{"id":3612,"date":"2025-10-20T00:00:24","date_gmt":"2025-10-19T15:00:24","guid":{"rendered":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/?p=3612"},"modified":"2025-10-20T09:38:04","modified_gmt":"2025-10-20T00:38:04","slug":"%e8%a6%8b%e7%a9%8d%e3%82%82%e3%82%8a%e3%81%8c%e5%8f%af%e8%83%bd%e3%81%aa%e7%a9%b4%e5%8a%a0%e5%b7%a5","status":"publish","type":"post","link":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/3612\/","title":{"rendered":"\u898b\u7a4d\u3082\u308a\u53ef\u80fd\u5f62\u72b6"},"content":{"rendered":"\t\t<div data-elementor-type=\"wp-post\" data-elementor-id=\"3612\" class=\"elementor elementor-3612\">\n\t\t\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-1a167ca elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"1a167ca\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-f8b10a7\" data-id=\"f8b10a7\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-79624d3 elementor-widget elementor-widget-text-editor\" data-id=\"79624d3\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\u5916\u5f62\u3084\u5bf8\u6cd5\u6761\u4ef6\u306b\u3088\u308a\u4e0b\u8a18\u5f62\u72b6\u3067\u3082\u88fd\u4f5c\u3067\u304d\u306a\u3044\u5834\u5408\u304c\u3054\u3056\u3044\u307e\u3059\u3002\u88fd\u4f5c\u3067\u304d\u306a\u3044\u5834\u5408\u306f\u3001\u3054\u6ce8\u6587\u5f8c\u306bmeviy\u30b5\u30dd\u30fc\u30c8\u304b\u3089\u3054\u9023\u7d61\u3044\u305f\u3057\u307e\u3059\u3002\n\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-fbea03d elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"fbea03d\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-67a16c7\" data-id=\"67a16c7\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-d83d208 elementor-widget elementor-widget-text-editor\" data-id=\"d83d208\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<span class=\"pCFStyle01_3612\">\u5f62\u72b6<\/span>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-9f3736c elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"9f3736c\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-d878ce1\" data-id=\"d878ce1\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<section class=\"elementor-section elementor-inner-section elementor-element elementor-element-a33819c elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"a33819c\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-20 elementor-inner-column elementor-element elementor-element-886d53e\" data-id=\"886d53e\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-992d276 elementor-drop-cap-yes elementor-drop-cap-view-default elementor-widget elementor-widget-text-editor\" data-id=\"992d276\" data-element_type=\"widget\" data-e-type=\"widget\" data-settings=\"{&quot;drop_cap&quot;:&quot;yes&quot;}\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"tblCFStyle01_3612\">\n<tbody>\n<tr>\n<th><b>1<\/b><\/th>\n<td>\u5e73\u677f<\/td>\n<\/tr>\n<tr>\n<td colspan=\"2\"><img decoding=\"async\" class=\"aligncenter\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/fcpl_item_correspond1.png\" alt=\"\u5e73\u677f\" \/><\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-20 elementor-inner-column elementor-element elementor-element-4725d8a\" data-id=\"4725d8a\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-b83fc0c elementor-drop-cap-yes elementor-drop-cap-view-default elementor-widget elementor-widget-text-editor\" data-id=\"b83fc0c\" data-element_type=\"widget\" data-e-type=\"widget\" data-settings=\"{&quot;drop_cap&quot;:&quot;yes&quot;}\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"tblCFStyle01_3612\">\n<tbody>\n<tr>\n<th><b>2<\/b><\/th>\n<td>\u5186\u5f62<\/td>\n<\/tr>\n<tr>\n<td colspan=\"2\"><img decoding=\"async\" class=\"aligncenter\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/fcpl_item_correspond2.png\" alt=\"\u5186\u5f62\" \/><\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-20 elementor-inner-column elementor-element elementor-element-3dcf9b8\" data-id=\"3dcf9b8\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-1e48a93 elementor-drop-cap-yes elementor-drop-cap-view-default elementor-widget elementor-widget-text-editor\" data-id=\"1e48a93\" data-element_type=\"widget\" data-e-type=\"widget\" data-settings=\"{&quot;drop_cap&quot;:&quot;yes&quot;}\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"tblCFStyle01_3612\">\n<tbody>\n<tr>\n<th><b>3<\/b><\/th>\n<td>L\u66f2\u3052<\/td>\n<\/tr>\n<tr>\n<td colspan=\"2\"><img decoding=\"async\" class=\"aligncenter\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/fcpl_item_correspond3.png\" alt=\"L\u66f2\u3052\" \/><\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-20 elementor-inner-column elementor-element elementor-element-b741272\" data-id=\"b741272\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-1331677 elementor-drop-cap-yes elementor-drop-cap-view-default elementor-widget elementor-widget-text-editor\" data-id=\"1331677\" data-element_type=\"widget\" data-e-type=\"widget\" data-settings=\"{&quot;drop_cap&quot;:&quot;yes&quot;}\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"tblCFStyle01_3612\">\n<tbody>\n<tr>\n<th><b>4<\/b><\/th>\n<td>Z\u66f2\u3052<\/td>\n<\/tr>\n<tr>\n<td colspan=\"2\"><img decoding=\"async\" class=\"aligncenter\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/fcpl_item_correspond4.png\" alt=\"Z\u66f2\u3052\" \/><\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-20 elementor-inner-column elementor-element elementor-element-0ada5f5\" data-id=\"0ada5f5\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-3df7384 elementor-drop-cap-yes elementor-drop-cap-view-default elementor-widget elementor-widget-text-editor\" data-id=\"3df7384\" data-element_type=\"widget\" data-e-type=\"widget\" data-settings=\"{&quot;drop_cap&quot;:&quot;yes&quot;}\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"tblCFStyle01_3612\">\n<tbody>\n<tr>\n<th><b>5<\/b><\/th>\n<td>\u51f8\u66f2\u3052<\/td>\n<\/tr>\n<tr>\n<td colspan=\"2\"><img decoding=\"async\" class=\"aligncenter\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/fcpl_item_correspond5.png\" alt=\"\u51f8\u66f2\u3052\" \/><\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-inner-section elementor-element elementor-element-b536f90 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"b536f90\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-20 elementor-inner-column elementor-element elementor-element-2713d35\" data-id=\"2713d35\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-f02c5ac elementor-drop-cap-yes elementor-drop-cap-view-default elementor-widget elementor-widget-text-editor\" data-id=\"f02c5ac\" data-element_type=\"widget\" data-e-type=\"widget\" data-settings=\"{&quot;drop_cap&quot;:&quot;yes&quot;}\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"tblCFStyle01_3612\">\n<tbody>\n<tr>\n<th><b>6<\/b><\/th>\n<td>\u30b3\u306e\u5b57\u66f2\u3052<\/td>\n<\/tr>\n<tr>\n<td colspan=\"2\"><img decoding=\"async\" class=\"aligncenter\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/fcpl_item_correspond6.png\" alt=\"\u30b3\u306e\u5b57\u66f2\u3052\" \/><\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-20 elementor-inner-column elementor-element elementor-element-83aa08a\" data-id=\"83aa08a\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-68721a3 elementor-drop-cap-yes elementor-drop-cap-view-default elementor-widget elementor-widget-text-editor\" data-id=\"68721a3\" data-element_type=\"widget\" data-e-type=\"widget\" data-settings=\"{&quot;drop_cap&quot;:&quot;yes&quot;}\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"tblCFStyle01_3612\">\n<tbody>\n<tr>\n<th><b>7<\/b><\/th>\n<td>\u89d2\u5ea6\u6307\u5b9a\u66f2\u3052(L\u66f2\u3052\u5f62\u72b6)<\/td>\n<\/tr>\n<tr>\n<td colspan=\"2\"><img decoding=\"async\" class=\"aligncenter\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/fcpl_item_correspond7.png\" alt=\"\u89d2\u5ea6\u6307\u5b9a\u66f2\u3052(L\u66f2\u3052\u5f62\u72b6)\" \/><\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-20 elementor-inner-column elementor-element elementor-element-7564e53\" data-id=\"7564e53\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-e0d6f9f elementor-drop-cap-yes elementor-drop-cap-view-default elementor-widget elementor-widget-text-editor\" data-id=\"e0d6f9f\" data-element_type=\"widget\" data-e-type=\"widget\" data-settings=\"{&quot;drop_cap&quot;:&quot;yes&quot;}\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"tblCFStyle01_3612\">\n<tbody>\n<tr>\n<th><b>8<\/b><\/th>\n<td>\u89d2\u5ea6\u6307\u5b9a\u66f2\u3052(L\u66f2\u3052\u5f62\u72b6\u4ee5\u5916)<\/td>\n<\/tr>\n<tr>\n<td colspan=\"2\"><img decoding=\"async\" class=\"aligncenter\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/fcpl_item_correspond8.png\" alt=\"\u89d2\u5ea6\u6307\u5b9a\u66f2\u3052(L\u66f2\u3052\u5f62\u72b6\u4ee5\u5916)\" \/><\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-20 elementor-inner-column elementor-element elementor-element-fc5c0ad\" data-id=\"fc5c0ad\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-17887c1 elementor-drop-cap-yes elementor-drop-cap-view-default elementor-widget elementor-widget-text-editor\" data-id=\"17887c1\" data-element_type=\"widget\" data-e-type=\"widget\" data-settings=\"{&quot;drop_cap&quot;:&quot;yes&quot;}\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"tblCFStyle01_3612\">\n<tbody>\n<tr>\n<th><b>9<\/b><\/th>\n<td>\u30d5\u30e9\u30f3\u30b8\u4ed8\u5f62\u72b6<\/td>\n<\/tr>\n<tr>\n<td colspan=\"2\"><img decoding=\"async\" class=\"aligncenter\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/fcpl_item_correspond9.png\" alt=\"\u30d5\u30e9\u30f3\u30b8\u4ed8\u5f62\u72b6\" \/><\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-20 elementor-inner-column elementor-element elementor-element-20eadb9\" data-id=\"20eadb9\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-4d33b0f elementor-drop-cap-yes elementor-drop-cap-view-default elementor-widget elementor-widget-text-editor\" data-id=\"4d33b0f\" data-element_type=\"widget\" data-e-type=\"widget\" data-settings=\"{&quot;drop_cap&quot;:&quot;yes&quot;}\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"tblCFStyle01_3612\">\n<tbody>\n<tr>\n<th><b>10<\/b><\/th>\n<td>\u66f2\u3052\u90e8\u5207\u6b20\u304d\u5f62\u72b6<\/td>\n<\/tr>\n<tr>\n<td colspan=\"2\"><img decoding=\"async\" class=\"aligncenter\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/fcpl_item_correspond10.png\" alt=\"\u66f2\u3052\u90e8\u5207\u6b20\u304d\u5f62\u72b6\" \/><\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-inner-section elementor-element elementor-element-334018b elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"334018b\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-20 elementor-inner-column elementor-element elementor-element-2c58c2a\" data-id=\"2c58c2a\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-45237ab elementor-drop-cap-yes elementor-drop-cap-view-default elementor-widget elementor-widget-text-editor\" data-id=\"45237ab\" data-element_type=\"widget\" data-e-type=\"widget\" data-settings=\"{&quot;drop_cap&quot;:&quot;yes&quot;}\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"tblCFStyle01_3612\">\n<tbody>\n<tr>\n<th><b>11<\/b><\/th>\n<td>\u5207\u8d77\u3053\u3057\u5f62\u72b6(\u90e8\u5206\u66f2\u3052)<\/td>\n<\/tr>\n<tr>\n<td colspan=\"2\"><img decoding=\"async\" class=\"aligncenter\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/fcpl_item_correspond11.png\" alt=\"\u5207\u8d77\u3053\u3057\u5f62\u72b6(\u90e8\u5206\u66f2\u3052)\" \/><\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-20 elementor-inner-column elementor-element elementor-element-70dcf63\" data-id=\"70dcf63\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-2eda043 elementor-drop-cap-yes elementor-drop-cap-view-default elementor-widget elementor-widget-text-editor\" data-id=\"2eda043\" data-element_type=\"widget\" data-e-type=\"widget\" data-settings=\"{&quot;drop_cap&quot;:&quot;yes&quot;}\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"tblCFStyle01_3612\">\n<tbody>\n<tr>\n<th><b>12<\/b><\/th>\n<td>\u5207\u6b20\u304d(\u89d2)<\/td>\n<\/tr>\n<tr>\n<td colspan=\"2\"><img decoding=\"async\" class=\"aligncenter\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/fcpl_item_correspond12.png\" alt=\"\u5207\u6b20\u304d(\u89d2)\" \/><\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-20 elementor-inner-column elementor-element elementor-element-4e81f62\" data-id=\"4e81f62\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-8964cfd elementor-drop-cap-yes elementor-drop-cap-view-default elementor-widget elementor-widget-text-editor\" data-id=\"8964cfd\" data-element_type=\"widget\" data-e-type=\"widget\" data-settings=\"{&quot;drop_cap&quot;:&quot;yes&quot;}\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"tblCFStyle01_3612\">\n<tbody>\n<tr>\n<th><b>13<\/b><\/th>\n<td>\u5207\u6b20\u304d\uff08U\u306e\u5b57\uff09<\/td>\n<\/tr>\n<tr>\n<td colspan=\"2\"><img decoding=\"async\" class=\"aligncenter\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/fcpl_item_correspond13.png\" alt=\"\u5207\u6b20\u304d\uff08U\u306e\u5b57\uff09\" \/><\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-20 elementor-inner-column elementor-element elementor-element-3059ade\" data-id=\"3059ade\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-da171ac elementor-drop-cap-yes elementor-drop-cap-view-default elementor-widget elementor-widget-text-editor\" data-id=\"da171ac\" data-element_type=\"widget\" data-e-type=\"widget\" data-settings=\"{&quot;drop_cap&quot;:&quot;yes&quot;}\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"tblCFStyle01_3612\">\n<tbody>\n<tr>\n<th><b>14<\/b><\/th>\n<td>\u9003\u3052(\u89d2)<\/td>\n<\/tr>\n<tr>\n<td colspan=\"2\"><img decoding=\"async\" class=\"aligncenter\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/fcpl_item_correspond14.png\" alt=\"\u9003\u3052(\u89d2)\" \/><\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-20 elementor-inner-column elementor-element elementor-element-91f33cf\" data-id=\"91f33cf\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-1c5cea6 print_page elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"1c5cea6\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-dd11f87\" data-id=\"dd11f87\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-77d8c3e elementor-widget elementor-widget-text-editor\" data-id=\"77d8c3e\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<span class=\"pCFStyle01_3612\">\u52a0\u5de5\u304c\u96e3\u3057\u3044\u5f62\u72b6\uff08\u4ee3\u8868\u4f8b\uff09<\/span>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-7e0d7ca elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"7e0d7ca\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-62eca47\" data-id=\"62eca47\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-5026629 elementor-widget elementor-widget-text-editor\" data-id=\"5026629\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p>\u4ee5\u4e0b\u306e\u3088\u3046\u306a\u5f62\u72b6\u542b\u3081\u3001\u8a2d\u5099\u306e\u52a0\u5de5\u9650\u754c\u306b\u3088\u308a\u88fd\u4f5c\u3067\u304d\u306a\u3044\u5834\u5408\u304c\u3054\u3056\u3044\u307e\u3059\u3002\u305d\u306e\u969b\u306f\u3001meviy\u30b5\u30dd\u30fc\u30c8\u3088\u308a\u3054\u9023\u7d61\u3044\u305f\u3057\u307e\u3059\u3002<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<section class=\"elementor-section elementor-inner-section elementor-element elementor-element-e0a193a elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"e0a193a\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-25 elementor-inner-column elementor-element elementor-element-f6b1f28\" data-id=\"f6b1f28\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-6cdd84f elementor-drop-cap-yes elementor-drop-cap-view-default elementor-widget elementor-widget-text-editor\" data-id=\"6cdd84f\" data-element_type=\"widget\" data-e-type=\"widget\" data-settings=\"{&quot;drop_cap&quot;:&quot;yes&quot;}\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"tblCFStyle02_3612\">\n<tbody>\n<tr>\n<th><b>1<\/b><\/th>\n<td>\u90e8\u54c1\u7e4b\u304e<\/td>\n<\/tr>\n<tr style=\"height: 160px;\">\n<td style=\"width: 100%; background-color: #f7f7f7; text-align: center;\" colspan=\"2\"><img decoding=\"async\" class=\"aligncenter\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2022\/12\/3578_01.png\" alt=\"\u90e8\u54c1\u7e4b\u304e\" \/><\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-25 elementor-inner-column elementor-element elementor-element-75d7ebd\" data-id=\"75d7ebd\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-192b8c0 elementor-drop-cap-yes elementor-drop-cap-view-default elementor-widget elementor-widget-text-editor\" data-id=\"192b8c0\" data-element_type=\"widget\" data-e-type=\"widget\" data-settings=\"{&quot;drop_cap&quot;:&quot;yes&quot;}\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"tblCFStyle02_3612\">\n<tbody>\n<tr>\n<th><b>2<\/b><\/th>\n<td>\u6587\u5b57\u629c\u304d<\/td>\n<\/tr>\n<tr style=\"height: 160px;\">\n<td style=\"width: 100%; background-color: #f7f7f7; text-align: center;\" colspan=\"2\"><img decoding=\"async\" class=\"aligncenter\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2022\/12\/3578_02.png\" alt=\"\u6587\u5b57\u629c\u304d\" \/><\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-25 elementor-inner-column elementor-element elementor-element-093a76c\" data-id=\"093a76c\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-5c00449 elementor-drop-cap-yes elementor-drop-cap-view-default elementor-widget elementor-widget-text-editor\" data-id=\"5c00449\" data-element_type=\"widget\" data-e-type=\"widget\" data-settings=\"{&quot;drop_cap&quot;:&quot;yes&quot;}\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"tblCFStyle02_3612\">\n<tbody>\n<tr>\n<th><b>3<\/b><\/th>\n<td>\u30ae\u30a2\u5f62\u72b6<\/td>\n<\/tr>\n<tr style=\"height: 160px;\">\n<td style=\"width: 100%; background-color: #f7f7f7; text-align: center;\" colspan=\"2\"><img decoding=\"async\" class=\"aligncenter\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2022\/12\/3578_03.png\" alt=\"\u30ae\u30a2\u5f62\u72b6\" \/><\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-25 elementor-inner-column elementor-element elementor-element-dec2f71\" data-id=\"dec2f71\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-2a965c9 elementor-drop-cap-yes elementor-drop-cap-view-default elementor-widget elementor-widget-text-editor\" data-id=\"2a965c9\" data-element_type=\"widget\" data-e-type=\"widget\" data-settings=\"{&quot;drop_cap&quot;:&quot;yes&quot;}\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"tblCFStyle02_3612\">\n<tbody>\n<tr>\n<th><b>4<\/b><\/th>\n<td>\u5c16\u5f62<\/td>\n<\/tr>\n<tr style=\"height: 160px;\">\n<td style=\"width: 100%; background-color: #f7f7f7; text-align: center;\" colspan=\"2\"><img decoding=\"async\" class=\"aligncenter\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2022\/12\/3578_04.png\" alt=\"\u5c16\u5f62\" \/><\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-9e50ac3 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"9e50ac3\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-c95bf7e\" data-id=\"c95bf7e\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-e94eed5 elementor-widget elementor-widget-html\" data-id=\"e94eed5\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"html.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<style>\r\n@media print {\r\n.print_none{\r\n        display: none;\r\n        opacity: 0\r\n        height: 0;\r\n}\r\n\r\n.print_block {\r\n        break-inside: avoid;\r\n}\r\n\r\n#anchor {\r\n        display:none;\r\n        opacity: 0;\r\n        height: 0;\r\n}\r\n}\r\n<\/style>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<\/div>\n\t\t\n\t\t\t<div id=\"daexthefu-container\"\n\t\t\t\tclass=\"daexthefu-container daexthefu-layout-stacked daexthefu-alignment-left\"\n\t\t\t\tdata-post-id=\"3612\">\n\n\t\t\t\t<div class=\"daexthefu-feedback\">\n\t\t\t\t\t<div class=\"daexthefu-text\">\n\t\t\t\t\t\t<h3 class=\"daexthefu-title\">\u3053\u306e\u8a18\u4e8b\u306f\u53c2\u8003\u306b\u306a\u308a\u307e\u3057\u305f\u304b\uff1f<\/h3>\n\t\t\t\t\t<\/div>\n\t\t\t\t\t<div class=\"daexthefu-buttons-container\">\n\t\t\t\t\t\t<div class=\"daexthefu-buttons\">\n\t\t\t\t\t\t\t\n\t\t\t<div class=\"daexthefu-yes daexthefu-button daexthefu-button-type-icon-and-text\" data-value=\"1\">\n\t\t\t\t<div class=\"daexthefu-button-icon\">\n\t\t\t\t\n                <svg>\n                    <defs>\n                        <style>.thumb-up-cls-1{fill:#c9c9c9;}.thumb-up-cls-2{fill:#e1e1e1;}.thumb-up-cls-3{fill:#676767;}<\/style>\n                    <\/defs>\n                    <g id=\"thumb_up\">\n                        <path class=\"thumb-up-cls-2 daexthefu-icon-circle\" d=\"m24,3c11.58,0,21,9.42,21,21s-9.42,21-21,21S3,35.58,3,24,12.42,3,24,3m0-1C11.85,2,2,11.85,2,24s9.85,22,22,22,22-9.85,22-22S36.15,2,24,2h0Z\" \/>\n                        <g>\n                            <rect class=\"thumb-up-cls-3 daexthefu-icon-secondary-color\" x=\"10\" y=\"20\" width=\"6\" height=\"15\" rx=\"1.5\" ry=\"1.5\" \/>\n                            <path class=\"thumb-up-cls-1 daexthefu-icon-primary-color\" d=\"m30.57,9.06l-.49-.1c-.81-.17-1.61.35-1.78,1.16l-5.3,11.74c-.17.81,3.16,1.61,3.97,1.78l1.96.41c.81.17,1.61-.35,1.78-1.16l2.18-10.27c.34-1.61-.7-3.21-2.31-3.56Z\" \/>\n                            <path class=\"thumb-up-cls-1 daexthefu-icon-primary-color\" d=\"m38.17,20h-18.67c-.83,0-1.5.67-1.5,1.5v12c0,.83.67,1.5,1.5,1.5h16.27c.71,0,1.33-.5,1.47-1.21l2.4-12c.19-.93-.53-1.8-1.47-1.8Z\" \/>\n                        <\/g>\n                    <\/g>\n                <\/svg>\t\t\t\t\t\t<\/div>\n\t\t\t\t<div class=\"daexthefu-button-text\">\u5f79\u306b\u7acb\u3063\u305f\uff01<\/div>\n\t\t\t<\/div>\n\n\t\t\t\t\t\t\t\t\t\t\n\t\t\t<div class=\"daexthefu-no daexthefu-button daexthefu-button-type-icon-and-text\" data-value=\"0\">\n\t\t\t\t<div class=\"daexthefu-button-icon\">\n\t\t\t\t\n                <svg>\n                    <defs>\n                        <style>.thumb-down-cls-1{fill:#c9c9c9;}.thumb-down-cls-2{fill:#e1e1e1;}.thumb-down-cls-3{fill:#676767;}<\/style>\n                    <\/defs>\n                    <g id=\"thumb_down\">\n                        <path class=\"thumb-down-cls-2 daexthefu-icon-circle\" d=\"m24,3c11.58,0,21,9.42,21,21s-9.42,21-21,21S3,35.58,3,24,12.42,3,24,3m0-1C11.85,2,2,11.85,2,24s9.85,22,22,22,22-9.85,22-22S36.15,2,24,2h0Z\" \/>\n                        <g>\n                            <rect class=\"thumb-down-cls-3 daexthefu-icon-secondary-color\" x=\"10\" y=\"13\" width=\"6\" height=\"15\" rx=\"1.5\" ry=\"1.5\" \/>\n                            <path class=\"thumb-down-cls-1 daexthefu-icon-primary-color\" d=\"m30.57,38.94l-.49.1c-.81.17-1.61-.35-1.78-1.16l-5.3-11.74c-.17-.81,3.16-1.61,3.97-1.78l1.96-.41c.81-.17,1.61.35,1.78,1.16l2.18,10.27c.34,1.61-.7,3.21-2.31,3.56Z\" \/>\n                            <path class=\"thumb-down-cls-1 daexthefu-icon-primary-color\" d=\"m38.17,28h-18.67c-.83,0-1.5-.67-1.5-1.5v-12c0-.83.67-1.5,1.5-1.5h16.27c.71,0,1.33.5,1.47,1.21l2.4,12c.19.93-.53,1.8-1.47,1.8Z\" \/>\n                        <\/g>\n                    <\/g>\n                <\/svg>\t\t\t\t\t\t<\/div>\n\t\t\t\t<div class=\"daexthefu-button-text\">\u5f79\u306b\u7acb\u305f\u306a\u304b\u3063\u305f<\/div>\n\t\t\t<\/div>\n\n\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\n\t\t\t\t<div class=\"daexthefu-comment\">\n\t\t\t\t\t<div class=\"daexthefu-comment-top-container\">\n\t\t\t\t\t\t<label id=\"daexthefu-comment-label\" class=\"daexthefu-comment-label\"><\/label>\n\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t\t<textarea id=\"daexthefu-comment-textarea\" class=\"daexthefu-comment-textarea\"\n\t\t\t\t\t\t\t\tplaceholder=\"\"\n\t\t\t\t\t\t\t\tmaxlength=\"\n\t\t\t\t\t\t\t\t400\t\t\t\t\t\t\t\t\t\"><\/textarea>\n\t\t\t\t\t<div class=\"daexthefu-comment-buttons-container\">\n\t\t\t\t\t\t<button class=\"daexthefu-comment-submit daexthefu-button\">\u9001\u4fe1<\/button>\n\t\t\t\t\t\t<button class=\"daexthefu-comment-cancel daexthefu-button\">\u53d6\u6d88<\/button>\n\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\n\t\t\t\t<div class=\"daexthefu-successful-submission-text\">\u8a55\u4fa1\u3044\u305f\u3060\u304d\u3042\u308a\u304c\u3068\u3046\u3054\u3056\u3044\u307e\u3057\u305f\u3002<\/div>\n\n\t\t\t<\/div>\n\n\t\t\t","protected":false},"excerpt":{"rendered":"<p>\u5916\u5f62\u3084\u5bf8\u6cd5\u6761\u4ef6\u306b\u3088\u308a\u4e0b\u8a18\u5f62\u72b6\u3067\u3082\u88fd\u4f5c\u3067\u304d\u306a\u3044\u5834\u5408\u304c\u3054\u3056\u3044\u307e\u3059\u3002\u88fd\u4f5c\u3067\u304d\u306a\u3044\u5834\u5408\u306f\u3001\u3054\u6ce8\u6587\u5f8c\u306bmeviy\u30b5\u30dd\u30fc\u30c8\u304b\u3089\u3054\u9023\u7d61\u3044\u305f\u3057\u307e\u3059\u3002 \u5f62\u72b6 1 \u5e73\u677f 2 \u5186\u5f62 3 L\u66f2\u3052 4 Z\u66f2\u3052 5 \u51f8\u66f2\u3052 6 \u30b3\u306e\u5b57\u66f2\u3052 7 \u89d2\u5ea6 [&hellip;]<\/p>\n","protected":false},"author":15,"featured_media":0,"comment_status":"closed","ping_status":"closed","sticky":false,"template":"","format":"standard","meta":{"_helpful_status":1,"footnotes":""},"categories":[50],"tags":[64],"class_list":["post-3612","post","type-post","status-publish","format-standard","hentry","category-shm_shape-material","tag-technical_shm"],"yoast_head":"<!-- This site is optimized with the Yoast SEO plugin v28.0 - https:\/\/yoast.com\/product\/yoast-seo-wordpress\/ -->\n<title>\u898b\u7a4d\u3082\u308a\u53ef\u80fd\u5f62\u72b6 | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb<\/title>\n<meta name=\"robots\" content=\"index, follow, max-snippet:-1, max-image-preview:large, max-video-preview:-1\" \/>\n<link rel=\"canonical\" href=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/3612\/\" \/>\n<meta property=\"og:locale\" content=\"ja_JP\" \/>\n<meta property=\"og:type\" content=\"article\" \/>\n<meta property=\"og:title\" content=\"\u898b\u7a4d\u3082\u308a\u53ef\u80fd\u5f62\u72b6 | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\" \/>\n<meta property=\"og:description\" content=\"\u5916\u5f62\u3084\u5bf8\u6cd5\u6761\u4ef6\u306b\u3088\u308a\u4e0b\u8a18\u5f62\u72b6\u3067\u3082\u88fd\u4f5c\u3067\u304d\u306a\u3044\u5834\u5408\u304c\u3054\u3056\u3044\u307e\u3059\u3002\u88fd\u4f5c\u3067\u304d\u306a\u3044\u5834\u5408\u306f\u3001\u3054\u6ce8\u6587\u5f8c\u306bmeviy\u30b5\u30dd\u30fc\u30c8\u304b\u3089\u3054\u9023\u7d61\u3044\u305f\u3057\u307e\u3059\u3002 \u5f62\u72b6 1 \u5e73\u677f 2 \u5186\u5f62 3 L\u66f2\u3052 4 Z\u66f2\u3052 5 \u51f8\u66f2\u3052 6 \u30b3\u306e\u5b57\u66f2\u3052 7 \u89d2\u5ea6 [&hellip;]\" \/>\n<meta property=\"og:url\" content=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/3612\/\" \/>\n<meta property=\"og:site_name\" content=\"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\" \/>\n<meta property=\"article:published_time\" content=\"2025-10-19T15:00:24+00:00\" \/>\n<meta property=\"article:modified_time\" content=\"2025-10-20T00:38:04+00:00\" \/>\n<meta property=\"og:image\" content=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/fcpl_item_correspond1.png\" \/>\n<meta name=\"author\" content=\"\u7f8e\u7d00\" \/>\n<meta name=\"twitter:card\" content=\"summary_large_image\" \/>\n<script type=\"application\/ld+json\" class=\"yoast-schema-graph\">{\"@context\":\"https:\\\/\\\/schema.org\",\"@graph\":[{\"@type\":\"Article\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_shape-material\\\/3612\\\/#article\",\"isPartOf\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_shape-material\\\/3612\\\/\"},\"author\":{\"name\":\"\u7f8e\u7d00\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#\\\/schema\\\/person\\\/6ff70d9094b7fdc810efdfcc2fdb63c5\"},\"headline\":\"\u898b\u7a4d\u3082\u308a\u53ef\u80fd\u5f62\u72b6\",\"datePublished\":\"2025-10-19T15:00:24+00:00\",\"dateModified\":\"2025-10-20T00:38:04+00:00\",\"mainEntityOfPage\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_shape-material\\\/3612\\\/\"},\"wordCount\":7,\"publisher\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#organization\"},\"image\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_shape-material\\\/3612\\\/#primaryimage\"},\"thumbnailUrl\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2020\\\/01\\\/fcpl_item_correspond1.png\",\"keywords\":[\"technical_shm\"],\"articleSection\":[\"\u5bfe\u8c61\u90e8\u54c1\\\/\u6750\u6599\"],\"inLanguage\":\"ja\"},{\"@type\":\"WebPage\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_shape-material\\\/3612\\\/\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_shape-material\\\/3612\\\/\",\"name\":\"\u898b\u7a4d\u3082\u308a\u53ef\u80fd\u5f62\u72b6 | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\",\"isPartOf\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#website\"},\"primaryImageOfPage\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_shape-material\\\/3612\\\/#primaryimage\"},\"image\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_shape-material\\\/3612\\\/#primaryimage\"},\"thumbnailUrl\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2020\\\/01\\\/fcpl_item_correspond1.png\",\"datePublished\":\"2025-10-19T15:00:24+00:00\",\"dateModified\":\"2025-10-20T00:38:04+00:00\",\"breadcrumb\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_shape-material\\\/3612\\\/#breadcrumb\"},\"inLanguage\":\"ja\",\"potentialAction\":[{\"@type\":\"ReadAction\",\"target\":[\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_shape-material\\\/3612\\\/\"]}]},{\"@type\":\"ImageObject\",\"inLanguage\":\"ja\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_shape-material\\\/3612\\\/#primaryimage\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2020\\\/01\\\/fcpl_item_correspond1.png\",\"contentUrl\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2020\\\/01\\\/fcpl_item_correspond1.png\",\"width\":100,\"height\":68,\"caption\":\"\u5e73\u677f\"},{\"@type\":\"BreadcrumbList\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_shape-material\\\/3612\\\/#breadcrumb\",\"itemListElement\":[{\"@type\":\"ListItem\",\"position\":1,\"name\":\"\u30db\u30fc\u30e0\",\"item\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/\"},{\"@type\":\"ListItem\",\"position\":2,\"name\":\"\u898b\u7a4d\u3082\u308a\u53ef\u80fd\u5f62\u72b6\"}]},{\"@type\":\"WebSite\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#website\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/\",\"name\":\"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\",\"description\":\"\",\"publisher\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#organization\"},\"potentialAction\":[{\"@type\":\"SearchAction\",\"target\":{\"@type\":\"EntryPoint\",\"urlTemplate\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/?s={search_term_string}\"},\"query-input\":{\"@type\":\"PropertyValueSpecification\",\"valueRequired\":true,\"valueName\":\"search_term_string\"}}],\"inLanguage\":\"ja\"},{\"@type\":\"Organization\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#organization\",\"name\":\"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/\",\"logo\":{\"@type\":\"ImageObject\",\"inLanguage\":\"ja\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#\\\/schema\\\/logo\\\/image\\\/\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2019\\\/05\\\/A01-b_b4-1_jpeg.jpg\",\"contentUrl\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2019\\\/05\\\/A01-b_b4-1_jpeg.jpg\",\"width\":260,\"height\":70,\"caption\":\"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df\"},\"image\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#\\\/schema\\\/logo\\\/image\\\/\"}},{\"@type\":\"Person\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#\\\/schema\\\/person\\\/6ff70d9094b7fdc810efdfcc2fdb63c5\",\"name\":\"\u7f8e\u7d00\",\"image\":{\"@type\":\"ImageObject\",\"inLanguage\":\"ja\",\"@id\":\"https:\\\/\\\/secure.gravatar.com\\\/avatar\\\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g\",\"url\":\"https:\\\/\\\/secure.gravatar.com\\\/avatar\\\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g\",\"contentUrl\":\"https:\\\/\\\/secure.gravatar.com\\\/avatar\\\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g\",\"caption\":\"\u7f8e\u7d00\"},\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/author\\\/miki-aa3x-momosemisumi-co-jp\\\/\"}]}<\/script>\n<!-- \/ Yoast SEO plugin. -->","yoast_head_json":{"title":"\u898b\u7a4d\u3082\u308a\u53ef\u80fd\u5f62\u72b6 | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","robots":{"index":"index","follow":"follow","max-snippet":"max-snippet:-1","max-image-preview":"max-image-preview:large","max-video-preview":"max-video-preview:-1"},"canonical":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/3612\/","og_locale":"ja_JP","og_type":"article","og_title":"\u898b\u7a4d\u3082\u308a\u53ef\u80fd\u5f62\u72b6 | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","og_description":"\u5916\u5f62\u3084\u5bf8\u6cd5\u6761\u4ef6\u306b\u3088\u308a\u4e0b\u8a18\u5f62\u72b6\u3067\u3082\u88fd\u4f5c\u3067\u304d\u306a\u3044\u5834\u5408\u304c\u3054\u3056\u3044\u307e\u3059\u3002\u88fd\u4f5c\u3067\u304d\u306a\u3044\u5834\u5408\u306f\u3001\u3054\u6ce8\u6587\u5f8c\u306bmeviy\u30b5\u30dd\u30fc\u30c8\u304b\u3089\u3054\u9023\u7d61\u3044\u305f\u3057\u307e\u3059\u3002 \u5f62\u72b6 1 \u5e73\u677f 2 \u5186\u5f62 3 L\u66f2\u3052 4 Z\u66f2\u3052 5 \u51f8\u66f2\u3052 6 \u30b3\u306e\u5b57\u66f2\u3052 7 \u89d2\u5ea6 [&hellip;]","og_url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/3612\/","og_site_name":"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","article_published_time":"2025-10-19T15:00:24+00:00","article_modified_time":"2025-10-20T00:38:04+00:00","og_image":[{"url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/fcpl_item_correspond1.png","type":"","width":"","height":""}],"author":"\u7f8e\u7d00","twitter_card":"summary_large_image","schema":{"@context":"https:\/\/schema.org","@graph":[{"@type":"Article","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/3612\/#article","isPartOf":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/3612\/"},"author":{"name":"\u7f8e\u7d00","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/person\/6ff70d9094b7fdc810efdfcc2fdb63c5"},"headline":"\u898b\u7a4d\u3082\u308a\u53ef\u80fd\u5f62\u72b6","datePublished":"2025-10-19T15:00:24+00:00","dateModified":"2025-10-20T00:38:04+00:00","mainEntityOfPage":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/3612\/"},"wordCount":7,"publisher":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#organization"},"image":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/3612\/#primaryimage"},"thumbnailUrl":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/fcpl_item_correspond1.png","keywords":["technical_shm"],"articleSection":["\u5bfe\u8c61\u90e8\u54c1\/\u6750\u6599"],"inLanguage":"ja"},{"@type":"WebPage","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/3612\/","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/3612\/","name":"\u898b\u7a4d\u3082\u308a\u53ef\u80fd\u5f62\u72b6 | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","isPartOf":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#website"},"primaryImageOfPage":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/3612\/#primaryimage"},"image":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/3612\/#primaryimage"},"thumbnailUrl":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/fcpl_item_correspond1.png","datePublished":"2025-10-19T15:00:24+00:00","dateModified":"2025-10-20T00:38:04+00:00","breadcrumb":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/3612\/#breadcrumb"},"inLanguage":"ja","potentialAction":[{"@type":"ReadAction","target":["https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/3612\/"]}]},{"@type":"ImageObject","inLanguage":"ja","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/3612\/#primaryimage","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/fcpl_item_correspond1.png","contentUrl":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2020\/01\/fcpl_item_correspond1.png","width":100,"height":68,"caption":"\u5e73\u677f"},{"@type":"BreadcrumbList","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/3612\/#breadcrumb","itemListElement":[{"@type":"ListItem","position":1,"name":"\u30db\u30fc\u30e0","item":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/"},{"@type":"ListItem","position":2,"name":"\u898b\u7a4d\u3082\u308a\u53ef\u80fd\u5f62\u72b6"}]},{"@type":"WebSite","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#website","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/","name":"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","description":"","publisher":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#organization"},"potentialAction":[{"@type":"SearchAction","target":{"@type":"EntryPoint","urlTemplate":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/?s={search_term_string}"},"query-input":{"@type":"PropertyValueSpecification","valueRequired":true,"valueName":"search_term_string"}}],"inLanguage":"ja"},{"@type":"Organization","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#organization","name":"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/","logo":{"@type":"ImageObject","inLanguage":"ja","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/logo\/image\/","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2019\/05\/A01-b_b4-1_jpeg.jpg","contentUrl":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2019\/05\/A01-b_b4-1_jpeg.jpg","width":260,"height":70,"caption":"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df"},"image":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/logo\/image\/"}},{"@type":"Person","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/person\/6ff70d9094b7fdc810efdfcc2fdb63c5","name":"\u7f8e\u7d00","image":{"@type":"ImageObject","inLanguage":"ja","@id":"https:\/\/secure.gravatar.com\/avatar\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g","url":"https:\/\/secure.gravatar.com\/avatar\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g","contentUrl":"https:\/\/secure.gravatar.com\/avatar\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g","caption":"\u7f8e\u7d00"},"url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/author\/miki-aa3x-momosemisumi-co-jp\/"}]}},"views":92123,"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts\/3612","targetHints":{"allow":["GET"]}}],"collection":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts"}],"about":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/types\/post"}],"author":[{"embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/users\/15"}],"replies":[{"embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/comments?post=3612"}],"version-history":[{"count":33,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts\/3612\/revisions"}],"predecessor-version":[{"id":34515,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts\/3612\/revisions\/34515"}],"wp:attachment":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/media?parent=3612"}],"wp:term":[{"taxonomy":"category","embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/categories?post=3612"},{"taxonomy":"post_tag","embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/tags?post=3612"}],"curies":[{"name":"wp","href":"https:\/\/api.w.org\/{rel}","templated":true}]}}
