{"id":9353,"date":"2026-02-02T00:00:22","date_gmt":"2026-02-01T15:00:22","guid":{"rendered":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/?p=9353"},"modified":"2026-10-05T10:31:08","modified_gmt":"2026-10-05T01:31:08","slug":"r%e6%9b%b2%e3%81%92%e5%bd%a2%e7%8a%b6%e3%81%ae%e5%af%be%e8%b1%a1%e7%af%84%e5%9b%b2","status":"publish","type":"post","link":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/9353\/","title":{"rendered":"R\u66f2\u3052\u5f62\u72b6\u306e\u5bfe\u8c61\u7bc4\u56f2"},"content":{"rendered":"\t\t<div data-elementor-type=\"wp-post\" data-elementor-id=\"9353\" class=\"elementor elementor-9353\">\n\t\t\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-e485c51 print_block elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"e485c51\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-640a3b4\" data-id=\"640a3b4\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-f986aef elementor-widget elementor-widget-heading\" data-id=\"f986aef\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h2 class=\"elementor-heading-title elementor-size-default\">R\u66f2\u3052\u5f62\u72b6\u306e\u5bfe\u8c61\u677f\u539a\u30fbR\u30b5\u30a4\u30ba<\/h2>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-c2dfb4b elementor-widget elementor-widget-text-editor\" data-id=\"c2dfb4b\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<ul>\n \t<li>R\u66f2\u3052\u5f62\u72b6\u306f\u3001\u57fa\u672c\u7684\u306bFR\u66f2\u3052(\u9001\u308a\u66f2\u3052)\u52a0\u5de5\u306b\u3088\u308a\u88fd\u4f5c\u3057\u307e\u3059\u3002\u305d\u306e\u969b\u3001\u66f2\u3052\u90e8\u306b\u306f\u9023\u7d9a\u3057\u305f\u91d1\u578b\u75d5\u304c\u3064\u304d\u307e\u3059\u3002\u8a73\u7d30\u306f\u300c<a href=\"\/help\/ja\/technical_info\/shm_conditions\/3445\/\">\u66f2\u3052\u52a0\u5de5\u4ed5\u69d8<\/a>\u300d\u3092\u3054\u78ba\u8a8d\u4e0b\u3055\u3044\u3002<\/li>\n \t<li>FR\u66f2\u3052\u304c\u56f0\u96e3\u306a\u5834\u5408\u3001\u901a\u5e38\u306e\u66f2\u3052(V\u66f2\u3052)\u3084R\u66f2\u3052\u5c02\u7528\u91d1\u578b\u304c\u4f7f\u7528\u53ef\u80fd\u306a\u5185R\u30b5\u30a4\u30ba\u3092\u63d0\u6848\u3057\u307e\u3059\u3002\u627f\u8afe\u3059\u308b\u3068meviy\u4e0a\u3067R\u30b5\u30a4\u30ba\u3092\u81ea\u52d5\u7684\u306b\u5909\u66f4\u3044\u305f\u3057\u307e\u3059\u3002<\/li>\n \t<li>\u8a73\u7d30\u306f\u4e0b\u8a18R\u30b5\u30a4\u30ba\u306e\u5909\u63db\u30c6\u30fc\u30d6\u30eb\u3092\u53c2\u7167\u304f\u3060\u3055\u3044\u3002<\/li>\n<\/ul>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<section class=\"elementor-section elementor-inner-section elementor-element elementor-element-0834fa6 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"0834fa6\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-6670cd5\" data-id=\"6670cd5\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-97ab03f elementor-widget elementor-widget-heading\" data-id=\"97ab03f\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h5 class=\"elementor-heading-title elementor-size-default\">\u25a0FR\u66f2\u3052\u52a0\u5de5\u304c\u53ef\u80fd\u306a\u5185R\u7bc4\u56f2<\/h5>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-24332ba tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"24332ba\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"mT0 tableHover_single\" style=\"width: 100%;\"><tbody><tr><th>\u677f\u539a<\/th><th>\u6700\u5c0f\u5185R<\/th><th>\u6700\u5927\u5185R<\/th><\/tr><tr><th>0.8<\/th><td>10<\/td><td>150<\/td><\/tr><tr><th>1.0<\/th><td>10<\/td><td>150<\/td><\/tr><tr><th>1.2<\/th><td>10<\/td><td>150<\/td><\/tr><tr><th>1.5<\/th><td>10<\/td><td>150<\/td><\/tr><tr><th>1.6<\/th><td>10<\/td><td>150<\/td><\/tr><tr><th>2.0<\/th><td>10 \u203b<\/td><td>150<\/td><\/tr><tr><th>2.3<\/th><td>15<\/td><td>150<\/td><\/tr><tr><th>2.5<\/th><td>10<\/td><td>150<\/td><\/tr><tr><th>3.0<\/th><td>30<\/td><td>150<\/td><\/tr><tr><th>3.2<\/th><td>30<\/td><td>150<\/td><\/tr><\/tbody><\/table><p>\u203b\u9244\u6750\u306f\u6700\u5c0f\u5185R15\u3068\u306a\u308a\u307e\u3059\u3002<\/p>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-7f8c6d9\" data-id=\"7f8c6d9\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-e81b1b6 elementor-widget__width-initial elementor-widget elementor-widget-image\" data-id=\"e81b1b6\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img fetchpriority=\"high\" decoding=\"async\" width=\"360\" height=\"174\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/09\/9353_01.png\" class=\"attachment-full size-full wp-image-10770\" alt=\"\" srcset=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/09\/9353_01.png 360w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/09\/9353_01-300x145.png 300w\" sizes=\"(max-width: 360px) 100vw, 360px\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-inner-section elementor-element elementor-element-3176f14 print_page elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"3176f14\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-ece4c06\" data-id=\"ece4c06\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-f5a7785 elementor-widget elementor-widget-heading\" data-id=\"f5a7785\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h5 class=\"elementor-heading-title elementor-size-default\">\u25a0FR\u66f2\u3052\u304c\u52a0\u5de5\u3067\u304d\u306a\u3044\u5834\u5408\u306eR\u30b5\u30a4\u30ba\u5909\u63db\u30c6\u30fc\u30d6\u30eb<\/h5>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-891c132 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"891c132\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"mT0 tableHover_single\" style=\"width: 100%;\"><tbody><tr><th>\u5909\u63db\u524d\u306e\u5185R\u30b5\u30a4\u30ba<\/th><th>\u5909\u63db\u5f8c\u306e\u5185R\u30b5\u30a4\u30ba<\/th><th>\u4f7f\u7528\u3055\u308c\u308b\u66f2\u3052\u52a0\u5de5<\/th><\/tr><tr><th>\u677f\u539a\u306e2\u500d\u4ee5\u5185<\/th><td>\u677f\u539a\uff08\u53c2\u8003\u5024\uff09<\/td><td rowspan=\"2\">\u901a\u5e38\u66f2\u3052\uff08V\u66f2\u3052\uff09<\/td><\/tr><tr><th>R3\u672a\u6e80<\/th><td>\u677f\u539a\uff08\u53c2\u8003\u5024\uff09<\/td><\/tr><tr><th>R3 \u2266 \u5185R \uff1c R6<\/th><td>R3<\/td><td rowspan=\"9\">\u5c02\u7528\u91d1\u578b\u306eR\u66f2\u3052<\/td><\/tr><tr><th>R6 \u2266 \u5185R \uff1c R10<\/th><td>R6<\/td><\/tr><tr><th>R10 \u2266 \u5185R \uff1c R12.5<\/th><td>R10<\/td><\/tr><tr><th>R12.5 \u2266 \u5185R \uff1c R15<\/th><td>R12.5<\/td><\/tr><tr><th>R15 \u2266 \u5185R \uff1c R17.5<\/th><td>R15<\/td><\/tr><tr><th>R17.5 \u2266 \u5185R \uff1c R20<\/th><td>R17.5<\/td><\/tr><tr><th>R20 \u2266 \u5185R \uff1c R22.5<\/th><td>R20<\/td><\/tr><tr><th>R22.5 \u2266 \u5185R \uff1c R25<\/th><td>R22.5<\/td><\/tr><tr><th>R25 \u2266 \u5185R \uff1c R30<\/th><td>R25<\/td><\/tr><tr><th>R30 \u2266 \u5185R<\/th><td><ul><li>\u5bfe\u8c61\u5916\u3000<\/li><li>\u203b\u62c5\u5f53\u8005\u898b\u7a4d\u3082\u308a\u3092\u3054\u4f9d\u983c\u304f\u3060\u3055\u3044<\/li><\/ul><\/td><td>\u30fc<\/td><\/tr><\/tbody><\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t<div class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-2fd054a\" data-id=\"2fd054a\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-fcc202b elementor-widget__width-initial enlarged elementor-widget elementor-widget-image\" data-id=\"fcc202b\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"image.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<img decoding=\"async\" width=\"710\" height=\"400\" src=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2025\/09\/9353_03.png\" class=\"attachment-full size-full wp-image-35118\" alt=\"\" srcset=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2025\/09\/9353_03.png 710w, https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2025\/09\/9353_03-300x169.png 300w\" sizes=\"(max-width: 710px) 100vw, 710px\" \/>\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-f36bba8 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"f36bba8\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-3616371\" data-id=\"3616371\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-d33d522 elementor-widget elementor-widget-heading\" data-id=\"d33d522\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"heading.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t<h2 class=\"elementor-heading-title elementor-size-default\">R\u66f2\u3052\u5f62\u72b6\u306e\u5bfe\u8c61\u6750\u8cea\u30fb\u8868\u9762\u51e6\u7406<\/h2>\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-fbcb343 elementor-widget elementor-widget-text-editor\" data-id=\"fbcb343\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\tR\u66f2\u3052\u52a0\u5de5\u306e\u5bfe\u5fdc\u6750\u8cea\u30fb\u8868\u9762\u51e6\u7406\u306f\u4ee5\u4e0b\u306e\u901a\u308a\u3067\u3059\u3002\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-85dadf5 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"85dadf5\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<p>\u3007\uff1a\u81ea\u52d5\u898b\u7a4d\u53ef\u80fd\u3000\u25b3\uff1a\u62c5\u5f53\u8005\u898b\u7a4d\u53ef\u80fd\u3000\u30fc\uff1a\u5bfe\u8c61\u5916<\/p><table class=\"mT0 table04 tableHover_single\"><tbody><tr><th rowspan=\"2\" width=\"20%\">\u6750\u8cea\uff1a\u9244\u7cfb<\/th><th rowspan=\"2\" width=\"25%\">\u8868\u9762\u51e6\u7406<\/th><th colspan=\"2\">R\u66f2\u3052\u5bfe\u5fdc\u53ef\u5426<\/th><\/tr><tr><th>FR\u66f2\u3052<\/th><th>\u5c02\u7528\u91d1\u578b\u306eR\u66f2\u3052<\/th><\/tr><tr><th rowspan=\"7\">SPCC\/SPHC<\/th><th>\u2013<\/th><td rowspan=\"6\">\u3007<\/td><td rowspan=\"6\">\u3007<\/td><\/tr><tr><th>\u7c89\u4f53\u5857\u88c5<\/th><\/tr><tr><th>\u6eb6\u5264\u5857\u88c5<\/th><\/tr><tr><th>\u7121\u96fb\u89e3\u30cb\u30c3\u30b1\u30eb\u30e1\u30c3\u30ad<\/th><\/tr><tr><th>\u56db\u4e09\u9178\u5316\u9244\u76ae\u819c<\/th><\/tr><tr><th>\u4e09\u4fa1\u30af\u30ed\u30e1\u30fc\u30c8(\u767d)<\/th><\/tr><tr><th>\u4e09\u4fa1\u30af\u30ed\u30e1\u30fc\u30c8(\u9ed2)<\/th><td>\u3007<\/td><td>\u25b3<\/td><\/tr><tr><th>SECC(\u96fb\u6c17\u4e9c\u925b\u30e1\u30c3\u30ad\u92fc\u677f)<\/th><th>\u96fb\u6c17\u4e9c\u925b\u30e1\u30c3\u30ad<\/th><td rowspan=\"2\">\u3007<\/td><td rowspan=\"2\">\u3007<\/td><\/tr><tr><th>SPCC(\u6eb6\u878d\u4e9c\u925b\u30e1\u30c3\u30ad\u92fc\u677f)<\/th><th>\u6eb6\u878d\u4e9c\u925b\u30e1\u30c3\u30ad<\/th><\/tr><\/tbody><\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-3badd28 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"3badd28\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"mT0 table04 tableHover_single\"><tbody><tr><th rowspan=\"2\" width=\"20%\">\u6750\u8cea\uff1a\u30b9\u30c6\u30f3\u30ec\u30b9\u7cfb<\/th><th rowspan=\"2\" width=\"25%\">\u4ed5\u4e0a\u3052\u65b9\u6cd5<\/th><th colspan=\"2\">R\u66f2\u3052\u5bfe\u5fdc\u53ef\u5426<\/th><\/tr><tr><th>FR\u66f2\u3052<\/th><th>\u5c02\u7528\u91d1\u578b\u306eR\u66f2\u3052<\/th><\/tr><tr><th rowspan=\"4\">SUS304<\/th><th>2B<\/th><td>\u3007<\/td><td>\u3007<\/td><\/tr><tr><th><ul><li>2B<\/li><li>\u7247\u9762\u4fdd\u8b77\u30b7\u30fc\u30c8\u4ed8<\/li><\/ul><\/th><td>\u25b3<\/td><td>\u2013<\/td><\/tr><tr><th><ul><li>\u7247\u9762#400\u7814\u78e8\uff08\u4f53\u88c1\u9762\u5074\uff09<\/li><li>\u7247\u9762\u4fdd\u8b77\u30b7\u30fc\u30c8\u4ed8<\/li><\/ul><\/th><td>\u3007<\/td><td>\u3007<\/td><\/tr><tr><th><ul><li>\u7247\u9762\u30d8\u30a2\u30e9\u30a4\u30f3(\u4f53\u88c1\u9762\u5074)<\/li><li>\u7247\u9762\u4fdd\u8b77\u30b7\u30fc\u30c8\u4ed8<\/li><\/ul><\/th><td>\u25b3<\/td><td>\u2013<\/td><\/tr><tr><th>SUS316\/SUS316L<\/th><th>2B<\/th><td>\u25b3<\/td><td>\u2013<\/td><\/tr><tr><th>SUS430<\/th><th>2B<\/th><td>\u3007<\/td><td>\u3007<\/td><\/tr><\/tbody><\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-8d4c7a6 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"8d4c7a6\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"mT0 table04 tableHover_single\" style=\"width: 100%;\">\n<tbody>\n<tr>\n<th rowspan=\"2\" width=\"20%\">\u6750\u8cea\uff1a\u30a2\u30eb\u30df\u30cb\u30a6\u30e0<\/th>\n<th rowspan=\"2\" width=\"25%\">\u8868\u9762\u51e6\u7406<\/th>\n<th colspan=\"2\">R\u66f2\u3052\u5bfe\u5fdc\u53ef\u5426<\/th>\n<\/tr>\n<tr>\n<th>FR\u66f2\u3052<\/th>\n<th>\u5c02\u7528\u91d1\u578b\u306eR\u66f2\u3052<\/th>\n<\/tr>\n<tr>\n<th rowspan=\"5\">A5052<\/th>\n<th>\u2013<\/th>\n<td rowspan=\"7\">\u3007<\/td>\n<td rowspan=\"7\">\u3007<\/td>\n<\/tr>\n<tr>\n<th>\u30a2\u30eb\u30de\u30a4\u30c8\uff08\u767d\uff09<\/th>\n<\/tr>\n<tr>\n<th>\u30a2\u30eb\u30de\u30a4\u30c8\uff08\u9ed2\uff09<\/th>\n<\/tr>\n<tr>\n<th>\u30a2\u30eb\u30de\u30a4\u30c8(\u3064\u3084\u6d88\u3057\u9ed2)<\/th>\n<\/tr>\n<tr>\n<th>\u30a2\u30ed\u30b8\u30f3\u51e6\u7406\u76f8\u5f53(\u4e09\u4fa1\u30af\u30ed\u30e0\u5316\u6210\u51e6\u7406)<\/th>\n<\/tr>\n<tr>\n<th>A5052(\u30a2\u30eb\u30de\u30a4\u30c8\u92fc\u677f\u767d)<\/th>\n<th>\u30a2\u30eb\u30de\u30a4\u30c8(\u767d)<\/th>\n<\/tr>\n<tr>\n<th>A5052(\u30a2\u30eb\u30de\u30a4\u30c8\u92fc\u677f\u9ed2)<\/th>\n<th>\u30a2\u30eb\u30de\u30a4\u30c8(\u9ed2)<\/th>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-38f33d1 tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"38f33d1\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"mT0 table04 tableHover_single\" style=\"width: 100%;\"><tbody><tr><th rowspan=\"2\" width=\"20%\">\u6750\u8cea\uff1a\u9285<\/th><th rowspan=\"2\" width=\"25%\">\u8868\u9762\u51e6\u7406<\/th><th colspan=\"2\">R\u66f2\u3052\u5bfe\u5fdc\u53ef\u5426<\/th><\/tr><tr><th>FR\u66f2\u3052<\/th><th>\u5c02\u7528\u91d1\u578b\u306eR\u66f2\u3052<\/th><\/tr><tr><th>C1020(\u7121\u9178\u7d20\u9285)<\/th><th>\u30fc<\/th><td rowspan=\"3\">\u3007<\/td><td rowspan=\"3\">\u30fc<\/td><\/tr><tr><th>C1100(\u30bf\u30d5\u30d4\u30c3\u30c1\u9285)<\/th><th>\u30fc<\/th><\/tr><tr><th>C2801P(\u771f\u936e\u30fb\u9ec4\u9285)<\/th><th>\u30fc<\/th><\/tr><\/tbody><\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t<div class=\"elementor-element elementor-element-ddfd76d tblBasic elementor-widget elementor-widget-text-editor\" data-id=\"ddfd76d\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<table class=\"mT0 table04 tableHover_single\" style=\"width: 100%;\">\n<tbody>\n<tr>\n<th rowspan=\"2\" width=\"20%\">\u6750\u8cea\uff1a\u30d1\u30f3\u30c1\u30f3\u30b0\u30e1\u30bf\u30eb\u6750<\/th>\n<th rowspan=\"2\" width=\"25%\">\u5b54\u5f84\u00d7\u5b54\u30d4\u30c3\u30c1<\/th>\n<th colspan=\"2\">R\u66f2\u3052\u5bfe\u5fdc\u53ef\u5426<\/th>\n<\/tr>\n<tr>\n<th>FR\u66f2\u3052<\/th>\n<th>\u5c02\u7528\u91d1\u578b\u306eR\u66f2\u3052<\/th>\n<\/tr>\n<tr>\n<th rowspan=\"5\">\u30d1\u30f3\u30c1\u30f3\u30b0\u30e1\u30bf\u30eb\uff08SUS304-BA\uff09<\/th>\n<th>\u00f81 \u00d7 2p<\/th>\n<td rowspan=\"5\">\u3007<\/td>\n<td rowspan=\"5\">\u3007<\/td>\n<\/tr>\n<tr>\n<th>\u00f82 \u00d7 3p<\/th>\n<\/tr>\n<tr>\n<th>\u00f83 \u00d7 5p<\/th>\n<\/tr>\n<tr>\n<th>\u00f85 \u00d7 8p<\/th>\n<\/tr>\n<tr>\n<th>\u00f88 \u00d7 12p<\/th>\n<\/tr>\n<\/tbody>\n<\/table>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<\/div>\n\t\t\n\t\t\t<div id=\"daexthefu-container\"\n\t\t\t\tclass=\"daexthefu-container daexthefu-layout-stacked daexthefu-alignment-left\"\n\t\t\t\tdata-post-id=\"9353\">\n\n\t\t\t\t<div class=\"daexthefu-feedback\">\n\t\t\t\t\t<div class=\"daexthefu-text\">\n\t\t\t\t\t\t<h3 class=\"daexthefu-title\">\u3053\u306e\u8a18\u4e8b\u306f\u53c2\u8003\u306b\u306a\u308a\u307e\u3057\u305f\u304b\uff1f<\/h3>\n\t\t\t\t\t<\/div>\n\t\t\t\t\t<div class=\"daexthefu-buttons-container\">\n\t\t\t\t\t\t<div class=\"daexthefu-buttons\">\n\t\t\t\t\t\t\t\n\t\t\t<button type=\"button\" class=\"daexthefu-yes daexthefu-button daexthefu-button-type-icon-and-text\" data-value=\"1\">\n\t\t\t\t<span class=\"daexthefu-button-icon\">\n\t\t\t\t\n                <svg>\n                    <defs>\n                        <style>.thumb-up-cls-1{fill:#c9c9c9;}.thumb-up-cls-2{fill:#e1e1e1;}.thumb-up-cls-3{fill:#676767;}<\/style>\n                    <\/defs>\n                    <g id=\"thumb_up\">\n                        <path class=\"thumb-up-cls-2 daexthefu-icon-circle\" d=\"m24,3c11.58,0,21,9.42,21,21s-9.42,21-21,21S3,35.58,3,24,12.42,3,24,3m0-1C11.85,2,2,11.85,2,24s9.85,22,22,22,22-9.85,22-22S36.15,2,24,2h0Z\" \/>\n                        <g>\n                            <rect class=\"thumb-up-cls-3 daexthefu-icon-secondary-color\" x=\"10\" y=\"20\" width=\"6\" height=\"15\" rx=\"1.5\" ry=\"1.5\" \/>\n                            <path class=\"thumb-up-cls-1 daexthefu-icon-primary-color\" d=\"m30.57,9.06l-.49-.1c-.81-.17-1.61.35-1.78,1.16l-5.3,11.74c-.17.81,3.16,1.61,3.97,1.78l1.96.41c.81.17,1.61-.35,1.78-1.16l2.18-10.27c.34-1.61-.7-3.21-2.31-3.56Z\" \/>\n                            <path class=\"thumb-up-cls-1 daexthefu-icon-primary-color\" d=\"m38.17,20h-18.67c-.83,0-1.5.67-1.5,1.5v12c0,.83.67,1.5,1.5,1.5h16.27c.71,0,1.33-.5,1.47-1.21l2.4-12c.19-.93-.53-1.8-1.47-1.8Z\" \/>\n                        <\/g>\n                    <\/g>\n                <\/svg>\t\t\t\t\t\t<\/span>\n\t\t\t\t<span class=\"daexthefu-button-text\">\u5f79\u306b\u7acb\u3063\u305f\uff01<\/span>\n\t\t\t<\/button>\n\n\t\t\t\t\t\t\t\t\t\t\n\t\t\t<button type=\"button\" class=\"daexthefu-no daexthefu-button daexthefu-button-type-icon-and-text\" data-value=\"0\">\n\t\t\t\t<span class=\"daexthefu-button-icon\">\n\t\t\t\t\n                <svg>\n                    <defs>\n                        <style>.thumb-down-cls-1{fill:#c9c9c9;}.thumb-down-cls-2{fill:#e1e1e1;}.thumb-down-cls-3{fill:#676767;}<\/style>\n                    <\/defs>\n                    <g id=\"thumb_down\">\n                        <path class=\"thumb-down-cls-2 daexthefu-icon-circle\" d=\"m24,3c11.58,0,21,9.42,21,21s-9.42,21-21,21S3,35.58,3,24,12.42,3,24,3m0-1C11.85,2,2,11.85,2,24s9.85,22,22,22,22-9.85,22-22S36.15,2,24,2h0Z\" \/>\n                        <g>\n                            <rect class=\"thumb-down-cls-3 daexthefu-icon-secondary-color\" x=\"10\" y=\"13\" width=\"6\" height=\"15\" rx=\"1.5\" ry=\"1.5\" \/>\n                            <path class=\"thumb-down-cls-1 daexthefu-icon-primary-color\" d=\"m30.57,38.94l-.49.1c-.81.17-1.61-.35-1.78-1.16l-5.3-11.74c-.17-.81,3.16-1.61,3.97-1.78l1.96-.41c.81-.17,1.61.35,1.78,1.16l2.18,10.27c.34,1.61-.7,3.21-2.31,3.56Z\" \/>\n                            <path class=\"thumb-down-cls-1 daexthefu-icon-primary-color\" d=\"m38.17,28h-18.67c-.83,0-1.5-.67-1.5-1.5v-12c0-.83.67-1.5,1.5-1.5h16.27c.71,0,1.33.5,1.47,1.21l2.4,12c.19.93-.53,1.8-1.47,1.8Z\" \/>\n                        <\/g>\n                    <\/g>\n                <\/svg>\t\t\t\t\t\t<\/span>\n\t\t\t\t<span class=\"daexthefu-button-text\">\u5f79\u306b\u7acb\u305f\u306a\u304b\u3063\u305f<\/span>\n\t\t\t<\/button>\n\n\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\n\t\t\t\t<div class=\"daexthefu-comment\">\n\t\t\t\t\t<div class=\"daexthefu-comment-top-container\">\n\t\t\t\t\t\t<label id=\"daexthefu-comment-label\" class=\"daexthefu-comment-label\"><\/label>\n\t\t\t\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t\t<textarea id=\"daexthefu-comment-textarea\" class=\"daexthefu-comment-textarea\"\n\t\t\t\t\t\t\t\tplaceholder=\"\"\n\t\t\t\t\t\t\t\tmaxlength=\"\n\t\t\t\t\t\t\t\t400\t\t\t\t\t\t\t\t\t\"><\/textarea>\n\t\t\t\t\t<div class=\"daexthefu-comment-buttons-container\">\n\t\t\t\t\t\t<button class=\"daexthefu-comment-submit daexthefu-button\">\u9001\u4fe1<\/button>\n\t\t\t\t\t\t<button class=\"daexthefu-comment-cancel daexthefu-button\">\u53d6\u6d88<\/button>\n\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\n\t\t\t\t<div class=\"daexthefu-successful-submission-text\">\u8a55\u4fa1\u3044\u305f\u3060\u304d\u3042\u308a\u304c\u3068\u3046\u3054\u3056\u3044\u307e\u3057\u305f\u3002<\/div>\n\n\t\t\t<\/div>\n\n\t\t\t","protected":false},"excerpt":{"rendered":"<p>R\u66f2\u3052\u5f62\u72b6\u306e\u5bfe\u8c61\u677f\u539a\u30fbR\u30b5\u30a4\u30ba R\u66f2\u3052\u5f62\u72b6\u306f\u3001\u57fa\u672c\u7684\u306bFR\u66f2\u3052(\u9001\u308a\u66f2\u3052)\u52a0\u5de5\u306b\u3088\u308a\u88fd\u4f5c\u3057\u307e\u3059\u3002\u305d\u306e\u969b\u3001\u66f2\u3052\u90e8\u306b\u306f\u9023\u7d9a\u3057\u305f\u91d1\u578b\u75d5\u304c\u3064\u304d\u307e\u3059\u3002\u8a73\u7d30\u306f\u300c\u66f2\u3052\u52a0\u5de5\u4ed5\u69d8\u300d\u3092\u3054\u78ba\u8a8d\u4e0b\u3055\u3044\u3002 FR\u66f2\u3052\u304c\u56f0\u96e3\u306a\u5834\u5408\u3001\u901a\u5e38\u306e\u66f2\u3052(V\u66f2\u3052 [&hellip;]<\/p>\n","protected":false},"author":20,"featured_media":0,"comment_status":"closed","ping_status":"closed","sticky":false,"template":"","format":"standard","meta":{"_helpful_status":1,"footnotes":""},"categories":[50],"tags":[64],"class_list":["post-9353","post","type-post","status-publish","format-standard","hentry","category-shm_shape-material","tag-technical_shm"],"yoast_head":"<!-- This site is optimized with the Yoast SEO plugin v28.7 - https:\/\/yoast.com\/product\/yoast-seo-wordpress\/ -->\n<title>R\u66f2\u3052\u5f62\u72b6\u306e\u5bfe\u8c61\u7bc4\u56f2 | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb<\/title>\n<meta name=\"robots\" content=\"index, follow, max-snippet:-1, max-image-preview:large, max-video-preview:-1\" \/>\n<link rel=\"canonical\" href=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/9353\/\" \/>\n<meta property=\"og:locale\" content=\"ja_JP\" \/>\n<meta property=\"og:type\" content=\"article\" \/>\n<meta property=\"og:title\" content=\"R\u66f2\u3052\u5f62\u72b6\u306e\u5bfe\u8c61\u7bc4\u56f2 | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\" \/>\n<meta property=\"og:description\" content=\"R\u66f2\u3052\u5f62\u72b6\u306e\u5bfe\u8c61\u677f\u539a\u30fbR\u30b5\u30a4\u30ba R\u66f2\u3052\u5f62\u72b6\u306f\u3001\u57fa\u672c\u7684\u306bFR\u66f2\u3052(\u9001\u308a\u66f2\u3052)\u52a0\u5de5\u306b\u3088\u308a\u88fd\u4f5c\u3057\u307e\u3059\u3002\u305d\u306e\u969b\u3001\u66f2\u3052\u90e8\u306b\u306f\u9023\u7d9a\u3057\u305f\u91d1\u578b\u75d5\u304c\u3064\u304d\u307e\u3059\u3002\u8a73\u7d30\u306f\u300c\u66f2\u3052\u52a0\u5de5\u4ed5\u69d8\u300d\u3092\u3054\u78ba\u8a8d\u4e0b\u3055\u3044\u3002 FR\u66f2\u3052\u304c\u56f0\u96e3\u306a\u5834\u5408\u3001\u901a\u5e38\u306e\u66f2\u3052(V\u66f2\u3052 [&hellip;]\" \/>\n<meta property=\"og:url\" content=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/9353\/\" \/>\n<meta property=\"og:site_name\" content=\"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\" \/>\n<meta property=\"article:published_time\" content=\"2026-02-01T15:00:22+00:00\" \/>\n<meta property=\"article:modified_time\" content=\"2026-10-05T01:31:08+00:00\" \/>\n<meta property=\"og:image\" content=\"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/09\/9353_01.png\" \/>\n\t<meta property=\"og:image:width\" content=\"360\" \/>\n\t<meta property=\"og:image:height\" content=\"174\" \/>\n\t<meta property=\"og:image:type\" content=\"image\/png\" \/>\n<meta name=\"author\" content=\"\u5bae\u539f\u82f1\u53f8\" \/>\n<meta name=\"twitter:card\" content=\"summary_large_image\" \/>\n<script type=\"application\/ld+json\" class=\"yoast-schema-graph\">{\"@context\":\"https:\\\/\\\/schema.org\",\"@graph\":[{\"@type\":\"Article\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_shape-material\\\/9353\\\/#article\",\"isPartOf\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_shape-material\\\/9353\\\/\"},\"author\":{\"name\":\"\u5bae\u539f\u82f1\u53f8\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#\\\/schema\\\/person\\\/998e605f5d18645b449b002ce2f79d07\"},\"headline\":\"R\u66f2\u3052\u5f62\u72b6\u306e\u5bfe\u8c61\u7bc4\u56f2\",\"datePublished\":\"2026-02-01T15:00:22+00:00\",\"dateModified\":\"2026-10-05T01:31:08+00:00\",\"mainEntityOfPage\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_shape-material\\\/9353\\\/\"},\"wordCount\":106,\"publisher\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#organization\"},\"image\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_shape-material\\\/9353\\\/#primaryimage\"},\"thumbnailUrl\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2021\\\/09\\\/9353_01.png\",\"keywords\":[\"technical_shm\"],\"articleSection\":[\"\u5bfe\u8c61\u90e8\u54c1\\\/\u6750\u6599\"],\"inLanguage\":\"ja\"},{\"@type\":\"WebPage\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_shape-material\\\/9353\\\/\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_shape-material\\\/9353\\\/\",\"name\":\"R\u66f2\u3052\u5f62\u72b6\u306e\u5bfe\u8c61\u7bc4\u56f2 | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\",\"isPartOf\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#website\"},\"primaryImageOfPage\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_shape-material\\\/9353\\\/#primaryimage\"},\"image\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_shape-material\\\/9353\\\/#primaryimage\"},\"thumbnailUrl\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2021\\\/09\\\/9353_01.png\",\"datePublished\":\"2026-02-01T15:00:22+00:00\",\"dateModified\":\"2026-10-05T01:31:08+00:00\",\"breadcrumb\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_shape-material\\\/9353\\\/#breadcrumb\"},\"inLanguage\":\"ja\",\"potentialAction\":[{\"@type\":\"ReadAction\",\"target\":[\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_shape-material\\\/9353\\\/\"]}]},{\"@type\":\"ImageObject\",\"inLanguage\":\"ja\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_shape-material\\\/9353\\\/#primaryimage\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2021\\\/09\\\/9353_01.png\",\"contentUrl\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2021\\\/09\\\/9353_01.png\",\"width\":360,\"height\":174},{\"@type\":\"BreadcrumbList\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/technical_info\\\/shm_shape-material\\\/9353\\\/#breadcrumb\",\"itemListElement\":[{\"@type\":\"ListItem\",\"position\":1,\"name\":\"\u30db\u30fc\u30e0\",\"item\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/\"},{\"@type\":\"ListItem\",\"position\":2,\"name\":\"R\u66f2\u3052\u5f62\u72b6\u306e\u5bfe\u8c61\u7bc4\u56f2\"}]},{\"@type\":\"WebSite\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#website\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/\",\"name\":\"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb\",\"description\":\"\",\"publisher\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#organization\"},\"potentialAction\":[{\"@type\":\"SearchAction\",\"target\":{\"@type\":\"EntryPoint\",\"urlTemplate\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/?s={search_term_string}\"},\"query-input\":{\"@type\":\"PropertyValueSpecification\",\"valueRequired\":true,\"valueName\":\"search_term_string\"}}],\"inLanguage\":\"ja\"},{\"@type\":\"Organization\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#organization\",\"name\":\"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/\",\"logo\":{\"@type\":\"ImageObject\",\"inLanguage\":\"ja\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#\\\/schema\\\/logo\\\/image\\\/\",\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2019\\\/05\\\/A01-b_b4-1_jpeg.jpg\",\"contentUrl\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/wp-content\\\/uploads\\\/2019\\\/05\\\/A01-b_b4-1_jpeg.jpg\",\"width\":260,\"height\":70,\"caption\":\"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df\"},\"image\":{\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#\\\/schema\\\/logo\\\/image\\\/\"}},{\"@type\":\"Person\",\"@id\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/#\\\/schema\\\/person\\\/998e605f5d18645b449b002ce2f79d07\",\"name\":\"\u5bae\u539f\u82f1\u53f8\",\"image\":{\"@type\":\"ImageObject\",\"inLanguage\":\"ja\",\"@id\":\"https:\\\/\\\/secure.gravatar.com\\\/avatar\\\/85fc577aa0fea687ad375a038226a98d78d685ba227ab0c7400421819b0afcdd?s=96&d=mm&r=g\",\"url\":\"https:\\\/\\\/secure.gravatar.com\\\/avatar\\\/85fc577aa0fea687ad375a038226a98d78d685ba227ab0c7400421819b0afcdd?s=96&d=mm&r=g\",\"contentUrl\":\"https:\\\/\\\/secure.gravatar.com\\\/avatar\\\/85fc577aa0fea687ad375a038226a98d78d685ba227ab0c7400421819b0afcdd?s=96&d=mm&r=g\",\"caption\":\"\u5bae\u539f\u82f1\u53f8\"},\"url\":\"https:\\\/\\\/jp.meviy.misumi-ec.com\\\/help\\\/ja\\\/author\\\/eiji-shg1-miyaharamisumi-co-jp\\\/\"}]}<\/script>\n<!-- \/ Yoast SEO plugin. -->","yoast_head_json":{"title":"R\u66f2\u3052\u5f62\u72b6\u306e\u5bfe\u8c61\u7bc4\u56f2 | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","robots":{"index":"index","follow":"follow","max-snippet":"max-snippet:-1","max-image-preview":"max-image-preview:large","max-video-preview":"max-video-preview:-1"},"canonical":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/9353\/","og_locale":"ja_JP","og_type":"article","og_title":"R\u66f2\u3052\u5f62\u72b6\u306e\u5bfe\u8c61\u7bc4\u56f2 | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","og_description":"R\u66f2\u3052\u5f62\u72b6\u306e\u5bfe\u8c61\u677f\u539a\u30fbR\u30b5\u30a4\u30ba R\u66f2\u3052\u5f62\u72b6\u306f\u3001\u57fa\u672c\u7684\u306bFR\u66f2\u3052(\u9001\u308a\u66f2\u3052)\u52a0\u5de5\u306b\u3088\u308a\u88fd\u4f5c\u3057\u307e\u3059\u3002\u305d\u306e\u969b\u3001\u66f2\u3052\u90e8\u306b\u306f\u9023\u7d9a\u3057\u305f\u91d1\u578b\u75d5\u304c\u3064\u304d\u307e\u3059\u3002\u8a73\u7d30\u306f\u300c\u66f2\u3052\u52a0\u5de5\u4ed5\u69d8\u300d\u3092\u3054\u78ba\u8a8d\u4e0b\u3055\u3044\u3002 FR\u66f2\u3052\u304c\u56f0\u96e3\u306a\u5834\u5408\u3001\u901a\u5e38\u306e\u66f2\u3052(V\u66f2\u3052 [&hellip;]","og_url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/9353\/","og_site_name":"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","article_published_time":"2026-02-01T15:00:22+00:00","article_modified_time":"2026-10-05T01:31:08+00:00","og_image":[{"width":360,"height":174,"url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/09\/9353_01.png","type":"image\/png"}],"author":"\u5bae\u539f\u82f1\u53f8","twitter_card":"summary_large_image","schema":{"@context":"https:\/\/schema.org","@graph":[{"@type":"Article","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/9353\/#article","isPartOf":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/9353\/"},"author":{"name":"\u5bae\u539f\u82f1\u53f8","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/person\/998e605f5d18645b449b002ce2f79d07"},"headline":"R\u66f2\u3052\u5f62\u72b6\u306e\u5bfe\u8c61\u7bc4\u56f2","datePublished":"2026-02-01T15:00:22+00:00","dateModified":"2026-10-05T01:31:08+00:00","mainEntityOfPage":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/9353\/"},"wordCount":106,"publisher":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#organization"},"image":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/9353\/#primaryimage"},"thumbnailUrl":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/09\/9353_01.png","keywords":["technical_shm"],"articleSection":["\u5bfe\u8c61\u90e8\u54c1\/\u6750\u6599"],"inLanguage":"ja"},{"@type":"WebPage","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/9353\/","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/9353\/","name":"R\u66f2\u3052\u5f62\u72b6\u306e\u5bfe\u8c61\u7bc4\u56f2 | meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","isPartOf":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#website"},"primaryImageOfPage":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/9353\/#primaryimage"},"image":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/9353\/#primaryimage"},"thumbnailUrl":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/09\/9353_01.png","datePublished":"2026-02-01T15:00:22+00:00","dateModified":"2026-10-05T01:31:08+00:00","breadcrumb":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/9353\/#breadcrumb"},"inLanguage":"ja","potentialAction":[{"@type":"ReadAction","target":["https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/9353\/"]}]},{"@type":"ImageObject","inLanguage":"ja","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/9353\/#primaryimage","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/09\/9353_01.png","contentUrl":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2021\/09\/9353_01.png","width":360,"height":174},{"@type":"BreadcrumbList","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/technical_info\/shm_shape-material\/9353\/#breadcrumb","itemListElement":[{"@type":"ListItem","position":1,"name":"\u30db\u30fc\u30e0","item":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/"},{"@type":"ListItem","position":2,"name":"R\u66f2\u3052\u5f62\u72b6\u306e\u5bfe\u8c61\u7bc4\u56f2"}]},{"@type":"WebSite","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#website","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/","name":"meviy\u4f7f\u3044\u65b9\u30de\u30cb\u30e5\u30a2\u30eb","description":"","publisher":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#organization"},"potentialAction":[{"@type":"SearchAction","target":{"@type":"EntryPoint","urlTemplate":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/?s={search_term_string}"},"query-input":{"@type":"PropertyValueSpecification","valueRequired":true,"valueName":"search_term_string"}}],"inLanguage":"ja"},{"@type":"Organization","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#organization","name":"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/","logo":{"@type":"ImageObject","inLanguage":"ja","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/logo\/image\/","url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2019\/05\/A01-b_b4-1_jpeg.jpg","contentUrl":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-content\/uploads\/2019\/05\/A01-b_b4-1_jpeg.jpg","width":260,"height":70,"caption":"\u682a\u5f0f\u4f1a\u793e\u30df\u30b9\u30df"},"image":{"@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/logo\/image\/"}},{"@type":"Person","@id":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/#\/schema\/person\/998e605f5d18645b449b002ce2f79d07","name":"\u5bae\u539f\u82f1\u53f8","image":{"@type":"ImageObject","inLanguage":"ja","@id":"https:\/\/secure.gravatar.com\/avatar\/85fc577aa0fea687ad375a038226a98d78d685ba227ab0c7400421819b0afcdd?s=96&d=mm&r=g","url":"https:\/\/secure.gravatar.com\/avatar\/85fc577aa0fea687ad375a038226a98d78d685ba227ab0c7400421819b0afcdd?s=96&d=mm&r=g","contentUrl":"https:\/\/secure.gravatar.com\/avatar\/85fc577aa0fea687ad375a038226a98d78d685ba227ab0c7400421819b0afcdd?s=96&d=mm&r=g","caption":"\u5bae\u539f\u82f1\u53f8"},"url":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/author\/eiji-shg1-miyaharamisumi-co-jp\/"}]}},"views":30547,"_links":{"self":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts\/9353","targetHints":{"allow":["GET"]}}],"collection":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts"}],"about":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/types\/post"}],"author":[{"embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/users\/20"}],"replies":[{"embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/comments?post=9353"}],"version-history":[{"count":81,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts\/9353\/revisions"}],"predecessor-version":[{"id":38026,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/posts\/9353\/revisions\/38026"}],"wp:attachment":[{"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/media?parent=9353"}],"wp:term":[{"taxonomy":"category","embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/categories?post=9353"},{"taxonomy":"post_tag","embeddable":true,"href":"https:\/\/jp.meviy.misumi-ec.com\/help\/ja\/wp-json\/wp\/v2\/tags?post=9353"}],"curies":[{"name":"wp","href":"https:\/\/api.w.org\/{rel}","templated":true}]}}
