{"id":3718,"date":"2025-10-20T00:00:37","date_gmt":"2025-10-19T15:00:37","guid":{"rendered":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/?p=3718"},"modified":"2026-10-05T10:30:31","modified_gmt":"2026-10-05T01:30:31","slug":"%e6%9d%90%e6%96%99%e7%89%b9%e6%80%a7","status":"publish","type":"post","link":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/3718\/","title":{"rendered":"\u6750\u6599\u306e\u7279\u6027"},"content":{"rendered":"\t\t<div data-elementor-type=\"wp-post\" data-elementor-id=\"3718\" class=\"elementor elementor-3718\">\n\t\t\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-e6e7223 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"e6e7223\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-219b380\" data-id=\"219b380\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-c6782e0 elementor-widget elementor-widget-text-editor\" data-id=\"c6782e0\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<ul id=\"anchor\">\n \t<li><a href=\"#box1\">\u9244<\/a><\/li>\n \t<li><a href=\"#box2\">\u30b9\u30c6\u30f3\u30ec\u30b9<\/a><\/li>\n \t<li><a href=\"#box3\">\u30a2\u30eb\u30df\u30cb\u30a6\u30e0<\/a><\/li>\n \t<li><a href=\"#box4\">\u9285\u30fb\u771f\u936e<\/a><\/li>\n \t<li><a href=\"#box5\">\u30e1\u30c3\u30ad\u92fc\u677f<\/a><\/li>\n \t<li><a href=\"#box6\">\u30d1\u30f3\u30c1\u30f3\u30b0\u30e1\u30bf\u30eb<\/a><\/li>\n \t<li><a href=\"#box7\">\u900f\u660e\u6a39\u8102\u30d7\u30ec\u30fc\u30c8<\/a><\/li>\n \t<li><a href=\"#box8\">\u8907\u5408\u677f<\/a><\/li>\n<\/ul>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-e1bceca print_break elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"e1bceca\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-5c27ef2\" data-id=\"5c27ef2\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-07b27c3 elementor-widget elementor-widget-menu-anchor\" data-id=\"07b27c3\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"menu-anchor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t<div class=\"elementor-menu-anchor\" id=\"box1\"><\/div>\n\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-ea8c48c elementor-widget elementor-widget-heading\" data-id=\"ea8c48c\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h2 class=\"elementor-heading-title elementor-size-default\">\u9244<\/h2>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-f7dd363 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"f7dd363\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\u6750\u8cea\u306e\u7279\u5fb4\/\u5916\u89b3\n<table class=\"mT0 tableHover\">\n<tbody>\n<tr>\n<th>\u6750\u8cea<\/th>\n<th class=\"tblRowCFStyle01_3718\">\u7279\u5fb4<\/th>\n<th>\u5916\u89b3<\/th>\n<\/tr>\n<tr>\n<td>\n<ul>\n \t<li>SPCC<\/li>\n \t<li>SPCC(\u30b7\u30e0\u7528)<\/li>\n<\/ul>\n<\/td>\n<td class=\"tblFldCFStyle04_3718\">\u4e00\u822c\u30d7\u30ec\u30b9\u677f\u91d1\u5411\u3051\u306e\u51b7\u9593\u5727\u5ef6\u92fc\u677f\u3067\u3059\u3002 \u5bf8\u6cd5\u7cbe\u5ea6\u304c\u9ad8\u304f\u808c\u304c\u7f8e\u3057\u3044\u306e\u304c\u7279\u5fb4\u3067\u3059\u304c\u3001\u9306\u3073\u3084\u3059\u304f\u52a0\u5de5\u5f8c\u306b\u8868\u9762\u51e6\u7406\u3092\u63a8\u5968\u3057\u307e\u3059\u3002\u4e00\u822c\u7684\u306a\u6a19\u6e96\u677f\u539a\u306f0.2mm\uff5e3.2mm\u7a0b\u5ea6\u3067\u3059\u3002<\/td>\n<td><img decoding=\"async\" class=\"imgCFStyle02_3718\" src=\"\/help\/ja\/wp-content\/uploads\/2020\/01\/spc04_sheet_pic_02.jpg\" alt=\"SPCC SPCC(\u30b7\u30e0\u7528)\u306e\u5916\u89b3\" \/><\/td>\n<\/tr>\n<tr>\n<td>SPHC<\/td>\n<td class=\"tblFldCFStyle04_3718\">\u4e00\u822c\u7528\u53ca\u3073\u7d5e\u308a\u7528\u306e\u71b1\u9593\u5727\u5ef6\u8edf\u92fc\u677f\u3067\u3059\u3002 SPCC\u540c\u69d8\u306b\u52a0\u5de5\u5f8c\u306b\u8868\u9762\u51e6\u7406\u3092\u63a8\u5968\u3057\u307e\u3059\u3002\u4e00\u822c\u7684\u306a\u6a19\u6e96\u677f\u539a\u306f1.2mm\u4ee5\u4e0a\u3067\u4e2d\u539a\u677f\u306e\u88fd\u54c1\u3067\u3088\u304f\u4f7f\u7528\u3055\u308c\u307e\u3059\u3002<\/td>\n<td><img decoding=\"async\" class=\"imgCFStyle02_3718\" src=\"\/help\/ja\/wp-content\/uploads\/2020\/01\/spc04_sheet_pic_03.jpg\" alt=\"SPHC\u306e\u5916\u89b3\" \/><\/td>\n<\/tr>\n<tr>\n<td>SS400<\/td>\n<td class=\"tblFldCFStyle04_3718\">\u4e00\u822c\u69cb\u9020\u7528\u5727\u5ef6\u92fc\u6750\u3067\u65e5\u672c\u3067\u5e83\u304f\u4f7f\u7528\u3055\u308c\u3066\u3044\u308b\u6750\u6599\u3067\u3059\u3002\u5f15\u3063\u5f35\u308a\u5f37\u3055\u304c400N\/mm^2\u4ee5\u4e0a\u3042\u308b\u3053\u3068\u304c\u540d\u79f0\u306e\u7531\u6765\u306b\u306a\u308a\u307e\u3059\u3002\u7279\u5fb4\u306f\u4f4e\u30b3\u30b9\u30c8\u3067\u52a0\u5de5\u304c\u826f\u597d\u3067\u3042\u308b\u4e8b\u3067\u3059\u3002\u6a5f\u68b0\u3001\u5efa\u7bc9\u306a\u3069\u5e45\u5e83\u3044\u696d\u754c\u3067\u4f7f\u7528\u3055\u308c\u307e\u3059\u3002<\/td>\n<td><img decoding=\"async\" class=\"imgCFStyle02_3718\" src=\"\/help\/ja\/wp-content\/uploads\/2021\/10\/spc04_sheet_pic_22.png\" alt=\"SS400\u306e\u5916\u89b3\" \/><\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-4bc8d73 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"4bc8d73\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\u6750\u8cea\u306e\u7279\u6027\u3000\u203b\u4e0b\u8a18\u7279\u6027\u5024\u306f\u53c2\u8003\u5024\u3067\u3042\u308a\u4fdd\u8a3c\u5024\u3067\u306f\u3042\u308a\u307e\u305b\u3093\n<table class=\"mT0 tableHover tblCFStyle01_3718\">\n<tbody>\n<tr>\n<th class=\"tblRowCFStyle02_3718\">\u6750\u8cea<\/th>\n<th>\n<div>\u5f15\u5f35\u5f37\u3055<\/div>\n(N\/mm2)<\/th>\n<th>\n<div>\u8010\u529b<\/div>\n(N\/mm2)<\/th>\n<th>\n<div>\u7834\u65ad\u4f38\u3073<\/div>\n%<\/th>\n<th>\n<div>\u66f2\u3052\u5f37\u3055<\/div>\n(N\/mm2)<\/th>\n<th>\n<div>\u5727\u7e2e\u5f37\u3055<\/div>\n(N\/mm2)<\/th>\n<th>\n<div>\u964d\u4f0f\u70b9<\/div>\n(N\/mm2)<\/th>\n<th>\n<div>\u30e4\u30f3\u30b0\u7387<\/div>\n(N\/mm2)<\/th>\n<th>\n<div>\u66f2\u3052\u5f3e\u6027\u7387<\/div>\n(N\/mm2)<\/th>\n<th>\u6bd4\u91cd<\/th>\n<th>\n<div>\u5c0e\u96fb\u7387<\/div>\n(S\/m)<\/th>\n<th>\n<div>\u71b1\u4f1d\u5c0e\u7387<\/div>\n(W\/m\u30fbK)<\/th>\n<th>\n<div>\u7dda\u81a8\u5f35\u4fc2\u6570<\/div>\n(\/\u2103)<\/th>\n<\/tr>\n<tr>\n<th>SPCC<\/th>\n<td>270~410<\/td>\n<td>205\u4ee5\u4e0a<\/td>\n<td>32\u4ee5\u4e0a<\/td>\n<td>243~390<\/td>\n<td>260~400<\/td>\n<td>205\u4ee5\u4e0a<\/td>\n<td>2.1\u00d710\u2075<\/td>\n<td>2.1\u00d710\u2075<\/td>\n<td>7.85<\/td>\n<td>6.96\u00d710\u2076<\/td>\n<td>58<\/td>\n<td>11.7\u00d710\u207b\u2076<\/td>\n<\/tr>\n<tr>\n<th>SPHC<\/th>\n<td>270~440<\/td>\n<td>175\u4ee5\u4e0a<\/td>\n<td>35\u4ee5\u4e0a<\/td>\n<td>243~418<\/td>\n<td>260~430<\/td>\n<td>175\u4ee5\u4e0a<\/td>\n<td>2.1\u00d710\u2075<\/td>\n<td>2.1\u00d710\u2075<\/td>\n<td>7.85<\/td>\n<td>6.96\u00d710\u2076<\/td>\n<td>58<\/td>\n<td>11.7\u00d710\u207b\u2076<\/td>\n<\/tr>\n<tr>\n<th>SS400<\/th>\n<td>400~510<\/td>\n<td>215\u4ee5\u4e0a<\/td>\n<td>21\u4ee5\u4e0a<\/td>\n<td>360~485<\/td>\n<td>380~485<\/td>\n<td>215\u4ee5\u4e0a<\/td>\n<td>2.1\u00d710\u2075<\/td>\n<td>2.1\u00d710\u2075<\/td>\n<td>7.85<\/td>\n<td>6.96\u00d710\u2076<\/td>\n<td>58<\/td>\n<td>11.7\u00d710\u207b\u2076<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-0cbdefb print_break elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"0cbdefb\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-48b06bb\" data-id=\"48b06bb\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-1e12a14 elementor-widget elementor-widget-menu-anchor\" data-id=\"1e12a14\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"menu-anchor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t<div class=\"elementor-menu-anchor\" id=\"box2\"><\/div>\n\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-8f2c528 print_page elementor-widget elementor-widget-heading\" data-id=\"8f2c528\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h2 class=\"elementor-heading-title elementor-size-default\">\u30b9\u30c6\u30f3\u30ec\u30b9<\/h2>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-fa19a20 tblBasic print_break elementor-widget elementor-widget-text-editor\" data-id=\"fa19a20\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\u6750\u8cea\u306e\u7279\u5fb4\/\u5916\u89b3\n<div class=\"print_break\">\n<div class=\"tableStickyHead\">\n<table class=\"mT0\">\n<tbody>\n<tr>\n<th>\u6750\u8cea<\/th>\n<th class=\"tblRowCFStyle01_3718\">\u7279\u5fb4<\/th>\n<th>\u5916\u89b3<\/th>\n<\/tr>\n<\/tbody>\n<\/table>\n<\/div>\n<table class=\"mT0 tableHover print_break\">\n<tbody class=\"print_break\">\n<tr>\n<td>SUS304(2B)<\/td>\n<td class=\"tblFldCFStyle04_3718 tblRowCFStyle01_3718\">\u8010\u98df\u6027\u3068\u6eb6\u63a5\u6027\u3092\u5411\u4e0a\u3055\u305b\u305f\u30aa\u30fc\u30b9\u30c6\u30ca\u30a4\u30c8\u7cfb\u30b9\u30c6\u30f3\u30ec\u30b9\u92fc\u3067\u3059\u3002\u7528\u9014\u306e\u5e83\u3055\u3068\u5165\u624b\u306e\u3057\u3084\u3059\u3055\u304b\u3089\u6c4e\u7528\u6027\u304c\u9ad8\u304f\u3001\u3055\u307e\u3056\u307e\u306a\u5206\u91ce\u3067\u5e83\u304f\u4f7f\u7528\u3055\u308c\u307e\u3059\u3002\u9ad8\u3044\u8010\u98df\u6027\u3068\u5f37\u5ea6\u3092\u4fdd\u3061\u3064\u3064\u512a\u308c\u305f\u6eb6\u63a5\u6027\u3092\u6709\u3057\u3066\u3044\u308b\u305f\u3081\u3001\u8a2d\u5099\u6a5f\u5668\u306a\u3069\u3078\u306e\u5229\u7528\u304c\u591a\u304f\u898b\u3089\u308c\u307e\u3059\u3002\u7f8e\u89b3\u3092\u4fdd\u8b77\u3057\u305f\u3044\u306a\u3069\u306e\u304a\u5ba2\u69d8\u306e\u7528\u9014\u306b\u5408\u308f\u305b\u3066\u3001\u300c\u4ed5\u4e0a\u3052\u9762\u3078\u306e\u4fdd\u8b77\u30b7\u30fc\u30c8\u8cbc\u4ed8\u300d\u306e\u72b6\u614b\u3092\u3054\u9078\u629e\u3044\u305f\u3060\u3051\u307e\u3059\u3002<\/td>\n<td><img decoding=\"async\" class=\"imgCFStyle02_3718\" src=\"\/help\/ja\/wp-content\/uploads\/2020\/01\/spc04_sheet_pic_09.jpg\" alt=\" SUS304(2B)\u306e\u5916\u89b3\" \/><\/td>\n<\/tr>\n<tr>\n<td>SUS304(\u7247\u9762#400\u7814\u78e8)<\/td>\n<td class=\"tblFldCFStyle04_3718\">\u5916\u88c5\u30ab\u30d0\u30fc\u306b\u4f7f\u7528\u3055\u308c\u308b\u7f8e\u89b3\u306b\u512a\u308c\u305f\u8868\u9762\u4ed5\u4e0a\u3052\u6750\u3067\u3059\u3002 \u8868\u9762\u306f\u93e1\u9762\u306b\u8fd1\u3044\u5149\u6ca2\u3067\u82e5\u5e72\u306e\u78e8\u304d\u76ee\u304c\u6b8b\u308a\u307e\u3059\u3002\u7f8e\u89b3\u4fdd\u8b77\u306e\u305f\u3081\u3001\u4ed5\u4e0a\u3052\u9762\u306b\u4fdd\u8b77\u30b7\u30fc\u30c8\u304c\u3064\u3044\u305f\u72b6\u614b\u3067\u5165\u624b\u53ef\u80fd\u3067\u3059\u3002<\/td>\n<td><img decoding=\"async\" class=\"imgCFStyle02_3718\" src=\"\/help\/ja\/wp-content\/uploads\/2020\/01\/spc04_sheet_pic_18.jpg\" alt=\" SUS304(\u7247\u9762#400\u7814\u78e8)\u306e\u5916\u89b3\" \/><\/td>\n<\/tr>\n<tr>\n<td>SUS304(\u7247\u9762\u30d8\u30a2\u30e9\u30a4\u30f3)<\/td>\n<td class=\"tblFldCFStyle04_3718\">\u9aea\u306e\u6bdb\u306e\u3088\u3046\u306b\u9577\u304f\u9023\u7d9a\u3057\u305f\u7814\u78e8\u76ee\u304c\u7279\u5fb4\u306e\u8868\u9762\u4ed5\u4e0a\u3052\u6750\u3067\u3059\u3002\u8868\u9762\u306f\u5149\u6ca2\u3092\u6291\u3048\u3066\u3042\u308a\u843d\u3061\u7740\u3044\u305f\u96f0\u56f2\u6c17\u306e\u5916\u89b3\u3067\u3059\u3002\u7f8e\u89b3\u4fdd\u8b77\u306e\u305f\u3081\u3001\u4ed5\u4e0a\u3052\u9762\u306b\u4fdd\u8b77\u30b7\u30fc\u30c8\u304c\u3064\u3044\u305f\u72b6\u614b\u3067\u5165\u624b\u53ef\u80fd\u3067\u3059\u3002<\/td>\n<td><img decoding=\"async\" class=\"imgCFStyle02_3718\" src=\"\/help\/ja\/wp-content\/uploads\/2021\/09\/spc04_sheet_pic_21.png\" alt=\"SUS304(\u7247\u9762\u30d8\u30a2\u30e9\u30a4\u30f3)\u306e\u5916\u89b3\" \/><\/td>\n<\/tr>\n<tr>\n<td>SUS304(No.1)<\/td>\n<td class=\"tblFldCFStyle04_3718\">\u71b1\u9593\u5727\u5ef6\u30fb\u71b1\u51e6\u7406\u5f8c\u3001\u9178\u6d17\u3092\u884c\u3044\u8868\u9762\u306b\u3064\u304f\u9ed2\u3044\u76ae\u819c\u3084\u6c5a\u308c\u3092\u53d6\u308a\u9664\u3044\u305f\u4e00\u822c\u7684\u306a\u4ed5\u4e0a\u3052\u6750\u3067\u3059\u3002 \u3064\u3084\u6d88\u3057\u3067\u68a8\u5730\u306e\u3088\u3046\u306a\u8868\u9762\u304c\u7279\u5fb4\u3067\u3059\u3002<\/td>\n<td><img decoding=\"async\" class=\"imgCFStyle02_3718\" src=\"\/help\/ja\/wp-content\/uploads\/2021\/07\/spc04_sheet_pic_20.png\" alt=\"SUS304(No.1)\u306e\u5916\u89b3\" \/><\/td>\n<\/tr>\n<tr>\n<td>SUS304(H)(\u30b7\u30e0\u7528)<\/td>\n<td class=\"tblFldCFStyle04_3718\">SUS304\u3092\u51b7\u9593\u52a0\u5de5\u306b\u3088\u3063\u3066\u786c\u5316\u3055\u305b\u3066\u304a\u308a\u3001\u5f15\u3063\u5f35\u308a\u5f37\u3055\u304c\u9ad8\u304f\u3001\u66f2\u3052\u30fb\u7d5e\u308a\u306b\u306f\u5411\u304b\u306a\u3044\u3082\u306e\u306e\u52a0\u5de5\u5f8c\u306e\u53cd\u308a\u304c\u5c11\u306a\u3044\u8abf\u8cea\u6750\u3067\u3059\u30022B\u6750\u3088\u308a\u512a\u308c\u305f\u677f\u539a\u516c\u5dee\u3092\u6709\u3057\u3066\u304a\u308a\u3001\u7cbe\u5bc6\u52a0\u5de5\u306b\u9069\u3057\u3066\u3044\u307e\u3059\u3002<\/td>\n<td><img decoding=\"async\" class=\"imgCFStyle02_3718\" src=\"\/help\/ja\/wp-content\/uploads\/2025\/08\/3718_06.png\" alt=\"SUS304(H)(\u30b7\u30e0\u7528) \u306e\u5916\u89b3\" \/><\/td>\n<\/tr>\n<tr>\n<td>SUS316(2B)<\/td>\n<td class=\"tblFldCFStyle04_3718\">SUS304\u306b\u8010\u98df\u6027\u3001\u8010\u5b54\u98df\u6027\u3092\u5411\u4e0a\u3055\u305b\u305f\u30aa\u30fc\u30b9\u30c6\u30ca\u30a4\u30c8\u7cfb\u30b9\u30c6\u30f3\u30ec\u30b9\u92fc\u3067\u3059\u3002\u6cbf\u5cb8\u90e8\u306a\u3069\u6d77\u6c34\u3092\u542b\u3080\u6c34\u306b\u89e6\u308c\u308b\u7b87\u6240\u3001\u6f6e\u98a8\u306e\u5f71\u97ff\u3092\u53d7\u3051\u308b\u74b0\u5883\u3067\u3001\u8150\u98df\u3057\u305f\u969b\u306b\u91cd\u5927\u306a\u6b20\u9665\u306b\u7e4b\u304c\u308b\u6050\u308c\u304c\u3042\u308b\u53ef\u80fd\u6027\u306e\u3042\u308b\u3068\u3053\u308d\u306b\u9069\u3057\u3066\u3044\u307e\u3059\u3002<\/td>\n<td><img decoding=\"async\" class=\"imgCFStyle02_3718\" src=\"\/help\/ja\/wp-content\/uploads\/2025\/09\/3718_11.png\" alt=\"SUS316(2B)\u306e\u5916\u89b3\" \/><\/td>\n<\/tr>\n<tr>\n<td>SUS316L(2B)<\/td>\n<td class=\"tblFldCFStyle04_3718\">SUS316\u3088\u308a\u70ad\u7d20\u91cf\u304c\u4f4e\u304f\u3001\u8010\u7c92\u754c\u8150\u98df\u6027\uff08\u7d50\u6676\u3068\u7d50\u6676\u306e\u5883\u754c\u9762\u306b\u6cbf\u3063\u305f\u8150\u98df\u3078\u306e\u8010\u6027\uff09\u304c\u9ad8\u3044\u305f\u3081\u6d77\u6c34\u3092\u306f\u3058\u3081\u3068\u3059\u308b\u8010\u98df\u6027\u3001\u8010\u5b54\u98df\u6027\u304c\u5fc5\u8981\u306a\u5834\u6240\u3067\u4f7f\u7528\u3055\u308c\u3066\u3044\u307e\u3059\u3002<\/td>\n<td><img decoding=\"async\" class=\"imgCFStyle02_3718\" src=\"\/help\/ja\/wp-content\/uploads\/2026\/09\/3718_16.png\" alt=\"SUS316L(2B)\" \/><\/td>\n<\/tr>\n<tr>\n<td>SUS430(2B)<\/td>\n<td class=\"tblFldCFStyle04_3718\">\u78c1\u6027\u3092\u6301\u3064SUS\u6750\u3067\u3059\u3002\u30d5\u30a7\u30e9\u30a4\u30c8\u7cfb\u30b9\u30c6\u30f3\u30ec\u30b9\u92fc\u3067\u30aa\u30fc\u30b9\u30c6\u30ca\u30a4\u30c8\u7cfb\u30b9\u30c6\u30f3\u30ec\u30b9\u92fc\u3068\u306e\u9055\u3044\u306f\u3001\u30cb\u30c3\u30b1\u30eb\u3092\u542b\u307e\u306a\u3044\u304c\u8010\u98df\u6027\u304c\u4f4e\u3044\u4e8b\u3067\u3059\u3002\u6c4e\u7528\u6027\u304c\u9ad8\u304f\u3001\u7528\u9014\u306e\u5e83\u3055\u3084\u5165\u624b\u306e\u3057\u3084\u3059\u3055\u304b\u3089\u3001\u65e5\u5e38\u751f\u6d3b\u306e\u3055\u307e\u3056\u307e\u306a\u5834\u9762\u3067\u5e83\u304f\u4f7f\u7528\u3055\u308c\u3066\u3044\u307e\u3059\u3002\u98df\u54c1\u696d\u754c\u306a\u3069\u3067\u3082\u4f7f\u7528\u3055\u308c\u3066\u3044\u307e\u3059\u3002<\/td>\n<td><img decoding=\"async\" class=\"imgCFStyle02_3718\" src=\"\/help\/ja\/wp-content\/uploads\/2020\/01\/spc04_sheet_pic_10.jpg\" alt=\"SUS430(2B)\u306e\u5916\u89b3\" \/><\/td>\n<\/tr>\n<\/tbody>\n<\/table>\n<\/div>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-661a1e3 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"661a1e3\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\u6750\u8cea\u306e\u7279\u6027\u3000\u203b\u4e0b\u8a18\u7279\u6027\u5024\u306f\u53c2\u8003\u5024\u3067\u3042\u308a\u4fdd\u8a3c\u5024\u3067\u306f\u3042\u308a\u307e\u305b\u3093\n<table class=\"mT0 tableHover tblCFStyle01_3718\">\n<tbody>\n<tr>\n<th class=\"tblRowCFStyle02_3718\">\u6750\u8cea<\/th>\n<th>\n<div>\u5f15\u5f35\u5f37\u3055<\/div>\n(N\/mm2)<\/th>\n<th>\n<div>\u8010\u529b<\/div>\n(N\/mm2)<\/th>\n<th>\n<div>\u7834\u65ad\u4f38\u3073<\/div>\n%<\/th>\n<th>\n<div>\u66f2\u3052\u5f37\u3055<\/div>\n(N\/mm2)<\/th>\n<th>\n<div>\u5727\u7e2e\u5f37\u3055<\/div>\n(N\/mm2)<\/th>\n<th>\n<div>\u964d\u4f0f\u70b9<\/div>\n(N\/mm2)<\/th>\n<th>\n<div>\u30e4\u30f3\u30b0\u7387<\/div>\n(N\/mm2)<\/th>\n<th>\n<div>\u66f2\u3052\u5f3e\u6027\u7387<\/div>\n(N\/mm2)<\/th>\n<th>\u6bd4\u91cd<\/th>\n<th>\n<div>\u5c0e\u96fb\u7387<\/div>\n(S\/m)<\/th>\n<th>\n<div>\u71b1\u4f1d\u5c0e\u7387<\/div>\n(W\/m\u30fbK)<\/th>\n<th>\n<div>\u7dda\u81a8\u5f35\u4fc2\u6570<\/div>\n(\/\u2103)<\/th>\n<\/tr>\n<tr>\n<th>SUS304<\/th>\n<td>520~690<\/td>\n<td>205\u4ee5\u4e0a<\/td>\n<td>40\u4ee5\u4e0a<\/td>\n<td>478~670<\/td>\n<td>495~520<\/td>\n<td>205\u4ee5\u4e0a<\/td>\n<td>1.9\u00d710\u2075<\/td>\n<td>1.9\u00d710\u2075<\/td>\n<td>7.93<\/td>\n<td>1.39\u00d710\u2076<\/td>\n<td>16.2<\/td>\n<td>17.3\u00d710\u207b\u2076<\/td>\n<\/tr>\n<tr>\n<th>SUS304(H)<\/th>\n<td>650~900<\/td>\n<td>450\u4ee5\u4e0a<\/td>\n<td>10\u4ee5\u4e0a<\/td>\n<td>598~873<\/td>\n<td>620~860<\/td>\n<td>450\u4ee5\u4e0a<\/td>\n<td>1.9\u00d710\u2075<\/td>\n<td>1.9\u00d710\u2075<\/td>\n<td>7.93<\/td>\n<td>1.39\u00d710\u2076<\/td>\n<td>16.2<\/td>\n<td>17.3\u00d710\u207b\u2076<\/td>\n<\/tr>\n<tr>\n<th>SUS316<\/th>\n<td>520~690<\/td>\n<td>205\u4ee5\u4e0a<\/td>\n<td>40\u4ee5\u4e0a<\/td>\n<td>478~670<\/td>\n<td>495~520<\/td>\n<td>205\u4ee5\u4e0a<\/td>\n<td>1.9\u00d710\u2075<\/td>\n<td>1.9\u00d710\u2075<\/td>\n<td>7.98<\/td>\n<td>1.39\u00d710\u2076<\/td>\n<td>15<\/td>\n<td>16.0\u00d710\u207b\u2076<\/td>\n<\/tr>\n<tr>\n<th>SUS316L<\/th>\n<td>480~680<\/td>\n<td>177\u4ee5\u4e0a<\/td>\n<td>45\u201365<\/td>\n<td>560<\/td>\n<td>560<\/td>\n<td>170~280<\/td>\n<td>1.93\u00d710\u2075<\/td>\n<td>1.93\u00d710\u2075<\/td>\n<td>7.98<\/td>\n<td>1.3\u00d710\u2076<\/td>\n<td>13<\/td>\n<td>15.9\u00d710\u207b\u2076<\/td>\n<\/tr>\n<tr>\n<th>SUS430<\/th>\n<td>450~470<\/td>\n<td>205\u4ee5\u4e0a<\/td>\n<td>22\u4ee5\u4e0a<\/td>\n<td>405~428<\/td>\n<td>450~470<\/td>\n<td>205\u4ee5\u4e0a<\/td>\n<td>2.0\u00d710\u2075<\/td>\n<td>2.0\u00d710\u2075<\/td>\n<td>7.70<\/td>\n<td>1.39\u00d710\u2076<\/td>\n<td>25<\/td>\n<td>10.4\u00d710\u207b\u2076<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-27ae922 print_block elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"27ae922\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-a931c53\" data-id=\"a931c53\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-0545bb6 elementor-widget elementor-widget-menu-anchor\" data-id=\"0545bb6\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"menu-anchor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t<div class=\"elementor-menu-anchor\" id=\"box3\"><\/div>\n\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-de7af5a elementor-widget elementor-widget-heading\" data-id=\"de7af5a\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h2 class=\"elementor-heading-title elementor-size-default\">\u30a2\u30eb\u30df\u30cb\u30a6\u30e0\n<\/h2>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-22f1ae5 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"22f1ae5\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\u6750\u8cea\u306e\u7279\u5fb4\/\u5916\u89b3\n<table class=\"mT0 tableHover\">\n<tbody>\n<tr>\n<th>\u6750\u8cea<\/th>\n<th class=\"tblRowCFStyle01_3718\">\u7279\u5fb4<\/th>\n<th>\u5916\u89b3<\/th>\n<\/tr>\n<tr>\n<td>A5052<\/td>\n<td class=\"tblFldCFStyle04_3718\">\u6700\u3082\u4e00\u822c\u7684\u306a\u30a2\u30eb\u30df\u5408\u91d1\u3067\u3059\u3002\u30a2\u30eb\u30df\u5408\u91d1\u306e\u4e2d\u3067\u3082\u7279\u306b\u5207\u524a\u6027\u306b\u512a\u308c\u3066\u304a\u308a\u3001\u7528\u9014\u304c\u5e83\u304f\u5165\u624b\u6027\u306b\u512a\u308c\u307e\u3059\u3002\u8010\u98df\u6027\u3082\u6709\u3057\u3066\u3044\u307e\u3059\u3002\u6c4e\u7528\u6027\u306e\u9ad8\u3044\u6750\u6599\u3068\u3057\u3066\u591a\u304f\u306e\u5206\u91ce\u3067\u5e83\u304f\u4f7f\u7528\u3055\u308c\u307e\u3059\u3002<\/td>\n<td><img decoding=\"async\" class=\"imgCFStyle02_3718\" src=\"\/help\/ja\/wp-content\/uploads\/2020\/01\/spc04_sheet_pic_11.jpg\" alt=\"A5052\u306e\u5916\u89b3\" \/><\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-56144e6 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"56144e6\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\u6750\u8cea\u306e\u7279\u6027\u3000\u203b\u4e0b\u8a18\u7279\u6027\u5024\u306f\u53c2\u8003\u5024\u3067\u3042\u308a\u4fdd\u8a3c\u5024\u3067\u306f\u3042\u308a\u307e\u305b\u3093\n<table class=\"mT0 tblCFStyle01_3718 tableHover\">\n<tbody>\n<tr>\n<th>\u6750\u8cea<\/th>\n<th>\n<div>\u5f15\u5f35\u5f37\u3055<\/div>\n(N\/mm2)<\/th>\n<th>\n<div>\u8010\u529b<\/div>\n(N\/mm2)<\/th>\n<th>\n<div>\u7834\u65ad\u4f38\u3073<\/div>\n%<\/th>\n<th>\n<div>\u66f2\u3052\u5f37\u3055<\/div>\n(N\/mm2)<\/th>\n<th>\n<div>\u5727\u7e2e\u5f37\u3055<\/div>\n(N\/mm2)<\/th>\n<th>\n<div>\u964d\u4f0f\u70b9<\/div>\n(N\/mm2)<\/th>\n<th>\n<div>\u30e4\u30f3\u30b0\u7387<\/div>\n(N\/mm2)<\/th>\n<th>\n<div>\u66f2\u3052\u5f3e\u6027\u7387<\/div>\n(N\/mm2)<\/th>\n<th>\n<div>\u6bd4\u91cd<\/div><\/th>\n<th>\n<div>\u5c0e\u96fb\u7387<\/div>\n(S\/m)<\/th>\n<th>\n<div>\u71b1\u4f1d\u5c0e\u7387<\/div>\n(W\/m\u30fbK)<\/th>\n<th>\n<div>\u7dda\u81a8\u5f35\u4fc2\u6570<\/div>\n(\/\u2103)<\/th>\n<\/tr>\n<tr>\n<th>A5052<\/th>\n<td>195~260<\/td>\n<td>110\u4ee5\u4e0a<\/td>\n<td>12\u4ee5\u4e0a<\/td>\n<td>180~252<\/td>\n<td>185~260<\/td>\n<td>110\u4ee5\u4e0a<\/td>\n<td>7\u00d710\u2074<\/td>\n<td>7\u00d710\u2074<\/td>\n<td>2.68<\/td>\n<td>1.91\u00d710\u2077<\/td>\n<td>138<\/td>\n<td>23.8\u00d710\u207b\u2076<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-2597b30 print_block elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"2597b30\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-c3df3f4\" data-id=\"c3df3f4\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-10c037e elementor-widget elementor-widget-menu-anchor\" data-id=\"10c037e\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"menu-anchor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t<div class=\"elementor-menu-anchor\" id=\"box4\"><\/div>\n\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-109cd58 elementor-widget elementor-widget-heading\" data-id=\"109cd58\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h2 class=\"elementor-heading-title elementor-size-default\">\u9285\u30fb\u771f\u936e<\/h2>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-7a9c54f tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"7a9c54f\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\u6750\u8cea\u306e\u7279\u5fb4\/\u5916\u89b3\n<table class=\"mT0 tableHover\">\n<tbody>\n<tr>\n<th>\u6750\u8cea<\/th>\n<th class=\"tblRowCFStyle01_3718\">\u7279\u5fb4<\/th>\n<th>\u5916\u89b3<\/th>\n<\/tr>\n<tr>\n<td>C1020(\u7121\u9178\u7d20\u9285)<\/td>\n<td class=\"tblFldCFStyle04_3718\">\u7d14\u5ea699.96%\u4ee5\u4e0a\u306e\u7d14\u9285\u3067\u3059\u3002\u5c0e\u96fb\u6027\u30fb\u71b1\u4f1d\u5c0e\u6027\u306b\u512a\u308c\u3001\u4f4e\u6e29\u3067\u8106\u5316\u3057\u306b\u304f\u3044\u7279\u5fb4\u3092\u6301\u3061\u307e\u3059\u3002C1100\u3068\u7570\u306a\u308a\u6b8b\u7559\u9178\u7d20\u3092\u6b86\u3069\u542b\u307e\u306a\u3044\u305f\u3081\u6c34\u7d20\u8106\u6027\u304c\u7121\u304f\u3001\u6c34\u7d20\u96f0\u56f2\u6c17\u4e0b\u3067\u4f7f\u7528\u53ef\u80fd\u3067\u3059\u3002C1100\u3088\u308a\u9ad8\u4fa1\u3067\u3059\u3002<\/td>\n<td><img decoding=\"async\" class=\"imgCFStyle02_3718\" src=\"\/help\/ja\/wp-content\/uploads\/2025\/10\/3718_13.png\" alt=\"\" \/><\/td>\n<\/tr>\n<tr>\n<td>C1100(\u30bf\u30d5\u30d4\u30c3\u30c1\u9285)<\/td>\n<td class=\"tblFldCFStyle04_3718\">\u7d14\u5ea699.9%\u4ee5\u4e0a\u306e\u7d14\u9285\u3067\u3059\u3002\u5fae\u91cf\u306e\u6b8b\u7559\u9178\u7d20\u3092\u542b\u3080\u305f\u3081\u6c34\u7d20\u8106\u6027\u3092\u6301\u3061\u307e\u3059\u3002C1020\u3088\u308a\u5b89\u4fa1\u3067\u3059\u3002\u5c0e\u96fb\u6027\u30fb\u71b1\u4f1d\u5c0e\u6027\u306b\u512a\u308c\u308b\u305f\u3081\u305f\u3081\u6c34\u7d20\u3092\u542b\u307e\u306a\u3044\u74b0\u5883\u3067\u306e\u96fb\u6975\u30fb\u653e\u71b1\u677f\u7b49\u3078\u306e\u4f7f\u7528\u306b\u9069\u3057\u307e\u3059\u3002<\/td>\n<td><img decoding=\"async\" class=\"imgCFStyle02_3718\" src=\"\/help\/ja\/wp-content\/uploads\/2025\/10\/3718_14.png\" alt=\"\" \/><\/td>\n<\/tr>\n<tr>\n<td>C2801P(\u771f\u936e\u30fb\u9ec4\u9285)<\/td>\n<td class=\"tblFldCFStyle04_3718\" rowspan=\"2\">\u771f\u936e\u3068\u547c\u3070\u308c\u308b\u9285\u3068\u4e9c\u925b\u306e\u5408\u91d1\u3067\u3059\u3002\u7d14\u9285\u3068\u6bd4\u8f03\u3057\u6a5f\u68b0\u7684\u5f37\u5ea6\u304c\u9ad8\u3044\u3067\u3059\u3002\u91d1\u8272\u306e\u5916\u89b3\u3092\u6301\u3061\u3001\u9306\u304c\u767a\u751f\u3057\u3084\u3059\u3044\u3067\u3059\u3002\u8868\u9762\u306b\u9178\u5316\u88ab\u819c\u3092\u5f62\u6210\u3059\u308b\u6027\u8cea\u306b\u3088\u308a\u9ad8\u3044\u8010\u8150\u98df\u6027\u3092\u6301\u3061\u307e\u3059\u3002<\/td>\n<td><img decoding=\"async\" class=\"imgCFStyle02_3718\" src=\"\/help\/ja\/wp-content\/uploads\/2025\/10\/3718_15.png\" alt=\"\" \/><\/td>\n<\/tr>\n<tr>\n<td>C2801P(\u30b7\u30e0\u7528)<\/td>\n<td rowspan=\"2\"><img decoding=\"async\" class=\"imgCFStyle02_3718\" src=\"\/help\/ja\/wp-content\/uploads\/2025\/09\/3718_12.png\" alt=\"C2801P\u30fbC2680P(\u30b7\u30e0\u7528)\u306e\u5916\u89b3\" \/><\/td>\n<\/tr>\n<tr>\n<td>C2680P(\u30b7\u30e0\u7528)<\/td>\n<td class=\"tblFldCFStyle04_3718\">\u771f\u936e\u3068\u547c\u3070\u308c\u308b\u9285\u3068\u4e9c\u925b\u306e\u5408\u91d1\u3067\u3059\u3002\u7d14\u9285\u3068\u6bd4\u8f03\u3057\u6a5f\u68b0\u7684\u5f37\u5ea6\u304c\u9ad8\u3044\u3067\u3059\u3002C2801\u3088\u308a\u9285\u542b\u6709\u91cf\u306e\u9ad8\u3044\u5206\u3001\u67d4\u3089\u304b\u304f\u5c55\u5ef6\u6027\u306b\u512a\u308c\u3001\u30b7\u30e0\u30d7\u30ec\u30fc\u30c8\u306e\u4e2d\u3067\u3082\u3088\u308a\u8584\u30440.1mm\u4ee5\u4e0b\u306e\u677f\u539a\u3067\u4f7f\u7528\u3055\u308c\u307e\u3059\u3002<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-94e027f tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"94e027f\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\u6750\u8cea\u306e\u7279\u6027\u3000\u203b\u4e0b\u8a18\u7279\u6027\u5024\u306f\u53c2\u8003\u5024\u3067\u3042\u308a\u4fdd\u8a3c\u5024\u3067\u306f\u3042\u308a\u307e\u305b\u3093\n<table class=\"mT0 tableHover tblCFStyle01_3718\">\n<tbody>\n<tr>\n<th class=\"tblRowCFStyle02_3718\">\u6750\u8cea<\/th>\n<th>\n<div>\u5f15\u5f35\u5f37\u3055<\/div>\n(N\/mm2)<\/th>\n<th>\n<div>\u8010\u529b<\/div>\n(N\/mm2)<\/th>\n<th>\n<div>\u7834\u65ad\u4f38\u3073<\/div>\n%<\/th>\n<th>\n<div>\u66f2\u3052\u5f37\u3055<\/div>\n(N\/mm2)<\/th>\n<th>\n<div>\u5727\u7e2e\u5f37\u3055<\/div>\n(N\/mm2)<\/th>\n<th>\n<div>\u964d\u4f0f\u70b9<\/div>\n(N\/mm2)<\/th>\n<th>\n<div>\u30e4\u30f3\u30b0\u7387<\/div>\n(N\/mm2)<\/th>\n<th>\n<div>\u66f2\u3052\u5f3e\u6027\u7387<\/div>\n(N\/mm2)<\/th>\n<th>\u6bd4\u91cd<\/th>\n<th>\n<div>\u5c0e\u96fb\u7387<\/div>\n(S\/m)<\/th>\n<th>\n<div>\u71b1\u4f1d\u5c0e\u7387<\/div>\n(W\/m\u30fbK)<\/th>\n<th>\n<div>\u7dda\u81a8\u5f35\u4fc2\u6570<\/div>\n(\/\u2103)<\/th>\n<\/tr>\n<tr>\n<th>C1020(\u7121\u9178\u7d20\u9285)<\/th>\n<td>195~265<\/td>\n<td>120~185<\/td>\n<td>35\u4ee5\u4e0a<\/td>\n<td>185~257<\/td>\n<td>185~265<\/td>\n<td>\u30fc<\/td>\n<td>1.1\u00d710\u2075<\/td>\n<td>1.1\u00d710\u2075<\/td>\n<td>8.94<\/td>\n<td>5.80\u00d710\u2077<\/td>\n<td>391<\/td>\n<td>17.6\u00d710\u207b\u2076<\/td>\n<\/tr>\n<tr>\n<th>C1100(\u30bf\u30d5\u30d4\u30c3\u30c1\u9285)<\/th>\n<td>195~265<\/td>\n<td>120~185<\/td>\n<td>35\u4ee5\u4e0a<\/td>\n<td>185~257<\/td>\n<td>185~265<\/td>\n<td>\u30fc<\/td>\n<td>1.1\u00d710\u2075<\/td>\n<td>1.1\u00d710\u2075<\/td>\n<td>8.94<\/td>\n<td>5.80\u00d710\u2077<\/td>\n<td>391<\/td>\n<td>17.6\u00d710\u207b\u2076<\/td>\n<\/tr>\n<tr>\n<th>C2680P(\u771f\u936e\u30fb\u9ec4\u9285)<\/th>\n<td>295~390<\/td>\n<td>180~273<\/td>\n<td>35\u4ee5\u4e0a<\/td>\n<td>270~370<\/td>\n<td>280~370<\/td>\n<td>180~273<\/td>\n<td>1.0\u00d710\u2075<\/td>\n<td>1.0\u00d710\u2075<\/td>\n<td>8.47<\/td>\n<td>1.74\u00d710\u2077<\/td>\n<td>184<\/td>\n<td>20.2\u00d710\u207b\u2076<\/td>\n<\/tr>\n<tr>\n<th>C2801P(\u771f\u936e\u30fb\u9ec4\u9285)<\/th>\n<td>355~440<\/td>\n<td>190~287<\/td>\n<td>30\u4ee5\u4e0a<\/td>\n<td>327~418<\/td>\n<td>337~418<\/td>\n<td>190~287<\/td>\n<td>1.0\u00d710\u2075<\/td>\n<td>1.0\u00d710\u2075<\/td>\n<td>8.43<\/td>\n<td>1.62\u00d710\u2077<\/td>\n<td>159<\/td>\n<td>20.8\u00d710\u207b\u2076<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-a7162bf print_block elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"a7162bf\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-aca9f14\" data-id=\"aca9f14\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-a20618e elementor-widget elementor-widget-menu-anchor\" data-id=\"a20618e\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"menu-anchor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t<div class=\"elementor-menu-anchor\" id=\"box5\"><\/div>\n\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-0af5ca9 elementor-widget elementor-widget-heading\" data-id=\"0af5ca9\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h2 class=\"elementor-heading-title elementor-size-default\">\u30e1\u30c3\u30ad\u92fc\u677f<\/h2>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-29ad872 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"29ad872\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p>\u6750\u8cea\u306e\u7279\u5fb4\/\u5916\u89b3<\/p><table class=\"mT0 tableHover\"><tbody><tr><th>\u6750\u8cea<\/th><th class=\"tblRowCFStyle01_3718\">\u7279\u5fb4<\/th><th>\u5916\u89b3<\/th><\/tr><tr><td><ul><li>SECC<\/li><li>(\u96fb\u6c17\u4e9c\u925b\u30e1\u30c3\u30ad\u92fc\u677f)<\/li><\/ul><\/td><td class=\"tblFldCFStyle04_3718\">SECC\u306b\u30e1\u30c3\u30ad\u3092\u65bd\u3057\u305f\u30e1\u30c3\u30ad\u51e6\u7406\u92fc\u677f\u3067\u3059\u3002\u5f8c\u51e6\u7406\u54c1\u306b\u6bd4\u3079\u3066\u77ed\u7d0d\u671f\u3067\u3059\u304c\u3001\u677f\u539a\u9762\u306a\u3069\u306e\u5207\u65ad\u9762\u306b\u306f\u30e1\u30c3\u30ad\u304c\u306a\u3044\u70b9\u306b\u6ce8\u610f\u304c\u5fc5\u8981\u3067\u3059(\u4ed6\u30e1\u30c3\u30ad\u92fc\u677f\u3082\u540c\u69d8)\u3002\u6750\u6599\u306e\u7279\u6027\u4e0a\u8868\u9762\u306b\u82e5\u5e72\u306e\u64e6\u308c\u75d5\u304c\u6b8b\u308a\u307e\u3059\u3002<\/td><td><img decoding=\"async\" class=\"imgCFStyle02_3718\" src=\"\/help\/ja\/wp-content\/uploads\/2020\/01\/spc04_sheet_pic_07.jpg\" alt=\"SECC (\u96fb\u6c17\u4e9c\u925b\u30e1\u30c3\u30ad\u92fc\u677f)\u306e\u5916\u89b3\" \/><\/td><\/tr><tr><td><ul><li>SPCC<\/li><li>(\u6eb6\u878d\u4e9c\u925b\u30e1\u30c3\u30ad\u92fc\u677f)<\/li><\/ul><\/td><td class=\"tblFldCFStyle04_3718\">\u5efa\u6750\u306b\u3082\u4f7f\u7528\u3055\u308c\u308b\u30e1\u30c3\u30ad\u51e6\u7406\u92fc\u677f\u3067\u3059\u3002SPCC(\u6eb6\u878d\u4e9c\u925b\u30e1\u30c3\u30ad\u92fc\u677f)\u306fSECC(\u96fb\u6c17\u4e9c\u925b\u30e1\u30c3\u30ad\u92fc\u677f)\u306b\u6bd4\u3079\u3066\u3082\u30e1\u30c3\u30ad\u539a\u304c\u539a\u3044\u305f\u3081\u3001\u66f4\u306b\u9ad8\u3044\u8010\u98df\u6027\u3092\u6301\u3061\u307e\u3059\u3002<\/td><td><img decoding=\"async\" class=\"imgCFStyle02_3718\" src=\"\/help\/ja\/wp-content\/uploads\/2020\/01\/spc04_sheet_pic_08.jpg\" alt=\"SPCC (\u6eb6\u878d\u4e9c\u925b\u30e1\u30c3\u30ad\u92fc\u677f)\u306e\u5916\u89b3\" \/><\/td><\/tr><tr><td><ul><li>A5052<\/li><li>(\u30a2\u30eb\u30de\u30a4\u30c8\u92fc\u677f\u767d)<\/li><\/ul><\/td><td class=\"tblFldCFStyle04_3718\" rowspan=\"2\">\u8010\u8150\u98df\u6027\u30fb\u8010\u6469\u8017\u6027\u3092\u78ba\u4fdd\u3057\u3064\u3064\u3001\u5f8c\u51e6\u7406\u54c1\u306b\u6bd4\u3079\u5b89\u4fa1\u304b\u3064\u77ed\u7d0d\u671f\u3067\u5165\u624b\u53ef\u80fd\u3067\u3059\u3002\u6750\u6599\u306e\u7279\u6027\u4e0a\u3001\u66f2\u3052\u90e8\u5206\u306b\u30af\u30e9\u30c3\u30af(\u5272\u308c\u76ee)\u304c\u5165\u308a\u3001\u30e1\u30c3\u30ad\u51e6\u7406\u304c\u5265\u304c\u308c\u308b\u53ef\u80fd\u6027\u304c\u3042\u308a\u307e\u3059\u3002<\/td><td><img decoding=\"async\" class=\"imgCFStyle02_3718\" src=\"\/help\/ja\/wp-content\/uploads\/2024\/04\/3718_01.png\" alt=\"A5052 (\u30a2\u30eb\u30de\u30a4\u30c8\u92fc\u677f\u767d) \u306e\u5916\u89b3\" \/><\/td><\/tr><tr><td><ul><li>A5052<\/li><li>(\u30a2\u30eb\u30de\u30a4\u30c8\u92fc\u677f\u9ed2)<\/li><\/ul><\/td><td><img decoding=\"async\" class=\"imgCFStyle02_3718\" src=\"\/help\/ja\/wp-content\/uploads\/2024\/04\/3718_02.png\" alt=\"A5052 (\u30a2\u30eb\u30de\u30a4\u30c8\u92fc\u677f\u9ed2)\u306e\u5916\u89b3\" \/><\/td><\/tr><\/tbody><\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-a65cddc print_block elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"a65cddc\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-ef2dcfd\" data-id=\"ef2dcfd\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-9d7fe18 elementor-widget elementor-widget-menu-anchor\" data-id=\"9d7fe18\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"menu-anchor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t<div class=\"elementor-menu-anchor\" id=\"box6\"><\/div>\n\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-f273b4c elementor-widget elementor-widget-heading\" data-id=\"f273b4c\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h2 class=\"elementor-heading-title elementor-size-default\">\u30d1\u30f3\u30c1\u30f3\u30b0\u30e1\u30bf\u30eb<\/h2>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-3bfe179 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"3bfe179\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\u6750\u8cea\u306e\u7279\u5fb4\/\u5916\u89b3\n<table class=\"mT0 tableHover\">\n<tbody>\n<tr>\n<th>\u6750\u8cea<\/th>\n<th class=\"tblRowCFStyle01_3718\">\u7279\u5fb4<\/th>\n<th>\u5916\u89b3<\/th>\n<\/tr>\n<tr>\n<td>\u30d1\u30f3\u30c1\u30f3\u30b0\u30e1\u30bf\u30eb<div>\uff08SUS304-BA\uff09<\/div>\u4e38\u5b5460\u00b0\u5343\u9ce5\u30bf\u30a4\u30d7<\/td>\n<td class=\"tblFldCFStyle04_3718\">\u901a\u6c17\u30ab\u30d0\u30fc\u3084\u30d5\u30a3\u30eb\u30bf\u30fc\u306a\u3069\u5e45\u5e83\u304f\u4f7f\u7528\u3055\u308c\u308b\u30d1\u30f3\u30c1\u30f3\u30b0\u30e1\u30bf\u30eb\u92fc\u677f\u3067\u3059\u3002\u4e00\u822c\u92fc\u6750\u4e0a\u306b\u5b54\u5f62\u72b6\u30fb\u30d1\u30bf\u30fc\u30f3\u3092\u52a0\u5de5\u3059\u308b\u3088\u308a\u5b89\u4fa1\u306b\u5165\u624b\u53ef\u80fd\u3067\u3059\u3002\u51fa\u8377\u6642\u306f\u53cd\u308a\u77ef\u6b63\u52a0\u5de5\u3092\u884c\u3044\u307e\u3059\u304c\u3001\u6750\u6599\u7279\u6027\u4e0a\u3001\u82e5\u5e72\u306e\u6b6a\u307f\u304c\u6b8b\u308a\u307e\u3059\u3002\u5b54\u5f84\u3068\u30d4\u30c3\u30c1\u306e\u30d1\u30bf\u30fc\u30f3\u3067\u4ee5\u4e0b5\u7a2e\u304b\u3089\u9078\u629e\u3067\u304d\u307e\u3059\u3002\n<ul>\n \t<li>\u00f81 \u00d7 2p<\/li>\n \t<li>\u00f82 \u00d7 3p<\/li>\n \t<li>\u00f83 \u00d7 5p<\/li>\n \t<li>\u00f85 \u00d7 8p<\/li>\n \t<li>\u00f88 \u00d7 12p<\/li>\n<\/ul>\n<\/td>\n<td><img decoding=\"async\" class=\"imgCFStyle02_3718\" src=\"\/help\/ja\/wp-content\/uploads\/2020\/01\/spc04_sheet_pic_17.jpg\" alt=\"\u30d1\u30f3\u30c1\u30f3\u30b0\u30e1\u30bf\u30eb \uff08SUS304-BA\uff09 \u4e38\u5b5460\u00b0\u5343\u9ce5\u30bf\u30a4\u30d7\u306e\u5916\u89b3\" \/><\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-065b9a3 print_block elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"065b9a3\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-109223a\" data-id=\"109223a\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-251a326 elementor-widget elementor-widget-menu-anchor\" data-id=\"251a326\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"menu-anchor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t<div class=\"elementor-menu-anchor\" id=\"box7\"><\/div>\n\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-bb743b1 elementor-widget elementor-widget-heading\" data-id=\"bb743b1\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h2 class=\"elementor-heading-title elementor-size-default\">\u900f\u660e\u6a39\u8102\u30d7\u30ec\u30fc\u30c8\n<\/h2>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-2c6a696 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"2c6a696\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\u6750\u8cea\u306e\u7279\u5fb4\/\u5916\u89b3\n<table class=\"mT0 tableHover\">\n<tbody>\n<tr>\n<th>\u6750\u8cea<\/th>\n<th class=\"tblRowCFStyle01_3718\">\u7279\u5fb4<\/th>\n<th>\u5916\u89b3<\/th>\n<\/tr>\n<tr>\n<td>PET (\u30dd\u30ea\u30a8\u30c1\u30ec\u30f3\u30c6\u30ec\u30d5\u30bf\u30ec\u30fc\u30c8)<\/td>\n<td class=\"tblFldCFStyle04_3718\">\u900f\u904e\u7387\u306e\u7570\u306a\u308b2\u8272\u3001\u304a\u3088\u3073\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\/\u5236\u96fb\u30b0\u30ec\u30fc\u30c9\u304c\u9078\u629e\u53ef\u80fd\u3067\u3059\u3002\u30b3\u30b9\u30c8\u3092\u6291\u3048\u3064\u3064\u3082\u8010\u85ac\u54c1\u6027\u30fb\u8010\u6c34\u6027\u30fb\u96fb\u6c17\u7d76\u7e01\u6027\u306b\u512a\u308c\u307e\u3059\u3002\u900f\u904e\u7387\u304c\u9ad8\u304f\u3001\u98df\u54c1\u5bb9\u5668\u3001\u5149\u5b66\u30d5\u30a3\u30eb\u30e0\u3001\u7d76\u7e01\u6750\u306b\u4f7f\u7528\u3055\u308c\u307e\u3059\u3002\u52a0\u5de5\u6027\u3082\u826f\u597d\u3067\u3059\u3002<\/td>\n<td><img decoding=\"async\" class=\"imgCFStyle02_3718\" src=\"\/help\/ja\/wp-content\/uploads\/2025\/08\/3718_07.png\" alt=\"PET (\u30dd\u30ea\u30a8\u30c1\u30ec\u30f3\u30c6\u30ec\u30d5\u30bf\u30ec\u30fc\u30c8)\u306e\u5916\u89b3\" \/><\/td>\n<\/tr>\n<tr>\n<td>\u30a2\u30af\u30ea\u30eb<\/td>\n<td class=\"tblFldCFStyle04_3718\">\u900f\u904e\u7387\u306e\u7570\u306a\u308b2\u8272\u3001\u304a\u3088\u3073\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\/\u5236\u96fb\u30b0\u30ec\u30fc\u30c9\u304c\u9078\u629e\u53ef\u80fd\u3067\u3059\u3002\u5149\u900f\u904e\u6027\u304c\u975e\u5e38\u306b\u9ad8\u3044\u7279\u6027\u3092\u3082\u3061\u3001\u30c7\u30a3\u30b9\u30d7\u30ec\u30a4\u3001\u7167\u660e\u30ab\u30d0\u30fc\u3001\u30a4\u30f3\u30c6\u30ea\u30a2\u306a\u3069\u306b\u5229\u7528\u3055\u308c\u307e\u3059\u3002\u77f3\u6cb9\u7cfb\u6eb6\u5264\u3084\u30a2\u30eb\u30ab\u30ea\u6027\u306e\u85ac\u54c1\u306b\u5f31\u3044\u70b9\u306b\u6ce8\u610f\u304c\u5fc5\u8981\u3067\u3059\u3002<\/td>\n<td><img decoding=\"async\" class=\"imgCFStyle02_3718\" src=\"\/help\/ja\/wp-content\/uploads\/2025\/08\/3718_08.png\" alt=\"\u30a2\u30af\u30ea\u30eb\u306e\u5916\u89b3\" \/><\/td>\n<\/tr>\n<tr>\n<td>\u30dd\u30ea\u30ab\u30fc\u30dc\u30cd\u30fc\u30c8<\/td>\n<td class=\"tblFldCFStyle04_3718\">\u900f\u904e\u7387\u306e\u7570\u306a\u308b2\u8272\u3001\u304a\u3088\u3073\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\/\u5236\u96fb\u30b0\u30ec\u30fc\u30c9\u304c\u9078\u629e\u53ef\u80fd\u3067\u3059\u3002\u8010\u885d\u6483\u6027\u30fb\u8010\u71b1\u6027\u30fb\u5bf8\u6cd5\u5b89\u5b9a\u6027\u306b\u512a\u308c\u307e\u3059\u3002\u5149\u900f\u904e\u6027\u304c\u9ad8\u304f\u3001\u30ab\u30d0\u30fc\u3084\u7a93\u6750\u3001\u4fdd\u8b77\u30d1\u30cd\u30eb\u306a\u3069\u306b\u4f7f\u7528\u3055\u308c\u307e\u3059\u3002\u5207\u524a\u52a0\u5de5\u6027\u3082\u826f\u597d\u3067\u3001\u6a5f\u68b0\u90e8\u54c1\u306b\u3082\u5229\u7528\u53ef\u80fd\u3067\u3059\u3002<\/td>\n<td><img decoding=\"async\" class=\"imgCFStyle02_3718\" src=\"\/help\/ja\/wp-content\/uploads\/2025\/08\/3718_09.png\" alt=\"\u30dd\u30ea\u30ab\u30fc\u30dc\u30cd\u30fc\u30c8\u306e\u5916\u89b3\" \/><\/td>\n<\/tr>\n<tr>\n<td>\u5869\u30d3 \uff08\u30dd\u30ea\u5869\u5316\u30d3\u30cb\u30eb\uff09<\/td>\n<td class=\"tblFldCFStyle04_3718\">\u900f\u904e\u7387\u306e\u7570\u306a\u308b2\u8272\u3001\u304a\u3088\u3073\u30b9\u30bf\u30f3\u30c0\u30fc\u30c9\/\u5236\u96fb\u30b0\u30ec\u30fc\u30c9\u304c\u9078\u629e\u53ef\u80fd\u3067\u3059\u3002\u8010\u85ac\u54c1\u6027\u30fb\u8010\u6c34\u6027\u30fb\u96fb\u6c17\u7d76\u7e01\u6027\u306b\u512a\u308c\u307e\u3059\u3002\u786c\u8cea\u3067\u5bf8\u6cd5\u5b89\u5b9a\u6027\u304c\u9ad8\u304f\u3001\u914d\u7ba1\u90e8\u54c1\u3001\u7b50\u4f53\u3001\u7d76\u7e01\u6750\u306a\u3069\u306b\u4f7f\u7528\u3055\u308c\u3001\u52a0\u5de5\u6027\u3082\u826f\u597d\u3067\u3059\u3002<\/td>\n<td><img decoding=\"async\" class=\"imgCFStyle02_3718\" src=\"\/help\/ja\/wp-content\/uploads\/2025\/08\/3718_10.png\" alt=\"\u5869\u30d3 \uff08\u30dd\u30ea\u5869\u5316\u30d3\u30cb\u30eb\uff09\u306e\u5916\u89b3\" \/><\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-dd0e3f5 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"dd0e3f5\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\u6750\u8cea\u306e\u7279\u6027\u3000\u203b\u4e0b\u8a18\u7279\u6027\u5024\u306f\u53c2\u8003\u5024\u3067\u3042\u308a\u4fdd\u8a3c\u5024\u3067\u306f\u3042\u308a\u307e\u305b\u3093\n<table class=\"mT0 tableHover tblCFStyle01_3718\">\n<tbody>\n<tr>\n<th>\u6750\u8cea<\/th>\n<th>\n<div>\u5f15\u5f35\u5f37\u3055<\/div>\n(N\/mm2)<\/th>\n<th>\n<div>\u66f2\u3052\u5f37\u3055<\/div>\n(N\/mm2)<\/th>\n<th>\n<div>\u7834\u65ad\u4f38\u3073<\/div>\n%<\/th>\n<th>\n<div>\u30e4\u30f3\u30b0\u7387<\/div>\n(N\/mm2)<\/th>\n<th>\u30ed\u30c3\u30af\u30a6\u30a7\u30eb\u786c\u3055<\/th>\n<th>\u6bd4\u91cd<\/th>\n<th>\n<div>\u9023\u7d9a\u4f7f\u7528\u6e29\u5ea6<\/div>\n\u2103<\/th>\n<\/tr>\n<tr>\n<th>PET (\u30dd\u30ea\u30a8\u30c1\u30ec\u30f3\u30c6\u30ec\u30d5\u30bf\u30ec\u30fc\u30c8)<\/th>\n<td>55~65<\/td>\n<td>80~100<\/td>\n<td>50~100<\/td>\n<td>2900<\/td>\n<td>M80~M90<\/td>\n<td>1.38<\/td>\n<td>80~100<\/td>\n<\/tr>\n<tr>\n<th>\u30a2\u30af\u30ea\u30eb<\/th>\n<td>65~75<\/td>\n<td>90~120<\/td>\n<td>2~7<\/td>\n<td>3000<\/td>\n<td>M85~M100<\/td>\n<td>1.19<\/td>\n<td>70~90<\/td>\n<\/tr>\n<tr>\n<th>\u30dd\u30ea\u30ab\u30fc\u30dc\u30cd\u30fc\u30c8<\/th>\n<td>60~70<\/td>\n<td>80~95<\/td>\n<td>90~120<\/td>\n<td>2400<\/td>\n<td>M70~M80<\/td>\n<td>1.2<\/td>\n<td>100~120<\/td>\n<\/tr>\n<tr>\n<th>\u5869\u30d3 \uff08\u30dd\u30ea\u5869\u5316\u30d3\u30cb\u30eb\uff09<\/th>\n<td>45~55<\/td>\n<td>70~90<\/td>\n<td>20~40<\/td>\n<td>2800<\/td>\n<td>R110~R120<\/td>\n<td>1.4<\/td>\n<td>50~70<\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-256280a print_block elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"256280a\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-9a0e3f2\" data-id=\"9a0e3f2\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-e5c1203 elementor-widget elementor-widget-menu-anchor\" data-id=\"e5c1203\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"menu-anchor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t<div class=\"elementor-menu-anchor\" id=\"box8\"><\/div>\n\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-f85f0a3 elementor-widget elementor-widget-heading\" data-id=\"f85f0a3\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h2 class=\"elementor-heading-title elementor-size-default\">\u8907\u5408\u677f<\/h2>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-2096872 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"2096872\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\u6750\u8cea\u306e\u7279\u5fb4\/\u5916\u89b3\n<table class=\"mT0 tableHover\">\n<tbody>\n<tr>\n<th>\u6750\u8cea<\/th>\n<th class=\"tblRowCFStyle01_3718\">\u7279\u5fb4<\/th>\n<th>\u5916\u89b3<\/th>\n<\/tr>\n<tr>\n<td>\u30a2\u30eb\u30df\u8907\u5408\u677f \u2013 \u30b7\u30eb\u30d0\u30fc<\/td>\n<td class=\"tblFldCFStyle04_3718\" rowspan=\"3\">\u30a2\u30eb\u30df\u30cb\u30a6\u30e0\uff0b\u767a\u6ce1\u30dd\u30ea\u30a8\u30c1\u30ec\u30f3\u6a39\u8102\uff0b\u30a2\u30eb\u30df\u30cb\u30a6\u30e0\u306e\u30b5\u30f3\u30c9\u30a4\u30c3\u30c1\u69cb\u9020\u3067\u8868\u9762\u6750\u304c\u8584\u3044\u305f\u3081\u3001\u91d1\u5c5e\u3088\u308a\u8efd\u91cf\u3067\u6a39\u8102\u3088\u308a\u525b\u6027\u304c\u512a\u308c\u3066\u3044\u307e\u3059\u3002\u6750\u6599\u306e\u7279\u6027\u4e0a\u3001\u8868\u9762\u6750\u306e\u91d1\u5c5e\u304c\u92ed\u5229\u306b\u306a\u308b\u6050\u308c\u304c\u3042\u308a\u307e\u3059\u3002<\/td>\n<td><img decoding=\"async\" class=\"imgCFStyle02_3718\" src=\"\/help\/ja\/wp-content\/uploads\/2025\/01\/3718_03.png\" alt=\"\u30a2\u30eb\u30df\u8907\u5408\u677f \u2013 \u30b7\u30eb\u30d0\u30fc\u306e\u5916\u89b3\" \/><\/td>\n<\/tr>\n<tr>\n<td>\u30a2\u30eb\u30df\u8907\u5408\u677f \u2013 \u3064\u3084\u6d88\u3057\u30b7\u30eb\u30d0\u30fc<\/td>\n<td><img decoding=\"async\" class=\"imgCFStyle02_3718\" src=\"\/help\/ja\/wp-content\/uploads\/2025\/01\/3718_04.png\" alt=\"\u30a2\u30eb\u30df\u8907\u5408\u677f \u2013 \u3064\u3084\u6d88\u3057\u30b7\u30eb\u30d0\u30fc\u306e\u5916\u89b3\" \/><\/td>\n<\/tr>\n<tr>\n<td>\u30a2\u30eb\u30df\u8907\u5408\u677f \u2013 \u9ed2<\/td>\n<td><img decoding=\"async\" class=\"imgCFStyle02_3718\" src=\"\/help\/ja\/wp-content\/uploads\/2025\/01\/3718_05.png\" alt=\"\u30a2\u30eb\u30df\u8907\u5408\u677f \u2013 \u9ed2\u306e\u5916\u89b3\" \/><\/td>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<\/div>\n\t\t\n\t\t\t<div id=\"daexthefu-container\"\n\t\t\t\tclass=\"daexthefu-container daexthefu-layout-stacked daexthefu-alignment-left\"\n\t\t\t\tdata-post-id=\"3718\">\n\n\t\t\t\t<div class=\"daexthefu-feedback\">\n\t\t\t\t\t<div class=\"daexthefu-text\">\n\t\t\t\t\t\t<h3 class=\"daexthefu-title\">\u3053\u306e\u8a18\u4e8b\u306f\u53c2\u8003\u306b\u306a\u308a\u307e\u3057\u305f\u304b\uff1f<\/h3>\n\t\t\t\t\t<\/div>\n\t\t\t\t\t<div class=\"daexthefu-buttons-container\">\n\t\t\t\t\t\t<div class=\"daexthefu-buttons\">\n\t\t\t\t\t\t\t\n\t\t\t<button type=\"button\" class=\"daexthefu-yes daexthefu-button daexthefu-button-type-icon-and-text\" data-value=\"1\">\n\t\t\t\t<span class=\"daexthefu-button-icon\">\n\t\t\t\t\n                <svg>\n                    <defs>\n                        <style>.thumb-up-cls-1{fill:#c9c9c9;}.thumb-up-cls-2{fill:#e1e1e1;}.thumb-up-cls-3{fill:#676767;}<\/style>\n                    <\/defs>\n                    <g id=\"thumb_up\">\n                        <path class=\"thumb-up-cls-2 daexthefu-icon-circle\" d=\"m24,3c11.58,0,21,9.42,21,21s-9.42,21-21,21S3,35.58,3,24,12.42,3,24,3m0-1C11.85,2,2,11.85,2,24s9.85,22,22,22,22-9.85,22-22S36.15,2,24,2h0Z\" \/>\n                        <g>\n                            <rect class=\"thumb-up-cls-3 daexthefu-icon-secondary-color\" x=\"10\" y=\"20\" width=\"6\" height=\"15\" rx=\"1.5\" ry=\"1.5\" \/>\n                            <path class=\"thumb-up-cls-1 daexthefu-icon-primary-color\" d=\"m30.57,9.06l-.49-.1c-.81-.17-1.61.35-1.78,1.16l-5.3,11.74c-.17.81,3.16,1.61,3.97,1.78l1.96.41c.81.17,1.61-.35,1.78-1.16l2.18-10.27c.34-1.61-.7-3.21-2.31-3.56Z\" \/>\n                            <path class=\"thumb-up-cls-1 daexthefu-icon-primary-color\" d=\"m38.17,20h-18.67c-.83,0-1.5.67-1.5,1.5v12c0,.83.67,1.5,1.5,1.5h16.27c.71,0,1.33-.5,1.47-1.21l2.4-12c.19-.93-.53-1.8-1.47-1.8Z\" \/>\n                        <\/g>\n                    <\/g>\n                <\/svg>\t\t\t\t\t\t<\/span>\n\t\t\t\t<span class=\"daexthefu-button-text\">\u5f79\u306b\u7acb\u3063\u305f\uff01<\/span>\n\t\t\t<\/button>\n\n\t\t\t\t\t\t\t\t\t\t\n\t\t\t<button type=\"button\" class=\"daexthefu-no daexthefu-button daexthefu-button-type-icon-and-text\" data-value=\"0\">\n\t\t\t\t<span class=\"daexthefu-button-icon\">\n\t\t\t\t\n                <svg>\n                    <defs>\n                        <style>.thumb-down-cls-1{fill:#c9c9c9;}.thumb-down-cls-2{fill:#e1e1e1;}.thumb-down-cls-3{fill:#676767;}<\/style>\n                    <\/defs>\n                    <g id=\"thumb_down\">\n                        <path class=\"thumb-down-cls-2 daexthefu-icon-circle\" d=\"m24,3c11.58,0,21,9.42,21,21s-9.42,21-21,21S3,35.58,3,24,12.42,3,24,3m0-1C11.85,2,2,11.85,2,24s9.85,22,22,22,22-9.85,22-22S36.15,2,24,2h0Z\" \/>\n                        <g>\n                            <rect class=\"thumb-down-cls-3 daexthefu-icon-secondary-color\" x=\"10\" y=\"13\" width=\"6\" height=\"15\" rx=\"1.5\" ry=\"1.5\" \/>\n                            <path class=\"thumb-down-cls-1 daexthefu-icon-primary-color\" d=\"m30.57,38.94l-.49.1c-.81.17-1.61-.35-1.78-1.16l-5.3-11.74c-.17-.81,3.16-1.61,3.97-1.78l1.96-.41c.81-.17,1.61.35,1.78,1.16l2.18,10.27c.34,1.61-.7,3.21-2.31,3.56Z\" \/>\n                            <path class=\"thumb-down-cls-1 daexthefu-icon-primary-color\" d=\"m38.17,28h-18.67c-.83,0-1.5-.67-1.5-1.5v-12c0-.83.67-1.5,1.5-1.5h16.27c.71,0,1.33.5,1.47,1.21l2.4,12c.19.93-.53,1.8-1.47,1.8Z\" \/>\n                        <\/g>\n                    <\/g>\n                <\/svg>\t\t\t\t\t\t<\/span>\n\t\t\t\t<span class=\"daexthefu-button-text\">\u5f79\u306b\u7acb\u305f\u306a\u304b\u3063\u305f<\/span>\n\t\t\t<\/button>\n\n\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\n\t\t\t\t<div class=\"daexthefu-comment\">\n\t\t\t\t\t<div class=\"daexthefu-comment-top-container\">\n\t\t\t\t\t\t<label id=\"daexthefu-comment-label\" class=\"daexthefu-comment-label\"><\/label>\n\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t\t<textarea id=\"daexthefu-comment-textarea\" class=\"daexthefu-comment-textarea\"\n\t\t\t\t\t\t\t\tplaceholder=\"\"\n\t\t\t\t\t\t\t\tmaxlength=\"\n\t\t\t\t\t\t\t\t400\t\t\t\t\t\t\t\t\t\"><\/textarea>\n\t\t\t\t\t<div class=\"daexthefu-comment-buttons-container\">\n\t\t\t\t\t\t<button class=\"daexthefu-comment-submit daexthefu-button\">\u9001\u4fe1<\/button>\n\t\t\t\t\t\t<button class=\"daexthefu-comment-cancel daexthefu-button\">\u53d6\u6d88<\/button>\n\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\n\t\t\t\t<div class=\"daexthefu-successful-submission-text\">\u8a55\u4fa1\u3044\u305f\u3060\u304d\u3042\u308a\u304c\u3068\u3046\u3054\u3056\u3044\u307e\u3057\u305f\u3002<\/div>\n\n\t\t\t<\/div>\n\n\t\t\t","protected":false},"excerpt":{"rendered":"<p>\u9244 \u30b9\u30c6\u30f3\u30ec\u30b9 \u30a2\u30eb\u30df\u30cb\u30a6\u30e0 \u9285\u30fb\u771f\u936e \u30e1\u30c3\u30ad\u92fc\u677f \u30d1\u30f3\u30c1\u30f3\u30b0\u30e1\u30bf\u30eb \u900f\u660e\u6a39\u8102\u30d7\u30ec\u30fc\u30c8 \u8907\u5408\u677f \u9244 \u6750\u8cea\u306e\u7279\u5fb4\/\u5916\u89b3 \u6750\u8cea \u7279\u5fb4 \u5916\u89b3 SPCC SPCC(\u30b7\u30e0\u7528) \u4e00\u822c\u30d7\u30ec\u30b9\u677f\u91d1\u5411\u3051\u306e\u51b7\u9593\u5727\u5ef6\u92fc\u677f\u3067\u3059\u3002 \u5bf8\u6cd5\u7cbe\u5ea6\u304c\u9ad8\u304f [&hellip;]<\/p>\n","protected":false},"author":15,"featured_media":0,"comment_status":"closed","ping_status":"closed","sticky":false,"template":"","format":"standard","meta":{"_helpful_status":1,"footnotes":""},"categories":[50],"tags":[64],"class_list":["post-3718","post","type-post","status-publish","format-standard","hentry","category-shm_shape-material","tag-technical_shm"],"yoast_head":"<!-- This site is optimized with the Yoast SEO plugin v28.7 - https:\/\/yoast.com\/product\/yoast-seo-wordpress\/ -->\n<title>\u6750\u6599\u306e\u7279\u6027 | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb<\/title>\n<meta name=\"robots\" content=\"index, follow, max-snippet:-1, max-image-preview:large, max-video-preview:-1\" \/>\n<link rel=\"canonical\" href=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/3718\/\" \/>\n<meta property=\"og:locale\" content=\"ja_JP\" \/>\n<meta property=\"og:type\" content=\"article\" \/>\n<meta property=\"og:title\" content=\"\u6750\u6599\u306e\u7279\u6027 | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\" \/>\n<meta property=\"og:description\" content=\"\u9244 \u30b9\u30c6\u30f3\u30ec\u30b9 \u30a2\u30eb\u30df\u30cb\u30a6\u30e0 \u9285\u30fb\u771f\u936e \u30e1\u30c3\u30ad\u92fc\u677f \u30d1\u30f3\u30c1\u30f3\u30b0\u30e1\u30bf\u30eb \u900f\u660e\u6a39\u8102\u30d7\u30ec\u30fc\u30c8 \u8907\u5408\u677f \u9244 \u6750\u8cea\u306e\u7279\u5fb4\/\u5916\u89b3 \u6750\u8cea \u7279\u5fb4 \u5916\u89b3 SPCC SPCC(\u30b7\u30e0\u7528) \u4e00\u822c\u30d7\u30ec\u30b9\u677f\u91d1\u5411\u3051\u306e\u51b7\u9593\u5727\u5ef6\u92fc\u677f\u3067\u3059\u3002 \u5bf8\u6cd5\u7cbe\u5ea6\u304c\u9ad8\u304f [&hellip;]\" \/>\n<meta property=\"og:url\" content=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/3718\/\" \/>\n<meta property=\"og:site_name\" content=\"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\" \/>\n<meta property=\"article:published_time\" content=\"2025-10-19T15:00:37+00:00\" \/>\n<meta property=\"article:modified_time\" content=\"2026-10-05T01:30:31+00:00\" \/>\n<meta name=\"author\" content=\"\u7f8e\u7d00\" \/>\n<meta name=\"twitter:card\" content=\"summary_large_image\" \/>\n<script type=\"application\/ld+json\" class=\"yoast-schema-graph\">{\"@context\":\"https:\\\/\\\/schema.org\",\"@graph\":[{\"@type\":\"Article\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_shape-material\\\/3718\\\/#article\",\"isPartOf\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_shape-material\\\/3718\\\/\"},\"author\":{\"name\":\"\u7f8e\u7d00\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#\\\/schema\\\/person\\\/6ff70d9094b7fdc810efdfcc2fdb63c5\"},\"headline\":\"\u6750\u6599\u306e\u7279\u6027\",\"datePublished\":\"2025-10-19T15:00:37+00:00\",\"dateModified\":\"2026-10-05T01:30:31+00:00\",\"mainEntityOfPage\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_shape-material\\\/3718\\\/\"},\"wordCount\":167,\"publisher\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#organization\"},\"keywords\":[\"technical_shm\"],\"articleSection\":[\"\u5bfe\u8c61\u90e8\u54c1\\\/\u6750\u6599\"],\"inLanguage\":\"ja\"},{\"@type\":\"WebPage\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_shape-material\\\/3718\\\/\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_shape-material\\\/3718\\\/\",\"name\":\"\u6750\u6599\u306e\u7279\u6027 | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\",\"isPartOf\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#website\"},\"datePublished\":\"2025-10-19T15:00:37+00:00\",\"dateModified\":\"2026-10-05T01:30:31+00:00\",\"breadcrumb\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_shape-material\\\/3718\\\/#breadcrumb\"},\"inLanguage\":\"ja\",\"potentialAction\":[{\"@type\":\"ReadAction\",\"target\":[\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_shape-material\\\/3718\\\/\"]}]},{\"@type\":\"BreadcrumbList\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_shape-material\\\/3718\\\/#breadcrumb\",\"itemListElement\":[{\"@type\":\"ListItem\",\"position\":1,\"name\":\"\u30db\u30fc\u30e0\",\"item\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/\"},{\"@type\":\"ListItem\",\"position\":2,\"name\":\"\u6750\u6599\u306e\u7279\u6027\"}]},{\"@type\":\"WebSite\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#website\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/\",\"name\":\"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\",\"description\":\"\",\"publisher\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#organization\"},\"potentialAction\":[{\"@type\":\"SearchAction\",\"target\":{\"@type\":\"EntryPoint\",\"urlTemplate\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/?s={search_term_string}\"},\"query-input\":{\"@type\":\"PropertyValueSpecification\",\"valueRequired\":true,\"valueName\":\"search_term_string\"}}],\"inLanguage\":\"ja\"},{\"@type\":\"Organization\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#organization\",\"name\":\"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/\",\"logo\":{\"@type\":\"ImageObject\",\"inLanguage\":\"ja\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#\\\/schema\\\/logo\\\/image\\\/\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2019\\\/05\\\/A01-b_b4-1_jpeg.jpg\",\"contentUrl\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2019\\\/05\\\/A01-b_b4-1_jpeg.jpg\",\"width\":260,\"height\":70,\"caption\":\"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df\"},\"image\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#\\\/schema\\\/logo\\\/image\\\/\"}},{\"@type\":\"Person\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#\\\/schema\\\/person\\\/6ff70d9094b7fdc810efdfcc2fdb63c5\",\"name\":\"\u7f8e\u7d00\",\"image\":{\"@type\":\"ImageObject\",\"inLanguage\":\"ja\",\"@id\":\"https:\\\/\\\/secure.gravatar.com\\\/avatar\\\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g\",\"url\":\"https:\\\/\\\/secure.gravatar.com\\\/avatar\\\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g\",\"contentUrl\":\"https:\\\/\\\/secure.gravatar.com\\\/avatar\\\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g\",\"caption\":\"\u7f8e\u7d00\"},\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/author\\\/miki-aa3x-momosemisumi-co-jp\\\/\"}]}<\/script>\n<!-- \/ Yoast SEO plugin. -->","yoast_head_json":{"title":"\u6750\u6599\u306e\u7279\u6027 | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","robots":{"index":"index","follow":"follow","max-snippet":"max-snippet:-1","max-image-preview":"max-image-preview:large","max-video-preview":"max-video-preview:-1"},"canonical":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/3718\/","og_locale":"ja_JP","og_type":"article","og_title":"\u6750\u6599\u306e\u7279\u6027 | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","og_description":"\u9244 \u30b9\u30c6\u30f3\u30ec\u30b9 \u30a2\u30eb\u30df\u30cb\u30a6\u30e0 \u9285\u30fb\u771f\u936e \u30e1\u30c3\u30ad\u92fc\u677f \u30d1\u30f3\u30c1\u30f3\u30b0\u30e1\u30bf\u30eb \u900f\u660e\u6a39\u8102\u30d7\u30ec\u30fc\u30c8 \u8907\u5408\u677f \u9244 \u6750\u8cea\u306e\u7279\u5fb4\/\u5916\u89b3 \u6750\u8cea \u7279\u5fb4 \u5916\u89b3 SPCC SPCC(\u30b7\u30e0\u7528) \u4e00\u822c\u30d7\u30ec\u30b9\u677f\u91d1\u5411\u3051\u306e\u51b7\u9593\u5727\u5ef6\u92fc\u677f\u3067\u3059\u3002 \u5bf8\u6cd5\u7cbe\u5ea6\u304c\u9ad8\u304f [&hellip;]","og_url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/3718\/","og_site_name":"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","article_published_time":"2025-10-19T15:00:37+00:00","article_modified_time":"2026-10-05T01:30:31+00:00","author":"\u7f8e\u7d00","twitter_card":"summary_large_image","schema":{"@context":"https:\/\/schema.org","@graph":[{"@type":"Article","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/3718\/#article","isPartOf":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/3718\/"},"author":{"name":"\u7f8e\u7d00","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/person\/6ff70d9094b7fdc810efdfcc2fdb63c5"},"headline":"\u6750\u6599\u306e\u7279\u6027","datePublished":"2025-10-19T15:00:37+00:00","dateModified":"2026-10-05T01:30:31+00:00","mainEntityOfPage":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/3718\/"},"wordCount":167,"publisher":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#organization"},"keywords":["technical_shm"],"articleSection":["\u5bfe\u8c61\u90e8\u54c1\/\u6750\u6599"],"inLanguage":"ja"},{"@type":"WebPage","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/3718\/","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/3718\/","name":"\u6750\u6599\u306e\u7279\u6027 | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","isPartOf":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#website"},"datePublished":"2025-10-19T15:00:37+00:00","dateModified":"2026-10-05T01:30:31+00:00","breadcrumb":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/3718\/#breadcrumb"},"inLanguage":"ja","potentialAction":[{"@type":"ReadAction","target":["https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/3718\/"]}]},{"@type":"BreadcrumbList","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/3718\/#breadcrumb","itemListElement":[{"@type":"ListItem","position":1,"name":"\u30db\u30fc\u30e0","item":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/"},{"@type":"ListItem","position":2,"name":"\u6750\u6599\u306e\u7279\u6027"}]},{"@type":"WebSite","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#website","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/","name":"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","description":"","publisher":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#organization"},"potentialAction":[{"@type":"SearchAction","target":{"@type":"EntryPoint","urlTemplate":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/?s={search_term_string}"},"query-input":{"@type":"PropertyValueSpecification","valueRequired":true,"valueName":"search_term_string"}}],"inLanguage":"ja"},{"@type":"Organization","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#organization","name":"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/","logo":{"@type":"ImageObject","inLanguage":"ja","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/logo\/image\/","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2019\/05\/A01-b_b4-1_jpeg.jpg","contentUrl":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2019\/05\/A01-b_b4-1_jpeg.jpg","width":260,"height":70,"caption":"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df"},"image":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/logo\/image\/"}},{"@type":"Person","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/person\/6ff70d9094b7fdc810efdfcc2fdb63c5","name":"\u7f8e\u7d00","image":{"@type":"ImageObject","inLanguage":"ja","@id":"https:\/\/secure.gravatar.com\/avatar\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g","url":"https:\/\/secure.gravatar.com\/avatar\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g","contentUrl":"https:\/\/secure.gravatar.com\/avatar\/2f44034cd72a74131a332394f8ca1fe64d6c9bba377a8e5634293f66bdada772?s=96&d=mm&r=g","caption":"\u7f8e\u7d00"},"url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/author\/miki-aa3x-momosemisumi-co-jp\/"}]}},"views":45175,"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts\/3718","targetHints":{"allow":["GET"]}}],"collection":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts"}],"about":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/types\/post"}],"author":[{"embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/users\/15"}],"replies":[{"embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/comments?post=3718"}],"version-history":[{"count":60,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts\/3718\/revisions"}],"predecessor-version":[{"id":38023,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts\/3718\/revisions\/38023"}],"wp:attachment":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/media?parent=3718"}],"wp:term":[{"taxonomy":"category","embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/categories?post=3718"},{"taxonomy":"post_tag","embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/tags?post=3718"}],"curies":[{"name":"wp","href":"https:\/\/api.w.org\/{rel}","templated":true}]}}
