{"id":3586,"date":"2025-11-17T00:00:41","date_gmt":"2025-11-16T15:00:41","guid":{"rendered":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/?p=3586"},"modified":"2026-02-02T10:10:52","modified_gmt":"2026-02-02T01:10:52","slug":"%e7%9a%bf%e7%a9%b4%e3%81%ae%e3%83%a2%e3%83%87%e3%83%aa%e3%83%b3%e3%82%b0%e3%83%ab%e3%83%bc%e3%83%ab-%e7%9a%bf%e7%a9%b4%e3%81%ae%e8%aa%8d%e8%ad%98-%e7%9a%bf%e7%a9%b4%e3%81%ae%e3%82%b5%e3%82%a4%e3%82%ba","status":"publish","type":"post","link":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_guideline\/3586\/","title":{"rendered":"\u76bf\u7a74\u306e\u30e2\u30c7\u30ea\u30f3\u30b0\u3068\u9078\u629e\u3067\u304d\u308b\u30b5\u30a4\u30ba"},"content":{"rendered":"\t\t<div data-elementor-type=\"wp-post\" data-elementor-id=\"3586\" class=\"elementor elementor-3586\">\n\t\t\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-10f8b0a elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"10f8b0a\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-5bb42b4\" data-id=\"5bb42b4\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-99252f8 elementor-widget elementor-widget-menu-anchor\" data-id=\"99252f8\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"menu-anchor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t<div class=\"elementor-menu-anchor\" id=\"box_1\"><\/div>\n\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-e722735 elementor-widget elementor-widget-heading\" data-id=\"e722735\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h2 class=\"elementor-heading-title elementor-size-default\">\u76bf\u7a74\u306e\u30e2\u30c7\u30ea\u30f3\u30b0\u30eb\u30fc\u30eb<\/h2>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-6480dfb elementor-widget elementor-widget-text-editor\" data-id=\"6480dfb\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p>\u76bf\uff08\u5186\u9310\u5f62\u72b6\uff09\u3092\u691c\u51fa\u3057\u305f\u3068\u304d\u3001\u76bf\u7a74\u3068\u3057\u3066\u8b58\u5225\u3055\u308c\u307e\u3059\u3002<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-5f10241e tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"5f10241e\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"tableHover_single\">\n<tbody>\n<tr>\n<th class=\"tblColCFStyle01_3586\">\u30e2\u30c7\u30ea\u30f3\u30b0\u4f5c\u6210\u30eb\u30fc\u30eb<\/th>\n<th>\u5f62\u72b6\u4f8b<\/th>\n<\/tr>\n<tr>\n<td class=\"pCFStyle01_3586\">\u76bf\uff08\u5186\u9310\u5f62\u72b6\uff09\u306e\u89d2\u5ea6\u306f90\u00b0\u3067\u30e2\u30c7\u30ea\u30f3\u30b0\u3057\u3066\u304f\u3060\u3055\u3044\n\u7a74\u5f84\u306e\u6bd4\u7387 D\/d \u306f\u3001d \u304c4.0[mm] \u4ee5\u4e0b\u306e\u3068\u304d1.4\u3092\u8d85\u3048\u308b\u6bd4\u7387\u3001 d \u304c4.0[mm] \u3092\u8d85\u3048\u308b\u3068\u304d1.7\u3092\u8d85\u3048\u308b\u6bd4\u7387\u306b\u3057\u3066\u304f\u3060\u3055\u3044<\/td>\n<td><img decoding=\"async\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/fcpl_item_guideline_30.png\" alt=\"\u5f62\u72b6\u4f8b\" \/><\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-913e5ce elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"913e5ce\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-5b4c1e5\" data-id=\"5b4c1e5\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-7f2607c elementor-widget elementor-widget-menu-anchor\" data-id=\"7f2607c\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"menu-anchor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t<div class=\"elementor-menu-anchor\" id=\"box_2\"><\/div>\n\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-ce724c0 elementor-widget elementor-widget-heading\" data-id=\"ce724c0\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h2 class=\"elementor-heading-title elementor-size-default\">\u76bf\u7a74\u306e\u8a8d\u8b58<\/h2>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-1c8ac17 elementor-widget elementor-widget-heading\" data-id=\"1c8ac17\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<div class=\"elementor-heading-title elementor-size-default\">\u76bf\u7a74\u306f\u4e0b\u8a18\u306e\u901a\u308a2\u3064\u306e\u30b9\u30c6\u30c3\u30d7\u3092\u7d4c\u3066\u8a8d\u8b58\u3055\u308c\u307e\u3059\u3002\n<\/div>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-eec4fd9 elementor-widget elementor-widget-heading\" data-id=\"eec4fd9\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h3 class=\"elementor-heading-title elementor-size-default\">STEP1\n<\/h3>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-514aa73 elementor-widget elementor-widget-text-editor\" data-id=\"514aa73\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<ul><li>meviy\u306e\u7a74\u60c5\u5831\u30c7\u30fc\u30bf\u30d9\u30fc\u30b9\u306b\u306f\u30013D CAD\u6bce\u306e\u76bf\u7a74\u306e\u4e0b\u7a74\u5f84\u304c\u767b\u9332\u3055\u308c\u3066\u304a\u308a\u3001\u691c\u51fa\u3055\u308c\u305f\u7a74\u5f84\u3068\u7167\u5408\u3055\u308c\u307e\u3059\uff08\u4e0b\u8868\uff09\u3002<\/li><\/ul>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-78ebbbd tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"78ebbbd\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"table04 tableHover\">\n<tbody>\n<tr>\n<th class=\"tblColCFStyle02_3586\" rowspan=\"2\">\u76bf\u7a74\u547c\u3073\u5f84<\/th>\n<th colspan=\"9\">\u30d5\u30a1\u30a4\u30eb\u62e1\u5f35\u5b50<\/th>\n<\/tr>\n<tr>\n<th  class=\"tblColCFStyle01_3586\" colspan=\"6\">\n<ul>\n \t<li>STEP(.step \/ .stp)<\/li>\n \t<li>Parasolid(.x_t\/.x_b\/.xmt \/.xmt_txt)ACIS(.sat\/.sab)JT(.jt)<\/li>\n \t<li>PRC(.prc)<\/li>\n \t<li>I-deas(.arc\/.unv)<\/li>\n \t<li>Autodesk Inventor(.ipt)<\/li>\n \t<li>CATIA V5(.CATPart)<\/li>\n<\/ul>\n<\/th>\n<th>Siemens PLM-NX(.prt) \u203b1\n\nCreo(.neu\/.prt\/.xpr)\n\nSolid Edge(.par\/.pwd)<\/th>\n<th>iCAD SX(.icd)<\/th>\n<th>SOLIDWORKS\n(.sldprt)Siemens PLM-NX(.prt) \u203b2<\/th>\n<\/tr>\n<tr>\n<th class=\"tblColCFStyle02_3586\">M3<\/th>\n<td class=\"tblColCFStyle02_3586\">3.20<\/td>\n<td class=\"tblColCFStyle02_3586\">3.30<\/td>\n<td class=\"tblColCFStyle02_3586\">3.40<\/td>\n<td class=\"tblColCFStyle02_3586\">3.58<\/td>\n<td class=\"tblColCFStyle02_3586\">3.60<\/td>\n<td class=\"tblColCFStyle02_3586\">4.00<\/td>\n<td>3.20<\/td>\n<td>3.30<\/td>\n<td>3.40<\/td>\n<\/tr>\n<tr>\n<th>M4<\/th>\n<td>4.30<\/td>\n<td>4.40<\/td>\n<td>4.50<\/td>\n<td>4.60<\/td>\n<td>4.68<\/td>\n<td>4.80<\/td>\n<td>4.30<\/td>\n<td>4.40<\/td>\n<td>4.50<\/td>\n<\/tr>\n<tr>\n<th>M5<\/th>\n<td>5.30<\/td>\n<td>5.50<\/td>\n<td>5.80<\/td>\n<td>6.00<\/td>\n<td>6.18<\/td>\n<td>6.50<\/td>\n<td>5.30<\/td>\n<td>5.50<\/td>\n<td>5.50<\/td>\n<\/tr>\n<tr>\n<th>M6<\/th>\n<td>6.40<\/td>\n<td>6.60<\/td>\n<td>6.82<\/td>\n<td>7.00<\/td>\n<td>&#8211;<\/td>\n<td>&#8211;<\/td>\n<td>6.40<\/td>\n<td>6.60<\/td>\n<td>6.60<\/td>\n<\/tr>\n<tr>\n<th>M8<\/th>\n<td>8.40<\/td>\n<td>8.54<\/td>\n<td>9.00<\/td>\n<td>9.22<\/td>\n<td>10.00<\/td>\n<td>&#8211;<\/td>\n<td>8.40<\/td>\n<td>8.54<\/td>\n<td>9.00<\/td>\n<\/tr>\n<tr>\n<th>M10<\/th>\n<td>10.50<\/td>\n<td>10.62<\/td>\n<td>11.00<\/td>\n<td>11.27<\/td>\n<td>12.00<\/td>\n<td>&#8211;<\/td>\n<td>10.50<\/td>\n<td>10.62<\/td>\n<td>11.00<\/td>\n<\/tr>\n<tr>\n<th>M12<\/th>\n<td>13.00<\/td>\n<td>13.50<\/td>\n<td>14.50<\/td>\n<td>\uff0d<\/td>\n<td>\uff0d<\/td>\n<td>\uff0d<\/td>\n<td>13.00<\/td>\n<td>\uff0d<\/td>\n<td>13.50<\/td>\n<\/tr>\n<tr>\n<th>M14<\/th>\n<td>15.00<\/td>\n<td>15.50<\/td>\n<td>16.50<\/td>\n<td>\uff0d<\/td>\n<td>\uff0d<\/td>\n<td>\uff0d<\/td>\n<td>\uff0d<\/td>\n<td>\uff0d<\/td>\n<td>\uff0d<\/td>\n<\/tr>\n<tr>\n<th>M16<\/th>\n<td>17.00<\/td>\n<td>17.50<\/td>\n<td>18.50<\/td>\n<td>\uff0d<\/td>\n<td>\uff0d<\/td>\n<td>\uff0d<\/td>\n<td>17.00<\/td>\n<td>\uff0d<\/td>\n<td>17.50<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-5ef6574 elementor-widget elementor-widget-text-editor\" data-id=\"5ef6574\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p>\u203b1 Siemens PLM-NX\u306eJIS\u30e2\u30c7\u30eb\u3067\u306e\u4e0b\u7a74\u5f84<br \/>\u203b2 Siemens PLM-NX\u306eISO\u30e2\u30c7\u30eb\u3067\u306e\u4e0b\u7a74\u5f84<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-1c09fc4 print_page elementor-widget elementor-widget-heading\" data-id=\"1c09fc4\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h3 class=\"elementor-heading-title elementor-size-default\">STEP2<\/h3>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-7f87ff0 elementor-widget elementor-widget-text-editor\" data-id=\"7f87ff0\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<ul>\n<li>STEP1\u3067\u5f15\u304d\u3042\u305f\u3089\u306a\u304b\u3063\u305f\u5834\u5408\u3001\u4e0b\u7a74\u5f84\u7bc4\u56f2\u306b\u5fdc\u3058\u3066\u547c\u3073\u5f84\u304c\u6c7a\u5b9a\u3055\u308c\u307e\u3059\u3002\uff08\u4e0b\u8868\uff09<\/li>\n<li>\u691c\u51fa\u3055\u308c\u305f\u7a74\u5f84\u304c\u4e0b\u7a74\u5f84\u306e\u30ea\u30b9\u30c8\u306b\u5f15\u304d\u5f53\u305f\u3089\u306a\u3044\u6642\u306f\u3001\u901a\u3057\u7a74(\u307e\u305f\u306f\u30bf\u30c3\u30d7\u7a74)\u3068\u3057\u3066\u6271\u308f\u308c\u307e\u3059\u3002\u305f\u3060\u3057\u3001\u7a74\u7a2e\u3084\u7a74\u5f84\u306f\u898b\u7a4d\u8a2d\u5b9a\u4e2d\u306b\u5909\u66f4\u3059\u308b\u4e8b\u304c\u3067\u304d\u307e\u3059\u3002<\/li>\n<\/ul>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-47fdec2 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"47fdec2\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"tableHover_single\">\n<tbody>\n<tr>\n<th class=\"tblColCFStyle02_3586\">\u76bf\u7a74\u547c\u3073\u5f84<\/th>\n<th class=\"tblColCFStyle03_3586\">\u4e0b\u7a74\u5f84(d)\u7bc4\u56f2<\/th>\n<th>\u5f62\u72b6\u4f8b<\/th>\n<\/tr>\n<tr>\n<th>M3<\/th>\n<td>3.2\u2266d\u22664.0<\/td>\n<td rowspan=\"9\"><img decoding=\"async\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2022\/05\/3586_01.png\" alt=\"\u5f62\u72b6\u4f8b\" width=\"300\" \/><\/td>\n<\/tr>\n<tr>\n<th>M4<\/th>\n<td>4.3\u2266d\u22664.8<\/td>\n<\/tr>\n<tr>\n<th>M5<\/th>\n<td>5.3\u2266d\u22666.5<\/td>\n<\/tr>\n<tr>\n<th>M6<\/th>\n<td>6.3\u2266d\u22667.0<\/td>\n<\/tr>\n<tr>\n<th>M8<\/th>\n<td>8.4\u2266d\u226610.0<\/td>\n<\/tr>\n<tr>\n<th>M10<\/th>\n<td>10.5\u2266d\u226612.0<\/td>\n<\/tr>\n<tr>\n<th>M12<\/th>\n<td>13.0\u2266d\u226614.5<\/td>\n<\/tr>\n<tr>\n<th>M14<\/th>\n<td>15.0\u2266d\u226616.5<\/td>\n<\/tr>\n<tr>\n<th>M16<\/th>\n<td>17.0\u2266d\u226618.5<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-6b24825 print_block elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"6b24825\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-a823f3f\" data-id=\"a823f3f\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-b3dbf07 elementor-widget elementor-widget-menu-anchor\" data-id=\"b3dbf07\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"menu-anchor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t<div class=\"elementor-menu-anchor\" id=\"box_3\"><\/div>\n\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-40df3df elementor-widget elementor-widget-heading\" data-id=\"40df3df\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h2 class=\"elementor-heading-title elementor-size-default\">\u76bf\u7a74\u306e\u30b5\u30a4\u30ba\u9078\u629e<\/h2>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-c748f5f elementor-widget elementor-widget-text-editor\" data-id=\"c748f5f\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p>\u6750\u8cea\u30fb\u677f\u539a\u3054\u3068\u306b\u9078\u629e\u3067\u304d\u308b\u30b5\u30a4\u30ba\u304c\u7570\u306a\u308a\u307e\u3059\u3002\u4e0b\u8868\u3092\u53c2\u7167\u3057\u3066\u304f\u3060\u3055\u3044\u3002<br>\u30d1\u30f3\u30c1\u30f3\u30b0\u30e1\u30bf\u30eb\u6750\u3084\u30b7\u30e0\u30d7\u30ec\u30fc\u30c8\u6750\uff08 SPCC(\u30b7\u30e0\u7528), SUS304(H)(\u30b7\u30e0\u7528) \uff09\u3067\u306f\u76bf\u7a74\u3092\u9078\u629e\u3067\u304d\u307e\u305b\u3093\u3002<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-c12f98a tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"c12f98a\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<div class=\"print_block\">\n\n&nbsp;\n\n&nbsp;\n<div class=\"tableStickyHead\">\n<table class=\"table04 tableHover\">\n<thead>\n<tr>\n<th class=\"tblColCFStyle04_3586\">\u6750\u8cea<\/th>\n<th class=\"tblColCFStyle02_3586\">\u677f\u539a<\/th>\n<th colspan=\"9\">\u76bf\u7a74\u30dc\u30eb\u30c8\u547c\u3073\u5f84<\/th>\n<\/tr>\n<\/thead>\n<\/table>\n<\/div>\n<table class=\"table04 tableHover mT0 print_break\">\n<tbody>\n<tr>\n<th class=\"tblColCFStyle04_3586\" rowspan=\"9\">\n<ul>\n \t<li>SPCC<\/li>\n \t<li>SPHC<\/li>\n \t<li>SS400<\/li>\n \t<li>SECC<\/li>\n<\/ul>\n<\/th>\n<th class=\"tblColCFStyle02_3586\">2.0<\/th>\n<td class=\"noBorder\">M3<\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td><\/td>\n<\/tr>\n<tr>\n<th>2.3<\/th>\n<td class=\"noBorder\">M3<\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td><\/td>\n<\/tr>\n<tr>\n<th>3.2<\/th>\n<td class=\"noBorder\">M3<\/td>\n<td class=\"noBorder\">M4<\/td>\n<td class=\"noBorder\">M5<\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td><\/td>\n<\/tr>\n<tr>\n<th>4.5<\/th>\n<td class=\"noBorder\">M3<\/td>\n<td class=\"noBorder\">M4<\/td>\n<td class=\"noBorder\">M5<\/td>\n<td class=\"noBorder\">M6<\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td><\/td>\n<\/tr>\n<tr>\n<th>6.0<\/th>\n<td class=\"noBorder\">M3<\/td>\n<td class=\"noBorder\">M4<\/td>\n<td class=\"noBorder\">M5<\/td>\n<td class=\"noBorder\">M6<\/td>\n<td class=\"noBorder\">M8<\/td>\n<td class=\"noBorder\">M10<\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td><\/td>\n<\/tr>\n<tr>\n<th>9.0<\/th>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\">M5<\/td>\n<td class=\"noBorder\">M6<\/td>\n<td class=\"noBorder\">M8<\/td>\n<td class=\"noBorder\">M10<\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td><\/td>\n<\/tr>\n<tr>\n<th>10.0<\/th>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\">M5<\/td>\n<td class=\"noBorder\">M6<\/td>\n<td class=\"noBorder\">M8<\/td>\n<td class=\"noBorder\">M10<\/td>\n<td class=\"noBorder\">M12<\/td>\n<td class=\"noBorder\">M14<\/td>\n<td>M16<\/td>\n<\/tr>\n<tr>\n<th>12.0<\/th>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\">M5<\/td>\n<td class=\"noBorder\">M6<\/td>\n<td class=\"noBorder\">M8<\/td>\n<td class=\"noBorder\">M10<\/td>\n<td class=\"noBorder\">M12<\/td>\n<td class=\"noBorder\">M14<\/td>\n<td>M16<\/td>\n<\/tr>\n<tr>\n<th>16.0<\/th>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\">M5<\/td>\n<td class=\"noBorder\">M6<\/td>\n<td class=\"noBorder\">M8<\/td>\n<td class=\"noBorder\">M10<\/td>\n<td class=\"noBorder\">M12<\/td>\n<td class=\"noBorder\">M14<\/td>\n<td>M16<\/td>\n<\/tr>\n<tr>\n<th rowspan=\"9\">\n<ul>\n \t<li>SUS304(No.1)<\/li>\n \t<li>SUS304(2B)<\/li>\n<li>SUS304(2B) \u7247\u9762\u4fdd\u8b77\u30b7\u30fc\u30c8\u4ed8\n<\/li>\n \t<li>SUS304(\u7247\u9762#400\u7814\u78e8)<\/li>\n \t<li>SUS304(\u7247\u9762\u30d8\u30a2\u30e9\u30a4\u30f3)<\/li>\n \t<li>SUS316(2B)<\/li>\n \t<li>SUS430(2B)<\/li>\n \t<li>A5052<\/li>\n \t<li>A5052(\u30a2\u30eb\u30de\u30a4\u30c8\u92fc\u677f\u767d)<\/li>\n \t<li>A5052(\u30a2\u30eb\u30de\u30a4\u30c8\u92fc\u677f\u9ed2)<\/li>\n<\/ul>\n<\/th>\n<th>2.0<\/th>\n<td class=\"noBorder\">M3<\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td><\/td>\n<\/tr>\n<tr>\n<th>2.5<\/th>\n<td class=\"noBorder\">M3<\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td><\/td>\n<\/tr>\n<tr>\n<th>3.0<\/th>\n<td class=\"noBorder\">M3<\/td>\n<td class=\"noBorder\">M4<\/td>\n<td class=\"noBorder\">M5<\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td><\/td>\n<\/tr>\n<tr>\n<th>4.0<\/th>\n<td class=\"noBorder\">M3<\/td>\n<td class=\"noBorder\">M4<\/td>\n<td class=\"noBorder\">M5<\/td>\n<td class=\"noBorder\">M6<\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td><\/td>\n<\/tr>\n<tr>\n<th>5.0<\/th>\n<td class=\"noBorder\">M3<\/td>\n<td class=\"noBorder\">M4<\/td>\n<td class=\"noBorder\">M5<\/td>\n<td class=\"noBorder\">M6<\/td>\n<td class=\"noBorder\">M8<\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td><\/td>\n<\/tr>\n<tr>\n<th>6.0<\/th>\n<td class=\"noBorder\">M3 (\u203b1)<\/td>\n<td class=\"noBorder\">M4<\/td>\n<td class=\"noBorder\">M5<\/td>\n<td class=\"noBorder\">M6<\/td>\n<td class=\"noBorder\">M8<\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td><\/td>\n<\/tr>\n<tr>\n<th>9.0<\/th>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\">M5<\/td>\n<td class=\"noBorder\">M6<\/td>\n<td class=\"noBorder\">M8<\/td>\n<td class=\"noBorder\">M10<\/td>\n<td class=\"noBorder\">M12<\/td>\n<td class=\"noBorder\">M14<\/td>\n<td>M16<\/td>\n<\/tr>\n<tr>\n<th>10.0<\/th>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\">M5<\/td>\n<td class=\"noBorder\">M6<\/td>\n<td class=\"noBorder\">M8<\/td>\n<td class=\"noBorder\">M10<\/td>\n<td class=\"noBorder\">M12<\/td>\n<td class=\"noBorder\">M14<\/td>\n<td>M16<\/td>\n<\/tr>\n<tr>\n<th>12.0<\/th>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\">M5<\/td>\n<td class=\"noBorder\">M6<\/td>\n<td class=\"noBorder\">M8<\/td>\n<td class=\"noBorder\">M10<\/td>\n<td class=\"noBorder\">M12<\/td>\n<td class=\"noBorder\">M14<\/td>\n<td>M16<\/td>\n<\/tr>\n<tr>\n<th class=\"txt\" rowspan=\"2\">\n<ul>\n \t<li>C1020(\u7121\u9178\u7d20\u9285)<\/li>\n \t<li>C1100(\u30bf\u30d5\u30d4\u30c3\u30c1\u9285)<\/li>\n \t<li>C2801P(\u771f\u936e\u30fb\u9ec4\u9285)<\/li>\n<\/ul>\n<\/th>\n<th class=\"txt\">2.0<\/th>\n<td class=\"noBorder\">M3<\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td><\/td>\n<\/tr>\n<tr>\n<th class=\"txt\">3.0<\/th>\n<td class=\"noBorder\">M3<\/td>\n<td class=\"noBorder\">M4<\/td>\n<td class=\"noBorder\">M5<\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td><\/td>\n<\/tr>\n<tr>\n<th class=\"txt\" rowspan=\"4\">\n<ul>\n \t<li>PET<\/li>\n \t<li>\u30a2\u30af\u30ea\u30eb<\/li>\n \t<li>\u30dd\u30ea\u30ab\u30fc\u30dc\u30cd\u30fc\u30c8<\/li>\n \t<li>\u5869\u30d3<\/li>\n<\/ul>\n<\/th>\n<th class=\"txt\">3.0<\/th>\n<td class=\"noBorder\">M3<\/td>\n<td class=\"noBorder\">M4<\/td>\n<td class=\"noBorder\">M5<\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td><\/td>\n<\/tr>\n<tr>\n<th class=\"txt\">5.0<\/th>\n<td class=\"noBorder\">M3<\/td>\n<td class=\"noBorder\">M4<\/td>\n<td class=\"noBorder\">M5<\/td>\n<td class=\"noBorder\">M6<\/td>\n<td class=\"noBorder\">M8<\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td><\/td>\n<\/tr>\n<tr>\n<th class=\"txt\">8.0 (\u203b2)<\/th>\n<td class=\"noBorder\">M3<\/td>\n<td class=\"noBorder\">M4<\/td>\n<td class=\"noBorder\">M5<\/td>\n<td class=\"noBorder\">M6<\/td>\n<td class=\"noBorder\">M8<\/td>\n<td class=\"noBorder\">M10<\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td><\/td>\n<\/tr>\n<tr>\n<th class=\"txt\">10.0 (\u203b3)<\/th>\n<td class=\"noBorder\">M3<\/td>\n<td class=\"noBorder\">M4<\/td>\n<td class=\"noBorder\">M5<\/td>\n<td class=\"noBorder\">M6<\/td>\n<td class=\"noBorder\">M8<\/td>\n<td class=\"noBorder\">M10<\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td><\/td>\n<\/tr>\n<tr>\n<th class=\"txt\">\u30a2\u30eb\u30df\u8907\u5408\u677f(\u82af\u6750\uff1a\u767a\u6ce1\u30dd\u30ea\u30a8\u30c1\u30ec\u30f3\u6a39\u8102) \u203b4<\/th>\n<th class=\"txt\">3.0<\/th>\n<td class=\"noBorder\">M3<\/td>\n<td class=\"noBorder\">M4<\/td>\n<td class=\"noBorder\">M5<\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td class=\"noBorder\"><\/td>\n<td><\/td>\n<\/tr>\n<\/tbody>\n<\/table>\n<\/div>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-dd0ff45 elementor-widget elementor-widget-text-editor\" data-id=\"dd0ff45\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<ul><li>\u203b1 A5052(\u30a2\u30eb\u30df)\u306b\u9650\u308b<\/li><li>\u203b2 PET(\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u900f\u660e)\/\u30a2\u30af\u30ea\u30eb(\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u900f\u660e)\u306b\u9650\u308b<\/li><li>\u203b3 \u30a2\u30af\u30ea\u30eb(\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\u30fb\u900f\u660e)\u306b\u9650\u308b<\/li><li>\u203b4 \u30a2\u30eb\u30df\u8907\u5408\u677f\u306e\u76bf\u7a74\u52a0\u5de5\u306e\u4ed5\u4e0a\u304c\u308a\u306f<a href=\"\/help\/ja\/technical_info\/shm_conditions\/28340\/\">\u3053\u3061\u3089<\/a>\u3092\u78ba\u8a8d\u3057\u3066\u304f\u3060\u3055\u3044\u3002<\/li><\/ul>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-eecfaab elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"eecfaab\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-d0843e1\" data-id=\"d0843e1\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap\">\n\t\t\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<\/div>\n\t\t\n\t\t\t<div id=\"daexthefu-container\"\n\t\t\t\tclass=\"daexthefu-container daexthefu-layout-stacked daexthefu-alignment-left\"\n\t\t\t\tdata-post-id=\"3586\">\n\n\t\t\t\t<div class=\"daexthefu-feedback\">\n\t\t\t\t\t<div class=\"daexthefu-text\">\n\t\t\t\t\t\t<h3 class=\"daexthefu-title\">\u3053\u306e\u8a18\u4e8b\u306f\u53c2\u8003\u306b\u306a\u308a\u307e\u3057\u305f\u304b\uff1f<\/h3>\n\t\t\t\t\t<\/div>\n\t\t\t\t\t<div class=\"daexthefu-buttons-container\">\n\t\t\t\t\t\t<div class=\"daexthefu-buttons\">\n\t\t\t\t\t\t\t\n\t\t\t<button type=\"button\" class=\"daexthefu-yes daexthefu-button daexthefu-button-type-icon-and-text\" data-value=\"1\">\n\t\t\t\t<span class=\"daexthefu-button-icon\">\n\t\t\t\t\n                <svg>\n                    <defs>\n                        <style>.thumb-up-cls-1{fill:#c9c9c9;}.thumb-up-cls-2{fill:#e1e1e1;}.thumb-up-cls-3{fill:#676767;}<\/style>\n                    <\/defs>\n                    <g id=\"thumb_up\">\n                        <path class=\"thumb-up-cls-2 daexthefu-icon-circle\" d=\"m24,3c11.58,0,21,9.42,21,21s-9.42,21-21,21S3,35.58,3,24,12.42,3,24,3m0-1C11.85,2,2,11.85,2,24s9.85,22,22,22,22-9.85,22-22S36.15,2,24,2h0Z\" \/>\n                        <g>\n                            <rect class=\"thumb-up-cls-3 daexthefu-icon-secondary-color\" x=\"10\" y=\"20\" width=\"6\" height=\"15\" rx=\"1.5\" ry=\"1.5\" \/>\n                            <path class=\"thumb-up-cls-1 daexthefu-icon-primary-color\" d=\"m30.57,9.06l-.49-.1c-.81-.17-1.61.35-1.78,1.16l-5.3,11.74c-.17.81,3.16,1.61,3.97,1.78l1.96.41c.81.17,1.61-.35,1.78-1.16l2.18-10.27c.34-1.61-.7-3.21-2.31-3.56Z\" \/>\n                            <path class=\"thumb-up-cls-1 daexthefu-icon-primary-color\" d=\"m38.17,20h-18.67c-.83,0-1.5.67-1.5,1.5v12c0,.83.67,1.5,1.5,1.5h16.27c.71,0,1.33-.5,1.47-1.21l2.4-12c.19-.93-.53-1.8-1.47-1.8Z\" \/>\n                        <\/g>\n                    <\/g>\n                <\/svg>\t\t\t\t\t\t<\/span>\n\t\t\t\t<span class=\"daexthefu-button-text\">\u5f79\u306b\u7acb\u3063\u305f\uff01<\/span>\n\t\t\t<\/button>\n\n\t\t\t\t\t\t\t\t\t\t\n\t\t\t<button type=\"button\" class=\"daexthefu-no daexthefu-button daexthefu-button-type-icon-and-text\" data-value=\"0\">\n\t\t\t\t<span class=\"daexthefu-button-icon\">\n\t\t\t\t\n                <svg>\n                    <defs>\n                        <style>.thumb-down-cls-1{fill:#c9c9c9;}.thumb-down-cls-2{fill:#e1e1e1;}.thumb-down-cls-3{fill:#676767;}<\/style>\n                    <\/defs>\n                    <g id=\"thumb_down\">\n                        <path class=\"thumb-down-cls-2 daexthefu-icon-circle\" d=\"m24,3c11.58,0,21,9.42,21,21s-9.42,21-21,21S3,35.58,3,24,12.42,3,24,3m0-1C11.85,2,2,11.85,2,24s9.85,22,22,22,22-9.85,22-22S36.15,2,24,2h0Z\" \/>\n                        <g>\n                            <rect class=\"thumb-down-cls-3 daexthefu-icon-secondary-color\" x=\"10\" y=\"13\" width=\"6\" height=\"15\" rx=\"1.5\" ry=\"1.5\" \/>\n                            <path class=\"thumb-down-cls-1 daexthefu-icon-primary-color\" d=\"m30.57,38.94l-.49.1c-.81.17-1.61-.35-1.78-1.16l-5.3-11.74c-.17-.81,3.16-1.61,3.97-1.78l1.96-.41c.81-.17,1.61.35,1.78,1.16l2.18,10.27c.34,1.61-.7,3.21-2.31,3.56Z\" \/>\n                            <path class=\"thumb-down-cls-1 daexthefu-icon-primary-color\" d=\"m38.17,28h-18.67c-.83,0-1.5-.67-1.5-1.5v-12c0-.83.67-1.5,1.5-1.5h16.27c.71,0,1.33.5,1.47,1.21l2.4,12c.19.93-.53,1.8-1.47,1.8Z\" \/>\n                        <\/g>\n                    <\/g>\n                <\/svg>\t\t\t\t\t\t<\/span>\n\t\t\t\t<span class=\"daexthefu-button-text\">\u5f79\u306b\u7acb\u305f\u306a\u304b\u3063\u305f<\/span>\n\t\t\t<\/button>\n\n\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\n\t\t\t\t<div class=\"daexthefu-comment\">\n\t\t\t\t\t<div class=\"daexthefu-comment-top-container\">\n\t\t\t\t\t\t<label id=\"daexthefu-comment-label\" class=\"daexthefu-comment-label\"><\/label>\n\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t\t<textarea id=\"daexthefu-comment-textarea\" class=\"daexthefu-comment-textarea\"\n\t\t\t\t\t\t\t\tplaceholder=\"\"\n\t\t\t\t\t\t\t\tmaxlength=\"\n\t\t\t\t\t\t\t\t400\t\t\t\t\t\t\t\t\t\"><\/textarea>\n\t\t\t\t\t<div class=\"daexthefu-comment-buttons-container\">\n\t\t\t\t\t\t<button class=\"daexthefu-comment-submit daexthefu-button\">\u9001\u4fe1<\/button>\n\t\t\t\t\t\t<button class=\"daexthefu-comment-cancel daexthefu-button\">\u53d6\u6d88<\/button>\n\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\n\t\t\t\t<div class=\"daexthefu-successful-submission-text\">\u8a55\u4fa1\u3044\u305f\u3060\u304d\u3042\u308a\u304c\u3068\u3046\u3054\u3056\u3044\u307e\u3057\u305f\u3002<\/div>\n\n\t\t\t<\/div>\n\n\t\t\t","protected":false},"excerpt":{"rendered":"<p>\u76bf\u7a74\u306e\u30e2\u30c7\u30ea\u30f3\u30b0\u30eb\u30fc\u30eb \u76bf\uff08\u5186\u9310\u5f62\u72b6\uff09\u3092\u691c\u51fa\u3057\u305f\u3068\u304d\u3001\u76bf\u7a74\u3068\u3057\u3066\u8b58\u5225\u3055\u308c\u307e\u3059\u3002 \u30e2\u30c7\u30ea\u30f3\u30b0\u4f5c\u6210\u30eb\u30fc\u30eb \u5f62\u72b6\u4f8b \u76bf\uff08\u5186\u9310\u5f62\u72b6\uff09\u306e\u89d2\u5ea6\u306f90\u00b0\u3067\u30e2\u30c7\u30ea\u30f3\u30b0\u3057\u3066\u304f\u3060\u3055\u3044 \u7a74\u5f84\u306e\u6bd4\u7387 D\/d \u306f\u3001d \u304c4.0[mm] \u4ee5\u4e0b\u306e\u3068\u304d [&hellip;]<\/p>\n","protected":false},"author":15,"featured_media":0,"comment_status":"closed","ping_status":"closed","sticky":false,"template":"","format":"standard","meta":{"_helpful_status":1,"footnotes":""},"categories":[49],"tags":[64],"class_list":["post-3586","post","type-post","status-publish","format-standard","hentry","category-shm_guideline","tag-technical_shm"],"yoast_head":"<!-- This site is optimized with the Yoast SEO plugin v28.7 - https:\/\/yoast.com\/product\/yoast-seo-wordpress\/ -->\n<title>\u76bf\u7a74\u306e\u30e2\u30c7\u30ea\u30f3\u30b0\u3068\u9078\u629e\u3067\u304d\u308b\u30b5\u30a4\u30ba | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb<\/title>\n<meta name=\"robots\" content=\"index, follow, max-snippet:-1, max-image-preview:large, max-video-preview:-1\" \/>\n<link rel=\"canonical\" href=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_guideline\/3586\/\" \/>\n<meta property=\"og:locale\" content=\"ja_JP\" \/>\n<meta property=\"og:type\" content=\"article\" \/>\n<meta property=\"og:title\" content=\"\u76bf\u7a74\u306e\u30e2\u30c7\u30ea\u30f3\u30b0\u3068\u9078\u629e\u3067\u304d\u308b\u30b5\u30a4\u30ba | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\" \/>\n<meta property=\"og:description\" content=\"\u76bf\u7a74\u306e\u30e2\u30c7\u30ea\u30f3\u30b0\u30eb\u30fc\u30eb \u76bf\uff08\u5186\u9310\u5f62\u72b6\uff09\u3092\u691c\u51fa\u3057\u305f\u3068\u304d\u3001\u76bf\u7a74\u3068\u3057\u3066\u8b58\u5225\u3055\u308c\u307e\u3059\u3002 \u30e2\u30c7\u30ea\u30f3\u30b0\u4f5c\u6210\u30eb\u30fc\u30eb \u5f62\u72b6\u4f8b \u76bf\uff08\u5186\u9310\u5f62\u72b6\uff09\u306e\u89d2\u5ea6\u306f90\u00b0\u3067\u30e2\u30c7\u30ea\u30f3\u30b0\u3057\u3066\u304f\u3060\u3055\u3044 \u7a74\u5f84\u306e\u6bd4\u7387 D\/d \u306f\u3001d \u304c4.0[mm] \u4ee5\u4e0b\u306e\u3068\u304d [&hellip;]\" \/>\n<meta property=\"og:url\" content=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_guideline\/3586\/\" \/>\n<meta property=\"og:site_name\" content=\"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\" \/>\n<meta property=\"article:published_time\" content=\"2025-11-16T15:00:41+00:00\" \/>\n<meta property=\"article:modified_time\" content=\"2026-02-02T01:10:52+00:00\" \/>\n<meta property=\"og:image\" content=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/fcpl_item_guideline_30.png\" \/>\n<meta name=\"author\" content=\"\u7f8e\u7d00\" \/>\n<meta name=\"twitter:card\" content=\"summary_large_image\" \/>\n<script type=\"application\/ld+json\" class=\"yoast-schema-graph\">{\"@context\":\"https:\\\/\\\/schema.org\",\"@graph\":[{\"@type\":\"Article\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_guideline\\\/3586\\\/#article\",\"isPartOf\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_guideline\\\/3586\\\/\"},\"author\":{\"name\":\"\u7f8e\u7d00\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#\\\/schema\\\/person\\\/6ff70d9094b7fdc810efdfcc2fdb63c5\"},\"headline\":\"\u76bf\u7a74\u306e\u30e2\u30c7\u30ea\u30f3\u30b0\u3068\u9078\u629e\u3067\u304d\u308b\u30b5\u30a4\u30ba\",\"datePublished\":\"2025-11-16T15:00:41+00:00\",\"dateModified\":\"2026-02-02T01:10:52+00:00\",\"mainEntityOfPage\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_guideline\\\/3586\\\/\"},\"wordCount\":234,\"publisher\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#organization\"},\"image\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_guideline\\\/3586\\\/#primaryimage\"},\"thumbnailUrl\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2020\\\/01\\\/fcpl_item_guideline_30.png\",\"keywords\":[\"technical_shm\"],\"articleSection\":[\"\u8a2d\u8a08\u30ac\u30a4\u30c9\u30e9\u30a4\u30f3\"],\"inLanguage\":\"ja\"},{\"@type\":\"WebPage\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_guideline\\\/3586\\\/\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_guideline\\\/3586\\\/\",\"name\":\"\u76bf\u7a74\u306e\u30e2\u30c7\u30ea\u30f3\u30b0\u3068\u9078\u629e\u3067\u304d\u308b\u30b5\u30a4\u30ba | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\",\"isPartOf\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#website\"},\"primaryImageOfPage\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_guideline\\\/3586\\\/#primaryimage\"},\"image\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_guideline\\\/3586\\\/#primaryimage\"},\"thumbnailUrl\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2020\\\/01\\\/fcpl_item_guideline_30.png\",\"datePublished\":\"2025-11-16T15:00:41+00:00\",\"dateModified\":\"2026-02-02T01:10:52+00:00\",\"breadcrumb\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_guideline\\\/3586\\\/#breadcrumb\"},\"inLanguage\":\"ja\",\"potentialAction\":[{\"@type\":\"ReadAction\",\"target\":[\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_guideline\\\/3586\\\/\"]}]},{\"@type\":\"ImageObject\",\"inLanguage\":\"ja\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_guideline\\\/3586\\\/#primaryimage\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2020\\\/01\\\/fcpl_item_guideline_30.png\",\"contentUrl\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2020\\\/01\\\/fcpl_item_guideline_30.png\",\"width\":364,\"height\":209,\"caption\":\"\u5f62\u72b6\u4f8b\"},{\"@type\":\"BreadcrumbList\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_guideline\\\/3586\\\/#breadcrumb\",\"itemListElement\":[{\"@type\":\"ListItem\",\"position\":1,\"name\":\"\u30db\u30fc\u30e0\",\"item\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/\"},{\"@type\":\"ListItem\",\"position\":2,\"name\":\"\u76bf\u7a74\u306e\u30e2\u30c7\u30ea\u30f3\u30b0\u3068\u9078\u629e\u3067\u304d\u308b\u30b5\u30a4\u30ba\"}]},{\"@type\":\"WebSite\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#website\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/\",\"name\":\"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\",\"description\":\"\",\"publisher\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#organization\"},\"potentialAction\":[{\"@type\":\"SearchAction\",\"target\":{\"@type\":\"EntryPoint\",\"urlTemplate\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/?s={search_term_string}\"},\"query-input\":{\"@type\":\"PropertyValueSpecification\",\"valueRequired\":true,\"valueName\":\"search_term_string\"}}],\"inLanguage\":\"ja\"},{\"@type\":\"Organization\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#organization\",\"name\":\"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/\",\"logo\":{\"@type\":\"ImageObject\",\"inLanguage\":\"ja\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#\\\/schema\\\/logo\\\/image\\\/\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2019\\\/05\\\/A01-b_b4-1_jpeg.jpg\",\"contentUrl\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2019\\\/05\\\/A01-b_b4-1_jpeg.jpg\",\"width\":260,\"height\":70,\"caption\":\"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df\"},\"image\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#\\\/schema\\\/logo\\\/image\\\/\"}},{\"@type\":\"Person\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#\\\/schema\\\/person\\\/6ff70d9094b7fdc810efdfcc2fdb63c5\",\"name\":\"\u7f8e\u7d00\",\"image\":{\"@type\":\"ImageObject\",\"inLanguage\":\"ja\",\"@id\":\"https:\\\/\\\/secure.gravatar.com\\\/avatar\\\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g\",\"url\":\"https:\\\/\\\/secure.gravatar.com\\\/avatar\\\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g\",\"contentUrl\":\"https:\\\/\\\/secure.gravatar.com\\\/avatar\\\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g\",\"caption\":\"\u7f8e\u7d00\"},\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/author\\\/miki-aa3x-momosemisumi-co-jp\\\/\"}]}<\/script>\n<!-- \/ Yoast SEO plugin. -->","yoast_head_json":{"title":"\u76bf\u7a74\u306e\u30e2\u30c7\u30ea\u30f3\u30b0\u3068\u9078\u629e\u3067\u304d\u308b\u30b5\u30a4\u30ba | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","robots":{"index":"index","follow":"follow","max-snippet":"max-snippet:-1","max-image-preview":"max-image-preview:large","max-video-preview":"max-video-preview:-1"},"canonical":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_guideline\/3586\/","og_locale":"ja_JP","og_type":"article","og_title":"\u76bf\u7a74\u306e\u30e2\u30c7\u30ea\u30f3\u30b0\u3068\u9078\u629e\u3067\u304d\u308b\u30b5\u30a4\u30ba | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","og_description":"\u76bf\u7a74\u306e\u30e2\u30c7\u30ea\u30f3\u30b0\u30eb\u30fc\u30eb \u76bf\uff08\u5186\u9310\u5f62\u72b6\uff09\u3092\u691c\u51fa\u3057\u305f\u3068\u304d\u3001\u76bf\u7a74\u3068\u3057\u3066\u8b58\u5225\u3055\u308c\u307e\u3059\u3002 \u30e2\u30c7\u30ea\u30f3\u30b0\u4f5c\u6210\u30eb\u30fc\u30eb \u5f62\u72b6\u4f8b \u76bf\uff08\u5186\u9310\u5f62\u72b6\uff09\u306e\u89d2\u5ea6\u306f90\u00b0\u3067\u30e2\u30c7\u30ea\u30f3\u30b0\u3057\u3066\u304f\u3060\u3055\u3044 \u7a74\u5f84\u306e\u6bd4\u7387 D\/d \u306f\u3001d \u304c4.0[mm] \u4ee5\u4e0b\u306e\u3068\u304d [&hellip;]","og_url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_guideline\/3586\/","og_site_name":"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","article_published_time":"2025-11-16T15:00:41+00:00","article_modified_time":"2026-02-02T01:10:52+00:00","og_image":[{"url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/fcpl_item_guideline_30.png","type":"","width":"","height":""}],"author":"\u7f8e\u7d00","twitter_card":"summary_large_image","schema":{"@context":"https:\/\/schema.org","@graph":[{"@type":"Article","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_guideline\/3586\/#article","isPartOf":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_guideline\/3586\/"},"author":{"name":"\u7f8e\u7d00","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/person\/6ff70d9094b7fdc810efdfcc2fdb63c5"},"headline":"\u76bf\u7a74\u306e\u30e2\u30c7\u30ea\u30f3\u30b0\u3068\u9078\u629e\u3067\u304d\u308b\u30b5\u30a4\u30ba","datePublished":"2025-11-16T15:00:41+00:00","dateModified":"2026-02-02T01:10:52+00:00","mainEntityOfPage":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_guideline\/3586\/"},"wordCount":234,"publisher":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#organization"},"image":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_guideline\/3586\/#primaryimage"},"thumbnailUrl":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/fcpl_item_guideline_30.png","keywords":["technical_shm"],"articleSection":["\u8a2d\u8a08\u30ac\u30a4\u30c9\u30e9\u30a4\u30f3"],"inLanguage":"ja"},{"@type":"WebPage","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_guideline\/3586\/","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_guideline\/3586\/","name":"\u76bf\u7a74\u306e\u30e2\u30c7\u30ea\u30f3\u30b0\u3068\u9078\u629e\u3067\u304d\u308b\u30b5\u30a4\u30ba | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","isPartOf":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#website"},"primaryImageOfPage":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_guideline\/3586\/#primaryimage"},"image":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_guideline\/3586\/#primaryimage"},"thumbnailUrl":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/fcpl_item_guideline_30.png","datePublished":"2025-11-16T15:00:41+00:00","dateModified":"2026-02-02T01:10:52+00:00","breadcrumb":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_guideline\/3586\/#breadcrumb"},"inLanguage":"ja","potentialAction":[{"@type":"ReadAction","target":["https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_guideline\/3586\/"]}]},{"@type":"ImageObject","inLanguage":"ja","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_guideline\/3586\/#primaryimage","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/fcpl_item_guideline_30.png","contentUrl":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/fcpl_item_guideline_30.png","width":364,"height":209,"caption":"\u5f62\u72b6\u4f8b"},{"@type":"BreadcrumbList","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_guideline\/3586\/#breadcrumb","itemListElement":[{"@type":"ListItem","position":1,"name":"\u30db\u30fc\u30e0","item":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/"},{"@type":"ListItem","position":2,"name":"\u76bf\u7a74\u306e\u30e2\u30c7\u30ea\u30f3\u30b0\u3068\u9078\u629e\u3067\u304d\u308b\u30b5\u30a4\u30ba"}]},{"@type":"WebSite","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#website","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/","name":"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","description":"","publisher":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#organization"},"potentialAction":[{"@type":"SearchAction","target":{"@type":"EntryPoint","urlTemplate":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/?s={search_term_string}"},"query-input":{"@type":"PropertyValueSpecification","valueRequired":true,"valueName":"search_term_string"}}],"inLanguage":"ja"},{"@type":"Organization","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#organization","name":"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/","logo":{"@type":"ImageObject","inLanguage":"ja","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/logo\/image\/","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2019\/05\/A01-b_b4-1_jpeg.jpg","contentUrl":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2019\/05\/A01-b_b4-1_jpeg.jpg","width":260,"height":70,"caption":"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df"},"image":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/logo\/image\/"}},{"@type":"Person","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/person\/6ff70d9094b7fdc810efdfcc2fdb63c5","name":"\u7f8e\u7d00","image":{"@type":"ImageObject","inLanguage":"ja","@id":"https:\/\/secure.gravatar.com\/avatar\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g","url":"https:\/\/secure.gravatar.com\/avatar\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g","contentUrl":"https:\/\/secure.gravatar.com\/avatar\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g","caption":"\u7f8e\u7d00"},"url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/author\/miki-aa3x-momosemisumi-co-jp\/"}]}},"views":37330,"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts\/3586","targetHints":{"allow":["GET"]}}],"collection":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts"}],"about":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/types\/post"}],"author":[{"embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/users\/15"}],"replies":[{"embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/comments?post=3586"}],"version-history":[{"count":86,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts\/3586\/revisions"}],"predecessor-version":[{"id":35502,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts\/3586\/revisions\/35502"}],"wp:attachment":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/media?parent=3586"}],"wp:term":[{"taxonomy":"category","embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/categories?post=3586"},{"taxonomy":"post_tag","embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/tags?post=3586"}],"curies":[{"name":"wp","href":"https:\/\/api.w.org\/{rel}","templated":true}]}}
