{"id":3474,"date":"2026-06-15T00:00:59","date_gmt":"2026-06-14T15:00:59","guid":{"rendered":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/?p=3474"},"modified":"2026-06-19T19:12:19","modified_gmt":"2026-06-19T10:12:19","slug":"%e5%8a%a0%e5%b7%a5%e9%99%90%e7%95%8c","status":"publish","type":"post","link":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_guideline\/3474\/","title":{"rendered":"\u52a0\u5de5\u9650\u754c\u306e\u7bc4\u56f2"},"content":{"rendered":"\t\t<div data-elementor-type=\"wp-post\" data-elementor-id=\"3474\" class=\"elementor elementor-3474\">\n\t\t\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-3ada338 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"3ada338\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-b8ed786\" data-id=\"b8ed786\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-eb4eacd elementor-widget elementor-widget-text-editor\" data-id=\"eb4eacd\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<ul id=\"anchor\"><li><a href=\"#box_1\">\u7a74\u3068\u7aef\u9762\u30fb\u7a74\u9593\u306e\u6700\u5c0f\u8ddd\u96e2<\/a><\/li><li><a href=\"#box_2\">\u901a\u3057\u7a74\u306e\u6700\u5c0f\u5f84\u3000\u9577\u7a74\u30fb\u89d2\u7a74\u30fb\u305d\u306e\u4ed6\u7a74\u306e\u6700\u5c0f\u5e45<\/a><\/li><li><a href=\"#box_3\">\u5207\u6b20\u5f62\u72b6\u306e\u6700\u5c0f\u30b5\u30a4\u30ba<\/a><\/li><li><a href=\"#box_18\">(\u5e73\u677f\u5c55\u958b\u6642\u306e)\u30b9\u30ea\u30c3\u30c8\u6700\u5c0f\u5e45<\/a><\/li><li><a href=\"#box_6\">\u6700\u5c0f\u66f2\u3052\u9ad8\u3055<\/a><\/li><li><a href=\"#box_19\">\u6700\u5c0f\u6bb5\u66f2\u3052\u9ad8\u3055<\/a><\/li><li><a href=\"#box_7\">\u66f2\u3052\u5e45\u5bf8\u6cd5\u6307\u5b9a\u7bc4\u56f2\u3068\u92ed\u89d2\u66f2\u3052\u306e\u6700\u5c0f\u89d2\u5ea6<\/a><\/li><li><a href=\"#box_4\">\u7a74\u3068\u66f2\u3052\u306e\u6700\u5c0f\u8ddd\u96e2\uff1a\u901a\u5e38\u66f2\u3052\u52a0\u5de5<\/a><\/li><li><a href=\"#box_4-1\">\u7a74\u3068\u66f2\u3052\u306e\u6700\u5c0f\u8ddd\u96e2\uff1aR\u66f2\u3052\u5f62\u72b6<\/a><\/li><li><a href=\"#box_10\">\u66f2\u3052\u7dda\u4e0a\u306e\u958b\u53e3\u90e8<\/a><\/li><li><a href=\"#box_15\">\u523b\u5370\u3068\u523b\u5370\u30fb\u7aef\u9762\u30fb\u7a74\u9593\u306e\u6700\u5c0f\u8ddd\u96e2<\/a><\/li><li><a href=\"#box_16\">\u523b\u5370\u3068\u30ca\u30c3\u30c8\u306e\u6700\u5c0f\u8ddd\u96e2<\/a><\/li><li><a href=\"#box_17\">\u523b\u5370\u3068\u66f2\u3052\u306e\u6700\u5c0f\u8ddd\u96e2<\/a><\/li><li><a href=\"#box_9\">\u7a74\u306e\u6700\u5c0f\u30b3\u30fc\u30ca\u30fcR<\/a><\/li><\/ul>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-902c91d elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"902c91d\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-323210b\" data-id=\"323210b\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-8d50a65 elementor-widget elementor-widget-text-editor\" data-id=\"8d50a65\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p>\u5404\u3005\u306e\u898f\u683c\u90e8\u4f4d\u306b\u306f\u3001\u52a0\u5de5\u9650\u754c\u5024\u307e\u305f\u306f\u5bf8\u6cd5\u7bc4\u56f2\u304c\u5b9a\u3081\u3089\u308c\u3066\u3044\u307e\u3059\u3002\u898f\u683c\u7bc4\u56f2\u5185\u306e\u30e2\u30c7\u30eb\u3092\u4f5c\u6210\u3057\u3066\u304f\u3060\u3055\u3044\u3002<\/p>\n<p>\u3000\u203b\u8868\u9762\u51e6\u7406\u3084\u5f62\u72b6\u3001\u52a0\u5de5\u6761\u4ef6\u306b\u3088\u3063\u3066\u8a18\u8f09\u306e\u5024\u3068\u7570\u306a\u308b\u5834\u5408\u304c\u3054\u3056\u3044\u307e\u3059\u3002<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-eaa622e elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"eaa622e\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-5bc68a16\" data-id=\"5bc68a16\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-881c2d6 elementor-widget elementor-widget-menu-anchor\" data-id=\"881c2d6\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"menu-anchor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t<div class=\"elementor-menu-anchor\" id=\"box_1\"><\/div>\n\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-791103e elementor-widget elementor-widget-heading\" data-id=\"791103e\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h4 class=\"elementor-heading-title elementor-size-default\">\u7a74\u3068\u7aef\u9762\u30fb\u7a74\u9593\u306e\u6700\u5c0f\u8ddd\u96e2<\/h4>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<section class=\"elementor-section elementor-inner-section elementor-element elementor-element-6efefb2 elementor-section-content-middle print_wrap  print_break elementor-reverse-mobile elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"6efefb2\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-e006f02 print_break\" data-id=\"e006f02\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-d5ab1ab elementor-widget elementor-widget-text-editor\" data-id=\"d5ab1ab\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p style=\"text-align: center;\">\u52a0\u5de5\u9650\u754c\u30fb\u5bf8\u6cd5\u7bc4\u56f2<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-839b0d6 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"839b0d6\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<div class=\"print_block\">\n\n&nbsp;\n<div class=\"tableStickyHead\">\n<table class=\"table05 min tableHover mT0\">\n<thead>\n<tr style=\"height: 24px;\">\n<th style=\"width: 76%;\" colspan=\"3\">\u677f\u539a<\/th>\n<th style=\"width: 8%;\" rowspan=\"2\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">a<\/span><\/th>\n<th style=\"width: 8%;\" rowspan=\"2\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">b<\/span><\/th>\n<th style=\"width: 8%;\" rowspan=\"2\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">c<\/span><\/th>\n<\/tr>\n<tr>\n<th>\n<ul>\n \t<li>SPCC<\/li>\n \t<li>SPHC<\/li>\n \t<li>SS400<\/li>\n \t<li>SECC<\/li>\n<\/ul>\n<\/th>\n<th>\n<ul>\n \t<li>SUS304(No.1)<\/li>\n \t<li>SUS304(2B)<\/li>\n<li>SUS304(2B) \u7247\u9762\u4fdd\u8b77\u30b7\u30fc\u30c8\u4ed8\n<\/li>\n \t<li>SUS304(\u7247\u9762#400\u7814\u78e8)<\/li>\n \t<li>SUS304(\u7247\u9762\u30d8\u30a2\u30e9\u30a4\u30f3)<\/li>\n \t<li>SUS316(2B)<\/li>\n \t<li>SUS430(2B)<\/li>\n<\/ul>\n<\/th>\n<th>\n<ul>\n \t<li>A5052<\/li>\n \t<li>A5052(\u30a2\u30eb\u30de\u30a4\u30c8\u92fc\u677f\u767d)<\/li>\n \t<li>A5052(\u30a2\u30eb\u30de\u30a4\u30c8\u92fc\u677f\u9ed2)<\/li>\n<\/ul>\n<\/th>\n<\/tr>\n<\/thead>\n<\/table>\n<\/div>\n<table class=\"table05 min tableHover mT0\">\n<tbody>\n<tr>\n<td>0.8<\/td>\n<td>0.8<\/td>\n<td>0.8<\/td>\n<td style=\"width: 8%;\" rowspan=\"2\">0.5<\/td>\n<td style=\"width: 8%;\" rowspan=\"5\">11.5<\/td>\n<td style=\"width: 8%;\" rowspan=\"5\">3<\/td>\n<\/tr>\n<tr>\n<td>1<\/td>\n<td>1<\/td>\n<td>1<\/td>\n<\/tr>\n<tr>\n<td>1.2<\/td>\n<td>1.2<\/td>\n<td>1.2<\/td>\n<td>0.6<\/td>\n<\/tr>\n<tr>\n<td>\u2013<\/td>\n<td>1.5<\/td>\n<td>1.5<\/td>\n<td>0.7<\/td>\n<\/tr>\n<tr>\n<td>1.6<\/td>\n<td>\u2013<\/td>\n<td>1.6<\/td>\n<td>0.8<\/td>\n<\/tr>\n<tr>\n<td>2<\/td>\n<td>2<\/td>\n<td>2<\/td>\n<td rowspan=\"2\">1<\/td>\n<td colspan=\"2\" rowspan=\"13\">\u2013<\/td>\n<\/tr>\n<tr>\n<td>2.3<\/td>\n<td>\u2013<\/td>\n<td>\u2013<\/td>\n<\/tr>\n<tr>\n<td>\u2013<\/td>\n<td>2.5<\/td>\n<td>2.5<\/td>\n<td>1.2<\/td>\n<\/tr>\n<tr>\n<td>\u2013<\/td>\n<td>3<\/td>\n<td>3<\/td>\n<td rowspan=\"2\">1.5<\/td>\n<\/tr>\n<tr>\n<td>3.2<\/td>\n<td>\u2013<\/td>\n<td>\u2013<\/td>\n<\/tr>\n<tr>\n<td>\u2013<\/td>\n<td>4<\/td>\n<td>4<\/td>\n<td>2<\/td>\n<\/tr>\n<tr>\n<td>4.5<\/td>\n<td>\u2013<\/td>\n<td>\u2013<\/td>\n<td>2.2<\/td>\n<\/tr>\n<tr>\n<td>\u2013<\/td>\n<td>5<\/td>\n<td>5<\/td>\n<td>2.5<\/td>\n<\/tr>\n<tr>\n<td>6<\/td>\n<td>6<\/td>\n<td>6<\/td>\n<td>3<\/td>\n<\/tr>\n<tr>\n<td>9<\/td>\n<td>9<\/td>\n<td rowspan=\"4\">\u2013<\/td>\n<td>4<\/td>\n<\/tr>\n<tr>\n<td>10<\/td>\n<td>10<\/td>\n<td>5<\/td>\n<\/tr>\n<tr>\n<td>12<\/td>\n<td>12<\/td>\n<td>6<\/td>\n<\/tr>\n<tr>\n<td>16<\/td>\n<td>\u2013<\/td>\n<td>8<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\n<\/div>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-a0ac571 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"a0ac571\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"table04 min tableHover\" style=\"width: 100%; margin-top: 8px; height: 60px;\">\n<tbody>\n<tr style=\"height: 24px;\">\n<th style=\"width: 76%;\" colspan=\"6\">\u677f\u539a<\/th>\n<th style=\"width: 8%;\" rowspan=\"2\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">a<\/span><\/th>\n<th style=\"width: 8%;\" rowspan=\"2\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">b<\/span><\/th>\n<th style=\"width: 8%;\" rowspan=\"2\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">c<\/span><\/th>\n<\/tr>\n<tr style=\"height: 24px;\">\n<th style=\"width: 70%;\" colspan=\"6\">\n<ul><li>C1020(\u7121\u9178\u7d20\u9285)<\/li>\n<li>C1100(\u30bf\u30d5\u30d4\u30c3\u30c1\u9285)<\/li>\n<li>C2801P(\u771f\u936e\u30fb\u9ec4\u9285)<\/li><\/ul>\n<\/th>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td style=\"width: 72%;\" colspan=\"6\">1.0<\/td>\n<td style=\"width: 8%;\">0.5<\/td>\n<td rowspan='2'>16.0<\/td>\n<td rowspan='2'>3.0<\/td>\n<td style=\"width: 17%; height: 40px;\" colspan=\"2\" rowspan=\"4\">&#8211;<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td style=\"width: 72%;\" colspan=\"6\">1.5<\/td>\n<td style=\"width: 8%;\">0.7<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td style=\"width: 72%;\" colspan=\"6\">2.0<\/td>\n<td style=\"width: 8%;\">1.0<\/td>\n<td rowspan='2' colspan='2'>&#8211;\t<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td style=\"width: 72%;\" colspan=\"6\">3.0<\/td>\n<td style=\"width: 8%;\">1.5<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-6804018 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"6804018\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"table04 min tableHover\" style=\"width: 100%; margin-top: 8px; height: 60px;\">\n<tbody>\n<tr style=\"height: 24px;\">\n<th style=\"width: 76%;\" colspan=\"6\">\u677f\u539a<\/th>\n<th style=\"width: 8%;\" rowspan=\"2\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">a<\/span><\/th>\n<th style=\"width: 8%;\" rowspan=\"2\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">b<\/span><\/th>\n<th style=\"width: 8%;\" rowspan=\"2\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">c<\/span><\/th>\n<\/tr>\n<tr style=\"height: 24px;\">\n<th style=\"width: 70%;\" colspan=\"6\">SPCC(\u30b7\u30e0\u7528)<\/th>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td style=\"width: 72%;\" colspan=\"6\">0.1<\/td>\n<td style=\"width: 8%; height: 40px;\" rowspan=\"4\">1.0<\/td>\n<td style=\"width: 17%; height: 40px;\" colspan=\"2\" rowspan=\"4\">&#8211;<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td style=\"width: 72%;\" colspan=\"6\">0.2<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td style=\"width: 72%;\" colspan=\"6\">0.3<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td style=\"width: 72%;\" colspan=\"6\">0.5<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-f80d2ad tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"f80d2ad\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"table05 min tableHover\" style=\"width: 100%; margin-top: 8px;\"><tbody><tr style=\"height: 24px;\"><th style=\"width: 76%;\" colspan=\"6\">\u677f\u539a<\/th><th style=\"width: 8%;\" rowspan=\"2\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">a<\/span><\/th><th style=\"width: 8%;\" rowspan=\"2\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">b<\/span><\/th><th style=\"width: 8%;\" rowspan=\"2\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">c<\/span><\/th><\/tr><tr style=\"height: 24px;\"><th colspan=\"6\">SUS304(H)(\u30b7\u30e0\u7528)<\/th><\/tr><tr style=\"height: 24px;\"><td style=\"height: 24px;\" colspan=\"6\">0.05<\/td><td rowspan=\"5\">0.5<\/td><td colspan=\"2\" rowspan=\"7\">&#8211;<\/td><\/tr><tr style=\"height: 24px;\"><td style=\"height: 24px;\" colspan=\"6\">0.1<\/td><\/tr><tr style=\"height: 24px;\"><td style=\"height: 24px;\" colspan=\"6\">0.2<\/td><\/tr><tr style=\"height: 24px;\"><td style=\"height: 24px;\" colspan=\"6\">0.3<\/td><\/tr><tr style=\"height: 24px;\"><td style=\"height: 24px;\" colspan=\"6\">0.5<\/td><\/tr><tr style=\"height: 24px;\"><td style=\"height: 24px;\" colspan=\"6\">0.8<\/td><td>0.8<\/td><\/tr><tr style=\"height: 24px;\"><td style=\"height: 24px;\" colspan=\"6\">1.0<\/td><td>1.0<\/td><\/tr><\/tbody><\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-416405a tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"416405a\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"table05 min tableHover\" style=\"width: 100%; margin-top: 8px;\"><tbody><tr style=\"height: 24px;\"><th style=\"width: 76%;\">\u677f\u539a<\/th><th style=\"width: 8%;\" rowspan=\"2\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">a<\/span><\/th><th style=\"width: 8%;\" rowspan=\"2\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">b<\/span><\/th><th style=\"width: 8%;\" rowspan=\"2\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">c<\/span><\/th><\/tr><tr><th>C2680P\/C2801P(\u30b7\u30e0\u7528)<\/th><\/tr><tr><td>0.05<\/td><td rowspan=\"5\">0.5<\/td><td colspan=\"2\" rowspan=\"6\">&#8211;<\/td><\/tr><tr><td>0.1<\/td><\/tr><tr><td>0.2<\/td><\/tr><tr><td>0.3<\/td><\/tr><tr><td>0.5<\/td><\/tr><tr><td>1.0<\/td><td>1.0<\/td><\/tr><\/tbody><\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-fcd85a0 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"fcd85a0\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"table05 min tableHover\" style=\"width: 100%; margin-top: 8px;\">\n<tbody>\n<tr style=\"height: 24px;\">\n<th style=\"width: 76%;\" colspan=\"6\">\u677f\u539a<\/th>\n<th style=\"width: 8%;\" rowspan=\"2\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">a<\/span><\/th>\n<th style=\"width: 8%;\" rowspan=\"2\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">b<\/span><\/th>\n<th style=\"width: 8%;\" rowspan=\"2\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">c<\/span><\/th>\n<\/tr>\n<tr style=\"height: 24px;\">\n<th colspan=\"6\">\u30d1\u30f3\u30c1\u30f3\u30b0\u30e1\u30bf\u30eb -\u4e38\u5b5460\u00b0\u5343\u9ce5\u30bf\u30a4\u30d7-<\/th>\n<\/tr>\n<tr>\n<td colspan=\"6\">0.8<\/td>\n<td rowspan=\"3\">10.0<\/td>\n<td colspan=\"2\" rowspan=\"3\">&#8211;<\/td>\n<\/tr>\n<tr>\n<td colspan=\"6\">1.0<\/td>\n<\/tr>\n<tr>\n<td colspan=\"6\">1.5<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-0638436 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"0638436\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"table05 min tableHover\" style=\"width: 100%; margin-top: 8px;\">\n<tbody>\n<tr style=\"height: 24px;\">\n<th style=\"width: 76%;\" colspan=\"4\">\u677f\u539a<\/th>\n<th style=\"width: 8%;\" rowspan=\"2\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">a<\/span><\/th>\n<th style=\"width: 8%;\" rowspan=\"2\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">b<\/span><\/th>\n<th style=\"width: 8%;\" rowspan=\"2\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">c<\/span><\/th>\n<\/tr>\n<tr style=\"height: 24px;\">\n<th style=\"width: 4%;\">PET<\/th>\n<th style=\"width: 8%;\">\u30a2\u30af\u30ea\u30eb<\/th>\n<th style=\"width: 14%;\">\u30dd\u30ea\u30ab\u30fc\u30dc\u30cd\u30fc\u30c8<\/th>\n<th style=\"width: 20%;\">\u5869\u30d3<\/th>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td style=\"width: 4%;\">3.0<\/td>\n<td style=\"width: 8%;\">3.0<\/td>\n<td style=\"width: 14%;\">3.0<\/td>\n<td style=\"width: 20%;\">3.0<\/td>\n<td style=\"width: 12px;\" rowspan=\"4\">2.0<\/td>\n<td style=\"width: 25%;\" colspan=\"2\" rowspan=\"4\">&#8211;<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>5.0<\/td>\n<td>5.0<\/td>\n<td>5.0<\/td>\n<td>5.0<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>8.0<\/td>\n<td>8.0<\/td>\n<td>&#8211;<\/td>\n<td>&#8211;<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>&#8211;<\/td>\n<td>10.0<\/td>\n<td>&#8211;<\/td>\n<td>&#8211;<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-a79567c tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"a79567c\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"table05 min tableHover\" style=\"width: 100%; margin-top: 8px;\">\n<tbody>\n<tr style=\"height: 24px;\">\n<th style=\"width: 76%;\">\u677f\u539a<\/th>\n<th style=\"width: 8%;\" rowspan=\"2\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">a<\/span><\/th>\n<th style=\"width: 8%;\" rowspan=\"2\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">b<\/span><\/th>\n<th style=\"width: 8%;\" rowspan=\"2\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">c<\/span><\/th>\n<\/tr>\n<tr style=\"height: 24px;\">\n<th>\u30a2\u30eb\u30df\u8907\u5408\u677f(\u82af\u6750\uff1a\u767a\u6ce1\u30dd\u30ea\u30a8\u30c1\u30ec\u30f3\u6a39\u8102)<\/th>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>3.0<\/td>\n<td>2.0<\/td>\n<td colspan=\"2\">&#8211;<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-43418e2\" data-id=\"43418e2\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-328393e elementor-widget elementor-widget-text-editor\" data-id=\"328393e\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p style=\"text-align: center;\">\u90e8\u4f4d\u4f8b<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-a9a05db elementor-widget elementor-widget-image\" data-id=\"a9a05db\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img fetchpriority=\"high\" decoding=\"async\" width=\"320\" height=\"238\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/fcpl_item_guideline_31.png\" class=\"attachment-large size-large wp-image-3143\" alt=\"\u90e8\u4f4d\u4f8b\" srcset=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/fcpl_item_guideline_31.png 320w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/fcpl_item_guideline_31-300x223.png 300w\" sizes=\"(max-width: 320px) 100vw, 320px\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-faf6e76 elementor-widget elementor-widget-text-editor\" data-id=\"faf6e76\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<ul>\n<li style=\"text-align: left;\">\u203b\u30bf\u30c3\u30d7\u7a74\u3068\u7aef\u9762\u307e\u305f\u306f\u30bf\u30c3\u30d7\u7a74\u9593\u306e\u8ddd\u96e2\u306f\u3001\u30cd\u30b8\u7a74\uff08\u7a74\uff09\u306e\u6700\u5916\u5f84\u304b\u3089\u306e\u8ddd\u96e2\u3067\u6700\u5c0f\u8ddd\u96e2\u304c\u8a08\u7b97\u3055\u308c\u307e\u3059\u3002<\/li>\n \t<li style=\"text-align: left;\">\u203b\u30d0\u30fc\u30ea\u30f3\u30b0\u30bf\u30c3\u30d7\u9593\u306e\u8ddd\u96e2\u306f\u3001\u7a74\u4e2d\u5fc3\u9593\u306e\u8ddd\u96e2\u3067\u6700\u5c0f\u8ddd\u96e2\u304c\u8a08\u7b97\u3055\u308c\u307e\u3059\u3002<\/li>\n \t<li style=\"text-align: left;\">\u203b\u76bf\u7a74\u3068\u7aef\u9762\u307e\u305f\u306f\u76bf\u7a74\u9593\u306e\u8ddd\u96e2\u306f\u3001\u76bf\u30b6\u30b0\u30ea\u90e8\u306e\u6700\u5916\u5f84\u304b\u3089\u306e\u8ddd\u96e2\u3067\u6700\u5c0f\u8ddd\u96e2\u304c\u8a08\u7b97\u3055\u308c\u307e\u3059\u3002<\/li>\n<\/ul>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-ece60bb elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"ece60bb\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-7dc72fa\" data-id=\"7dc72fa\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-3337a19 elementor-widget elementor-widget-menu-anchor\" data-id=\"3337a19\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"menu-anchor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t<div class=\"elementor-menu-anchor\" id=\"box_2\"><\/div>\n\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-2a7c677 elementor-widget elementor-widget-heading\" data-id=\"2a7c677\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h4 class=\"elementor-heading-title elementor-size-default\">\u901a\u3057\u7a74\u306e\u6700\u5c0f\u5f84<br>\n\u9577\u7a74\u30fb\u89d2\u7a74\u30fb\u305d\u306e\u4ed6\u7a74\u306e\u6700\u5c0f\u5e45\n\n<\/h4>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<section class=\"elementor-section elementor-inner-section elementor-element elementor-element-c0f48c7 elementor-section-content-middle print_wrap  print_break elementor-reverse-mobile elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"c0f48c7\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-4950fcd print_break\" data-id=\"4950fcd\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-08637b0 elementor-widget elementor-widget-text-editor\" data-id=\"08637b0\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p style=\"text-align: center;\">\u52a0\u5de5\u9650\u754c\u30fb\u5bf8\u6cd5\u7bc4\u56f2<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-8750758 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"8750758\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<div class=\"print_block\">\n<div class=\"tableStickyHead\">\n<table class=\"table05 min tableHover mT0\">\n<thead>\n<tr style=\"height: 24px;\">\n<th colspan=\"4\">\u677f\u539a<\/th>\n<th rowspan=\"2\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">d<\/span><\/th>\n<th rowspan=\"2\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">w1<\/span><\/th>\n<th rowspan=\"2\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">w2<\/span><\/th>\n<\/tr>\n<tr style=\"height: 24px;\">\n<th>\n<ul>\n \t<li>SPCC<\/li>\n \t<li>SPHC<\/li>\n \t<li>SS400<\/li>\n \t<li>SECC<\/li>\n<\/ul>\n<\/th>\n<th>\n<ul>\n \t<li>SUS304(No.1)<\/li>\n \t<li>SUS304(2B)<\/li>\n<li>SUS304(2B) \u7247\u9762\u4fdd\u8b77\u30b7\u30fc\u30c8\u4ed8<\/li>\n \t<li>SUS316(2B)<\/li>\n \t<li>SUS430(2B)<\/li>\n<\/ul>\n<\/th>\n<th>\n<ul>\n \t<li>A5052<\/li>\n \t<li>A5052(\u30a2\u30eb\u30de\u30a4\u30c8\u92fc\u677f\u767d)<\/li>\n \t<li>A5052(\u30a2\u30eb\u30de\u30a4\u30c8\u92fc\u677f\u9ed2)<\/li>\n<\/ul>\n<\/th>\n<th>\n<ul>\n \t<li>\u30d1\u30f3\u30c1\u30f3\u30b0\u30e1\u30bf\u30eb<\/li>\n \t<li>-\u4e38\u5b5460\u00b0\u5343\u9ce5\u30bf\u30a4\u30d7-<\/li>\n<\/ul>\n<\/th>\n<\/tr>\n<\/thead>\n<\/table>\n<\/div>\n<table class=\"table05 min tableHover mT0\">\n<tbody>\n<tr style=\"height: 24px;\">\n<td>0.8<\/td>\n<td>0.8<\/td>\n<td>0.8<\/td>\n<td>0.8<\/td>\n<td>0.4<\/td>\n<td>0.8<\/td>\n<td>0.8<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>1.0<\/td>\n<td>1.0<\/td>\n<td>1.0<\/td>\n<td>1.0<\/td>\n<td>0.5<\/td>\n<td>1.0<\/td>\n<td>1.0<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>1.2<\/td>\n<td>1.2<\/td>\n<td>1.2<\/td>\n<td>&#8211;<\/td>\n<td>0.6<\/td>\n<td>1.2<\/td>\n<td>1.2<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>&#8211;<\/td>\n<td>1.5<\/td>\n<td>1.5<\/td>\n<td>1.5<\/td>\n<td>0.7<\/td>\n<td>1.5<\/td>\n<td>1.5<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>1.6<\/td>\n<td>&#8211;<\/td>\n<td>1.6<\/td>\n<td rowspan=\"15\">&#8211;<\/td>\n<td>0.8<\/td>\n<td>1.6<\/td>\n<td>1.6<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>2.0<\/td>\n<td>2.0<\/td>\n<td>2.0<\/td>\n<td>1.0<\/td>\n<td>2.0<\/td>\n<td>2.0<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>2.3<\/td>\n<td>&#8211;<\/td>\n<td>&#8211;<\/td>\n<td>1.1<\/td>\n<td>2.3<\/td>\n<td>2.3<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>&#8211;<\/td>\n<td>2.5<\/td>\n<td>2.5<\/td>\n<td>1.2<\/td>\n<td>2.5<\/td>\n<td>2.5<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>&#8211;<\/td>\n<td>3.0<\/td>\n<td>3.0<\/td>\n<td>1.5<\/td>\n<td>3.0<\/td>\n<td>3.0<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>3.2<\/td>\n<td>&#8211;<\/td>\n<td>&#8211;<\/td>\n<td>1.6<\/td>\n<td>3.0<\/td>\n<td>3.0<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>&#8211;<\/td>\n<td>4.0<\/td>\n<td>4.0<\/td>\n<td>2.0<\/td>\n<td>3.0<\/td>\n<td>3.0<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>4.5<\/td>\n<td>&#8211;<\/td>\n<td>&#8211;<\/td>\n<td>2.2<\/td>\n<td rowspan=\"3\">4.0<\/td>\n<td rowspan=\"3\">4.0<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>&#8211;<\/td>\n<td>5.0<\/td>\n<td>5.0<\/td>\n<td>2.5<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>6.0<\/td>\n<td>&#8211;<\/td>\n<td>&#8211;<\/td>\n<td rowspan=\"2\">3.0<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>&#8211;<\/td>\n<td>6.0<\/td>\n<td>6.0<\/td>\n<td rowspan=\"3\">6.0<\/td>\n<td rowspan=\"3\">6.0<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>9.0<\/td>\n<td>9.0<\/td>\n<td rowspan=\"4\">&#8211;<\/td>\n<td>4.5<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>10.0<\/td>\n<td>10.0<\/td>\n<td>5.0<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>12.0<\/td>\n<td>12.0<\/td>\n<td>6.0<\/td>\n<td>8.0<\/td>\n<td>8.0<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>16.0<\/td>\n<td>&#8211;<\/td>\n<td>8.0<\/td>\n<td>10.0<\/td>\n<td>10.0<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\n<\/div>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-98e6d25 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"98e6d25\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"table05 min fixed tableHover\" style=\"margin-top: 8px; width: 100%;\">\n<tbody>\n<tr style=\"height: 24px;\">\n<th style=\"width: 65%;\">\u677f\u539a<\/th>\n<th style=\"width: 16.0152%;\" rowspan=\"2\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">d<\/span><\/th>\n<th style=\"width: 15.8031%;\" rowspan=\"2\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">w1<\/span><\/th>\n<th style=\"width: 17.0555%;\" rowspan=\"2\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">w2<\/span><\/th>\n<\/tr>\n<tr style=\"height: 24px;\">\n<th style=\"width: 57%;\">\n<ul>\n \t<li>SUS304(\u7247\u9762#400\u7814\u78e8)<\/li>\n \t<li>SUS304(\u7247\u9762\u30d8\u30a2\u30e9\u30a4\u30f3)<\/li>\n<\/ul>\n<\/th>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td style=\"width: 65.1263%;\">0.8<\/td>\n<td style=\"width: 16.0152%;\">1.6<\/td>\n<td style=\"width: 15.8031%;\" rowspan=\"4\">3.0<\/td>\n<td style=\"width: 17.0555%;\" rowspan=\"4\">3.0<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td style=\"width: 65.1263%;\">1.0<\/td>\n<td style=\"width: 16.0152%;\">1.6<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td style=\"width: 65.1263%;\">1.2<\/td>\n<td style=\"width: 16.0152%;\">2.0<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td style=\"width: 65.1263%;\">1.5<\/td>\n<td style=\"width: 16.0152%;\">2.5<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td style=\"width: 65.1263%;\">2.0<\/td>\n<td style=\"width: 16.0152%;\">4.0<\/td>\n<td style=\"width: 15.8031%;\" rowspan=\"2\">4.5<\/td>\n<td style=\"width: 17.0555%;\" rowspan=\"2\">4.5<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td style=\"width: 65.1263%;\">3.0<\/td>\n<td style=\"width: 16.0152%;\">4.5<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\n\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-063ec8a tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"063ec8a\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"table05 min fixed tableHover\" style=\"margin-top: 8px; width: 100%;\">\n<tbody>\n<tr style=\"height: 24px;\">\n<th style=\"width: 65%;\">\u677f\u539a<\/th>\n<th style=\"width: 16.0152%;\" rowspan=\"2\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">a<\/span><\/th>\n<th style=\"width: 15.8031%;\" rowspan=\"2\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">b<\/span><\/th>\n<th style=\"width: 17.0555%;\" rowspan=\"2\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">c<\/span><\/th>\n<\/tr>\n<tr style=\"height: 24px;\">\n<th style=\"width: 57%;\">\n<ul>\n<li>C1020(\u7121\u9178\u7d20\u9285)<\/li>\n<li>C1100(\u30bf\u30d5\u30d4\u30c3\u30c1\u9285)<\/li>\n<li>C2801P(\u771f\u936e\u30fb\u9ec4\u9285)<\/li>\n<\/ul>\n<\/th>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td style=\"width: 65.1263%;\">1.0<\/td>\n<td style=\"width: 16.0152%;\">0.7<\/td>\n<td style=\"width: 15.8031%;\">1.0<\/td>\n<td style=\"width: 17.0555%;\">1.0<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td style=\"width: 65.1263%;\">1.5<\/td>\n<td style=\"width: 16.0152%;\">1.1<\/td>\n<td style=\"width: 15.8031%;\">1.5<\/td>\n<td style=\"width: 17.0555%;\">1.5<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td style=\"width: 65.1263%;\">2.0<\/td>\n<td style=\"width: 16.0152%;\">1.4<\/td>\n<td style=\"width: 15.8031%;\">2.0<\/td>\n<td style=\"width: 17.0555%;\">2.0<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td style=\"width: 65.1263%;\">3.0<\/td>\n<td style=\"width: 16.0152%;\">2.1<\/td>\n<td style=\"width: 15.8031%;\">3.0<\/td>\n<td style=\"width: 17.0555%;\">3.0<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-225aced tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"225aced\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"table05 min fixed tableHover\" style=\"margin-top: 8px; width: 100%;\">\n<tbody>\n<tr style=\"height: 24px;\">\n<th style=\"width: 55%;\" colspan=\"2\">\u677f\u539a<\/th>\n<th style=\"width: 13.3496%;\" rowspan=\"2\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">d<\/span><\/th>\n<th style=\"width: 13.835%;\" rowspan=\"2\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">w1<\/span><\/th>\n<th style=\"width: 14.0777%;\" rowspan=\"2\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">w2<\/span><\/th>\n<\/tr>\n<tr style=\"height: 24px;\">\n<th style=\"width: 25%;\">SPCC(\u30b7\u30e0\u7528)<\/th>\n<th style=\"width: 25%;\">SUS304(H)\n(\u30b7\u30e0\u7528)<\/th>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td style=\"width: 25%;\">&#8211;<\/td>\n<td style=\"width: 30.3397%;\">0.05<\/td>\n<td style=\"width: 13.3496%;\" rowspan=\"5\">0.3<\/td>\n<td style=\"width: 13.835%;\" rowspan=\"5\">0.5<\/td>\n<td style=\"width: 14.0777%;\" rowspan=\"5\">0.5<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td style=\"width: 25%;\">0.1<\/td>\n<td style=\"width: 30.3397%;\">0.1<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td style=\"width: 25%;\">0.2<\/td>\n<td style=\"width: 30.3397%;\">0.2<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td style=\"width: 25%;\">0.3<\/td>\n<td style=\"width: 30.3397%;\">0.3<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td style=\"width: 25%;\">0.5<\/td>\n<td style=\"width: 30.3397%;\">0.5<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td style=\"width: 25%;\" rowspan=\"2\">&#8211;<\/td>\n<td style=\"width: 30.3397%;\">0.8<\/td>\n<td style=\"width: 13.3496%;\">1.0<\/td>\n<td style=\"width: 13.835%;\">0.8<\/td>\n<td style=\"width: 14.0777%;\">0.8<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td style=\"width: 30.3397%;\">1.0<\/td>\n<td style=\"width: 13.3496%;\">1.0<\/td>\n<td style=\"width: 13.835%;\">1.0<\/td>\n<td style=\"width: 14.0777%;\">1.0<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-155c199 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"155c199\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"table05 min fixed tableHover\" style=\"margin-top: 8px; width: 100%;\">\n<tbody>\n<tr style=\"height: 24px;\">\n<th style=\"width: 55%;\">\u677f\u539a<\/th>\n<th style=\"width: 13.3496%;\" rowspan=\"2\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">d<\/span><\/th>\n<th style=\"width: 13.835%;\" rowspan=\"2\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">w1<\/span><\/th>\n<th style=\"width: 14.0777%;\" rowspan=\"2\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">w2<\/span><\/th>\n<\/tr>\n<tr>\n\t\t<th>C2680P\/C2801P(\u30b7\u30e0\u7528)<\/th>\n\t<\/tr>\n\t<tr>\n\t\t<td>0.05<\/td>\n\t\t<td rowspan=\"3\">0.5<\/td>\n\t\t<td rowspan=\"3\">0.5<\/td>\n\t\t<td rowspan=\"3\">0.5<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<td>0.1<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<td>0.2<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<td>0.3<\/td>\n\t\t<td>0.8<\/td>\n\t\t<td>0.8<\/td>\n\t\t<td>0.8<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<td>0.5<\/td>\n\t\t<td rowspan=\"2\">1.0<\/td>\n\t\t<td rowspan=\"2\">1.0<\/td>\n\t\t<td rowspan=\"2\">1.0<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<td>1.0<\/td>\n\t<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-27e6380 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"27e6380\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"table05 min fixed tableHover\" style=\"margin-top: 8px; width: 100%;\">\n<tbody>\n<tr style=\"height: 24px;\">\n<th style=\"width: 67.5%;\" colspan=\"4\">\u677f\u539a<\/th>\n<th style=\"width: 16.5146%;\" rowspan=\"2\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">d<\/span><\/th>\n<th style=\"width: 17%;\" rowspan=\"2\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">w1<\/span><\/th>\n<th style=\"width: 17%;\" rowspan=\"2\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">w2<\/span><\/th>\n<\/tr>\n<tr style=\"height: 24px;\">\n<th style=\"width: 15%;\">PET<\/th>\n<th style=\"width: 15%;\">\u30a2\u30af\u30ea\u30eb<\/th>\n<th style=\"width: 16.4563%;\">\u30dd\u30ea\u30ab\u30fc\u30dc\u30cd\u30fc\u30c8<\/th>\n<th style=\"width: 20%;\">\u5869\u30d3<\/th>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td style=\"width: 15%;\">3.0<\/td>\n<td style=\"width: 15%;\">3.0<\/td>\n<td style=\"width: 16.4563%;\">3.0<\/td>\n<td style=\"width: 20%;\">3.0<\/td>\n<td style=\"width: 16.5146%;\" rowspan=\"4\">2.0<\/td>\n<td style=\"width: 17%;\" rowspan=\"4\">3.0<\/td>\n<td style=\"width: 17%;\" rowspan=\"4\">7.0<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td style=\"width: 15%;\">5.0<\/td>\n<td style=\"width: 15%;\">5.0<\/td>\n<td style=\"width: 16.4563%;\">5.0<\/td>\n<td style=\"width: 20%;\">5.0<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>8.0<\/td>\n<td>8.0<\/td>\n<td>&#8211;<\/td>\n<td>&#8211;<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>&#8211;<\/td>\n<td>10.0<\/td>\n<td>&#8211;<\/td>\n<td>&#8211;<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-c5fe23d tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"c5fe23d\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"table05 min tableHover\" style=\"width: 100%; margin-top: 8px;\">\n<tbody>\n<tr style=\"height: 24px;\">\n<th style=\"width: 67.5%;\">\u677f\u539a<\/th>\n<th style=\"width: 16.5146%;\" rowspan=\"2\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">d<\/span><\/th>\n<th style=\"width: 17%;\" rowspan=\"2\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">w1<\/span><\/th>\n<th style=\"width: 17%;\" rowspan=\"2\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">w2<\/span><\/th>\n<\/tr>\n<tr style=\"height: 24px;\">\n<th>\u30a2\u30eb\u30df\u8907\u5408\u677f(\u82af\u6750\uff1a\u767a\u6ce1\u30dd\u30ea\u30a8\u30c1\u30ec\u30f3\u6a39\u8102)<\/th>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>3.0<\/td>\n<td>2.0<\/td>\n<td>3.0<\/td>\n<td>7.0<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-7a2dd7e\" data-id=\"7a2dd7e\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-3ea31b8 elementor-widget elementor-widget-text-editor\" data-id=\"3ea31b8\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p style=\"text-align: center;\">\u90e8\u4f4d\u4f8b<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-8ba51d9 elementor-widget elementor-widget-image\" data-id=\"8ba51d9\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img decoding=\"async\" width=\"350\" height=\"240\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2025\/03\/3474_15_A.png\" class=\"attachment-large size-large wp-image-31882\" alt=\"\" srcset=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2025\/03\/3474_15_A.png 350w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2025\/03\/3474_15_A-300x206.png 300w\" sizes=\"(max-width: 350px) 100vw, 350px\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-35d359e print_page elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"35d359e\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-f6bfe33\" data-id=\"f6bfe33\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-95eb386 elementor-widget elementor-widget-menu-anchor\" data-id=\"95eb386\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"menu-anchor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t<div class=\"elementor-menu-anchor\" id=\"box_3\"><\/div>\n\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-6d31f55 elementor-widget elementor-widget-heading\" data-id=\"6d31f55\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h4 class=\"elementor-heading-title elementor-size-default\">\u5207\u6b20\u5f62\u72b6\u306e\u6700\u5c0f\u30b5\u30a4\u30ba<\/h4>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<section class=\"elementor-section elementor-inner-section elementor-element elementor-element-3fca78e elementor-section-content-middle print_wrap  print_break elementor-reverse-mobile elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"3fca78e\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-da08093 print_break\" data-id=\"da08093\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-7fb3af3 elementor-widget elementor-widget-text-editor\" data-id=\"7fb3af3\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p style=\"text-align: center;\">\u52a0\u5de5\u9650\u754c\u30fb\u5bf8\u6cd5\u7bc4\u56f2<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-a5f0d60 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"a5f0d60\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<div class=\"print_block\">\n<div class=\"tableStickyHead\">\n<table class=\"table05 min tableHover mT0\">\n<thead>\n<tr style=\"height: 24px;\">\n<th rowspan=\"2\">\u6750\u8cea<\/th>\n<th rowspan=\"2\">\u677f\u539a<\/th>\n<th>\u4fdd\u8a3c\u5024<\/th>\n<th>\u9650\u754c\u5024<\/th>\n<\/tr>\n<tr style=\"height: 24px;\">\n<th colspan=\"2\">\u5207\u6b20\u5e45\u30fb\u6df1\u3055<span style=\"color: #d8352a;\">A<\/span><\/th>\n<\/tr>\n<\/thead>\n<\/table>\n<\/div>\n<table class=\"table05 min tableHover mT0\">\n<tbody>\n<tr>\n\t\t<th rowspan=\"7\">SPCC(\u30b7\u30e0\u7528)<br>SUS304(H) (\u30b7\u30e0\u7528)<\/td>\n\t\t<td>0.05<\/td>\n\t\t<td rowspan=\"4\">0.5<\/td>\n\t\t<td rowspan=\"4\">0.3<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<td>0.1<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<td>0.2<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<td>0.3<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<td>0.5<\/td>\n\t\t<td>0.8<\/td>\n\t\t<td>0.4<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<td>0.8<\/td>\n\t\t<td>1.2<\/td>\n\t\t<td rowspan=\"2\">0.5<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<td>1.0<\/td>\n\t\t<td>1.5<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<th rowspan=\"6\">C2680P\/C2801P(\u30b7\u30e0\u7528)<\/th>\n\t\t<td>0.05<\/td>\n\t\t<td rowspan=\"3\">0.5<\/td>\n\t\t<td rowspan=\"3\">0.5<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<td>0.1<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<td>0.2<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<td>0.3<\/td>\n\t\t<td>0.8<\/td>\n\t\t<td>0.8<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<td>0.5<\/td>\n\t\t<td>1.0<\/td>\n\t\t<td rowspan=\"2\">1.0<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<td>1.0<\/td>\n\t\t<td>1.5<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<th rowspan=\"4\">PET<br>\u30a2\u30af\u30ea\u30eb<br>\u30dd\u30ea\u30ab\u30fc\u30dc\u30cd\u30fc\u30c8<br>\u5869\u30d3<br>\u30a2\u30eb\u30df\u8907\u5408\u677f(\u82af\u6750\uff1a\u767a\u6ce1\u30dd\u30ea\u30a8\u30c1\u30ec\u30f3\u6a39\u8102)<\/td>\n\t\t<td>3.0<\/td>\n\t\t<td rowspan=\"4\">&#8211;<\/td>\n\t\t<td rowspan=\"4\">7.0<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<td>5.0<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<td>8.0<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<td>10.0<\/td>\n\t<\/tr>\n<\/tbody>\n<\/table>\n<\/div>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-4d930f2\" data-id=\"4d930f2\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-c677765 elementor-widget elementor-widget-text-editor\" data-id=\"c677765\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p style=\"text-align: center;\">\u90e8\u4f4d\u4f8b<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-96247e3 elementor-widget elementor-widget-image\" data-id=\"96247e3\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img decoding=\"async\" width=\"243\" height=\"169\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/fcpl_item_guideline_49.png\" class=\"attachment-large size-large wp-image-3142\" alt=\"\u90e8\u4f4d\u4f8b\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-1dab571 print_page elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"1dab571\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-63df74a\" data-id=\"63df74a\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-5312b30 elementor-widget elementor-widget-menu-anchor\" data-id=\"5312b30\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"menu-anchor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t<div class=\"elementor-menu-anchor\" id=\"box_18\"><\/div>\n\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-c10558b elementor-widget elementor-widget-heading\" data-id=\"c10558b\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h4 class=\"elementor-heading-title elementor-size-default\">(\u5e73\u677f\u5c55\u958b\u6642\u306e)\u30b9\u30ea\u30c3\u30c8\u6700\u5c0f\u5e45<\/h4>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<section class=\"elementor-section elementor-inner-section elementor-element elementor-element-7f0bed9 elementor-section-content-middle print_wrap  print_break elementor-reverse-mobile elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"7f0bed9\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-a8aea26 print_break\" data-id=\"a8aea26\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-64ff876 elementor-widget elementor-widget-text-editor\" data-id=\"64ff876\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p style=\"text-align: center;\">\u52a0\u5de5\u9650\u754c\u30fb\u5bf8\u6cd5\u7bc4\u56f2<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-388c53e tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"388c53e\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"table05 min tableHover\" style=\"width: 100%; margin-top: 0px;\">\n<tbody>\n<tr style=\"height: 24px;\">\n<th style=\"width: 70%;\" colspan=\"4\">\u677f\u539a<\/th>\n<th style=\"width: 30%;\" colspan=\"2\">(\u5e73\u677f\u5c55\u958b\u6642\u306e)\u30b9\u30ea\u30c3\u30c8\u6700\u5c0f\u5e45<\/th>\n<\/tr>\n<tr style=\"height: 24px;\">\n<th style=\"width: 17.5%;\">\n<ul>\n<li>SPCC(SPHC)<\/li>\n<li>SS400<\/li>\n<li>SECC<\/li>\n<\/ul>\n<\/th>\n<th style=\"width: 17.5%;\">\n<ul>\n<li>SUS304<\/li>\n<li>SUS316<\/li>\n<li>SUS430<\/li>\n<li>\u30d1\u30f3\u30c1\u30f3\u30b0\u30e1\u30bf\u30eb<\/li>\n<\/ul>\n<\/th>\n<th style=\"width: 17.5%;\">\n<ul><li>A5052<\/li>\n<li>\u30a2\u30eb\u30de\u30a4\u30c8\u92fc\u677f\uff08\u767d\u30fb\u9ed2\uff09<\/li><\/ul>\n<\/th>\n<th style=\"width: 17.5%;\"><ul><li>C1020<\/li>\n<li>C1100<\/li>\n<li>C2801P<\/li><\/ul><\/th>\n<th style=\"width: 17.5%; text-align: center;\">\u4fdd\u8a3c\u5024<span style=\"color: #d8352a;\">a<\/span><\/th>\n<th style=\"width: 17.5%; text-align: center;\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">a<\/span><\/th>\n<\/tr>\n<tr><td>0.8<\/td><td>0.8<\/td><td>0.8<\/td><td>\u2013<\/td><td>0.8<\/td><td>0.5<\/td><\/tr>\n<tr><td>1.0<\/td><td>1.0<\/td><td>1.0<\/td><td>1.0<\/td><td>1.0<\/td><td>0.5<\/td><\/tr>\n<tr><td>1.2<\/td><td>1.2<\/td><td>1.2<\/td><td>\u2013<\/td><td>1.2<\/td><td>0.5<\/td><\/tr>\n<tr><td>\u2013<\/td><td>1.5<\/td><td>1.5<\/td><td>1.5<\/td><td>1.5<\/td><td>0.5<\/td><\/tr>\n<tr><td>1.6<\/td><td>\u2013<\/td><td>1.6<\/td><td>\u2013<\/td><td>1.6<\/td><td>0.5<\/td><\/tr>\n<tr><td>2.0<\/td><td>2.0<\/td><td>2.0<\/td><td>2.0<\/td><td>2.0<\/td><td>0.5<\/td><\/tr>\n<tr><td>2.3<\/td><td>\u2013<\/td><td>\u2013<\/td><td rowspan='2'>\u2013<\/td><td>2.3<\/td><td>0.8<\/td><\/tr>\n<tr><td>\u2013<\/td><td>2.5<\/td><td>2.5<\/td><td>2.5<\/td><td>0.8<\/td><\/tr>\n<tr><td>\u2013<\/td><td>3.0<\/td><td>3.0<\/td><td>3.0<\/td><td>3.0<\/td><td>1.5<\/td><\/tr>\n<tr><td>3.2<\/td><td>\u2013<\/td><td>\u2013<\/td><td rowspan='9'>\u2013<\/td><td>3.2<\/td><td>1.6<\/td><\/tr>\n<tr><td>\u2013<\/td><td>4.0<\/td><td>4.0<\/td><td>4.0<\/td><td>2.0<\/td><\/tr>\n<tr><td>4.5<\/td><td>\u2013<\/td><td>\u2013<\/td><td>4.5<\/td><td>2.3<\/td><\/tr>\n<tr><td>\u2013<\/td><td>5.0<\/td><td>5.0<\/td><td>5.0<\/td><td>2.5<\/td><\/tr>\n<tr><td>6.0<\/td><td>6.0<\/td><td>6.0<\/td><td>6.0<\/td><td>3.0<\/td><\/tr>\n<tr><td>9.0<\/td><td>9.0<\/td><td rowspan='4'>\u2013<\/td><td>9.0<\/td><td>4.5<\/td><\/tr>\n<tr><td>10.0<\/td><td>10.0<\/td><td>10.0<\/td><td>5.0<\/td><\/tr>\n<tr><td>12.0<\/td><td>12.0<\/td><td>12.0<\/td><td>6.0<\/td><\/tr>\n<tr><td>16.0<\/td><td>\u2013<\/td><td>16.0<\/td><td>8.0<\/td><\/tr>\n\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-fe0f6d4\" data-id=\"fe0f6d4\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-01f9838 elementor-widget elementor-widget-text-editor\" data-id=\"01f9838\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p style=\"text-align: center;\">\u90e8\u4f4d\u4f8b<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-e5014fd elementor-widget elementor-widget-text-editor\" data-id=\"e5014fd\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p style=\"text-align: left;\">\u5e73\u677f\u5c55\u958b\u524d<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-a81064a elementor-widget elementor-widget-image\" data-id=\"a81064a\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img loading=\"lazy\" decoding=\"async\" width=\"500\" height=\"300\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/08\/3474_10.png\" class=\"attachment-large size-large wp-image-20078\" alt=\"\" srcset=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/08\/3474_10.png 500w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/08\/3474_10-300x180.png 300w\" sizes=\"(max-width: 500px) 100vw, 500px\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-b4fc7d5 elementor-widget elementor-widget-text-editor\" data-id=\"b4fc7d5\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p style=\"text-align: left;\">\u5e73\u677f\u5c55\u958b\u5f8c<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-a5776c1 elementor-widget elementor-widget-image\" data-id=\"a5776c1\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img loading=\"lazy\" decoding=\"async\" width=\"500\" height=\"350\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/10\/3474_11.png\" class=\"attachment-large size-large wp-image-20901\" alt=\"\" srcset=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/10\/3474_11.png 500w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/10\/3474_11-300x210.png 300w\" sizes=\"(max-width: 500px) 100vw, 500px\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-02a5577 elementor-widget elementor-widget-text-editor\" data-id=\"02a5577\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p style=\"text-align: left;\">\u8a73\u7d30\u56f3<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-484f4c3 elementor-widget elementor-widget-image\" data-id=\"484f4c3\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img loading=\"lazy\" decoding=\"async\" width=\"500\" height=\"130\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/10\/3474_12.png\" class=\"attachment-large size-large wp-image-20902\" alt=\"\" srcset=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/10\/3474_12.png 500w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/10\/3474_12-300x78.png 300w\" sizes=\"(max-width: 500px) 100vw, 500px\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-cea471a print_page elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"cea471a\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-5b29a9f\" data-id=\"5b29a9f\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-d51662c elementor-widget elementor-widget-menu-anchor\" data-id=\"d51662c\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"menu-anchor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t<div class=\"elementor-menu-anchor\" id=\"box_6\"><\/div>\n\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-5c71419 elementor-widget elementor-widget-heading\" data-id=\"5c71419\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h4 class=\"elementor-heading-title elementor-size-default\">\u6700\u5c0f\u66f2\u3052\u9ad8\u3055\uff1a\u901a\u5e38\u66f2\u3052\u52a0\u5de5<\/h4>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<section class=\"elementor-section elementor-inner-section elementor-element elementor-element-8bf71b5 elementor-section-content-middle print_wrap  print_break elementor-reverse-mobile elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"8bf71b5\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-f25ac6a print_break\" data-id=\"f25ac6a\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-a508bfb elementor-widget elementor-widget-text-editor\" data-id=\"a508bfb\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p style=\"text-align: center;\">\u52a0\u5de5\u9650\u754c\u30fb\u5bf8\u6cd5\u7bc4\u56f2<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-bb9181d tblBasic print_break elementor-widget elementor-widget-text-editor\" data-id=\"bb9181d\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<div>\n<div class=\"tableStickyHead\">\n<table class=\"table05 min fixed tableHover_single mT0 print_break\">\n<thead>\n<tr style=\"height: 24px;\">\n<th>\u6750\u8cea<\/th>\n<th>\u677f\u539a<\/th>\n<th>\u9650\u754c\u5024<span style=\"color: #d8352a;\">h<\/span><\/th>\n<\/tr>\n<\/thead>\n<\/table>\n<\/div>\n<table class=\"table05 min fixed tableHover_single mT0\">\n<tbody>\n<tr style=\"height: 24px;\">\n<th rowspan=\"13\">\n<ul>\n \t<li>SPCC<\/li>\n \t<li>SPHC<\/li>\n \t<li>SS400<\/li>\n<\/ul>\n<\/th>\n<td>0.8<\/td>\n<td>4.2<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>1.0<\/td>\n<td>4.3<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>1.2<\/td>\n<td>5.5<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>1.6<\/td>\n<td>6.8<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>2.0<\/td>\n<td>8.2<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>2.3<\/td>\n<td>9.4<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>3.2<\/td>\n<td>13.3<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>4.5<\/td>\n<td>17.4<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>6.0<\/td>\n<td>23.5<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>9.0<\/td>\n<td>33.5<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>10.0<\/td>\n<td>46.5<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>12.0<\/td>\n<td>62.0<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>16.0<\/td>\n<td>88.5<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<th rowspan=\"7\">SECC<\/th>\n<td>0.8<\/td>\n<td>4.2<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>1.0<\/td>\n<td>4.3<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>1.2<\/td>\n<td>4.5<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>1.6<\/td>\n<td>5.8<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>2.0<\/td>\n<td>7.0<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>2.3<\/td>\n<td>8.3<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>3.2<\/td>\n<td>11.1<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<th rowspan=\"13\">\n<ul>\n \t<li>SUS304(No.1)<\/li>\n \t<li>SUS304(2B)<\/li>\n<li>SUS304(2B) \u7247\u9762\u4fdd\u8b77\u30b7\u30fc\u30c8\u4ed8\n<\/li>\n \t<li>SUS304(\u7247\u9762#400\u7814\u78e8)<\/li>\n \t<li>SUS304(\u7247\u9762\u30d8\u30a2\u30e9\u30a4\u30f3)<\/li>\n \t<li>SUS316(2B)<\/li>\n \t<li>SUS430(2B)<\/li>\n<\/ul>\n<\/th>\n<td>0.8<\/td>\n<td>4.2<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>1.0<\/td>\n<td>4.3<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>1.2<\/td>\n<td>4.5<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>1.5<\/td>\n<td>6.0<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>2.0<\/td>\n<td>7.1<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>2.5<\/td>\n<td>11.3<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>3.0<\/td>\n<td>11.5<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>4.0<\/td>\n<td>17.2<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>5.0<\/td>\n<td>23.5<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>6.0<\/td>\n<td>25.0<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>9.0<\/td>\n<td>39.0<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>10.0<\/td>\n<td>46.5<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>12.0<\/td>\n<td>62.0<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<th rowspan=\"11\">\n<ul>\n \t<li>A5052<\/li>\n \t<li>A5052(\u30a2\u30eb\u30de\u30a4\u30c8\u92fc\u677f\u767d)<\/li>\n \t<li>A5052(\u30a2\u30eb\u30de\u30a4\u30c8\u92fc\u677f\u9ed2)<\/li>\n<\/ul>\n<\/th>\n<td>0.8<\/td>\n<td>4.2<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>1.0<\/td>\n<td>4.3<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>1.2<\/td>\n<td>5.5<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>1.5<\/td>\n<td>6.0<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>1.6<\/td>\n<td>6.0<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>2.0<\/td>\n<td>8.2<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>2.5<\/td>\n<td>10.0<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>3.0<\/td>\n<td>13.3<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>4.0<\/td>\n<td>17.2<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>5.0<\/td>\n<td>27.0<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>6.0<\/td>\n<td>28.0<\/td>\n<\/tr>\n<tr>\n<th rowspan=\"4\">\n<ul>\n \t<li>C1020(\u7121\u9178\u7d20\u9285)<\/li>\n \t<li>C1100(\u30bf\u30d5\u30d4\u30c3\u30c1\u9285)<\/li>\n \t<li>C2801P(\u771f\u936e\u30fb\u9ec4\u9285)<\/li>\n<\/ul>\n<\/th>\n<td>1.0<\/td>\n<td>4.3<\/td>\n<\/tr>\n<tr>\n<td>1.5<\/td>\n<td>6.0<\/td>\n<\/tr>\n<tr>\n<td>2.0<\/td>\n<td>7.1<\/td>\n<\/tr>\n<tr>\n<td>3.0<\/td>\n<td>11.5<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<th rowspan=\"3\">\n<ul>\n \t<li>\u30d1\u30f3\u30c1\u30f3\u30b0\u30e1\u30bf\u30eb<\/li>\n \t<li>-\u4e38\u5b5460\u00b0\u5343\u9ce5\u30bf\u30a4\u30d7-<\/li>\n<\/ul>\n<\/th>\n<td>0.8<\/td>\n<td>4.2<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>1.0<\/td>\n<td>4.3<\/td>\n<\/tr>\n<tr style=\"height: 24px;\">\n<td>1.5<\/td>\n<td>6.0<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\n<\/div>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-27078c7\" data-id=\"27078c7\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-b9c0664 elementor-widget elementor-widget-text-editor\" data-id=\"b9c0664\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p style=\"text-align: center;\">\u90e8\u4f4d\u4f8b<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-da201f9 elementor-widget elementor-widget-image\" data-id=\"da201f9\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img loading=\"lazy\" decoding=\"async\" width=\"255\" height=\"178\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/fcpl_item_guideline_34.png\" class=\"attachment-large size-large wp-image-3146\" alt=\"\u90e8\u4f4d\u4f8b\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-b93f6f8 print_page elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"b93f6f8\" data-element_type=\"section\" data-e-type=\"section\" id=\"box_21\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-2ddf24b\" data-id=\"2ddf24b\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-c8567a6 elementor-widget elementor-widget-heading\" data-id=\"c8567a6\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h4 class=\"elementor-heading-title elementor-size-default\">\u6700\u5c0f\u66f2\u3052\u9ad8\u3055\uff1aR\u66f2\u3052\u5f62\u72b6<\/h4>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<section class=\"elementor-section elementor-inner-section elementor-element elementor-element-d32c6c0 elementor-section-content-middle print_wrap  print_break elementor-reverse-mobile elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"d32c6c0\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-163be1a print_break\" data-id=\"163be1a\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-bdddbaf elementor-widget elementor-widget-text-editor\" data-id=\"bdddbaf\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p style=\"text-align: center;\">\u52a0\u5de5\u9650\u754c\u30fb\u5bf8\u6cd5\u7bc4\u56f2<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-29f0b10 tblBasic print_break elementor-widget elementor-widget-text-editor\" data-id=\"29f0b10\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<div class=\"print_block\">\n<div class=\"tableStickyHead\">\n<table class=\"table05 min fixed tableHover_single mT0\">\n<thead>\n<tr style=\"height: 24px;\">\n<th>\u6750\u8cea<\/th>\n<th>\u677f\u539a<\/th>\n<th>\u9650\u754c\u5024<span style=\"color: #d8352a;\">h<\/span><\/th>\n<\/tr>\n<\/thead>\n<\/table>\n<\/div>\n<table class=\"table05 min fixed tableHover_single mT0\">\n<tbody>\n<tr>\n<th rowspan=\"7\">SPCC<\/th>\n<td>0.8<\/td>\n<td>2.6<\/td>\n<\/tr>\n<tr>\n<td>1.0<\/td>\n<td>2.3<\/td>\n<\/tr>\n<tr>\n<td>1.2<\/td>\n<td>3.1<\/td>\n<\/tr>\n<tr>\n<td>1.6<\/td>\n<td>3.6<\/td>\n<\/tr>\n<tr>\n<td>2.0<\/td>\n<td>4.2<\/td>\n<\/tr>\n<tr>\n<td>2.3<\/td>\n<td>4.8<\/td>\n<\/tr>\n<tr>\n<td>3.2<\/td>\n<td>6.9<\/td>\n<\/tr>\n<tr>\n<th rowspan=\"7\">SECC<\/th>\n<td>0.8<\/td>\n<td>2.6<\/td>\n<\/tr>\n<tr>\n<td>1.0<\/td>\n<td>2.3<\/td>\n<\/tr>\n<tr>\n<td>1.2<\/td>\n<td>2.1<\/td>\n<\/tr>\n<tr>\n<td>1.6<\/td>\n<td>2.6<\/td>\n<\/tr>\n<tr>\n<td>2.0<\/td>\n<td>3.0<\/td>\n<\/tr>\n<tr>\n<td>2.3<\/td>\n<td>3.7<\/td>\n<\/tr>\n<tr>\n<td>3.2<\/td>\n<td>4.7<\/td>\n<\/tr>\n<tr>\n<th rowspan=\"7\">\n<ul>\n \t<li>SUS304(2B)<\/li>\n \t<li>SUS304(\u7247\u9762#400\u7814\u78e8)<\/li>\n \t<li>SUS430(2B)<\/li>\n<\/ul>\n<\/th>\n<td>0.8<\/td>\n<td>2.6<\/td>\n<\/tr>\n<tr>\n<td>1.0<\/td>\n<td>2.3<\/td>\n<\/tr>\n<tr>\n<td>1.2<\/td>\n<td>2.1<\/td>\n<\/tr>\n<tr>\n<td>1.5<\/td>\n<td>3.0<\/td>\n<\/tr>\n<tr>\n<td>2.0<\/td>\n<td>3.1<\/td>\n<\/tr>\n<tr>\n<td>2.5<\/td>\n<td>6.3<\/td>\n<\/tr>\n<tr>\n<td>3.0<\/td>\n<td>5.5<\/td>\n<\/tr>\n<tr>\n<th rowspan=\"8\">\n<ul>\n \t<li>A5052<\/li>\n \t<li>A5052(\u30a2\u30eb\u30de\u30a4\u30c8\u92fc\u677f\u767d)<\/li>\n \t<li>A5052(\u30a2\u30eb\u30de\u30a4\u30c8\u92fc\u677f\u9ed2)<\/li>\n<\/ul>\n<\/th>\n<td>0.8<\/td>\n<td>2.6<\/td>\n<\/tr>\n<tr>\n<td>1.0<\/td>\n<td>2.3<\/td>\n<\/tr>\n<tr>\n<td>1.2<\/td>\n<td>2.1<\/td>\n<\/tr>\n<tr>\n<td>1.5<\/td>\n<td>3.0<\/td>\n<\/tr>\n<tr>\n<td>1.6<\/td>\n<td>2.8<\/td>\n<\/tr>\n<tr>\n<td>2.0<\/td>\n<td>3.1<\/td>\n<\/tr>\n<tr>\n<td>2.5<\/td>\n<td>5.0<\/td>\n<\/tr>\n<tr>\n<td>3.0<\/td>\n<td>5.5<\/td>\n<\/tr>\n<tr><th rowspan='4'>\n<ul><li>C1020(\u7121\u9178\u7d20\u9285)<\/li>\n<li>C1100(\u30bf\u30d5\u30d4\u30c3\u30c1\u9285)<\/li>\n<li>C2801P(\u771f\u936e\u30fb\u9ec4\u9285)<\/li><\/ul><\/th><td>1.0<\/td><td>2.3<\/td><\/tr>\n<tr><td>1.5<\/td><td>3.0<\/td><\/tr>\n<tr><td>2.0<\/td><td>3.1<\/td><\/tr>\n<tr><td>3.0<\/td><td>5.5<\/td><\/tr>\n\n<tr>\n<th rowspan=\"3\">\n<ul>\n \t<li>\u30d1\u30f3\u30c1\u30f3\u30b0\u30e1\u30bf\u30eb<\/li>\n \t<li>-\u4e38\u5b5460\u00b0\u5343\u9ce5\u30bf\u30a4\u30d7-<\/li>\n<\/ul>\n<\/th>\n<td>0.8<\/td>\n<td>2.6<\/td>\n<\/tr>\n<tr>\n<td>1.0<\/td>\n<td>2.3<\/td>\n<\/tr>\n<tr>\n<td>1.5<\/td>\n<td>3.0<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\n<\/div>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-7198c7c\" data-id=\"7198c7c\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-6063c27 elementor-widget elementor-widget-text-editor\" data-id=\"6063c27\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p style=\"text-align: center;\">\u90e8\u4f4d\u4f8b<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-1f4d3c1 elementor-widget elementor-widget-image\" data-id=\"1f4d3c1\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img loading=\"lazy\" decoding=\"async\" width=\"530\" height=\"320\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/09\/3474_02_B.png\" class=\"attachment-large size-large wp-image-20296\" alt=\"\" srcset=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/09\/3474_02_B.png 530w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/09\/3474_02_B-300x181.png 300w\" sizes=\"(max-width: 530px) 100vw, 530px\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-a05a627 print_page elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"a05a627\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-7505d67\" data-id=\"7505d67\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-6c2ee0e elementor-widget elementor-widget-menu-anchor\" data-id=\"6c2ee0e\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"menu-anchor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t<div class=\"elementor-menu-anchor\" id=\"box_19\"><\/div>\n\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-52a07a6 elementor-widget elementor-widget-heading\" data-id=\"52a07a6\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h4 class=\"elementor-heading-title elementor-size-default\">\u6700\u5c0f\u6bb5\u66f2\u3052\u9ad8\u3055<\/h4>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<section class=\"elementor-section elementor-inner-section elementor-element elementor-element-59db21e elementor-section-content-middle print_wrap  print_break elementor-reverse-mobile elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"59db21e\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-1f7cc2a print_break\" data-id=\"1f7cc2a\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-2360f6c elementor-widget elementor-widget-text-editor\" data-id=\"2360f6c\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p style=\"text-align: center;\">\u52a0\u5de5\u9650\u754c\u30fb\u5bf8\u6cd5\u7bc4\u56f2<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-5fb40cc tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"5fb40cc\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"table05 min tableHover\" style=\"margin-top: 0px; width: 100%;\">\n<tbody>\n<tr style=\"height: 24px;\">\n<th style=\"width: 16.6%;\" rowspan=\"3\">\u6750\u8cea<\/th>\n<th style=\"width: 16.6%;\" rowspan=\"3\">\u677f\u539a<\/th>\n<th colspan=\"4\">\u8868\u9762\u51e6\u7406<\/th>\n<\/tr>\n<tr>\n<th>\u306a\u3057<\/th>\n<th>\n<ul>\n \t<li>\u7c89\u4f53\u5857\u88c5<\/li>\n \t<li>\u6eb6\u5264\u5857\u88c5<\/li>\n \t<li>\u7121\u96fb\u89e3\u30cb\u30c3\u30b1\u30eb\u30e1\u30c3\u30ad<\/li>\n \t<li>\u56db\u4e09\u9178\u5316\u9244\u88ab\u819c<\/li>\n \t<li>\u4e09\u4fa1\u30af\u30ed\u30e1\u30fc\u30c8(\u767d)<\/li>\n<\/ul>\n<\/th>\n<th>\n<ul>\n \t<li>\u4e09\u4fa1\u30af\u30ed\u30e1\u30fc\u30c8(\u9ed2)<\/li>\n<\/ul>\n<\/th>\n<th>\n<ul>\n \t<li>\u96fb\u6c17\u4e9c\u925b\u30e1\u30c3\u30ad<\/li>\n \t<li>\u6eb6\u878d\u4e9c\u925b\u30e1\u30c3\u30ad<\/li>\n<\/ul>\n<\/th>\n<\/tr>\n<tr style=\"height: 24px;\">\n<th colspan=\"4\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">a<\/span><\/th>\n<\/tr>\n<tr style=\"height: 24px;\">\n<th rowspan=\"13\">\n<ul>\n \t<li>SPCC\/SPHC<\/li>\n \t<li>SS400<\/li>\n \t<li>SECC(\u96fb\u6c17\u4e9c\u925b\u30e1\u30c3\u30ad\u92fc\u677f)<\/li>\n \t<li>SPCC(\u6eb6\u878d\u4e9c\u925b\u30e1\u30c3\u30ad\u92fc\u677f)<\/li>\n<\/ul>\n<\/th>\n<td style=\"height: 24px;\">0.8<\/td>\n<td style=\"height: 24px;\">8.2<\/td>\n<td style=\"height: 24px;\">6.8<\/td>\n<td style=\"height: 24px;\">7.1<\/td>\n<td style=\"height: 24px;\" rowspan=\"13\">&#8211;<\/td>\n<\/tr>\n<tr>\n<td style=\"height: 24px;\">1.0<\/td>\n<td style=\"height: 24px;\">8.5<\/td>\n<td style=\"height: 24px;\">6.8<\/td>\n<td style=\"height: 24px;\">7.5<\/td>\n<\/tr>\n<tr>\n<td style=\"height: 24px;\">1.2<\/td>\n<td style=\"height: 24px;\">9.9<\/td>\n<td style=\"height: 24px;\">9.0<\/td>\n<td style=\"height: 24px;\">8.4<\/td>\n<\/tr>\n<tr>\n<td style=\"height: 24px;\">1.6<\/td>\n<td style=\"height: 24px;\">11.6<\/td>\n<td style=\"height: 24px;\">9.5<\/td>\n<td style=\"height: 24px;\">9.2<\/td>\n<\/tr>\n<tr>\n<td style=\"height: 24px;\">2.0<\/td>\n<td style=\"height: 24px;\">13.1<\/td>\n<td style=\"height: 24px;\">13.5<\/td>\n<td style=\"height: 24px;\">11.0<\/td>\n<\/tr>\n<tr>\n<td style=\"height: 24px;\">2.3<\/td>\n<td style=\"height: 24px;\">13.7<\/td>\n<td style=\"height: 24px;\">14.0<\/td>\n<td style=\"height: 24px;\">11.6<\/td>\n<\/tr>\n<tr>\n<td style=\"height: 24px;\">3.2<\/td>\n<td style=\"height: 24px;\">19.4<\/td>\n<td style=\"height: 24px;\">22.0<\/td>\n<td style=\"height: 24px;\">15.4<\/td>\n<\/tr>\n<tr>\n<td style=\"height: 24px;\">4.5<\/td>\n<td style=\"height: 24px;\">28.0<\/td>\n<td style=\"height: 24px;\">28.0<\/td>\n<td style=\"height: 24px;\">20.0<\/td>\n<\/tr>\n<tr>\n<td style=\"height: 24px;\">6.0<\/td>\n<td style=\"height: 24px;\">37.3<\/td>\n<td style=\"height: 24px;\">32.0<\/td>\n<td style=\"height: 24px;\">30.0<\/td>\n<\/tr>\n<tr>\n<td style=\"height: 24px;\">9.0<\/td>\n<td style=\"height: 24px;\">56.8<\/td>\n<td style=\"height: 24px;\">57.0<\/td>\n<td rowspan=\"4\">&#8211;<\/td>\n<\/tr>\n<tr>\n<td style=\"height: 24px;\">10.0<\/td>\n<td style=\"height: 24px;\">75.1<\/td>\n<td rowspan=\"3\">&#8211;<\/td>\n<\/tr>\n<tr>\n<td style=\"height: 24px;\">12.0<\/td>\n<td style=\"height: 24px;\">91.0<\/td>\n<\/tr>\n<tr>\n<td style=\"height: 24px;\">16.0<\/td>\n<td style=\"height: 24px;\">158.0<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\n\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-6875b21 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"6875b21\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"table05 min tableHover_single\" style=\"margin-top: 8px; width: 100%;\">\n<tbody>\n<tr style=\"height: 24px;\">\n<th style=\"width: 16.6%;\">\u6750\u8cea<\/th>\n<th style=\"width: 16.6%;\">\u677f\u539a<\/th>\n<th style=\"width: 16.6%;\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">a<\/span><\/th>\n<\/tr>\n<tr>\n<th rowspan=\"14\">\n<ul>\n \t<li>SUS304(No.1)<\/li>\n \t<li>SUS304(2B)<\/li>\n<li>SUS304(2B) \u7247\u9762\u4fdd\u8b77\u30b7\u30fc\u30c8\u4ed8\n<\/li>\n \t<li>SUS304(\u7247\u9762#400\u7814\u78e8)<\/li>\n \t<li>SUS304(\u7247\u9762\u30d8\u30a2\u30e9\u30a4\u30f3)<\/li>\n \t<li>SUS430(2B)<\/li>\n<\/ul>\n<\/th>\n<\/tr>\n<tr>\n<td style=\"height: 24px;\">0.8<\/td>\n<td style=\"height: 24px;\">6.9<\/td>\n<\/tr>\n<tr>\n<td style=\"height: 24px;\">1.0<\/td>\n<td style=\"height: 24px;\">7.4<\/td>\n<\/tr>\n<tr>\n<td style=\"height: 24px;\">1.2<\/td>\n<td style=\"height: 24px;\">7.9<\/td>\n<\/tr>\n<tr>\n<td style=\"height: 24px;\">1.5<\/td>\n<td style=\"height: 24px;\">9.7<\/td>\n<\/tr>\n<tr>\n<td style=\"height: 24px;\">2.0<\/td>\n<td style=\"height: 24px;\">12.6<\/td>\n<\/tr>\n<tr>\n<td style=\"height: 24px;\">2.5<\/td>\n<td style=\"height: 24px;\">17.6<\/td>\n<\/tr>\n<tr>\n<td style=\"height: 24px;\">3.0<\/td>\n<td style=\"height: 24px;\">18.6<\/td>\n<\/tr>\n<tr>\n<td style=\"height: 24px;\">4.0<\/td>\n<td style=\"height: 24px;\">26.6<\/td>\n<\/tr>\n<tr>\n<td style=\"height: 24px;\">5.0<\/td>\n<td style=\"height: 24px;\">33.8<\/td>\n<\/tr>\n<tr>\n<td style=\"height: 24px;\">6.0<\/td>\n<td style=\"height: 24px;\">36.4<\/td>\n<\/tr>\n<tr>\n<td style=\"height: 24px;\">9.0<\/td>\n<td style=\"height: 24px;\">56.8<\/td>\n<\/tr>\n<tr>\n<td style=\"height: 24px;\">10.0<\/td>\n<td style=\"height: 24px;\">75.1<\/td>\n<\/tr>\n<tr>\n<td style=\"height: 24px;\">12.0<\/td>\n<td style=\"height: 24px;\">91.0<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-b45bdec tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"b45bdec\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"table05 min tableHover_single\" style=\"margin-top: 8px; width: 100%;\">\n<tbody>\n<tr style=\"height: 24px;\">\n<th style=\"width: 16.6%;\">\u6750\u8cea<\/th>\n<th style=\"width: 16.6%;\">\u677f\u539a<\/th>\n<th style=\"width: 16.6%;\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">a<\/span><\/th>\n<\/tr>\n<tr>\n\t\t<th rowspan=\"9\">SUS316(2B)<\/th>\n\t\t<td>0.8<\/td>\n\t\t<td>7.6<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<td>1.0<\/td>\n\t\t<td>7.9<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<td>1.2<\/td>\n\t\t<td>8.3<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<td>1.5<\/td>\n\t\t<td>9.7<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<td>2.0<\/td>\n\t\t<td>12.6<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<td>3.0<\/td>\n\t\t<td>18.6<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<td>4.0<\/td>\n\t\t<td>26.6<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<td>5.0<\/td>\n\t\t<td>35.7<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<td>6.0<\/td>\n\t\t<td>37.3<\/td>\n\t<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-efbada0 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"efbada0\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"table05 min tableHover\" style=\"margin-top: 8px; width: 100%;\"><tbody><tr><th style=\"width: 16.65%;\" rowspan=\"4\">\u6750\u8cea<\/th><th style=\"width: 16.65%;\" rowspan=\"4\">\u677f\u539a<\/th><th style=\"width: 33.3% height: 24px;\" colspan=\"2\">\u8868\u9762\u51e6\u7406<\/th><\/tr><tr><th style=\"width: 16.65% height:24px;\">\u306a\u3057<\/th><th style=\"width: 16.65% height:24px;\" rowspan=\"2\"><ul><li>\u30a2\u30eb\u30de\u30a4\u30c8(\u767d)<\/li><li>\u30a2\u30eb\u30de\u30a4\u30c8(\u9ed2)<\/li><li>\u30a2\u30eb\u30de\u30a4\u30c8(\u3064\u3084\u6d88\u3057\u9ed2)<\/li><li>(\u5916\u5f62\u5bf8\u6cd5:\u9577\u624b300mm\u4ee5\u4e0b)<\/li><\/ul><\/th><\/tr><tr><th><ul><li>\u30a2\u30eb\u30de\u30a4\u30c8(\u767d)<\/li><li>\u30a2\u30eb\u30de\u30a4\u30c8(\u9ed2)<\/li><li>\u30a2\u30eb\u30de\u30a4\u30c8(\u3064\u3084\u6d88\u3057\u9ed2)<\/li><li>(\u5916\u5f62\u5bf8\u6cd5:\u9577\u624b300mm\u8d85)<\/li><\/ul><\/th><\/tr><tr><th style=\"height: 24px;\" colspan=\"2\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">a<\/span><\/th><\/tr><tr><th rowspan=\"12\"><ul><li><p>A5052<\/p><\/li><\/ul><\/th><\/tr><tr><td style=\"height: 24px;\">0.8<\/td><td style=\"height: 24px;\">6.8<\/td><td style=\"height: 24px;\">7.1<\/td><\/tr><tr><td style=\"height: 24px;\">1.0<\/td><td style=\"height: 24px;\">6.8<\/td><td style=\"height: 24px;\">7.5<\/td><\/tr><tr><td style=\"height: 24px;\">1.2<\/td><td style=\"height: 24px;\">9.0<\/td><td style=\"height: 24px;\">9.0<\/td><\/tr><tr><td style=\"height: 24px;\">1.5<\/td><td style=\"height: 24px;\">9.5<\/td><td style=\"height: 24px;\">9.0<\/td><\/tr><tr><td style=\"height: 24px;\">1.6<\/td><td style=\"height: 24px;\">9.5<\/td><td style=\"height: 24px;\">9.5<\/td><\/tr><tr><td style=\"height: 24px;\">2.0<\/td><td style=\"height: 24px;\">13.5<\/td><td style=\"height: 24px;\">11.0<\/td><\/tr><tr><td style=\"height: 24px;\">2.5<\/td><td style=\"height: 24px;\">15.5<\/td><td style=\"height: 24px;\">15.5<\/td><\/tr><tr><td style=\"height: 24px;\">3.0<\/td><td style=\"height: 24px;\">22.0<\/td><td style=\"height: 24px;\">15.0<\/td><\/tr><tr><td style=\"height: 24px;\">4.0<\/td><td style=\"height: 24px;\">28.0<\/td><td style=\"height: 24px;\">19.0<\/td><\/tr><tr><td style=\"height: 24px;\">5.0<\/td><td style=\"height: 24px;\">44.0<\/td><td style=\"height: 24px;\">28.0<\/td><\/tr><tr><td style=\"height: 24px;\">6.0<\/td><td style=\"height: 24px;\">48.0<\/td><td style=\"height: 24px;\">48.0<\/td><\/tr><\/tbody><\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-34fd651 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"34fd651\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"table05 min tableHover_single\" style=\"margin-top: 8px; width: 100%;\">\n<tbody>\n<tr style=\"height: 24px;\">\n<th style=\"width: 16.6%;\">\u6750\u8cea<\/th>\n<th style=\"width: 16.6%;\">\u677f\u539a<\/th>\n<th style=\"width: 16.6%;\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">a<\/span><\/th>\n<\/tr>\n<tr>\n\t\t<th rowspan=\"4\">A5052(\u30a2\u30eb\u30de\u30a4\u30c8\u92fc\u677f\u767d)<br>A5052(\u30a2\u30eb\u30de\u30a4\u30c8\u92fc\u677f\u9ed2)<\/th>\n\t\t<td>1.0<\/td>\n\t\t<td>6.8<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<td>1.5<\/td>\n\t\t<td>9.5<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<td>2.0<\/td>\n\t\t<td>13.5<\/td>\n\t<\/tr>\n\t<tr>\n\t\t<td>3.0<\/td>\n\t\t<td>22.0<\/td>\n\t<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-924d0bb tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"924d0bb\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"table05 min tableHover_single\" style=\"margin-top: 8px; width: 100%;\">\n<tbody>\n<tr style=\"height: 24px;\">\n<th style=\"width: 16.6%;\">\u6750\u8cea<\/th>\n<th style=\"width: 16.6%;\">\u677f\u539a<\/th>\n<th style=\"width: 16.6%;\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">a<\/span><\/th>\n<\/tr>\n<tr>\n<th rowspan=\"4\"><ul><li>C1020(\u7121\u9178\u7d20\u9285)<\/li>\n<li>C1100(\u30bf\u30d5\u30d4\u30c3\u30c1\u9285)<\/li>\n<li>C2801P(\u771f\u936e\u30fb\u9ec4\u9285)<\/li><\/ul><\/th>\n<td>1.0<\/td>\n<td>7.4<\/td>\n<\/tr>\n<tr>\n<td>1.5<\/td>\n<td>9.7<\/td>\n<\/tr>\n<tr>\n<td>2.0<\/td>\n<td>12.6<\/td>\n<\/tr>\n<tr>\n<td>3.0<\/td>\n<td>18.6<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-da5b5ed tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"da5b5ed\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"table05 min tableHover_single\" style=\"margin-top: 8px; width: 100%;\">\n<tbody>\n<tr style=\"height: 24px;\">\n<th style=\"height: 24px;\">\u6750\u8cea<\/th>\n<th style=\"height: 24px;\">\u677f\u539a<\/th>\n<th style=\"height: 24px;\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">a<\/span><\/th>\n<\/tr>\n<tr>\n<th rowspan=\"5\">\u30d1\u30f3\u30c1\u30f3\u30b0\u30e1\u30bf\u30eb\n-\u4e38\u5b5460\u00b0\u5343\u9ce5\u30bf\u30a4\u30d7-<\/th>\n<\/tr>\n<tr>\n<td style=\"height: 24px;\">0.8<\/td>\n<td style=\"height: 24px;\">6.8<\/td>\n<\/tr>\n<tr>\n<td style=\"height: 24px;\">1.0<\/td>\n<td style=\"height: 24px;\">6.8<\/td>\n<\/tr>\n<tr>\n<td style=\"height: 24px;\">1.5<\/td>\n<td style=\"height: 24px;\">9.5<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-98a4c9c\" data-id=\"98a4c9c\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-ba3fbcf elementor-widget elementor-widget-text-editor\" data-id=\"ba3fbcf\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p style=\"text-align: center;\">\u90e8\u4f4d\u4f8b<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-0490d04 elementor-widget elementor-widget-image\" data-id=\"0490d04\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img loading=\"lazy\" decoding=\"async\" width=\"530\" height=\"262\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/10\/3474_13.png\" class=\"attachment-large size-large wp-image-21280\" alt=\"\" srcset=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/10\/3474_13.png 530w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2023\/10\/3474_13-300x148.png 300w\" sizes=\"(max-width: 530px) 100vw, 530px\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-bc884bb elementor-reverse-mobile print_page elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"bc884bb\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-b1aea19\" data-id=\"b1aea19\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-b8cd86e elementor-widget elementor-widget-menu-anchor\" data-id=\"b8cd86e\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"menu-anchor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t<div class=\"elementor-menu-anchor\" id=\"box_7\"><\/div>\n\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-91a4993 elementor-widget elementor-widget-heading\" data-id=\"91a4993\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h4 class=\"elementor-heading-title elementor-size-default\">\u66f2\u3052\u5e45\u5bf8\u6cd5\u6307\u5b9a\u7bc4\u56f2\u3068\u92ed\u89d2\u66f2\u3052\u306e\u6700\u5c0f\u89d2\u5ea6<\/h4>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-7bdb9d7 elementor-widget elementor-widget-text-editor\" data-id=\"7bdb9d7\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p>\u66f2\u3052\u5e45\u5bf8\u6cd5\u306b\u3088\u3063\u3066\u0398\u306e\u8981\u4ef6\u304c\u7570\u306a\u308a\u307e\u3059<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<section class=\"elementor-section elementor-inner-section elementor-element elementor-element-641d021 elementor-section-content-middle print_wrap  print_break elementor-reverse-mobile elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"641d021\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-27665c5 print_break\" data-id=\"27665c5\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-f5100d6 elementor-widget elementor-widget-text-editor\" data-id=\"f5100d6\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p style=\"text-align: center;\">\u52a0\u5de5\u9650\u754c\u30fb\u5bf8\u6cd5\u7bc4\u56f2<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-faf7c05 tblBasic print_break elementor-widget elementor-widget-text-editor\" data-id=\"faf7c05\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<div>\n<div class=\"tableStickyHead\">\n<table class=\"table05 min fixed tableHover mT0 print_break\">\n<thead>\n<tr>\n<th>\u6750\u8cea<\/th>\n<th>\u677f\u539a\n\u30a2\u30eb\u30de\u30a4\u30c8\u92fc\u677f\u306f( )\u5185\u306e\u307f<\/th>\n<th>\u5bf8\u6cd5\u7bc4\u56f2<span style=\"color: #d8352a;\">w<\/span><\/th>\n<th>\u92ed\u89d2\u66f2\u3052\u89d2\u5ea6<span style=\"color: #d8352a;\">\u0398<\/span><\/th>\n<\/tr>\n<\/thead>\n<\/table>\n<\/div>\n<table class=\"table05 min fixed tableHover mT0\">\n<tbody>\n<tr>\n<th rowspan=\"8\">SPCC\/SPHC SS400<\/th>\n<td>0.8 1.0 1.2 1.6 2.0<\/td>\n<td>5\u2266w&lt;1500<\/td>\n<td rowspan=\"3\">\u0398\u226745\u00b0<\/td>\n<\/tr>\n<tr>\n<td>2.3 3.2<\/td>\n<td>10\u2266w&lt;1500<\/td>\n<\/tr>\n<tr>\n<td rowspan=\"2\">4.5<\/td>\n<td>10\u2266w&lt;835<\/td>\n<\/tr>\n<tr>\n<td>835\u2266w&lt;1500<\/td>\n<td>\u0398\u226788\u00b0<\/td>\n<\/tr>\n<tr>\n<td>6.0 9.0<\/td>\n<td>10\u2266w\u22661200<\/td>\n<td rowspan=\"4\">\u0398\u226788\u00b0<\/td>\n<\/tr>\n<tr>\n<td>10.0<\/td>\n<td>20\u2266w\u2266835<\/td>\n<\/tr>\n<tr>\n<td>12.0<\/td>\n<td>20\u2266w\u2266750<\/td>\n<\/tr>\n<tr>\n<td>16.0<\/td>\n<td>20\u2266w\u2266500<\/td>\n<\/tr>\n<tr>\n<th rowspan=\"2\">SPCC(\u6eb6\u878d\u4e9c\u925b\u30e1\u30c3\u30ad\u92fc\u677f)<\/th>\n<td>1.6<\/td>\n<td>5\u2266w\u22661200<\/td>\n<td rowspan=\"2\">\u0398\u226745\u00b0<\/td>\n<\/tr>\n<tr>\n<td>2.3<\/td>\n<td>10\u2266w\u22661200<\/td>\n<\/tr>\n<tr>\n<th rowspan=\"6\">SECC(\u96fb\u6c17\u4e9c\u925b\u30e1\u30c3\u30ad)<\/th>\n<td rowspan=\"2\">0.8 1.0 1.2 1.6 2.0<\/td>\n<td>5\u2266w\u22661500<\/td>\n<td>\u0398\u226730\u00b0<\/td>\n<\/tr>\n<tr>\n<td>1500&lt;w\u22661700<\/td>\n<td>\u0398\u226745\u00b0<\/td>\n<\/tr>\n<tr>\n<td rowspan=\"2\">2.3<\/td>\n<td>10\u2266w\u22661500<\/td>\n<td>\u0398\u226730\u00b0<\/td>\n<\/tr>\n<tr>\n<td>1500&lt;w\u22661700<\/td>\n<td>\u0398\u226745\u00b0<\/td>\n<\/tr>\n<tr>\n<td rowspan=\"2\">3.2<\/td>\n<td>10\u2266w\u22661200<\/td>\n<td>\u0398\u226750\u00b0<\/td>\n<\/tr>\n<tr>\n<td>10\u2266w\u22661700<\/td>\n<td>\u0398\u226760\u00b0<\/td>\n<\/tr>\n<tr>\n<th rowspan=\"2\">SUS304(No.1)<\/th>\n<td>9.0<\/td>\n<td>10\u2266w\u2266550<\/td>\n<td rowspan=\"2\">\u0398\u226788\u00b0<\/td>\n<\/tr>\n<tr>\n<td>10.0 12.0<\/td>\n<td>20\u2266w\u2266550<\/td>\n<\/tr>\n<tr>\n<th rowspan=\"7\">SUS304(2B)<\/th>\n<td>0.8 1.0 1.2 1.5 2.0<\/td>\n<td>5\u2266w\u22661700<\/td>\n<td rowspan=\"2\">\u0398\u226745\u00b0<\/td>\n<\/tr>\n<tr>\n<td rowspan=\"2\">2.5<\/td>\n<td>10\u2266w\u22661200<\/td>\n<\/tr>\n<tr>\n<td>1200&lt;w\u22661700<\/td>\n<td>\u0398\u226790\u00b0<\/td>\n<\/tr>\n<tr>\n<td rowspan=\"2\">3.0 4.0<\/td>\n<td>10\u2266w\u22661200<\/td>\n<td>\u0398\u226745\u00b0<\/td>\n<\/tr>\n<tr>\n<td>1200&lt;w\u22661500<\/td>\n<td>\u0398\u226790\u00b0<\/td>\n<\/tr>\n<tr>\n<td>5.0<\/td>\n<td>10\u2266w\u22661200<\/td>\n<td>\u0398\u226745\u00b0<\/td>\n<\/tr>\n<tr>\n<td>6.0<\/td>\n<td>10\u2266w\u2266800<\/td>\n<td>\u0398\u226760\u00b0<\/td>\n<\/tr>\n<tr>\n<th rowspan=\"5\">SUS304(2B) \u7247\u9762\u4fdd\u8b77\u30b7\u30fc\u30c8\u4ed8<\/th>\n<td>0.8 1.0 1.2 1.5 2.0<\/td>\n<td>5\u2266w\u22661700<\/td>\n<td>\u0398\u226745\u00b0<\/td>\n<\/tr>\n<tr>\n<td rowspan=\"2\">2.5<\/td>\n<td>10\u2266w\u22661200<\/td>\n<td>\u0398\u226745\u00b0<\/td>\n<\/tr>\n<tr>\n<td>1200&lt;w\u22661700<\/td>\n<td>\u0398\u226790\u00b0<\/td>\n<\/tr>\n<tr>\n<td rowspan=\"2\">3.0<\/td>\n<td>10\u2266w\u22661200<\/td>\n<td>\u0398\u226745\u00b0<\/td>\n<\/tr>\n<tr>\n<td>1200&lt;w\u22661500<\/td>\n<td>\u0398\u226790\u00b0<\/td>\n<\/tr>\n<tr>\n<th rowspan=\"3\">\n<ul>\n \t<li>SUS304(\u7247\u9762#400\u7814\u78e8)<\/li>\n \t<li>SUS304(\u7247\u9762\u30d8\u30a2\u30e9\u30a4\u30f3)<\/li>\n<\/ul>\n<\/th>\n<td>0.8 1.0 1.2 1.5 2.0<\/td>\n<td>5\u2266w\u22661700<\/td>\n<td>\u0398\u226745\u00b0<\/td>\n<\/tr>\n<tr>\n<td rowspan=\"2\">3.0<\/td>\n<td>10\u2266w\u22661200<\/td>\n<td>\u0398\u226745\u00b0<\/td>\n<\/tr>\n<tr>\n<td>1200&lt;w\u22661500<\/td>\n<td>\u0398\u226790\u00b0<\/td>\n<\/tr>\n<tr>\n<th rowspan=\"3\">SUS316(2B)<\/th>\n<td>0.8 1.0 1.2 1.5 2.0<\/td>\n<td>5\u2266w\u22661700<\/td>\n<td rowspan=\"2\">\u0398\u226745\u00b0<\/td>\n<\/tr>\n<tr>\n<td>3.0<\/td>\n<td>10\u2266w\u22661700<\/td>\n<\/tr>\n<tr>\n<td>4.0 5.0 6.0<\/td>\n<td>10\u2266w\u22661500<\/td>\n<td>\u0398\u226788\u00b0<\/td>\n<\/tr>\n<tr>\n<th rowspan=\"4\">SUS430(2B)<\/th>\n<td rowspan=\"2\">0.8 1.0 1.2 1.5 2.0<\/td>\n<td>5\u2266w\u22661500<\/td>\n<td>\u0398\u226730\u00b0<\/td>\n<\/tr>\n<tr>\n<td>1500&lt;w\u22661700<\/td>\n<td>\u0398\u226745\u00b0<\/td>\n<\/tr>\n<tr>\n<td rowspan=\"2\">3.0<\/td>\n<td>10\u2266w\u22661200<\/td>\n<td>\u0398\u226750\u00b0<\/td>\n<\/tr>\n<tr>\n<td>1500&lt;w\u22661700<\/td>\n<td>\u0398\u226760\u00b0<\/td>\n<\/tr>\n<th rowspan=\"4\">\n<ul>\n \t<li>A5052<\/li>\n \t<li>A5052\u30a2\u30eb\u30de\u30a4\u30c8\u92fc\u677f(\u767d)<\/li>\n \t<li>A5052\u30a2\u30eb\u30de\u30a4\u30c8\u92fc\u677f(\u9ed2)<\/li>\n<\/ul>\n<\/th>\n<td rowspan=\"2\">0.8 (1.0) 1.2 (1.5) 1.6 (2.0)<\/td>\n<td>5\u2266w\u22661200<\/td>\n<td>\u0398\u226745\u00b0<\/td>\n<\/tr>\n<tr>\n<td>1200&lt;w\u22661700<\/td>\n<td>\u0398\u226786\u00b0<\/td>\n<\/tr>\n<tr>\n<td rowspan=\"2\">2.5 (3.0) 4.0 5.0 6.0<\/td>\n<td>10\u2266w\u22661200<\/td>\n<td>\u0398\u226745\u00b0<\/td>\n<\/tr>\n<tr>\n<td>1200&lt;w\u22661700<\/td>\n<td>\u0398\u226786\u00b0<\/td>\n<\/tr>\n<tr>\n<th rowspan=\"2\">C1020(\u7121\u9178\u7d20\u9285)<\/th>\n<td>1.0 1.5 2.0<\/td>\n<td>5\u2266w\u22661200<\/td>\n<td>\u0398\u226745\u00b0<\/td>\n<\/tr>\n<tr>\n<td>3.0<\/td>\n<td>10\u2266w\u22661500<\/td>\n<td>\u0398\u226788\u00b0<\/td>\n<\/tr>\n<tr>\n<th rowspan=\"2\">\n<ul>\n \t<li>C1100(\u30bf\u30d5\u30d4\u30c3\u30c1\u9285)<\/li>\n \t<li>C2801P(\u771f\u936e\u30fb\u9ec4\u9285)<\/li>\n<\/ul>\n<\/th>\n<td>1.0 2.0<\/td>\n<td>5\u2266w\u22661500<\/td>\n<td>\u0398\u226745\u00b0<\/td>\n<\/tr>\n<tr>\n<td>3.0<\/td>\n<td>10\u2266w\u22661500<\/td>\n<td>\u0398\u226788\u00b0<\/td>\n<\/tr>\n<tr>\n<th>\u30d1\u30f3\u30c1\u30f3\u30b0\u30e1\u30bf\u30eb\n\u30fc\u4e38\u5b5460\u00b0\u5343\u9ce5\u30bf\u30a4\u30d7\u30fc<\/th>\n<td>0.8 1.0 1.5<\/td>\n<td>30&lt;w\u2266900<\/td>\n<td>\u0398\u226745\u00b0<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\n<\/div>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-1c95842\" data-id=\"1c95842\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-65f1a10 elementor-widget elementor-widget-text-editor\" data-id=\"65f1a10\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p style=\"text-align: center;\">\u90e8\u4f4d\u4f8b<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-b267979 elementor-widget elementor-widget-image\" data-id=\"b267979\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img loading=\"lazy\" decoding=\"async\" width=\"255\" height=\"197\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/fcpl_item_guideline_35.png\" class=\"attachment-large size-large wp-image-3129\" alt=\"\u90e8\u4f4d\u4f8b\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-8e16262 elementor-widget elementor-widget-image\" data-id=\"8e16262\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img loading=\"lazy\" decoding=\"async\" width=\"248\" height=\"181\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/fcpl_item_guideline_36.png\" class=\"attachment-large size-large wp-image-3128\" alt=\"\u90e8\u4f4d\u4f8b\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-1439aff print_page elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"1439aff\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-913e9eb\" data-id=\"913e9eb\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-52979b3 elementor-widget elementor-widget-menu-anchor\" data-id=\"52979b3\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"menu-anchor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t<div class=\"elementor-menu-anchor\" id=\"box_4\"><\/div>\n\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-8b1d861 elementor-widget elementor-widget-heading\" data-id=\"8b1d861\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h4 class=\"elementor-heading-title elementor-size-default\">\u7a74\u3068\u66f2\u3052\u306e\u6700\u5c0f\u8ddd\u96e2\uff1a\u901a\u5e38\u66f2\u3052\u52a0\u5de5<\/h4>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<section class=\"elementor-section elementor-inner-section elementor-element elementor-element-44944da elementor-section-content-middle print_wrap  print_break elementor-reverse-mobile elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"44944da\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-e342bff print_break\" data-id=\"e342bff\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-4268adc elementor-widget elementor-widget-text-editor\" data-id=\"4268adc\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p style=\"text-align: center;\">\u52a0\u5de5\u9650\u754c\u30fb\u5bf8\u6cd5\u7bc4\u56f2<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-3b5ba13 tblBasic print_break elementor-widget elementor-widget-text-editor\" data-id=\"3b5ba13\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p style=\"text-align: center;\">\u52a0\u5de5\u9650\u754c\u306e\u8003\u3048\u65b9\u306e\u8a73\u7d30\u306f<a href=\"\/help\/ja\/technical_info\/shm_guideline\/3467\/\">\u3053\u3061\u3089<\/a><\/p>\n\n<div>\n<div class=\"tableStickyHead\">\n<table class=\"table05 min tableHover mT0 print_break\" style=\"word-break: break-word;\">\n<thead>\n<tr style=\"height: 24px;\">\n<th style=\"width: 15%;\" rowspan=\"3\">\u6750\u8cea<\/th>\n<th style=\"width: 8%;\" rowspan=\"3\">\u677f\u539a<\/th>\n<th colspan=\"5\">\u7a74\u7a2e(\u4e00\u822c\u516c\u5dee\u6642) \u203b1<\/th>\n<th>\u7a74\u7a2e(\u00b10.2mm\u4ee5\u4e0a\u516c\u5dee\u8a2d\u5b9a\u6642)<\/th>\n<\/tr>\n<tr>\n<th colspan=\"2\">\u901a\u3057\u7a74 \u9577\u7a74\u3000\u89d2\u7a74\u3000\u76bf\u7a74<\/th>\n<th colspan=\"2\">\u30bf\u30c3\u30d7\u7a74<\/th>\n<th>\u30d0\u30fc\u30ea\u30f3\u30b0\u30bf\u30c3\u30d7<\/th>\n<th>\u901a\u3057\u7a74<\/th>\n<\/tr>\n<tr>\n<th>\u4fdd\u8a3c\u5024<span style=\"color: red;\">a<\/span><\/th>\n<th>\u9650\u754c\u5024<span style=\"color: red;\">a<\/span><\/th>\n<th>\u4fdd\u8a3c\u5024<span style=\"color: red;\">a<\/span><\/th>\n<th>\u9650\u754c\u5024<span style=\"color: red;\">a<\/span><\/th>\n<th>\u9650\u754c\u5024<span style=\"color: red;\">a<\/span><\/th>\n<th>\u9650\u754c\u5024<span style=\"color: red;\">a<\/span> \u203b2<\/th>\n<\/tr>\n<\/thead>\n<\/table>\n<\/div>\n<table class=\"table05 min tableHover mT0\" style=\"word-break: break-word;\">\n<tbody>\n<tr>\n<th style=\"width: 15%;\" rowspan=\"13\">\n<ul>\n \t<li>SPCC\/SPHC<\/li>\n \t<li>SS400<\/li>\n<\/ul>\n<\/th>\n<td style=\"width: 8%;\">0.8<\/td>\n<td>4.2<\/td>\n<td>1.6<\/td>\n<td>\u2013<\/td>\n<td>\u2013<\/td>\n<td>4.2<\/td>\n<td>4.2<\/td>\n<\/tr>\n<tr><td>1.0<\/td><td>4.3<\/td><td>2.0<\/td><td>4.8<\/td><td>2.0<\/td><td>4.3<\/td><td>4.3<\/td><\/tr>\n<tr><td>1.2<\/td><td>5.5<\/td><td>2.5<\/td><td>6.0<\/td><td>2.5<\/td><td>5.5<\/td><td>5.5<\/td><\/tr>\n<tr><td>1.6<\/td><td>6.8<\/td><td>3.3<\/td><td>7.3<\/td><td>3.3<\/td><td>6.8<\/td><td>6.8<\/td><\/tr>\n<tr><td>2.0<\/td><td>8.0<\/td><td>4.0<\/td><td>8.7<\/td><td>4.0<\/td><td rowspan='9'>\u2013<\/td><td>8.0<\/td><\/tr>\n<tr><td>2.3<\/td><td>9.3<\/td><td>4.7<\/td><td>9.9<\/td><td>4.7<\/td><td>9.3<\/td><\/tr>\n<tr><td>3.2<\/td><td>13.3<\/td><td>6.5<\/td><td>13.8<\/td><td>6.5<\/td><td>13.3<\/td><\/tr>\n<tr><td>4.5<\/td><td>17.4<\/td><td>9.2<\/td><td>18.4<\/td><td>9.2<\/td><td>17.4<\/td><\/tr>\n<tr><td>6.0<\/td><td>23.5<\/td><td>12.3<\/td><td>24.5<\/td><td>12.3<\/td><td rowspan='5'>\u2013<\/td><\/tr>\n<tr><td>9.0<\/td><td>33.5<\/td><td>18.5<\/td><td>34.5<\/td><td>18.5<\/td><\/tr>\n<tr><td>10.0<\/td><td>48.5<\/td><td>20.5<\/td><td>47.5<\/td><td>20.5<\/td><\/tr>\n<tr><td>12.0<\/td><td>62.0<\/td><td>24.6<\/td><td>63.0<\/td><td>24.6<\/td><\/tr>\n<tr><td>16.0<\/td><td>88.5<\/td><td>32.8<\/td><td>89.5<\/td><td>32.8<\/td><\/tr>\n\n<tr>\n<th rowspan=\"7\">SECC<\/th>\n<td>0.8<\/td><td>4.2<\/td><td>1.6<\/td><td>\u2013<\/td><td>\u2013<\/td><td>4.2<\/td><td rowspan='7'>\u2013<\/td><\/tr>\n<tr><td>1.0<\/td><td>4.3<\/td><td>2.0<\/td><td>5.3<\/td><td>2.0<\/td><td>4.3<\/td><\/tr>\n<tr><td>1.2<\/td><td>4.5<\/td><td>2.5<\/td><td>5.5<\/td><td>2.5<\/td><td>4.5<\/td><\/tr>\n<tr><td>1.6<\/td><td>5.8<\/td><td>3.3<\/td><td>6.8<\/td><td>3.3<\/td><td>5.8<\/td><\/tr>\n<tr><td>2.0<\/td><td>7.0<\/td><td>4.0<\/td><td>8.0<\/td><td>4.0<\/td><td rowspan='3'>\u2013<\/td><\/tr>\n<tr><td>2.3<\/td><td>8.3<\/td><td>4.7<\/td><td>9.3<\/td><td>4.7<\/td><\/tr>\n<tr><td>3.2<\/td><td>11.1<\/td><td>6.5<\/td><td>12.1<\/td><td>6.5<\/td><\/tr>\n\n<tr>\n<th rowspan=\"13\">\n<ul>\n \t<li>SUS304(No.1)<\/li>\n \t<li>SUS304(2B)<\/li>\n \t<li>SUS304(2B) \u7247\u9762\u4fdd\u8b77\u30b7\u30fc\u30c8\u4ed8<\/li>\n \t<li>SUS304(\u7247\u9762#400\u7814\u78e8)<\/li>\n \t<li>SUS304(\u7247\u9762\u30d8\u30a2\u30e9\u30a4\u30f3)<\/li>\n \t<li>SUS316(2B)<\/li>\n \t<li>SUS430(2B)<\/li>\n<\/ul>\n<\/th>\n<td>0.8<\/td><td>4.2<\/td><td>1.6<\/td><td>\u2013<\/td><td>\u2013<\/td><td>4.2<\/td><td>4.2<\/td><\/tr>\n<tr><td>1.0<\/td><td>4.3<\/td><td>2.0<\/td><td>5.3<\/td><td>2.1<\/td><td>4.3<\/td><td>4.3<\/td><\/tr>\n<tr><td>1.2<\/td><td>4.5<\/td><td>2.5<\/td><td>5.5<\/td><td>2.5<\/td><td>4.5<\/td><td>4.5<\/td><\/tr>\n<tr><td>1.5<\/td><td>6.0<\/td><td>3.1<\/td><td>7.0<\/td><td>3.1<\/td><td>6.0<\/td><td>6.0<\/td><\/tr>\n<tr><td>2.0<\/td><td>7.1<\/td><td>4.0<\/td><td>8.1<\/td><td>4.0<\/td><td rowspan='9'>\u2013<\/td><td>7.1<\/td><\/tr>\n<tr><td>2.5<\/td><td>11.3<\/td><td>5.1<\/td><td>12.3<\/td><td>5.1<\/td><td>11.3<\/td><\/tr>\n<tr><td>3.0<\/td><td>11.5<\/td><td>6.2<\/td><td>12.5<\/td><td>6.2<\/td><td>11.5<\/td><\/tr>\n<tr><td>4.0<\/td><td>17.2<\/td><td>8.2<\/td><td>18.2<\/td><td>8.2<\/td><td>17.2<\/td><\/tr>\n<tr><td>5.0<\/td><td>23.5<\/td><td>10.3<\/td><td>24.5<\/td><td>10.3<\/td><td>23.5<\/td><\/tr>\n<tr><td>6.0<\/td><td>25.0<\/td><td>12.3<\/td><td>26.0<\/td><td>12.3<\/td><td>25.0<\/td><\/tr>\n<tr><td>9.0<\/td><td>39.0<\/td><td>18.5<\/td><td>40.0<\/td><td>18.5<\/td><td rowspan='3'>\u2013<\/td><\/tr>\n<tr><td>10.0<\/td><td>46.5<\/td><td>20.5<\/td><td>47.5<\/td><td>20.5<\/td><\/tr>\n<tr><td>12.0<\/td><td>62.0<\/td><td>24.6<\/td><td>63.0<\/td><td>24.6<\/td><\/tr>\n\n<tr>\n<th rowspan=\"11\">\n<ul>\n \t<li>A5052<\/li>\n \t<li>A5052(\u30a2\u30eb\u30de\u30a4\u30c8\u92fc\u677f\u767d)<\/li>\n \t<li>A5052(\u30a2\u30eb\u30de\u30a4\u30c8\u92fc\u677f\u9ed2)<\/li>\n<\/ul>\n<\/th>\n<td>0.8<\/td><td>4.2<\/td><td>1.6<\/td><td>\u2013<\/td><td>1.6<\/td><td>4.2<\/td><td rowspan='11'>\u2013<\/td><\/tr>\n<tr><td>1.0<\/td><td>4.3<\/td><td>2.0<\/td><td>5.2<\/td><td>2.0<\/td><td>4.3<\/td><\/tr>\n<tr><td>1.2<\/td><td>5.5<\/td><td>2.5<\/td><td>5.5<\/td><td>2.5<\/td><td>5.5<\/td><\/tr>\n<tr><td>1.5<\/td><td>6.0<\/td><td>3.1<\/td><td>7.0<\/td><td>3.1<\/td><td>6.0<\/td><\/tr>\n<tr><td>1.6<\/td><td>6.0<\/td><td>3.3<\/td><td>7.0<\/td><td>3.3<\/td><td>6.0<\/td><\/tr>\n<tr><td>2.0<\/td><td>8.2<\/td><td>4.0<\/td><td>8.2<\/td><td>4.0<\/td><td rowspan='6'>\u2013<\/td><\/tr>\n<tr><td>2.5<\/td><td>10.0<\/td><td>5.1<\/td><td>11.0<\/td><td>5.1<\/td><\/tr>\n<tr><td>3.0<\/td><td>13.3<\/td><td>6.2<\/td><td>13.3<\/td><td>6.2<\/td><\/tr>\n<tr><td>4.0<\/td><td>17.2<\/td><td>8.2<\/td><td>18.2<\/td><td>8.2<\/td><\/tr>\n<tr><td>5.0<\/td><td>27.0<\/td><td>10.3<\/td><td>27.0<\/td><td>10.3<\/td><\/tr>\n<tr><td>6.0<\/td><td>28.0<\/td><td>12.3<\/td><td>28.0<\/td><td>12.3<\/td><\/tr>\n\n<tr>\n<th rowspan=\"4\">\n<ul>\n \t<li>C1020(\u7121\u9178\u7d20\u9285)<\/li>\n \t<li>C1100(\u30bf\u30d5\u30d4\u30c3\u30c1\u9285)<\/li>\n \t<li>C2801P(\u771f\u936e\u30fb\u9ec4\u9285)<\/li>\n<\/ul>\n<\/th>\n<td>1.0<\/td><td>4.3<\/td><td>2.0<\/td><td>5.2<\/td><td>2.0<\/td><td>4.3<\/td><td rowspan='4'>\u2013<\/td><\/tr>\n<tr><td>1.5<\/td><td>6.0<\/td><td>3.1<\/td><td>7.0<\/td><td>3.1<\/td><td>6.0<\/td><\/tr>\n<tr><td>2.0<\/td><td>7.1<\/td><td>4.0<\/td><td>8.1<\/td><td>4.0<\/td><td rowspan='2'>\u2013<\/td><\/tr>\n<tr><td>3.0<\/td><td>11.5<\/td><td>6.2<\/td><td>12.5<\/td><td>6.2<\/td><\/tr>\n\n<tr>\n<th rowspan=\"3\">\n<ul>\n \t<li>\u30d1\u30f3\u30c1\u30f3\u30b0\u30e1\u30bf\u30eb<\/li>\n \t<li>-\u4e38\u5b5460\u00b0\u5343\u9ce5\u30bf\u30a4\u30d7-<\/li>\n<\/ul>\n<\/th>\n<td>0.8<\/td><td>4.2<\/td><td>1.6<\/td><td rowspan='3'>\u2013<\/td><td rowspan='3'>\u2013<\/td><td rowspan='3'>\u2013<\/td><td rowspan='3'>\u2013<\/td><\/tr>\n<tr><td>1.0<\/td><td>4.3<\/td><td>2.0<\/td><\/tr>\n<tr><td>1.5<\/td><td>6.0<\/td><td>3.1<\/td><\/tr>\n\n<\/tbody>\n<\/table>\n<\/div>\n<ul style=\"margin-top: 10px; text-align: left;\">\n \t<li>\u203b1 \u4fdd\u8a3c\u5024\u3092\u4e0b\u56de\u3063\u305f\u5834\u5408\u3001\u7a74\u304c\u5909\u5f62\u3059\u308b\u6050\u308c\u304c\u3042\u308a\u307e\u3059\u3002\u30bf\u30c3\u30d7\u7a74\u306f\u30ea\u30bf\u30c3\u30d7\u52a0\u5de5\u3068\u306a\u308a\u3001\u904a\u3073\u304c\u751f\u3058\u308b\u6050\u308c\u304c\u3042\u308a\u307e\u3059\u3002\u305d\u306e\u4ed6\u306e\u7a74\u306f\u5bf8\u6cd5\u3082\u4e0d\u6b63\u78ba\u306b\u306a\u308a\u307e\u3059\u304c\u3001\u305d\u306e\u307e\u307e\u52a0\u5de5\u3044\u305f\u3057\u307e\u3059\u3002<\/li>\n \t<li>\u203b2 \u30b9\u30c6\u30f3\u30ec\u30b9\u306fSUS304(2B)\u3001SUS430(2B)\u306e\u307f\u5bfe\u8c61\u3067\u3059\u3002<\/li>\n<\/ul>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-a29c71b\" data-id=\"a29c71b\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-9761e21 elementor-widget elementor-widget-text-editor\" data-id=\"9761e21\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p style=\"text-align: center;\">\u90e8\u4f4d\u4f8b<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-397271c tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"397271c\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"mT0\">\n<tbody>\n<tr>\n<td>\u901a\u3057\u7a74\u30fb\u9577\u7a74\u30fb\u89d2\u7a74\u30fb\u30bf\u30c3\u30d7\u7a74\u306e\u6642<\/td>\n<\/tr>\n<tr>\n<td>\n<span class=\"enlarged\"><img decoding=\"async\" style=\"width: 70%; max-width: 200px;\" src=\"\/help\/ja\/wp-content\/uploads\/2026\/06\/3474_18-01.png\" \/><\/span><\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-c18e855 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"c18e855\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table>\n<tbody>\n<tr>\n<td>\u30d0\u30fc\u30ea\u30f3\u30b0\u30bf\u30c3\u30d7\u30fb\u76bf\u7a74\u306e\u6642<\/td>\n<\/tr>\n<tr>\n<td>\n<span class=\"enlarged\"><img decoding=\"async\" style=\"width: 70%; max-width: 200px;\" src=\"\/help\/ja\/wp-content\/uploads\/2026\/06\/3474_18-02.png\" \/><\/span><\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-5c7813d elementor-widget elementor-widget-text-editor\" data-id=\"5c7813d\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\u5185\u89d290\u00b0\u672a\u6e80\u306e\u92ed\u89d2\u66f2\u3052\u5f62\u72b6\u306e\u5834\u5408\u3001\u4fdd\u8a3c\u5024\u7bc4\u56f2\u5185\u3067\u3042\u3063\u3066\u3082\u52a0\u5de5\u4e0d\u53ef\u306b\u306a\u308b\u3053\u3068\u304c\u3042\u308a\u307e\u3059\u3002\u305d\u306e\u5834\u5408\u5f0a\u793e\u3088\u308a\u3054\u9023\u7d61\u81f4\u3057\u307e\u3059\u3002\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-7736a64 enlarged elementor-widget elementor-widget-image\" data-id=\"7736a64\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img loading=\"lazy\" decoding=\"async\" width=\"470\" height=\"290\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2025\/11\/3474_16.png\" class=\"attachment-full size-full wp-image-36606\" alt=\"\" srcset=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2025\/11\/3474_16.png 470w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2025\/11\/3474_16-300x185.png 300w\" sizes=\"(max-width: 470px) 100vw, 470px\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-ae8cb7d print_page elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"ae8cb7d\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-bd06cec\" data-id=\"bd06cec\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-b93eeb7 elementor-widget elementor-widget-menu-anchor\" data-id=\"b93eeb7\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"menu-anchor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t<div class=\"elementor-menu-anchor\" id=\"box_4-1\"><\/div>\n\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-df6e47d elementor-widget elementor-widget-heading\" data-id=\"df6e47d\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h4 class=\"elementor-heading-title elementor-size-default\">\u7a74\u3068\u66f2\u3052\u306e\u6700\u5c0f\u8ddd\u96e2\uff1aR\u66f2\u3052\u5f62\u72b6<\/h4>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<section class=\"elementor-section elementor-inner-section elementor-element elementor-element-29d8aea elementor-section-content-middle print_wrap  print_break elementor-reverse-mobile elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"29d8aea\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-0a7f141 print_break\" data-id=\"0a7f141\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-c7565fc elementor-widget elementor-widget-text-editor\" data-id=\"c7565fc\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p style=\"text-align: center;\">\u52a0\u5de5\u9650\u754c\u30fb\u5bf8\u6cd5\u7bc4\u56f2<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-4dc5c4a tblBasic print_break elementor-widget elementor-widget-text-editor\" data-id=\"4dc5c4a\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<div>\n<div class=\"tableStickyHead\">\n<table class=\"table05 min tableHover mT0 print_break\" style=\"word-break: break-word;\">\n<thead>\n<tr style=\"height: 24px;\">\n<th style=\"width: 15%;\" rowspan=\"3\">\u6750\u8cea<\/th>\n<th style=\"width: 8%;\" rowspan=\"3\">\u677f\u539a<\/th>\n<th colspan=\"5\">\u7a74\u7a2e(\u4e00\u822c\u516c\u5dee\u6642) \u203b1<\/th>\n<th>\u7a74\u7a2e(\u00b10.2mm\u4ee5\u4e0a\u516c\u5dee\u8a2d\u5b9a\u6642)<\/th>\n<\/tr>\n<tr>\n<th colspan=\"2\">\u901a\u3057\u7a74 \u9577\u7a74 \u89d2\u7a74 \u76bf\u7a74<\/th>\n<th colspan=\"2\">\u30bf\u30c3\u30d7\u7a74<\/th>\n<th>\u30d0\u30fc\u30ea\u30f3\u30b0\u30bf\u30c3\u30d7<\/th>\n<th>\u901a\u3057\u7a74<\/th>\n<\/tr>\n<tr>\n<th>\u4fdd\u8a3c\u5024<span style=\"color: red;\">a<\/span><\/th>\n<th>\u9650\u754c\u5024<span style=\"color: red;\">a<\/span><\/th>\n<th>\u4fdd\u8a3c\u5024<span style=\"color: red;\">a<\/span><\/th>\n<th>\u9650\u754c\u5024<span style=\"color: red;\">a<\/span><\/th>\n<th>\u9650\u754c\u5024<span style=\"color: red;\">a<\/span><\/th>\n<th>\u9650\u754c\u5024<span style=\"color: red;\">a<\/span> \u203b2<\/th>\n<\/tr>\n<\/thead>\n<\/table>\n<\/div>\n<table class=\"table05 min tableHover mT0\" style=\"word-break: break-word;\">\n<tbody>\n<tr>\n<th style=\"width: 15%;\" rowspan=\"7\">\n<ul>\n \t<li>SPCC\/SPHC<\/li>\n \t<li>SS400<\/li>\n<\/ul>\n<td style=\"width: 8%;\">0.8<\/td><td>2.6<\/td><td>0.1<\/td><td>\u2013<\/td><td>\u2013<\/td><td>2.6<\/td><td>3.0<\/td><\/tr>\n<tr><td>1.0<\/td><td>2.3<\/td><td>0.1<\/td><td>2.8<\/td><td>0.1<\/td><td>2.3<\/td><td>3.0<\/td><\/tr>\n<tr><td>1.2<\/td><td>3.1<\/td><td>0.1<\/td><td>3.6<\/td><td>0.1<\/td><td>3.1<\/td><td>4.0<\/td><\/tr>\n<tr><td>1.6<\/td><td>3.6<\/td><td>0.1<\/td><td>4.1<\/td><td>0.1<\/td><td>3.6<\/td><td>5.0<\/td><\/tr>\n<tr><td>2.0<\/td><td>4.0<\/td><td>0.1<\/td><td>4.7<\/td><td>0.1<\/td><td rowspan='3'>\u2013<\/td><td>6.0<\/td><\/tr>\n<tr><td>2.3<\/td><td>4.7<\/td><td>0.1<\/td><td>5.3<\/td><td>0.1<\/td><td>7.0<\/td><\/tr>\n<tr><td>3.2<\/td><td>6.9<\/td><td>0.1<\/td><td>7.4<\/td><td>0.1<\/td><td>9.0<\/td><\/tr>\n\n<tr style=\"height: 24px;\">\n<th rowspan=\"7\">SECC<\/th>\n<td>0.8<\/td><td>2.6<\/td><td>0.1<\/td><td>\u2013<\/td><td>\u2013<\/td><td>2.6<\/td><td rowspan='7'>\u2013<\/td><\/tr>\n<tr><td>1.0<\/td><td>2.3<\/td><td>0.1<\/td><td>3.3<\/td><td>0.1<\/td><td>2.3<\/td><\/tr>\n<tr><td>1.2<\/td><td>2.1<\/td><td>0.1<\/td><td>3.1<\/td><td>0.1<\/td><td>2.1<\/td><\/tr>\n<tr><td>1.6<\/td><td>2.6<\/td><td>0.1<\/td><td>3.6<\/td><td>0.1<\/td><td>2.6<\/td><\/tr>\n<tr><td>2.0<\/td><td>3.0<\/td><td>0.1<\/td><td>4.0<\/td><td>0.1<\/td><td rowspan='3'>\u2013<\/td><\/tr>\n<tr><td>2.3<\/td><td>3.7<\/td><td>0.1<\/td><td>4.7<\/td><td>0.1<\/td><\/tr>\n<tr><td>3.2<\/td><td>4.7<\/td><td>0.1<\/td><td>5.7<\/td><td>0.1<\/td><\/tr>\n\n<tr>\n<th rowspan=\"7\">\n<ul>\n \t<li>SUS304(2B)<\/li>\n \t<li>SUS304(\u7247\u9762#400\u7814\u78e8)<\/li>\n \t<li>SUS430(2B)<\/li>\n<\/ul>\n<\/th>\n<td>0.8<\/td><td>2.6<\/td><td>0.1<\/td><td>\u2013<\/td><td>\u2013<\/td><td>2.6<\/td><td>3.0<\/td><\/tr>\n<tr><td>1.0<\/td><td>2.3<\/td><td>0.1<\/td><td>3.3<\/td><td>0.1<\/td><td>2.3<\/td><td>3.0<\/td><\/tr>\n<tr><td>1.2<\/td><td>2.1<\/td><td>0.1<\/td><td>3.1<\/td><td>0.1<\/td><td>2.1<\/td><td>4.0<\/td><\/tr>\n<tr><td>1.5<\/td><td>3.0<\/td><td>0.1<\/td><td>4.0<\/td><td>0.1<\/td><td>3.0<\/td><td>5.0<\/td><\/tr>\n<tr><td>2.0<\/td><td>3.1<\/td><td>0.1<\/td><td>4.1<\/td><td>0.1<\/td><td rowspan='3'>\u2013<\/td><td>6.0<\/td><\/tr>\n<tr><td>2.5<\/td><td>6.3<\/td><td>0.1<\/td><td>7.3<\/td><td>0.1<\/td><td>7.0<\/td><\/tr>\n<tr><td>3.0<\/td><td>5.5<\/td><td>0.1<\/td><td>6.5<\/td><td>0.1<\/td><td>9.0<\/td><\/tr>\n\n<tr>\n<th style=\"height: 184px;\" rowspan=\"8\">\n<ul>\n \t<li>A5052<\/li>\n \t<li>A5052(\u30a2\u30eb\u30de\u30a4\u30c8\u92fc\u677f\u767d)<\/li>\n \t<li>A5052(\u30a2\u30eb\u30de\u30a4\u30c8\u92fc\u677f\u9ed2)<\/li>\n<\/ul>\n<\/th>\n<td>0.8<\/td><td>2.6<\/td><td>0.1<\/td><td>\u2013<\/td><td>\u2013<\/td><td>2.6<\/td><td rowspan='8'>\u2013<\/td><\/tr>\n<tr><td>1.0<\/td><td>2.3<\/td><td>0.1<\/td><td>3.2<\/td><td>0.1<\/td><td>2.3<\/td><\/tr>\n<tr><td>1.2<\/td><td>3.1<\/td><td>0.1<\/td><td>3.1<\/td><td>0.1<\/td><td>3.1<\/td><\/tr>\n<tr><td>1.5<\/td><td>3.0<\/td><td>0.1<\/td><td>4.0<\/td><td>0.1<\/td><td>3.0<\/td><\/tr>\n<tr><td>1.6<\/td><td>2.8<\/td><td>0.1<\/td><td>3.8<\/td><td>0.1<\/td><td>2.8<\/td><\/tr>\n<tr><td>2.0<\/td><td>4.2<\/td><td>0.1<\/td><td>4.2<\/td><td>0.1<\/td><td rowspan='3'>\u2013<\/td><\/tr>\n<tr><td>2.5<\/td><td>5.0<\/td><td>0.1<\/td><td>6.0<\/td><td>0.1<\/td><\/tr>\n<tr><td>3.0<\/td><td>7.3<\/td><td>0.1<\/td><td>7.3<\/td><td>0.1<\/td><\/tr>\n\n<tr>\n<th rowspan=\"4\">\n<ul>\n \t<li>C1020(\u7121\u9178\u7d20\u9285)<\/li>\n \t<li>C1100(\u30bf\u30d5\u30d4\u30c3\u30c1\u9285)<\/li>\n \t<li>C2801P(\u771f\u936e\u30fb\u9ec4\u9285)<\/li>\n<\/ul>\n<\/th>\n<td>1.0<\/td><td>2.3<\/td><td>0.1<\/td><td>3.2<\/td><td>0.1<\/td><td>2.3<\/td><td rowspan='4'>\u2013<\/td><\/tr>\n<tr><td>1.5<\/td><td>3.0<\/td><td>0.1<\/td><td>4.0<\/td><td>0.1<\/td><td>3.0<\/td><\/tr>\n<tr><td>2.0<\/td><td>3.1<\/td><td>0.1<\/td><td>4.1<\/td><td>0.1<\/td><td rowspan='2'>\u2013<\/td><\/tr>\n<tr><td>3.0<\/td><td>5.5<\/td><td>0.1<\/td><td>6.5<\/td><td>0.1<\/td><\/tr>\n\n<tr>\n<th rowspan=\"3\">\u30d1\u30f3\u30c1\u30f3\u30b0\u30e1\u30bf\u30eb\n-\u4e38\u5b5460\u00b0\u5343\u9ce5\u30bf\u30a4\u30d7-<\/th>\n<td>0.8<\/td><td>2.6<\/td><td>0.1<\/td><td rowspan='3'>\u2013<\/td><td rowspan='3'>\u2013<\/td><td rowspan='3'>\u2013<\/td><td rowspan='3'>\u2013<\/td><\/tr>\n<tr><td>1.0<\/td><td>2.3<\/td><td>0.1<\/td><\/tr>\n<tr><td>1.5<\/td><td>3.0<\/td><td>0.1<\/td><\/tr>\n\n<\/tbody>\n<\/table>\n<\/div>\n<ul style=\"margin-top: 10px; text-align: left;\">\n \t<li>\u203b1 \u4fdd\u8a3c\u5024\u3092\u4e0b\u56de\u3063\u305f\u5834\u5408\u3001\u7a74\u304c\u5909\u5f62\u3059\u308b\u6050\u308c\u304c\u3042\u308a\u307e\u3059\u3002\u30bf\u30c3\u30d7\u7a74\u306f\u30ea\u30bf\u30c3\u30d7\u52a0\u5de5\u3068\u306a\u308a\u3001\u904a\u3073\u304c\u751f\u3058\u308b\u6050\u308c\u304c\u3042\u308a\u307e\u3059\u3002\u305d\u306e\u4ed6\u306e\u7a74\u306f\u5bf8\u6cd5\u3082\u4e0d\u6b63\u78ba\u306b\u306a\u308a\u307e\u3059\u304c\u3001\u305d\u306e\u307e\u307e\u52a0\u5de5\u3044\u305f\u3057\u307e\u3059\u3002<\/li>\n \t<li>\u203b2 \u30b9\u30c6\u30f3\u30ec\u30b9\u306fSUS304(2B)\u3001SUS430(2B)\u306e\u307f\u5bfe\u8c61\u3067\u3059\u3002<\/li>\n<\/ul>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-7869b25\" data-id=\"7869b25\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-f13d058 elementor-widget elementor-widget-text-editor\" data-id=\"f13d058\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p style=\"text-align: center;\">\u90e8\u4f4d\u4f8b<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-7bec109 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"7bec109\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"mT0\">\n<tbody>\n<tr>\n<td>\u901a\u3057\u7a74\u30fb\u9577\u7a74\u30fb\u89d2\u7a74\u30fb\u30bf\u30c3\u30d7\u7a74\u306e\u6642<\/td>\n<\/tr>\n<tr>\n<td>\n<span class=\"enlarged\"><img decoding=\"async\" style=\"width: 70%; max-width: 200px;\" src=\"\/help\/ja\/wp-content\/uploads\/2026\/06\/3474_01-01.png\" \/><\/span><\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-07ceb4b tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"07ceb4b\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table>\n<tbody>\n<tr>\n<td>\u30d0\u30fc\u30ea\u30f3\u30b0\u30bf\u30c3\u30d7\u30fb\u76bf\u7a74\u306e\u6642<\/td>\n<\/tr>\n<tr>\n<td>\n<span class=\"enlarged\"><img decoding=\"async\" style=\"width: 70%; max-width: 200px;\" src=\"\/help\/ja\/wp-content\/uploads\/2026\/06\/3474_01-02.png\" \/><\/span><\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-0bf7a3a enlarged elementor-widget elementor-widget-image\" data-id=\"0bf7a3a\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img loading=\"lazy\" decoding=\"async\" width=\"470\" height=\"290\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2025\/11\/3474_17.png\" class=\"attachment-full size-full wp-image-36608\" alt=\"\" srcset=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2025\/11\/3474_17.png 470w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2025\/11\/3474_17-300x185.png 300w\" sizes=\"(max-width: 470px) 100vw, 470px\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-544d1d6 print_page elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"544d1d6\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-28666cd\" data-id=\"28666cd\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-56fab99 elementor-widget elementor-widget-menu-anchor\" data-id=\"56fab99\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"menu-anchor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t<div class=\"elementor-menu-anchor\" id=\"box_10\"><\/div>\n\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-faa7750 elementor-widget elementor-widget-heading\" data-id=\"faa7750\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h4 class=\"elementor-heading-title elementor-size-default\">\u66f2\u3052\u7dda\u4e0a\u306e\u958b\u53e3\u90e8 (\u5185\u89d290\u00b0\u672a\u6e80\u306e\u92ed\u89d2\u66f2\u3052\u5f62\u72b6\u3092\u9664\u304f)<\/h4>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<section class=\"elementor-section elementor-inner-section elementor-element elementor-element-71f01e4 elementor-section-content-middle print_wrap  print_break elementor-reverse-mobile elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"71f01e4\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-efab604 print_break\" data-id=\"efab604\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-473a83b elementor-widget elementor-widget-text-editor\" data-id=\"473a83b\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p style=\"text-align: center;\">\u52a0\u5de5\u9650\u754c\u30fb\u5bf8\u6cd5\u7bc4\u56f2<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-0ff4994 tblBasic print_break elementor-widget elementor-widget-text-editor\" data-id=\"0ff4994\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<div class=\"print_block\">\n\n&nbsp;\n<div class=\"tableStickyHead\">\n<table class=\"table05 min fixed alignleft tableHover mT0\">\n<thead>\n<tr style=\"height: 20px;\">\n<th colspan=\"4\">\u677f\u539a<\/th>\n<th rowspan=\"2\">\u6700\u5c0f\u5024<span style=\"color: #d8352a;\">a <\/span>\u203b1<\/th>\n<th rowspan=\"2\">\u6700\u5c0f\u5024<span style=\"color: #d8352a;\">b <\/span>\u203b2<\/th>\n<th rowspan=\"2\">\u9650\u754c\u5024<span style=\"color: #d8352a;\">c<\/span><\/th>\n<\/tr>\n<tr>\n<th>\n<ul>\n<li>SPCC(SPHC)<\/li>\n<li>SS400<\/li>\n<li>SECC<\/li>\n<\/ul>\n<\/th>\n<th>\n<ul>\n \t<li>SUS304<\/li>\n<li>SUS316<\/li>\n<li>SUS430<\/li>\n<\/ul>\n<\/th>\n<th>\n<ul>\n \t<li>A5052<\/li>\n<li>A5052(\u30a2\u30eb\u30de\u30a4\u30c8\u92fc\u677f\u767d\u30fb\u9ed2)<\/li>\n<\/ul>\n<\/th>\n<th>\n<ul>\n \t<li>C1020<\/li>\n<li>C1100<\/li>\n<li>C2801P<\/li>\n<\/ul>\n<\/th>\n<\/tr>\n<\/thead>\n<\/table>\n<\/div>\n<table class=\"table05 min fixed alignleft tableHover mT0\">\n<tbody>\n<tr><td>0.8<\/td><td>0.8<\/td><td>0.8<\/td><td>\u2013<\/td><td>0.8<\/td><td>1.2<\/td><td rowspan='2'>0.5<\/td><\/tr>\n<tr><td>1.0<\/td><td>1.0<\/td><td>1.0<\/td><td>1.0<\/td><td>1.0<\/td><td>1.5<\/td><\/tr>\n<tr><td>1.2<\/td><td>1.2<\/td><td>1.2<\/td><td>\u2013<\/td><td>1.2<\/td><td>1.8<\/td><td>0.6<\/td><\/tr>\n<tr><td>\u2013<\/td><td>1.5<\/td><td>1.5<\/td><td>1.5<\/td><td>1.5<\/td><td>2.3<\/td><td>0.7<\/td><\/tr>\n<tr><td>1.6<\/td><td>\u2013<\/td><td>1.6<\/td><td>\u2013<\/td><td>1.6<\/td><td>2.4<\/td><td>0.8<\/td><\/tr>\n<tr><td>2.0<\/td><td>2.0<\/td><td>2.0<\/td><td>2.0<\/td><td>2.0<\/td><td>3.0<\/td><td rowspan='2'>1.0<\/td><\/tr>\n<tr><td>2.3<\/td><td>\u2013<\/td><td>\u2013<\/td><td>\u2013<\/td><td>2.3<\/td><td>3.5<\/td><\/tr>\n<tr><td>\u2013<\/td><td>2.5<\/td><td>2.5<\/td><td>\u2013<\/td><td>2.5<\/td><td>3.8<\/td><td>1.2<\/td><\/tr>\n<tr><td>\u2013<\/td><td>3.0<\/td><td>3.0<\/td><td>3.0<\/td><td>3.0<\/td><td>4.5<\/td><td rowspan='2'>1.5<\/td><\/tr>\n<tr><td>3.2<\/td><td>\u2013<\/td><td>\u2013<\/td><td rowspan='9'>\u2013<\/td><td>3.2<\/td><td>4.8<\/td><\/tr>\n<tr><td>\u2013<\/td><td>4.0<\/td><td>4.0<\/td><td>4.0<\/td><td>6.0<\/td><td>2.0<\/td><\/tr>\n<tr><td>4.5<\/td><td>\u2013<\/td><td>\u2013<\/td><td>4.5<\/td><td>6.7<\/td><td>2.2<\/td><\/tr>\n<tr><td>\u2013<\/td><td>5.0<\/td><td>5.0<\/td><td>5.0<\/td><td>7.5<\/td><td>2.5<\/td><\/tr>\n<tr><td>6.0<\/td><td>6.0<\/td><td>6.0<\/td><td>6.0<\/td><td>9.0<\/td><td>3.0<\/td><\/tr>\n<tr><td>9.0<\/td><td>9.0<\/td><td rowspan='4'>\u2013<\/td><td>9.0<\/td><td>13.5<\/td><td>4.0<\/td><\/tr>\n<tr><td>10.0<\/td><td>10.0<\/td><td>10.0<\/td><td>15.0<\/td><td>5.0<\/td><\/tr>\n<tr><td>12.0<\/td><td>12.0<\/td><td>12.0<\/td><td>18.0<\/td><td>6.0<\/td><\/tr>\n<tr><td>16.0<\/td><td>\u2013<\/td><td>16.0<\/td><td>24.0<\/td><td>8.0<\/td><\/tr>\n\n<\/tbody>\n<\/table>\n<\/div>\n<ul style=\"text-align: left; margin-top: 10px;\">\n \t<li>\u203b1 \u958b\u53e3\u90e8\u6a2a\u5e45\u3067<span style=\"color: #d8352a;\">a<\/span>\u304c\u78ba\u4fdd\u3055\u308c\u306a\u3044\u6642\u3001\u307e\u305f\u306f\u92ed\u89d2\u66f2\u3052\u3067\u3042\u308b\u6642\u3082\u304a\u898b\u7a4d\u3082\u308a\u306f\u53ef\u80fd\u3067\u3059\u304c\u3001\u9650\u754c\u5024<span style=\"color: #d8352a;\">c<\/span>\u306e\u4ee3\u308f\u308a\u306b\u524d\u8ff0\u306e\u300c\u7a74\u3068\u66f2\u3052\u306e\u6700\u5c0f\u8ddd\u96e2\u300d\u304c\u7a74\u4f4d\u7f6e\u306e\u9650\u754c\u5024\u3068\u306a\u308a\u307e\u3059\u3002<a href=\"#box_4\">\u901a\u5e38\u66f2\u3052\u52a0\u5de5\u306f\u3053\u3061\u3089<\/a>\u3002<a href=\"#box_4-1\">R\u66f2\u3052\u5f62\u72b6\u306f\u3053\u3061\u3089<\/a>\u3002<\/li>\n \t<li>\u203b2 \u958b\u53e3\u90e8\u9ad8\u3055\u304c<span style=\"color: #d8352a;\">b<\/span>\u307e\u305f\u306f\u66f2\u3052\u90e8\u306e\u5916\uff32(\u30d5\u30a3\u30ec\u30c3\u30c8\u30b5\u30a4\u30ba)\u3088\u308a\u3082\u5c0f\u3055\u3044\u5834\u5408\u306f\u81ea\u52d5\u898b\u7a4d\u304c\u3067\u304d\u307e\u305b\u3093\u3002<\/li>\n \t<li>\u203b3 \u53f3\u56f3\u306e\u8fd1\u508d\u7a74\u304c\u30d0\u30fc\u30ea\u30f3\u30b0\u30bf\u30c3\u30d7\u306e\u5834\u5408\u306b\u9650\u308a\u3001\u9650\u754c\u5024<span style=\"color: #d8352a;\">c<\/span>\u306f\u4e00\u5f8b3.0mm\u3068\u306a\u308a\u307e\u3059\u3002<\/li>\n \t<li>\u203b4 A5052(\u30a2\u30eb\u30df)\u306b\u9650\u308b<\/li>\n<\/ul>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-a93897c\" data-id=\"a93897c\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-c898f8d elementor-widget elementor-widget-text-editor\" data-id=\"c898f8d\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p style=\"text-align: center;\">\u90e8\u4f4d\u4f8b<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-980373f elementor-widget elementor-widget-image\" data-id=\"980373f\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img loading=\"lazy\" decoding=\"async\" width=\"639\" height=\"319\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/11\/fcpl_item_guideline_51.png\" class=\"attachment-large size-large wp-image-9355\" alt=\"\" srcset=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/11\/fcpl_item_guideline_51.png 639w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/11\/fcpl_item_guideline_51-300x150.png 300w\" sizes=\"(max-width: 639px) 100vw, 639px\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-460a79f elementor-widget elementor-widget-image\" data-id=\"460a79f\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img loading=\"lazy\" decoding=\"async\" width=\"718\" height=\"379\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/11\/fcpl_item_guideline_52.png\" class=\"attachment-large size-large wp-image-9356\" alt=\"\" srcset=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/11\/fcpl_item_guideline_52.png 718w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/11\/fcpl_item_guideline_52-300x158.png 300w\" sizes=\"(max-width: 718px) 100vw, 718px\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-dea149a elementor-widget elementor-widget-image\" data-id=\"dea149a\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img loading=\"lazy\" decoding=\"async\" width=\"781\" height=\"346\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/11\/fcpl_item_guideline_53.png\" class=\"attachment-large size-large wp-image-9354\" alt=\"\" srcset=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/11\/fcpl_item_guideline_53.png 781w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/11\/fcpl_item_guideline_53-300x133.png 300w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/11\/fcpl_item_guideline_53-768x340.png 768w\" sizes=\"(max-width: 781px) 100vw, 781px\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-2a5245f print_page elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"2a5245f\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-5bc254b\" data-id=\"5bc254b\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-fdbc94d elementor-widget elementor-widget-heading\" data-id=\"fdbc94d\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h4 class=\"elementor-heading-title elementor-size-default\">\u203b\u53c2\u8003\uff09\u958b\u53e3\u90e8\u306e\u6709\u7121\u306b\u3088\u308b\u3001\u7a74\u4f4d\u7f6e\u306e\u52a0\u5de5\u9650\u754c\u6bd4\u8f03\u4f8b<\/h4>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<section class=\"elementor-section elementor-inner-section elementor-element elementor-element-c42814d elementor-section-content-middle print_wrap  print_break elementor-reverse-mobile elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"c42814d\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-1faaf16 print_break\" data-id=\"1faaf16\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-90cae09 elementor-widget elementor-widget-text-editor\" data-id=\"90cae09\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p style=\"text-align: center;\">\u4ee3\u8868\u6750\u8cea\u306e\u6bd4\u8f03\u4f8b<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-d4d62ab tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"d4d62ab\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"table05 min fixed alignleft tableHover\" style=\"margin-top: 0px; width: 100%;\">\n<tbody>\n<tr>\n<th rowspan=\"3\">\u7d20\u6750<\/th>\n<th rowspan=\"3\">\u677f\u539a<\/th>\n<th colspan=\"4\">\u958b\u53e3\u90e8\u306a\u3057 (\u53c2\u7167:\u7a74\u3068\u66f2\u3052\u306e\u6700\u5c0f\u8ddd\u96e2) <span style=\"color: red;\">h1<\/span><\/th>\n<th>\u958b\u53e3\u90e8\u3042\u308a (\u8fd1\u508d\u7a74\u3068\u66f2\u3052\u306e\u6700\u5c0f\u8ddd\u96e2)\n\u4fdd\u8a3c\u5024 <span style=\"color: red;\">h2<\/span><\/th>\n<\/tr>\n<tr>\n<th colspan=\"2\">\u901a\u3057\u7a74 \u9577\u7a74 \u89d2\u7a74 \u76bf\u7a74<\/th>\n<th colspan=\"2\">\u30bf\u30c3\u30d7\u7a74<\/th>\n<th>\u901a\u3057\u7a74 \u9577\u7a74 \u89d2\u7a74 \u76bf\u7a74 \u30bf\u30c3\u30d7\u7a74<\/th>\n<\/tr>\n<tr>\n<th>\u4fdd\u8a3c\u5024<\/th>\n<th>\u9650\u754c\u5024<\/th>\n<th>\u4fdd\u8a3c\u5024<\/th>\n<th>\u9650\u754c\u5024<\/th>\n<th>\u4fdd\u8a3c\u5024<\/th>\n<\/tr>\n<tr style=\"height: 24px;\">\n<th style=\"width: 25%;\" rowspan=\"13\">\n<ul>\n \t<li>SPCC\/SPHC<\/li>\n \t<li>SECC<\/li>\n \t<li>SS400<\/li>\n<\/ul>\n<\/th>\n<td>0.8<\/td>\n<td>4.2<\/td>\n<td>1.6<\/td>\n<td>\u2013<\/td>\n<td>\u2013<\/td>\n<td>1.7<\/td>\n<\/tr>\n<tr>\n<td>1.0<\/td>\n<td>4.3<\/td>\n<td>2.1<\/td>\n<td>4.8<\/td>\n<td>2.1<\/td>\n<td>2.0<\/td>\n<\/tr>\n<tr>\n<td>1.2<\/td>\n<td>5.5<\/td>\n<td>2.5<\/td>\n<td>6.0<\/td>\n<td>2.5<\/td>\n<td>2.4<\/td>\n<\/tr>\n<tr>\n<td>1.6<\/td>\n<td>6.8<\/td>\n<td>3.3<\/td>\n<td>7.3<\/td>\n<td>3.3<\/td>\n<td>3.2<\/td>\n<\/tr>\n<tr>\n<td>2.0<\/td>\n<td>8.0<\/td>\n<td>4.1<\/td>\n<td>8.7<\/td>\n<td>4.1<\/td>\n<td>4.0<\/td>\n<\/tr>\n<tr>\n<td>2.3<\/td>\n<td>9.3<\/td>\n<td>4.7<\/td>\n<td>9.9<\/td>\n<td>4.7<\/td>\n<td>4.5<\/td>\n<\/tr>\n<tr>\n<td>3.2<\/td>\n<td>13.3<\/td>\n<td>6.6<\/td>\n<td>13.8<\/td>\n<td>6.6<\/td>\n<td>6.3<\/td>\n<\/tr>\n<tr>\n<td>4.5<\/td>\n<td>17.4<\/td>\n<td>9.2<\/td>\n<td>18.4<\/td>\n<td>9.2<\/td>\n<td>8.9<\/td>\n<\/tr>\n<tr>\n<td>6.0<\/td>\n<td>23.5<\/td>\n<td>12.3<\/td>\n<td>24.5<\/td>\n<td>12.3<\/td>\n<td>12.0<\/td>\n<\/tr>\n<tr>\n<td>9.0<\/td>\n<td>33.5<\/td>\n<td>18.5<\/td>\n<td>34.5<\/td>\n<td>18.5<\/td>\n<td>17.5<\/td>\n<\/tr>\n<tr>\n<td>10.0<\/td>\n<td>48.5<\/td>\n<td>20.5<\/td>\n<td>47.5<\/td>\n<td>20.5<\/td>\n<td>20.0<\/td>\n<\/tr>\n<tr>\n<td>12.0<\/td>\n<td>62.0<\/td>\n<td>24.6<\/td>\n<td>63.0<\/td>\n<td>24.6<\/td>\n<td>24.0<\/td>\n<\/tr>\n<tr>\n<td>16.0<\/td>\n<td>88.5<\/td>\n<td>32.8<\/td>\n<td>89.5<\/td>\n<td>32.8<\/td>\n<td>32.0<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-3e3faf4 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"3e3faf4\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"table05 min fixed alignleft tableHover\" style=\"margin-top: 8px; width: 100%;\">\n<tbody>\n<tr>\n<th rowspan=\"3\">\u7d20\u6750<\/th>\n<th rowspan=\"3\">\u677f\u539a<\/th>\n<th colspan=\"4\">\u958b\u53e3\u90e8\u306a\u3057 (\u53c2\u7167:\u7a74\u3068\u66f2\u3052\u306e\u6700\u5c0f\u8ddd\u96e2) <span style=\"color: red;\">h1<\/span><\/th>\n<th>\u958b\u53e3\u90e8\u3042\u308a (\u8fd1\u508d\u7a74\u3068\u66f2\u3052\u306e\u6700\u5c0f\u8ddd\u96e2)\n\u4fdd\u8a3c\u5024 <span style=\"color: red;\">h2<\/span><\/th>\n<\/tr>\n<tr>\n<th colspan=\"2\">\u901a\u3057\u7a74 \u9577\u7a74 \u89d2\u7a74 \u76bf\u7a74<\/th>\n<th colspan=\"2\">\u30bf\u30c3\u30d7\u7a74<\/th>\n<th>\u901a\u3057\u7a74 \u9577\u7a74 \u89d2\u7a74 \u76bf\u7a74 \u30bf\u30c3\u30d7\u7a74<\/th>\n<\/tr>\n<tr>\n<th>\u4fdd\u8a3c\u5024<\/th>\n<th>\u9650\u754c\u5024<\/th>\n<th>\u4fdd\u8a3c\u5024<\/th>\n<th>\u9650\u754c\u5024<\/th>\n<th>\u4fdd\u8a3c\u5024<\/th>\n<\/tr>\n<tr style=\"height: 24px;\">\n<th style=\"width: 20%; height: 184px;\" rowspan=\"13\">\n<ul>\n \t<li>SUS304(No.1)<\/li>\n \t<li>SUS304(2B)<\/li>\n \t<li>SUS304(2B) \u7247\u9762\u4fdd\u8b77\u30b7\u30fc\u30c8\u4ed8<\/li>\n \t<li>SUS304(\u7247\u9762#400\u7814\u78e8)<\/li>\n \t<li>SUS304(\u7247\u9762\u30d8\u30a2\u30e9\u30a4\u30f3)<\/li>\n \t<li>SUS316(2B)<\/li>\n \t<li>SUS430(2B)<\/li>\n<\/ul>\n<\/th>\n<td>0.8<\/td>\n<td>4.2<\/td>\n<td>1.6<\/td>\n<td>\u2013<\/td>\n<td>\u2013<\/td>\n<td>1.7<\/td>\n<\/tr>\n<tr>\n<td>1.0<\/td>\n<td>4.3<\/td>\n<td>2.1<\/td>\n<td>5.3<\/td>\n<td>2.1<\/td>\n<td>2.0<\/td>\n<\/tr>\n<tr>\n<td>1.2<\/td>\n<td>4.5<\/td>\n<td>2.5<\/td>\n<td>5.5<\/td>\n<td>2.5<\/td>\n<td>2.4<\/td>\n<\/tr>\n<tr>\n<td>1.5<\/td>\n<td>6.0<\/td>\n<td>3.1<\/td>\n<td>7.0<\/td>\n<td>3.1<\/td>\n<td>3.0<\/td>\n<\/tr>\n<tr>\n<td>2.0<\/td>\n<td>7.1<\/td>\n<td>4.1<\/td>\n<td>8.1<\/td>\n<td>4.1<\/td>\n<td>4.0<\/td>\n<\/tr>\n<tr>\n<td>2.5<\/td>\n<td>11.3<\/td>\n<td>5.1<\/td>\n<td>12.3<\/td>\n<td>5.1<\/td>\n<td>5.0<\/td>\n<\/tr>\n<tr>\n<td>3.0<\/td>\n<td>11.5<\/td>\n<td>6.2<\/td>\n<td>12.5<\/td>\n<td>6.2<\/td>\n<td>6.0<\/td>\n<\/tr>\n<tr>\n<td>4.0<\/td>\n<td>17.2<\/td>\n<td>8.2<\/td>\n<td>18.2<\/td>\n<td>8.2<\/td>\n<td>8.0<\/td>\n<\/tr>\n<tr>\n<td>5.0<\/td>\n<td>23.5<\/td>\n<td>10.3<\/td>\n<td>24.5<\/td>\n<td>10.3<\/td>\n<td>10.0<\/td>\n<\/tr>\n<tr>\n<td>6.0<\/td>\n<td>25.0<\/td>\n<td>12.3<\/td>\n<td>26.0<\/td>\n<td>12.3<\/td>\n<td>12.0<\/td>\n<\/tr>\n<tr>\n<td>9.0<\/td>\n<td>39.0<\/td>\n<td>18.5<\/td>\n<td>40.0<\/td>\n<td>18.5<\/td>\n<td>17.5<\/td>\n<\/tr>\n<tr>\n<td>10.0<\/td>\n<td>46.5<\/td>\n<td>20.5<\/td>\n<td>47.5<\/td>\n<td>20.5<\/td>\n<td>20.0<\/td>\n<\/tr>\n<tr>\n<td>12.0<\/td>\n<td>62.0<\/td>\n<td>24.6<\/td>\n<td>63.0<\/td>\n<td>24.6<\/td>\n<td>24.0<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-d04f67a tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"d04f67a\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"table05 min fixed alignleft tableHover\" style=\"margin-top: 8px; width: 100%; height: 100%;\">\n<tbody>\n<tr>\n<th rowspan=\"3\">\u7d20\u6750<\/th>\n<th rowspan=\"3\">\u677f\u539a<\/th>\n<th colspan=\"4\">\u958b\u53e3\u90e8\u306a\u3057 (\u53c2\u7167:\u7a74\u3068\u66f2\u3052\u306e\u6700\u5c0f\u8ddd\u96e2) <span style=\"color: red;\">h1<\/span><\/th>\n<th>\u958b\u53e3\u90e8\u3042\u308a (\u8fd1\u508d\u7a74\u3068\u66f2\u3052\u306e\u6700\u5c0f\u8ddd\u96e2)\n\u4fdd\u8a3c\u5024 <span style=\"color: red;\">h2<\/span><\/th>\n<\/tr>\n<tr>\n<th colspan=\"2\">\u901a\u3057\u7a74 \u9577\u7a74 \u89d2\u7a74 \u76bf\u7a74<\/th>\n<th colspan=\"2\">\u30bf\u30c3\u30d7\u7a74<\/th>\n<th>\u901a\u3057\u7a74 \u9577\u7a74 \u89d2\u7a74 \u76bf\u7a74 \u30bf\u30c3\u30d7\u7a74<\/th>\n<\/tr>\n<tr>\n<th>\u4fdd\u8a3c\u5024<\/th>\n<th>\u9650\u754c\u5024<\/th>\n<th>\u4fdd\u8a3c\u5024<\/th>\n<th>\u9650\u754c\u5024<\/th>\n<th>\u4fdd\u8a3c\u5024<\/th>\n<\/tr>\n<tr style=\"height: 24px;\">\n<th style=\"width: 37%; height: 240px;\" rowspan=\"11\">\n<ul>\n \t<li>A5052<\/li>\n \t<li>A5052(\u30a2\u30eb\u30de\u30a4\u30c8\u92fc\u677f\u767d)<\/li>\n \t<li>A5052(\u30a2\u30eb\u30de\u30a4\u30c8\u92fc\u677f\u9ed2)<\/li>\n<\/ul>\n<\/th>\n<td>0.8<\/td>\n<td>4.2<\/td>\n<td>1.6<\/td>\n<td>\u2013<\/td>\n<td>\u2013<\/td>\n<td>1.7<\/td>\n<\/tr>\n<tr>\n<td>1.0<\/td>\n<td>4.3<\/td>\n<td>2.1<\/td>\n<td>5.2<\/td>\n<td>2.1<\/td>\n<td>2.0<\/td>\n<\/tr>\n<tr>\n<td>1.2<\/td>\n<td>5.5<\/td>\n<td>2.5<\/td>\n<td>5.5<\/td>\n<td>2.5<\/td>\n<td>2.4<\/td>\n<\/tr>\n<tr>\n<td>1.5<\/td>\n<td>6.0<\/td>\n<td>3.1<\/td>\n<td>7.0<\/td>\n<td>3.1<\/td>\n<td>3.0<\/td>\n<\/tr>\n<tr>\n<td>1.6<\/td>\n<td>6.0<\/td>\n<td>3.3<\/td>\n<td>7.0<\/td>\n<td>3.3<\/td>\n<td>3.2<\/td>\n<\/tr>\n<tr>\n<td>2.0<\/td>\n<td>8.2<\/td>\n<td>4.1<\/td>\n<td>8.2<\/td>\n<td>4.1<\/td>\n<td>4.0<\/td>\n<\/tr>\n<tr>\n<td>2.5<\/td>\n<td>10.0<\/td>\n<td>5.1<\/td>\n<td>11.0<\/td>\n<td>5.1<\/td>\n<td>5.0<\/td>\n<\/tr>\n<tr>\n<td>3.0<\/td>\n<td>13.3<\/td>\n<td>6.2<\/td>\n<td>13.3<\/td>\n<td>6.2<\/td>\n<td>6.0<\/td>\n<\/tr>\n<tr>\n<td>4.0<\/td>\n<td>17.2<\/td>\n<td>8.2<\/td>\n<td>18.2<\/td>\n<td>8.2<\/td>\n<td>8.0<\/td>\n<\/tr>\n<tr>\n<td>5.0<\/td>\n<td>27.0<\/td>\n<td>10.3<\/td>\n<td>27.0<\/td>\n<td>10.3<\/td>\n<td>10.0<\/td>\n<\/tr>\n<tr>\n<td>6.0<\/td>\n<td>28.0<\/td>\n<td>12.3<\/td>\n<td>28.0<\/td>\n<td>12.3<\/td>\n<td>12.0<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-aa6606d tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"aa6606d\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"table05 min fixed alignleft tableHover\" style=\"margin-top: 8px; width: 100%; height: 100%;\">\n<tbody>\n<tr>\n<th rowspan=\"3\">\u7d20\u6750<\/th>\n<th rowspan=\"3\">\u677f\u539a<\/th>\n<th colspan=\"4\">\u958b\u53e3\u90e8\u306a\u3057 (\u53c2\u7167:\u7a74\u3068\u66f2\u3052\u306e\u6700\u5c0f\u8ddd\u96e2) <span style=\"color: red;\">h1<\/span><\/th>\n<th>\u958b\u53e3\u90e8\u3042\u308a (\u8fd1\u508d\u7a74\u3068\u66f2\u3052\u306e\u6700\u5c0f\u8ddd\u96e2)\n\u4fdd\u8a3c\u5024 <span style=\"color: red;\">h2<\/span><\/th>\n<\/tr>\n<tr>\n<th colspan=\"2\">\u901a\u3057\u7a74 \u9577\u7a74 \u89d2\u7a74 \u76bf\u7a74<\/th>\n<th colspan=\"2\">\u30bf\u30c3\u30d7\u7a74<\/th>\n<th>\u901a\u3057\u7a74 \u9577\u7a74 \u89d2\u7a74 \u76bf\u7a74 \u30bf\u30c3\u30d7\u7a74<\/th>\n<\/tr>\n<tr>\n<th>\u4fdd\u8a3c\u5024<\/th>\n<th>\u9650\u754c\u5024<\/th>\n<th>\u4fdd\u8a3c\u5024<\/th>\n<th>\u9650\u754c\u5024<\/th>\n<th>\u4fdd\u8a3c\u5024<\/th>\n<\/tr>\n<tr style=\"height: 24px;\">\n<th style=\"width: 37%;\" rowspan=\"11\">\n<ul>\n \t<li>C1020(\u7121\u9178\u7d20\u9285)<\/li>\n \t<li>C1100(\u30bf\u30d5\u30d4\u30c3\u30c1\u9285)<\/li>\n \t<li>C2801P(\u771f\u936e\u30fb\u9ec4\u9285)<\/li>\n<\/ul>\n<\/th>\n<td>1.0<\/td>\n<td>4.3<\/td>\n<td>2.1<\/td>\n<td>5.2<\/td>\n<td>2.1<\/td>\n<td>2.0<\/td>\n<\/tr>\n<tr>\n<td>1.5<\/td>\n<td>6.0<\/td>\n<td>3.1<\/td>\n<td>7.0<\/td>\n<td>3.1<\/td>\n<td>3.0<\/td>\n<\/tr>\n<tr>\n<td>2.0<\/td>\n<td>7.1<\/td>\n<td>4.1<\/td>\n<td>8.1<\/td>\n<td>4.1<\/td>\n<td>4.0<\/td>\n<\/tr>\n<tr>\n<td>3.0<\/td>\n<td>11.5<\/td>\n<td>6.2<\/td>\n<td>12.5<\/td>\n<td>6.2<\/td>\n<td>6.0<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-ab91ffd\" data-id=\"ab91ffd\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-561e465 elementor-widget elementor-widget-text-editor\" data-id=\"561e465\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p style=\"text-align: center;\">\u30a4\u30e1\u30fc\u30b8\u30fb\u524d\u63d0\u6761\u4ef6<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-75d2e31 elementor-widget elementor-widget-image\" data-id=\"75d2e31\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img loading=\"lazy\" decoding=\"async\" width=\"547\" height=\"284\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/12\/fcpl_item_guideline_54.png\" class=\"attachment-large size-large wp-image-9455\" alt=\"\u66f2\u3052\u89d2\u306e\u4eee\u60f3\u4ea4\u70b9\" srcset=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/12\/fcpl_item_guideline_54.png 547w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/12\/fcpl_item_guideline_54-300x156.png 300w\" sizes=\"(max-width: 547px) 100vw, 547px\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-60b934d elementor-widget elementor-widget-text-editor\" data-id=\"60b934d\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<ul style=\"text-align: left; margin-top: 10px;\">\n \t<li>\u30fb\u672c\u6bd4\u8f03\u4f8b\u306f\u4ee3\u8868\u6750\u8cea\u30fb\u7a74\u7a2e\u3067\u306e\u629c\u7c8b\u3067\u3042\u308a\u3001\u672a\u63b2\u8f09\u6750\u8cea\u30fb\u4ed6\u306e\u7a74\u7a2e\u3067\u3082 \u52b9\u679c\u306f\u3054\u3056\u3044\u307e\u3059\u3002<\/li>\n \t<li>\u30fb\u66f2\u3052\u90e8\u306e\u5916\uff32(\u30d5\u30a3\u30ec\u30c3\u30c8\u30b5\u30a4\u30ba)\u3068\u66f2\u3052\u7dda\u4e0a\u306e\u958b\u53e3\u90e8\u9ad8\u3055\u3092\u6700\u5c0f\u5024\u201db\u201d\u306b\u5408\u308f\u305b\u3066\u30e2\u30c7\u30ea\u30f3\u30b0\u3057\u305f\u5834\u5408\u306e\u6bd4\u8f03\u3067\u3059\u3002\u958b\u53e3\u90e8\u9ad8\u3055\u3092\u201db&#8221;\u3088\u308a\u3082\u5927\u304d\u304f\u30e2\u30c7\u30ea\u30f3\u30b0\u3057\u305f\u5834\u5408\u3001<span style=\"color: #d8352a;\">h2<\/span>\u306e\u5024\u306f\u7570\u306a\u308a\u307e\u3059\u3002<\/li>\n<\/ul>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-d39f9c9 print_page elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"d39f9c9\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-af6ebd4\" data-id=\"af6ebd4\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-cfecf65 elementor-widget elementor-widget-menu-anchor\" data-id=\"cfecf65\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"menu-anchor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t<div class=\"elementor-menu-anchor\" id=\"box_15\"><\/div>\n\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-8d627de elementor-widget elementor-widget-heading\" data-id=\"8d627de\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h4 class=\"elementor-heading-title elementor-size-default\">\u523b\u5370\u3068\u523b\u5370\u30fb\u7aef\u9762\u30fb\u7a74\u9593\u306e\u6700\u5c0f\u8ddd\u96e2\n<\/h4>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<section class=\"elementor-section elementor-inner-section elementor-element elementor-element-11f8b4d elementor-section-content-middle print_wrap  print_break elementor-reverse-mobile elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"11f8b4d\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-9fe07ba print_break\" data-id=\"9fe07ba\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-2f95374 elementor-widget elementor-widget-text-editor\" data-id=\"2f95374\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p style=\"text-align: center;\">\u52a0\u5de5\u9650\u754c\u30fb\u5bf8\u6cd5\u7bc4\u56f2<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-d1ad32c tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"d1ad32c\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"table05 mT0 min tableHover\" style=\"width: 100%; word-break: break-word;\">\n<tbody>\n<tr>\n<th colspan=\"3\">\u677f\u539a<\/th>\n<th>\u523b\u5370\u30fb\u7aef\u9762<\/th>\n<th colspan=\"2\">\u901a\u3057\u7a74\u30fb\u30bf\u30c3\u30d7\u7a74\u30fb\u76bf\u7a74\u30fb\u4e2d\u629c\u304d\u7a74<\/th>\n<th colspan=\"2\">\u30d0\u30fc\u30ea\u30f3\u30b0\u30bf\u30c3\u30d7<\/th>\n<\/tr>\n<tr>\n<th>\n<ul>\n \t<li>SPCC<\/li>\n \t<li>SPHC<\/li>\n \t<li>SS400<\/li>\n<\/ul>\n<\/th>\n<th>\n<ul>\n \t<li>SUS304(No.1)<\/li>\n \t<li>SUS304(2B)<\/li>\n \t<li>SUS430(2B)<\/li>\n<\/ul>\n<\/th>\n<th>A5052<\/th>\n<th>\u9650\u754c\u5024<span style=\"color: #d8352a;\"> a<\/span><\/th>\n<th>\u4fdd\u8a3c\u5024<span style=\"color: #d8352a;\"> b<\/span><\/th>\n<th>\u9650\u754c\u5024<span style=\"color: #d8352a;\"> b<\/span><\/th>\n<th>\u4fdd\u8a3c\u5024<span style=\"color: #d8352a;\"> c<\/span><\/th>\n<th>\u9650\u754c\u5024<span style=\"color: #d8352a;\"> c<\/span><\/th>\n<\/tr>\n<tr>\n<td>0.8<\/td>\n<td>0.8<\/td>\n<td>0.8<\/td>\n<td rowspan=\"18\">2.0<\/td>\n<td rowspan=\"18\">4.0<\/td>\n<td rowspan=\"18\">2.0<\/td>\n<td rowspan=\"5\">5.0<\/td>\n<td rowspan=\"5\">3.0<\/td>\n<\/tr>\n<tr>\n<td>1.0<\/td>\n<td>1.0<\/td>\n<td>1.0<\/td>\n<\/tr>\n<tr>\n<td>1.2<\/td>\n<td>1.2<\/td>\n<td>1.2<\/td>\n<\/tr>\n<tr>\n<td>\u2013<\/td>\n<td>1.5<\/td>\n<td>1.5<\/td>\n<\/tr>\n<tr>\n<td>1.6<\/td>\n<td>\u2013<\/td>\n<td>1.6<\/td>\n<\/tr>\n<tr>\n<td>2.0<\/td>\n<td>2.0<\/td>\n<td>2.0<\/td>\n<td rowspan=\"13\">\u2013<\/td>\n<td rowspan=\"13\">\u2013<\/td>\n<\/tr>\n<tr>\n<td>2.3<\/td>\n<td>\u2013<\/td>\n<td>\u2013<\/td>\n<\/tr>\n<tr>\n<td>\u2013<\/td>\n<td>2.5<\/td>\n<td>2.5<\/td>\n<\/tr>\n<tr>\n<td>\u2013<\/td>\n<td>3.0<\/td>\n<td>3.0<\/td>\n<\/tr>\n<tr>\n<td>3.2<\/td>\n<td>\u2013<\/td>\n<td>\u2013<\/td>\n<\/tr>\n<tr>\n<td>\u2013<\/td>\n<td>4.0<\/td>\n<td>4.0<\/td>\n<\/tr>\n<tr>\n<td>4.5<\/td>\n<td>\u2013<\/td>\n<td>\u2013<\/td>\n<\/tr>\n<tr>\n<td>\u2013<\/td>\n<td>5.0<\/td>\n<td>5.0<\/td>\n<\/tr>\n<tr>\n<td>6.0<\/td>\n<td>6.0<\/td>\n<td>6.0<\/td>\n<\/tr>\n<tr>\n<td>9.0<\/td>\n<td>9.0<\/td>\n<td rowspan=\"4\">\u2013<\/td>\n<\/tr>\n<tr>\n<td>10.0<\/td>\n<td>10.0<\/td>\n<\/tr>\n<tr>\n<td>12.0<\/td>\n<td>12.0<\/td>\n<\/tr>\n<tr>\n<td>16.0<\/td>\n<td>\u2013<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-19242fc\" data-id=\"19242fc\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-c2f41c1 elementor-widget elementor-widget-text-editor\" data-id=\"c2f41c1\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p style=\"text-align: center;\">\u90e8\u4f4d\u4f8b<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-4f1a2d2 elementor-widget elementor-widget-image\" data-id=\"4f1a2d2\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img loading=\"lazy\" decoding=\"async\" width=\"500\" height=\"350\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/3474_07.png\" class=\"attachment-large size-large wp-image-17991\" alt=\"\" srcset=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/3474_07.png 500w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/3474_07-300x210.png 300w\" sizes=\"(max-width: 500px) 100vw, 500px\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-96cb8e0 elementor-widget elementor-widget-text-editor\" data-id=\"96cb8e0\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<ul style=\"text-align: left; margin-top: 20px;\">\n \t<li>\u203b\u7a74\u306f\u3059\u3079\u3066\u6700\u5916\u5f84\u304b\u3089\u3001\u523b\u5370\u6587\u5b57\u306e\u5916\u5074\u3068\u306e\u6700\u5c0f\u8ddd\u96e2\u304c\u8a08\u7b97\u3055\u308c\u307e\u3059\u3002<\/li>\n \t<li>\u203b\u30d0\u30fc\u30ea\u30f3\u30b0\u30bf\u30c3\u30d7\u306b\u9650\u308a\u3001\u9650\u754c\u5024<span style=\"color: #ff0000;\">c<\/span>\u306f\u4e00\u5f8b3.0mm\u3068\u306a\u308a\u307e\u3059\u3002<\/li>\n \t<li>\u203b\u4fdd\u8a3c\u5024\u3092\u4e0b\u56de\u3063\u305f\u5834\u5408\u3001\u523b\u5370\u304c\u5909\u5f62\u3059\u308b\u6050\u308c\u304c\u3042\u308a\u307e\u3059\u3002<\/li>\n<\/ul>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-0533517 print_page elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"0533517\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-e886913\" data-id=\"e886913\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-35b7e1c elementor-widget elementor-widget-menu-anchor\" data-id=\"35b7e1c\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"menu-anchor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t<div class=\"elementor-menu-anchor\" id=\"box_16\"><\/div>\n\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-4964554 elementor-widget elementor-widget-heading\" data-id=\"4964554\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h4 class=\"elementor-heading-title elementor-size-default\">\u523b\u5370\u3068\u30ca\u30c3\u30c8\u306e\u6700\u5c0f\u8ddd\u96e2<\/h4>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<section class=\"elementor-section elementor-inner-section elementor-element elementor-element-4a7ddcb elementor-section-content-middle print_wrap  print_break elementor-reverse-mobile elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"4a7ddcb\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-f34b05d print_break\" data-id=\"f34b05d\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-0893a85 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"0893a85\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"table05 mT0 min tableHover\" style=\"width: 100%;\">\n<tbody>\n<tr>\n<th style=\"width: 30%;\" colspan=\"2\" rowspan=\"3\">\u30ca\u30c3\u30c8\uff08\u5727\u5165\uff09<\/th>\n<th style=\"width: 40%;\" colspan=\"6\">\u6750\u8cea<\/th>\n<\/tr>\n<tr>\n<th colspan=\"2\">\n<ul>\n \t<li>SPCC<\/li>\n \t<li>SPHC<\/li>\n<\/ul>\n<\/th>\n<th colspan=\"2\">\n<ul>\n \t<li>SUS304(2B)<\/li>\n \t<li>SUS430(2B)<\/li>\n<\/ul>\n<\/th>\n<th colspan=\"2\">A5052<\/th>\n<\/tr>\n<tr>\n<th>\u4fdd\u8a3c\u5024<span style=\"color: #d8352a;\"> a<\/span><\/th>\n<th>\u9650\u754c\u5024<span style=\"color: #d8352a;\"> a<\/span><\/th>\n<th>\u4fdd\u8a3c\u5024<span style=\"color: #d8352a;\"> a<\/span><\/th>\n<th>\u9650\u754c\u5024<span style=\"color: #d8352a;\"> a<\/span><\/th>\n<th>\u4fdd\u8a3c\u5024<span style=\"color: #d8352a;\"> a<\/span><\/th>\n<th>\u9650\u754c\u5024<span style=\"color: #d8352a;\"> a<\/span><\/th>\n<\/tr>\n<tr>\n<th rowspan=\"5\">\u547c\u3073\u5f84<\/th>\n<td>M3<\/td>\n<td>6.5<\/td>\n<td>4.5<\/td>\n<td>8.7<\/td>\n<td>6.7<\/td>\n<td>6.5<\/td>\n<td>4.5<\/td>\n<\/tr>\n<tr>\n<td>M4<\/td>\n<td>7.5<\/td>\n<td>5.5<\/td>\n<td>9.6<\/td>\n<td>7.6<\/td>\n<td>7.5<\/td>\n<td>5.5<\/td>\n<\/tr>\n<tr>\n<td>M5<\/td>\n<td>8.5<\/td>\n<td>6.5<\/td>\n<td>10.2<\/td>\n<td>8.2<\/td>\n<td>8.5<\/td>\n<td>6.5<\/td>\n<\/tr>\n<tr>\n<td>M6<\/td>\n<td>10.0<\/td>\n<td>8.0<\/td>\n<td>11.3<\/td>\n<td>9.3<\/td>\n<td>10.0<\/td>\n<td>8.0<\/td>\n<\/tr>\n<tr>\n<td>M8<\/td>\n<td>12.0<\/td>\n<td>10.0<\/td>\n<td>13.1<\/td>\n<td>11.1<\/td>\n<td>12.0<\/td>\n<td>10.0<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-2d4da07 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"2d4da07\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"table05 min tableHover\" style=\"width: 100%;\"><tbody><tr><th colspan=\"2\" rowspan=\"3\">\u30ca\u30c3\u30c8\uff08\u30b9\u30dd\u30c3\u30c8\u6eb6\u63a5\uff09<\/th><th colspan=\"4\">\u6750\u8cea<\/th><\/tr><tr><th colspan=\"2\"><ul><li>SPCC<\/li><li>SPHC<\/li><\/ul><\/th><th colspan=\"2\"><ul><li>SUS304(2B)<\/li><li>SUS430(2B)<\/li><\/ul><\/th><\/tr><tr><th>\u4fdd\u8a3c\u5024<span style=\"color: #d8352a;\"> a<\/span><\/th><th>\u9650\u754c\u5024<span style=\"color: #d8352a;\"> a<\/span><\/th><th>\u4fdd\u8a3c\u5024<span style=\"color: #d8352a;\"> a<\/span><\/th><th>\u9650\u754c\u5024<span style=\"color: #d8352a;\"> a<\/span><\/th><\/tr><tr><th rowspan=\"6\">\u547c\u3073\u5f84<\/th><td>M4<\/td><td>9.5<\/td><td>7.5<\/td><td>9.9<\/td><td>7.9<\/td><\/tr><tr><td>M5<\/td><td>9.5<\/td><td>7.5<\/td><td>9.9<\/td><td>7.9<\/td><\/tr><tr><td>M6<\/td><td>11.0<\/td><td>9.0<\/td><td>11.1<\/td><td>9.1<\/td><\/tr><tr><td>M8<\/td><td>12.4<\/td><td>10.4<\/td><td>12.7<\/td><td>10.7<\/td><\/tr><tr><td>M10<\/td><td>14.5<\/td><td>12.5<\/td><td>14.9<\/td><td>12.9<\/td><\/tr><tr><td>M11<\/td><td>16.5<\/td><td>14.5<\/td><td>17.0<\/td><td>15.0<\/td><\/tr><\/tbody><\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-a3e65cf\" data-id=\"a3e65cf\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-ed0c428 elementor-widget elementor-widget-text-editor\" data-id=\"ed0c428\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p style=\"text-align: center;\">\u90e8\u4f4d\u4f8b<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-b751aff elementor-widget elementor-widget-image\" data-id=\"b751aff\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img loading=\"lazy\" decoding=\"async\" width=\"500\" height=\"350\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/3474_08.png\" class=\"attachment-large size-large wp-image-18206\" alt=\"\" srcset=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/3474_08.png 500w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/3474_08-300x210.png 300w\" sizes=\"(max-width: 500px) 100vw, 500px\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-8c96735 elementor-widget elementor-widget-text-editor\" data-id=\"8c96735\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<ul style=\"text-align: left; margin-top: 40px;\">\n \t<li>\u203b\u523b\u5370\u6587\u5b57\u306e\u5916\u5074\u3068\u30ca\u30c3\u30c8\u4e2d\u5fc3\u304b\u3089\u306e\u8ddd\u96e2\u3067\u6700\u5c0f\u8ddd\u96e2\u304c\u8a08\u7b97\u3055\u308c\u307e\u3059\u3002<\/li>\n \t<li>\u203b\u4fdd\u8a3c\u5024\u3092\u4e0b\u56de\u3063\u305f\u5834\u5408\u3001\u523b\u5370\u304c\u5909\u5f62\u3059\u308b\u6050\u308c\u304c\u3042\u308a\u307e\u3059\u3002<\/li>\n<\/ul>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-3917743 print_page elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"3917743\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-acf38ef\" data-id=\"acf38ef\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-dbe3043 elementor-widget elementor-widget-menu-anchor\" data-id=\"dbe3043\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"menu-anchor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t<div class=\"elementor-menu-anchor\" id=\"box_17\"><\/div>\n\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-ae2d2c7 elementor-widget elementor-widget-heading\" data-id=\"ae2d2c7\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h4 class=\"elementor-heading-title elementor-size-default\">\u523b\u5370\u3068\u66f2\u3052\u306e\u6700\u5c0f\u8ddd\u96e2<\/h4>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<section class=\"elementor-section elementor-inner-section elementor-element elementor-element-f30ca05 elementor-section-content-middle print_wrap  print_break elementor-reverse-mobile elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"f30ca05\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-84fafa5 print_break\" data-id=\"84fafa5\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-3fe1a49 elementor-widget elementor-widget-text-editor\" data-id=\"3fe1a49\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p style=\"text-align: center;\">\u52a0\u5de5\u9650\u754c\u30fb\u5bf8\u6cd5\u7bc4\u56f2<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-ae1bd22 tblBasic print_break elementor-widget elementor-widget-text-editor\" data-id=\"ae1bd22\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<div class=\"print_break\">\n\n&nbsp;\n<div class=\"tableStickyHead\">\n<table class=\"table05 mT0 min tableHover\">\n<thead>\n<tr>\n<th>\u6750\u8cea<\/th>\n<th>\u677f\u539a<\/th>\n<th>\u4fdd\u8a3c\u5024<span style=\"color: #d8352a;\"> h<\/span><\/th>\n<th>\u9650\u754c\u5024<span style=\"color: #d8352a;\"> h<\/span><\/th>\n<\/tr>\n<\/thead>\n<\/table>\n<\/div>\n<table class=\"table05 mT0 min tableHover\">\n<tbody>\n<tr>\n<th rowspan=\"13\">\n<ul>\n \t<li>SPCC<\/li>\n \t<li>SPHC<\/li>\n \t<li>SS400<\/li>\n<\/ul>\n<\/th>\n<td>0.8<\/td>\n<td>6.2<\/td>\n<td>4.2<\/td>\n<\/tr>\n<tr>\n<td>1.0<\/td>\n<td>6.3<\/td>\n<td>4.3<\/td>\n<\/tr>\n<tr>\n<td>1.2<\/td>\n<td>7.5<\/td>\n<td>5.5<\/td>\n<\/tr>\n<tr>\n<td>1.6<\/td>\n<td>8.8<\/td>\n<td>6.8<\/td>\n<\/tr>\n<tr>\n<td>2.0<\/td>\n<td>10.2<\/td>\n<td>8.2<\/td>\n<\/tr>\n<tr>\n<td>2.3<\/td>\n<td>11.4<\/td>\n<td>9.4<\/td>\n<\/tr>\n<tr>\n<td>3.2<\/td>\n<td>15.3<\/td>\n<td>13.3<\/td>\n<\/tr>\n<tr>\n<td>4.5<\/td>\n<td>19.4<\/td>\n<td>17.4<\/td>\n<\/tr>\n<tr>\n<td>6.0<\/td>\n<td>25.5<\/td>\n<td>23.5<\/td>\n<\/tr>\n<tr>\n<td>9.0<\/td>\n<td>41.0<\/td>\n<td>39.0<\/td>\n<\/tr>\n<tr>\n<td>10.0<\/td>\n<td>48.5<\/td>\n<td>46.5<\/td>\n<\/tr>\n<tr>\n<td>12.0<\/td>\n<td>64.0<\/td>\n<td>62.0<\/td>\n<\/tr>\n<tr>\n<td>16.0<\/td>\n<td>90.5<\/td>\n<td>88.5<\/td>\n<\/tr>\n<tr>\n<th rowspan=\"13\">\n<ul>\n \t<li>SUS304(No.1)<\/li>\n \t<li>SUS304(2B)<\/li>\n \t<li>SUS430(2B)<\/li>\n<\/ul>\n<\/th>\n<td>0.8<\/td>\n<td>6.2<\/td>\n<td>4.2<\/td>\n<\/tr>\n<tr>\n<td>1.0<\/td>\n<td>6.3<\/td>\n<td>4.3<\/td>\n<\/tr>\n<tr>\n<td>1.2<\/td>\n<td>6.5<\/td>\n<td>4.5<\/td>\n<\/tr>\n<tr>\n<td>1.5<\/td>\n<td>8.0<\/td>\n<td>6.0<\/td>\n<\/tr>\n<tr>\n<td>2.0<\/td>\n<td>9.1<\/td>\n<td>7.1<\/td>\n<\/tr>\n<tr>\n<td>2.5<\/td>\n<td>13.3<\/td>\n<td>11.3<\/td>\n<\/tr>\n<tr>\n<td>3.0<\/td>\n<td>13.5<\/td>\n<td>11.5<\/td>\n<\/tr>\n<tr>\n<td>4.0<\/td>\n<td>19.2<\/td>\n<td>17.2<\/td>\n<\/tr>\n<tr>\n<td>5.0<\/td>\n<td>25.5<\/td>\n<td>23.5<\/td>\n<\/tr>\n<tr>\n<td>6.0<\/td>\n<td>27.0<\/td>\n<td>25.0<\/td>\n<\/tr>\n<tr>\n<td>9.0<\/td>\n<td>41.0<\/td>\n<td>39.0<\/td>\n<\/tr>\n<tr>\n<td>10.0<\/td>\n<td>48.5<\/td>\n<td>46.5<\/td>\n<\/tr>\n<tr>\n<td>12.0<\/td>\n<td>64.0<\/td>\n<td>62.0<\/td>\n<\/tr>\n<tr>\n<th rowspan=\"11\">A5052<\/th>\n<td>0.8<\/td>\n<td>6.2<\/td>\n<td>4.2<\/td>\n<\/tr>\n<tr>\n<td>1.0<\/td>\n<td>6.3<\/td>\n<td>4.3<\/td>\n<\/tr>\n<tr>\n<td>1.2<\/td>\n<td>7.5<\/td>\n<td>5.5<\/td>\n<\/tr>\n<tr>\n<td>1.5<\/td>\n<td>8.0<\/td>\n<td>6.0<\/td>\n<\/tr>\n<tr>\n<td>1.6<\/td>\n<td>8.0<\/td>\n<td>6.0<\/td>\n<\/tr>\n<tr>\n<td>2.0<\/td>\n<td>10.2<\/td>\n<td>8.2<\/td>\n<\/tr>\n<tr>\n<td>2.5<\/td>\n<td>12.0<\/td>\n<td>10.0<\/td>\n<\/tr>\n<tr>\n<td>3.0<\/td>\n<td>15.3<\/td>\n<td>13.3<\/td>\n<\/tr>\n<tr>\n<td>4.0<\/td>\n<td>19.2<\/td>\n<td>17.2<\/td>\n<\/tr>\n<tr>\n<td>5.0<\/td>\n<td>29.0<\/td>\n<td>27.0<\/td>\n<\/tr>\n<tr>\n<td>6.0<\/td>\n<td>30.0<\/td>\n<td>28.0<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\n<\/div>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-06c7cb2\" data-id=\"06c7cb2\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-c6abcad elementor-widget elementor-widget-text-editor\" data-id=\"c6abcad\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p style=\"text-align: center;\">\u90e8\u4f4d\u4f8b<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-4c1f571 elementor-widget elementor-widget-image\" data-id=\"4c1f571\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img loading=\"lazy\" decoding=\"async\" width=\"500\" height=\"300\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/3474_09_A.png\" class=\"attachment-large size-large wp-image-19594\" alt=\"\" srcset=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/3474_09_A.png 500w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/3474_09_A-300x180.png 300w\" sizes=\"(max-width: 500px) 100vw, 500px\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-9dc6c04 elementor-widget elementor-widget-text-editor\" data-id=\"9dc6c04\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<ul style=\"text-align: left; margin-top: 40px;\">\n \t<li>\u203b\u6750\u8cea\u30fb\u677f\u539a\u6bce\u306e\u6700\u5c0f\u66f2\u3052\u9ad8\u3055\u3092\u3001\u523b\u5370\u6587\u5b57\u306e\u5916\u5074\u3068\u306e\u6700\u5c0f\u8ddd\u96e2\uff08\u9650\u754c\u5024\uff09\u306b\u9069\u7528\u3057\u3066\u3044\u307e\u3059\u3002<\/li>\n \t<li>\u203b\u4fdd\u8a3c\u5024\u3092\u4e0b\u56de\u3063\u305f\u5834\u5408\u3001\u523b\u5370\u304c\u5909\u5f62\u3059\u308b\u6050\u308c\u304c\u3042\u308a\u307e\u3059\u3002<\/li>\n<\/ul>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-c53c2c4 print_block elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"c53c2c4\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-9722521\" data-id=\"9722521\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-9773256 elementor-widget elementor-widget-menu-anchor\" data-id=\"9773256\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"menu-anchor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t<div class=\"elementor-menu-anchor\" id=\"box_9\"><\/div>\n\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-e605836 elementor-widget elementor-widget-heading\" data-id=\"e605836\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h4 class=\"elementor-heading-title elementor-size-default\">\u7a74\u306e\u6700\u5c0f\u30b3\u30fc\u30ca\u30fcR<\/h4>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<section class=\"elementor-section elementor-inner-section elementor-element elementor-element-4a63c6d elementor-section-content-middle print_wrap  print_break elementor-reverse-mobile elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"4a63c6d\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-bbd732b print_break\" data-id=\"bbd732b\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-d00dde4 elementor-widget elementor-widget-text-editor\" data-id=\"d00dde4\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p style=\"text-align: center;\">\u52a0\u5de5\u9650\u754c\u30fb\u5bf8\u6cd5\u7bc4\u56f2<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-5fd2566 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"5fd2566\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"table04 mT0 tableHover_single\" style=\"width: 100%;\"><tbody><tr><td style=\"text-align: left;\"><ul><li>\u7a74\u306e\u30b3\u30fc\u30ca\u30fcR\u3092\u6307\u5b9a\u3059\u308b\u5834\u5408\u306f\u30010.5mm\u4ee5\u4e0a\u306b\u3057\u3066\u304f\u3060\u3055\u3044<\/li><li>\uff08\u900f\u660e\u6a39\u8102\u30fb\u8907\u5408\u677f\u306f3mm\u4ee5\u4e0a\u304b\u3089\u3068\u306a\u308a\u307e\u3059\u3002\uff09<\/li><\/ul><\/td><\/tr><\/tbody><\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-a7a06c5\" data-id=\"a7a06c5\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-4cb32d6 elementor-widget elementor-widget-text-editor\" data-id=\"4cb32d6\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p style=\"text-align: center;\">\u90e8\u4f4d\u4f8b<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-741bf13 elementor-widget elementor-widget-image\" data-id=\"741bf13\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img loading=\"lazy\" decoding=\"async\" width=\"245\" height=\"142\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/fcpl_item_guideline_37.png\" class=\"attachment-large size-large wp-image-3137\" alt=\"\u90e8\u4f4d\u4f8b\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<\/div>\n\t\t\n\t\t\t<div id=\"daexthefu-container\"\n\t\t\t\tclass=\"daexthefu-container daexthefu-layout-stacked daexthefu-alignment-left\"\n\t\t\t\tdata-post-id=\"3474\">\n\n\t\t\t\t<div class=\"daexthefu-feedback\">\n\t\t\t\t\t<div class=\"daexthefu-text\">\n\t\t\t\t\t\t<h3 class=\"daexthefu-title\">\u3053\u306e\u8a18\u4e8b\u306f\u53c2\u8003\u306b\u306a\u308a\u307e\u3057\u305f\u304b\uff1f<\/h3>\n\t\t\t\t\t<\/div>\n\t\t\t\t\t<div class=\"daexthefu-buttons-container\">\n\t\t\t\t\t\t<div class=\"daexthefu-buttons\">\n\t\t\t\t\t\t\t\n\t\t\t<button type=\"button\" class=\"daexthefu-yes daexthefu-button daexthefu-button-type-icon-and-text\" data-value=\"1\">\n\t\t\t\t<span class=\"daexthefu-button-icon\">\n\t\t\t\t\n                <svg>\n                    <defs>\n                        <style>.thumb-up-cls-1{fill:#c9c9c9;}.thumb-up-cls-2{fill:#e1e1e1;}.thumb-up-cls-3{fill:#676767;}<\/style>\n                    <\/defs>\n                    <g id=\"thumb_up\">\n                        <path class=\"thumb-up-cls-2 daexthefu-icon-circle\" d=\"m24,3c11.58,0,21,9.42,21,21s-9.42,21-21,21S3,35.58,3,24,12.42,3,24,3m0-1C11.85,2,2,11.85,2,24s9.85,22,22,22,22-9.85,22-22S36.15,2,24,2h0Z\" \/>\n                        <g>\n                            <rect class=\"thumb-up-cls-3 daexthefu-icon-secondary-color\" x=\"10\" y=\"20\" width=\"6\" height=\"15\" rx=\"1.5\" ry=\"1.5\" \/>\n                            <path class=\"thumb-up-cls-1 daexthefu-icon-primary-color\" d=\"m30.57,9.06l-.49-.1c-.81-.17-1.61.35-1.78,1.16l-5.3,11.74c-.17.81,3.16,1.61,3.97,1.78l1.96.41c.81.17,1.61-.35,1.78-1.16l2.18-10.27c.34-1.61-.7-3.21-2.31-3.56Z\" \/>\n                            <path class=\"thumb-up-cls-1 daexthefu-icon-primary-color\" d=\"m38.17,20h-18.67c-.83,0-1.5.67-1.5,1.5v12c0,.83.67,1.5,1.5,1.5h16.27c.71,0,1.33-.5,1.47-1.21l2.4-12c.19-.93-.53-1.8-1.47-1.8Z\" \/>\n                        <\/g>\n                    <\/g>\n                <\/svg>\t\t\t\t\t\t<\/span>\n\t\t\t\t<span class=\"daexthefu-button-text\">\u5f79\u306b\u7acb\u3063\u305f\uff01<\/span>\n\t\t\t<\/button>\n\n\t\t\t\t\t\t\t\t\t\t\n\t\t\t<button type=\"button\" class=\"daexthefu-no daexthefu-button daexthefu-button-type-icon-and-text\" data-value=\"0\">\n\t\t\t\t<span class=\"daexthefu-button-icon\">\n\t\t\t\t\n                <svg>\n                    <defs>\n                        <style>.thumb-down-cls-1{fill:#c9c9c9;}.thumb-down-cls-2{fill:#e1e1e1;}.thumb-down-cls-3{fill:#676767;}<\/style>\n                    <\/defs>\n                    <g id=\"thumb_down\">\n                        <path class=\"thumb-down-cls-2 daexthefu-icon-circle\" d=\"m24,3c11.58,0,21,9.42,21,21s-9.42,21-21,21S3,35.58,3,24,12.42,3,24,3m0-1C11.85,2,2,11.85,2,24s9.85,22,22,22,22-9.85,22-22S36.15,2,24,2h0Z\" \/>\n                        <g>\n                            <rect class=\"thumb-down-cls-3 daexthefu-icon-secondary-color\" x=\"10\" y=\"13\" width=\"6\" height=\"15\" rx=\"1.5\" ry=\"1.5\" \/>\n                            <path class=\"thumb-down-cls-1 daexthefu-icon-primary-color\" d=\"m30.57,38.94l-.49.1c-.81.17-1.61-.35-1.78-1.16l-5.3-11.74c-.17-.81,3.16-1.61,3.97-1.78l1.96-.41c.81-.17,1.61.35,1.78,1.16l2.18,10.27c.34,1.61-.7,3.21-2.31,3.56Z\" \/>\n                            <path class=\"thumb-down-cls-1 daexthefu-icon-primary-color\" d=\"m38.17,28h-18.67c-.83,0-1.5-.67-1.5-1.5v-12c0-.83.67-1.5,1.5-1.5h16.27c.71,0,1.33.5,1.47,1.21l2.4,12c.19.93-.53,1.8-1.47,1.8Z\" \/>\n                        <\/g>\n                    <\/g>\n                <\/svg>\t\t\t\t\t\t<\/span>\n\t\t\t\t<span class=\"daexthefu-button-text\">\u5f79\u306b\u7acb\u305f\u306a\u304b\u3063\u305f<\/span>\n\t\t\t<\/button>\n\n\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\n\t\t\t\t<div class=\"daexthefu-comment\">\n\t\t\t\t\t<div class=\"daexthefu-comment-top-container\">\n\t\t\t\t\t\t<label id=\"daexthefu-comment-label\" class=\"daexthefu-comment-label\"><\/label>\n\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t\t<textarea id=\"daexthefu-comment-textarea\" class=\"daexthefu-comment-textarea\"\n\t\t\t\t\t\t\t\tplaceholder=\"\"\n\t\t\t\t\t\t\t\tmaxlength=\"\n\t\t\t\t\t\t\t\t400\t\t\t\t\t\t\t\t\t\"><\/textarea>\n\t\t\t\t\t<div class=\"daexthefu-comment-buttons-container\">\n\t\t\t\t\t\t<button class=\"daexthefu-comment-submit daexthefu-button\">\u9001\u4fe1<\/button>\n\t\t\t\t\t\t<button class=\"daexthefu-comment-cancel daexthefu-button\">\u53d6\u6d88<\/button>\n\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\n\t\t\t\t<div class=\"daexthefu-successful-submission-text\">\u8a55\u4fa1\u3044\u305f\u3060\u304d\u3042\u308a\u304c\u3068\u3046\u3054\u3056\u3044\u307e\u3057\u305f\u3002<\/div>\n\n\t\t\t<\/div>\n\n\t\t\t","protected":false},"excerpt":{"rendered":"<p>\u7a74\u3068\u7aef\u9762\u30fb\u7a74\u9593\u306e\u6700\u5c0f\u8ddd\u96e2 \u901a\u3057\u7a74\u306e\u6700\u5c0f\u5f84\u3000\u9577\u7a74\u30fb\u89d2\u7a74\u30fb\u305d\u306e\u4ed6\u7a74\u306e\u6700\u5c0f\u5e45 \u5207\u6b20\u5f62\u72b6\u306e\u6700\u5c0f\u30b5\u30a4\u30ba (\u5e73\u677f\u5c55\u958b\u6642\u306e)\u30b9\u30ea\u30c3\u30c8\u6700\u5c0f\u5e45 \u6700\u5c0f\u66f2\u3052\u9ad8\u3055 \u6700\u5c0f\u6bb5\u66f2\u3052\u9ad8\u3055 \u66f2\u3052\u5e45\u5bf8\u6cd5\u6307\u5b9a\u7bc4\u56f2\u3068\u92ed\u89d2\u66f2\u3052\u306e\u6700\u5c0f\u89d2\u5ea6 \u7a74\u3068\u66f2\u3052\u306e\u6700\u5c0f\u8ddd\u96e2\uff1a\u901a\u5e38 [&hellip;]<\/p>\n","protected":false},"author":15,"featured_media":0,"comment_status":"closed","ping_status":"closed","sticky":false,"template":"","format":"standard","meta":{"_helpful_status":1,"footnotes":""},"categories":[49],"tags":[64],"class_list":["post-3474","post","type-post","status-publish","format-standard","hentry","category-shm_guideline","tag-technical_shm"],"yoast_head":"<!-- This site is optimized with the Yoast SEO plugin v28.7 - https:\/\/yoast.com\/product\/yoast-seo-wordpress\/ -->\n<title>\u52a0\u5de5\u9650\u754c\u306e\u7bc4\u56f2 | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb<\/title>\n<meta name=\"robots\" content=\"index, follow, max-snippet:-1, max-image-preview:large, max-video-preview:-1\" \/>\n<link rel=\"canonical\" href=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_guideline\/3474\/\" \/>\n<meta property=\"og:locale\" content=\"ja_JP\" \/>\n<meta property=\"og:type\" content=\"article\" \/>\n<meta property=\"og:title\" content=\"\u52a0\u5de5\u9650\u754c\u306e\u7bc4\u56f2 | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\" \/>\n<meta property=\"og:description\" content=\"\u7a74\u3068\u7aef\u9762\u30fb\u7a74\u9593\u306e\u6700\u5c0f\u8ddd\u96e2 \u901a\u3057\u7a74\u306e\u6700\u5c0f\u5f84\u3000\u9577\u7a74\u30fb\u89d2\u7a74\u30fb\u305d\u306e\u4ed6\u7a74\u306e\u6700\u5c0f\u5e45 \u5207\u6b20\u5f62\u72b6\u306e\u6700\u5c0f\u30b5\u30a4\u30ba (\u5e73\u677f\u5c55\u958b\u6642\u306e)\u30b9\u30ea\u30c3\u30c8\u6700\u5c0f\u5e45 \u6700\u5c0f\u66f2\u3052\u9ad8\u3055 \u6700\u5c0f\u6bb5\u66f2\u3052\u9ad8\u3055 \u66f2\u3052\u5e45\u5bf8\u6cd5\u6307\u5b9a\u7bc4\u56f2\u3068\u92ed\u89d2\u66f2\u3052\u306e\u6700\u5c0f\u89d2\u5ea6 \u7a74\u3068\u66f2\u3052\u306e\u6700\u5c0f\u8ddd\u96e2\uff1a\u901a\u5e38 [&hellip;]\" \/>\n<meta property=\"og:url\" content=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_guideline\/3474\/\" \/>\n<meta property=\"og:site_name\" content=\"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\" \/>\n<meta property=\"article:published_time\" content=\"2026-06-14T15:00:59+00:00\" \/>\n<meta property=\"article:modified_time\" content=\"2026-06-19T10:12:19+00:00\" \/>\n<meta property=\"og:image\" content=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/fcpl_item_guideline_31.png\" \/>\n<meta name=\"author\" content=\"\u7f8e\u7d00\" \/>\n<meta name=\"twitter:card\" content=\"summary_large_image\" \/>\n<script type=\"application\/ld+json\" class=\"yoast-schema-graph\">{\"@context\":\"https:\\\/\\\/schema.org\",\"@graph\":[{\"@type\":\"Article\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_guideline\\\/3474\\\/#article\",\"isPartOf\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_guideline\\\/3474\\\/\"},\"author\":{\"name\":\"\u7f8e\u7d00\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#\\\/schema\\\/person\\\/6ff70d9094b7fdc810efdfcc2fdb63c5\"},\"headline\":\"\u52a0\u5de5\u9650\u754c\u306e\u7bc4\u56f2\",\"datePublished\":\"2026-06-14T15:00:59+00:00\",\"dateModified\":\"2026-06-19T10:12:19+00:00\",\"mainEntityOfPage\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_guideline\\\/3474\\\/\"},\"wordCount\":541,\"publisher\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#organization\"},\"image\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_guideline\\\/3474\\\/#primaryimage\"},\"thumbnailUrl\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2020\\\/01\\\/fcpl_item_guideline_31.png\",\"keywords\":[\"technical_shm\"],\"articleSection\":[\"\u8a2d\u8a08\u30ac\u30a4\u30c9\u30e9\u30a4\u30f3\"],\"inLanguage\":\"ja\"},{\"@type\":\"WebPage\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_guideline\\\/3474\\\/\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_guideline\\\/3474\\\/\",\"name\":\"\u52a0\u5de5\u9650\u754c\u306e\u7bc4\u56f2 | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\",\"isPartOf\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#website\"},\"primaryImageOfPage\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_guideline\\\/3474\\\/#primaryimage\"},\"image\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_guideline\\\/3474\\\/#primaryimage\"},\"thumbnailUrl\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2020\\\/01\\\/fcpl_item_guideline_31.png\",\"datePublished\":\"2026-06-14T15:00:59+00:00\",\"dateModified\":\"2026-06-19T10:12:19+00:00\",\"breadcrumb\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_guideline\\\/3474\\\/#breadcrumb\"},\"inLanguage\":\"ja\",\"potentialAction\":[{\"@type\":\"ReadAction\",\"target\":[\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_guideline\\\/3474\\\/\"]}]},{\"@type\":\"ImageObject\",\"inLanguage\":\"ja\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_guideline\\\/3474\\\/#primaryimage\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2020\\\/01\\\/fcpl_item_guideline_31.png\",\"contentUrl\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2020\\\/01\\\/fcpl_item_guideline_31.png\",\"width\":320,\"height\":238,\"caption\":\"\u90e8\u4f4d\u4f8b\"},{\"@type\":\"BreadcrumbList\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_guideline\\\/3474\\\/#breadcrumb\",\"itemListElement\":[{\"@type\":\"ListItem\",\"position\":1,\"name\":\"\u30db\u30fc\u30e0\",\"item\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/\"},{\"@type\":\"ListItem\",\"position\":2,\"name\":\"\u52a0\u5de5\u9650\u754c\u306e\u7bc4\u56f2\"}]},{\"@type\":\"WebSite\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#website\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/\",\"name\":\"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\",\"description\":\"\",\"publisher\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#organization\"},\"potentialAction\":[{\"@type\":\"SearchAction\",\"target\":{\"@type\":\"EntryPoint\",\"urlTemplate\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/?s={search_term_string}\"},\"query-input\":{\"@type\":\"PropertyValueSpecification\",\"valueRequired\":true,\"valueName\":\"search_term_string\"}}],\"inLanguage\":\"ja\"},{\"@type\":\"Organization\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#organization\",\"name\":\"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/\",\"logo\":{\"@type\":\"ImageObject\",\"inLanguage\":\"ja\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#\\\/schema\\\/logo\\\/image\\\/\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2019\\\/05\\\/A01-b_b4-1_jpeg.jpg\",\"contentUrl\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2019\\\/05\\\/A01-b_b4-1_jpeg.jpg\",\"width\":260,\"height\":70,\"caption\":\"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df\"},\"image\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#\\\/schema\\\/logo\\\/image\\\/\"}},{\"@type\":\"Person\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#\\\/schema\\\/person\\\/6ff70d9094b7fdc810efdfcc2fdb63c5\",\"name\":\"\u7f8e\u7d00\",\"image\":{\"@type\":\"ImageObject\",\"inLanguage\":\"ja\",\"@id\":\"https:\\\/\\\/secure.gravatar.com\\\/avatar\\\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g\",\"url\":\"https:\\\/\\\/secure.gravatar.com\\\/avatar\\\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g\",\"contentUrl\":\"https:\\\/\\\/secure.gravatar.com\\\/avatar\\\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g\",\"caption\":\"\u7f8e\u7d00\"},\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/author\\\/miki-aa3x-momosemisumi-co-jp\\\/\"}]}<\/script>\n<!-- \/ Yoast SEO plugin. -->","yoast_head_json":{"title":"\u52a0\u5de5\u9650\u754c\u306e\u7bc4\u56f2 | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","robots":{"index":"index","follow":"follow","max-snippet":"max-snippet:-1","max-image-preview":"max-image-preview:large","max-video-preview":"max-video-preview:-1"},"canonical":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_guideline\/3474\/","og_locale":"ja_JP","og_type":"article","og_title":"\u52a0\u5de5\u9650\u754c\u306e\u7bc4\u56f2 | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","og_description":"\u7a74\u3068\u7aef\u9762\u30fb\u7a74\u9593\u306e\u6700\u5c0f\u8ddd\u96e2 \u901a\u3057\u7a74\u306e\u6700\u5c0f\u5f84\u3000\u9577\u7a74\u30fb\u89d2\u7a74\u30fb\u305d\u306e\u4ed6\u7a74\u306e\u6700\u5c0f\u5e45 \u5207\u6b20\u5f62\u72b6\u306e\u6700\u5c0f\u30b5\u30a4\u30ba (\u5e73\u677f\u5c55\u958b\u6642\u306e)\u30b9\u30ea\u30c3\u30c8\u6700\u5c0f\u5e45 \u6700\u5c0f\u66f2\u3052\u9ad8\u3055 \u6700\u5c0f\u6bb5\u66f2\u3052\u9ad8\u3055 \u66f2\u3052\u5e45\u5bf8\u6cd5\u6307\u5b9a\u7bc4\u56f2\u3068\u92ed\u89d2\u66f2\u3052\u306e\u6700\u5c0f\u89d2\u5ea6 \u7a74\u3068\u66f2\u3052\u306e\u6700\u5c0f\u8ddd\u96e2\uff1a\u901a\u5e38 [&hellip;]","og_url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_guideline\/3474\/","og_site_name":"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","article_published_time":"2026-06-14T15:00:59+00:00","article_modified_time":"2026-06-19T10:12:19+00:00","og_image":[{"url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/fcpl_item_guideline_31.png","type":"","width":"","height":""}],"author":"\u7f8e\u7d00","twitter_card":"summary_large_image","schema":{"@context":"https:\/\/schema.org","@graph":[{"@type":"Article","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_guideline\/3474\/#article","isPartOf":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_guideline\/3474\/"},"author":{"name":"\u7f8e\u7d00","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/person\/6ff70d9094b7fdc810efdfcc2fdb63c5"},"headline":"\u52a0\u5de5\u9650\u754c\u306e\u7bc4\u56f2","datePublished":"2026-06-14T15:00:59+00:00","dateModified":"2026-06-19T10:12:19+00:00","mainEntityOfPage":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_guideline\/3474\/"},"wordCount":541,"publisher":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#organization"},"image":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_guideline\/3474\/#primaryimage"},"thumbnailUrl":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/fcpl_item_guideline_31.png","keywords":["technical_shm"],"articleSection":["\u8a2d\u8a08\u30ac\u30a4\u30c9\u30e9\u30a4\u30f3"],"inLanguage":"ja"},{"@type":"WebPage","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_guideline\/3474\/","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_guideline\/3474\/","name":"\u52a0\u5de5\u9650\u754c\u306e\u7bc4\u56f2 | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","isPartOf":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#website"},"primaryImageOfPage":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_guideline\/3474\/#primaryimage"},"image":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_guideline\/3474\/#primaryimage"},"thumbnailUrl":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/fcpl_item_guideline_31.png","datePublished":"2026-06-14T15:00:59+00:00","dateModified":"2026-06-19T10:12:19+00:00","breadcrumb":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_guideline\/3474\/#breadcrumb"},"inLanguage":"ja","potentialAction":[{"@type":"ReadAction","target":["https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_guideline\/3474\/"]}]},{"@type":"ImageObject","inLanguage":"ja","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_guideline\/3474\/#primaryimage","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/fcpl_item_guideline_31.png","contentUrl":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/fcpl_item_guideline_31.png","width":320,"height":238,"caption":"\u90e8\u4f4d\u4f8b"},{"@type":"BreadcrumbList","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_guideline\/3474\/#breadcrumb","itemListElement":[{"@type":"ListItem","position":1,"name":"\u30db\u30fc\u30e0","item":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/"},{"@type":"ListItem","position":2,"name":"\u52a0\u5de5\u9650\u754c\u306e\u7bc4\u56f2"}]},{"@type":"WebSite","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#website","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/","name":"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","description":"","publisher":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#organization"},"potentialAction":[{"@type":"SearchAction","target":{"@type":"EntryPoint","urlTemplate":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/?s={search_term_string}"},"query-input":{"@type":"PropertyValueSpecification","valueRequired":true,"valueName":"search_term_string"}}],"inLanguage":"ja"},{"@type":"Organization","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#organization","name":"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/","logo":{"@type":"ImageObject","inLanguage":"ja","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/logo\/image\/","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2019\/05\/A01-b_b4-1_jpeg.jpg","contentUrl":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2019\/05\/A01-b_b4-1_jpeg.jpg","width":260,"height":70,"caption":"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df"},"image":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/logo\/image\/"}},{"@type":"Person","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/person\/6ff70d9094b7fdc810efdfcc2fdb63c5","name":"\u7f8e\u7d00","image":{"@type":"ImageObject","inLanguage":"ja","@id":"https:\/\/secure.gravatar.com\/avatar\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g","url":"https:\/\/secure.gravatar.com\/avatar\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g","contentUrl":"https:\/\/secure.gravatar.com\/avatar\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g","caption":"\u7f8e\u7d00"},"url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/author\/miki-aa3x-momosemisumi-co-jp\/"}]}},"views":392880,"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts\/3474","targetHints":{"allow":["GET"]}}],"collection":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts"}],"about":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/types\/post"}],"author":[{"embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/users\/15"}],"replies":[{"embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/comments?post=3474"}],"version-history":[{"count":418,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts\/3474\/revisions"}],"predecessor-version":[{"id":36791,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts\/3474\/revisions\/36791"}],"wp:attachment":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/media?parent=3474"}],"wp:term":[{"taxonomy":"category","embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/categories?post=3474"},{"taxonomy":"post_tag","embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/tags?post=3474"}],"curies":[{"name":"wp","href":"https:\/\/api.w.org\/{rel}","templated":true}]}}
