/li><\/ul><\/div>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-c6d957c print_page elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"c6d957c\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-693803f\" data-id=\"693803f\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-16a9106 elementor-widget elementor-widget-menu-anchor\" data-id=\"16a9106\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"menu-anchor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t<div class=\"elementor-menu-anchor\" id=\"box2\"><\/div>\n\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-578f164 elementor-widget elementor-widget-heading\" data-id=\"578f164\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h3 class=\"elementor-heading-title elementor-size-default\">\u81ea\u52d5\u898b\u7a4d\u30b5\u30a4\u30ba \u539a\u307f(Z)<\/h3>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-ab27000 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"ab27000\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p style=\"text-align: right;\">[ mm ]<\/p>\n\n<table class=\"table04 mT0 fixed tableHover\">\n<tbody>\n<tr>\n<th rowspan=\"2\">[ \u6750\u8cea ]\n<ul>\n \t<li>\u9244\u30fb\u30b9\u30c6\u30f3\u30ec\u30b9\u30fb\u30a2\u30eb\u30df<\/li>\n \t<li>\u9285\u30fb\u771f\u936e\u30fb\u5de5\u5177\u92fc<\/li>\n<\/ul>\n<\/th>\n<th colspan=\"4\">\u539a\u307f(Z)<\/th>\n<\/tr>\n<tr>\n<th>\u8584\u677f\u898f\u683c\uff083\u2266Z\uff1c5\uff09<\/th>\n<th>\u901a\u5e38\u898f\u683c\uff085\u2266Z\u226670\uff09<\/th>\n<th>\u539a\u677f\u898f\u683c\uff0870\uff1cZ\u2266130\uff09<\/th>\n<th>\u6750\u6599\u30d7\u30ec\u30fc\u30c8\u898f\u683c\uff085\u2266Z\u226650\uff09<\/th>\n<\/tr>\n<tr>\n<th>SS400, S45C(\u76f8\u5f53), S50C(\u76f8\u5f53)<\/th>\n<td>\u3007<\/td>\n<td>\u3007<\/td>\n<td>\u3007<\/td>\n<td>\u203b\u3007<\/td>\n<\/tr>\n<tr>\n<th>SS400(\u713c\u920d\u6750)\u30fbS50C(\u76f8\u5f53)(\u8abf\u8cea\u6750)\u30fbSCM440\u30fbNAK55(\u76f8\u5f53)<\/th>\n<td>\u00d7<\/td>\n<td>\u3007<\/td>\n<td>\u00d7<\/td>\n<td>\u203b\u3007<\/td>\n<\/tr>\n<tr>\n<th>SKD11\u30fbSK105(SK3\u76f8\u5f53)\u30fbSKS3(\u76f8\u5f53)\u30fbDC53<\/th>\n<td>\u00d7<\/td>\n<td>\u3007<\/td>\n<td>\u00d7<\/td>\n<td>\u00d7<\/td>\n<\/tr>\n<tr>\n<th>A5052\u30fbA5083\u30fbA2017\u30fb A6061\u30fb A7075<\/th>\n<td>\u3007<\/td>\n<td>\u3007<\/td>\n<td>\u3007<\/td>\n<td>\u203b\u3007<\/td>\n<\/tr>\n<tr>\n<th>SUS303\u30fbSUS303(\u713c\u920d\u6750)\u30fbSUS304\u30fbSUS304(\u713c\u920d\u6750)\u30fbSUS316L<\/th>\n<td>\u3007<\/td>\n<td>\u3007<\/td>\n<td>\u00d7<\/td>\n<td>\u203b\u3007<\/td>\n<\/tr>\n<tr>\n<th>C1020(\u7121\u9178\u7d20\u9285)\u30fbC1100(\u30bf\u30d5\u30d4\u30c3\u30c1\u9285)\u30fbC2801P(\u771f\u936e)<\/th>\n<td>\u3007<\/td>\n<td>\u3007<\/td>\n<td>\u00d7<\/td>\n<td>\u00d7<\/td>\n<\/tr>\n<tr>\n<th>SUS316<\/th>\n<td>\u3007<\/td>\n<td>\u203b Z\u226668<\/td>\n<td>\u00d7<\/td>\n<td>\u203b Z\u226630<\/td>\n<\/tr>\n<tr>\n<th>SUS430<\/th>\n<td>\u3007<\/td>\n<td>\u203b Z\u226630<\/td>\n<td>\u00d7<\/td>\n<td>\u203b Z\u226630<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\n<ul>\n \t<li>\u203b\u6750\u6599\u30d7\u30ec\u30fc\u30c8\u306f\u3001\u4ee5\u4e0b\u306e\u6750\u8cea\u306b\u306f\u5bfe\u5fdc\u3057\u3066\u304a\u308a\u307e\u305b\u3093\u3002<\/li>\n \t<li>S45C(\u76f8\u5f53)\u3001SKD11\u3001SK105(SK3\u76f8\u5f53)\u3001SKS3(\u76f8\u5f53)\u3001DC53\u3001A5083\u3001SUS316L\u3001C1020(\u7121\u9178\u7d20\u9285)\u3001C1100(\u30bf\u30d5\u30d4\u30c3\u30c1\u9285)\u3001C2801(\u771f\u936e)<\/li>\n \t<li>\u203b\u6750\u6599\u30d7\u30ec\u30fc\u30c8\u306e\u539a\u307f(Z)\u306f\u3001\u4ee5\u4e0b\u306e\u6750\u8cea\u306b\u3064\u3044\u3066\u306f\u6750\u6599\u30d7\u30ec\u30fc\u30c8\u898f\u683c\u3068\u7570\u306a\u308a\u307e\u3059\u3002<\/li>\n \t<li>\u203b\u3007(\u6750\u6599\u30d7\u30ec\u30fc\u30c8\u898f\u683c)\uff1a5\u2266Z&lt;50\u3001S50C\u76f8\u5f53(\u8abf\u8cea\u6750)\uff1a5\u2266Z\u226630\u3001NAK55(\u76f8\u5f53)\uff1a5\u2266Z\u226640\u3001SCM440\uff1a5\u2266Z\u226635\u3001SUS303(\u713c\u920d\u6750)\uff1a5\u2266Z\u226630\u3001SUS304(\u713c\u920d\u6750)\uff1a5\u2266Z\u226630<\/li>\n<\/ul>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-7fe4d5b tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"7fe4d5b\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p style=\"text-align: right;\">[ mm ]<\/p><table class=\"table04 mT0 fixed tableHover\"><tbody><tr><th rowspan=\"2\">[ \u6750\u8cea ]<br \/>\u6a39\u8102<\/th><th colspan=\"4\">\u539a\u307f(Z)<\/th><\/tr><tr><th>\u8584\u677f\u898f\u683c\uff083\u2266Z\uff1c5\uff09<\/th><th>\u901a\u5e38\u898f\u683c\uff085\u2266Z\u226670\uff09<\/th><th>\u539a\u677f\u898f\u683c\uff0870\uff1cZ\u2266130\uff09<\/th><th>\u6750\u6599\u30d7\u30ec\u30fc\u30c8\u898f\u683c\uff085\u2266Z\u226650\uff09<\/th><\/tr><tr><th>MC\u30ca\u30a4\u30ed\u30f3\uff08\u8010\u5019\/\u9ed2\u7070, \u30a2\u30a4\u30dc\u30ea\u30fc\uff09<\/th><td>\u00d7<\/td><td>\u203b Z\u226650<\/td><td>\u00d7<\/td><td>\u203b Z\u226650<\/td><\/tr><tr><th>MC\u30ca\u30a4\u30ed\u30f3\uff08\u5c0e\u96fb\/\u9ed2\uff09<\/th><td>\u00d7<\/td><td>\u203b Z\u226630<\/td><td>\u00d7<\/td><td>\u203b Z\u226630<\/td><\/tr><tr><th>MC\u30ca\u30a4\u30ed\u30f3\uff08\u5e2f\u96fb\u9632\u6b62\/\u9ed2\uff09<\/th><td>\u00d7<\/td><td>\u203b Z\u226650<\/td><td>\u00d7<\/td><td>\u00d7<\/td><\/tr><tr><th>\u8d85\u9ad8\u5206\u5b50\u91cf\u30dd\u30ea\u30a8\u30c1\u30ec\u30f3\uff08\u5c0e\u96fb\/\u9ed2\uff09<\/th><td>\u00d7<\/td><td>\u203b Z\u226650<\/td><td>\u00d7<\/td><td>\u00d7<\/td><\/tr><tr><th>\u30e6\u30cb\u30ec\u30fc\u30c8<br \/>\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\/\u8336\uff09<\/th><td>\u00d7<\/td><td>\u203b Z\u226650<\/td><td>\u00d7<\/td><td>\u00d7<\/td><\/tr><tr><th>\u3075\u3063\u7d20\uff08PTFE\uff09<\/th><td>\u00d7<\/td><td>\u203bZ\u226630<\/td><td>\u00d7<\/td><td>\u00d7<\/td><\/tr><tr><th>\u30d9\u30fc\u30af\u30e9\u30a4\u30c8<br \/>\uff08\u7d19\/\u81ea\u7136\u8272, \u7d19\/\u9ed2, \u5e03\/\u81ea\u7136\u8272\uff09<\/th><td>\u00d7<\/td><td>\u203b Z\u226630<\/td><td>\u00d7<\/td><td>\u203b Z\u226630<\/td><\/tr><tr><th>PPS<br \/>\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\/\u81ea\u7136\u8272\uff09<\/th><td>\u00d7<\/td><td>\u203b Z\u226630<\/td><td>\u00d7<\/td><td>\u00d7<\/td><\/tr><tr><th>\u4e0a\u8a18\u4ee5\u5916\u306e\u6a39\u8102\u6750\u8cea<\/th><td>\u00d7<\/td><td>\u203b Z\u226660<\/td><td>\u00d7<\/td><td>\u203b Z\u226650<\/td><\/tr><\/tbody><\/table><ul><li>\u203b\u6a39\u8102\u6750\u306e\u901a\u5e38\u898f\u683c\u306fZ\u226660\u3068\u306a\u308a\u307e\u3059\u3002<\/li><li>\u203b\u6750\u6599\u30d7\u30ec\u30fc\u30c8\u306f\u3001\u4e0a\u8a18\u30ea\u30b9\u30c8\u4ee5\u5916\u306b\u3082\u3001\u4ee5\u4e0b\u306e\u6750\u8cea\u306b\u306f\u5bfe\u5fdc\u3057\u3066\u304a\u308a\u307e\u305b\u3093\u3002<br \/>\u3075\u3063\u7d20(\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u767d)\u3001PEEK(\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u7070\u8910\u8272)\u3001PP(\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u767d)\u3001\u30e6\u30cb\u30ec\u30fc\u30c8(\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u8336)<\/li><\/ul>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-bc0f662 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"bc0f662\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p style=\"text-align: right;\">[ mm ]<\/p><table class=\"table04 mT0 fixed tableHover_single\"><tbody><tr><th class=\"tblColCFStyle01_3420\" rowspan=\"2\"><div>[ \u6750\u8cea ]<\/div><p>\u30a6\u30ec\u30bf\u30f3<\/p><\/th><th colspan=\"2\">\u539a\u307f(Z)<\/th><\/tr><tr><th>\u8584\u677f\u898f\u683c\uff081\u2266Z\u226650\uff09<\/th><th>\u539a\u677f\u898f\u683c\uff0850\uff1cZ\uff09<\/th><\/tr><tr><th>\u6a19\u6e96\u30a6\u30ec\u30bf\u30f3(A90\u30fb\u30a8\u30fc\u30c6\u30eb\u7cfb\u30fb\u81ea\u7136\u8272)<\/th><td>\u3007<\/td><td>\u00d7<\/td><\/tr><tr><th>\u6a19\u6e96\u30a6\u30ec\u30bf\u30f3(A70\u30fb\u30a8\u30b9\u30c6\u30eb\u7cfb\u30fb\u81ea\u7136\u8272)<\/th><td>\u3007<\/td><td>\u00d7<\/td><\/tr><tr><th>\u6a19\u6e96\u30a6\u30ec\u30bf\u30f3(A50\u30fb\u30a8\u30b9\u30c6\u30eb\u7cfb\u30fb\u81ea\u7136\u8272)<\/th><td>Z\u226630<\/td><td>\u00d7<\/td><\/tr><\/tbody><\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-a357eb7 print_block\t elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"a357eb7\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-096424c\" data-id=\"096424c\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-74fa5f8 elementor-widget elementor-widget-menu-anchor\" data-id=\"74fa5f8\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"menu-anchor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t<div class=\"elementor-menu-anchor\" id=\"box3\"><\/div>\n\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-93f572a elementor-widget elementor-widget-heading\" data-id=\"93f572a\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h3 class=\"elementor-heading-title elementor-size-default\">\u81ea\u52d5\u898b\u7a4d\u30b5\u30a4\u30ba \u9577\u3055(X)\u30fb\u5e45(Y)\n<\/h3>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-222da04 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"222da04\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p style=\"text-align: right;\">[ mm ]<\/p>\n\n<table class=\"table04 mT0 w100p\">\n<tbody>\n<tr>\n<th colspan=\"2\" rowspan=\"2\">\n<ul>\n \t<li>[ \u6750\u8cea ]<\/li>\n \t<li>\u9244\u30fb\u30b9\u30c6\u30f3\u30ec\u30b9\u30fb\u30a2\u30eb\u30df<\/li>\n \t<li>\u9285\u30fb\u771f\u936e\u30fb\u5de5\u5177\u92fc<\/li>\n<\/ul>\n<\/th>\n<th colspan=\"9\">\u5e45(Y)<\/th>\n<\/tr>\n<tr>\n<th>5\u2266<\/th>\n<th>\u226610<\/th>\n<th>\u226670<\/th>\n<th>\u2266100<\/th>\n<th>\u2266200<\/th>\n<th>\u2266300<\/th>\n<th>\u2266400<\/th>\n<th>\u2266500<\/th>\n<th>\u2266600<\/th>\n<\/tr>\n<tr>\n<th rowspan=\"10\">\u9577\u3055(X)<\/th>\n<th>5\u2266<\/th>\n<td style=\"background-color: #fbe2d5;\" colspan=\"4\" rowspan=\"4\">\n<ul>\n \t<li>\u8584\u677f\u898f\u683c\uff083\u2266Z\uff1c5\uff09<\/li>\n \t<li>\u5bfe\u8c61\u6750\u8cea\u5168\u3066<\/li>\n<\/ul>\n<\/td>\n<td style=\"border-right: none;\" colspan=\"4\"><\/td>\n<td><\/td>\n<\/tr>\n<tr>\n<th>\u226610<\/th>\n<td style=\"border-right: 2px dashed #4d93d9; background-color: #c0e6f5;\" rowspan=\"2\"><\/td>\n<td style=\"border-right: 2px dashed #4d93d9; background-color: #c0e6f5;\" rowspan=\"2\"><\/td>\n<td style=\"border-right: 2px dashed #4d93d9; background-color: #c0e6f5;\" rowspan=\"2\"><\/td>\n<td style=\"border-bottom: none; background-color: #c0e6f5;\" colspan=\"2\" rowspan=\"8\"><\/td>\n<\/tr>\n<tr>\n<th>\u226670<\/th>\n<\/tr>\n<tr>\n<th>\u2266100<\/th>\n<td style=\"border-bottom: none; background-color: #daf2d0;\" colspan=\"3\"><\/td>\n<\/tr>\n<tr>\n<th>\u2266250<\/th>\n<td rowspan=\"6\"><\/td>\n<td style=\"border-bottom: 2px dashed #4d93d9; background-color: #c0e6f5; text-align: left; vertical-align: bottom; color: #215f9a;\" colspan=\"2\">S50C \u8abf\u8cea\u6750<\/td>\n<td style=\"border-bottom: none; background-color: #daf2d0;\" colspan=\"4\" rowspan=\"2\">\n<ul>\n \t<li>\u539a\u677f\u898f\u683c\uff0870\uff1cZ\u2266130\uff09<\/li>\n \t<li>\u5bfe\u8c61\u6750\u8cea\u5168\u3066<\/li>\n<\/ul>\n<\/td>\n<\/tr>\n<tr>\n<th>\u2266300<\/th>\n<td style=\"border-bottom: 2px dashed #4d93d9; background-color: #c0e6f5; text-align: left; vertical-align: bottom; color: #215f9a;\" colspan=\"2\">NAK55\u30fbSKD11<\/td>\n<\/tr>\n<tr>\n<th>\u2266400<\/th>\n<td style=\"border-bottom: 2px dashed #4d93d9; background-color: #c0e6f5; text-align: left; vertical-align: bottom; color: #215f9a;\" colspan=\"2\">SK105\uff08SK3\u76f8\u5f53\uff09\u30fbSKS3\uff08\u76f8\u5f53\uff09\u30fbDC53\u30fbSUS316L\u30fbC1020\uff08\u7121\u9178\u7d20\u9285\uff09\u30fbC1100\uff08\u30bf\u30d5\u30d4\u30c3\u30c1\u9285\uff09\u30fbC2801P\uff08\u771f\u936e\uff09<\/td>\n<td style=\"background-color: #daf2d0;\" colspan=\"4\"><\/td>\n<\/tr>\n<tr>\n<th>\u2266500<\/th>\n<td style=\"border: none; background-color: #c0e6f5; text-align: left; vertical-align: bottom;\" colspan=\"3\"><\/td>\n<td style=\"border: none; background-color: #c0e6f5; text-align: left; vertical-align: bottom;\" colspan=\"2\">\u901a\u5e38\u898f\u683c\uff085\u2266Z\u226670\uff09<\/td>\n<td style=\"border-right: 2px dashed #4d93d9; border-bottom: none; background-color: #c0e6f5; text-align: left; vertical-align: bottom;\"><\/td>\n<\/tr>\n<tr>\n<th>\u2266600<\/th>\n<td style=\"border-bottom: 2px dashed #4d93d9; border-right: 2px dashed #4d93d9; background-color: #c0e6f5; text-align: left; vertical-align: bottom; color: #215f9a;\" colspan=\"6\">SS400 \u713c\u920d\u6750\u30fbSCM440\u30fbSUS303 \u713c\u920d\u6750\u30fbSUS304 \u713c\u920d\u6750\u30fbSUS316\u30fbSUS430<\/td>\n<\/tr>\n<tr>\n<th>\u22661000<\/th>\n<td style=\"background-color: #c0e6f5; text-align: left; vertical-align: bottom; color: #215f9a;\" colspan=\"8\">SS400\u30fbS50C(\u76f8\u5f53)\u30fbS45C(\u76f8\u5f53)\u30fbA2017\u30fbA5052\u30fbA5083\u30fbA6061\u30fbA7075\u30fbSUS303\u30fbSUS304<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-c63cd56 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"c63cd56\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p style=\"text-align: right;\">[ mm ]<\/p><table class=\"table04 mT0 w100p\"><tbody><tr><th colspan=\"2\" rowspan=\"2\"><div>[ \u6750\u8cea ]<\/div><div>\u6a39\u8102\u30fb\u30a6\u30ec\u30bf\u30f3<\/div><\/th><th colspan=\"9\">\u5e45(Y)<\/th><\/tr><tr><th>5\u2266<\/th><th>\u226610<\/th><th>\u226670<\/th><th>\u2266100<\/th><th>\u2266200<\/th><th>\u2266300<\/th><th>\u2266400<\/th><th>\u2266500<\/th><th>\u2266600<\/th><\/tr><tr><th rowspan=\"10\">\u9577\u3055(X)<\/th><th>5\u2266<\/th><td style=\"border-bottom: none; border-right: none;\">\u00a0<\/td><td style=\"border-right: none;\" colspan=\"6\">\u00a0<\/td><td style=\"border-bottom: none;\" colspan=\"2\" rowspan=\"10\">\u00a0<\/td><\/tr><tr><th>\u226610<\/th><td style=\"border-bottom: none;\" rowspan=\"8\">\u00a0<\/td><td style=\"border-right: none; border-bottom: none; background-color: #c0e6f5;\" colspan=\"2\" rowspan=\"6\">\u00a0<\/td><td style=\"border-right: none; border-bottom: 2px dashed #4d93d9; background-color: #c0e6f5;\" colspan=\"2\" rowspan=\"7\"><div>\u901a\u5e38\u898f\u683c\uff085\u2266Z\u226660\uff09<\/div><p>\u203b\u30a6\u30ec\u30bf\u30f3\u306f1\u2266Z\u226650<\/p><\/td><td style=\"border-bottom: none; background-color: #c0e6f5;\" colspan=\"2\" rowspan=\"6\">\u00a0<\/td><\/tr><tr><th>\u226670<\/th><\/tr><tr><th>\u2266100<\/th><\/tr><tr><th>\u2266200<\/th><\/tr><tr><th>\u2266300<\/th><\/tr><tr><th>\u2266400<\/th><\/tr><tr><th>\u2266500<\/th><td style=\"border-right: none; border-bottom: 2px dashed #4d93d9; background-color: #c0e6f5; text-align: left; vertical-align: bottom; color: #215f9a;\" colspan=\"2\">\u3075\u3063\u7d20 [PTFE]<\/td><td style=\"border-bottom: 2px dashed #4d93d9; background-color: #c0e6f5;\" colspan=\"2\">\u00a0<\/td><\/tr><tr><th>\u2266600<\/th><td style=\"background-color: #c0e6f5; text-align: left; vertical-align: bottom; color: #215f9a;\" colspan=\"6\">\u3075\u3063\u7d20 [PTFE] \u4ee5\u5916\u306e\u5bfe\u8c61\u6750\u8cea\u5168\u3066<\/td><\/tr><tr><th>\u22661000<\/th><td colspan=\"9\">\u00a0<\/td><\/tr><\/tbody><\/table><ul><li>\u203b\u6750\u6599\u30d7\u30ec\u30fc\u30c8\u306e\u9577\u3055(X)\u30fb\u5e45(Y)\u306f\u3001\u4ee5\u4e0b\u306e\u6750\u8cea\u306b\u3064\u3044\u3066\u306f\u901a\u5e38\u306e\u898f\u683c\u3068\u7570\u306a\u308a\u307e\u3059\u3002<\/li><li>SCM440\uff1a10\u2266X\u2266300 10\u2266Y\u2266200\u3001SUS303\/SUS303(\u713c\u920d\u6750)\/SUS304\/SUS304(\u713c\u920d\u6750)\/SUS316\/SUS430\uff1a10\u2266X\u2266500 10\u2266Y\u2266200<\/li><\/ul>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-a132c05 elementor-widget elementor-widget-text-editor\" data-id=\"a132c05\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<div class=\"txtBasic bg\"><p class=\"labelNote\">\u6ce8\u610f<\/p><ul><li>\u81ea\u52d5\u898b\u7a4d\u30b5\u30a4\u30ba\u306f\u3001\u304a\u898b\u7a4d\u6761\u4ef6\u306b\u3088\u3063\u3066\u306f\u9069\u5408\u3057\u306a\u3044\u5834\u5408\u304c\u3054\u3056\u3044\u307e\u3059\u3002\uff08\u8584\u677f\u898f\u683c\u306f\u8868\u9762\u51e6\u7406\u306b\u5bfe\u5fdc\u3057\u3066\u3044\u307e\u305b\u3093\u3002\uff09<\/li><li>\u4e0d\u660e\u70b9\u304c\u3054\u3056\u3044\u307e\u3057\u305f\u3089 meviy\u30b5\u30dd\u30fc\u30c8\u307e\u3067\u304a\u554f\u3044\u5408\u308f\u305b\u304f\u3060\u3055\u3044\u3002<\/li><li>\u304a\u554f\u3044\u5408\u308f\u305b\u306f<a href=\"https:\/\/pages.jp.meviy.misumi-ec.com\/ask\/\">\u3053\u3061\u3089<\/a><\/li><\/ul><\/div>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-9a44ed4 print_block elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"9a44ed4\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-d2625cd\" data-id=\"d2625cd\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-47a2ccf elementor-widget elementor-widget-menu-anchor\" data-id=\"47a2ccf\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"menu-anchor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t<div class=\"elementor-menu-anchor\" id=\"box4\"><\/div>\n\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-3994140 elementor-widget elementor-widget-heading\" data-id=\"3994140\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h3 class=\"elementor-heading-title elementor-size-default\">\u30df\u30ac\u30ad\u6750\u30d5\u30e9\u30c3\u30c8\u30d0\u30fc \u81ea\u52d5\u898b\u7a4d\u30b5\u30a4\u30ba \u5e45(Y)\u30fb\u539a\u307f(Z)<\/h3>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-bf2c40e elementor-widget elementor-widget-heading\" data-id=\"bf2c40e\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h5 class=\"elementor-heading-title elementor-size-default\">[ \u30df\u30ac\u30ad\u6750\u5171\u901a ] \u9577\u3055(X)\uff1a10\u2266X\u2266500\n<\/h5>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-e13d975 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"e13d975\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p style=\"text-align: right;\">[ mm ]<\/p>\n\n<table class=\"table04 fixed tableHover\" style=\"width: 100%; margin-top: 10px;\">\n<tbody>\n<tr>\n<th colspan=\"2\" width=\"12%\">SS400-D<\/th>\n<th colspan=\"23\" width=\"\">\u00a0Y\u5bf8<\/th>\n<\/tr>\n<tr>\n<th rowspan=\"14\">Z\u5bf8<\/th>\n<th>3<\/th>\n\t\t<td>10<\/td>\n\t\t<td>12<\/td>\n\t\t<td>13<\/td>\n\t\t<td><\/td>\n\t\t<td>16<\/td>\n\t\t<td>19<\/td>\n\t\t<td><\/td>\n\t\t<td>22<\/td>\n\t\t<td>25<\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>32<\/td>\n\t\t<td>38<\/td>\n\t\t<td><\/td>\n\t\t<td>44<\/td>\n\t\t<td><\/td>\n\t\t<td>50<\/td>\n\t\t<td><\/td>\n\t\t<td>65<\/td>\n\t\t<td>75<\/td>\n\t\t<td><\/td>\n\t\t<td>100<\/td>\n\t\t<td><\/td>\n\t<\/tr>\n\t<tr>\n\t\t<th>4<\/th>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>16<\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>32<\/td>\n\t\t<td>38<\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t<\/tr>\n\t<tr>\n\t\t<th>4.5<\/th>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>13<\/td>\n\t\t<td><\/td>\n\t\t<td>16<\/td>\n\t\t<td>19<\/td>\n\t\t<td><\/td>\n\t\t<td>22<\/td>\n\t\t<td>25<\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>32<\/td>\n\t\t<td>38<\/td>\n\t\t<td><\/td>\n\t\t<td>44<\/td>\n\t\t<td><\/td>\n\t\t<td>50<\/td>\n\t\t<td><\/td>\n\t\t<td>65<\/td>\n\t\t<td>75<\/td>\n\t\t<td>90<\/td>\n\t\t<td>100<\/td>\n\t\t<td><\/td>\n\t<\/tr>\n\t<tr>\n\t\t<th>5<\/th>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>16<\/td>\n\t\t<td>19<\/td>\n\t\t<td><\/td>\n\t\t<td>22<\/td>\n\t\t<td>25<\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>32<\/td>\n\t\t<td>38<\/td>\n\t\t<td><\/td>\n\t\t<td>44<\/td>\n\t\t<td><\/td>\n\t\t<td>50<\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t<\/tr>\n\t<tr>\n\t\t<th>6<\/th>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>16<\/td>\n\t\t<td>19<\/td>\n\t\t<td><\/td>\n\t\t<td>22<\/td>\n\t\t<td>25<\/td>\n\t\t<td>28<\/td>\n\t\t<td><\/td>\n\t\t<td>32<\/td>\n\t\t<td>38<\/td>\n\t\t<td>40<\/td>\n\t\t<td>44<\/td>\n\t\t<td>45<\/td>\n\t\t<td>50<\/td>\n\t\t<td>60<\/td>\n\t\t<td>65<\/td>\n\t\t<td>75<\/td>\n\t\t<td>90<\/td>\n\t\t<td>100<\/td>\n\t\t<td>125<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<th>8<\/th>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>16<\/td>\n\t\t<td>19<\/td>\n\t\t<td><\/td>\n\t\t<td>22<\/td>\n\t\t<td>25<\/td>\n\t\t<td><\/td>\n\t\t<td>30<\/td>\n\t\t<td>32<\/td>\n\t\t<td>38<\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>50<\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t<\/tr>\n\t<tr>\n\t\t<th>9<\/th>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>16<\/td>\n\t\t<td>19<\/td>\n\t\t<td><\/td>\n\t\t<td>22<\/td>\n\t\t<td>25<\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>32<\/td>\n\t\t<td>38<\/td>\n\t\t<td><\/td>\n\t\t<td>44<\/td>\n\t\t<td>45<\/td>\n\t\t<td>50<\/td>\n\t\t<td>60<\/td>\n\t\t<td>65<\/td>\n\t\t<td>75<\/td>\n\t\t<td>90<\/td>\n\t\t<td>100<\/td>\n\t\t<td>125<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<th>10<\/th>\n\t\t<td>10<\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>15<\/td>\n\t\t<td>16<\/td>\n\t\t<td><\/td>\n\t\t<td>20<\/td>\n\t\t<td>22<\/td>\n\t\t<td>25<\/td>\n\t\t<td><\/td>\n\t\t<td>30<\/td>\n\t\t<td>32<\/td>\n\t\t<td>38<\/td>\n\t\t<td>40<\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>50<\/td>\n\t\t<td>60<\/td>\n\t\t<td>65<\/td>\n\t\t<td>75<\/td>\n\t\t<td>90<\/td>\n\t\t<td>100<\/td>\n\t\t<td>125<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<th>12<\/th>\n\t\t<td><\/td>\n\t\t<td>12<\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>16<\/td>\n\t\t<td>19<\/td>\n\t\t<td>20<\/td>\n\t\t<td>22<\/td>\n\t\t<td>25<\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>32<\/td>\n\t\t<td>38<\/td>\n\t\t<td><\/td>\n\t\t<td>44<\/td>\n\t\t<td>45<\/td>\n\t\t<td>50<\/td>\n\t\t<td>60<\/td>\n\t\t<td>65<\/td>\n\t\t<td>75<\/td>\n\t\t<td>90<\/td>\n\t\t<td>100<\/td>\n\t\t<td>125<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<th>16<\/th>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>16<\/td>\n\t\t<td>19<\/td>\n\t\t<td>20<\/td>\n\t\t<td>22<\/td>\n\t\t<td>25<\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>32<\/td>\n\t\t<td>38<\/td>\n\t\t<td><\/td>\n\t\t<td>44<\/td>\n\t\t<td>45<\/td>\n\t\t<td>50<\/td>\n\t\t<td>60<\/td>\n\t\t<td>65<\/td>\n\t\t<td>75<\/td>\n\t\t<td>90<\/td>\n\t\t<td>100<\/td>\n\t\t<td>125<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<th>19<\/th>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>19<\/td>\n\t\t<td><\/td>\n\t\t<td>22<\/td>\n\t\t<td>25<\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>32<\/td>\n\t\t<td>38<\/td>\n\t\t<td><\/td>\n\t\t<td>44<\/td>\n\t\t<td>45<\/td>\n\t\t<td>50<\/td>\n\t\t<td>60<\/td>\n\t\t<td>65<\/td>\n\t\t<td>75<\/td>\n\t\t<td>90<\/td>\n\t\t<td>100<\/td>\n\t\t<td>125<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<th>22<\/th>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>22<\/td>\n\t\t<td>25<\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>32<\/td>\n\t\t<td>38<\/td>\n\t\t<td><\/td>\n\t\t<td>44<\/td>\n\t\t<td><\/td>\n\t\t<td>50<\/td>\n\t\t<td>60<\/td>\n\t\t<td>65<\/td>\n\t\t<td>75<\/td>\n\t\t<td>90<\/td>\n\t\t<td>100<\/td>\n\t\t<td>125<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<th>25<\/th>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>25<\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>32<\/td>\n\t\t<td>38<\/td>\n\t\t<td><\/td>\n\t\t<td>44<\/td>\n\t\t<td>45<\/td>\n\t\t<td>50<\/td>\n\t\t<td>60<\/td>\n\t\t<td>65<\/td>\n\t\t<td>75<\/td>\n\t\t<td>90<\/td>\n\t\t<td>100<\/td>\n\t\t<td>125<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<th>30<\/th>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>30<\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>50<\/td>\n\t\t<td><\/td>\n\t\t<td>65<\/td>\n\t\t<td>75<\/td>\n\t\t<td><\/td>\n\t\t<td>100<\/td>\n\t\t<td>125<\/td>\n\t<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-03e3279 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"03e3279\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"table04 fixed tableHover\" style=\"width: 100%;\">\n<tbody>\n<tr>\n<th colspan=\"2\" width=\"12%\">S45C-D<\/th>\n<th colspan=\"17\">\u00a0Y\u5bf8<\/th>\n<\/tr>\n<tr>\n<th rowspan=\"11\">Z\u5bf8<\/th>\n<th>3<\/th>\n\t\t<td><\/td>\n\t\t<td>13<\/td>\n\t\t<td>16<\/td>\n\t\t<td>19<\/td>\n\t\t<td>22<\/td>\n\t\t<td>25<\/td>\n\t\t<td><\/td>\n\t\t<td>32<\/td>\n\t\t<td>38<\/td>\n\t\t<td><\/td>\n\t\t<td>50<\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t<\/tr>\n\t<tr>\n\t\t<th>4.5<\/th>\n\t\t<td><\/td>\n\t\t<td>13<\/td>\n\t\t<td>16<\/td>\n\t\t<td>19<\/td>\n\t\t<td>22<\/td>\n\t\t<td>25<\/td>\n\t\t<td><\/td>\n\t\t<td>32<\/td>\n\t\t<td>38<\/td>\n\t\t<td><\/td>\n\t\t<td>50<\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t<\/tr>\n\t<tr>\n\t\t<th>5<\/th>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>16<\/td>\n\t\t<td>19<\/td>\n\t\t<td>22<\/td>\n\t\t<td>25<\/td>\n\t\t<td><\/td>\n\t\t<td>32<\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t<\/tr>\n\t<tr>\n\t\t<th>6<\/th>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>16<\/td>\n\t\t<td>19<\/td>\n\t\t<td>22<\/td>\n\t\t<td>25<\/td>\n\t\t<td><\/td>\n\t\t<td>32<\/td>\n\t\t<td>38<\/td>\n\t\t<td>44<\/td>\n\t\t<td>50<\/td>\n\t\t<td>60<\/td>\n\t\t<td>65<\/td>\n\t\t<td>75<\/td>\n\t\t<td>90<\/td>\n\t\t<td>100<\/td>\n\t\t<td>125<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<th>9<\/th>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>16<\/td>\n\t\t<td>19<\/td>\n\t\t<td>22<\/td>\n\t\t<td>25<\/td>\n\t\t<td><\/td>\n\t\t<td>32<\/td>\n\t\t<td>38<\/td>\n\t\t<td>44<\/td>\n\t\t<td>50<\/td>\n\t\t<td>60<\/td>\n\t\t<td>65<\/td>\n\t\t<td>75<\/td>\n\t\t<td>90<\/td>\n\t\t<td>100<\/td>\n\t\t<td>125<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<th>12<\/th>\n\t\t<td>12<\/td>\n\t\t<td><\/td>\n\t\t<td>16<\/td>\n\t\t<td>19<\/td>\n\t\t<td>22<\/td>\n\t\t<td>25<\/td>\n\t\t<td><\/td>\n\t\t<td>32<\/td>\n\t\t<td>38<\/td>\n\t\t<td>44<\/td>\n\t\t<td>50<\/td>\n\t\t<td>60<\/td>\n\t\t<td>65<\/td>\n\t\t<td>75<\/td>\n\t\t<td>90<\/td>\n\t\t<td>100<\/td>\n\t\t<td>125<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<th>16<\/th>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>16<\/td>\n\t\t<td>19<\/td>\n\t\t<td>22<\/td>\n\t\t<td>25<\/td>\n\t\t<td><\/td>\n\t\t<td>32<\/td>\n\t\t<td>38<\/td>\n\t\t<td>44<\/td>\n\t\t<td>50<\/td>\n\t\t<td>60<\/td>\n\t\t<td>65<\/td>\n\t\t<td>75<\/td>\n\t\t<td>90<\/td>\n\t\t<td>100<\/td>\n\t\t<td>125<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<th>19<\/th>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>19<\/td>\n\t\t<td>22<\/td>\n\t\t<td>25<\/td>\n\t\t<td><\/td>\n\t\t<td>32<\/td>\n\t\t<td>38<\/td>\n\t\t<td>44<\/td>\n\t\t<td>50<\/td>\n\t\t<td>60<\/td>\n\t\t<td>65<\/td>\n\t\t<td>75<\/td>\n\t\t<td>90<\/td>\n\t\t<td>100<\/td>\n\t\t<td>125<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<th>22<\/th>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>22<\/td>\n\t\t<td>25<\/td>\n\t\t<td><\/td>\n\t\t<td>32<\/td>\n\t\t<td>38<\/td>\n\t\t<td>44<\/td>\n\t\t<td>50<\/td>\n\t\t<td><\/td>\n\t\t<td>65<\/td>\n\t\t<td>75<\/td>\n\t\t<td><\/td>\n\t\t<td>100<\/td>\n\t\t<td>125<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<th>25<\/th>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>25<\/td>\n\t\t<td><\/td>\n\t\t<td>32<\/td>\n\t\t<td>38<\/td>\n\t\t<td>44<\/td>\n\t\t<td>50<\/td>\n\t\t<td>60<\/td>\n\t\t<td>65<\/td>\n\t\t<td>75<\/td>\n\t\t<td>90<\/td>\n\t\t<td>100<\/td>\n\t\t<td>125<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<th>30<\/th>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>30<\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>50<\/td>\n\t\t<td><\/td>\n\t\t<td>65<\/td>\n\t\t<td>75<\/td>\n\t\t<td><\/td>\n\t\t<td>100<\/td>\n\t\t<td>125<\/td>\n\t<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-8d9fce3 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"8d9fce3\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"table04 fixed tableHover\" style=\"width: 100%;\">\n<tbody>\n<tr>\n<th colspan=\"2\" width=\"12%\">SUS304-D<\/th>\n<th colspan=\"26\">\u00a0Y\u5bf8<\/th>\n<\/tr>\n<tr>\n<th rowspan=\"13\">Z\u5bf8<\/th>\n<th>3<\/th>\n\t\t<td>10<\/td>\n\t\t<td><\/td>\n\t\t<td>12<\/td>\n\t\t<td>13<\/td>\n\t\t<td>15<\/td>\n\t\t<td>16<\/td>\n\t\t<td><\/td>\n\t\t<td>19<\/td>\n\t\t<td>20<\/td>\n\t\t<td>22<\/td>\n\t\t<td>25<\/td>\n\t\t<td>30<\/td>\n\t\t<td>32<\/td>\n\t\t<td>35<\/td>\n\t\t<td>38<\/td>\n\t\t<td>40<\/td>\n\t\t<td>42<\/td>\n\t\t<td>45<\/td>\n\t\t<td>48<\/td>\n\t\t<td>50<\/td>\n\t\t<td>60<\/td>\n\t\t<td>65<\/td>\n\t\t<td>75<\/td>\n\t\t<td>90<\/td>\n\t\t<td>100<\/td>\n\t\t<td><\/td>\n\t<\/tr>\n\t<tr>\n\t\t<th>4<\/th>\n\t\t<td>10<\/td>\n\t\t<td>11<\/td>\n\t\t<td>12<\/td>\n\t\t<td>13<\/td>\n\t\t<td>15<\/td>\n\t\t<td>16<\/td>\n\t\t<td>17<\/td>\n\t\t<td>19<\/td>\n\t\t<td>20<\/td>\n\t\t<td>22<\/td>\n\t\t<td>25<\/td>\n\t\t<td>30<\/td>\n\t\t<td>32<\/td>\n\t\t<td>35<\/td>\n\t\t<td>38<\/td>\n\t\t<td>40<\/td>\n\t\t<td><\/td>\n\t\t<td>45<\/td>\n\t\t<td><\/td>\n\t\t<td>50<\/td>\n\t\t<td>60<\/td>\n\t\t<td>65<\/td>\n\t\t<td>75<\/td>\n\t\t<td>90<\/td>\n\t\t<td>100<\/td>\n\t\t<td><\/td>\n\t<\/tr>\n\t<tr>\n\t\t<th>5<\/th>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>15<\/td>\n\t\t<td>16<\/td>\n\t\t<td><\/td>\n\t\t<td>19<\/td>\n\t\t<td>20<\/td>\n\t\t<td>22<\/td>\n\t\t<td>25<\/td>\n\t\t<td>30<\/td>\n\t\t<td>32<\/td>\n\t\t<td>35<\/td>\n\t\t<td>38<\/td>\n\t\t<td>40<\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>50<\/td>\n\t\t<td>60<\/td>\n\t\t<td>65<\/td>\n\t\t<td>75<\/td>\n\t\t<td>90<\/td>\n\t\t<td>100<\/td>\n\t\t<td><\/td>\n\t<\/tr>\n\t<tr>\n\t\t<th>6<\/th>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>15<\/td>\n\t\t<td>16<\/td>\n\t\t<td><\/td>\n\t\t<td>19<\/td>\n\t\t<td>20<\/td>\n\t\t<td>22<\/td>\n\t\t<td>25<\/td>\n\t\t<td>30<\/td>\n\t\t<td>32<\/td>\n\t\t<td>35<\/td>\n\t\t<td>38<\/td>\n\t\t<td>40<\/td>\n\t\t<td><\/td>\n\t\t<td>45<\/td>\n\t\t<td><\/td>\n\t\t<td>50<\/td>\n\t\t<td>60<\/td>\n\t\t<td>65<\/td>\n\t\t<td>75<\/td>\n\t\t<td>90<\/td>\n\t\t<td>100<\/td>\n\t\t<td>125<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<th>8<\/th>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>16<\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>32<\/td>\n\t\t<td><\/td>\n\t\t<td>38<\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>50<\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t<\/tr>\n\t<tr>\n\t\t<th>9<\/th>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>15<\/td>\n\t\t<td>16<\/td>\n\t\t<td><\/td>\n\t\t<td>19<\/td>\n\t\t<td>20<\/td>\n\t\t<td>22<\/td>\n\t\t<td>25<\/td>\n\t\t<td><\/td>\n\t\t<td>32<\/td>\n\t\t<td><\/td>\n\t\t<td>38<\/td>\n\t\t<td>40<\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>50<\/td>\n\t\t<td>60<\/td>\n\t\t<td>65<\/td>\n\t\t<td>75<\/td>\n\t\t<td>90<\/td>\n\t\t<td>100<\/td>\n\t\t<td>125<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<th>10<\/th>\n\t\t<td>10<\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>15<\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>19<\/td>\n\t\t<td>20<\/td>\n\t\t<td><\/td>\n\t\t<td>25<\/td>\n\t\t<td>30<\/td>\n\t\t<td>32<\/td>\n\t\t<td><\/td>\n\t\t<td>38<\/td>\n\t\t<td>40<\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>50<\/td>\n\t\t<td><\/td>\n\t\t<td>65<\/td>\n\t\t<td>75<\/td>\n\t\t<td><\/td>\n\t\t<td>100<\/td>\n\t\t<td>125<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<th>12<\/th>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>12<\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>16<\/td>\n\t\t<td><\/td>\n\t\t<td>19<\/td>\n\t\t<td>20<\/td>\n\t\t<td><\/td>\n\t\t<td>25<\/td>\n\t\t<td>30<\/td>\n\t\t<td>32<\/td>\n\t\t<td><\/td>\n\t\t<td>38<\/td>\n\t\t<td>40<\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>50<\/td>\n\t\t<td><\/td>\n\t\t<td>65<\/td>\n\t\t<td>75<\/td>\n\t\t<td>90<\/td>\n\t\t<td>100<\/td>\n\t\t<td>125<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<th>16<\/th>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>16<\/td>\n\t\t<td><\/td>\n\t\t<td>19<\/td>\n\t\t<td>20<\/td>\n\t\t<td><\/td>\n\t\t<td>25<\/td>\n\t\t<td><\/td>\n\t\t<td>32<\/td>\n\t\t<td><\/td>\n\t\t<td>38<\/td>\n\t\t<td>40<\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>50<\/td>\n\t\t<td><\/td>\n\t\t<td>65<\/td>\n\t\t<td>75<\/td>\n\t\t<td><\/td>\n\t\t<td>100<\/td>\n\t\t<td>125<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<th>19<\/th>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>19<\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>25<\/td>\n\t\t<td><\/td>\n\t\t<td>32<\/td>\n\t\t<td><\/td>\n\t\t<td>38<\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>50<\/td>\n\t\t<td><\/td>\n\t\t<td>65<\/td>\n\t\t<td>75<\/td>\n\t\t<td><\/td>\n\t\t<td>100<\/td>\n\t\t<td>125<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<th>22<\/th>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>22<\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>32<\/td>\n\t\t<td><\/td>\n\t\t<td>38<\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>50<\/td>\n\t\t<td><\/td>\n\t\t<td>65<\/td>\n\t\t<td>75<\/td>\n\t\t<td><\/td>\n\t\t<td>100<\/td>\n\t\t<td><\/td>\n\t<\/tr>\n\t<tr>\n\t\t<th>25<\/th>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>25<\/td>\n\t\t<td><\/td>\n\t\t<td>32<\/td>\n\t\t<td><\/td>\n\t\t<td>38<\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>50<\/td>\n\t\t<td><\/td>\n\t\t<td>65<\/td>\n\t\t<td>75<\/td>\n\t\t<td><\/td>\n\t\t<td>100<\/td>\n\t\t<td>125<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<th>30<\/th>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>30<\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td><\/td>\n\t\t<td>50<\/td>\n\t\t<td><\/td>\n\t\t<td>65<\/td>\n\t\t<td>75<\/td>\n\t\t<td><\/td>\n\t\t<td>100<\/td>\n\t\t<td><\/td>\n\t<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-6b83fc0 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"6b83fc0\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t&nbsp;\n<table class=\"table04 fixed tableHover\" style=\"width: 100%;\">\n<tbody>\n<tr>\n<th colspan=\"2\" width=\"12%\">A6063S<\/th>\n<th colspan=\"12\">\u00a0Y\u5bf8<\/th>\n<\/tr>\n<tr>\n<th rowspan=\"11\">Z\u5bf8<\/th>\n<th>3<\/th>\n<td>10<\/td>\n<td>12<\/td>\n<td>15<\/td>\n<td>20<\/td>\n<td>25<\/td>\n<td>30<\/td>\n<td>35<\/td>\n<td>40<\/td>\n<td>50<\/td>\n<td>60<\/td>\n<td>70<\/td>\n<td><\/td>\n<\/tr>\n<tr>\n<th>4<\/th>\n<td>10<\/td>\n<td>12<\/td>\n<td>15<\/td>\n<td>20<\/td>\n<td>25<\/td>\n<td>30<\/td>\n<td><\/td>\n<td>40<\/td>\n<td>50<\/td>\n<td>60<\/td>\n<td>70<\/td>\n<td><\/td>\n<\/tr>\n<tr>\n<th>5<\/th>\n<td><\/td>\n<td><\/td>\n<td>15<\/td>\n<td>20<\/td>\n<td><\/td>\n<td>30<\/td>\n<td><\/td>\n<td>40<\/td>\n<td>50<\/td>\n<td>60<\/td>\n<td><\/td>\n<td>100<\/td>\n<\/tr>\n<tr>\n<th>6<\/th>\n<td><\/td>\n<td><\/td>\n<td>15<\/td>\n<td>20<\/td>\n<td><\/td>\n<td>30<\/td>\n<td><\/td>\n<td>40<\/td>\n<td>50<\/td>\n<td>60<\/td>\n<td><\/td>\n<td>100<\/td>\n<\/tr>\n<tr>\n<th>8<\/th>\n<td><\/td>\n<td><\/td>\n<td>15<\/td>\n<td>20<\/td>\n<td><\/td>\n<td>30<\/td>\n<td><\/td>\n<td>40<\/td>\n<td>50<\/td>\n<td>60<\/td>\n<td><\/td>\n<td>100<\/td>\n<\/tr>\n<tr>\n<th>10<\/th>\n<td>10<\/td>\n<td><\/td>\n<td>15<\/td>\n<td>20<\/td>\n<td><\/td>\n<td>30<\/td>\n<td><\/td>\n<td>40<\/td>\n<td>50<\/td>\n<td>60<\/td>\n<td><\/td>\n<td>100<\/td>\n<\/tr>\n<tr>\n<th>12<\/th>\n<td><\/td>\n<td>12<\/td>\n<td>15<\/td>\n<td>20<\/td>\n<td><\/td>\n<td>30<\/td>\n<td><\/td>\n<td>40<\/td>\n<td>50<\/td>\n<td>60<\/td>\n<td><\/td>\n<td>100<\/td>\n<\/tr>\n<tr>\n<th>15<\/th>\n<td><\/td>\n<td><\/td>\n<td>15<\/td>\n<td>20<\/td>\n<td><\/td>\n<td>30<\/td>\n<td><\/td>\n<td>40<\/td>\n<td>50<\/td>\n<td>60<\/td>\n<td><\/td>\n<td>100<\/td>\n<\/tr>\n<tr>\n<th>20<\/th>\n<td><\/td>\n<td><\/td>\n<td><\/td>\n<td>20<\/td>\n<td><\/td>\n<td>30<\/td>\n<td><\/td>\n<td>40<\/td>\n<td>50<\/td>\n<td>60<\/td>\n<td><\/td>\n<td>100<\/td>\n<\/tr>\n<tr>\n<th>25<\/th>\n<td><\/td>\n<td><\/td>\n<td><\/td>\n<td><\/td>\n<td>25<\/td>\n<td>30<\/td>\n<td><\/td>\n<td>40<\/td>\n<td>50<\/td>\n<td>60<\/td>\n<td><\/td>\n<td>100<\/td>\n<\/tr>\n<tr>\n<th>30<\/th>\n<td><\/td>\n<td><\/td>\n<td><\/td>\n<td><\/td>\n<td><\/td>\n<td>30<\/td>\n<td><\/td>\n<td>40<\/td>\n<td>50<\/td>\n<td>60<\/td>\n<td><\/td>\n<td>100<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-28e49545 print_page elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"28e49545\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-3d84f7bc\" data-id=\"3d84f7bc\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-a190461 elementor-widget elementor-widget-menu-anchor\" data-id=\"a190461\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"menu-anchor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t<div class=\"elementor-menu-anchor\" id=\"box5\"><\/div>\n\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-2902cca elementor-widget elementor-widget-heading\" data-id=\"2902cca\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h3 class=\"elementor-heading-title elementor-size-default\">\u6750\u6599\u6bd4\u91cd<\/h3>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-13ac6e8f tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"13ac6e8f\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p style=\"text-align: right;\">[ \u53c2\u8003\u5024 ]<\/p><table class=\"table04 mT0 fixed tableHover_single\"><tbody><tr><th colspan=\"2\">[ \u6750\u8cea ]<\/th><th>\u6bd4\u91cd(g\/cm3)<\/th><\/tr><tr><th rowspan=\"3\">\u9244<\/th><th>SS400\u30fbSS400\u713c\u920d\u6750\u30fbSS400-D\u30fbSCM440<\/th><td>7.87<\/td><\/tr><tr><th>S45C-D\u30fbS45C(\u76f8\u5f53)\u30fbS50C\uff08\u76f8\u5f53\uff09<\/th><td>7.87<\/td><\/tr><tr><th>S50C\uff08\u76f8\u5f53\uff09\u8abf\u8cea\u6750\u30fbNAK55\uff08\u76f8\u5f53\uff09\u30fbSKD11\u30fbSK105\uff08\u76f8\u5f53\uff09\u30fbSKS3\uff08\u76f8\u5f53\uff09\u30fbDC53<\/th><td>7.8<\/td><\/tr><tr><th rowspan=\"6\">\u30a2\u30eb\u30df<\/th><th>A2017<\/th><td>2.79<\/td><\/tr><tr><th>A5052<\/th><td>2.68<\/td><\/tr><tr><th>A5083<\/th><td>2.6<\/td><\/tr><tr><th>A6061<\/th><td>2.7<\/td><\/tr><tr><th>A6063S<\/th><td>2.69<\/td><\/tr><tr><th>A7075<\/th><td>2.8<\/td><\/tr><tr><th rowspan=\"7\">SUS<\/th><th>SUS303<\/th><td>7.93<\/td><\/tr><tr><th>SUS303\u713c\u920d\u6750<\/th><td>7.93<\/td><\/tr><tr><th>SUS304<\/th><td>7.93<\/td><\/tr><tr><th>SUS304\u713c\u920d\u6750<\/th><td>7.93<\/td><\/tr><tr><th>SUS304-D<\/th><td>7.93<\/td><\/tr><tr><th>SUS316\u30fbSUS316L<\/th><td>7.98<\/td><\/tr><tr><th>SUS430<\/th><td>7.7<\/td><\/tr><tr><th rowspan=\"4\">\u9285\u30fb\u771f\u936e<\/th><th>C1020\uff08\u7121\u9178\u7d20\u9285\uff09<\/th><td>8.94<\/td><\/tr><tr><th>C1100\uff08\u30bf\u30d5\u30d4\u30c3\u30c1\u9285\uff09<\/th><td>8.94<\/td><\/tr><tr><th>C2801P\uff08\u771f\u936e\uff09<\/th><td>8.43<\/td><\/tr><tr><th>C3604-LCd\uff08\u5feb\u524a\u771f\u936e\uff09<\/th><td>8.5<\/td><\/tr><tr><th rowspan=\"13\">\u6a39\u8102<\/th><th>\u30dd\u30ea\u30a2\u30bb\u30bf\u30fc\u30eb\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\uff09<\/th><td>1.41<\/td><\/tr><tr><th>MC\u30ca\u30a4\u30ed\u30f3\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u8010\u5019\uff09<\/th><td>1.16<\/td><\/tr><tr><th>MC\u30ca\u30a4\u30ed\u30f3\uff08\u5c0e\u96fb\uff09[MC501CD R2]<\/th><td>1.2<\/td><\/tr><tr><th>MC\u30ca\u30a4\u30ed\u30f3\uff08\u5e2f\u96fb\u9632\u6b62\uff09<\/th><td>1.2<\/td><\/tr><tr><th>\u30d9\u30fc\u30af\u30e9\u30a4\u30c8\uff08\u7d19\u30fb\u5e03\uff09<\/th><td>1.4<\/td><\/tr><tr><th>\u3075\u3063\u7d20\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\uff09[PTFE]<\/th><td>2.2<\/td><\/tr><tr><th>\u8d85\u9ad8\u5206\u5b50\u91cf\u30dd\u30ea\u30a8\u30c1\u30ec\u30f3\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\uff09<\/th><td>0.94<\/td><\/tr><tr><th>\u8d85\u9ad8\u5206\u5b50\u91cf\u30dd\u30ea\u30a8\u30c1\u30ec\u30f3\uff08\u5c0e\u96fb\uff09<\/th><td>0.95<\/td><\/tr><tr><th>ABS\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\uff09<\/th><td>1.05<\/td><\/tr><tr><th>PEEK\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\uff09<\/th><td>1.32<\/td><\/tr><tr><th>PP\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\uff09<\/th><td>0.91<\/td><\/tr><tr><th>\u30e6\u30cb\u30ec\u30fc\u30c8\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\uff09<\/th><td>1.63<\/td><\/tr><tr><th>PPS\uff08\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\uff09<\/th><td>1.35<\/td><\/tr><tr><th rowspan=\"3\">\u30a6\u30ec\u30bf\u30f3<\/th><th>\u6a19\u6e96\u30a6\u30ec\u30bf\u30f3(A90\u30fb\u30a8\u30fc\u30c6\u30eb\u7cfb\u30fb\u81ea\u7136\u8272)<\/th><td>1.13<\/td><\/tr><tr><th>\u6a19\u6e96\u30a6\u30ec\u30bf\u30f3(A70\u30fb\u30a8\u30b9\u30c6\u30eb\u7cfb\u30fb\u81ea\u7136\u8272)<\/th><td>1.2<\/td><\/tr><tr><th>\u6a19\u6e96\u30a6\u30ec\u30bf\u30f3(A50\u30fb\u30a8\u30b9\u30c6\u30eb\u7cfb\u30fb\u81ea\u7136\u8272)<\/th><td>1.2<\/td><\/tr><\/tbody><\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<\/div>\n\t\t\n\t\t\t<div id=\"daexthefu-container\"\n\t\t\t\tclass=\"daexthefu-container daexthefu-layout-stacked daexthefu-alignment-left\"\n\t\t\t\tdata-post-id=\"3420\">\n\n\t\t\t\t<div class=\"daexthefu-feedback\">\n\t\t\t\t\t<div class=\"daexthefu-text\">\n\t\t\t\t\t\t<h3 class=\"daexthefu-title\">\u3053\u306e\u8a18\u4e8b\u306f\u53c2\u8003\u306b\u306a\u308a\u307e\u3057\u305f\u304b\uff1f<\/h3>\n\t\t\t\t\t<\/div>\n\t\t\t\t\t<div class=\"daexthefu-buttons-container\">\n\t\t\t\t\t\t<div class=\"daexthefu-buttons\">\n\t\t\t\t\t\t\t\n\t\t\t<button type=\"button\" class=\"daexthefu-yes daexthefu-button daexthefu-button-type-icon-and-text\" data-value=\"1\">\n\t\t\t\t<span class=\"daexthefu-button-icon\">\n\t\t\t\t\n                <svg>\n                    <defs>\n                        <style>.thumb-up-cls-1{fill:#c9c9c9;}.thumb-up-cls-2{fill:#e1e1e1;}.thumb-up-cls-3{fill:#676767;}<\/style>\n                    <\/defs>\n                    <g id=\"thumb_up\">\n                        <path class=\"thumb-up-cls-2 daexthefu-icon-circle\" d=\"m24,3c11.58,0,21,9.42,21,21s-9.42,21-21,21S3,35.58,3,24,12.42,3,24,3m0-1C11.85,2,2,11.85,2,24s9.85,22,22,22,22-9.85,22-22S36.15,2,24,2h0Z\" \/>\n                        <g>\n                            <rect class=\"thumb-up-cls-3 daexthefu-icon-secondary-color\" x=\"10\" y=\"20\" width=\"6\" height=\"15\" rx=\"1.5\" ry=\"1.5\" \/>\n                            <path class=\"thumb-up-cls-1 daexthefu-icon-primary-color\" d=\"m30.57,9.06l-.49-.1c-.81-.17-1.61.35-1.78,1.16l-5.3,11.74c-.17.81,3.16,1.61,3.97,1.78l1.96.41c.81.17,1.61-.35,1.78-1.16l2.18-10.27c.34-1.61-.7-3.21-2.31-3.56Z\" \/>\n                            <path class=\"thumb-up-cls-1 daexthefu-icon-primary-color\" d=\"m38.17,20h-18.67c-.83,0-1.5.67-1.5,1.5v12c0,.83.67,1.5,1.5,1.5h16.27c.71,0,1.33-.5,1.47-1.21l2.4-12c.19-.93-.53-1.8-1.47-1.8Z\" \/>\n                        <\/g>\n                    <\/g>\n                <\/svg>\t\t\t\t\t\t<\/span>\n\t\t\t\t<span class=\"daexthefu-button-text\">\u5f79\u306b\u7acb\u3063\u305f\uff01<\/span>\n\t\t\t<\/button>\n\n\t\t\t\t\t\t\t\t\t\t\n\t\t\t<button type=\"button\" class=\"daexthefu-no daexthefu-button daexthefu-button-type-icon-and-text\" data-value=\"0\">\n\t\t\t\t<span class=\"daexthefu-button-icon\">\n\t\t\t\t\n                <svg>\n                    <defs>\n                        <style>.thumb-down-cls-1{fill:#c9c9c9;}.thumb-down-cls-2{fill:#e1e1e1;}.thumb-down-cls-3{fill:#676767;}<\/style>\n                    <\/defs>\n                    <g id=\"thumb_down\">\n                        <path class=\"thumb-down-cls-2 daexthefu-icon-circle\" d=\"m24,3c11.58,0,21,9.42,21,21s-9.42,21-21,21S3,35.58,3,24,12.42,3,24,3m0-1C11.85,2,2,11.85,2,24s9.85,22,22,22,22-9.85,22-22S36.15,2,24,2h0Z\" \/>\n                        <g>\n                            <rect class=\"thumb-down-cls-3 daexthefu-icon-secondary-color\" x=\"10\" y=\"13\" width=\"6\" height=\"15\" rx=\"1.5\" ry=\"1.5\" \/>\n                            <path class=\"thumb-down-cls-1 daexthefu-icon-primary-color\" d=\"m30.57,38.94l-.49.1c-.81.17-1.61-.35-1.78-1.16l-5.3-11.74c-.17-.81,3.16-1.61,3.97-1.78l1.96-.41c.81-.17,1.61.35,1.78,1.16l2.18,10.27c.34,1.61-.7,3.21-2.31,3.56Z\" \/>\n                            <path class=\"thumb-down-cls-1 daexthefu-icon-primary-color\" d=\"m38.17,28h-18.67c-.83,0-1.5-.67-1.5-1.5v-12c0-.83.67-1.5,1.5-1.5h16.27c.71,0,1.33.5,1.47,1.21l2.4,12c.19.93-.53,1.8-1.47,1.8Z\" \/>\n                        <\/g>\n                    <\/g>\n                <\/svg>\t\t\t\t\t\t<\/span>\n\t\t\t\t<span class=\"daexthefu-button-text\">\u5f79\u306b\u7acb\u305f\u306a\u304b\u3063\u305f<\/span>\n\t\t\t<\/button>\n\n\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\n\t\t\t\t<div class=\"daexthefu-comment\">\n\t\t\t\t\t<div class=\"daexthefu-comment-top-container\">\n\t\t\t\t\t\t<label id=\"daexthefu-comment-label\" class=\"daexthefu-comment-label\"><\/label>\n\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t\t<textarea id=\"daexthefu-comment-textarea\" class=\"daexthefu-comment-textarea\"\n\t\t\t\t\t\t\t\tplaceholder=\"\"\n\t\t\t\t\t\t\t\tmaxlength=\"\n\t\t\t\t\t\t\t\t400\t\t\t\t\t\t\t\t\t\"><\/textarea>\n\t\t\t\t\t<div class=\"daexthefu-comment-buttons-container\">\n\t\t\t\t\t\t<button class=\"daexthefu-comment-submit daexthefu-button\">\u9001\u4fe1<\/button>\n\t\t\t\t\t\t<button class=\"daexthefu-comment-cancel daexthefu-button\">\u53d6\u6d88<\/button>\n\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\n\t\t\t\t<div class=\"daexthefu-successful-submission-text\">\u8a55\u4fa1\u3044\u305f\u3060\u304d\u3042\u308a\u304c\u3068\u3046\u3054\u3056\u3044\u307e\u3057\u305f\u3002<\/div>\n\n\t\t\t<\/div>\n\n\t\t\t","protected":false},"excerpt":{"rendered":"<p>\u898f\u683c\u4e00\u89a7 \u81ea\u52d5\u898b\u7a4d\u30b5\u30a4\u30ba \u539a\u307f(Z) \u81ea\u52d5\u898b\u7a4d\u30b5\u30a4\u30ba\u9577\u3055(X)\u30fb\u5e45(Y) \u30df\u30ac\u30ad\u6750\u30d5\u30e9\u30c3\u30c8\u30d0\u30fc \u81ea\u52d5\u898b\u7a4d\u30b5\u30a4\u30ba \u5e45(Y)\u30fb\u539a\u307f(Z) \u6750\u6599\u6bd4\u91cd \u898f\u683c\u4e00\u89a7 \u30fb\u901a\u5e38\u898f\u683c \u9577\u3055(X)\uff1a10mm\u4ee5\u4e0a\uff5e1,000mm\u4ee5\u4e0b \u5e45(Y) [&hellip;]<\/p>\n","protected":false},"author":15,"featured_media":0,"comment_status":"closed","ping_status":"closed","sticky":false,"template":"","format":"standard","meta":{"_helpful_status":1,"footnotes":""},"categories":[46],"tags":[65],"class_list":["post-3420","post","type-post","status-publish","format-standard","hentry","category-mpb_shape-material","tag-technical_mpb"],"yoast_head":"<!-- This site is optimized with the Yoast SEO plugin v28.7 - https:\/\/yoast.com\/product\/yoast-seo-wordpress\/ -->\n<title>\u898b\u7a4d\u3082\u308a\u53ef\u80fd\u306a\u30b5\u30a4\u30ba | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb<\/title>\n<meta name=\"robots\" content=\"index, follow, max-snippet:-1, max-image-preview:large, max-video-preview:-1\" \/>\n<link rel=\"canonical\" href=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/mpb_shape-material\/3420\/\" \/>\n<meta property=\"og:locale\" content=\"ja_JP\" \/>\n<meta property=\"og:type\" content=\"article\" \/>\n<meta property=\"og:title\" content=\"\u898b\u7a4d\u3082\u308a\u53ef\u80fd\u306a\u30b5\u30a4\u30ba | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\" \/>\n<meta property=\"og:description\" content=\"\u898f\u683c\u4e00\u89a7 \u81ea\u52d5\u898b\u7a4d\u30b5\u30a4\u30ba \u539a\u307f(Z) \u81ea\u52d5\u898b\u7a4d\u30b5\u30a4\u30ba\u9577\u3055(X)\u30fb\u5e45(Y) \u30df\u30ac\u30ad\u6750\u30d5\u30e9\u30c3\u30c8\u30d0\u30fc \u81ea\u52d5\u898b\u7a4d\u30b5\u30a4\u30ba \u5e45(Y)\u30fb\u539a\u307f(Z) \u6750\u6599\u6bd4\u91cd \u898f\u683c\u4e00\u89a7 \u30fb\u901a\u5e38\u898f\u683c \u9577\u3055(X)\uff1a10mm\u4ee5\u4e0a\uff5e1,000mm\u4ee5\u4e0b \u5e45(Y) [&hellip;]\" \/>\n<meta property=\"og:url\" content=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/mpb_shape-material\/3420\/\" \/>\n<meta property=\"og:site_name\" content=\"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\" \/>\n<meta property=\"article:published_time\" content=\"2025-12-14T15:00:58+00:00\" \/>\n<meta property=\"article:modified_time\" content=\"2026-08-10T03:05:12+00:00\" \/>\n<meta property=\"og:image\" content=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/tgt04_plate_pic_01.png\" \/>\n<meta name=\"author\" content=\"\u7f8e\u7d00\" \/>\n<meta name=\"twitter:card\" content=\"summary_large_image\" \/>\n<script type=\"application\/ld+json\" class=\"yoast-schema-graph\">{\"@context\":\"https:\\\/\\\/schema.org\",\"@graph\":[{\"@type\":\"Article\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/mpb_shape-material\\\/3420\\\/#article\",\"isPartOf\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/mpb_shape-material\\\/3420\\\/\"},\"author\":{\"name\":\"\u7f8e\u7d00\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#\\\/schema\\\/person\\\/6ff70d9094b7fdc810efdfcc2fdb63c5\"},\"headline\":\"\u898b\u7a4d\u3082\u308a\u53ef\u80fd\u306a\u30b5\u30a4\u30ba\",\"datePublished\":\"2025-12-14T15:00:58+00:00\",\"dateModified\":\"2026-08-10T03:05:12+00:00\",\"mainEntityOfPage\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/mpb_shape-material\\\/3420\\\/\"},\"wordCount\":300,\"publisher\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#organization\"},\"image\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/mpb_shape-material\\\/3420\\\/#primaryimage\"},\"thumbnailUrl\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2020\\\/01\\\/tgt04_plate_pic_01.png\",\"keywords\":[\"technical_mpb\"],\"articleSection\":[\"\u5bfe\u8c61\u90e8\u54c1\\\/\u6750\u6599\"],\"inLanguage\":\"ja\"},{\"@type\":\"WebPage\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/mpb_shape-material\\\/3420\\\/\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/mpb_shape-material\\\/3420\\\/\",\"name\":\"\u898b\u7a4d\u3082\u308a\u53ef\u80fd\u306a\u30b5\u30a4\u30ba | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\",\"isPartOf\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#website\"},\"primaryImageOfPage\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/mpb_shape-material\\\/3420\\\/#primaryimage\"},\"image\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/mpb_shape-material\\\/3420\\\/#primaryimage\"},\"thumbnailUrl\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2020\\\/01\\\/tgt04_plate_pic_01.png\",\"datePublished\":\"2025-12-14T15:00:58+00:00\",\"dateModified\":\"2026-08-10T03:05:12+00:00\",\"breadcrumb\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/mpb_shape-material\\\/3420\\\/#breadcrumb\"},\"inLanguage\":\"ja\",\"potentialAction\":[{\"@type\":\"ReadAction\",\"target\":[\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/mpb_shape-material\\\/3420\\\/\"]}]},{\"@type\":\"ImageObject\",\"inLanguage\":\"ja\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/mpb_shape-material\\\/3420\\\/#primaryimage\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2020\\\/01\\\/tgt04_plate_pic_01.png\",\"contentUrl\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2020\\\/01\\\/tgt04_plate_pic_01.png\",\"width\":313,\"height\":224,\"caption\":\"\u304a\u898b\u7a4d\u53ef\u80fd\u306a\u30b5\u30a4\u30ba\"},{\"@type\":\"BreadcrumbList\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/mpb_shape-material\\\/3420\\\/#breadcrumb\",\"itemListElement\":[{\"@type\":\"ListItem\",\"position\":1,\"name\":\"\u30db\u30fc\u30e0\",\"item\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/\"},{\"@type\":\"ListItem\",\"position\":2,\"name\":\"\u898b\u7a4d\u3082\u308a\u53ef\u80fd\u306a\u30b5\u30a4\u30ba\"}]},{\"@type\":\"WebSite\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#website\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/\",\"name\":\"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\",\"description\":\"\",\"publisher\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#organization\"},\"potentialAction\":[{\"@type\":\"SearchAction\",\"target\":{\"@type\":\"EntryPoint\",\"urlTemplate\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/?s={search_term_string}\"},\"query-input\":{\"@type\":\"PropertyValueSpecification\",\"valueRequired\":true,\"valueName\":\"search_term_string\"}}],\"inLanguage\":\"ja\"},{\"@type\":\"Organization\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#organization\",\"name\":\"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/\",\"logo\":{\"@type\":\"ImageObject\",\"inLanguage\":\"ja\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#\\\/schema\\\/logo\\\/image\\\/\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2019\\\/05\\\/A01-b_b4-1_jpeg.jpg\",\"contentUrl\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2019\\\/05\\\/A01-b_b4-1_jpeg.jpg\",\"width\":260,\"height\":70,\"caption\":\"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df\"},\"image\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#\\\/schema\\\/logo\\\/image\\\/\"}},{\"@type\":\"Person\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#\\\/schema\\\/person\\\/6ff70d9094b7fdc810efdfcc2fdb63c5\",\"name\":\"\u7f8e\u7d00\",\"image\":{\"@type\":\"ImageObject\",\"inLanguage\":\"ja\",\"@id\":\"https:\\\/\\\/secure.gravatar.com\\\/avatar\\\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g\",\"url\":\"https:\\\/\\\/secure.gravatar.com\\\/avatar\\\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g\",\"contentUrl\":\"https:\\\/\\\/secure.gravatar.com\\\/avatar\\\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g\",\"caption\":\"\u7f8e\u7d00\"},\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/author\\\/miki-aa3x-momosemisumi-co-jp\\\/\"}]}<\/script>\n<!-- \/ Yoast SEO plugin. -->","yoast_head_json":{"title":"\u898b\u7a4d\u3082\u308a\u53ef\u80fd\u306a\u30b5\u30a4\u30ba | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","robots":{"index":"index","follow":"follow","max-snippet":"max-snippet:-1","max-image-preview":"max-image-preview:large","max-video-preview":"max-video-preview:-1"},"canonical":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/mpb_shape-material\/3420\/","og_locale":"ja_JP","og_type":"article","og_title":"\u898b\u7a4d\u3082\u308a\u53ef\u80fd\u306a\u30b5\u30a4\u30ba | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","og_description":"\u898f\u683c\u4e00\u89a7 \u81ea\u52d5\u898b\u7a4d\u30b5\u30a4\u30ba \u539a\u307f(Z) \u81ea\u52d5\u898b\u7a4d\u30b5\u30a4\u30ba\u9577\u3055(X)\u30fb\u5e45(Y) \u30df\u30ac\u30ad\u6750\u30d5\u30e9\u30c3\u30c8\u30d0\u30fc \u81ea\u52d5\u898b\u7a4d\u30b5\u30a4\u30ba \u5e45(Y)\u30fb\u539a\u307f(Z) \u6750\u6599\u6bd4\u91cd \u898f\u683c\u4e00\u89a7 \u30fb\u901a\u5e38\u898f\u683c \u9577\u3055(X)\uff1a10mm\u4ee5\u4e0a\uff5e1,000mm\u4ee5\u4e0b \u5e45(Y) [&hellip;]","og_url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/mpb_shape-material\/3420\/","og_site_name":"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","article_published_time":"2025-12-14T15:00:58+00:00","article_modified_time":"2026-08-10T03:05:12+00:00","og_image":[{"url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/tgt04_plate_pic_01.png","type":"","width":"","height":""}],"author":"\u7f8e\u7d00","twitter_card":"summary_large_image","schema":{"@context":"https:\/\/schema.org","@graph":[{"@type":"Article","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/mpb_shape-material\/3420\/#article","isPartOf":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/mpb_shape-material\/3420\/"},"author":{"name":"\u7f8e\u7d00","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/person\/6ff70d9094b7fdc810efdfcc2fdb63c5"},"headline":"\u898b\u7a4d\u3082\u308a\u53ef\u80fd\u306a\u30b5\u30a4\u30ba","datePublished":"2025-12-14T15:00:58+00:00","dateModified":"2026-08-10T03:05:12+00:00","mainEntityOfPage":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/mpb_shape-material\/3420\/"},"wordCount":300,"publisher":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#organization"},"image":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/mpb_shape-material\/3420\/#primaryimage"},"thumbnailUrl":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/tgt04_plate_pic_01.png","keywords":["technical_mpb"],"articleSection":["\u5bfe\u8c61\u90e8\u54c1\/\u6750\u6599"],"inLanguage":"ja"},{"@type":"WebPage","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/mpb_shape-material\/3420\/","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/mpb_shape-material\/3420\/","name":"\u898b\u7a4d\u3082\u308a\u53ef\u80fd\u306a\u30b5\u30a4\u30ba | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","isPartOf":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#website"},"primaryImageOfPage":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/mpb_shape-material\/3420\/#primaryimage"},"image":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/mpb_shape-material\/3420\/#primaryimage"},"thumbnailUrl":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/tgt04_plate_pic_01.png","datePublished":"2025-12-14T15:00:58+00:00","dateModified":"2026-08-10T03:05:12+00:00","breadcrumb":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/mpb_shape-material\/3420\/#breadcrumb"},"inLanguage":"ja","potentialAction":[{"@type":"ReadAction","target":["https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/mpb_shape-material\/3420\/"]}]},{"@type":"ImageObject","inLanguage":"ja","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/mpb_shape-material\/3420\/#primaryimage","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/tgt04_plate_pic_01.png","contentUrl":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/tgt04_plate_pic_01.png","width":313,"height":224,"caption":"\u304a\u898b\u7a4d\u53ef\u80fd\u306a\u30b5\u30a4\u30ba"},{"@type":"BreadcrumbList","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/mpb_shape-material\/3420\/#breadcrumb","itemListElement":[{"@type":"ListItem","position":1,"name":"\u30db\u30fc\u30e0","item":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/"},{"@type":"ListItem","position":2,"name":"\u898b\u7a4d\u3082\u308a\u53ef\u80fd\u306a\u30b5\u30a4\u30ba"}]},{"@type":"WebSite","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#website","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/","name":"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","description":"","publisher":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#organization"},"potentialAction":[{"@type":"SearchAction","target":{"@type":"EntryPoint","urlTemplate":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/?s={search_term_string}"},"query-input":{"@type":"PropertyValueSpecification","valueRequired":true,"valueName":"search_term_string"}}],"inLanguage":"ja"},{"@type":"Organization","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#organization","name":"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/","logo":{"@type":"ImageObject","inLanguage":"ja","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/logo\/image\/","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2019\/05\/A01-b_b4-1_jpeg.jpg","contentUrl":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2019\/05\/A01-b_b4-1_jpeg.jpg","width":260,"height":70,"caption":"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df"},"image":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/logo\/image\/"}},{"@type":"Person","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/person\/6ff70d9094b7fdc810efdfcc2fdb63c5","name":"\u7f8e\u7d00","image":{"@type":"ImageObject","inLanguage":"ja","@id":"https:\/\/secure.gravatar.com\/avatar\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g","url":"https:\/\/secure.gravatar.com\/avatar\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g","contentUrl":"https:\/\/secure.gravatar.com\/avatar\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g","caption":"\u7f8e\u7d00"},"url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/author\/miki-aa3x-momosemisumi-co-jp\/"}]}},"views":115347,"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts\/3420","targetHints":{"allow":["GET"]}}],"collection":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts"}],"about":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/types\/post"}],"author":[{"embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/users\/15"}],"replies":[{"embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/comments?post=3420"}],"version-history":[{"count":182,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts\/3420\/revisions"}],"predecessor-version":[{"id":37682,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts\/3420\/revisions\/37682"}],"wp:attachment":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/media?parent=3420"}],"wp:term":[{"taxonomy":"category","embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/categories?post=3420"},{"taxonomy":"post_tag","embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/tags?post=3420"}],"curies":[{"name":"wp","href":"https:\/\/api.w.org\/{rel}","templated":true}]}}
